# # ChangeLog for cpukit/aclocal in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/24 12:32:31 Thu, 14 Feb 2013 22:45:23 GMT Ralf Corsépius [390258c] * cpukit/aclocal/check-atomic.m4 (added) New. Thu, 03 May 2012 22:14:47 GMT Joel Sherrill [ae55da72] * cpukit/aclocal/canonicalize-tools.m4 (modified) cpukit/aclocal - Fix one mistake by script Thu, 03 May 2012 15:09:24 GMT Joel Sherrill [9b4422a2] * Makefile.am (modified) * README (modified) * README.configure (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/check-custom-bsp.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rtems-debug.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-smp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/path-ksh.m4 (modified) * aclocal/project-root.m4 (modified) * aclocal/rtems-top.m4 (modified) * automake/host.am (modified) * automake/local.am (modified) * automake/subdirs.am (modified) * c/Makefile.am (modified) * c/acinclude.m4 (modified) * c/configure.ac (modified) * c/src/Makefile.am (modified) * c/src/README (modified) * c/src/acinclude.m4 (modified) * c/src/aclocal/bsp-alias.m4 (modified) * c/src/aclocal/bsp-arg-enable.m4 (modified) * c/src/aclocal/bsp-bootcard-options.m4 (modified) * c/src/aclocal/bsp-bspcleanup-options.m4 (modified) * c/src/aclocal/bsp-configure.m4 (modified) * c/src/aclocal/bsp-linkcmds.m4 (modified) * c/src/aclocal/bspopts.m4 (modified) * c/src/aclocal/canonical-target-name.m4 (modified) * c/src/aclocal/canonicalize-tools.m4 (modified) * c/src/aclocal/check-custom-bsp.m4 (modified) * c/src/aclocal/check-cxx.m4 (modified) * c/src/aclocal/check-multiprocessing.m4 (modified) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/check-posix.m4 (modified) * c/src/aclocal/check-smp.m4 (modified) * c/src/aclocal/check-tool.m4 (modified) * c/src/aclocal/config-subdirs.m4 (modified) * c/src/aclocal/enable-cxx.m4 (modified) * c/src/aclocal/enable-multiprocessing.m4 (modified) * c/src/aclocal/enable-networking.m4 (modified) * c/src/aclocal/enable-posix.m4 (modified) * c/src/aclocal/enable-rtemsbsp.m4 (modified) * c/src/aclocal/enable-smp.m4 (modified) * c/src/aclocal/env-rtemsbsp.m4 (modified) * c/src/aclocal/gcc-isystem.m4 (modified) * c/src/aclocal/gcc-pipe.m4 (modified) * c/src/aclocal/gcc-specs.m4 (modified) * c/src/aclocal/i386-gas-code16.m4 (modified) * c/src/aclocal/path-ksh.m4 (modified) * c/src/aclocal/prog-cc.m4 (modified) * c/src/aclocal/prog-ccas.m4 (modified) * c/src/aclocal/prog-cxx.m4 (modified) * c/src/aclocal/project-root.m4 (modified) * c/src/aclocal/rtems-ampolish.m4 (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/aclocal/target.m4 (modified) * c/src/ada-tests/Makefile.am (modified) * c/src/ada-tests/aclocal/prog-gnat.m4 (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/mptests/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/config_base.h (modified) * c/src/ada-tests/mptests/mp01/mp01.adb (modified) * c/src/ada-tests/mptests/mp01/mptest.adb (modified) * c/src/ada-tests/mptests/mp01/mptest.ads (modified) * c/src/ada-tests/mptests/mp01/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/node1/config.h (modified) * c/src/ada-tests/mptests/mp01/node1/mp01_node1.adb (modified) * c/src/ada-tests/mptests/mp01/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/node2/config.h (modified) * c/src/ada-tests/mptests/mp01/node2/mp01_node2.adb (modified) * c/src/ada-tests/mptests/mp02/Makefile.am (modified) * c/src/ada-tests/mptests/mp02/config_base.h (modified) * c/src/ada-tests/mptests/mp02/mptest.adb (modified) * c/src/ada-tests/mptests/mp02/mptest.ads (modified) * c/src/ada-tests/mptests/mp02/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp02/node1/config.h (modified) * c/src/ada-tests/mptests/mp02/node1/mp02_node1.adb (modified) * c/src/ada-tests/mptests/mp02/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp02/node2/config.h (modified) * c/src/ada-tests/mptests/mp02/node2/mp02_node2.adb (modified) * c/src/ada-tests/mptests/mp03/Makefile.am (modified) * c/src/ada-tests/mptests/mp03/config_base.h (modified) * c/src/ada-tests/mptests/mp03/mptest.adb (modified) * c/src/ada-tests/mptests/mp03/mptest.ads (modified) * c/src/ada-tests/mptests/mp03/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp03/node1/config.h (modified) * c/src/ada-tests/mptests/mp03/node1/mp03_node1.adb (modified) * c/src/ada-tests/mptests/mp03/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp03/node2/config.h (modified) * c/src/ada-tests/mptests/mp03/node2/mp03_node2.adb (modified) * c/src/ada-tests/mptests/mp04/Makefile.am (modified) * c/src/ada-tests/mptests/mp04/config_base.h (modified) * c/src/ada-tests/mptests/mp04/mptest.adb (modified) * c/src/ada-tests/mptests/mp04/mptest.ads (modified) * c/src/ada-tests/mptests/mp04/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp04/node1/config.h (modified) * c/src/ada-tests/mptests/mp04/node1/mp04_node1.adb (modified) * c/src/ada-tests/mptests/mp04/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp04/node2/config.h (modified) * c/src/ada-tests/mptests/mp04/node2/mp04_node2.adb (modified) * c/src/ada-tests/mptests/mp05/Makefile.am (modified) * c/src/ada-tests/mptests/mp05/config_base.h (modified) * c/src/ada-tests/mptests/mp05/mptest.adb (modified) * c/src/ada-tests/mptests/mp05/mptest.ads (modified) * c/src/ada-tests/mptests/mp05/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp05/node1/config.h (modified) * c/src/ada-tests/mptests/mp05/node1/mp05_node1.adb (modified) * c/src/ada-tests/mptests/mp05/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp05/node2/config.h (modified) * c/src/ada-tests/mptests/mp05/node2/mp05_node2.adb (modified) * c/src/ada-tests/mptests/mp06/Makefile.am (modified) * c/src/ada-tests/mptests/mp06/config_base.h (modified) * c/src/ada-tests/mptests/mp06/mptest.adb (modified) * c/src/ada-tests/mptests/mp06/mptest.ads (modified) * c/src/ada-tests/mptests/mp06/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp06/node1/config.h (modified) * c/src/ada-tests/mptests/mp06/node1/mp06_node1.adb (modified) * c/src/ada-tests/mptests/mp06/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp06/node2/config.h (modified) * c/src/ada-tests/mptests/mp06/node2/mp06_node2.adb (modified) * c/src/ada-tests/mptests/mp07/Makefile.am (modified) * c/src/ada-tests/mptests/mp07/config_base.h (modified) * c/src/ada-tests/mptests/mp07/mptest.adb (modified) * c/src/ada-tests/mptests/mp07/mptest.ads (modified) * c/src/ada-tests/mptests/mp07/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp07/node1/config.h (modified) * c/src/ada-tests/mptests/mp07/node1/mp07_node1.adb (modified) * c/src/ada-tests/mptests/mp07/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp07/node2/config.h (modified) * c/src/ada-tests/mptests/mp07/node2/mp07_node2.adb (modified) * c/src/ada-tests/mptests/mp08/Makefile.am (modified) * c/src/ada-tests/mptests/mp08/config_base.h (modified) * c/src/ada-tests/mptests/mp08/mptest.adb (modified) * c/src/ada-tests/mptests/mp08/mptest.ads (modified) * c/src/ada-tests/mptests/mp08/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp08/node1/config.h (modified) * c/src/ada-tests/mptests/mp08/node1/mp08_node1.adb (modified) * c/src/ada-tests/mptests/mp08/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp08/node2/config.h (modified) * c/src/ada-tests/mptests/mp08/node2/mp08_node2.adb (modified) * c/src/ada-tests/mptests/mp09/Makefile.am (modified) * c/src/ada-tests/mptests/mp09/config_base.h (modified) * c/src/ada-tests/mptests/mp09/mptest.adb (modified) * c/src/ada-tests/mptests/mp09/mptest.ads (modified) * c/src/ada-tests/mptests/mp09/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp09/node1/config.h (modified) * c/src/ada-tests/mptests/mp09/node1/mp09_node1.adb (modified) * c/src/ada-tests/mptests/mp09/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp09/node2/config.h (modified) * c/src/ada-tests/mptests/mp09/node2/mp09_node2.adb (modified) * c/src/ada-tests/mptests/mp10/Makefile.am (modified) * c/src/ada-tests/mptests/mp10/config_base.h (modified) * c/src/ada-tests/mptests/mp10/mptest.adb (modified) * c/src/ada-tests/mptests/mp10/mptest.ads (modified) * c/src/ada-tests/mptests/mp10/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp10/node1/config.h (modified) * c/src/ada-tests/mptests/mp10/node1/mp10_node1.adb (modified) * c/src/ada-tests/mptests/mp10/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp10/node2/config.h (modified) * c/src/ada-tests/mptests/mp10/node2/mp10_node2.adb (modified) * c/src/ada-tests/mptests/mp11/Makefile.am (modified) * c/src/ada-tests/mptests/mp11/config_base.h (modified) * c/src/ada-tests/mptests/mp11/mptest.adb (modified) * c/src/ada-tests/mptests/mp11/mptest.ads (modified) * c/src/ada-tests/mptests/mp11/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp11/node1/config.h (modified) * c/src/ada-tests/mptests/mp11/node1/mp11_node1.adb (modified) * c/src/ada-tests/mptests/mp11/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp11/node2/config.h (modified) * c/src/ada-tests/mptests/mp11/node2/mp11_node2.adb (modified) * c/src/ada-tests/mptests/mp12/Makefile.am (modified) * c/src/ada-tests/mptests/mp12/config_base.h (modified) * c/src/ada-tests/mptests/mp12/mptest.adb (modified) * c/src/ada-tests/mptests/mp12/mptest.ads (modified) * c/src/ada-tests/mptests/mp12/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp12/node1/config.h (modified) * c/src/ada-tests/mptests/mp12/node1/mp12_node1.adb (modified) * c/src/ada-tests/mptests/mp12/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp12/node2/config.h (modified) * c/src/ada-tests/mptests/mp12/node2/mp12_node2.adb (modified) * c/src/ada-tests/mptests/mp13/Makefile.am (modified) * c/src/ada-tests/mptests/mp13/config_base.h (modified) * c/src/ada-tests/mptests/mp13/mptest.adb (modified) * c/src/ada-tests/mptests/mp13/mptest.ads (modified) * c/src/ada-tests/mptests/mp13/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp13/node1/config.h (modified) * c/src/ada-tests/mptests/mp13/node1/mp13_node1.adb (modified) * c/src/ada-tests/mptests/mp13/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp13/node2/config.h (modified) * c/src/ada-tests/mptests/mp13/node2/mp13_node2.adb (modified) * c/src/ada-tests/mptests/mp14/Makefile.am (modified) * c/src/ada-tests/mptests/mp14/config_base.h (modified) * c/src/ada-tests/mptests/mp14/mptest.adb (modified) * c/src/ada-tests/mptests/mp14/mptest.ads (modified) * c/src/ada-tests/mptests/mp14/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp14/node1/config.h (modified) * c/src/ada-tests/mptests/mp14/node1/mp14_node1.adb (modified) * c/src/ada-tests/mptests/mp14/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp14/node2/config.h (modified) * c/src/ada-tests/mptests/mp14/node2/mp14_node2.adb (modified) * c/src/ada-tests/samples/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/config.h (modified) * c/src/ada-tests/samples/base_mp/mptest.adb (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) * c/src/ada-tests/samples/base_mp/node1/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (modified) * c/src/ada-tests/samples/base_sp/Makefile.am (modified) * c/src/ada-tests/samples/base_sp/base_sp.adb (modified) * c/src/ada-tests/samples/base_sp/config.h (modified) * c/src/ada-tests/samples/base_sp/sptest.adb (modified) * c/src/ada-tests/samples/base_sp/sptest.ads (modified) * c/src/ada-tests/samples/hello/Makefile.am (modified) * c/src/ada-tests/samples/hello/config.h (modified) * c/src/ada-tests/samples/hello/hello.adb (modified) * c/src/ada-tests/samples/hello/sptest.adb (modified) * c/src/ada-tests/samples/hello/sptest.ads (modified) * c/src/ada-tests/samples/nsecs/Makefile.am (modified) * c/src/ada-tests/samples/nsecs/config.h (modified) * c/src/ada-tests/samples/nsecs/nsecs.adb (modified) * c/src/ada-tests/samples/nsecs/sptest.adb (modified) * c/src/ada-tests/samples/nsecs/sptest.ads (modified) * c/src/ada-tests/samples/ticker/Makefile.am (modified) * c/src/ada-tests/samples/ticker/config.h (modified) * c/src/ada-tests/samples/ticker/sptest.adb (modified) * c/src/ada-tests/samples/ticker/sptest.ads (modified) * c/src/ada-tests/samples/ticker/ticker.adb (modified) * c/src/ada-tests/sptests/Makefile.am (modified) * c/src/ada-tests/sptests/sp01/Makefile.am (modified) * c/src/ada-tests/sptests/sp01/config.h (modified) * c/src/ada-tests/sptests/sp01/sp01.adb (modified) * c/src/ada-tests/sptests/sp01/sptest.adb (modified) * c/src/ada-tests/sptests/sp01/sptest.ads (modified) * c/src/ada-tests/sptests/sp02/Makefile.am (modified) * c/src/ada-tests/sptests/sp02/config.h (modified) * c/src/ada-tests/sptests/sp02/sp02.adb (modified) * c/src/ada-tests/sptests/sp02/sptest.adb (modified) * c/src/ada-tests/sptests/sp02/sptest.ads (modified) * c/src/ada-tests/sptests/sp03/Makefile.am (modified) * c/src/ada-tests/sptests/sp03/config.h (modified) * c/src/ada-tests/sptests/sp03/sp03.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.ads (modified) * c/src/ada-tests/sptests/sp04/Makefile.am (modified) * c/src/ada-tests/sptests/sp04/README (modified) * c/src/ada-tests/sptests/sp04/config.h (modified) * c/src/ada-tests/sptests/sp04/sp04.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.ads (modified) * c/src/ada-tests/sptests/sp05/Makefile.am (modified) * c/src/ada-tests/sptests/sp05/config.h (modified) * c/src/ada-tests/sptests/sp05/sp05.adb (modified) * c/src/ada-tests/sptests/sp05/sptest.adb (modified) * c/src/ada-tests/sptests/sp05/sptest.ads (modified) * c/src/ada-tests/sptests/sp06/Makefile.am (modified) * c/src/ada-tests/sptests/sp06/config.h (modified) * c/src/ada-tests/sptests/sp06/sp06.adb (modified) * c/src/ada-tests/sptests/sp06/sptest.adb (modified) * c/src/ada-tests/sptests/sp06/sptest.ads (modified) * c/src/ada-tests/sptests/sp07/Makefile.am (modified) * c/src/ada-tests/sptests/sp07/config.h (modified) * c/src/ada-tests/sptests/sp07/sp07.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.ads (modified) * c/src/ada-tests/sptests/sp08/Makefile.am (modified) * c/src/ada-tests/sptests/sp08/config.h (modified) * c/src/ada-tests/sptests/sp08/sp08.adb (modified) * c/src/ada-tests/sptests/sp08/sptest.adb (modified) * c/src/ada-tests/sptests/sp08/sptest.ads (modified) * c/src/ada-tests/sptests/sp09/Makefile.am (modified) * c/src/ada-tests/sptests/sp09/config.h (modified) * c/src/ada-tests/sptests/sp09/sp09.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.ads (modified) * c/src/ada-tests/sptests/sp11/Makefile.am (modified) * c/src/ada-tests/sptests/sp11/config.h (modified) * c/src/ada-tests/sptests/sp11/sp11.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.ads (modified) * c/src/ada-tests/sptests/sp12/Makefile.am (modified) * c/src/ada-tests/sptests/sp12/config.h (modified) * c/src/ada-tests/sptests/sp12/sp12.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.ads (modified) * c/src/ada-tests/sptests/sp13/Makefile.am (modified) * c/src/ada-tests/sptests/sp13/config.h (modified) * c/src/ada-tests/sptests/sp13/sp13.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.ads (modified) * c/src/ada-tests/sptests/sp14/Makefile.am (modified) * c/src/ada-tests/sptests/sp14/config.h (modified) * c/src/ada-tests/sptests/sp14/sp14.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.ads (modified) * c/src/ada-tests/sptests/sp15/Makefile.am (modified) * c/src/ada-tests/sptests/sp15/config.h (modified) * c/src/ada-tests/sptests/sp15/sp15.adb (modified) * c/src/ada-tests/sptests/sp15/sptest.adb (modified) * c/src/ada-tests/sptests/sp15/sptest.ads (modified) * c/src/ada-tests/sptests/sp16/Makefile.am (modified) * c/src/ada-tests/sptests/sp16/config.h (modified) * c/src/ada-tests/sptests/sp16/sp16.adb (modified) * c/src/ada-tests/sptests/sp16/sptest.adb (modified) * c/src/ada-tests/sptests/sp16/sptest.ads (modified) * c/src/ada-tests/sptests/sp17/Makefile.am (modified) * c/src/ada-tests/sptests/sp17/config.h (modified) * c/src/ada-tests/sptests/sp17/sp17.adb (modified) * c/src/ada-tests/sptests/sp17/sptest.adb (modified) * c/src/ada-tests/sptests/sp17/sptest.ads (modified) * c/src/ada-tests/sptests/sp19/Makefile.am (modified) * c/src/ada-tests/sptests/sp19/README (modified) * c/src/ada-tests/sptests/sp19/config.h (modified) * c/src/ada-tests/sptests/sp19/sp19.adb (modified) * c/src/ada-tests/sptests/sp19/sptest.adp (modified) * c/src/ada-tests/sptests/sp19/sptest.ads (modified) * c/src/ada-tests/sptests/sp20/Makefile.am (modified) * c/src/ada-tests/sptests/sp20/config.h (modified) * c/src/ada-tests/sptests/sp20/sp20.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.ads (modified) * c/src/ada-tests/sptests/sp22/Makefile.am (modified) * c/src/ada-tests/sptests/sp22/config.h (modified) * c/src/ada-tests/sptests/sp22/sp22.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.ads (modified) * c/src/ada-tests/sptests/sp23/Makefile.am (modified) * c/src/ada-tests/sptests/sp23/config.h (modified) * c/src/ada-tests/sptests/sp23/sp23.adb (modified) * c/src/ada-tests/sptests/sp23/sptest.adb (modified) * c/src/ada-tests/sptests/sp23/sptest.ads (modified) * c/src/ada-tests/sptests/sp24/Makefile.am (modified) * c/src/ada-tests/sptests/sp24/config.h (modified) * c/src/ada-tests/sptests/sp24/sp24.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.ads (modified) * c/src/ada-tests/sptests/sp25/Makefile.am (modified) * c/src/ada-tests/sptests/sp25/config.h (modified) * c/src/ada-tests/sptests/sp25/sp25.adb (modified) * c/src/ada-tests/sptests/sp25/sptest.adb (modified) * c/src/ada-tests/sptests/sp25/sptest.ads (modified) * c/src/ada-tests/sptests/spname01/Makefile.am (modified) * c/src/ada-tests/sptests/spname01/config.h (modified) * c/src/ada-tests/sptests/spname01/spname01.adb (modified) * c/src/ada-tests/sptests/spname01/sptest.adb (modified) * c/src/ada-tests/sptests/spname01/sptest.ads (modified) * c/src/ada-tests/support/Makefile.am (modified) * c/src/ada-tests/support/address_io.adb (modified) * c/src/ada-tests/support/address_io.ads (modified) * c/src/ada-tests/support/float_io.ads (modified) * c/src/ada-tests/support/fp.inc (modified) * c/src/ada-tests/support/init.c (modified) * c/src/ada-tests/support/integer.inc (modified) * c/src/ada-tests/support/rtems_calling_overhead.ads (modified) * c/src/ada-tests/support/status_io.ads (modified) * c/src/ada-tests/support/test_support.adb (modified) * c/src/ada-tests/support/test_support.ads (modified) * c/src/ada-tests/support/time_test_support.adb (modified) * c/src/ada-tests/support/time_test_support.ads (modified) * c/src/ada-tests/support/timer_driver.adb (modified) * c/src/ada-tests/support/timer_driver.ads (modified) * c/src/ada-tests/support/unsigned32_io.ads (modified) * c/src/ada-tests/tmtests/Makefile.am (modified) * c/src/ada-tests/tmtests/tm01/Makefile.am (modified) * c/src/ada-tests/tmtests/tm01/config.h (modified) * c/src/ada-tests/tmtests/tm01/tm01.adb (modified) * c/src/ada-tests/tmtests/tm01/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm01/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm02/Makefile.am (modified) * c/src/ada-tests/tmtests/tm02/config.h (modified) * c/src/ada-tests/tmtests/tm02/tm02.adb (modified) * c/src/ada-tests/tmtests/tm02/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm02/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm03/Makefile.am (modified) * c/src/ada-tests/tmtests/tm03/config.h (modified) * c/src/ada-tests/tmtests/tm03/tm03.adb (modified) * c/src/ada-tests/tmtests/tm03/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm03/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm04/Makefile.am (modified) * c/src/ada-tests/tmtests/tm04/config.h (modified) * c/src/ada-tests/tmtests/tm04/tm04.adb (modified) * c/src/ada-tests/tmtests/tm04/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm04/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm05/Makefile.am (modified) * c/src/ada-tests/tmtests/tm05/config.h (modified) * c/src/ada-tests/tmtests/tm05/tm05.adb (modified) * c/src/ada-tests/tmtests/tm05/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm05/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm06/Makefile.am (modified) * c/src/ada-tests/tmtests/tm06/config.h (modified) * c/src/ada-tests/tmtests/tm06/tm06.adb (modified) * c/src/ada-tests/tmtests/tm06/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm06/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm07/Makefile.am (modified) * c/src/ada-tests/tmtests/tm07/config.h (modified) * c/src/ada-tests/tmtests/tm07/tm07.adb (modified) * c/src/ada-tests/tmtests/tm07/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm07/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm08/Makefile.am (modified) * c/src/ada-tests/tmtests/tm08/config.h (modified) * c/src/ada-tests/tmtests/tm08/tm08.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm09/Makefile.am (modified) * c/src/ada-tests/tmtests/tm09/config.h (modified) * c/src/ada-tests/tmtests/tm09/tm09.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/Makefile.am (modified) * c/src/ada-tests/tmtests/tm10/config.h (modified) * c/src/ada-tests/tmtests/tm10/tm10.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/Makefile.am (modified) * c/src/ada-tests/tmtests/tm11/config.h (modified) * c/src/ada-tests/tmtests/tm11/tm11.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/Makefile.am (modified) * c/src/ada-tests/tmtests/tm12/config.h (modified) * c/src/ada-tests/tmtests/tm12/tm12.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/Makefile.am (modified) * c/src/ada-tests/tmtests/tm13/config.h (modified) * c/src/ada-tests/tmtests/tm13/tm13.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/Makefile.am (modified) * c/src/ada-tests/tmtests/tm14/config.h (modified) * c/src/ada-tests/tmtests/tm14/tm14.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm15/Makefile.am (modified) * c/src/ada-tests/tmtests/tm15/config.h (modified) * c/src/ada-tests/tmtests/tm15/tm15.adb (modified) * c/src/ada-tests/tmtests/tm15/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm16/Makefile.am (modified) * c/src/ada-tests/tmtests/tm16/config.h (modified) * c/src/ada-tests/tmtests/tm16/tm16.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm17/Makefile.am (modified) * c/src/ada-tests/tmtests/tm17/config.h (modified) * c/src/ada-tests/tmtests/tm17/tm17.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm18/Makefile.am (modified) * c/src/ada-tests/tmtests/tm18/config.h (modified) * c/src/ada-tests/tmtests/tm18/tm18.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm19/Makefile.am (modified) * c/src/ada-tests/tmtests/tm19/config.h (modified) * c/src/ada-tests/tmtests/tm19/tm19.adb (modified) * c/src/ada-tests/tmtests/tm19/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm19/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm20/Makefile.am (modified) * c/src/ada-tests/tmtests/tm20/config.h (modified) * c/src/ada-tests/tmtests/tm20/tm20.adb (modified) * c/src/ada-tests/tmtests/tm20/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm21/Makefile.am (modified) * c/src/ada-tests/tmtests/tm21/config.h (modified) * c/src/ada-tests/tmtests/tm21/tm21.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/Makefile.am (modified) * c/src/ada-tests/tmtests/tm22/config.h (modified) * c/src/ada-tests/tmtests/tm22/tm22.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm23/Makefile.am (modified) * c/src/ada-tests/tmtests/tm23/config.h (modified) * c/src/ada-tests/tmtests/tm23/tm23.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm24/Makefile.am (modified) * c/src/ada-tests/tmtests/tm24/config.h (modified) * c/src/ada-tests/tmtests/tm24/tm24.adb (modified) * c/src/ada-tests/tmtests/tm24/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm24/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm25/Makefile.am (modified) * c/src/ada-tests/tmtests/tm25/config.h (modified) * c/src/ada-tests/tmtests/tm25/tm25.adb (modified) * c/src/ada-tests/tmtests/tm25/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm25/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm28/Makefile.am (modified) * c/src/ada-tests/tmtests/tm28/config.h (modified) * c/src/ada-tests/tmtests/tm28/tm28.adb (modified) * c/src/ada-tests/tmtests/tm28/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm28/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm29/Makefile.am (modified) * c/src/ada-tests/tmtests/tm29/config.h (modified) * c/src/ada-tests/tmtests/tm29/tm29.adb (modified) * c/src/ada-tests/tmtests/tm29/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm29/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmck/Makefile.am (modified) * c/src/ada-tests/tmtests/tmck/config.h (modified) * c/src/ada-tests/tmtests/tmck/tmck.adb (modified) * c/src/ada-tests/tmtests/tmck/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmck/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/Makefile.am (modified) * c/src/ada-tests/tmtests/tmoverhd/README (modified) * c/src/ada-tests/tmtests/tmoverhd/config.h (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) * c/src/ada/Makefile.am (modified) * c/src/ada/rtems-barrier.adb (modified) * c/src/ada/rtems-barrier.ads (modified) * c/src/ada/rtems-clock.adb (modified) * c/src/ada/rtems-clock.ads (modified) * c/src/ada/rtems-cpu_usage.ads (modified) * c/src/ada/rtems-debug.adb (modified) * c/src/ada/rtems-debug.ads (modified) * c/src/ada/rtems-event.adb (modified) * c/src/ada/rtems-event.ads (modified) * c/src/ada/rtems-extension.adb (modified) * c/src/ada/rtems-extension.ads (modified) * c/src/ada/rtems-fatal.adb (modified) * c/src/ada/rtems-fatal.ads (modified) * c/src/ada/rtems-interrupt.ads (modified) * c/src/ada/rtems-io.adb (modified) * c/src/ada/rtems-io.ads (modified) * c/src/ada/rtems-message_queue.adb (modified) * c/src/ada/rtems-message_queue.ads (modified) * c/src/ada/rtems-multiprocessing.adb (modified) * c/src/ada/rtems-multiprocessing.ads (modified) * c/src/ada/rtems-object.adb (modified) * c/src/ada/rtems-object.ads (modified) * c/src/ada/rtems-partition.adb (modified) * c/src/ada/rtems-partition.ads (modified) * c/src/ada/rtems-port.adb (modified) * c/src/ada/rtems-port.ads (modified) * c/src/ada/rtems-rate_monotonic.adb (modified) * c/src/ada/rtems-rate_monotonic.ads (modified) * c/src/ada/rtems-region.adb (modified) * c/src/ada/rtems-region.ads (modified) * c/src/ada/rtems-semaphore.adb (modified) * c/src/ada/rtems-semaphore.ads (modified) * c/src/ada/rtems-signal.adb (modified) * c/src/ada/rtems-signal.ads (modified) * c/src/ada/rtems-stack_checker.ads (modified) * c/src/ada/rtems-tasks.adb (modified) * c/src/ada/rtems-tasks.ads (modified) * c/src/ada/rtems-timer.adb (modified) * c/src/ada/rtems-timer.ads (modified) * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * c/src/automake/compile.am (modified) * c/src/automake/host.am (modified) * c/src/automake/local.am (modified) * c/src/automake/subdirs.am (modified) * c/src/configure.ac (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/README (modified) * c/src/lib/libbsp/arm/csb336/README (modified) * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) * c/src/lib/libbsp/arm/csb336/make/custom/csb336.cfg (modified) * c/src/lib/libbsp/arm/csb336/network/lan91c11x.c (modified) * c/src/lib/libbsp/arm/csb336/network/lan91c11x.h (modified) * c/src/lib/libbsp/arm/csb336/network/network.c (modified) * c/src/lib/libbsp/arm/csb336/start/start.S (modified) * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/csb336/startup/memmap.c (modified) * c/src/lib/libbsp/arm/csb337/README (modified) * c/src/lib/libbsp/arm/csb337/README.kit637_v6 (modified) * c/src/lib/libbsp/arm/csb337/console/fbcons.c (modified) * c/src/lib/libbsp/arm/csb337/console/font8x16.h (modified) * c/src/lib/libbsp/arm/csb337/console/sed1356.c (modified) * c/src/lib/libbsp/arm/csb337/console/sed1356_16bit.h (modified) * c/src/lib/libbsp/arm/csb337/console/uarts.c (modified) * c/src/lib/libbsp/arm/csb337/include/bsp.h (modified) * c/src/lib/libbsp/arm/csb337/include/sed1356.h (modified) * c/src/lib/libbsp/arm/csb337/make/custom/csb337.cfg (modified) * c/src/lib/libbsp/arm/csb337/make/custom/csb637.cfg (modified) * c/src/lib/libbsp/arm/csb337/make/custom/kit637_v6.cfg (modified) * c/src/lib/libbsp/arm/csb337/network/network.c (modified) * c/src/lib/libbsp/arm/csb337/start/start.S (modified) * c/src/lib/libbsp/arm/csb337/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/csb337/startup/memmap.c (modified) * c/src/lib/libbsp/arm/csb337/startup/umonsupp.c (modified) * c/src/lib/libbsp/arm/edb7312/README (modified) * c/src/lib/libbsp/arm/edb7312/console/uart.c (modified) * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) * c/src/lib/libbsp/arm/edb7312/include/ep7312.h (modified) * c/src/lib/libbsp/arm/edb7312/irq/bsp_irq_asm.S (modified) * c/src/lib/libbsp/arm/edb7312/irq/irq.c (modified) * c/src/lib/libbsp/arm/edb7312/irq/irq.h (modified) * c/src/lib/libbsp/arm/edb7312/make/custom/edb7312.cfg (modified) * c/src/lib/libbsp/arm/edb7312/start/start.S (modified) * c/src/lib/libbsp/arm/edb7312/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/edb7312/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/edb7312/timer/timer.c (modified) * c/src/lib/libbsp/arm/gba/README (modified) * c/src/lib/libbsp/arm/gba/console/conio.c (modified) * c/src/lib/libbsp/arm/gba/console/console.c (modified) * c/src/lib/libbsp/arm/gba/console/defaultfont.h (modified) * c/src/lib/libbsp/arm/gba/include/arm_mode_bits.h (modified) * c/src/lib/libbsp/arm/gba/include/asm_macros.h (modified) * c/src/lib/libbsp/arm/gba/include/bsp.h (modified) * c/src/lib/libbsp/arm/gba/include/conio.h (modified) * c/src/lib/libbsp/arm/gba/include/gba.h (modified) * c/src/lib/libbsp/arm/gba/include/gba_registers.h (modified) * c/src/lib/libbsp/arm/gba/irq/irq.c (modified) * c/src/lib/libbsp/arm/gba/irq/irq.h (modified) * c/src/lib/libbsp/arm/gba/make/custom/gba.cfg (modified) * c/src/lib/libbsp/arm/gba/start/logo.S (modified) * c/src/lib/libbsp/arm/gba/start/start.S (modified) * c/src/lib/libbsp/arm/gba/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/arm/gba/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/gba/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gba/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gba/timer/timer.c (modified) * c/src/lib/libbsp/arm/gdbarmsim/console/console-io.c (modified) * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) * c/src/lib/libbsp/arm/gdbarmsim/include/swi.h (modified) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136jfs.cfg (modified) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136js.cfg (modified) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm7tdmi.cfg (modified) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm920.cfg (modified) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/armcortexa9.cfg (modified) * c/src/lib/libbsp/arm/gdbarmsim/start/start.S (modified) * c/src/lib/libbsp/arm/gdbarmsim/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/gdbarmsim/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gdbarmsim/startup/syscalls.c (modified) * c/src/lib/libbsp/arm/gp32/console/uart.c (modified) * c/src/lib/libbsp/arm/gp32/make/custom/gp32.cfg (modified) * c/src/lib/libbsp/arm/gp32/start/start.S (modified) * c/src/lib/libbsp/arm/gp32/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/gp32/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gp32/startup/memmap.c (modified) * c/src/lib/libbsp/arm/gumstix/README (modified) * c/src/lib/libbsp/arm/gumstix/console/uarts.c (modified) * c/src/lib/libbsp/arm/gumstix/fb/fb.c (modified) * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) * c/src/lib/libbsp/arm/gumstix/include/tm27.h (modified) * c/src/lib/libbsp/arm/gumstix/make/custom/gumstix.cfg (modified) * c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c (modified) * c/src/lib/libbsp/arm/gumstix/rtl8019/wd80x3.h (modified) * c/src/lib/libbsp/arm/gumstix/start/start.S (modified) * c/src/lib/libbsp/arm/gumstix/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gumstix/startup/memmap.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/console/uart.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965.cfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s69xx.inc (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lpc24xx/README (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc17xx.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc24xx.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/start-config.h (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362.cfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800.cfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx.inc (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_ea.cfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_ncs_ram.cfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_ncs_rom_ext.cfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_ncs_rom_int.cfg (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/restart.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/system-clocks.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/start-config-emc-dynamic.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/start-config-emc-static.c (modified) * c/src/lib/libbsp/arm/lpc32xx/include/tm27.h (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx.inc (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_mzx.cfg (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_mzx_stage_1.cfg (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_mzx_stage_2.cfg (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_phycore.cfg (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/restart.c (modified) * c/src/lib/libbsp/arm/nds/README (modified) * c/src/lib/libbsp/arm/nds/block/block.c (modified) * c/src/lib/libbsp/arm/nds/console/console.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/common/source/spinlock.S (modified) * c/src/lib/libbsp/arm/nds/fb/fb.c (modified) * c/src/lib/libbsp/arm/nds/include/bsp.h (modified) * c/src/lib/libbsp/arm/nds/include/my_ipc.h (modified) * c/src/lib/libbsp/arm/nds/include/types.h (modified) * c/src/lib/libbsp/arm/nds/irq/irq.c (modified) * c/src/lib/libbsp/arm/nds/libnds/include/gbfs.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/audio.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/serial.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/touch.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/boxtest.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/cache.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/console.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/exceptions.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/image.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/input.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/math.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/ndsmotion.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/pcx.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/rumble.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/sound.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/trig_lut.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/video.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/videoGL.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/bios.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/card.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/dma.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/interrupts.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/ipc.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/jtypes.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/registers_alt.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/system.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/timers.h (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/audio.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/clock.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/microphone.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/touch.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/userSettings.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/boxtest.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/console.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/dcache.S (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/exceptionHandler.S (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/exceptions.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/gurumeditation.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/icache.S (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/image.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/keys.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/pcx.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/sound.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/touch.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/videoGL.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/biosCalls.S (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/card.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/gbfs.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/interruptDispatcher.S (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/interrupts.c (modified) * c/src/lib/libbsp/arm/nds/make/custom/nds.cfg (modified) * c/src/lib/libbsp/arm/nds/rtc/rtc.c (modified) * c/src/lib/libbsp/arm/nds/sound/sound.c (modified) * c/src/lib/libbsp/arm/nds/sound/sound.h (modified) * c/src/lib/libbsp/arm/nds/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/nds/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/nds/timer/timer.c (modified) * c/src/lib/libbsp/arm/nds/tools/bin2s.c (modified) * c/src/lib/libbsp/arm/nds/tools/runtest (modified) * c/src/lib/libbsp/arm/nds/touchscreen/parser.c (modified) * c/src/lib/libbsp/arm/nds/touchscreen/reco.c (modified) * c/src/lib/libbsp/arm/nds/touchscreen/touchscreen.c (modified) * c/src/lib/libbsp/arm/nds/touchscreen/touchscreen.h (modified) * c/src/lib/libbsp/arm/nds/wifi/compat.c (modified) * c/src/lib/libbsp/arm/nds/wifi/compat.h (modified) * c/src/lib/libbsp/arm/nds/wifi/wifi.c (modified) * c/src/lib/libbsp/arm/rtl22xx/README (modified) * c/src/lib/libbsp/arm/rtl22xx/console/lpc22xx_uart.h (modified) * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx.cfg (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx_t.cfg (modified) * c/src/lib/libbsp/arm/rtl22xx/start/start.S (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/comm/uart.c (modified) * c/src/lib/libbsp/arm/shared/comm/uart.h (modified) * c/src/lib/libbsp/arm/smdk2410/make/custom/smdk2410.cfg (modified) * c/src/lib/libbsp/arm/smdk2410/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/smdk2410/startup/memmap.c (modified) * c/src/lib/libbsp/avr/avrtest/README (modified) * c/src/lib/libbsp/avr/avrtest/console/console-io.c (modified) * c/src/lib/libbsp/avr/avrtest/include/bsp.h (modified) * c/src/lib/libbsp/avr/avrtest/make/custom/avrtest.cfg (modified) * c/src/lib/libbsp/avr/avrtest/start/start.S (modified) * c/src/lib/libbsp/avr/avrtest/startup/linkcmds (modified) * c/src/lib/libbsp/bfin/TLL6527M/README (modified) * c/src/lib/libbsp/bfin/TLL6527M/console/console.c (modified) * c/src/lib/libbsp/bfin/TLL6527M/include/bsp.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/include/cplb.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/include/tm27.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/make/custom/TLL6527M.cfg (modified) * c/src/lib/libbsp/bfin/TLL6527M/startup/bspstart.c (modified) * c/src/lib/libbsp/bfin/TLL6527M/times (modified) * c/src/lib/libbsp/bfin/bf537Stamp/README (modified) * c/src/lib/libbsp/bfin/bf537Stamp/console/console.c (modified) * c/src/lib/libbsp/bfin/bf537Stamp/include/bsp.h (modified) * c/src/lib/libbsp/bfin/bf537Stamp/make/custom/bf537Stamp.cfg (modified) * c/src/lib/libbsp/bfin/bf537Stamp/network/networkconfig.c (modified) * c/src/lib/libbsp/bfin/bf537Stamp/start/start.S (modified) * c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c (modified) * c/src/lib/libbsp/bfin/bf537Stamp/startup/linkcmds (modified) * c/src/lib/libbsp/bfin/eZKit533/README (modified) * c/src/lib/libbsp/bfin/eZKit533/console/console-io.c (modified) * c/src/lib/libbsp/bfin/eZKit533/include/bsp.h (modified) * c/src/lib/libbsp/bfin/eZKit533/include/cplb.h (modified) * c/src/lib/libbsp/bfin/eZKit533/include/tm27.h (modified) * c/src/lib/libbsp/bfin/eZKit533/make/custom/eZKit533.cfg (modified) * c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c (modified) * c/src/lib/libbsp/bfin/eZKit533/times (modified) * c/src/lib/libbsp/bfin/shared/start/start.S (modified) * c/src/lib/libbsp/bsp.am (modified) * c/src/lib/libbsp/h8300/h8sim/console/console-io.c (modified) * c/src/lib/libbsp/h8300/h8sim/console/syscalls.S (modified) * c/src/lib/libbsp/h8300/h8sim/include/bsp.h (modified) * c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim.cfg (modified) * c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim.cfg (modified) * c/src/lib/libbsp/h8300/h8sim/startup/__main.c (modified) * c/src/lib/libbsp/h8300/h8sim/startup/h8bdinstallirq.c (modified) * c/src/lib/libbsp/h8300/h8sim/startup/linkcmds (modified) * c/src/lib/libbsp/i386/pc386/3c509/3c509.c (modified) * c/src/lib/libbsp/i386/pc386/3c509/3c509.h (modified) * c/src/lib/libbsp/i386/pc386/README (modified) * c/src/lib/libbsp/i386/pc386/README.dec21140 (modified) * c/src/lib/libbsp/i386/pc386/STATUS (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/clock/todcfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_control.c (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vga.c (modified) * c/src/lib/libbsp/i386/pc386/console/kbd_parser.c (modified) * c/src/lib/libbsp/i386/pc386/console/kd.h (modified) * c/src/lib/libbsp/i386/pc386/console/keyboard.c (modified) * c/src/lib/libbsp/i386/pc386/console/keyboard.h (modified) * c/src/lib/libbsp/i386/pc386/console/ps2_drv.h (modified) * c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c (modified) * c/src/lib/libbsp/i386/pc386/console/serial_mouse_config.c (modified) * c/src/lib/libbsp/i386/pc386/console/vgacons.c (modified) * c/src/lib/libbsp/i386/pc386/console/vgacons.h (modified) * c/src/lib/libbsp/i386/pc386/console/videoAsm.S (modified) * c/src/lib/libbsp/i386/pc386/include/crt.h (modified) * c/src/lib/libbsp/i386/pc386/include/tm27.h (modified) * c/src/lib/libbsp/i386/pc386/include/wd80x3.h (modified) * c/src/lib/libbsp/i386/pc386/make/custom/pc386.cfg (modified) * c/src/lib/libbsp/i386/pc386/make/custom/pc386dx.cfg (modified) * c/src/lib/libbsp/i386/pc386/make/custom/pc486.cfg (modified) * c/src/lib/libbsp/i386/pc386/make/custom/pc586-sse.cfg (modified) * c/src/lib/libbsp/i386/pc386/make/custom/pc586.cfg (modified) * c/src/lib/libbsp/i386/pc386/make/custom/pc686.cfg (modified) * c/src/lib/libbsp/i386/pc386/make/custom/pcp4.cfg (modified) * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspreset.c (modified) * c/src/lib/libbsp/i386/pc386/startup/linkcmds (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/pc386/times_i486dx (modified) * c/src/lib/libbsp/i386/pc386/times_p5 (modified) * c/src/lib/libbsp/i386/pc386/tools/Spec.doc (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c (modified) * c/src/lib/libbsp/i386/shared/comm/gdb_glue.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386_io.h (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.c (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.h (modified) * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq.h (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.h (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/i386/shared/pci/pcibios.c (modified) * c/src/lib/libbsp/i386/shared/smp/README (modified) * c/src/lib/libbsp/i386/shared/smp/getcpuid.c (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.h (modified) * c/src/lib/libbsp/lm32/lm32_evr/README (modified) * c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h (modified) * c/src/lib/libbsp/lm32/lm32_evr/include/coverhd.h (modified) * c/src/lib/libbsp/lm32/lm32_evr/include/tm27.h (modified) * c/src/lib/libbsp/lm32/milkymist/README (modified) * c/src/lib/libbsp/lm32/milkymist/include/bsp.h (modified) * c/src/lib/libbsp/lm32/milkymist/include/system_conf.h (modified) * c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c (modified) * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/clock/clock.h (modified) * c/src/lib/libbsp/lm32/shared/console/console.c (modified) * c/src/lib/libbsp/lm32/shared/console/uart.c (modified) * c/src/lib/libbsp/lm32/shared/console/uart.h (modified) * c/src/lib/libbsp/lm32/shared/gdbstub/README (modified) * c/src/lib/libbsp/lm32/shared/gdbstub/gdb_if.h (modified) * c/src/lib/libbsp/lm32/shared/gdbstub/lm32-debug.S (modified) * c/src/lib/libbsp/lm32/shared/gdbstub/lm32-stub.c (modified) * c/src/lib/libbsp/lm32/shared/include/irq.h (modified) * c/src/lib/libbsp/lm32/shared/irq/irq.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_ac97/ac97.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_ac97/milkymist_ac97.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_buttons/buttons.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_buttons/milkymist_buttons.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/clock.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_console/console.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_console/uart.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_console/uart.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_dmx/dmx.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_dmx/milkymist_dmx.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_flash/flash.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_flash/milkymist_flash.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_framebuffer/framebuffer.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_gpio/gpio.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_gpio/milkymist_gpio.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_ir/ir.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_ir/milkymist_ir.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_memcard/milkymist_memcard.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_midi/midi.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_midi/milkymist_midi.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_networking/network.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_networking/network.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_pfpu/milkymist_pfpu.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_pfpu/pfpu.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_timer/timer.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_tmu/milkymist_tmu.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_tmu/tmu.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/comloc.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/milkymist_usbinput.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/usbinput.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_versions/milkymist_versions.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_versions/versions.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_video/milkymist_video.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_video/video.c (modified) * c/src/lib/libbsp/lm32/shared/start/start.S (modified) * c/src/lib/libbsp/lm32/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/lm32/shared/timer/timer.c (modified) * c/src/lib/libbsp/lm32/shared/tsmac/dp83848phy.h (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.c (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.h (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/README (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/console/console-io.c (modified) * c/src/lib/libbsp/m32c/m32cbsp/console/syscalls.S (modified) * c/src/lib/libbsp/m32c/m32cbsp/include/bsp.h (modified) * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim.cfg (modified) * c/src/lib/libbsp/m32c/m32cbsp/startup/bspstart.c (modified) * c/src/lib/libbsp/m32c/m32cbsp/startup/linkcmds (modified) * c/src/lib/libbsp/m32c/m32cbsp/timer/timer.c (modified) * c/src/lib/libbsp/m32r/Makefile.am (modified) * c/src/lib/libbsp/m32r/configure.ac (modified) * c/src/lib/libbsp/m32r/m32rsim/Makefile.am (modified) * c/src/lib/libbsp/m32r/m32rsim/configure.ac (modified) * c/src/lib/libbsp/m32r/m32rsim/console/console-io.c (modified) * c/src/lib/libbsp/m32r/m32rsim/console/syscalls.S (modified) * c/src/lib/libbsp/m32r/m32rsim/include/bsp.h (modified) * c/src/lib/libbsp/m32r/m32rsim/include/tm27.h (modified) * c/src/lib/libbsp/m32r/m32rsim/make/custom/m32rsim.cfg (modified) * c/src/lib/libbsp/m32r/m32rsim/start/start.S (modified) * c/src/lib/libbsp/m32r/m32rsim/startup/bspreset.c (modified) * c/src/lib/libbsp/m32r/m32rsim/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/README (modified) * c/src/lib/libbsp/m68k/av5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) * c/src/lib/libbsp/m68k/av5282/start/start.S (modified) * c/src/lib/libbsp/m68k/av5282/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/av5282/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/av5282/startup/linkcmdsflash (modified) * c/src/lib/libbsp/m68k/av5282/startup/linkcmdsram (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/README (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/console/console-io.c (modified) * c/src/lib/libbsp/m68k/csb360/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/csb360/include/tm27.h (modified) * c/src/lib/libbsp/m68k/csb360/make/custom/csb360.cfg (modified) * c/src/lib/libbsp/m68k/csb360/network/network.c (modified) * c/src/lib/libbsp/m68k/csb360/start/start.S (modified) * c/src/lib/libbsp/m68k/csb360/startup/init5272.c (modified) * c/src/lib/libbsp/m68k/csb360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/csb360/times (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/README (modified) * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/m302_int.h (modified) * c/src/lib/libbsp/m68k/gen68302/make/custom/gen68302.cfg (modified) * c/src/lib/libbsp/m68k/gen68302/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68302/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/gen68302/times (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/README (modified) * c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/m340uart.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/m340timer.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/m340uart.h (modified) * c/src/lib/libbsp/m68k/gen68340/make/custom/gen68340.cfg (modified) * c/src/lib/libbsp/m68k/gen68340/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/init68340.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/README (modified) * c/src/lib/libbsp/m68k/gen68360/clock/clock.c (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/gen68360/include/tm27.h (modified) * c/src/lib/libbsp/m68k/gen68360/make/custom/gen68360.cfg (modified) * c/src/lib/libbsp/m68k/gen68360/make/custom/gen68360_040.cfg (modified) * c/src/lib/libbsp/m68k/gen68360/make/custom/pgh360.cfg (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/startup/alloc360.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/gen68360/timer/timer.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/make/custom/COBRA5475.cfg (modified) * c/src/lib/libbsp/m68k/genmcf548x/make/custom/m5484FireEngine.cfg (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/README (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/console/console.c (modified) * c/src/lib/libbsp/m68k/idp/console/duart.c (modified) * c/src/lib/libbsp/m68k/idp/console/leds.c (modified) * c/src/lib/libbsp/m68k/idp/console/mc68ec.c (modified) * c/src/lib/libbsp/m68k/idp/include/README (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/include/leds.h (modified) * c/src/lib/libbsp/m68k/idp/make/custom/idp.cfg (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/idp/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/idp/times (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/i2c/i2c.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/i2c/i2cdrv.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/ds1307.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/i2c.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/i2cdrv.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/nvram.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/make/custom/mcf5206elite.cfg (modified) * c/src/lib/libbsp/m68k/mcf5206elite/nvram/nvram.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/start/start.S (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/init5206e.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/linkcmds.flash (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tod/todcfg.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/README (modified) * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/start/start.S (modified) * c/src/lib/libbsp/m68k/mcf52235/startup/bspgetcpuclockspeed.c (modified) * c/src/lib/libbsp/m68k/mcf52235/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/README (modified) * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/console/debugio.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5225x/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mcf5225x/start/start.S (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/init5225x.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5225x/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/README (modified) * c/src/lib/libbsp/m68k/mcf5235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/start/start.S (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/bspgetcpuclockspeed.c (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmdsflash (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmdsram (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/README (modified) * c/src/lib/libbsp/m68k/mcf5329/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/make/custom/mcf5329.cfg (modified) * c/src/lib/libbsp/m68k/mcf5329/network/network.c (modified) * c/src/lib/libbsp/m68k/mcf5329/start/start.S (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/cfinit.c (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/init5329.c (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/linkcmdsflash (modified) * c/src/lib/libbsp/m68k/mcf5329/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/README (modified) * c/src/lib/libbsp/m68k/mrm332/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/console/console.c (modified) * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/include/mrm332.h (modified) * c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg (modified) * c/src/lib/libbsp/m68k/mrm332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c (modified) * c/src/lib/libbsp/m68k/mrm332/startup/bsppredriverhook.c (modified) * c/src/lib/libbsp/m68k/mrm332/startup/except_vect_332_ROM.S (modified) * c/src/lib/libbsp/m68k/mrm332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mrm332/startup/linkcmds_ROM (modified) * c/src/lib/libbsp/m68k/mrm332/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mrm332/times (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mvme136/times (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/README (modified) * c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mvme147/make/custom/mvme147.cfg (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mvme147/times (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/README (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mvme147s/make/custom/mvme147s.cfg (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/times (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/README (modified) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/page_table.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162.cfg (modified) * c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx.cfg (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/startup/page_table.c (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mvme162/times (modified) * c/src/lib/libbsp/m68k/mvme162/tod/tod.c (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/sload.c (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/README (modified) * c/src/lib/libbsp/m68k/mvme167/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/bspfatal.c (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/fatal.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/page_table.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mvme167/make/custom/mvme167.cfg (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mvme167/times (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/README (modified) * c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/console/console.c (modified) * c/src/lib/libbsp/m68k/ods68302/include/bare.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/crc.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/debugport.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/m68302scc.h (modified) * c/src/lib/libbsp/m68k/ods68302/make/custom/ods68302.cfg (modified) * c/src/lib/libbsp/m68k/ods68302/start/debugreset.S (modified) * c/src/lib/libbsp/m68k/ods68302/start/reset.S (modified) * c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/crc.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/debugport.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/startup/m68302scc.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/m68k-stub.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/memcheck.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/trace.c (modified) * c/src/lib/libbsp/m68k/ods68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/ods68302/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/shared/bspspuriousinit.c (modified) * c/src/lib/libbsp/m68k/shared/gdbstub/gdb_if.h (modified) * c/src/lib/libbsp/m68k/shared/m68000spurious.c (modified) * c/src/lib/libbsp/m68k/shared/mvme/mvme16x_hw.h (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) * c/src/lib/libbsp/m68k/sim68000/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/README (modified) * c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/console/conscfg.c (modified) * c/src/lib/libbsp/m68k/sim68000/console/debugio.c (modified) * c/src/lib/libbsp/m68k/sim68000/include/bsp.h (modified) * c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg (modified) * c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg (modified) * c/src/lib/libbsp/m68k/sim68000/start/start.S (modified) * c/src/lib/libbsp/m68k/sim68000/startup/bsppredriverhook.c (modified) * c/src/lib/libbsp/m68k/sim68000/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/sim68000/startup/spurious_assistant.c (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/README (modified) * c/src/lib/libbsp/m68k/uC5282/TIMES (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/make/custom/uC5282.cfg (modified) * c/src/lib/libbsp/m68k/uC5282/start/start.S (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspreset.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/linkcmds (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/console/console-io.c (modified) * c/src/lib/libbsp/mips/csb350/include/bsp.h (modified) * c/src/lib/libbsp/mips/csb350/include/irq.h (modified) * c/src/lib/libbsp/mips/csb350/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/csb350/make/custom/csb350.cfg (modified) * c/src/lib/libbsp/mips/csb350/network/network.c (modified) * c/src/lib/libbsp/mips/csb350/start/start.S (modified) * c/src/lib/libbsp/mips/csb350/startup/bspreset.c (modified) * c/src/lib/libbsp/mips/csb350/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/csb350/startup/linkcmds (modified) * c/src/lib/libbsp/mips/csb350/timer/timer.c (modified) * c/src/lib/libbsp/mips/genmongoosev/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/README (modified) * c/src/lib/libbsp/mips/genmongoosev/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c (modified) * c/src/lib/libbsp/mips/genmongoosev/include/bsp.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/irq.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/lr33000.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/lr333x0.h (modified) * c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/genmongoosev/make/custom/genmongoosev.cfg (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/linkcmds (modified) * c/src/lib/libbsp/mips/genmongoosev/timer/timer.c (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/clock/ckinit.c (modified) * c/src/lib/libbsp/mips/hurricane/clock/clock.S (modified) * c/src/lib/libbsp/mips/hurricane/clock/clock.h (modified) * c/src/lib/libbsp/mips/hurricane/console/console.c (modified) * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) * c/src/lib/libbsp/mips/hurricane/include/coverhd.h (modified) * c/src/lib/libbsp/mips/hurricane/include/irq.h (modified) * c/src/lib/libbsp/mips/hurricane/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/hurricane/start/start.S (modified) * c/src/lib/libbsp/mips/hurricane/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/hurricane/startup/inittlb.c (modified) * c/src/lib/libbsp/mips/hurricane/startup/usc.S (modified) * c/src/lib/libbsp/mips/hurricane/times (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/README (modified) * c/src/lib/libbsp/mips/jmr3904/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/console/console-io.c (modified) * c/src/lib/libbsp/mips/jmr3904/include/bsp.h (modified) * c/src/lib/libbsp/mips/jmr3904/include/irq.h (modified) * c/src/lib/libbsp/mips/jmr3904/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/jmr3904/make/custom/jmr3904.cfg (modified) * c/src/lib/libbsp/mips/jmr3904/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/jmr3904/startup/linkcmds (modified) * c/src/lib/libbsp/mips/jmr3904/timer/timer.c (modified) * c/src/lib/libbsp/mips/jmr3904/tools/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/runtest.in (modified) * c/src/lib/libbsp/mips/malta/STATUS (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4925/console/console-io.c (modified) * c/src/lib/libbsp/mips/rbtx4925/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4925/include/irq.h (modified) * c/src/lib/libbsp/mips/rbtx4925/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/rbtx4925/start/start.S (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4938/clock/yamon_api.h (modified) * c/src/lib/libbsp/mips/rbtx4938/console/console-io.c (modified) * c/src/lib/libbsp/mips/rbtx4938/console/yamon_api.h (modified) * c/src/lib/libbsp/mips/rbtx4938/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4938/include/irq.h (modified) * c/src/lib/libbsp/mips/rbtx4938/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/rbtx4938/start/start.S (modified) * c/src/lib/libbsp/mips/rbtx4938/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/shared/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/shared/clock/mips_timer.S (modified) * c/src/lib/libbsp/mips/shared/gdbstub/README (modified) * c/src/lib/libbsp/mips/shared/gdbstub/gdb_if.h (modified) * c/src/lib/libbsp/mips/shared/gdbstub/mips-stub.c (modified) * c/src/lib/libbsp/mips/shared/irq/exception.S (modified) * c/src/lib/libbsp/mips/shared/irq/i8259.h (modified) * c/src/lib/libbsp/mips/shared/irq/interruptmask.c (modified) * c/src/lib/libbsp/mips/shared/irq/interruptmask_TX49.c (modified) * c/src/lib/libbsp/mips/shared/irq/irq.c (modified) * c/src/lib/libbsp/mips/shared/irq/maxvectors.c (modified) * c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c (modified) * c/src/lib/libbsp/mips/shared/startup/idtmem.S (modified) * c/src/lib/libbsp/nios2/Makefile.am (modified) * c/src/lib/libbsp/nios2/README (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/clock/clock.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/console/console.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/include/bsp.h (modified) * c/src/lib/libbsp/nios2/nios2_iss/start/crtnn.s (modified) * c/src/lib/libbsp/nios2/nios2_iss/start/start.S (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/bspstart.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/main.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/setvec.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/times (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/README (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/make/custom/no_bsp.cfg (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/lock.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/linkcmds (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/times (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c (modified) * c/src/lib/libbsp/powerpc/beatnik/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/beatnik/marvell/discovery.c (modified) * c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c (modified) * c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.h (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em_pub.h (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em_rtems.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_gfe/if_gfe_pub.h (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_gfe/if_gfe_rtems.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_mve/if_mve_pub.h (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_mve/mv643xx_eth.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/porting/if_xxx_rtems.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/support/bsp_attach.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/support/bsp_bsdnet_attach.h (modified) * c/src/lib/libbsp/powerpc/beatnik/network/support/early_enet_link_status.h (modified) * c/src/lib/libbsp/powerpc/beatnik/network/support/early_link_status.c (modified) * c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c (modified) * c/src/lib/libbsp/powerpc/beatnik/pci/motload_fixup.c (modified) * c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/i2c_init.c (modified) * c/src/lib/libbsp/powerpc/beatnik/tod/todcfg.c (modified) * c/src/lib/libbsp/powerpc/beatnik/vme/VMEConfig.h (modified) * c/src/lib/libbsp/powerpc/beatnik/vme/vme_dma.c (modified) * c/src/lib/libbsp/powerpc/beatnik/vme/vmeconfig.c (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/console/alloc360.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/config.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/console.h (modified) * c/src/lib/libbsp/powerpc/ep1a/console/init68360.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/m68360.h (modified) * c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.h (modified) * c/src/lib/libbsp/powerpc/ep1a/console/printk_support.c (modified) * c/src/lib/libbsp/powerpc/ep1a/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ep1a/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/ep1a/irq/openpic_xxx_irq.c (modified) * c/src/lib/libbsp/powerpc/ep1a/pci/no_host_bridge.c (modified) * c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ep1a/vme/VMEConfig.h (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/README.IceCube (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_ata.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_crc16_dp_0.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_crc16_dp_1.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_fec_rx_bd.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_fec_tx_bd.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_0.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_1.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_2.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_3.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_bd_0.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_bd_1.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_rx_bd.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_tx_bd.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_lpc.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_pci_rx.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_pci_tx.c (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/include/u-boot-config.h (modified) * c/src/lib/libbsp/powerpc/gen5200/make/custom/brs5l.cfg (modified) * c/src/lib/libbsp/powerpc/gen5200/make/custom/dp2.cfg (modified) * c/src/lib/libbsp/powerpc/gen5200/make/custom/gen5200.inc (modified) * c/src/lib/libbsp/powerpc/gen5200/make/custom/icecube.cfg (modified) * c/src/lib/libbsp/powerpc/gen5200/make/custom/pm520_cr825.cfg (modified) * c/src/lib/libbsp/powerpc/gen5200/make/custom/pm520_ze30.cfg (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/uboot_support.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/README.mpc8313erdb (modified) * c/src/lib/libbsp/powerpc/gen83xx/README.mpc8349eamds (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/hwreg_vals.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/irq.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/tsec-config.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/u-boot-config.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/make/custom/gen83xx.inc (modified) * c/src/lib/libbsp/powerpc/gen83xx/make/custom/hsc_cm01.cfg (modified) * c/src/lib/libbsp/powerpc/gen83xx/make/custom/mpc8349eamds.cfg (modified) * c/src/lib/libbsp/powerpc/gen83xx/network/network.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/cpuinit.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/mpc83xx_regs.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/uboot_support.c (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/README (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/dlentry/dlentry.S (modified) * c/src/lib/libbsp/powerpc/haleakala/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/haleakala/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/haleakala/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/haleakala/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mbx8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/README (modified) * c/src/lib/libbsp/powerpc/mbx8xx/clock/p_clock.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/8xx_immap.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/commproc.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/mbx.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/network/network.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mbx8xx/times-mbx821 (modified) * c/src/lib/libbsp/powerpc/mbx8xx/times-mbx860 (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/README (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/README.MVME2100 (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/README.OTHERBOARDS (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/README.dec21140 (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/times.mcp750 (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/times.mvme2307 (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/mpc55xx-config.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/reset.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs-cal.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-siu-pcr.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-flash.S (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/README (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/clock/p_clock.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/make/custom/mpc8260ads.cfg (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/if_hdlcsubr.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/network.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/start/start.S (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/cpuinit.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/times (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/flash/flashcfg.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/i2c/i2c_init.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/pci/detect_host_bridge.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/start/start.S (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/misc.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/tod/todcfg.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/vme/VMEConfig.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/GT64260/GT64260TWSI.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/GT64260/MVME5500I2C.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/README (modified) * c/src/lib/libbsp/powerpc/mvme5500/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/make/custom/mvme5500.cfg (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/GT64260ethreg.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/start/start.S (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bootpstuff.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/tod/todcfg.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/vectors/bspException.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/README (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/console/console-io.c (modified) * c/src/lib/libbsp/powerpc/psim/console/consupp.S (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/psim/include/psim.h (modified) * c/src/lib/libbsp/powerpc/psim/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/psim/make/custom/psim.cfg (modified) * c/src/lib/libbsp/powerpc/psim/network/if_sim.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/README (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/lock.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/powerpc/psim/start/start.S (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/psim/startup/psim_registers.c (modified) * c/src/lib/libbsp/powerpc/psim/vectors/README (modified) * c/src/lib/libbsp/powerpc/psim/vectors/align_h.S (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/README (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/console/console-io.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qemuppc/make/custom/qemuppc.cfg (modified) * c/src/lib/libbsp/powerpc/qemuppc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-master.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-slave.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/intercom.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/mmu.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/qoriq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/u-boot-config.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/uart-bridge.h (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq.inc (modified) * c/src/lib/libbsp/powerpc/qoriq/network/network.c (modified) * c/src/lib/libbsp/powerpc/qoriq/rtc/rtc-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/shmsupp/intercom-mpci.c (modified) * c/src/lib/libbsp/powerpc/qoriq/shmsupp/intercom.c (modified) * c/src/lib/libbsp/powerpc/qoriq/shmsupp/lock.S (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bsppredriverhook.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-tlb1.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu.c (modified) * c/src/lib/libbsp/powerpc/qoriq/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c (modified) * c/src/lib/libbsp/powerpc/score603e/README (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.h (modified) * c/src/lib/libbsp/powerpc/score603e/console/console.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolebsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/console/tbl85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/gen2.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c (modified) * c/src/lib/libbsp/powerpc/score603e/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/score603e/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/score603e/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/score603e/irq/no_pic.c (modified) * c/src/lib/libbsp/powerpc/score603e/make/custom/score603e.cfg (modified) * c/src/lib/libbsp/powerpc/score603e/start/start.S (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/vmeintr.c (modified) * c/src/lib/libbsp/powerpc/score603e/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/score603e/tod/tod.c (modified) * c/src/lib/libbsp/powerpc/score603e/vme/VMEConfig.h (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/README (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/bootldr.h (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/em86.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/em86real.S (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/exception.S (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/head.S (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/lib.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/mm.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/zlib.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/zlib.h (modified) * c/src/lib/libbsp/powerpc/shared/clock/p_clock.c (modified) * c/src/lib/libbsp/powerpc/shared/console/bspreset.c (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/console/console.inl (modified) * c/src/lib/libbsp/powerpc/shared/console/consoleIo.h (modified) * c/src/lib/libbsp/powerpc/shared/console/inch.c (modified) * c/src/lib/libbsp/powerpc/shared/console/keyboard.h (modified) * c/src/lib/libbsp/powerpc/shared/console/polled_io.c (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.c (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.h (modified) * c/src/lib/libbsp/powerpc/shared/flash/flash.c (modified) * c/src/lib/libbsp/powerpc/shared/flash/flashPgm.h (modified) * c/src/lib/libbsp/powerpc/shared/flash/flashPgmPvt.h (modified) * c/src/lib/libbsp/powerpc/shared/flash/intelFlash.c (modified) * c/src/lib/libbsp/powerpc/shared/flash/spansionFlash.c (modified) * c/src/lib/libbsp/powerpc/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/powerpc/shared/include/nvram.h (modified) * c/src/lib/libbsp/powerpc/shared/include/start.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/i8259.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/openpic_i8259_irq.c (modified) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.c (modified) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.h (modified) * c/src/lib/libbsp/powerpc/shared/motorola/vpd.c (modified) * c/src/lib/libbsp/powerpc/shared/motorola/vpd.h (modified) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.c (modified) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.h (modified) * c/src/lib/libbsp/powerpc/shared/pci/detect_raven_bridge.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/generic_clear_hberrs.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/pci.h (modified) * c/src/lib/libbsp/powerpc/shared/pci/pcifinddevice.c (modified) * c/src/lib/libbsp/powerpc/shared/residual/pnp.h (modified) * c/src/lib/libbsp/powerpc/shared/residual/residual.c (modified) * c/src/lib/libbsp/powerpc/shared/residual/residual.h (modified) * c/src/lib/libbsp/powerpc/shared/showbats.c (modified) * c/src/lib/libbsp/powerpc/shared/src/bsp-start-zero.S (modified) * c/src/lib/libbsp/powerpc/shared/src/memcpy.c (modified) * c/src/lib/libbsp/powerpc/shared/start/preload.S (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) * c/src/lib/libbsp/powerpc/shared/start/vectors_entry.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspidle.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/pgtbl_activate.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/pgtbl_setup.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/ppc_idle.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/pretaskinghook.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/probeMemEnd.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/sbrk.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/zerobss.c (modified) * c/src/lib/libbsp/powerpc/shared/tod/todcfg.c (modified) * c/src/lib/libbsp/powerpc/shared/uboot_dump_bdinfo.c (modified) * c/src/lib/libbsp/powerpc/shared/uboot_getenv.c (modified) * c/src/lib/libbsp/powerpc/shared/vme/VMEConfig.h (modified) * c/src/lib/libbsp/powerpc/shared/vme/vme_universe.c (modified) * c/src/lib/libbsp/powerpc/shared/vme/vmeconfig.c (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/README (modified) * c/src/lib/libbsp/powerpc/ss555/clock/p_clock.c (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ss555/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/ss555/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/ss555/make/custom/ss555.cfg (modified) * c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ss555/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/ss555/startup/tm27supp.c (modified) * c/src/lib/libbsp/powerpc/ss555/times (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/README (modified) * c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/network/network_fec.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/network/network_scc.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/start.S (modified) * c/src/lib/libbsp/powerpc/tqm8xx/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/README (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/dlentry/dlentry.S (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/xparameters_dflt.h (modified) * c/src/lib/libbsp/powerpc/virtex/make/custom/virtex.cfg (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex4/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex5/include/coverhd.h (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/README (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/include/coverhd.h (modified) * c/src/lib/libbsp/sh/gensh1/make/custom/gensh1.cfg (modified) * c/src/lib/libbsp/sh/gensh1/start/start.S (modified) * c/src/lib/libbsp/sh/gensh1/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh1/times (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/README (modified) * c/src/lib/libbsp/sh/gensh2/README.EVB7045F (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/console/config.c (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/include/coverhd.h (modified) * c/src/lib/libbsp/sh/gensh2/make/custom/gensh2.cfg (modified) * c/src/lib/libbsp/sh/gensh2/start/start.S (modified) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.ram (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.rom (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/README (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/console/console.c (modified) * c/src/lib/libbsp/sh/gensh4/hw_init/hw_init.c (modified) * c/src/lib/libbsp/sh/gensh4/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh4/include/sdram.h (modified) * c/src/lib/libbsp/sh/gensh4/include/tm27.h (modified) * c/src/lib/libbsp/sh/gensh4/make/custom/gensh4.cfg (modified) * c/src/lib/libbsp/sh/gensh4/start/start.S (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds.rom (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds.rom2ram (modified) * c/src/lib/libbsp/sh/gensh4/times (modified) * c/src/lib/libbsp/sh/shared/bsphwinit.c (modified) * c/src/lib/libbsp/sh/shared/bspstart.c (modified) * c/src/lib/libbsp/sh/shared/console.c (modified) * c/src/lib/libbsp/sh/shared/setvec.c (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/README (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/include/bsp.h (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh1.cfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2.cfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2e.cfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh4.cfg (modified) * c/src/lib/libbsp/sh/shsim/start/start.S (modified) * c/src/lib/libbsp/sh/shsim/startup/linkcmds (modified) * c/src/lib/libbsp/sh/shsim/startup/linkcmds.sim (modified) * c/src/lib/libbsp/sh/shsim/trap34/console-io.c (modified) * c/src/lib/libbsp/sh/shsim/trap34/console-support.S (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/shared/bspgetworkarea.c (modified) * c/src/lib/libbsp/shared/bspinit.c (modified) * c/src/lib/libbsp/shared/bsplibc.c (modified) * c/src/lib/libbsp/shared/bsppost.c (modified) * c/src/lib/libbsp/shared/bsppredriverhook.c (modified) * c/src/lib/libbsp/shared/bsppretaskinghook.c (modified) * c/src/lib/libbsp/shared/bspreset.c (modified) * c/src/lib/libbsp/shared/bspreset_fatal.c (modified) * c/src/lib/libbsp/shared/bspreset_loop.c (modified) * c/src/lib/libbsp/shared/bspstart.c (modified) * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/shared/console-polled.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shared/console_control.c (modified) * c/src/lib/libbsp/shared/console_private.h (modified) * c/src/lib/libbsp/shared/console_read.c (modified) * c/src/lib/libbsp/shared/console_select.c (modified) * c/src/lib/libbsp/shared/console_write.c (modified) * c/src/lib/libbsp/shared/dummy_printk_support.c (modified) * c/src/lib/libbsp/shared/gnatinstallhandler.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/shared/include/coverhd.h (modified) * c/src/lib/libbsp/shared/include/tm27.h (modified) * c/src/lib/libbsp/shared/include/u-boot.h (modified) * c/src/lib/libbsp/shared/include/utility.h (modified) * c/src/lib/libbsp/shared/sbrk.c (modified) * c/src/lib/libbsp/shared/setvec.c (modified) * c/src/lib/libbsp/shared/smp/bspsmp_wait_for.c (modified) * c/src/lib/libbsp/shared/smp/getcpuid.c (modified) * c/src/lib/libbsp/shared/smp/smp_stub.c (modified) * c/src/lib/libbsp/shared/src/bsp-uboot-board-info.c (modified) * c/src/lib/libbsp/shared/timerstub.c (modified) * c/src/lib/libbsp/shared/tod.c (modified) * c/src/lib/libbsp/shared/tod.h (modified) * c/src/lib/libbsp/shared/umon/README (modified) * c/src/lib/libbsp/shared/umon/cli.h (modified) * c/src/lib/libbsp/shared/umon/monlib.c (modified) * c/src/lib/libbsp/shared/umon/monlib.h (modified) * c/src/lib/libbsp/shared/umon/tfs.h (modified) * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) * c/src/lib/libbsp/shared/umon/umon.h (modified) * c/src/lib/libbsp/shared/umon/umoncons.c (modified) * c/src/lib/libbsp/shared/umon/umonrtemsglue.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/README.porting (modified) * c/src/lib/libbsp/shared/vmeUniverse/VME.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/VMEDMA.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/bspVmeDmaList.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/bspVmeDmaList.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/bspVmeDmaListP.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148DMA.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverseDMA.h (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/README (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/console/debugputs.c (modified) * c/src/lib/libbsp/sparc/erc32/console/erc32_console.c (modified) * c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c (modified) * c/src/lib/libbsp/sparc/erc32/include/erc32.h (modified) * c/src/lib/libbsp/sparc/erc32/include/tm27.h (modified) * c/src/lib/libbsp/sparc/erc32/make/custom/erc32.cfg (modified) * c/src/lib/libbsp/sparc/erc32/make/custom/sis.cfg (modified) * c/src/lib/libbsp/sparc/erc32/startup/boardinit.S (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspdelay.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspidle.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/erc32mec.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/erc32/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/timer.c (modified) * c/src/lib/libbsp/sparc/erc32/times (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/README (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/console/console.c (modified) * c/src/lib/libbsp/sparc/leon2/console/debugputs.c (modified) * c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c (modified) * c/src/lib/libbsp/sparc/leon2/include/cchip.h (modified) * c/src/lib/libbsp/sparc/leon2/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon2/include/rasta.h (modified) * c/src/lib/libbsp/sparc/leon2/include/tm27.h (modified) * c/src/lib/libbsp/sparc/leon2/leon_open_eth/leon_open_eth.c (modified) * c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c (modified) * c/src/lib/libbsp/sparc/leon2/make/custom/leon2.cfg (modified) * c/src/lib/libbsp/sparc/leon2/pci/pci.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/bspidle.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/leon2/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/timer/timer.c (modified) * c/src/lib/libbsp/sparc/leon2/times (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/README (modified) * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c (modified) * c/src/lib/libbsp/sparc/leon3/include/amba.h (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/include/tm27.h (modified) * c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c (modified) * c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/README (modified) * c/src/lib/libbsp/sparc/leon3/smp/getcpuid.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspidle.S (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/leon3/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/timer/timer.c (modified) * c/src/lib/libbsp/sparc/leon3/times (modified) * c/src/lib/libbsp/sparc/shared/bsppretaskinghook.c (modified) * c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c (modified) * c/src/lib/libbsp/sparc/shared/can/occan_pci.c (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp.h (modified) * c/src/lib/libbsp/sparc/shared/include/debug_defs.h (modified) * c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/pci/pcifinddevice.c (modified) * c/src/lib/libbsp/sparc/shared/start.S (modified) * c/src/lib/libbsp/sparc/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c (modified) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/README (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/niagara/include/tm27.h (modified) * c/src/lib/libbsp/sparc64/niagara/make/custom/niagara.cfg (modified) * c/src/lib/libbsp/sparc64/niagara/start/bspinit.S (modified) * c/src/lib/libbsp/sparc64/shared/asm/asm.S (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/console/conscfg.c (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/genarch/balloc.c (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/genarch/ofw.c (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/genarch/ofw_tree.c (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/generic/string.c (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/include/balloc.h (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/sparc64/loader/main.c (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/sparc64/loader/ofwarch.c (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/sparc64/loader/ofwasm.S (modified) * c/src/lib/libbsp/sparc64/shared/helenos/kernel/sparc64/src/sun4u/takemmu.S (modified) * c/src/lib/libbsp/sparc64/shared/include/asm.h (modified) * c/src/lib/libbsp/sparc64/shared/include/traptable.h (modified) * c/src/lib/libbsp/sparc64/shared/start/start.S (modified) * c/src/lib/libbsp/sparc64/shared/start/trap_table.S (modified) * c/src/lib/libbsp/sparc64/shared/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/sparc64/shared/startup/bsppredriverhook.c (modified) * c/src/lib/libbsp/sparc64/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc64/shared/startup/linkcmds (modified) * c/src/lib/libbsp/sparc64/shared/startup/setvec.c (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/README (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/usiii/include/tm27.h (modified) * c/src/lib/libbsp/sparc64/usiii/make/custom/usiii.cfg (modified) * c/src/lib/libbsp/sparc64/usiii/start/bspinit.S (modified) * c/src/lib/libcpu/Makefile.am (modified) * c/src/lib/libcpu/README (modified) * c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200_dbgu.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200_emac.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200_gpio.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200_mem.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200_pmc.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200_usart.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/bits.h (modified) * c/src/lib/libcpu/arm/at91rm9200/irq/irq.c (modified) * c/src/lib/libcpu/arm/at91rm9200/irq/irq.h (modified) * c/src/lib/libcpu/arm/at91rm9200/pmc/pmc.c (modified) * c/src/lib/libcpu/arm/at91rm9200/timer/timer.c (modified) * c/src/lib/libcpu/arm/at91rm9200/usart/usart.c (modified) * c/src/lib/libcpu/arm/lpc22xx/include/lpc22xx.h (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_asm.S (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_init.c (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/irq.c (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/irq.h (modified) * c/src/lib/libcpu/arm/lpc22xx/timer/timer.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/include/mc9328mxl.h (modified) * c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/irq/irq.h (modified) * c/src/lib/libcpu/arm/mc9328mxl/timer/timer.c (modified) * c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c (modified) * c/src/lib/libcpu/arm/pxa255/include/ffuart.h (modified) * c/src/lib/libcpu/arm/pxa255/include/pxa255.h (modified) * c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_asm.S (modified) * c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_init.c (modified) * c/src/lib/libcpu/arm/pxa255/irq/irq.c (modified) * c/src/lib/libcpu/arm/pxa255/irq/irq.h (modified) * c/src/lib/libcpu/arm/pxa255/pmc/pmc.c (modified) * c/src/lib/libcpu/arm/pxa255/timer/timer.c (modified) * c/src/lib/libcpu/arm/s3c24xx/irq/irq.c (modified) * c/src/lib/libcpu/arm/s3c24xx/timer/timer.c (modified) * c/src/lib/libcpu/arm/shared/arm920/mmu.c (modified) * c/src/lib/libcpu/arm/shared/include/cache_.h (modified) * c/src/lib/libcpu/arm/shared/include/mmu.h (modified) * c/src/lib/libcpu/bfin/README (modified) * c/src/lib/libcpu/bfin/bf52x/include/bf52x.h (modified) * c/src/lib/libcpu/bfin/bf52x/interrupt/interrupt.c (modified) * c/src/lib/libcpu/bfin/bf52x/interrupt/interrupt.h (modified) * c/src/lib/libcpu/bfin/cache/cache.c (modified) * c/src/lib/libcpu/bfin/cache/cache_.h (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) * c/src/lib/libcpu/bfin/clock/rtc.c (modified) * c/src/lib/libcpu/bfin/clock/tod.h (modified) * c/src/lib/libcpu/bfin/include/bf533.h (modified) * c/src/lib/libcpu/bfin/include/bf537.h (modified) * c/src/lib/libcpu/bfin/include/cecRegs.h (modified) * c/src/lib/libcpu/bfin/include/coreTimerRegs.h (modified) * c/src/lib/libcpu/bfin/include/dmaRegs.h (modified) * c/src/lib/libcpu/bfin/include/ebiuRegs.h (modified) * c/src/lib/libcpu/bfin/include/ethernetRegs.h (modified) * c/src/lib/libcpu/bfin/include/gpioRegs.h (modified) * c/src/lib/libcpu/bfin/include/memoryRegs.h (modified) * c/src/lib/libcpu/bfin/include/mmuRegs.h (modified) * c/src/lib/libcpu/bfin/include/ppiRegs.h (modified) * c/src/lib/libcpu/bfin/include/rtcRegs.h (modified) * c/src/lib/libcpu/bfin/include/sicRegs.h (modified) * c/src/lib/libcpu/bfin/include/spiRegs.h (modified) * c/src/lib/libcpu/bfin/include/sportRegs.h (modified) * c/src/lib/libcpu/bfin/include/timerRegs.h (modified) * c/src/lib/libcpu/bfin/include/twiRegs.h (modified) * c/src/lib/libcpu/bfin/include/uartRegs.h (modified) * c/src/lib/libcpu/bfin/include/wdogRegs.h (modified) * c/src/lib/libcpu/bfin/interrupt/interrupt.c (modified) * c/src/lib/libcpu/bfin/interrupt/interrupt.h (modified) * c/src/lib/libcpu/bfin/mmu/mmu.c (modified) * c/src/lib/libcpu/bfin/mmu/mmu.h (modified) * c/src/lib/libcpu/bfin/network/ethernet.c (modified) * c/src/lib/libcpu/bfin/network/ethernet.h (modified) * c/src/lib/libcpu/bfin/serial/spi.c (modified) * c/src/lib/libcpu/bfin/serial/spi.h (modified) * c/src/lib/libcpu/bfin/serial/twi.c (modified) * c/src/lib/libcpu/bfin/serial/twi.h (modified) * c/src/lib/libcpu/bfin/serial/uart.c (modified) * c/src/lib/libcpu/bfin/serial/uart.h (modified) * c/src/lib/libcpu/bfin/timer/timer.c (modified) * c/src/lib/libcpu/i386/byteorder.h (modified) * c/src/lib/libcpu/i386/cache.c (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * c/src/lib/libcpu/i386/cpuModel.S (modified) * c/src/lib/libcpu/i386/cpuModel.h (modified) * c/src/lib/libcpu/i386/displayCpu.c (modified) * c/src/lib/libcpu/i386/idtr.S (modified) * c/src/lib/libcpu/i386/page.c (modified) * c/src/lib/libcpu/lm32/shared/cache/cache_.h (modified) * c/src/lib/libcpu/lm32/shared/misc/memcpy.c (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/README (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/bindec.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/binstr.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/bugfix.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/decbin.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/do_func.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/gen_except.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/get_op.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/kernel_ex.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/res_func.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/round.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/rtems_fpsp.c (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/rtems_skel.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sacos.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sasin.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/satan.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/satanh.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/scale.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/scosh.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/setox.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sgetem.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sint.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/slog2.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/slogn.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/smovecr.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/srem_mod.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/ssin.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/ssinh.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stan.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stanh.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sto_res.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stwotox.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/tbldo.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/util.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_bsun.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_fline.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_operr.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_ovfl.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_snan.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_store.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unfl.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unimp.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unsupp.S (modified) * c/src/lib/libcpu/m68k/mcf5206/clock/ckinit.c (modified) * c/src/lib/libcpu/m68k/mcf5206/console/mcfuart.c (modified) * c/src/lib/libcpu/m68k/mcf5206/timer/timer.c (modified) * c/src/lib/libcpu/m68k/mcf5206/timer/timerisr.S (modified) * c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c (modified) * c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c (modified) * c/src/lib/libcpu/m68k/shared/cache/cache.c (modified) * c/src/lib/libcpu/m68k/shared/misc/m68kidle.c (modified) * c/src/lib/libcpu/mips/au1x00/include/au1x00.h (modified) * c/src/lib/libcpu/mips/au1x00/vectorisrs/vectorisrs.c (modified) * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips/clock/clock.S (modified) * c/src/lib/libcpu/mips/clock/clock.h (modified) * c/src/lib/libcpu/mips/mongoosev/README (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart_reg.c (modified) * c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h (modified) * c/src/lib/libcpu/mips/mongoosev/vectorisrs/vectorisrs.c (modified) * c/src/lib/libcpu/mips/r46xx/vectorisrs/vectorisrs.c (modified) * c/src/lib/libcpu/mips/rm52xx/include/rm5231.h (modified) * c/src/lib/libcpu/mips/shared/cache/cache.c (modified) * c/src/lib/libcpu/mips/shared/interrupts/installisrentries.c (modified) * c/src/lib/libcpu/mips/shared/interrupts/interruptmask.c (modified) * c/src/lib/libcpu/mips/shared/interrupts/isr_entries.S (modified) * c/src/lib/libcpu/mips/shared/interrupts/isr_entries.h (modified) * c/src/lib/libcpu/mips/timer/gettime.S (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/mips/tx39/include/tx3904.h (modified) * c/src/lib/libcpu/mips/tx39/vectorisrs/vectorisrs.c (modified) * c/src/lib/libcpu/mips/tx49/include/tx4925.h (modified) * c/src/lib/libcpu/mips/tx49/include/tx4938.h (modified) * c/src/lib/libcpu/powerpc/README (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/e500/mmu/e500_mmu.h (modified) * c/src/lib/libcpu/powerpc/e500/mmu/mmu.c (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/esci/esci.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/mpc55xx.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/reg-defs.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/regs.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/README (modified) * c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/exceptions/raw_exception.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/include/console.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/include/mpc5xx.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors.S (modified) * c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors_init.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup_asm.S (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.h (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/asm_utils.S (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.h (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/mmuAsm.S (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.h (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/README (modified) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/cpm/brg.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/include/console.h (modified) * c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/include/mpc83xx.h (modified) * c/src/lib/libcpu/powerpc/mpc8xx/README (modified) * c/src/lib/libcpu/powerpc/mpc8xx/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/include/console.h (modified) * c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/asm_utils.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/irq.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/irq_supp.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/nested_irq_test.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_address.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_alignment.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_categories.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_hdl.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_prologue.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_test.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * c/src/lib/libcpu/powerpc/ppc403/README (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock_4xx.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console405.c (modified) * c/src/lib/libcpu/powerpc/ppc403/include/ppc405ex.h (modified) * c/src/lib/libcpu/powerpc/ppc403/include/ppc405gp.h (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/README (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/cache.h (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/debugmod.h (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * c/src/lib/libcpu/powerpc/shared/include/byteorder.h (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) * c/src/lib/libcpu/powerpc/shared/include/io.h (modified) * c/src/lib/libcpu/powerpc/shared/include/mmu.h (modified) * c/src/lib/libcpu/powerpc/shared/include/page.h (modified) * c/src/lib/libcpu/powerpc/shared/include/pgtable.h (modified) * c/src/lib/libcpu/powerpc/shared/include/spr.h (modified) * c/src/lib/libcpu/powerpc/shared/src/cache_.h (modified) * c/src/lib/libcpu/sh/sh7032/clock/ckinit.c (modified) * c/src/lib/libcpu/sh/sh7032/delay/delay.c (modified) * c/src/lib/libcpu/sh/sh7032/include/iosh7032.h (modified) * c/src/lib/libcpu/sh/sh7032/include/ispsh7032.h (modified) * c/src/lib/libcpu/sh/sh7032/include/sci.h (modified) * c/src/lib/libcpu/sh/sh7032/include/sh7_pfc.h (modified) * c/src/lib/libcpu/sh/sh7032/include/sh7_sci.h (modified) * c/src/lib/libcpu/sh/sh7032/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7032/score/ispsh7032.c (modified) * c/src/lib/libcpu/sh/sh7032/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7045/clock/ckinit.c (modified) * c/src/lib/libcpu/sh/sh7045/include/io_types.h (modified) * c/src/lib/libcpu/sh/sh7045/include/iosh7045.h (modified) * c/src/lib/libcpu/sh/sh7045/include/ispsh7045.h (modified) * c/src/lib/libcpu/sh/sh7045/include/sci.h (modified) * c/src/lib/libcpu/sh/sh7045/include/sci_termios.h (modified) * c/src/lib/libcpu/sh/sh7045/include/sh7_pfc.h (modified) * c/src/lib/libcpu/sh/sh7045/include/sh7_sci.h (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/ispsh7045.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7750/clock/ckinit.c (modified) * c/src/lib/libcpu/sh/sh7750/include/rtems/score/iosh7750.h (modified) * c/src/lib/libcpu/sh/sh7750/include/rtems/score/ipl.h (modified) * c/src/lib/libcpu/sh/sh7750/include/rtems/score/ispsh7750.h (modified) * c/src/lib/libcpu/sh/sh7750/include/rtems/score/sh4_regs.h (modified) * c/src/lib/libcpu/sh/sh7750/include/rtems/score/sh7750_regs.h (modified) * c/src/lib/libcpu/sh/sh7750/sci/console.c (modified) * c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/ispsh7750.c (modified) * c/src/lib/libcpu/sh/sh7750/timer/timer.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/ispshgdb.c (modified) * c/src/lib/libcpu/shared/include/cache.h (modified) * c/src/lib/libcpu/shared/src/cache_aligned_malloc.c (modified) * c/src/lib/libcpu/shared/src/no_cache.c (modified) * c/src/lib/libcpu/sparc/cache/cache.c (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.h (modified) * c/src/lib/libcpu/sparc64/shared/cache/cache.c (modified) * c/src/lib/libcpu/sparc64/shared/interrupts/installisrentries.c (modified) * c/src/lib/libcpu/sparc64/shared/score/cpu.c (modified) * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * c/src/lib/libcpu/sparc64/shared/syscall/sparc64-syscall.h (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/flash/am29lv160.c (modified) * c/src/libchip/flash/am29lv160.h (modified) * c/src/libchip/i2c/i2c-2b-eeprom.c (modified) * c/src/libchip/i2c/i2c-2b-eeprom.h (modified) * c/src/libchip/i2c/i2c-ds1621.c (modified) * c/src/libchip/i2c/i2c-ds1621.h (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ata.h (modified) * c/src/libchip/ide/ata_internal.h (modified) * c/src/libchip/ide/ata_util.c (modified) * c/src/libchip/ide/ide_controller.c (modified) * c/src/libchip/ide/ide_ctrl.h (modified) * c/src/libchip/ide/ide_ctrl_cfg.h (modified) * c/src/libchip/ide/ide_ctrl_io.h (modified) * c/src/libchip/network/README (modified) * c/src/libchip/network/README.cs8900 (modified) * c/src/libchip/network/README.dec21140 (modified) * c/src/libchip/network/README.i82586 (modified) * c/src/libchip/network/README.open_eth (modified) * c/src/libchip/network/README.sonic (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/greth.c (modified) * c/src/libchip/network/greth.h (modified) * c/src/libchip/network/smc91111.c (modified) * c/src/libchip/network/smc91111.h (modified) * c/src/libchip/network/smc91111config.h (modified) * c/src/libchip/network/smc91111exp.h (modified) * c/src/libchip/network/sonic.c (modified) * c/src/libchip/network/sonic.h (modified) * c/src/libchip/rtc/README.ds1643 (modified) * c/src/libchip/rtc/README.icm7170 (modified) * c/src/libchip/rtc/README.m48t08 (modified) * c/src/libchip/rtc/README.m48t18 (modified) * c/src/libchip/rtc/README.mc146818a (modified) * c/src/libchip/rtc/STATUS (modified) * c/src/libchip/rtc/ds1375-rtc.h (modified) * c/src/libchip/rtc/ds1375.c (modified) * c/src/libchip/rtc/icm7170.c (modified) * c/src/libchip/rtc/icm7170.h (modified) * c/src/libchip/rtc/icm7170_reg.c (modified) * c/src/libchip/rtc/icm7170_reg2.c (modified) * c/src/libchip/rtc/icm7170_reg4.c (modified) * c/src/libchip/rtc/icm7170_reg8.c (modified) * c/src/libchip/rtc/m48t08.c (modified) * c/src/libchip/rtc/m48t08.h (modified) * c/src/libchip/rtc/m48t08_reg.c (modified) * c/src/libchip/rtc/m48t08_reg2.c (modified) * c/src/libchip/rtc/m48t08_reg4.c (modified) * c/src/libchip/rtc/m48t08_reg8.c (modified) * c/src/libchip/rtc/mc146818a.c (modified) * c/src/libchip/rtc/mc146818a.h (modified) * c/src/libchip/rtc/mc146818a_ioreg.c (modified) * c/src/libchip/rtc/rtc.h (modified) * c/src/libchip/rtc/rtcprobe.c (modified) * c/src/libchip/serial/README (modified) * c/src/libchip/serial/README.mc68681 (modified) * c/src/libchip/serial/README.ns16550 (modified) * c/src/libchip/serial/README.xr88681 (modified) * c/src/libchip/serial/README.z85c30 (modified) * c/src/libchip/serial/STATUS (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_baud.c (modified) * c/src/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681_reg.c (modified) * c/src/libchip/serial/mc68681_reg2.c (modified) * c/src/libchip/serial/mc68681_reg4.c (modified) * c/src/libchip/serial/mc68681_reg8.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.h (modified) * c/src/libchip/serial/ns16550_p.h (modified) * c/src/libchip/serial/serial.h (modified) * c/src/libchip/serial/serprobe.c (modified) * c/src/libchip/serial/sersupp.h (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30_p.h (modified) * c/src/libchip/serial/z85c30_reg.c (modified) * c/src/libchip/shmdr/README (modified) * c/src/libchip/shmdr/addlq.c (modified) * c/src/libchip/shmdr/cnvpkt.c (modified) * c/src/libchip/shmdr/dump.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * c/src/libchip/shmdr/getlq.c (modified) * c/src/libchip/shmdr/getpkt.c (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/initlq.c (modified) * c/src/libchip/shmdr/intr.c (modified) * c/src/libchip/shmdr/mpci.h (modified) * c/src/libchip/shmdr/mpisr.c (modified) * c/src/libchip/shmdr/poll.c (modified) * c/src/libchip/shmdr/receive.c (modified) * c/src/libchip/shmdr/retpkt.c (modified) * c/src/libchip/shmdr/send.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/librtems++/Makefile.am (modified) * c/src/librtems++/README (modified) * c/src/librtems++/configure.ac (modified) * c/src/librtems++/include/rtems++/rtemsEvent.h (modified) * c/src/librtems++/include/rtems++/rtemsInterrupt.h (modified) * c/src/librtems++/include/rtems++/rtemsMessageQueue.h (modified) * c/src/librtems++/include/rtems++/rtemsSemaphore.h (modified) * c/src/librtems++/include/rtems++/rtemsStatusCode.h (modified) * c/src/librtems++/include/rtems++/rtemsTask.h (modified) * c/src/librtems++/include/rtems++/rtemsTaskMode.h (modified) * c/src/librtems++/include/rtems++/rtemsTimer.h (modified) * c/src/librtems++/src/rtemsEvent.cc (modified) * c/src/librtems++/src/rtemsInterrupt.cc (modified) * c/src/librtems++/src/rtemsMessageQueue.cc (modified) * c/src/librtems++/src/rtemsSemaphore.cc (modified) * c/src/librtems++/src/rtemsStatusCode.cc (modified) * c/src/librtems++/src/rtemsTask.cc (modified) * c/src/librtems++/src/rtemsTimer.cc (modified) * c/src/make/Makefile.am (modified) * c/src/make/README (modified) * c/src/make/aclocal/rtems-flags.m4 (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.ac (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/make/directory.cfg (modified) * c/src/make/host.cfg.in (modified) * c/src/make/leaf.cfg (modified) * c/src/make/lib.cfg (modified) * c/src/make/target.cfg.in (modified) * c/src/support/Makefile.am (modified) * c/src/support/version.c (modified) * c/src/wrapup/Makefile.am (modified) * configure.ac (modified) * contrib/mingw/README (modified) * contrib/mingw/ba-wrap.sh (modified) * contrib/mingw/build-autotools.sh (modified) * contrib/mingw/build-exes.sh (modified) * contrib/mingw/build-rpms.sh (modified) * contrib/mingw/build.sh (modified) * contrib/mingw/instance-check.nsi (modified) * contrib/mingw/mingw-path.nsi (modified) * contrib/mingw/msys-path.nsi (modified) * contrib/mingw/options.nsi (modified) * contrib/mingw/rtems-autotools.nsi (modified) * contrib/mingw/rtems-tools.nsi (modified) * contrib/mingw/upload.sh (modified) * contrib/rtemsrpms/Makefile.am (modified) * contrib/rtemsrpms/configure.ac (modified) * cpukit/Makefile.am (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/canonicalize-tools.m4 (modified) * cpukit/aclocal/check-func.m4 (modified) * cpukit/aclocal/check-multiprocessing.m4 (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/aclocal/check-newlib.m4 (modified) * cpukit/aclocal/check-posix.m4 (modified) * cpukit/aclocal/check-rtems-debug.m4 (modified) * cpukit/aclocal/check-smp.m4 (modified) * cpukit/aclocal/check-tool.m4 (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/aclocal/enable-networking.m4 (modified) * cpukit/aclocal/enable-posix.m4 (modified) * cpukit/aclocal/enable-rtems-debug.m4 (modified) * cpukit/aclocal/enable-smp.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/gcc-pipe.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/aclocal/prog-ccas.m4 (modified) * cpukit/aclocal/rtems-ampolish.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/automake/compile.am (modified) * cpukit/automake/local.am (modified) * cpukit/automake/multilib.am (modified) * cpukit/automake/subdirs.am (modified) * cpukit/configure.ac (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/ftpd/ftpd.h (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/btimer.h (modified) * cpukit/include/rtems/concat.h (modified) * cpukit/include/rtems/endian.h (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/include/rtems/irq.h (modified) * cpukit/include/rtems/pci.h (modified) * cpukit/include/rtems/userenv.h (modified) * cpukit/include/sys/priority.h (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/README (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/include/rtems/flashdisk.h (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libblock/include/rtems/nvdisk-sram.h (modified) * cpukit/libblock/include/rtems/nvdisk.h (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-config.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/clockdrv.h (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/iosupp.h (modified) * cpukit/libcsupport/include/motorola/mc68230.h (modified) * cpukit/libcsupport/include/motorola/mc68681.h (modified) * cpukit/libcsupport/include/ringbuf.h (modified) * cpukit/libcsupport/include/rtc.h (modified) * cpukit/libcsupport/include/rtems/assoc.h (modified) * cpukit/libcsupport/include/rtems/error.h (modified) * cpukit/libcsupport/include/rtems/framebuffer.h (modified) * cpukit/libcsupport/include/rtems/gxx_wrappers.h (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/rtems/malloc.h (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/include/rtems/watchdogdrv.h (modified) * cpukit/libcsupport/include/spurious.h (modified) * cpukit/libcsupport/include/sys/ioccom.h (modified) * cpukit/libcsupport/include/sys/ioctl.h (modified) * cpukit/libcsupport/include/sys/sockio.h (modified) * cpukit/libcsupport/include/sys/statvfs.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/include/sys/utsname.h (modified) * cpukit/libcsupport/include/timerdrv.h (modified) * cpukit/libcsupport/include/vmeintr.h (modified) * cpukit/libcsupport/include/zilog/z8036.h (modified) * cpukit/libcsupport/include/zilog/z8530.h (modified) * cpukit/libcsupport/include/zilog/z8536.h (modified) * cpukit/libcsupport/src/README (modified) * cpukit/libcsupport/src/__assert.c (modified) * cpukit/libcsupport/src/__getpid.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libcsupport/src/_calloc_r.c (modified) * cpukit/libcsupport/src/_free_r.c (modified) * cpukit/libcsupport/src/_malloc_r.c (modified) * cpukit/libcsupport/src/_realloc_r.c (modified) * cpukit/libcsupport/src/_rename_r.c (modified) * cpukit/libcsupport/src/access.c (modified) * cpukit/libcsupport/src/assoclocalbyname.c (modified) * cpukit/libcsupport/src/assoclocalbyremote.c (modified) * cpukit/libcsupport/src/assoclocalbyremotebitfield.c (modified) * cpukit/libcsupport/src/assocnamebad.c (modified) * cpukit/libcsupport/src/assocnamebylocal.c (modified) * cpukit/libcsupport/src/assocnamebylocalbitfield.c (modified) * cpukit/libcsupport/src/assocnamebyremote.c (modified) * cpukit/libcsupport/src/assocnamebyremotebitfield.c (modified) * cpukit/libcsupport/src/assocptrbylocal.c (modified) * cpukit/libcsupport/src/assocptrbyname.c (modified) * cpukit/libcsupport/src/assocptrbyremote.c (modified) * cpukit/libcsupport/src/assocremotebylocal.c (modified) * cpukit/libcsupport/src/assocremotebylocalbitfield.c (modified) * cpukit/libcsupport/src/assocremotebyname.c (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/calloc.c (modified) * cpukit/libcsupport/src/cfgetispeed.c (modified) * cpukit/libcsupport/src/cfgetospeed.c (modified) * cpukit/libcsupport/src/cfsetispeed.c (modified) * cpukit/libcsupport/src/cfsetospeed.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chmod.c (modified) * cpukit/libcsupport/src/chown.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/ctermid.c (modified) * cpukit/libcsupport/src/dup.c (modified) * cpukit/libcsupport/src/dup2.c (modified) * cpukit/libcsupport/src/envlock.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libcsupport/src/fchdir.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fchown.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/fpathconf.c (modified) * cpukit/libcsupport/src/free.c (modified) * cpukit/libcsupport/src/freenode.c (modified) * cpukit/libcsupport/src/fstat.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/getchark.c (modified) * cpukit/libcsupport/src/getcwd.c (modified) * cpukit/libcsupport/src/getdents.c (modified) * cpukit/libcsupport/src/getegid.c (modified) * cpukit/libcsupport/src/geteuid.c (modified) * cpukit/libcsupport/src/getgid.c (modified) * cpukit/libcsupport/src/getgroups.c (modified) * cpukit/libcsupport/src/getlogin.c (modified) * cpukit/libcsupport/src/getpagesize.c (modified) * cpukit/libcsupport/src/getpgrp.c (modified) * cpukit/libcsupport/src/getpid.c (modified) * cpukit/libcsupport/src/getppid.c (modified) * cpukit/libcsupport/src/getpwent.c (modified) * cpukit/libcsupport/src/getrusage.c (modified) * cpukit/libcsupport/src/getuid.c (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/isatty.c (modified) * cpukit/libcsupport/src/isatty_r.c (modified) * cpukit/libcsupport/src/issetugid.c (modified) * cpukit/libcsupport/src/kill_noposix.c (modified) * cpukit/libcsupport/src/lchown.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/lstat.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/malloc_deferred.c (modified) * cpukit/libcsupport/src/malloc_dirtier.c (modified) * cpukit/libcsupport/src/malloc_get_statistics.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/malloc_p.h (modified) * cpukit/libcsupport/src/malloc_report_statistics.c (modified) * cpukit/libcsupport/src/malloc_report_statistics_plugin.c (modified) * cpukit/libcsupport/src/malloc_sbrk_helpers.c (modified) * cpukit/libcsupport/src/malloc_statistics_helpers.c (modified) * cpukit/libcsupport/src/malloc_walk.c (modified) * cpukit/libcsupport/src/mallocfreespace.c (modified) * cpukit/libcsupport/src/mallocgetheapptr.c (modified) * cpukit/libcsupport/src/mallocinfo.c (modified) * cpukit/libcsupport/src/mallocsetheapptr.c (modified) * cpukit/libcsupport/src/mkdir.c (modified) * cpukit/libcsupport/src/mkfifo.c (modified) * cpukit/libcsupport/src/mknod.c (modified) * cpukit/libcsupport/src/mount-mgr.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/libcsupport/src/newlibc_init.c (modified) * cpukit/libcsupport/src/newlibc_reent.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/open_dev_console.c (modified) * cpukit/libcsupport/src/pathconf.c (modified) * cpukit/libcsupport/src/pipe.c (modified) * cpukit/libcsupport/src/posix_memalign.c (modified) * cpukit/libcsupport/src/printk.c (modified) * cpukit/libcsupport/src/printk_plugin.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/putk.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/readdir_r.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/readv.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/rtems_heap_extend.c (modified) * cpukit/libcsupport/src/rtems_malloc.c (modified) * cpukit/libcsupport/src/rtems_memalign.c (modified) * cpukit/libcsupport/src/setegid.c (modified) * cpukit/libcsupport/src/seteuid.c (modified) * cpukit/libcsupport/src/setgid.c (modified) * cpukit/libcsupport/src/setpgid.c (modified) * cpukit/libcsupport/src/setsid.c (modified) * cpukit/libcsupport/src/setuid.c (modified) * cpukit/libcsupport/src/stat.c (modified) * cpukit/libcsupport/src/statvfs.c (modified) * cpukit/libcsupport/src/symlink.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libcsupport/src/tcdrain.c (modified) * cpukit/libcsupport/src/tcflow.c (modified) * cpukit/libcsupport/src/tcflush.c (modified) * cpukit/libcsupport/src/tcgetattr.c (modified) * cpukit/libcsupport/src/tcgetpgrp.c (modified) * cpukit/libcsupport/src/tcsendbreak.c (modified) * cpukit/libcsupport/src/tcsetattr.c (modified) * cpukit/libcsupport/src/tcsetpgrp.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_baud2index.c (modified) * cpukit/libcsupport/src/termios_baud2num.c (modified) * cpukit/libcsupport/src/termios_baudtable.c (modified) * cpukit/libcsupport/src/termios_num2baud.c (modified) * cpukit/libcsupport/src/termios_setinitialbaud.c (modified) * cpukit/libcsupport/src/termiosinitialize.c (modified) * cpukit/libcsupport/src/truncate.c (modified) * cpukit/libcsupport/src/ttyname.c (modified) * cpukit/libcsupport/src/umask.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libcsupport/src/utime.c (modified) * cpukit/libcsupport/src/utimes.c (modified) * cpukit/libcsupport/src/utsname.c (modified) * cpukit/libcsupport/src/vprintk.c (modified) * cpukit/libcsupport/src/write.c (modified) * cpukit/libcsupport/src/write_r.c (modified) * cpukit/libcsupport/src/writev.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/README (modified) * cpukit/libfs/src/defaults/default_chown.c (modified) * cpukit/libfs/src/defaults/default_close.c (modified) * cpukit/libfs/src/defaults/default_fchmod.c (modified) * cpukit/libfs/src/defaults/default_fcntl.c (modified) * cpukit/libfs/src/defaults/default_freenode.c (modified) * cpukit/libfs/src/defaults/default_fsmount.c (modified) * cpukit/libfs/src/defaults/default_fstat.c (modified) * cpukit/libfs/src/defaults/default_fsunmount.c (modified) * cpukit/libfs/src/defaults/default_fsync.c (modified) * cpukit/libfs/src/defaults/default_ftruncate.c (modified) * cpukit/libfs/src/defaults/default_ioctl.c (modified) * cpukit/libfs/src/defaults/default_link.c (modified) * cpukit/libfs/src/defaults/default_lseek.c (modified) * cpukit/libfs/src/defaults/default_mknod.c (modified) * cpukit/libfs/src/defaults/default_mount.c (modified) * cpukit/libfs/src/defaults/default_open.c (modified) * cpukit/libfs/src/defaults/default_read.c (modified) * cpukit/libfs/src/defaults/default_readlink.c (modified) * cpukit/libfs/src/defaults/default_rename.c (modified) * cpukit/libfs/src/defaults/default_rmnod.c (modified) * cpukit/libfs/src/defaults/default_statvfs.c (modified) * cpukit/libfs/src/defaults/default_symlink.c (modified) * cpukit/libfs/src/defaults/default_unmount.c (modified) * cpukit/libfs/src/defaults/default_utime.c (modified) * cpukit/libfs/src/defaults/default_write.c (modified) * cpukit/libfs/src/devfs/devclose.c (modified) * cpukit/libfs/src/devfs/devfs_eval.c (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/devfs/devfs_mknod.c (modified) * cpukit/libfs/src/devfs/devfs_node_type.c (modified) * cpukit/libfs/src/devfs/devfs_show.c (modified) * cpukit/libfs/src/devfs/devioctl.c (modified) * cpukit/libfs/src/devfs/devopen.c (modified) * cpukit/libfs/src/devfs/devread.c (modified) * cpukit/libfs/src/devfs/devstat.c (modified) * cpukit/libfs/src/devfs/devwrite.c (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/fat_file.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_free.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) * cpukit/libfs/src/dosfs/msdos_node_type.c (modified) * cpukit/libfs/src/dosfs/msdos_rename.c (modified) * cpukit/libfs/src/dosfs/msdos_rmnod.c (modified) * cpukit/libfs/src/imfs/deviceerrno.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_chown.c (modified) * cpukit/libfs/src/imfs/imfs_config.c (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_ntype.c (modified) * cpukit/libfs/src/imfs/imfs_readlink.c (modified) * cpukit/libfs/src/imfs/imfs_rename.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/nfsclient/Makefile.am (modified) * cpukit/libfs/src/nfsclient/src/dirutils.c (modified) * cpukit/libfs/src/nfsclient/src/librtemsNfs.h (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/nfsclient/src/nfsTest.c (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) * cpukit/libfs/src/nfsclient/src/rpcio.h (modified) * cpukit/libfs/src/nfsclient/src/sock_mbuf.c (modified) * cpukit/libfs/src/nfsclient/src/xdr_mbuf.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libfs/src/pipe/pipe.c (modified) * cpukit/libfs/src/pipe/pipe.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps-ut.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-block-pos.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-data.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir-hash.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system-fwd.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-mutex.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-mutex.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-trace.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-trace.h (modified) * cpukit/libfs/src/rfs/rtems-rfs.h (modified) * cpukit/libgnat/Makefile.am (modified) * cpukit/libgnat/ada_intrsupp.c (modified) * cpukit/libgnat/adasupp.c (modified) * cpukit/libi2c/Makefile.am (modified) * cpukit/libi2c/README_libi2c (modified) * cpukit/libi2c/libi2c.c (modified) * cpukit/libi2c/libi2c.h (modified) * cpukit/libmd/Makefile.am (modified) * cpukit/libmd/md4.h (modified) * cpukit/libmd/md5.c (modified) * cpukit/libmisc/README (modified) * cpukit/libmisc/bspcmdline/bspcmdline.h (modified) * cpukit/libmisc/bspcmdline/bspcmdline_get.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparam.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c (modified) * cpukit/libmisc/capture/README (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture-cli.h (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/capture/capture.h (modified) * cpukit/libmisc/cpuuse/README (modified) * cpukit/libmisc/cpuuse/cpuusagedata.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libmisc/cpuuse/cpuuse.h (modified) * cpukit/libmisc/devnull/devnull.c (modified) * cpukit/libmisc/devnull/devnull.h (modified) * cpukit/libmisc/devnull/devzero.c (modified) * cpukit/libmisc/devnull/devzero.h (modified) * cpukit/libmisc/dummy/dummy-networking.c (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/dumpbuf/dumpbuf.c (modified) * cpukit/libmisc/dumpbuf/dumpbuf.h (modified) * cpukit/libmisc/fb/fb.h (modified) * cpukit/libmisc/fb/mw_print.c (modified) * cpukit/libmisc/fb/mw_uid.c (modified) * cpukit/libmisc/fb/mw_uid.h (modified) * cpukit/libmisc/monitor/README (modified) * cpukit/libmisc/monitor/mon-command.c (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/libmisc/monitor/mon-driver.c (modified) * cpukit/libmisc/monitor/mon-editor.c (modified) * cpukit/libmisc/monitor/mon-extension.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/libmisc/monitor/mon-manager.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-mpci.c (modified) * cpukit/libmisc/monitor/mon-network.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-part.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/libmisc/monitor/mon-queue.c (modified) * cpukit/libmisc/monitor/mon-region.c (modified) * cpukit/libmisc/monitor/mon-sema.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/libmisc/monitor/symbols.h (modified) * cpukit/libmisc/mouse/README (modified) * cpukit/libmisc/mouse/mouse_parser.c (modified) * cpukit/libmisc/mouse/mouse_parser.h (modified) * cpukit/libmisc/mouse/serial_mouse.c (modified) * cpukit/libmisc/mouse/serial_mouse.h (modified) * cpukit/libmisc/serdbg/README (modified) * cpukit/libmisc/serdbg/serdbg.c (modified) * cpukit/libmisc/serdbg/serdbg.h (modified) * cpukit/libmisc/serdbg/serdbgcnf.h (modified) * cpukit/libmisc/serdbg/termios_printk.h (modified) * cpukit/libmisc/serdbg/termios_printk_cnf.h (modified) * cpukit/libmisc/shell/README (modified) * cpukit/libmisc/shell/cat_file.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/main_alias.c (modified) * cpukit/libmisc/shell/main_blksync.c (modified) * cpukit/libmisc/shell/main_cat.c (modified) * cpukit/libmisc/shell/main_cd.c (modified) * cpukit/libmisc/shell/main_chdir.c (modified) * cpukit/libmisc/shell/main_chmod.c (modified) * cpukit/libmisc/shell/main_chroot.c (modified) * cpukit/libmisc/shell/main_cpuuse.c (modified) * cpukit/libmisc/shell/main_date.c (modified) * cpukit/libmisc/shell/main_debugrfs.c (modified) * cpukit/libmisc/shell/main_dir.c (modified) * cpukit/libmisc/shell/main_echo.c (modified) * cpukit/libmisc/shell/main_exit.c (modified) * cpukit/libmisc/shell/main_halt.c (modified) * cpukit/libmisc/shell/main_help.c (modified) * cpukit/libmisc/shell/main_id.c (modified) * cpukit/libmisc/shell/main_ifconfig.c (modified) * cpukit/libmisc/shell/main_logoff.c (modified) * cpukit/libmisc/shell/main_mallocinfo.c (modified) * cpukit/libmisc/shell/main_mfill.c (modified) * cpukit/libmisc/shell/main_mkdir.c (modified) * cpukit/libmisc/shell/main_mkrfs.c (modified) * cpukit/libmisc/shell/main_mmove.c (modified) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/main_mount_nfs.c (modified) * cpukit/libmisc/shell/main_msdosfmt.c (modified) * cpukit/libmisc/shell/main_netstats.c (modified) * cpukit/libmisc/shell/main_perioduse.c (modified) * cpukit/libmisc/shell/main_pwd.c (modified) * cpukit/libmisc/shell/main_rmdir.c (modified) * cpukit/libmisc/shell/main_route.c (modified) * cpukit/libmisc/shell/main_sleep.c (modified) * cpukit/libmisc/shell/main_stackuse.c (modified) * cpukit/libmisc/shell/main_time.c (modified) * cpukit/libmisc/shell/main_tty.c (modified) * cpukit/libmisc/shell/main_umask.c (modified) * cpukit/libmisc/shell/main_unmount.c (modified) * cpukit/libmisc/shell/main_whoami.c (modified) * cpukit/libmisc/shell/main_wkspaceinfo.c (modified) * cpukit/libmisc/shell/print_heapinfo.c (modified) * cpukit/libmisc/shell/shell-wait-for-input.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) * cpukit/libmisc/shell/shell_getchar.c (modified) * cpukit/libmisc/shell/shell_getprompt.c (modified) * cpukit/libmisc/shell/shell_makeargs.c (modified) * cpukit/libmisc/shell/shell_script.c (modified) * cpukit/libmisc/shell/shellconfig.c (modified) * cpukit/libmisc/shell/write_file.c (modified) * cpukit/libmisc/stackchk/README (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) * cpukit/libmisc/stringto/stringto.h (modified) * cpukit/libmisc/stringto/stringtodouble.c (modified) * cpukit/libmisc/stringto/stringtofloat.c (modified) * cpukit/libmisc/stringto/stringtoint.c (modified) * cpukit/libmisc/stringto/stringtolong.c (modified) * cpukit/libmisc/stringto/stringtolongdouble.c (modified) * cpukit/libmisc/stringto/stringtolonglong.c (modified) * cpukit/libmisc/stringto/stringtopointer.c (modified) * cpukit/libmisc/stringto/stringtounsignedchar.c (modified) * cpukit/libmisc/stringto/stringtounsignedint.c (modified) * cpukit/libmisc/stringto/stringtounsignedlong.c (modified) * cpukit/libmisc/stringto/stringtounsignedlonglong.c (modified) * cpukit/libmisc/untar/README (modified) * cpukit/libmisc/untar/untar.c (modified) * cpukit/libmisc/untar/untar.h (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/README (modified) * cpukit/libnetworking/arpa/ftp.h (modified) * cpukit/libnetworking/arpa/inet.h (modified) * cpukit/libnetworking/arpa/nameser.h (modified) * cpukit/libnetworking/bpfilter.h (modified) * cpukit/libnetworking/kern/kern_mib.c (modified) * cpukit/libnetworking/kern/kern_subr.c (modified) * cpukit/libnetworking/kern/uipc_domain.c (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/lib/README (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/getprotoby.c (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/lib/syslog.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/libc/byteorder.3 (modified) * cpukit/libnetworking/libc/ethers.3 (modified) * cpukit/libnetworking/libc/gethostbyname.3 (modified) * cpukit/libnetworking/libc/gethostname.c (modified) * cpukit/libnetworking/libc/getnetent.3 (modified) * cpukit/libnetworking/libc/getproto.c (modified) * cpukit/libnetworking/libc/getprotoent.3 (modified) * cpukit/libnetworking/libc/getprotoent.c (modified) * cpukit/libnetworking/libc/getprotoname.c (modified) * cpukit/libnetworking/libc/getservbyname.c (modified) * cpukit/libnetworking/libc/getservbyport.c (modified) * cpukit/libnetworking/libc/getservent.3 (modified) * cpukit/libnetworking/libc/getservent.c (modified) * cpukit/libnetworking/libc/inet.3 (modified) * cpukit/libnetworking/libc/inet_lnaof.c (modified) * cpukit/libnetworking/libc/inet_makeaddr.c (modified) * cpukit/libnetworking/libc/inet_netof.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/libc/inet_ntoa.c (modified) * cpukit/libnetworking/libc/linkaddr.3 (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/ns.3 (modified) * cpukit/libnetworking/libc/ns_addr.c (modified) * cpukit/libnetworking/libc/ns_ntoa.c (modified) * cpukit/libnetworking/libc/rcmd.3 (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/recv.c (modified) * cpukit/libnetworking/libc/res_config.h (modified) * cpukit/libnetworking/libc/res_stubs.c (modified) * cpukit/libnetworking/libc/resolver.3 (modified) * cpukit/libnetworking/libc/send.c (modified) * cpukit/libnetworking/libc/strsep.c (modified) * cpukit/libnetworking/loop.h (modified) * cpukit/libnetworking/machine/cpu.h (modified) * cpukit/libnetworking/machine/cpufunc.h (modified) * cpukit/libnetworking/machine/limits.h (modified) * cpukit/libnetworking/machine/vmparam.h (modified) * cpukit/libnetworking/net/bpf.h (modified) * cpukit/libnetworking/net/ethernet.h (modified) * cpukit/libnetworking/net/if.c (modified) * cpukit/libnetworking/net/if.h (modified) * cpukit/libnetworking/net/if_arp.h (modified) * cpukit/libnetworking/net/if_dl.h (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/if_llc.h (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/if_ppp.h (modified) * cpukit/libnetworking/net/if_pppvar.h (modified) * cpukit/libnetworking/net/if_types.h (modified) * cpukit/libnetworking/net/if_var.h (modified) * cpukit/libnetworking/net/netisr.h (modified) * cpukit/libnetworking/net/ppp_comp.h (modified) * cpukit/libnetworking/net/ppp_defs.h (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/libnetworking/net/raw_cb.c (modified) * cpukit/libnetworking/net/raw_cb.h (modified) * cpukit/libnetworking/net/raw_usrreq.c (modified) * cpukit/libnetworking/net/route.h (modified) * cpukit/libnetworking/net/rtsock.c (modified) * cpukit/libnetworking/netdb.h (modified) * cpukit/libnetworking/netinet/icmp_var.h (modified) * cpukit/libnetworking/netinet/if_ether.c (modified) * cpukit/libnetworking/netinet/if_ether.h (modified) * cpukit/libnetworking/netinet/igmp.c (modified) * cpukit/libnetworking/netinet/in.h (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum_i386.h (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.h (modified) * cpukit/libnetworking/netinet/in_cksum_powerpc.h (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/in_pcb.h (modified) * cpukit/libnetworking/netinet/in_rmx.c (modified) * cpukit/libnetworking/netinet/in_systm.h (modified) * cpukit/libnetworking/netinet/ip.h (modified) * cpukit/libnetworking/netinet/ip_divert.c (modified) * cpukit/libnetworking/netinet/ip_icmp.c (modified) * cpukit/libnetworking/netinet/ip_icmp.h (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/netinet/ip_mroute.h (modified) * cpukit/libnetworking/netinet/ip_output.c (modified) * cpukit/libnetworking/netinet/ip_var.h (modified) * cpukit/libnetworking/netinet/raw_ip.c (modified) * cpukit/libnetworking/netinet/tcp.h (modified) * cpukit/libnetworking/netinet/tcp_debug.c (modified) * cpukit/libnetworking/netinet/tcp_debug.h (modified) * cpukit/libnetworking/netinet/tcp_fsm.h (modified) * cpukit/libnetworking/netinet/tcp_seq.h (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) * cpukit/libnetworking/netinet/tcpip.h (modified) * cpukit/libnetworking/netinet/udp.h (modified) * cpukit/libnetworking/netinet/udp_var.h (modified) * cpukit/libnetworking/nfs/nfsproto.h (modified) * cpukit/libnetworking/nfs/rpcv2.h (modified) * cpukit/libnetworking/nfs/xdr_subs.h (modified) * cpukit/libnetworking/nfsclient/nfsargs.h (modified) * cpukit/libnetworking/nfsclient/nfsdiskless.h (modified) * cpukit/libnetworking/opt_atalk.h (modified) * cpukit/libnetworking/opt_bdg.h (modified) * cpukit/libnetworking/opt_compat.h (modified) * cpukit/libnetworking/opt_inet.h (modified) * cpukit/libnetworking/opt_inet6.h (modified) * cpukit/libnetworking/opt_ipfw.h (modified) * cpukit/libnetworking/opt_ipsec.h (modified) * cpukit/libnetworking/opt_ipx.h (modified) * cpukit/libnetworking/opt_mac.h (modified) * cpukit/libnetworking/opt_mrouting.h (modified) * cpukit/libnetworking/opt_netgraph.h (modified) * cpukit/libnetworking/opt_ppp.h (modified) * cpukit/libnetworking/opt_tcpdebug.h (modified) * cpukit/libnetworking/rtems/bsdnet/_types.h (modified) * cpukit/libnetworking/rtems/bsdnet/servers.h (modified) * cpukit/libnetworking/rtems/dhcp.h (modified) * cpukit/libnetworking/rtems/ftpfs.h (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_malloc_starvation.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_malloc_mbuf.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.h (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_showipstat.c (modified) * cpukit/libnetworking/rtems/rtems_showmbuf.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showudpstat.c (modified) * cpukit/libnetworking/rtems/rtems_socketpair.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/sghostname.c (modified) * cpukit/libnetworking/rtems/tftp.h (modified) * cpukit/libnetworking/sys/conf.h (modified) * cpukit/libnetworking/sys/domain.h (modified) * cpukit/libnetworking/sys/kernel.h (modified) * cpukit/libnetworking/sys/libkern.h (modified) * cpukit/libnetworking/sys/malloc.h (modified) * cpukit/libnetworking/sys/mbuf.h (modified) * cpukit/libnetworking/sys/mount.h (modified) * cpukit/libnetworking/sys/proc.h (modified) * cpukit/libnetworking/sys/reboot.h (modified) * cpukit/libnetworking/sys/resourcevar.h (modified) * cpukit/libnetworking/sys/select.h (modified) * cpukit/libnetworking/sys/signalvar.h (modified) * cpukit/libnetworking/sys/socket.h (modified) * cpukit/libnetworking/sys/syslog.h (modified) * cpukit/libnetworking/sys/systm.h (modified) * cpukit/libnetworking/sys/ttydefaults.h (modified) * cpukit/libnetworking/sys/ucred.h (modified) * cpukit/libnetworking/sys/uio.h (modified) * cpukit/libnetworking/sys/un.h (modified) * cpukit/libnetworking/syslog.h (modified) * cpukit/libnetworking/vm/vm_extern.h (modified) * cpukit/libnetworking/vm/vm_kern.h (modified) * cpukit/libnetworking/vm/vm_param.h (modified) * cpukit/libqos/qreslib.h (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/rpc_com.h (modified) * cpukit/librpc/include/rpc/rpc_msg.h (modified) * cpukit/librpc/src/rpc/rtems_rpc.c (modified) * cpukit/mghttpd/mongoose.1 (modified) * cpukit/mghttpd/mongoose.c (modified) * cpukit/mghttpd/mongoose.h (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/aio.h (modified) * cpukit/posix/include/mqueue.h (modified) * cpukit/posix/include/rtems/posix/aio_misc.h (modified) * cpukit/posix/include/rtems/posix/barrier.h (modified) * cpukit/posix/include/rtems/posix/cancel.h (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/priority.h (modified) * cpukit/posix/include/rtems/posix/psignal.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/rwlock.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/include/rtems/posix/sigset.h (modified) * cpukit/posix/include/rtems/posix/spinlock.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/include/rtems/posix/time.h (modified) * cpukit/posix/include/rtems/posix/timer.h (modified) * cpukit/posix/include/semaphore.h (modified) * cpukit/posix/inline/rtems/posix/barrier.inl (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/inline/rtems/posix/key.inl (modified) * cpukit/posix/inline/rtems/posix/mqueue.inl (modified) * cpukit/posix/inline/rtems/posix/mutex.inl (modified) * cpukit/posix/inline/rtems/posix/priority.inl (modified) * cpukit/posix/inline/rtems/posix/pthread.inl (modified) * cpukit/posix/inline/rtems/posix/rwlock.inl (modified) * cpukit/posix/inline/rtems/posix/semaphore.inl (modified) * cpukit/posix/inline/rtems/posix/spinlock.inl (modified) * cpukit/posix/inline/rtems/posix/timer.inl (modified) * cpukit/posix/src/README.mqueue (modified) * cpukit/posix/src/_execve.c (modified) * cpukit/posix/src/adjtime.c (modified) * cpukit/posix/src/aio_cancel.c (modified) * cpukit/posix/src/aio_error.c (modified) * cpukit/posix/src/aio_fsync.c (modified) * cpukit/posix/src/aio_misc.c (modified) * cpukit/posix/src/aio_read.c (modified) * cpukit/posix/src/aio_return.c (modified) * cpukit/posix/src/aio_suspend.c (modified) * cpukit/posix/src/aio_write.c (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/barrierattrdestroy.c (modified) * cpukit/posix/src/barrierattrgetpshared.c (modified) * cpukit/posix/src/barrierattrinit.c (modified) * cpukit/posix/src/barrierattrsetpshared.c (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/canceleval.c (modified) * cpukit/posix/src/cancelrun.c (modified) * cpukit/posix/src/cleanuppop.c (modified) * cpukit/posix/src/cleanuppush.c (modified) * cpukit/posix/src/clockgetcpuclockid.c (modified) * cpukit/posix/src/clockgetenableattr.c (modified) * cpukit/posix/src/clockgetres.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/clocksetenableattr.c (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/posix/src/cond.c (modified) * cpukit/posix/src/condattrdestroy.c (modified) * cpukit/posix/src/condattrgetpshared.c (modified) * cpukit/posix/src/condattrinit.c (modified) * cpukit/posix/src/condattrsetpshared.c (modified) * cpukit/posix/src/condbroadcast.c (modified) * cpukit/posix/src/conddefaultattributes.c (modified) * cpukit/posix/src/conddestroy.c (modified) * cpukit/posix/src/condget.c (modified) * cpukit/posix/src/condinit.c (modified) * cpukit/posix/src/condsignal.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condtimedwait.c (modified) * cpukit/posix/src/condwait.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/execl.c (modified) * cpukit/posix/src/execle.c (modified) * cpukit/posix/src/execlp.c (modified) * cpukit/posix/src/execv.c (modified) * cpukit/posix/src/execve.c (modified) * cpukit/posix/src/execvp.c (modified) * cpukit/posix/src/fork.c (modified) * cpukit/posix/src/getitimer.c (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keydelete.c (modified) * cpukit/posix/src/keyfreememory.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keyrundestructors.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/kill_r.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/lio_listio.c (modified) * cpukit/posix/src/mprotect.c (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueueclose.c (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuegetattr.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/mqueuereceive.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesend.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mqueuesetattr.c (modified) * cpukit/posix/src/mqueuetimedreceive.c (modified) * cpukit/posix/src/mqueuetimedsend.c (modified) * cpukit/posix/src/mqueuetranslatereturncode.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/mutex.c (modified) * cpukit/posix/src/mutexattrdestroy.c (modified) * cpukit/posix/src/mutexattrgetprioceiling.c (modified) * cpukit/posix/src/mutexattrgetprotocol.c (modified) * cpukit/posix/src/mutexattrgetpshared.c (modified) * cpukit/posix/src/mutexattrgettype.c (modified) * cpukit/posix/src/mutexattrinit.c (modified) * cpukit/posix/src/mutexattrsetprioceiling.c (modified) * cpukit/posix/src/mutexattrsetprotocol.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/mutexattrsettype.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexget.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlock.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutextimedlock.c (modified) * cpukit/posix/src/mutextranslatereturncode.c (modified) * cpukit/posix/src/mutextrylock.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/pause.c (modified) * cpukit/posix/src/pbarrier.c (modified) * cpukit/posix/src/pbarrierdestroy.c (modified) * cpukit/posix/src/pbarrierinit.c (modified) * cpukit/posix/src/pbarriertranslatereturncode.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/posix/src/posixtimespecabsolutetimeout.c (modified) * cpukit/posix/src/prwlock.c (modified) * cpukit/posix/src/prwlockdestroy.c (modified) * cpukit/posix/src/prwlockinit.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktranslatereturncode.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalchecksignal.c (modified) * cpukit/posix/src/psignalclearprocesssignals.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalsetprocesssignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pspin.c (modified) * cpukit/posix/src/pspindestroy.c (modified) * cpukit/posix/src/pspininit.c (modified) * cpukit/posix/src/pspinlock.c (modified) * cpukit/posix/src/pspinlocktranslatereturncode.c (modified) * cpukit/posix/src/pspintrylock.c (modified) * cpukit/posix/src/pspinunlock.c (modified) * cpukit/posix/src/psxnametoid.c (modified) * cpukit/posix/src/psxpriorityisvalid.c (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadatfork.c (modified) * cpukit/posix/src/pthreadattrdestroy.c (modified) * cpukit/posix/src/pthreadattrgetdetachstate.c (modified) * cpukit/posix/src/pthreadattrgetguardsize.c (modified) * cpukit/posix/src/pthreadattrgetinheritsched.c (modified) * cpukit/posix/src/pthreadattrgetschedparam.c (modified) * cpukit/posix/src/pthreadattrgetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrgetscope.c (modified) * cpukit/posix/src/pthreadattrgetstack.c (modified) * cpukit/posix/src/pthreadattrgetstackaddr.c (modified) * cpukit/posix/src/pthreadattrgetstacksize.c (modified) * cpukit/posix/src/pthreadattrinit.c (modified) * cpukit/posix/src/pthreadattrsetdetachstate.c (modified) * cpukit/posix/src/pthreadattrsetguardsize.c (modified) * cpukit/posix/src/pthreadattrsetinheritsched.c (modified) * cpukit/posix/src/pthreadattrsetschedparam.c (modified) * cpukit/posix/src/pthreadattrsetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrsetscope.c (modified) * cpukit/posix/src/pthreadattrsetstack.c (modified) * cpukit/posix/src/pthreadattrsetstackaddr.c (modified) * cpukit/posix/src/pthreadattrsetstacksize.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetcpuclockid.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadonce.c (modified) * cpukit/posix/src/pthreadself.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/rwlockattrdestroy.c (modified) * cpukit/posix/src/rwlockattrgetpshared.c (modified) * cpukit/posix/src/rwlockattrinit.c (modified) * cpukit/posix/src/rwlockattrsetpshared.c (modified) * cpukit/posix/src/sched_getparam.c (modified) * cpukit/posix/src/sched_getprioritymax.c (modified) * cpukit/posix/src/sched_getprioritymin.c (modified) * cpukit/posix/src/sched_getscheduler.c (modified) * cpukit/posix/src/sched_rr_get_interval.c (modified) * cpukit/posix/src/sched_setparam.c (modified) * cpukit/posix/src/sched_setscheduler.c (modified) * cpukit/posix/src/sched_yield.c (modified) * cpukit/posix/src/semaphore.c (modified) * cpukit/posix/src/semaphorecreatesupp.c (modified) * cpukit/posix/src/semaphoredeletesupp.c (modified) * cpukit/posix/src/semaphoretranslatereturncode.c (modified) * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/posix/src/semclose.c (modified) * cpukit/posix/src/semdestroy.c (modified) * cpukit/posix/src/semgetvalue.c (modified) * cpukit/posix/src/seminit.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semtimedwait.c (modified) * cpukit/posix/src/semtrywait.c (modified) * cpukit/posix/src/semunlink.c (modified) * cpukit/posix/src/semwait.c (modified) * cpukit/posix/src/setcancelstate.c (modified) * cpukit/posix/src/setcanceltype.c (modified) * cpukit/posix/src/setitimer.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigaddset.c (modified) * cpukit/posix/src/sigdelset.c (modified) * cpukit/posix/src/sigemptyset.c (modified) * cpukit/posix/src/sigfillset.c (modified) * cpukit/posix/src/sigismember.c (modified) * cpukit/posix/src/signal_2.c (modified) * cpukit/posix/src/sigpending.c (modified) * cpukit/posix/src/sigprocmask.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/sigsuspend.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/sigwait.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) * cpukit/posix/src/sysconf.c (modified) * cpukit/posix/src/testcancel.c (modified) * cpukit/posix/src/timercreate.c (modified) * cpukit/posix/src/timerdelete.c (modified) * cpukit/posix/src/timergetoverrun.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timerinserthelper.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/timertsr.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/posix/src/vfork.c (modified) * cpukit/posix/src/wait.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/barrier.h (modified) * cpukit/rtems/include/rtems/rtems/barriermp.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/eventset.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/object.h (modified) * cpukit/rtems/include/rtems/rtems/options.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/smp.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/asr.inl (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/inline/rtems/rtems/barrier.inl (modified) * cpukit/rtems/inline/rtems/rtems/dpmem.inl (modified) * cpukit/rtems/inline/rtems/rtems/event.inl (modified) * cpukit/rtems/inline/rtems/rtems/eventset.inl (modified) * cpukit/rtems/inline/rtems/rtems/message.inl (modified) * cpukit/rtems/inline/rtems/rtems/modes.inl (modified) * cpukit/rtems/inline/rtems/rtems/options.inl (modified) * cpukit/rtems/inline/rtems/rtems/part.inl (modified) * cpukit/rtems/inline/rtems/rtems/ratemon.inl (modified) * cpukit/rtems/inline/rtems/rtems/region.inl (modified) * cpukit/rtems/inline/rtems/rtems/sem.inl (modified) * cpukit/rtems/inline/rtems/rtems/status.inl (modified) * cpukit/rtems/inline/rtems/rtems/support.inl (modified) * cpukit/rtems/inline/rtems/rtems/tasks.inl (modified) * cpukit/rtems/inline/rtems/rtems/timer.inl (modified) * cpukit/rtems/mainpage.h (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/barriercreate.c (modified) * cpukit/rtems/src/barrierdata.c (modified) * cpukit/rtems/src/barrierdelete.c (modified) * cpukit/rtems/src/barrierident.c (modified) * cpukit/rtems/src/barrierrelease.c (modified) * cpukit/rtems/src/barriertranslatereturncode.c (modified) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/rtems/src/clockget.c (modified) * cpukit/rtems/src/clockgetsecondssinceepoch.c (modified) * cpukit/rtems/src/clockgettickspersecond.c (modified) * cpukit/rtems/src/clockgettickssinceboot.c (modified) * cpukit/rtems/src/clockgettod.c (modified) * cpukit/rtems/src/clockgettodtimeval.c (modified) * cpukit/rtems/src/clockgetuptime.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/clocksetnsecshandler.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/rtems/src/clocktodtoseconds.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/dpmemdata.c (modified) * cpukit/rtems/src/dpmemdelete.c (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/eventdata.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/eventtimeout.c (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/rtems/src/intrcatch.c (modified) * cpukit/rtems/src/mp.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgdata.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqallocate.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqtranslatereturncode.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/partdata.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemondata.c (modified) * cpukit/rtems/src/ratemondelete.c (modified) * cpukit/rtems/src/ratemongetstatistics.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/rtems/src/ratemonresetall.c (modified) * cpukit/rtems/src/ratemonresetstatistics.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/regiondata.c (modified) * cpukit/rtems/src/regiondelete.c (modified) * cpukit/rtems/src/regionextend.c (modified) * cpukit/rtems/src/regiongetfreeinfo.c (modified) * cpukit/rtems/src/regiongetinfo.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/regionprocessqueue.c (modified) * cpukit/rtems/src/regionresizesegment.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemsbuildid.c (modified) * cpukit/rtems/src/rtemsbuildname.c (modified) * cpukit/rtems/src/rtemsobjectapimaximumclass.c (modified) * cpukit/rtems/src/rtemsobjectapiminimumclass.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/rtems/src/rtemsobjectgetapiname.c (modified) * cpukit/rtems/src/rtemsobjectgetclassicname.c (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/rtems/src/rtemsobjectgetname.c (modified) * cpukit/rtems/src/rtemsobjectidapimaximum.c (modified) * cpukit/rtems/src/rtemsobjectidapiminimum.c (modified) * cpukit/rtems/src/rtemsobjectidgetapi.c (modified) * cpukit/rtems/src/rtemsobjectidgetclass.c (modified) * cpukit/rtems/src/rtemsobjectidgetindex.c (modified) * cpukit/rtems/src/rtemsobjectidgetnode.c (modified) * cpukit/rtems/src/rtemsobjectsetname.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/rtemstimerdata.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdata.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/status.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/taskdata.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskself.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/rtems/src/taskvariable_invoke_dtor.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timergetinfo.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/rtems/src/workspace.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/README (modified) * cpukit/sapi/include/rtems/cbs.h (modified) * cpukit/sapi/include/rtems/chain.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/include/rtems/mptables.h (modified) * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/sapi/include/rtems/sptables.h (modified) * cpukit/sapi/inline/rtems/cbs.inl (modified) * cpukit/sapi/inline/rtems/chain.inl (modified) * cpukit/sapi/inline/rtems/extension.inl (modified) * cpukit/sapi/src/debug.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/exshutdown.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/sapi/src/extensiondata.c (modified) * cpukit/sapi/src/extensiondelete.c (modified) * cpukit/sapi/src/extensionident.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/getversionstring.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/ioclose.c (modified) * cpukit/sapi/src/iocontrol.c (modified) * cpukit/sapi/src/iodata.c (modified) * cpukit/sapi/src/ioinitialize.c (modified) * cpukit/sapi/src/ioopen.c (modified) * cpukit/sapi/src/ioread.c (modified) * cpukit/sapi/src/ioregisterdriver.c (modified) * cpukit/sapi/src/iounregisterdriver.c (modified) * cpukit/sapi/src/iowrite.c (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/arm_exc_handler_high.c (modified) * cpukit/score/cpu/arm/arm_exc_handler_low.S (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/arm/rtems/score/types.h (modified) * cpukit/score/cpu/avr/Makefile.am (modified) * cpukit/score/cpu/avr/avr/boot.h (modified) * cpukit/score/cpu/avr/avr/common.h (modified) * cpukit/score/cpu/avr/avr/crc16.h (modified) * cpukit/score/cpu/avr/avr/delay.h (modified) * cpukit/score/cpu/avr/avr/eeprom.h (modified) * cpukit/score/cpu/avr/avr/fuse.h (modified) * cpukit/score/cpu/avr/avr/interrupt.h (modified) * cpukit/score/cpu/avr/avr/io.h (modified) * cpukit/score/cpu/avr/avr/io1200.h (modified) * cpukit/score/cpu/avr/avr/io2313.h (modified) * cpukit/score/cpu/avr/avr/io2323.h (modified) * cpukit/score/cpu/avr/avr/io2333.h (modified) * cpukit/score/cpu/avr/avr/io2343.h (modified) * cpukit/score/cpu/avr/avr/io43u32x.h (modified) * cpukit/score/cpu/avr/avr/io43u35x.h (modified) * cpukit/score/cpu/avr/avr/io4414.h (modified) * cpukit/score/cpu/avr/avr/io4433.h (modified) * cpukit/score/cpu/avr/avr/io4434.h (modified) * cpukit/score/cpu/avr/avr/io76c711.h (modified) * cpukit/score/cpu/avr/avr/io8515.h (modified) * cpukit/score/cpu/avr/avr/io8534.h (modified) * cpukit/score/cpu/avr/avr/io8535.h (modified) * cpukit/score/cpu/avr/avr/io90pwm1.h (modified) * cpukit/score/cpu/avr/avr/io90pwm216.h (modified) * cpukit/score/cpu/avr/avr/io90pwm2b.h (modified) * cpukit/score/cpu/avr/avr/io90pwm316.h (modified) * cpukit/score/cpu/avr/avr/io90pwm3b.h (modified) * cpukit/score/cpu/avr/avr/io90pwm81.h (modified) * cpukit/score/cpu/avr/avr/io90pwmx.h (modified) * cpukit/score/cpu/avr/avr/io90scr100.h (modified) * cpukit/score/cpu/avr/avr/ioa6289.h (modified) * cpukit/score/cpu/avr/avr/ioat94k.h (modified) * cpukit/score/cpu/avr/avr/iocan128.h (modified) * cpukit/score/cpu/avr/avr/iocan32.h (modified) * cpukit/score/cpu/avr/avr/iocan64.h (modified) * cpukit/score/cpu/avr/avr/iocanxx.h (modified) * cpukit/score/cpu/avr/avr/iom103.h (modified) * cpukit/score/cpu/avr/avr/iom128.h (modified) * cpukit/score/cpu/avr/avr/iom1280.h (modified) * cpukit/score/cpu/avr/avr/iom1281.h (modified) * cpukit/score/cpu/avr/avr/iom1284p.h (modified) * cpukit/score/cpu/avr/avr/iom128rfa1.h (modified) * cpukit/score/cpu/avr/avr/iom16.h (modified) * cpukit/score/cpu/avr/avr/iom161.h (modified) * cpukit/score/cpu/avr/avr/iom162.h (modified) * cpukit/score/cpu/avr/avr/iom163.h (modified) * cpukit/score/cpu/avr/avr/iom164.h (modified) * cpukit/score/cpu/avr/avr/iom165.h (modified) * cpukit/score/cpu/avr/avr/iom165p.h (modified) * cpukit/score/cpu/avr/avr/iom168.h (modified) * cpukit/score/cpu/avr/avr/iom168p.h (modified) * cpukit/score/cpu/avr/avr/iom169.h (modified) * cpukit/score/cpu/avr/avr/iom169p.h (modified) * cpukit/score/cpu/avr/avr/iom169pa.h (modified) * cpukit/score/cpu/avr/avr/iom16a.h (modified) * cpukit/score/cpu/avr/avr/iom16hva.h (modified) * cpukit/score/cpu/avr/avr/iom16hva2.h (modified) * cpukit/score/cpu/avr/avr/iom16hvb.h (modified) * cpukit/score/cpu/avr/avr/iom16m1.h (modified) * cpukit/score/cpu/avr/avr/iom16u2.h (modified) * cpukit/score/cpu/avr/avr/iom16u4.h (modified) * cpukit/score/cpu/avr/avr/iom2560.h (modified) * cpukit/score/cpu/avr/avr/iom2561.h (modified) * cpukit/score/cpu/avr/avr/iom32.h (modified) * cpukit/score/cpu/avr/avr/iom323.h (modified) * cpukit/score/cpu/avr/avr/iom324.h (modified) * cpukit/score/cpu/avr/avr/iom324pa.h (modified) * cpukit/score/cpu/avr/avr/iom325.h (modified) * cpukit/score/cpu/avr/avr/iom3250.h (modified) * cpukit/score/cpu/avr/avr/iom328p.h (modified) * cpukit/score/cpu/avr/avr/iom32c1.h (modified) * cpukit/score/cpu/avr/avr/iom32hvb.h (modified) * cpukit/score/cpu/avr/avr/iom32m1.h (modified) * cpukit/score/cpu/avr/avr/iom32u2.h (modified) * cpukit/score/cpu/avr/avr/iom32u4.h (modified) * cpukit/score/cpu/avr/avr/iom32u6.h (modified) * cpukit/score/cpu/avr/avr/iom406.h (modified) * cpukit/score/cpu/avr/avr/iom48.h (modified) * cpukit/score/cpu/avr/avr/iom48p.h (modified) * cpukit/score/cpu/avr/avr/iom64.h (modified) * cpukit/score/cpu/avr/avr/iom640.h (modified) * cpukit/score/cpu/avr/avr/iom644.h (modified) * cpukit/score/cpu/avr/avr/iom644p.h (modified) * cpukit/score/cpu/avr/avr/iom644pa.h (modified) * cpukit/score/cpu/avr/avr/iom645.h (modified) * cpukit/score/cpu/avr/avr/iom6450.h (modified) * cpukit/score/cpu/avr/avr/iom649p.h (modified) * cpukit/score/cpu/avr/avr/iom64c1.h (modified) * cpukit/score/cpu/avr/avr/iom64hve.h (modified) * cpukit/score/cpu/avr/avr/iom64m1.h (modified) * cpukit/score/cpu/avr/avr/iom8.h (modified) * cpukit/score/cpu/avr/avr/iom8515.h (modified) * cpukit/score/cpu/avr/avr/iom8535.h (modified) * cpukit/score/cpu/avr/avr/iom88.h (modified) * cpukit/score/cpu/avr/avr/iom88p.h (modified) * cpukit/score/cpu/avr/avr/iom88pa.h (modified) * cpukit/score/cpu/avr/avr/iom8hva.h (modified) * cpukit/score/cpu/avr/avr/iom8u2.h (modified) * cpukit/score/cpu/avr/avr/iomx8.h (modified) * cpukit/score/cpu/avr/avr/iomxx0_1.h (modified) * cpukit/score/cpu/avr/avr/iomxx4.h (modified) * cpukit/score/cpu/avr/avr/iomxxhva.h (modified) * cpukit/score/cpu/avr/avr/iotn11.h (modified) * cpukit/score/cpu/avr/avr/iotn12.h (modified) * cpukit/score/cpu/avr/avr/iotn13.h (modified) * cpukit/score/cpu/avr/avr/iotn13a.h (modified) * cpukit/score/cpu/avr/avr/iotn15.h (modified) * cpukit/score/cpu/avr/avr/iotn167.h (modified) * cpukit/score/cpu/avr/avr/iotn22.h (modified) * cpukit/score/cpu/avr/avr/iotn2313.h (modified) * cpukit/score/cpu/avr/avr/iotn2313a.h (modified) * cpukit/score/cpu/avr/avr/iotn24.h (modified) * cpukit/score/cpu/avr/avr/iotn24a.h (modified) * cpukit/score/cpu/avr/avr/iotn25.h (modified) * cpukit/score/cpu/avr/avr/iotn26.h (modified) * cpukit/score/cpu/avr/avr/iotn261.h (modified) * cpukit/score/cpu/avr/avr/iotn261a.h (modified) * cpukit/score/cpu/avr/avr/iotn28.h (modified) * cpukit/score/cpu/avr/avr/iotn4313.h (modified) * cpukit/score/cpu/avr/avr/iotn43u.h (modified) * cpukit/score/cpu/avr/avr/iotn44.h (modified) * cpukit/score/cpu/avr/avr/iotn44a.h (modified) * cpukit/score/cpu/avr/avr/iotn45.h (modified) * cpukit/score/cpu/avr/avr/iotn461.h (modified) * cpukit/score/cpu/avr/avr/iotn461a.h (modified) * cpukit/score/cpu/avr/avr/iotn48.h (modified) * cpukit/score/cpu/avr/avr/iotn84.h (modified) * cpukit/score/cpu/avr/avr/iotn85.h (modified) * cpukit/score/cpu/avr/avr/iotn861.h (modified) * cpukit/score/cpu/avr/avr/iotn861a.h (modified) * cpukit/score/cpu/avr/avr/iotn87.h (modified) * cpukit/score/cpu/avr/avr/iotn88.h (modified) * cpukit/score/cpu/avr/avr/iotnx4.h (modified) * cpukit/score/cpu/avr/avr/iotnx5.h (modified) * cpukit/score/cpu/avr/avr/iotnx61.h (modified) * cpukit/score/cpu/avr/avr/iousb1286.h (modified) * cpukit/score/cpu/avr/avr/iousb1287.h (modified) * cpukit/score/cpu/avr/avr/iousb162.h (modified) * cpukit/score/cpu/avr/avr/iousb646.h (modified) * cpukit/score/cpu/avr/avr/iousb647.h (modified) * cpukit/score/cpu/avr/avr/iousb82.h (modified) * cpukit/score/cpu/avr/avr/iousbxx2.h (modified) * cpukit/score/cpu/avr/avr/iousbxx6_7.h (modified) * cpukit/score/cpu/avr/avr/iox128a1.h (modified) * cpukit/score/cpu/avr/avr/iox128a3.h (modified) * cpukit/score/cpu/avr/avr/iox128d3.h (modified) * cpukit/score/cpu/avr/avr/iox16a4.h (modified) * cpukit/score/cpu/avr/avr/iox16d4.h (modified) * cpukit/score/cpu/avr/avr/iox192a3.h (modified) * cpukit/score/cpu/avr/avr/iox192d3.h (modified) * cpukit/score/cpu/avr/avr/iox256a3.h (modified) * cpukit/score/cpu/avr/avr/iox256a3b.h (modified) * cpukit/score/cpu/avr/avr/iox256d3.h (modified) * cpukit/score/cpu/avr/avr/iox32a4.h (modified) * cpukit/score/cpu/avr/avr/iox32d4.h (modified) * cpukit/score/cpu/avr/avr/iox64a1.h (modified) * cpukit/score/cpu/avr/avr/iox64a3.h (modified) * cpukit/score/cpu/avr/avr/iox64d3.h (modified) * cpukit/score/cpu/avr/avr/lock.h (modified) * cpukit/score/cpu/avr/avr/parity.h (modified) * cpukit/score/cpu/avr/avr/pgmspace.h (modified) * cpukit/score/cpu/avr/avr/portpins.h (modified) * cpukit/score/cpu/avr/avr/power.h (modified) * cpukit/score/cpu/avr/avr/sfr_defs.h (modified) * cpukit/score/cpu/avr/avr/signal.h (modified) * cpukit/score/cpu/avr/avr/signature.h (modified) * cpukit/score/cpu/avr/avr/sleep.h (modified) * cpukit/score/cpu/avr/avr/version.h (modified) * cpukit/score/cpu/avr/avr/wdt.h (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/cpu_asm.S (modified) * cpukit/score/cpu/avr/rtems/asm.h (modified) * cpukit/score/cpu/avr/rtems/score/avr.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/avr/rtems/score/types.h (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/cpu_asm.S (modified) * cpukit/score/cpu/bfin/rtems/asm.h (modified) * cpukit/score/cpu/bfin/rtems/bfin/bf52x.h (modified) * cpukit/score/cpu/bfin/rtems/bfin/bf533.h (modified) * cpukit/score/cpu/bfin/rtems/bfin/bfin.h (modified) * cpukit/score/cpu/bfin/rtems/score/bfin.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/bfin/rtems/score/types.h (modified) * cpukit/score/cpu/h8300/Makefile.am (modified) * cpukit/score/cpu/h8300/README (modified) * cpukit/score/cpu/h8300/cpu.c (modified) * cpukit/score/cpu/h8300/cpu_asm.S (modified) * cpukit/score/cpu/h8300/rtems/asm.h (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/rtems/score/h8300.h (modified) * cpukit/score/cpu/h8300/rtems/score/types.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/asm.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i386/rtems/score/idtr.h (modified) * cpukit/score/cpu/i386/rtems/score/interrupts.h (modified) * cpukit/score/cpu/i386/rtems/score/registers.h (modified) * cpukit/score/cpu/i386/rtems/score/types.h (modified) * cpukit/score/cpu/i386/sse_test.c (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/cpu_asm.S (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/lm32/rtems/asm.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/lm32/rtems/score/lm32.h (modified) * cpukit/score/cpu/lm32/rtems/score/types.h (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m32c/context_init.c (modified) * cpukit/score/cpu/m32c/context_switch.S (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/cpu_asm.c (modified) * cpukit/score/cpu/m32c/rtems/asm.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/m32c/rtems/score/m32c.h (modified) * cpukit/score/cpu/m32c/rtems/score/types.h (modified) * cpukit/score/cpu/m32r/Makefile.am (modified) * cpukit/score/cpu/m32r/context_init.c (modified) * cpukit/score/cpu/m32r/context_switch.S (modified) * cpukit/score/cpu/m32r/cpu.c (modified) * cpukit/score/cpu/m32r/cpu_asm.c (modified) * cpukit/score/cpu/m32r/rtems/asm.h (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/m32r/rtems/score/m32r.h (modified) * cpukit/score/cpu/m32r/rtems/score/types.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/rtems/asm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/m68302.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/sim.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/rtems/score/types.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/rtems/asm.h (modified) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/mips/rtems/score/types.h (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/irq.c (modified) * cpukit/score/cpu/nios2/nios2-context-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-context-switch.S (modified) * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-eic-rsie-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-fatal-halt.c (modified) * cpukit/score/cpu/nios2/nios2-iic-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-initialize-vectors.c (modified) * cpukit/score/cpu/nios2/nios2-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) * cpukit/score/cpu/nios2/nios2-isr-install-raw-handler.c (modified) * cpukit/score/cpu/nios2/nios2-isr-install-vector.c (modified) * cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c (modified) * cpukit/score/cpu/nios2/nios2-isr-set-level.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-configuration.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-descriptor.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-reset.c (modified) * cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c (modified) * cpukit/score/cpu/nios2/rtems/asm.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/nios2/rtems/score/nios2-utility.h (modified) * cpukit/score/cpu/nios2/rtems/score/nios2.h (modified) * cpukit/score/cpu/nios2/rtems/score/types.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/asm.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/types.h (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) * cpukit/score/cpu/powerpc/rtems/score/types.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/context.c (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/asm.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sh/rtems/score/sh_io.h (modified) * cpukit/score/cpu/sh/rtems/score/types.h (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/README (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/asm.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/rtems/score/types.h (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/sparc64/README (modified) * cpukit/score/cpu/sparc64/context.S (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/rtems/asm.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/sparc64.h (modified) * cpukit/score/cpu/sparc64/rtems/score/types.h (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/include/rtems/debug.h (modified) * cpukit/score/include/rtems/score/address.h (modified) * cpukit/score/include/rtems/score/apiext.h (modified) * cpukit/score/include/rtems/score/apimutex.h (modified) * cpukit/score/include/rtems/score/basedefs.h (modified) * cpukit/score/include/rtems/score/bitfield.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/copyrt.h (modified) * cpukit/score/include/rtems/score/corebarrier.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/corerwlock.h (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/include/rtems/score/corespinlock.h (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/mpci.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/prioritybitmap.h (modified) * cpukit/score/include/rtems/score/protectedheap.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/include/rtems/score/stack.h (modified) * cpukit/score/include/rtems/score/states.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadsync.h (modified) * cpukit/score/include/rtems/score/timespec.h (modified) * cpukit/score/include/rtems/score/timestamp.h (modified) * cpukit/score/include/rtems/score/timestamp64.h (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/tqdata.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/include/rtems/seterr.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/inline/rtems/score/address.inl (modified) * cpukit/score/inline/rtems/score/chain.inl (modified) * cpukit/score/inline/rtems/score/corebarrier.inl (modified) * cpukit/score/inline/rtems/score/coremsg.inl (modified) * cpukit/score/inline/rtems/score/coremutex.inl (modified) * cpukit/score/inline/rtems/score/corerwlock.inl (modified) * cpukit/score/inline/rtems/score/coresem.inl (modified) * cpukit/score/inline/rtems/score/corespinlock.inl (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/inline/rtems/score/isr.inl (modified) * cpukit/score/inline/rtems/score/mppkt.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/inline/rtems/score/objectmp.inl (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) * cpukit/score/inline/rtems/score/prioritybitmap.inl (modified) * cpukit/score/inline/rtems/score/scheduler.inl (modified) * cpukit/score/inline/rtems/score/schedulerpriority.inl (modified) * cpukit/score/inline/rtems/score/schedulersimple.inl (modified) * cpukit/score/inline/rtems/score/stack.inl (modified) * cpukit/score/inline/rtems/score/states.inl (modified) * cpukit/score/inline/rtems/score/sysstate.inl (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/inline/rtems/score/threadmp.inl (modified) * cpukit/score/inline/rtems/score/threadq.inl (modified) * cpukit/score/inline/rtems/score/tod.inl (modified) * cpukit/score/inline/rtems/score/tqdata.inl (modified) * cpukit/score/inline/rtems/score/watchdog.inl (modified) * cpukit/score/inline/rtems/score/wkspace.inl (modified) * cpukit/score/src/apiext.c (modified) * cpukit/score/src/apimutex.c (modified) * cpukit/score/src/apimutexallocate.c (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/chainappend.c (modified) * cpukit/score/src/chainextract.c (modified) * cpukit/score/src/chainget.c (modified) * cpukit/score/src/chaininsert.c (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushsupp.c (modified) * cpukit/score/src/coremsgflushwait.c (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexflush.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexseizeintr.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/corerwlocktimeout.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coresemflush.c (modified) * cpukit/score/src/coresemseize.c (modified) * cpukit/score/src/coresemsurrender.c (modified) * cpukit/score/src/corespinlock.c (modified) * cpukit/score/src/corespinlockrelease.c (modified) * cpukit/score/src/corespinlockwait.c (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodget.c (modified) * cpukit/score/src/coretodgetuptime.c (modified) * cpukit/score/src/coretodgetuptimetimespec.c (modified) * cpukit/score/src/coretodmsecstoticks.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/coretodtickspersec.c (modified) * cpukit/score/src/coretodusectoticks.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/heapgetfreeinfo.c (modified) * cpukit/score/src/heapgetinfo.c (modified) * cpukit/score/src/heapiterate.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/heapwalk.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/isrsmp.c (modified) * cpukit/score/src/iterateoverthreads.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectapimaximumclass.c (modified) * cpukit/score/src/objectclose.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectget.c (modified) * cpukit/score/src/objectgetinfo.c (modified) * cpukit/score/src/objectgetinfoid.c (modified) * cpukit/score/src/objectgetisr.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectgetnoprotection.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnamespaceremove.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectsetname.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/pheapallocate.c (modified) * cpukit/score/src/pheapextend.c (modified) * cpukit/score/src/pheapfree.c (modified) * cpukit/score/src/pheapgetblocksize.c (modified) * cpukit/score/src/pheapgetfreeinfo.c (modified) * cpukit/score/src/pheapgetinfo.c (modified) * cpukit/score/src/pheapgetsize.c (modified) * cpukit/score/src/pheapinit.c (modified) * cpukit/score/src/pheapiterate.c (modified) * cpukit/score/src/pheapresizeblock.c (modified) * cpukit/score/src/pheapwalk.c (modified) * cpukit/score/src/rbtree.c (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreefind.c (modified) * cpukit/score/src/rbtreefindheader.c (modified) * cpukit/score/src/rbtreeget.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/scheduler.c (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbscleanup.c (modified) * cpukit/score/src/schedulercbscreateserver.c (modified) * cpukit/score/src/schedulercbsdestroyserver.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetapprovedbudget.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetparameters.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/schedulercbsgetserverid.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulercbssetparameters.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/scheduleredfallocate.c (modified) * cpukit/score/src/scheduleredfblock.c (modified) * cpukit/score/src/scheduleredfenqueue.c (modified) * cpukit/score/src/scheduleredfenqueuefirst.c (modified) * cpukit/score/src/scheduleredfextract.c (modified) * cpukit/score/src/scheduleredffree.c (modified) * cpukit/score/src/scheduleredfprioritycompare.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfupdate.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerpriority.c (modified) * cpukit/score/src/schedulerpriorityallocate.c (modified) * cpukit/score/src/schedulerpriorityblock.c (modified) * cpukit/score/src/schedulerpriorityenqueue.c (modified) * cpukit/score/src/schedulerpriorityenqueuefirst.c (modified) * cpukit/score/src/schedulerpriorityextract.c (modified) * cpukit/score/src/schedulerpriorityfree.c (modified) * cpukit/score/src/schedulerpriorityprioritycompare.c (modified) * cpukit/score/src/schedulerpriorityreleasejob.c (modified) * cpukit/score/src/schedulerpriorityschedule.c (modified) * cpukit/score/src/schedulerprioritytick.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityupdate.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimple.c (modified) * cpukit/score/src/schedulersimpleblock.c (modified) * cpukit/score/src/schedulersimpleenqueue.c (modified) * cpukit/score/src/schedulersimpleenqueuefirst.c (modified) * cpukit/score/src/schedulersimpleextract.c (modified) * cpukit/score/src/schedulersimplereadyqueueenqueue.c (modified) * cpukit/score/src/schedulersimplereadyqueueenqueuefirst.c (modified) * cpukit/score/src/schedulersimpleschedule.c (modified) * cpukit/score/src/schedulersimplesmpblock.c (modified) * cpukit/score/src/schedulersimplesmptick.c (modified) * cpukit/score/src/schedulersimplesmpunblock.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadblockingoperationcancel.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadclose.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddelayended.c (modified) * cpukit/score/src/threaddisabledispatch.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * cpukit/score/src/threadenabledispatch.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqdequeue.c (modified) * cpukit/score/src/threadqdequeuefifo.c (modified) * cpukit/score/src/threadqdequeuepriority.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqenqueuefifo.c (modified) * cpukit/score/src/threadqenqueuepriority.c (modified) * cpukit/score/src/threadqextract.c (modified) * cpukit/score/src/threadqextractfifo.c (modified) * cpukit/score/src/threadqextractpriority.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadqfirstfifo.c (modified) * cpukit/score/src/threadqfirstpriority.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadqprocesstimeout.c (modified) * cpukit/score/src/threadqrequeue.c (modified) * cpukit/score/src/threadqtimeout.c (modified) * cpukit/score/src/threadready.c (modified) * cpukit/score/src/threadreset.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadsetpriority.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadsettransient.c (modified) * cpukit/score/src/threadstackallocate.c (modified) * cpukit/score/src/threadstackfree.c (modified) * cpukit/score/src/threadstart.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * cpukit/score/src/timespecaddto.c (modified) * cpukit/score/src/timespecdivide.c (modified) * cpukit/score/src/timespecdividebyinteger.c (modified) * cpukit/score/src/timespecfromticks.c (modified) * cpukit/score/src/timespecisvalid.c (modified) * cpukit/score/src/timespeclessthan.c (modified) * cpukit/score/src/timespecsubtract.c (modified) * cpukit/score/src/timespectoticks.c (modified) * cpukit/score/src/ts64addto.c (modified) * cpukit/score/src/ts64divide.c (modified) * cpukit/score/src/ts64dividebyinteger.c (modified) * cpukit/score/src/ts64equalto.c (modified) * cpukit/score/src/ts64getnanoseconds.c (modified) * cpukit/score/src/ts64getseconds.c (modified) * cpukit/score/src/ts64lessthan.c (modified) * cpukit/score/src/ts64set.c (modified) * cpukit/score/src/ts64settozero.c (modified) * cpukit/score/src/ts64subtract.c (modified) * cpukit/score/src/ts64toticks.c (modified) * cpukit/score/src/ts64totimespec.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/userextaddset.c (modified) * cpukit/score/src/userextremoveset.c (modified) * cpukit/score/src/userextthreadbegin.c (modified) * cpukit/score/src/userextthreadcreate.c (modified) * cpukit/score/src/userextthreaddelete.c (modified) * cpukit/score/src/userextthreadrestart.c (modified) * cpukit/score/src/userextthreadstart.c (modified) * cpukit/score/src/userextthreadswitch.c (modified) * cpukit/score/src/watchdog.c (modified) * cpukit/score/src/watchdogadjust.c (modified) * cpukit/score/src/watchdogadjusttochain.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdognanoseconds.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogreport.c (modified) * cpukit/score/src/watchdogreportchain.c (modified) * cpukit/score/src/watchdogtickle.c (modified) * cpukit/score/src/wkspace.c (modified) * cpukit/score/src/wkstringduplicate.c (modified) * cpukit/telnetd/Makefile.am (modified) * cpukit/telnetd/README (modified) * cpukit/telnetd/check_passwd.c (modified) * cpukit/telnetd/passwd.h (modified) * cpukit/telnetd/pty.c (modified) * cpukit/telnetd/pty.h (modified) * cpukit/telnetd/telnetd.c (modified) * cpukit/telnetd/telnetd.h (modified) * cpukit/wrapup/Makefile.am (modified) * cpukit/zlib/Makefile.am (modified) * cpukit/zlib/adler32.c (modified) * cpukit/zlib/compress.c (modified) * cpukit/zlib/crc32.c (modified) * cpukit/zlib/deflate.c (modified) * cpukit/zlib/deflate.h (modified) * cpukit/zlib/trees.c (modified) * cpukit/zlib/uncompr.c (modified) * cpukit/zlib/zconf.h.in (modified) * cpukit/zlib/zutil.c (modified) * cpukit/zlib/zutil.h (modified) * doc/Makefile.am (modified) * doc/README (modified) * doc/ada_user/Makefile.am (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/bsp_howto/Makefile.am (modified) * doc/bsp_howto/adaintr.t (modified) * doc/bsp_howto/analog.t (modified) * doc/bsp_howto/ata.t (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/bsp_howto/clock.t (modified) * doc/bsp_howto/console.t (modified) * doc/bsp_howto/discrete.t (modified) * doc/bsp_howto/framebuffer.t (modified) * doc/bsp_howto/ide-ctrl.t (modified) * doc/bsp_howto/init.t (modified) * doc/bsp_howto/intro.t (modified) * doc/bsp_howto/linkcmds.t (modified) * doc/bsp_howto/makefiles.t (modified) * doc/bsp_howto/nvmem.t (modified) * doc/bsp_howto/rtc.t (modified) * doc/bsp_howto/shmsupp.t (modified) * doc/bsp_howto/support.t (modified) * doc/bsp_howto/target.t (modified) * doc/bsp_howto/timer.t (modified) * doc/common/cpright.texi (modified) * doc/common/opengroup_manpage_acknowledgement.texi (modified) * doc/common/opengroup_preface_acknowledgement.texi (modified) * doc/common/rtems.texi.in (modified) * doc/common/setup.texi (modified) * doc/common/wksheets.t (modified) * doc/cpu_supplement/Makefile.am (modified) * doc/cpu_supplement/arm.t (modified) * doc/cpu_supplement/avr.t (modified) * doc/cpu_supplement/bfin.t (modified) * doc/cpu_supplement/cpu_supplement.texi (modified) * doc/cpu_supplement/general.t (modified) * doc/cpu_supplement/i386.t (modified) * doc/cpu_supplement/lm32.t (modified) * doc/cpu_supplement/m68k.t (modified) * doc/cpu_supplement/mips.t (modified) * doc/cpu_supplement/powerpc.t (modified) * doc/cpu_supplement/preface.texi (modified) * doc/cpu_supplement/sh.t (modified) * doc/cpu_supplement/sparc.t (modified) * doc/cpu_supplement/sparc64.t (modified) * doc/develenv/Makefile.am (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.t (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.t (modified) * doc/develenv/utils.t (modified) * doc/filesystem/Makefile.am (modified) * doc/filesystem/filesystem.texi (modified) * doc/filesystem/fsrequirements.t (modified) * doc/filesystem/imfs.t (modified) * doc/filesystem/init.t (modified) * doc/filesystem/miniimfs.t (modified) * doc/filesystem/mounting.t (modified) * doc/filesystem/patheval.t (modified) * doc/filesystem/preface.texi (modified) * doc/filesystem/syscalls.t (modified) * doc/filesystem/tftp.t (modified) * doc/networking/Makefile.am (modified) * doc/networking/decdriver.t (modified) * doc/networking/driver.t (modified) * doc/networking/networkapp.t (modified) * doc/networking/networking.texi (modified) * doc/networking/networktasks.t (modified) * doc/networking/preface.texi (modified) * doc/networking/servers.t (modified) * doc/networking/testing.t (modified) * doc/new_chapters/Makefile.am (modified) * doc/new_chapters/error.t (modified) * doc/new_chapters/monitor.t (modified) * doc/new_chapters/new_chapters.texi (modified) * doc/porting/Makefile.am (modified) * doc/porting/codetuning.t (modified) * doc/porting/cpuinit.t (modified) * doc/porting/cpumodels.t (modified) * doc/porting/developtools.t (modified) * doc/porting/idlethread.t (modified) * doc/porting/interrupts.t (modified) * doc/porting/miscellaneous.t (modified) * doc/porting/porting.texi (modified) * doc/porting/preface.texi (modified) * doc/porting/prioritybitmap.t (modified) * doc/porting/sourcecode.t (modified) * doc/porting/taskcontext.t (modified) * doc/posix1003.1/Makefile.am (modified) * doc/posix1003.1/ch01.t (modified) * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix1003.1/preface.texi (modified) * doc/posix_users/Makefile.am (modified) * doc/posix_users/cancel.t (modified) * doc/posix_users/clock.t (modified) * doc/posix_users/cond.t (modified) * doc/posix_users/cspecific.t (modified) * doc/posix_users/device.t (modified) * doc/posix_users/files.t (modified) * doc/posix_users/io.t (modified) * doc/posix_users/key.t (modified) * doc/posix_users/libc.t (modified) * doc/posix_users/libm.t (modified) * doc/posix_users/memorymgmt.t (modified) * doc/posix_users/message.t (modified) * doc/posix_users/mutex.t (modified) * doc/posix_users/posix_users.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/procenv.t (modified) * doc/posix_users/process.t (modified) * doc/posix_users/sched.t (modified) * doc/posix_users/semaphores.t (modified) * doc/posix_users/signal.t (modified) * doc/posix_users/status.t (modified) * doc/posix_users/systemdb.t (modified) * doc/posix_users/thread.t (modified) * doc/posix_users/timer.t (modified) * doc/project.am (modified) * doc/relnotes/Makefile.am (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/shell/Makefile.am (modified) * doc/shell/confinit.t (modified) * doc/shell/file.t (modified) * doc/shell/general.t (modified) * doc/shell/network.t (modified) * doc/shell/preface.texi (modified) * doc/shell/rtems.t (modified) * doc/shell/shell.texi (modified) * doc/started/Makefile.am (modified) * doc/started/binaries.t (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/started/intro.t (modified) * doc/started/nextstep.t (modified) * doc/started/nt.t (modified) * doc/started/require.t (modified) * doc/started/sample.t (modified) * doc/started/started.texi (modified) * doc/tools/Makefile.am (modified) * doc/tools/bmenu/Makefile.am (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/bmenu2.c (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/system.h (modified) * doc/user/Makefile.am (modified) * doc/user/barrier.t (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/cbs.t (modified) * doc/user/chains.t (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/cpuuse.t (modified) * doc/user/datatypes.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/object.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/stackchk.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) * make/custom/default.cfg (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * testsuites/Makefile.am (modified) * testsuites/PROBLEMS (modified) * testsuites/README (modified) * testsuites/aclocal/canonical-target-name.m4 (modified) * testsuites/aclocal/canonicalize-tools.m4 (modified) * testsuites/aclocal/check-cpuopts.m4 (modified) * testsuites/aclocal/check-custom-bsp.m4 (modified) * testsuites/aclocal/check-cxx.m4 (modified) * testsuites/aclocal/check-tool.m4 (modified) * testsuites/aclocal/enable-cxx.m4 (modified) * testsuites/aclocal/enable-rtemsbsp.m4 (modified) * testsuites/aclocal/enable-tests.m4 (modified) * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/aclocal/prog-cc.m4 (modified) * testsuites/aclocal/prog-cxx.m4 (modified) * testsuites/aclocal/project-root.m4 (modified) * testsuites/aclocal/rtems-top.m4 (modified) * testsuites/automake/compile.am (modified) * testsuites/automake/host.am (modified) * testsuites/automake/local.am (modified) * testsuites/automake/subdirs.am (modified) * testsuites/configure.ac (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fserror/fserror.doc (modified) * testsuites/fstests/fserror/test.c (modified) * testsuites/fstests/fslink/fslink.doc (modified) * testsuites/fstests/fslink/test.c (modified) * testsuites/fstests/fspatheval/patheval.doc (modified) * testsuites/fstests/fspatheval/test.c (modified) * testsuites/fstests/fspermission/fspermission.doc (modified) * testsuites/fstests/fspermission/test.c (modified) * testsuites/fstests/fsrdwr/fsrdwr.doc (modified) * testsuites/fstests/fsrdwr/init.c (modified) * testsuites/fstests/fssymlink/fssymlink.doc (modified) * testsuites/fstests/fssymlink/test.c (modified) * testsuites/fstests/fstime/fstime.doc (modified) * testsuites/fstests/fstime/test.c (modified) * testsuites/fstests/imfs_fserror/Makefile.am (modified) * testsuites/fstests/imfs_fslink/Makefile.am (modified) * testsuites/fstests/imfs_fspatheval/Makefile.am (modified) * testsuites/fstests/imfs_fspermission/Makefile.am (modified) * testsuites/fstests/imfs_fsrdwr/Makefile.am (modified) * testsuites/fstests/imfs_fssymlink/Makefile.am (modified) * testsuites/fstests/imfs_fstime/Makefile.am (modified) * testsuites/fstests/imfs_support/fs_config.h (modified) * testsuites/fstests/imfs_support/fs_support.c (modified) * testsuites/fstests/mdosfs_fserror/Makefile.am (modified) * testsuites/fstests/mdosfs_fspatheval/Makefile.am (modified) * testsuites/fstests/mdosfs_fsrdwr/Makefile.am (modified) * testsuites/fstests/mdosfs_fstime/Makefile.am (modified) * testsuites/fstests/mdosfs_support/fs_config.h (modified) * testsuites/fstests/mdosfs_support/fs_support.c (modified) * testsuites/fstests/mimfs_fserror/Makefile.am (modified) * testsuites/fstests/mimfs_fslink/Makefile.am (modified) * testsuites/fstests/mimfs_fspatheval/Makefile.am (modified) * testsuites/fstests/mimfs_fspermission/Makefile.am (modified) * testsuites/fstests/mimfs_fsrdwr/Makefile.am (modified) * testsuites/fstests/mimfs_fssymlink/Makefile.am (modified) * testsuites/fstests/mimfs_fstime/Makefile.am (modified) * testsuites/fstests/mimfs_support/fs_config.h (modified) * testsuites/fstests/mimfs_support/fs_support.c (modified) * testsuites/fstests/mrfs_fserror/Makefile.am (modified) * testsuites/fstests/mrfs_fslink/Makefile.am (modified) * testsuites/fstests/mrfs_fspatheval/Makefile.am (modified) * testsuites/fstests/mrfs_fspermission/Makefile.am (modified) * testsuites/fstests/mrfs_fsrdwr/Makefile.am (modified) * testsuites/fstests/mrfs_fssymlink/Makefile.am (modified) * testsuites/fstests/mrfs_fstime/Makefile.am (modified) * testsuites/fstests/mrfs_support/fs_config.h (modified) * testsuites/fstests/mrfs_support/fs_support.c (modified) * testsuites/fstests/support/fstest.h (modified) * testsuites/fstests/support/fstest_support.c (modified) * testsuites/fstests/support/fstest_support.h (modified) * testsuites/fstests/support/ramdisk_support.c (modified) * testsuites/fstests/support/ramdisk_support.h (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/README (modified) * testsuites/libtests/block01/Makefile.am (modified) * testsuites/libtests/block01/block01.doc (modified) * testsuites/libtests/block01/init.c (modified) * testsuites/libtests/block02/Makefile.am (modified) * testsuites/libtests/block02/block02.doc (modified) * testsuites/libtests/block03/Makefile.am (modified) * testsuites/libtests/block03/block03.doc (modified) * testsuites/libtests/block04/Makefile.am (modified) * testsuites/libtests/block04/block04.doc (modified) * testsuites/libtests/block05/Makefile.am (modified) * testsuites/libtests/block05/block05.doc (modified) * testsuites/libtests/block06/Makefile.am (modified) * testsuites/libtests/block06/block06.doc (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block07/Makefile.am (modified) * testsuites/libtests/block07/block07.doc (modified) * testsuites/libtests/block08/Makefile.am (modified) * testsuites/libtests/block08/bdbuf_test1_2.c (modified) * testsuites/libtests/block08/bdbuf_test1_3.c (modified) * testsuites/libtests/block08/bdbuf_test1_4.c (modified) * testsuites/libtests/block08/bdbuf_test1_5.c (modified) * testsuites/libtests/block08/bdbuf_test2_1.c (modified) * testsuites/libtests/block08/bdbuf_test2_2.c (modified) * testsuites/libtests/block08/bdbuf_test3_1.c (modified) * testsuites/libtests/block08/bdbuf_test3_2.c (modified) * testsuites/libtests/block08/bdbuf_test3_3.c (modified) * testsuites/libtests/block08/bdbuf_test4_1.c (modified) * testsuites/libtests/block08/bdbuf_test4_2.c (modified) * testsuites/libtests/block08/bdbuf_test4_3.c (modified) * testsuites/libtests/block08/bdbuf_tests.c (modified) * testsuites/libtests/block08/bdbuf_tests.h (modified) * testsuites/libtests/block08/init.c (modified) * testsuites/libtests/block08/system.h (modified) * testsuites/libtests/block08/test_disk.c (modified) * testsuites/libtests/block09/Makefile.am (modified) * testsuites/libtests/block09/block09.doc (modified) * testsuites/libtests/block10/Makefile.am (modified) * testsuites/libtests/block10/block10.doc (modified) * testsuites/libtests/block11/Makefile.am (modified) * testsuites/libtests/bspcmdline01/Makefile.am (modified) * testsuites/libtests/bspcmdline01/bspcmdline01.doc (modified) * testsuites/libtests/bspcmdline01/init.c (modified) * testsuites/libtests/complex/Makefile.am (modified) * testsuites/libtests/complex/init.c (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/cpuuse/init.c (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task1.c (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/task3.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/devfs01/Makefile.am (modified) * testsuites/libtests/devfs01/devfs01.doc (modified) * testsuites/libtests/devfs01/init.c (modified) * testsuites/libtests/devfs02/Makefile.am (modified) * testsuites/libtests/devfs02/devfs02.doc (modified) * testsuites/libtests/devfs02/init.c (modified) * testsuites/libtests/devfs03/Makefile.am (modified) * testsuites/libtests/devfs03/devfs03.doc (modified) * testsuites/libtests/devfs03/init.c (modified) * testsuites/libtests/devfs04/Makefile.am (modified) * testsuites/libtests/devfs04/devfs04.doc (modified) * testsuites/libtests/devfs04/init.c (modified) * testsuites/libtests/devfs04/test_driver.c (modified) * testsuites/libtests/devfs04/test_driver.h (modified) * testsuites/libtests/deviceio01/Makefile.am (modified) * testsuites/libtests/deviceio01/deviceio01.doc (modified) * testsuites/libtests/deviceio01/init.c (modified) * testsuites/libtests/deviceio01/test_driver.c (modified) * testsuites/libtests/deviceio01/test_driver.h (modified) * testsuites/libtests/devnullfatal01/Makefile.am (modified) * testsuites/libtests/devnullfatal01/devnullfatal01.doc (modified) * testsuites/libtests/devnullfatal01/testcase.h (modified) * testsuites/libtests/dumpbuf01/Makefile.am (modified) * testsuites/libtests/dumpbuf01/dumpbuf01.doc (modified) * testsuites/libtests/dumpbuf01/init.c (modified) * testsuites/libtests/ftp01/Makefile.am (modified) * testsuites/libtests/ftp01/ftp01.doc (modified) * testsuites/libtests/ftp01/init.c (modified) * testsuites/libtests/gxx01/Makefile.am (modified) * testsuites/libtests/gxx01/gxx01.doc (modified) * testsuites/libtests/gxx01/init.c (modified) * testsuites/libtests/heapwalk/Makefile.am (modified) * testsuites/libtests/heapwalk/init.c (modified) * testsuites/libtests/heapwalk/system.h (modified) * testsuites/libtests/malloc02/Makefile.am (modified) * testsuites/libtests/malloc02/init.c (modified) * testsuites/libtests/malloc02/malloc02.doc (modified) * testsuites/libtests/malloc03/Makefile.am (modified) * testsuites/libtests/malloc03/init.c (modified) * testsuites/libtests/malloc03/malloc03.doc (modified) * testsuites/libtests/malloc04/Makefile.am (modified) * testsuites/libtests/malloc04/init.c (modified) * testsuites/libtests/malloc04/malloc04.doc (modified) * testsuites/libtests/malloc05/Makefile.am (modified) * testsuites/libtests/malloc05/init.c (modified) * testsuites/libtests/malloc05/malloc05.doc (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/malloctest/init.c (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/malloctest/task1.c (modified) * testsuites/libtests/math/Makefile.am (modified) * testsuites/libtests/math/init.c (modified) * testsuites/libtests/mathf/Makefile.am (modified) * testsuites/libtests/mathf/init.c (modified) * testsuites/libtests/mathl/Makefile.am (modified) * testsuites/libtests/mathl/init.c (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/monitor/init.c (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/monitor02/Makefile.am (modified) * testsuites/libtests/monitor02/init.c (modified) * testsuites/libtests/monitor02/system.h (modified) * testsuites/libtests/mouse01/Makefile.am (modified) * testsuites/libtests/mouse01/init.c (modified) * testsuites/libtests/mouse01/mouse01.doc (modified) * testsuites/libtests/mouse01/msmouse.c (modified) * testsuites/libtests/mouse01/serial_mouse_config.c (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/putenvtest/init.c (modified) * testsuites/libtests/rtems++/Init.cc (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtems++/Task1.cc (modified) * testsuites/libtests/rtems++/Task2.cc (modified) * testsuites/libtests/rtems++/Task3.cc (modified) * testsuites/libtests/rtems++/rtems++.doc (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/rtmonuse/getall.c (modified) * testsuites/libtests/rtmonuse/init.c (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/rtmonuse/task1.c (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/stackchk/blow.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/stackchk/task1.c (modified) * testsuites/libtests/stackchk01/Makefile.am (modified) * testsuites/libtests/stackchk01/init.c (modified) * testsuites/libtests/stackchk01/stackchk01.doc (modified) * testsuites/libtests/stringto01/Makefile.am (modified) * testsuites/libtests/stringto01/init.c (modified) * testsuites/libtests/stringto01/stringto01.doc (modified) * testsuites/libtests/stringto01/stringto_test_template.h (modified) * testsuites/libtests/tar01/Makefile.am (modified) * testsuites/libtests/tar01/init.c (modified) * testsuites/libtests/tar01/tar01.doc (modified) * testsuites/libtests/tar02/Makefile.am (modified) * testsuites/libtests/tar02/init.c (modified) * testsuites/libtests/tar02/tar02.doc (modified) * testsuites/libtests/tar03/Makefile.am (modified) * testsuites/libtests/tar03/init.c (modified) * testsuites/libtests/tar03/tar03.doc (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/libtests/termios/README (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/libtests/termios01/Makefile.am (modified) * testsuites/libtests/termios01/init.c (modified) * testsuites/libtests/termios01/termios01.doc (modified) * testsuites/libtests/termios01/termios_testdriver.c (modified) * testsuites/libtests/termios01/termios_testdriver.h (modified) * testsuites/libtests/termios02/Makefile.am (modified) * testsuites/libtests/termios02/init.c (modified) * testsuites/libtests/termios02/termios02.doc (modified) * testsuites/libtests/termios03/Makefile.am (modified) * testsuites/libtests/termios03/init.c (modified) * testsuites/libtests/termios03/termios03.doc (modified) * testsuites/libtests/termios03/termios_testdriver_polled.c (modified) * testsuites/libtests/termios03/termios_testdriver_polled.h (modified) * testsuites/libtests/termios04/Makefile.am (modified) * testsuites/libtests/termios04/init.c (modified) * testsuites/libtests/termios04/termios04.doc (modified) * testsuites/libtests/termios04/termios_testdriver_intr.c (modified) * testsuites/libtests/termios04/termios_testdriver_intr.h (modified) * testsuites/libtests/termios05/Makefile.am (modified) * testsuites/libtests/termios05/init.c (modified) * testsuites/libtests/termios05/termios05.doc (modified) * testsuites/libtests/termios05/termios_testdriver_taskdriven.c (modified) * testsuites/libtests/termios05/termios_testdriver_taskdriven.h (modified) * testsuites/libtests/termios06/Makefile.am (modified) * testsuites/libtests/termios06/init.c (modified) * testsuites/libtests/termios06/termios06.doc (modified) * testsuites/libtests/termios06/test_pppd.c (modified) * testsuites/libtests/termios07/Makefile.am (modified) * testsuites/libtests/termios07/init.c (modified) * testsuites/libtests/termios07/termios07.doc (modified) * testsuites/libtests/termios08/Makefile.am (modified) * testsuites/libtests/termios08/init.c (modified) * testsuites/libtests/termios08/termios08.doc (modified) * testsuites/libtests/tztest/Makefile.am (modified) * testsuites/libtests/tztest/init.c (modified) * testsuites/libtests/tztest/tztest.doc (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/mptests/README (modified) * testsuites/mptests/configure.ac (modified) * testsuites/mptests/mp01/Makefile.am (modified) * testsuites/mptests/mp01/init.c (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node1/mp01-node1.doc (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp01/node2/mp01-node2.doc (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp01/task1.c (modified) * testsuites/mptests/mp02/Makefile.am (modified) * testsuites/mptests/mp02/init.c (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node1/mp02-node1.doc (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp02/node2/mp02-node2.doc (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp02/task1.c (modified) * testsuites/mptests/mp03/Makefile.am (modified) * testsuites/mptests/mp03/delay.c (modified) * testsuites/mptests/mp03/init.c (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node1/mp03-node1.doc (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp03/node2/mp03-node2.doc (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp03/task1.c (modified) * testsuites/mptests/mp04/Makefile.am (modified) * testsuites/mptests/mp04/init.c (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node1/mp04-node1.doc (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp04/node2/mp04-node2.doc (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp04/task1.c (modified) * testsuites/mptests/mp05/Makefile.am (modified) * testsuites/mptests/mp05/asr.c (modified) * testsuites/mptests/mp05/init.c (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node1/mp05-node1.doc (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp05/node2/mp05-node2.doc (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp05/task1.c (modified) * testsuites/mptests/mp06/Makefile.am (modified) * testsuites/mptests/mp06/init.c (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node1/mp06-node1.doc (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp06/node2/mp06-node2.doc (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp06/task1.c (modified) * testsuites/mptests/mp07/Makefile.am (modified) * testsuites/mptests/mp07/init.c (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node1/mp07-node1.doc (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp07/node2/mp07-node2.doc (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp07/task1.c (modified) * testsuites/mptests/mp08/Makefile.am (modified) * testsuites/mptests/mp08/init.c (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node1/mp08-node1.doc (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp08/node2/mp08-node2.doc (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp08/task1.c (modified) * testsuites/mptests/mp09/Makefile.am (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node1/mp09-node1.doc (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp09/node2/mp09-node2.doc (modified) * testsuites/mptests/mp09/recvmsg.c (modified) * testsuites/mptests/mp09/sendmsg.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/mptests/mp10/Makefile.am (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node1/mp10-node1.doc (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp10/node2/mp10-node2.doc (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp10/task1.c (modified) * testsuites/mptests/mp10/task2.c (modified) * testsuites/mptests/mp10/task3.c (modified) * testsuites/mptests/mp11/Makefile.am (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node1/mp11-node1.doc (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp11/node2/mp11-node2.doc (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/Makefile.am (modified) * testsuites/mptests/mp12/init.c (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node1/mp12-node1.doc (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp12/node2/mp12-node2.doc (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/Makefile.am (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node1/mp13-node1.doc (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp13/node2/mp13-node2.doc (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp13/task1.c (modified) * testsuites/mptests/mp13/task2.c (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/mptests/mp14/delay.c (modified) * testsuites/mptests/mp14/evtask1.c (modified) * testsuites/mptests/mp14/evtmtask.c (modified) * testsuites/mptests/mp14/exit.c (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/msgtask1.c (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node1/mp14-node1.doc (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mp14/node2/mp14-node2.doc (modified) * testsuites/mptests/mp14/pttask1.c (modified) * testsuites/mptests/mp14/smtask1.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/include/pmacros.h (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx02/init.c (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx02/task.c (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx03/init.c (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx03/task.c (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx04/task1.c (modified) * testsuites/psxtests/psx04/task2.c (modified) * testsuites/psxtests/psx04/task3.c (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx05/task.c (modified) * testsuites/psxtests/psx05/task2.c (modified) * testsuites/psxtests/psx05/task3.c (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx06/init.c (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx06/task.c (modified) * testsuites/psxtests/psx06/task2.c (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx07/task.c (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx08/init.c (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx08/task1.c (modified) * testsuites/psxtests/psx08/task2.c (modified) * testsuites/psxtests/psx08/task3.c (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx09/init.c (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx10/task.c (modified) * testsuites/psxtests/psx10/task2.c (modified) * testsuites/psxtests/psx10/task3.c (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx11/init.c (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx11/task.c (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx12/init.c (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx12/task.c (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psx13/test.c (modified) * testsuites/psxtests/psx14/Makefile.am (modified) * testsuites/psxtests/psx14/init.c (modified) * testsuites/psxtests/psx14/system.h (modified) * testsuites/psxtests/psx15/Makefile.am (modified) * testsuites/psxtests/psx15/init.c (modified) * testsuites/psxtests/psx16/Makefile.am (modified) * testsuites/psxtests/psx16/init.c (modified) * testsuites/psxtests/psx16/psx16.doc (modified) * testsuites/psxtests/psxaio01/Makefile.am (modified) * testsuites/psxtests/psxaio01/init.c (modified) * testsuites/psxtests/psxaio01/system.h (modified) * testsuites/psxtests/psxaio02/Makefile.am (modified) * testsuites/psxtests/psxaio02/init.c (modified) * testsuites/psxtests/psxaio02/system.h (modified) * testsuites/psxtests/psxaio03/Makefile.am (modified) * testsuites/psxtests/psxalarm01/Makefile.am (modified) * testsuites/psxtests/psxalarm01/init.c (modified) * testsuites/psxtests/psxalarm01/psxalarm01.doc (modified) * testsuites/psxtests/psxautoinit01/Makefile.am (modified) * testsuites/psxtests/psxautoinit01/init.c (modified) * testsuites/psxtests/psxautoinit02/Makefile.am (modified) * testsuites/psxtests/psxautoinit02/init.c (modified) * testsuites/psxtests/psxautoinit02/psxautoinit02.doc (modified) * testsuites/psxtests/psxbarrier01/Makefile.am (modified) * testsuites/psxtests/psxbarrier01/main.c (modified) * testsuites/psxtests/psxbarrier01/test.c (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxcancel/init.c (modified) * testsuites/psxtests/psxcancel/psxcancel.doc (modified) * testsuites/psxtests/psxcancel01/Makefile.am (modified) * testsuites/psxtests/psxcancel01/init.c (modified) * testsuites/psxtests/psxcancel01/psxcancel01.doc (modified) * testsuites/psxtests/psxchroot01/Makefile.am (modified) * testsuites/psxtests/psxchroot01/test.c (modified) * testsuites/psxtests/psxclassic01/Makefile.am (modified) * testsuites/psxtests/psxclassic01/init.c (modified) * testsuites/psxtests/psxclassic01/psxclassic01.doc (modified) * testsuites/psxtests/psxcleanup/Makefile.am (modified) * testsuites/psxtests/psxcleanup/psxcleanup.c (modified) * testsuites/psxtests/psxcleanup/system.h (modified) * testsuites/psxtests/psxcleanup01/Makefile.am (modified) * testsuites/psxtests/psxcleanup01/init.c (modified) * testsuites/psxtests/psxcleanup01/psxcleanup01.doc (modified) * testsuites/psxtests/psxclock/Makefile.am (modified) * testsuites/psxtests/psxclock/init.c (modified) * testsuites/psxtests/psxclock/psxclock.doc (modified) * testsuites/psxtests/psxcond01/Makefile.am (modified) * testsuites/psxtests/psxcond01/init.c (modified) * testsuites/psxtests/psxcond01/psxcond01.doc (modified) * testsuites/psxtests/psxconfig01/Makefile.am (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxconfig01/psxconfig01.doc (modified) * testsuites/psxtests/psxeintr_join/Makefile.am (modified) * testsuites/psxtests/psxeintr_join/init.c (modified) * testsuites/psxtests/psxeintr_join/psxeintr_join.doc (modified) * testsuites/psxtests/psxenosys/Makefile.am (modified) * testsuites/psxtests/psxenosys/init.c (modified) * testsuites/psxtests/psxenosys/psxenosys.doc (modified) * testsuites/psxtests/psxenosys/system.h (modified) * testsuites/psxtests/psxfatal01/Makefile.am (modified) * testsuites/psxtests/psxfatal01/testcase.h (modified) * testsuites/psxtests/psxfatal02/Makefile.am (modified) * testsuites/psxtests/psxfatal02/testcase.h (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/psxtests/psxfatal_support/system.h (modified) * testsuites/psxtests/psxfchx01/Makefile.am (modified) * testsuites/psxtests/psxfchx01/init.c (modified) * testsuites/psxtests/psxfchx01/psxfchx01.doc (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxfile01/test_cat.c (modified) * testsuites/psxtests/psxfile01/test_extend.c (modified) * testsuites/psxtests/psxfile01/test_write.c (modified) * testsuites/psxtests/psxfile02/Makefile.am (modified) * testsuites/psxtests/psxfile02/init.c (modified) * testsuites/psxtests/psxfile02/psxfile02.doc (modified) * testsuites/psxtests/psxfilelock01/Makefile.am (modified) * testsuites/psxtests/psxfilelock01/init.c (modified) * testsuites/psxtests/psxfilelock01/psxfilelock01.doc (modified) * testsuites/psxtests/psxgetrusage01/Makefile.am (modified) * testsuites/psxtests/psxgetrusage01/init.c (modified) * testsuites/psxtests/psxgetrusage01/psxgetrusage01.doc (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxhdrs/clock01.c (modified) * testsuites/psxtests/psxhdrs/clock02.c (modified) * testsuites/psxtests/psxhdrs/clock03.c (modified) * testsuites/psxtests/psxhdrs/clock04.c (modified) * testsuites/psxtests/psxhdrs/clock05.c (modified) * testsuites/psxtests/psxhdrs/clock06.c (modified) * testsuites/psxtests/psxhdrs/cond01.c (modified) * testsuites/psxtests/psxhdrs/cond02.c (modified) * testsuites/psxtests/psxhdrs/cond03.c (modified) * testsuites/psxtests/psxhdrs/cond04.c (modified) * testsuites/psxtests/psxhdrs/cond05.c (modified) * testsuites/psxtests/psxhdrs/cond06.c (modified) * testsuites/psxtests/psxhdrs/cond07.c (modified) * testsuites/psxtests/psxhdrs/cond08.c (modified) * testsuites/psxtests/psxhdrs/cond09.c (modified) * testsuites/psxtests/psxhdrs/cond10.c (modified) * testsuites/psxtests/psxhdrs/key01.c (modified) * testsuites/psxtests/psxhdrs/key02.c (modified) * testsuites/psxtests/psxhdrs/key03.c (modified) * testsuites/psxtests/psxhdrs/key04.c (modified) * testsuites/psxtests/psxhdrs/mutex01.c (modified) * testsuites/psxtests/psxhdrs/mutex02.c (modified) * testsuites/psxtests/psxhdrs/mutex03.c (modified) * testsuites/psxtests/psxhdrs/mutex04.c (modified) * testsuites/psxtests/psxhdrs/mutex05.c (modified) * testsuites/psxtests/psxhdrs/mutex06.c (modified) * testsuites/psxtests/psxhdrs/mutex07.c (modified) * testsuites/psxtests/psxhdrs/mutex08.c (modified) * testsuites/psxtests/psxhdrs/mutex09.c (modified) * testsuites/psxtests/psxhdrs/mutex10.c (modified) * testsuites/psxtests/psxhdrs/mutex11.c (modified) * testsuites/psxtests/psxhdrs/mutex12.c (modified) * testsuites/psxtests/psxhdrs/mutex13.c (modified) * testsuites/psxtests/psxhdrs/mutex14.c (modified) * testsuites/psxtests/psxhdrs/mutex15.c (modified) * testsuites/psxtests/psxhdrs/mutex16.c (modified) * testsuites/psxtests/psxhdrs/proc01.c (modified) * testsuites/psxtests/psxhdrs/proc02.c (modified) * testsuites/psxtests/psxhdrs/proc03.c (modified) * testsuites/psxtests/psxhdrs/proc04.c (modified) * testsuites/psxtests/psxhdrs/proc05.c (modified) * testsuites/psxtests/psxhdrs/proc06.c (modified) * testsuites/psxtests/psxhdrs/proc07.c (modified) * testsuites/psxtests/psxhdrs/proc08.c (modified) * testsuites/psxtests/psxhdrs/proc09.c (modified) * testsuites/psxtests/psxhdrs/proc10.c (modified) * testsuites/psxtests/psxhdrs/proc11.c (modified) * testsuites/psxtests/psxhdrs/proc12.c (modified) * testsuites/psxtests/psxhdrs/proc13.c (modified) * testsuites/psxtests/psxhdrs/proc14.c (modified) * testsuites/psxtests/psxhdrs/pthread01.c (modified) * testsuites/psxtests/psxhdrs/pthread02.c (modified) * testsuites/psxtests/psxhdrs/pthread03.c (modified) * testsuites/psxtests/psxhdrs/pthread04.c (modified) * testsuites/psxtests/psxhdrs/pthread05.c (modified) * testsuites/psxtests/psxhdrs/pthread06.c (modified) * testsuites/psxtests/psxhdrs/pthread07.c (modified) * testsuites/psxtests/psxhdrs/pthread08.c (modified) * testsuites/psxtests/psxhdrs/pthread09.c (modified) * testsuites/psxtests/psxhdrs/pthread10.c (modified) * testsuites/psxtests/psxhdrs/pthread11.c (modified) * testsuites/psxtests/psxhdrs/pthread12.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread14.c (modified) * testsuites/psxtests/psxhdrs/pthread15.c (modified) * testsuites/psxtests/psxhdrs/pthread16.c (modified) * testsuites/psxtests/psxhdrs/pthread17.c (modified) * testsuites/psxtests/psxhdrs/pthread18.c (modified) * testsuites/psxtests/psxhdrs/pthread19.c (modified) * testsuites/psxtests/psxhdrs/pthread20.c (modified) * testsuites/psxtests/psxhdrs/pthread21.c (modified) * testsuites/psxtests/psxhdrs/pthread22.c (modified) * testsuites/psxtests/psxhdrs/pthread23.c (modified) * testsuites/psxtests/psxhdrs/pthread24.c (modified) * testsuites/psxtests/psxhdrs/pthread25.c (modified) * testsuites/psxtests/psxhdrs/pthread26.c (modified) * testsuites/psxtests/psxhdrs/pthread27.c (modified) * testsuites/psxtests/psxhdrs/pthread28.c (modified) * testsuites/psxtests/psxhdrs/pthread29.c (modified) * testsuites/psxtests/psxhdrs/pthread30.c (modified) * testsuites/psxtests/psxhdrs/pthread31.c (modified) * testsuites/psxtests/psxhdrs/pthread32.c (modified) * testsuites/psxtests/psxhdrs/pthread33.c (modified) * testsuites/psxtests/psxhdrs/pthread34.c (modified) * testsuites/psxtests/psxhdrs/pthread35.c (modified) * testsuites/psxtests/psxhdrs/pthread36.c (modified) * testsuites/psxtests/psxhdrs/pthread37.c (modified) * testsuites/psxtests/psxhdrs/pthread38.c (modified) * testsuites/psxtests/psxhdrs/pthread39.c (modified) * testsuites/psxtests/psxhdrs/pthread40.c (modified) * testsuites/psxtests/psxhdrs/sched01.c (modified) * testsuites/psxtests/psxhdrs/sched02.c (modified) * testsuites/psxtests/psxhdrs/sched03.c (modified) * testsuites/psxtests/psxhdrs/sched04.c (modified) * testsuites/psxtests/psxhdrs/sched05.c (modified) * testsuites/psxtests/psxhdrs/sched06.c (modified) * testsuites/psxtests/psxhdrs/sched07.c (modified) * testsuites/psxtests/psxhdrs/sched08.c (modified) * testsuites/psxtests/psxhdrs/signal01.c (modified) * testsuites/psxtests/psxhdrs/signal02.c (modified) * testsuites/psxtests/psxhdrs/signal03.c (modified) * testsuites/psxtests/psxhdrs/signal04.c (modified) * testsuites/psxtests/psxhdrs/signal05.c (modified) * testsuites/psxtests/psxhdrs/signal06.c (modified) * testsuites/psxtests/psxhdrs/signal07.c (modified) * testsuites/psxtests/psxhdrs/signal08.c (modified) * testsuites/psxtests/psxhdrs/signal09.c (modified) * testsuites/psxtests/psxhdrs/signal10.c (modified) * testsuites/psxtests/psxhdrs/signal11.c (modified) * testsuites/psxtests/psxhdrs/signal12.c (modified) * testsuites/psxtests/psxhdrs/signal13.c (modified) * testsuites/psxtests/psxhdrs/signal14.c (modified) * testsuites/psxtests/psxhdrs/signal15.c (modified) * testsuites/psxtests/psxhdrs/signal16.c (modified) * testsuites/psxtests/psxhdrs/signal17.c (modified) * testsuites/psxtests/psxhdrs/signal18.c (modified) * testsuites/psxtests/psxhdrs/signal19.c (modified) * testsuites/psxtests/psxhdrs/signal20.c (modified) * testsuites/psxtests/psxhdrs/signal21.c (modified) * testsuites/psxtests/psxhdrs/signal22.c (modified) * testsuites/psxtests/psxhdrs/signal23.c (modified) * testsuites/psxtests/psxhdrs/sync01.c (modified) * testsuites/psxtests/psxhdrs/sync02.c (modified) * testsuites/psxtests/psxhdrs/sync03.c (modified) * testsuites/psxtests/psxhdrs/time01.c (modified) * testsuites/psxtests/psxhdrs/time02.c (modified) * testsuites/psxtests/psxhdrs/time03.c (modified) * testsuites/psxtests/psxhdrs/time04.c (modified) * testsuites/psxtests/psxhdrs/time05.c (modified) * testsuites/psxtests/psxhdrs/time06.c (modified) * testsuites/psxtests/psxhdrs/time07.c (modified) * testsuites/psxtests/psxhdrs/time08.c (modified) * testsuites/psxtests/psxhdrs/time09.c (modified) * testsuites/psxtests/psxhdrs/time10.c (modified) * testsuites/psxtests/psxhdrs/time11.c (modified) * testsuites/psxtests/psxhdrs/time12.c (modified) * testsuites/psxtests/psxhdrs/time13.c (modified) * testsuites/psxtests/psxhdrs/timer01.c (modified) * testsuites/psxtests/psxhdrs/timer02.c (modified) * testsuites/psxtests/psxhdrs/timer03.c (modified) * testsuites/psxtests/psxhdrs/timer04.c (modified) * testsuites/psxtests/psxhdrs/timer05.c (modified) * testsuites/psxtests/psxhdrs/timer06.c (modified) * testsuites/psxtests/psxhdrs/timer07.c (modified) * testsuites/psxtests/psxid01/Makefile.am (modified) * testsuites/psxtests/psxid01/init.c (modified) * testsuites/psxtests/psxid01/psxid01.doc (modified) * testsuites/psxtests/psximfs01/Makefile.am (modified) * testsuites/psxtests/psximfs01/init.c (modified) * testsuites/psxtests/psximfs01/psximfs01.doc (modified) * testsuites/psxtests/psximfs02/Makefile.am (modified) * testsuites/psxtests/psximfs02/init.c (modified) * testsuites/psxtests/psximfs02/psximfs02.doc (modified) * testsuites/psxtests/psxintrcritical01/Makefile.am (modified) * testsuites/psxtests/psxintrcritical01/init.c (modified) * testsuites/psxtests/psxintrcritical01/psxintrcritical01.doc (modified) * testsuites/psxtests/psxitimer/Makefile.am (modified) * testsuites/psxtests/psxitimer/init.c (modified) * testsuites/psxtests/psxkey01/Makefile.am (modified) * testsuites/psxtests/psxkey01/init.c (modified) * testsuites/psxtests/psxkey01/system.h (modified) * testsuites/psxtests/psxkey01/task.c (modified) * testsuites/psxtests/psxkey02/Makefile.am (modified) * testsuites/psxtests/psxkey02/init.c (modified) * testsuites/psxtests/psxkey02/psxkey02.doc (modified) * testsuites/psxtests/psxkey03/Makefile.am (modified) * testsuites/psxtests/psxkey03/init.c (modified) * testsuites/psxtests/psxkey03/psxkey03.doc (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmount/test.c (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxmsgq02/Makefile.am (modified) * testsuites/psxtests/psxmsgq02/init.c (modified) * testsuites/psxtests/psxmsgq02/system.h (modified) * testsuites/psxtests/psxmsgq03/Makefile.am (modified) * testsuites/psxtests/psxmsgq03/init.c (modified) * testsuites/psxtests/psxmsgq03/psxmsgq03.doc (modified) * testsuites/psxtests/psxmsgq03/system.h (modified) * testsuites/psxtests/psxmsgq04/Makefile.am (modified) * testsuites/psxtests/psxmsgq04/init.c (modified) * testsuites/psxtests/psxmsgq04/psxmsgq04.doc (modified) * testsuites/psxtests/psxmutexattr01/Makefile.am (modified) * testsuites/psxtests/psxmutexattr01/init.c (modified) * testsuites/psxtests/psxmutexattr01/psxmutexattr01.doc (modified) * testsuites/psxtests/psxobj01/Makefile.am (modified) * testsuites/psxtests/psxobj01/init.c (modified) * testsuites/psxtests/psxobj01/psxobj01.doc (modified) * testsuites/psxtests/psxpasswd01/Makefile.am (modified) * testsuites/psxtests/psxpasswd01/init.c (modified) * testsuites/psxtests/psxpasswd01/psxpasswd01.doc (modified) * testsuites/psxtests/psxpasswd02/Makefile.am (modified) * testsuites/psxtests/psxpasswd02/init.c (modified) * testsuites/psxtests/psxpasswd02/psxpasswd02.doc (modified) * testsuites/psxtests/psxpipe01/Makefile.am (modified) * testsuites/psxtests/psxpipe01/init.c (modified) * testsuites/psxtests/psxpipe01/psxpipe01.doc (modified) * testsuites/psxtests/psxrdwrv/Makefile.am (modified) * testsuites/psxtests/psxrdwrv/main.c (modified) * testsuites/psxtests/psxrdwrv/test.c (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxreaddir/test.c (modified) * testsuites/psxtests/psxrwlock01/Makefile.am (modified) * testsuites/psxtests/psxrwlock01/main.c (modified) * testsuites/psxtests/psxrwlock01/test.c (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxsem01/init.c (modified) * testsuites/psxtests/psxsignal01/Makefile.am (modified) * testsuites/psxtests/psxsignal01/init.c (modified) * testsuites/psxtests/psxsignal01/system.h (modified) * testsuites/psxtests/psxsignal01/task1.c (modified) * testsuites/psxtests/psxsignal02/Makefile.am (modified) * testsuites/psxtests/psxsignal02/init.c (modified) * testsuites/psxtests/psxsignal02/psxsignal02.doc (modified) * testsuites/psxtests/psxsignal03/Makefile.am (modified) * testsuites/psxtests/psxsignal03/init.c (modified) * testsuites/psxtests/psxsignal03/psxsignal03.doc (modified) * testsuites/psxtests/psxsignal04/Makefile.am (modified) * testsuites/psxtests/psxsignal04/psxsignal04.doc (modified) * testsuites/psxtests/psxsignal05/Makefile.am (modified) * testsuites/psxtests/psxsignal05/init.c (modified) * testsuites/psxtests/psxsignal05/psxsignal05.doc (modified) * testsuites/psxtests/psxsignal06/Makefile.am (modified) * testsuites/psxtests/psxsignal06/init.c (modified) * testsuites/psxtests/psxsignal06/psxsignal06.doc (modified) * testsuites/psxtests/psxspin01/Makefile.am (modified) * testsuites/psxtests/psxspin01/main.c (modified) * testsuites/psxtests/psxspin01/test.c (modified) * testsuites/psxtests/psxspin02/Makefile.am (modified) * testsuites/psxtests/psxspin02/main.c (modified) * testsuites/psxtests/psxspin02/psxspin02.doc (modified) * testsuites/psxtests/psxspin02/test.c (modified) * testsuites/psxtests/psxstack01/Makefile.am (modified) * testsuites/psxtests/psxstack01/init.c (modified) * testsuites/psxtests/psxstack01/psxstack01.doc (modified) * testsuites/psxtests/psxstack02/Makefile.am (modified) * testsuites/psxtests/psxstack02/init.c (modified) * testsuites/psxtests/psxstack02/psxstack02.doc (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxsysconf/Makefile.am (modified) * testsuites/psxtests/psxsysconf/init.c (modified) * testsuites/psxtests/psxsysconf/system.h (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtime/main.c (modified) * testsuites/psxtests/psxtime/test.c (modified) * testsuites/psxtests/psxtimer01/Makefile.am (modified) * testsuites/psxtests/psxtimer01/psxtimer.c (modified) * testsuites/psxtests/psxtimer01/system.h (modified) * testsuites/psxtests/psxtimer02/Makefile.am (modified) * testsuites/psxtests/psxtimer02/psxtimer.c (modified) * testsuites/psxtests/psxtimer02/system.h (modified) * testsuites/psxtests/psxtimes01/Makefile.am (modified) * testsuites/psxtests/psxtimes01/init.c (modified) * testsuites/psxtests/psxtimes01/psxtimes01.doc (modified) * testsuites/psxtests/psxualarm/Makefile.am (modified) * testsuites/psxtests/psxualarm/init.c (modified) * testsuites/psxtests/psxualarm/system.h (modified) * testsuites/psxtests/psxusleep/Makefile.am (modified) * testsuites/psxtests/psxusleep/init.c (modified) * testsuites/psxtests/psxusleep/psxusleep.doc (modified) * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/README (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmbarrier01/Makefile.am (modified) * testsuites/psxtmtests/psxtmbarrier01/init.c (modified) * testsuites/psxtmtests/psxtmbarrier01/psxtmbarrier01.doc (modified) * testsuites/psxtmtests/psxtmbarrier02/Makefile.am (modified) * testsuites/psxtmtests/psxtmbarrier02/init.c (modified) * testsuites/psxtmtests/psxtmbarrier02/psxtmbarrier02.doc (modified) * testsuites/psxtmtests/psxtmbarrier03/Makefile.am (modified) * testsuites/psxtmtests/psxtmbarrier03/init.c (modified) * testsuites/psxtmtests/psxtmbarrier03/psxtmbarrier03.doc (modified) * testsuites/psxtmtests/psxtmkey01/Makefile.am (modified) * testsuites/psxtmtests/psxtmkey01/init.c (modified) * testsuites/psxtmtests/psxtmkey01/psxtmkey01.doc (modified) * testsuites/psxtmtests/psxtmkey02/Makefile.am (modified) * testsuites/psxtmtests/psxtmkey02/init.c (modified) * testsuites/psxtmtests/psxtmkey02/psxtmkey02.doc (modified) * testsuites/psxtmtests/psxtmmq01/Makefile.am (modified) * testsuites/psxtmtests/psxtmmq01/init.c (modified) * testsuites/psxtmtests/psxtmmq01/psxtmmq01.doc (modified) * testsuites/psxtmtests/psxtmmutex01/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex01/init.c (modified) * testsuites/psxtmtests/psxtmmutex01/psxtmmutex01.doc (modified) * testsuites/psxtmtests/psxtmmutex02/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex02/init.c (modified) * testsuites/psxtmtests/psxtmmutex02/psxtmmutex02.doc (modified) * testsuites/psxtmtests/psxtmmutex03/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex03/init.c (modified) * testsuites/psxtmtests/psxtmmutex03/psxtmmutex03.doc (modified) * testsuites/psxtmtests/psxtmmutex04/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex04/init.c (modified) * testsuites/psxtmtests/psxtmmutex04/psxtmmutex04.doc (modified) * testsuites/psxtmtests/psxtmmutex05/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex05/init.c (modified) * testsuites/psxtmtests/psxtmmutex05/psxtmmutex05.doc (modified) * testsuites/psxtmtests/psxtmmutex06/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex06/init.c (modified) * testsuites/psxtmtests/psxtmmutex06/psxtmmutex06.doc (modified) * testsuites/psxtmtests/psxtmmutex07/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex07/init.c (modified) * testsuites/psxtmtests/psxtmmutex07/psxtmmutex07.doc (modified) * testsuites/psxtmtests/psxtmnanosleep01/Makefile.am (modified) * testsuites/psxtmtests/psxtmnanosleep01/init.c (modified) * testsuites/psxtmtests/psxtmnanosleep01/psxtmnanosleep01.doc (modified) * testsuites/psxtmtests/psxtmnanosleep02/Makefile.am (modified) * testsuites/psxtmtests/psxtmnanosleep02/init.c (modified) * testsuites/psxtmtests/psxtmnanosleep02/psxtmnanosleep02.doc (modified) * testsuites/psxtmtests/psxtmrwlock01/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock01/init.c (modified) * testsuites/psxtmtests/psxtmrwlock01/psxtmrwlock01.doc (modified) * testsuites/psxtmtests/psxtmrwlock02/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock02/init.c (modified) * testsuites/psxtmtests/psxtmrwlock02/psxtmrwlock02.doc (modified) * testsuites/psxtmtests/psxtmrwlock03/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock03/init.c (modified) * testsuites/psxtmtests/psxtmrwlock03/psxtmrwlock03.doc (modified) * testsuites/psxtmtests/psxtmrwlock04/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock04/init.c (modified) * testsuites/psxtmtests/psxtmrwlock04/psxtmrwlock04.doc (modified) * testsuites/psxtmtests/psxtmrwlock05/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock05/init.c (modified) * testsuites/psxtmtests/psxtmrwlock05/psxtmrwlock05.doc (modified) * testsuites/psxtmtests/psxtmrwlock06/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock06/init.c (modified) * testsuites/psxtmtests/psxtmrwlock06/psxtmrwlock06.doc (modified) * testsuites/psxtmtests/psxtmrwlock07/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock07/init.c (modified) * testsuites/psxtmtests/psxtmrwlock07/psxtmrwlock07.doc (modified) * testsuites/psxtmtests/psxtmsem01/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem01/init.c (modified) * testsuites/psxtmtests/psxtmsem01/psxtmsem01.doc (modified) * testsuites/psxtmtests/psxtmsem02/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem02/init.c (modified) * testsuites/psxtmtests/psxtmsem02/psxtmsem02.doc (modified) * testsuites/psxtmtests/psxtmsem03/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem03/init.c (modified) * testsuites/psxtmtests/psxtmsem03/psxtmsem03.doc (modified) * testsuites/psxtmtests/psxtmsem04/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem04/init.c (modified) * testsuites/psxtmtests/psxtmsem04/psxtmsem04.doc (modified) * testsuites/psxtmtests/psxtmsem05/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem05/init.c (modified) * testsuites/psxtmtests/psxtmsem05/psxtmsem05.doc (modified) * testsuites/psxtmtests/psxtmsleep01/Makefile.am (modified) * testsuites/psxtmtests/psxtmsleep01/init.c (modified) * testsuites/psxtmtests/psxtmsleep01/psxtmsleep01.doc (modified) * testsuites/psxtmtests/psxtmsleep02/Makefile.am (modified) * testsuites/psxtmtests/psxtmsleep02/init.c (modified) * testsuites/psxtmtests/psxtmsleep02/psxtmsleep02.doc (modified) * testsuites/psxtmtests/psxtmthread01/Makefile.am (modified) * testsuites/psxtmtests/psxtmthread01/init.c (modified) * testsuites/psxtmtests/psxtmthread01/psxtmthread01.doc (modified) * testsuites/psxtmtests/psxtmthread03/Makefile.am (modified) * testsuites/psxtmtests/psxtmthread03/init.c (modified) * testsuites/psxtmtests/psxtmthread03/psxtmthread03.doc (modified) * testsuites/samples/Makefile.am (modified) * testsuites/samples/README (modified) * testsuites/samples/base_mp/Makefile.am (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node1/base_mp-node1.doc (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/base_mp/node2/base_mp-node2.doc (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/Makefile.am (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/base_sp.doc (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/capture/Makefile.am (modified) * testsuites/samples/capture/capture.doc (modified) * testsuites/samples/capture/init.c (modified) * testsuites/samples/capture/system.h (modified) * testsuites/samples/capture/test1.c (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/main.cc (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/configure.ac (modified) * testsuites/samples/fileio/init.c (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/hello/hello.doc (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/iostream/Makefile.am (modified) * testsuites/samples/iostream/init.cc (modified) * testsuites/samples/iostream/iostream.doc (modified) * testsuites/samples/iostream/system.h (modified) * testsuites/samples/loopback/Makefile.am (modified) * testsuites/samples/loopback/README (modified) * testsuites/samples/loopback/init.c (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/minimum/minimum.doc (modified) * testsuites/samples/nsecs/Makefile.am (modified) * testsuites/samples/nsecs/empty.c (modified) * testsuites/samples/nsecs/init.c (modified) * testsuites/samples/nsecs/nsecs.doc (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/paranoia.c (modified) * testsuites/samples/paranoia/paranoia.doc (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/pppd/Makefile.am (modified) * testsuites/samples/pppd/README (modified) * testsuites/samples/pppd/netconfig.h (modified) * testsuites/samples/pppd/system.h (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/ticker/ticker.doc (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/system.h (modified) * testsuites/samples/unlimited/test1.c (modified) * testsuites/samples/unlimited/test2.c (modified) * testsuites/samples/unlimited/test3.c (modified) * testsuites/samples/unlimited/unlimited.doc (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/README (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smp01/Makefile.am (modified) * testsuites/smptests/smp01/init.c (modified) * testsuites/smptests/smp01/smp01.doc (modified) * testsuites/smptests/smp01/system.h (modified) * testsuites/smptests/smp01/tasks.c (modified) * testsuites/smptests/smp02/Makefile.am (modified) * testsuites/smptests/smp02/init.c (modified) * testsuites/smptests/smp02/smp02.doc (modified) * testsuites/smptests/smp02/system.h (modified) * testsuites/smptests/smp02/tasks.c (modified) * testsuites/smptests/smp03/Makefile.am (modified) * testsuites/smptests/smp03/init.c (modified) * testsuites/smptests/smp03/smp03.doc (modified) * testsuites/smptests/smp03/system.h (modified) * testsuites/smptests/smp03/tasks.c (modified) * testsuites/smptests/smp04/Makefile.am (modified) * testsuites/smptests/smp04/init.c (modified) * testsuites/smptests/smp04/smp04.doc (modified) * testsuites/smptests/smp04/system.h (modified) * testsuites/smptests/smp05/Makefile.am (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp05/smp05.doc (modified) * testsuites/smptests/smp06/Makefile.am (modified) * testsuites/smptests/smp06/init.c (modified) * testsuites/smptests/smp06/smp06.doc (modified) * testsuites/smptests/smp07/Makefile.am (modified) * testsuites/smptests/smp07/init.c (modified) * testsuites/smptests/smp07/smp07.doc (modified) * testsuites/smptests/smp08/Makefile.am (modified) * testsuites/smptests/smp08/init.c (modified) * testsuites/smptests/smp08/smp08.doc (modified) * testsuites/smptests/smp08/system.h (modified) * testsuites/smptests/smp08/tasks.c (modified) * testsuites/smptests/smp09/Makefile.am (modified) * testsuites/smptests/smp09/init.c (modified) * testsuites/smptests/smp09/smp09.doc (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/README (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/sp01/sp01.doc (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp01/task1.c (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp02/init.c (modified) * testsuites/sptests/sp02/preempt.c (modified) * testsuites/sptests/sp02/sp02.doc (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp02/task1.c (modified) * testsuites/sptests/sp02/task2.c (modified) * testsuites/sptests/sp02/task3.c (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp03/init.c (modified) * testsuites/sptests/sp03/sp03.doc (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp03/task1.c (modified) * testsuites/sptests/sp03/task2.c (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp04/init.c (modified) * testsuites/sptests/sp04/sp04.doc (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp04/task2.c (modified) * testsuites/sptests/sp04/task3.c (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp05/init.c (modified) * testsuites/sptests/sp05/sp05.doc (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp05/task1.c (modified) * testsuites/sptests/sp05/task2.c (modified) * testsuites/sptests/sp05/task3.c (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp06/init.c (modified) * testsuites/sptests/sp06/sp06.doc (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp06/task1.c (modified) * testsuites/sptests/sp06/task2.c (modified) * testsuites/sptests/sp06/task3.c (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/sp07.doc (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/task1.c (modified) * testsuites/sptests/sp07/task2.c (modified) * testsuites/sptests/sp07/task3.c (modified) * testsuites/sptests/sp07/task4.c (modified) * testsuites/sptests/sp07/taskexit.c (modified) * testsuites/sptests/sp07/tcreate.c (modified) * testsuites/sptests/sp07/tdelete.c (modified) * testsuites/sptests/sp07/trestart.c (modified) * testsuites/sptests/sp07/tstart.c (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp08/sp08.doc (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp09/delay.c (modified) * testsuites/sptests/sp09/init.c (modified) * testsuites/sptests/sp09/isr.c (modified) * testsuites/sptests/sp09/screen01.c (modified) * testsuites/sptests/sp09/screen02.c (modified) * testsuites/sptests/sp09/screen03.c (modified) * testsuites/sptests/sp09/screen04.c (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen06.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/screen10.c (modified) * testsuites/sptests/sp09/screen11.c (modified) * testsuites/sptests/sp09/screen12.c (modified) * testsuites/sptests/sp09/screen13.c (modified) * testsuites/sptests/sp09/screen14.c (modified) * testsuites/sptests/sp09/sp09.doc (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp09/task1.c (modified) * testsuites/sptests/sp09/task2.c (modified) * testsuites/sptests/sp09/task3.c (modified) * testsuites/sptests/sp09/task4.c (modified) * testsuites/sptests/sp10/Makefile.am (modified) * testsuites/sptests/sp10/init.c (modified) * testsuites/sptests/sp10/sp10.doc (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp11/init.c (modified) * testsuites/sptests/sp11/sp11.doc (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp11/task1.c (modified) * testsuites/sptests/sp11/task2.c (modified) * testsuites/sptests/sp11/timer.c (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp12/init.c (modified) * testsuites/sptests/sp12/pridrv.c (modified) * testsuites/sptests/sp12/pritask.c (modified) * testsuites/sptests/sp12/sp12.doc (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp12/task1.c (modified) * testsuites/sptests/sp12/task2.c (modified) * testsuites/sptests/sp12/task3.c (modified) * testsuites/sptests/sp12/task4.c (modified) * testsuites/sptests/sp12/task5.c (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/sp13.doc (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp13/task3.c (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp14/asr.c (modified) * testsuites/sptests/sp14/init.c (modified) * testsuites/sptests/sp14/sp14.doc (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp14/task1.c (modified) * testsuites/sptests/sp14/task2.c (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp15/init.c (modified) * testsuites/sptests/sp15/sp15.doc (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp15/task1.c (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp16/init.c (modified) * testsuites/sptests/sp16/sp16.doc (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp16/task1.c (modified) * testsuites/sptests/sp16/task2.c (modified) * testsuites/sptests/sp16/task3.c (modified) * testsuites/sptests/sp16/task4.c (modified) * testsuites/sptests/sp16/task5.c (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp17/asr.c (modified) * testsuites/sptests/sp17/init.c (modified) * testsuites/sptests/sp17/sp17.doc (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp17/task1.c (modified) * testsuites/sptests/sp17/task2.c (modified) * testsuites/sptests/sp18/Makefile.am (modified) * testsuites/sptests/sp18/init.c (modified) * testsuites/sptests/sp18/sp18.doc (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp19/first.c (modified) * testsuites/sptests/sp19/fptask.c (modified) * testsuites/sptests/sp19/fptest.h (modified) * testsuites/sptests/sp19/init.c (modified) * testsuites/sptests/sp19/inttest.h (modified) * testsuites/sptests/sp19/sp19.doc (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp19/task1.c (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp20/getall.c (modified) * testsuites/sptests/sp20/init.c (modified) * testsuites/sptests/sp20/sp20.doc (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp20/task1.c (modified) * testsuites/sptests/sp2038/Makefile.am (modified) * testsuites/sptests/sp2038/init.c (modified) * testsuites/sptests/sp2038/sp2038.doc (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp21/init.c (modified) * testsuites/sptests/sp21/sp21.doc (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp22/delay.c (modified) * testsuites/sptests/sp22/init.c (modified) * testsuites/sptests/sp22/prtime.c (modified) * testsuites/sptests/sp22/sp22.doc (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp22/task1.c (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp23/init.c (modified) * testsuites/sptests/sp23/sp23.doc (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp23/task1.c (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp24/init.c (modified) * testsuites/sptests/sp24/resume.c (modified) * testsuites/sptests/sp24/sp24.doc (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp24/task1.c (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp25/init.c (modified) * testsuites/sptests/sp25/sp25.doc (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp25/task1.c (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp26/init.c (modified) * testsuites/sptests/sp26/sp26.doc (modified) * testsuites/sptests/sp26/system.h (modified) * testsuites/sptests/sp26/task1.c (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp27/init.c (modified) * testsuites/sptests/sp27/sp27.doc (modified) * testsuites/sptests/sp27a/Makefile.am (modified) * testsuites/sptests/sp27a/sp27a.doc (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp28/init.c (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/sp29/init.c (modified) * testsuites/sptests/sp30/Makefile.am (modified) * testsuites/sptests/sp30/init.c (modified) * testsuites/sptests/sp30/resume.c (modified) * testsuites/sptests/sp30/sp30.doc (modified) * testsuites/sptests/sp30/system.h (modified) * testsuites/sptests/sp30/task1.c (modified) * testsuites/sptests/sp31/Makefile.am (modified) * testsuites/sptests/sp31/delay.c (modified) * testsuites/sptests/sp31/init.c (modified) * testsuites/sptests/sp31/prtime.c (modified) * testsuites/sptests/sp31/sp31.doc (modified) * testsuites/sptests/sp31/system.h (modified) * testsuites/sptests/sp31/task1.c (modified) * testsuites/sptests/sp32/Makefile.am (modified) * testsuites/sptests/sp32/init.c (modified) * testsuites/sptests/sp32/sp32.doc (modified) * testsuites/sptests/sp33/Makefile.am (modified) * testsuites/sptests/sp33/init.c (modified) * testsuites/sptests/sp33/sp33.doc (modified) * testsuites/sptests/sp34/Makefile.am (modified) * testsuites/sptests/sp34/changepri.c (modified) * testsuites/sptests/sp35/Makefile.am (modified) * testsuites/sptests/sp35/priinv.c (modified) * testsuites/sptests/sp36/Makefile.am (modified) * testsuites/sptests/sp36/strict_order_mut.c (modified) * testsuites/sptests/sp37/Makefile.am (modified) * testsuites/sptests/sp37/sp37.doc (modified) * testsuites/sptests/sp38/Makefile.am (modified) * testsuites/sptests/sp38/init.c (modified) * testsuites/sptests/sp38/sp38.doc (modified) * testsuites/sptests/sp38/system.h (modified) * testsuites/sptests/sp39/Makefile.am (modified) * testsuites/sptests/sp39/init.c (modified) * testsuites/sptests/sp39/sp39.doc (modified) * testsuites/sptests/sp39/system.h (modified) * testsuites/sptests/sp40/Makefile.am (modified) * testsuites/sptests/sp40/init.c (modified) * testsuites/sptests/sp40/sp40.doc (modified) * testsuites/sptests/sp41/Makefile.am (modified) * testsuites/sptests/sp41/init.c (modified) * testsuites/sptests/sp41/sp41.doc (modified) * testsuites/sptests/sp42/Makefile.am (modified) * testsuites/sptests/sp42/init.c (modified) * testsuites/sptests/sp42/sp42.doc (modified) * testsuites/sptests/sp43/Makefile.am (modified) * testsuites/sptests/sp43/init.c (modified) * testsuites/sptests/sp43/sp43.doc (modified) * testsuites/sptests/sp43/system.h (modified) * testsuites/sptests/sp44/Makefile.am (modified) * testsuites/sptests/sp44/init.c (modified) * testsuites/sptests/sp44/sp44.doc (modified) * testsuites/sptests/sp45/Makefile.am (modified) * testsuites/sptests/sp45/init.c (modified) * testsuites/sptests/sp45/sp45.doc (modified) * testsuites/sptests/sp46/Makefile.am (modified) * testsuites/sptests/sp46/init.c (modified) * testsuites/sptests/sp46/sp46.doc (modified) * testsuites/sptests/sp47/Makefile.am (modified) * testsuites/sptests/sp47/init.c (modified) * testsuites/sptests/sp47/sp47.doc (modified) * testsuites/sptests/sp48/Makefile.am (modified) * testsuites/sptests/sp48/init.c (modified) * testsuites/sptests/sp48/sp48.doc (modified) * testsuites/sptests/sp49/Makefile.am (modified) * testsuites/sptests/sp49/init.c (modified) * testsuites/sptests/sp49/sp49.doc (modified) * testsuites/sptests/sp50/Makefile.am (modified) * testsuites/sptests/sp50/init.c (modified) * testsuites/sptests/sp50/sp50.doc (modified) * testsuites/sptests/sp51/Makefile.am (modified) * testsuites/sptests/sp51/init.c (modified) * testsuites/sptests/sp51/sp51.doc (modified) * testsuites/sptests/sp52/Makefile.am (modified) * testsuites/sptests/sp52/init.c (modified) * testsuites/sptests/sp52/sp52.doc (modified) * testsuites/sptests/sp53/Makefile.am (modified) * testsuites/sptests/sp53/sp53.doc (modified) * testsuites/sptests/sp54/Makefile.am (modified) * testsuites/sptests/sp54/init.c (modified) * testsuites/sptests/sp54/sp54.doc (modified) * testsuites/sptests/sp55/Makefile.am (modified) * testsuites/sptests/sp55/init.c (modified) * testsuites/sptests/sp55/sp55.doc (modified) * testsuites/sptests/sp56/Makefile.am (modified) * testsuites/sptests/sp56/init.c (modified) * testsuites/sptests/sp56/sp56.doc (modified) * testsuites/sptests/sp57/Makefile.am (modified) * testsuites/sptests/sp57/init.c (modified) * testsuites/sptests/sp57/sp57.doc (modified) * testsuites/sptests/sp58/Makefile.am (modified) * testsuites/sptests/sp58/init.c (modified) * testsuites/sptests/sp58/sp58.doc (modified) * testsuites/sptests/sp59/Makefile.am (modified) * testsuites/sptests/sp59/init.c (modified) * testsuites/sptests/sp59/sp59.doc (modified) * testsuites/sptests/sp60/Makefile.am (modified) * testsuites/sptests/sp60/init.c (modified) * testsuites/sptests/sp60/sp60.doc (modified) * testsuites/sptests/sp62/Makefile.am (modified) * testsuites/sptests/sp62/init.c (modified) * testsuites/sptests/sp62/sp62.doc (modified) * testsuites/sptests/sp63/Makefile.am (modified) * testsuites/sptests/sp63/init.c (modified) * testsuites/sptests/sp63/sp63.doc (modified) * testsuites/sptests/sp64/Makefile.am (modified) * testsuites/sptests/sp64/init.c (modified) * testsuites/sptests/sp64/sp64.doc (modified) * testsuites/sptests/sp65/Makefile.am (modified) * testsuites/sptests/sp65/init.c (modified) * testsuites/sptests/sp65/sp65.doc (modified) * testsuites/sptests/sp66/Makefile.am (modified) * testsuites/sptests/sp66/sp66.doc (modified) * testsuites/sptests/sp67/Makefile.am (modified) * testsuites/sptests/sp67/init.c (modified) * testsuites/sptests/sp67/sp67.doc (modified) * testsuites/sptests/sp68/Makefile.am (modified) * testsuites/sptests/sp68/init.c (modified) * testsuites/sptests/sp68/sp68.doc (modified) * testsuites/sptests/sp69/Makefile.am (modified) * testsuites/sptests/sp69/init.c (modified) * testsuites/sptests/sp69/sp69.doc (modified) * testsuites/sptests/sp70/Makefile.am (modified) * testsuites/sptests/sp70/init.c (modified) * testsuites/sptests/sp70/sp70.doc (modified) * testsuites/sptests/sp71/Makefile.am (modified) * testsuites/sptests/sp71/init.c (modified) * testsuites/sptests/sp71/sp71.doc (modified) * testsuites/sptests/sp72/Makefile.am (modified) * testsuites/sptests/sp72/init.c (modified) * testsuites/sptests/sp72/sp72.doc (modified) * testsuites/sptests/sp73/Makefile.am (modified) * testsuites/sptests/sp73/init.c (modified) * testsuites/sptests/sp73/sp73.doc (modified) * testsuites/sptests/sp74/Makefile.am (modified) * testsuites/sptests/sp74/init.c (modified) * testsuites/sptests/sp74/sp74.doc (modified) * testsuites/sptests/sp75/Makefile.am (modified) * testsuites/sptests/sp75/init.c (modified) * testsuites/sptests/sp75/sp75.doc (modified) * testsuites/sptests/sp76/Makefile.am (modified) * testsuites/sptests/sp76/init.c (modified) * testsuites/sptests/sp76/sp76.doc (modified) * testsuites/sptests/spassoc01/Makefile.am (modified) * testsuites/sptests/spassoc01/init.c (modified) * testsuites/sptests/spassoc01/spassoc01.doc (modified) * testsuites/sptests/spcbssched01/Makefile.am (modified) * testsuites/sptests/spcbssched01/init.c (modified) * testsuites/sptests/spcbssched01/spcbssched01.doc (modified) * testsuites/sptests/spcbssched01/system.h (modified) * testsuites/sptests/spcbssched01/task1.c (modified) * testsuites/sptests/spcbssched02/Makefile.am (modified) * testsuites/sptests/spcbssched02/init.c (modified) * testsuites/sptests/spcbssched02/spcbssched02.doc (modified) * testsuites/sptests/spcbssched02/system.h (modified) * testsuites/sptests/spcbssched02/task_periodic.c (modified) * testsuites/sptests/spcbssched03/Makefile.am (modified) * testsuites/sptests/spcbssched03/cbsparams.h (modified) * testsuites/sptests/spcbssched03/init.c (modified) * testsuites/sptests/spcbssched03/spcbssched03.doc (modified) * testsuites/sptests/spcbssched03/system.h (modified) * testsuites/sptests/spcbssched03/tasks_aperiodic.c (modified) * testsuites/sptests/spcbssched03/tasks_periodic.c (modified) * testsuites/sptests/spchain/Makefile.am (modified) * testsuites/sptests/spchain/init.c (modified) * testsuites/sptests/spchain/spchain.doc (modified) * testsuites/sptests/spclockget/Makefile.am (modified) * testsuites/sptests/spclockget/init.c (modified) * testsuites/sptests/spclockget/spclockget.doc (modified) * testsuites/sptests/spcoverage/Makefile.am (modified) * testsuites/sptests/spcoverage/init.c (modified) * testsuites/sptests/spcoverage/spcoverage.doc (modified) * testsuites/sptests/spedfsched01/Makefile.am (modified) * testsuites/sptests/spedfsched01/init.c (modified) * testsuites/sptests/spedfsched01/spedfsched01.doc (modified) * testsuites/sptests/spedfsched01/system.h (modified) * testsuites/sptests/spedfsched01/task1.c (modified) * testsuites/sptests/spedfsched02/Makefile.am (modified) * testsuites/sptests/spedfsched02/getall.c (modified) * testsuites/sptests/spedfsched02/init.c (modified) * testsuites/sptests/spedfsched02/spedfsched02.doc (modified) * testsuites/sptests/spedfsched02/system.h (modified) * testsuites/sptests/spedfsched02/task1.c (modified) * testsuites/sptests/spedfsched03/Makefile.am (modified) * testsuites/sptests/spedfsched03/edfparams.h (modified) * testsuites/sptests/spedfsched03/init.c (modified) * testsuites/sptests/spedfsched03/spedfsched03.doc (modified) * testsuites/sptests/spedfsched03/system.h (modified) * testsuites/sptests/spedfsched03/tasks_aperiodic.c (modified) * testsuites/sptests/spedfsched03/tasks_periodic.c (modified) * testsuites/sptests/sperror01/Makefile.am (modified) * testsuites/sptests/sperror01/init.c (modified) * testsuites/sptests/sperror01/sperror01.doc (modified) * testsuites/sptests/sperror02/Makefile.am (modified) * testsuites/sptests/sperror02/init.c (modified) * testsuites/sptests/sperror02/sperror02.doc (modified) * testsuites/sptests/sperror03/Makefile.am (modified) * testsuites/sptests/sperror03/init.c (modified) * testsuites/sptests/sperror03/sperror03.doc (modified) * testsuites/sptests/spfatal01/Makefile.am (modified) * testsuites/sptests/spfatal01/spfatal01.doc (modified) * testsuites/sptests/spfatal01/testcase.h (modified) * testsuites/sptests/spfatal02/Makefile.am (modified) * testsuites/sptests/spfatal02/spfatal02.doc (modified) * testsuites/sptests/spfatal02/testcase.h (modified) * testsuites/sptests/spfatal03/Makefile.am (modified) * testsuites/sptests/spfatal03/spfatal03.doc (modified) * testsuites/sptests/spfatal03/testcase.h (modified) * testsuites/sptests/spfatal04/Makefile.am (modified) * testsuites/sptests/spfatal04/spfatal04.doc (modified) * testsuites/sptests/spfatal04/testcase.h (modified) * testsuites/sptests/spfatal05/Makefile.am (modified) * testsuites/sptests/spfatal05/spfatal05.doc (modified) * testsuites/sptests/spfatal05/testcase.h (modified) * testsuites/sptests/spfatal06/Makefile.am (modified) * testsuites/sptests/spfatal06/spfatal06.doc (modified) * testsuites/sptests/spfatal06/testcase.h (modified) * testsuites/sptests/spfatal07/Makefile.am (modified) * testsuites/sptests/spfatal07/spfatal07.doc (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spfatal08/Makefile.am (modified) * testsuites/sptests/spfatal08/spfatal08.doc (modified) * testsuites/sptests/spfatal08/testcase.h (modified) * testsuites/sptests/spfatal09/Makefile.am (modified) * testsuites/sptests/spfatal09/spfatal09.doc (modified) * testsuites/sptests/spfatal09/testcase.h (modified) * testsuites/sptests/spfatal10/Makefile.am (modified) * testsuites/sptests/spfatal10/spfatal10.doc (modified) * testsuites/sptests/spfatal10/testcase.h (modified) * testsuites/sptests/spfatal11/Makefile.am (modified) * testsuites/sptests/spfatal11/spfatal11.doc (modified) * testsuites/sptests/spfatal11/testcase.h (modified) * testsuites/sptests/spfatal12/Makefile.am (modified) * testsuites/sptests/spfatal12/spfatal12.doc (modified) * testsuites/sptests/spfatal12/testcase.h (modified) * testsuites/sptests/spfatal13/Makefile.am (modified) * testsuites/sptests/spfatal13/spfatal13.doc (modified) * testsuites/sptests/spfatal13/testcase.h (modified) * testsuites/sptests/spfatal14/Makefile.am (modified) * testsuites/sptests/spfatal14/spfatal14.doc (modified) * testsuites/sptests/spfatal14/testcase.h (modified) * testsuites/sptests/spfatal15/Makefile.am (modified) * testsuites/sptests/spfatal15/spfatal15.doc (modified) * testsuites/sptests/spfatal15/testcase.h (modified) * testsuites/sptests/spfatal16/Makefile.am (modified) * testsuites/sptests/spfatal16/spfatal16.doc (modified) * testsuites/sptests/spfatal16/testcase.h (modified) * testsuites/sptests/spfatal17/Makefile.am (modified) * testsuites/sptests/spfatal17/spfatal17.doc (modified) * testsuites/sptests/spfatal17/testcase.h (modified) * testsuites/sptests/spfatal18/Makefile.am (modified) * testsuites/sptests/spfatal18/spfatal18.doc (modified) * testsuites/sptests/spfatal18/testcase.h (modified) * testsuites/sptests/spfatal19/Makefile.am (modified) * testsuites/sptests/spfatal19/spfatal19.doc (modified) * testsuites/sptests/spfatal19/testcase.h (modified) * testsuites/sptests/spfatal20/Makefile.am (modified) * testsuites/sptests/spfatal20/spfatal20.doc (modified) * testsuites/sptests/spfatal20/testcase.h (modified) * testsuites/sptests/spfatal21/Makefile.am (modified) * testsuites/sptests/spfatal21/spfatal21.doc (modified) * testsuites/sptests/spfatal21/testcase.h (modified) * testsuites/sptests/spfatal22/Makefile.am (modified) * testsuites/sptests/spfatal22/spfatal22.doc (modified) * testsuites/sptests/spfatal22/testcase.h (modified) * testsuites/sptests/spfatal23/Makefile.am (modified) * testsuites/sptests/spfatal23/spfatal23.doc (modified) * testsuites/sptests/spfatal23/testcase.h (modified) * testsuites/sptests/spfatal24/Makefile.am (modified) * testsuites/sptests/spfatal24/spfatal24.doc (modified) * testsuites/sptests/spfatal24/testcase.h (modified) * testsuites/sptests/spfatal25/Makefile.am (modified) * testsuites/sptests/spfatal25/spfatal25.doc (modified) * testsuites/sptests/spfatal25/testcase.h (modified) * testsuites/sptests/spfatal_support/consume_sems.c (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) * testsuites/sptests/spfifo01/Makefile.am (modified) * testsuites/sptests/spfifo01/init.c (modified) * testsuites/sptests/spfifo01/spfifo01.doc (modified) * testsuites/sptests/spfifo02/Makefile.am (modified) * testsuites/sptests/spfifo02/init.c (modified) * testsuites/sptests/spfifo02/spfifo02.doc (modified) * testsuites/sptests/spfifo03/Makefile.am (modified) * testsuites/sptests/spfifo03/init.c (modified) * testsuites/sptests/spfifo03/spfifo03.doc (modified) * testsuites/sptests/spfifo04/Makefile.am (modified) * testsuites/sptests/spfifo04/init.c (modified) * testsuites/sptests/spfifo04/spfifo04.doc (modified) * testsuites/sptests/spfifo05/Makefile.am (modified) * testsuites/sptests/spfifo05/init.c (modified) * testsuites/sptests/spfifo05/spfifo05.doc (modified) * testsuites/sptests/spheapprot/Makefile.am (modified) * testsuites/sptests/spheapprot/init.c (modified) * testsuites/sptests/spheapprot/spheapprot.doc (modified) * testsuites/sptests/spintrcritical01/Makefile.am (modified) * testsuites/sptests/spintrcritical01/init.c (modified) * testsuites/sptests/spintrcritical01/spintrcritical01.doc (modified) * testsuites/sptests/spintrcritical02/Makefile.am (modified) * testsuites/sptests/spintrcritical02/spintrcritical02.doc (modified) * testsuites/sptests/spintrcritical03/Makefile.am (modified) * testsuites/sptests/spintrcritical03/spintrcritical03.doc (modified) * testsuites/sptests/spintrcritical04/Makefile.am (modified) * testsuites/sptests/spintrcritical04/spintrcritical04.doc (modified) * testsuites/sptests/spintrcritical05/Makefile.am (modified) * testsuites/sptests/spintrcritical05/spintrcritical05.doc (modified) * testsuites/sptests/spintrcritical06/Makefile.am (modified) * testsuites/sptests/spintrcritical06/init.c (modified) * testsuites/sptests/spintrcritical06/spintrcritical06.doc (modified) * testsuites/sptests/spintrcritical07/Makefile.am (modified) * testsuites/sptests/spintrcritical07/spintrcritical07.doc (modified) * testsuites/sptests/spintrcritical08/Makefile.am (modified) * testsuites/sptests/spintrcritical08/init.c (modified) * testsuites/sptests/spintrcritical08/spintrcritical08.doc (modified) * testsuites/sptests/spintrcritical09/Makefile.am (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spintrcritical09/spintrcritical09.doc (modified) * testsuites/sptests/spintrcritical10/Makefile.am (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical10/spintrcritical10.doc (modified) * testsuites/sptests/spintrcritical11/Makefile.am (modified) * testsuites/sptests/spintrcritical11/init.c (modified) * testsuites/sptests/spintrcritical11/spintrcritical11.doc (modified) * testsuites/sptests/spintrcritical12/Makefile.am (modified) * testsuites/sptests/spintrcritical12/spintrcritical12.doc (modified) * testsuites/sptests/spintrcritical13/Makefile.am (modified) * testsuites/sptests/spintrcritical13/init.c (modified) * testsuites/sptests/spintrcritical13/spintrcritical13.doc (modified) * testsuites/sptests/spintrcritical14/Makefile.am (modified) * testsuites/sptests/spintrcritical14/spintrcritical14.doc (modified) * testsuites/sptests/spintrcritical15/Makefile.am (modified) * testsuites/sptests/spintrcritical15/init.c (modified) * testsuites/sptests/spintrcritical15/spintrcritical15.doc (modified) * testsuites/sptests/spintrcritical16/Makefile.am (modified) * testsuites/sptests/spintrcritical16/init.c (modified) * testsuites/sptests/spintrcritical16/spintrcritical16.doc (modified) * testsuites/sptests/spintrcritical17/Makefile.am (modified) * testsuites/sptests/spintrcritical17/init.c (modified) * testsuites/sptests/spintrcritical17/spintrcritical17.doc (modified) * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.h (modified) * testsuites/sptests/spmkdir/Makefile.am (modified) * testsuites/sptests/spmkdir/init.c (modified) * testsuites/sptests/spmkdir/spmkdir.doc (modified) * testsuites/sptests/spmountmgr01/Makefile.am (modified) * testsuites/sptests/spmountmgr01/init.c (modified) * testsuites/sptests/spmountmgr01/spmountmgr01.doc (modified) * testsuites/sptests/spnotepad01/Makefile.am (modified) * testsuites/sptests/spnotepad01/init.c (modified) * testsuites/sptests/spnotepad01/spnotepad01.doc (modified) * testsuites/sptests/spnsext01/Makefile.am (modified) * testsuites/sptests/spnsext01/init.c (modified) * testsuites/sptests/spnsext01/spnsext01.doc (modified) * testsuites/sptests/spobjgetnext/Makefile.am (modified) * testsuites/sptests/spobjgetnext/init.c (modified) * testsuites/sptests/spobjgetnext/spobjgetnext.doc (modified) * testsuites/sptests/spobjgetnext/system.h (modified) * testsuites/sptests/spprintk/Makefile.am (modified) * testsuites/sptests/spprintk/init.c (modified) * testsuites/sptests/spprintk/spprintk.doc (modified) * testsuites/sptests/spprivenv01/Makefile.am (modified) * testsuites/sptests/spprivenv01/init.c (modified) * testsuites/sptests/spprivenv01/spprivenv01.doc (modified) * testsuites/sptests/spqreslib/Makefile.am (modified) * testsuites/sptests/spqreslib/init.c (modified) * testsuites/sptests/spqreslib/spqreslib.doc (modified) * testsuites/sptests/spqreslib/system.h (modified) * testsuites/sptests/spqreslib/task_periodic.c (modified) * testsuites/sptests/sprbtree01/Makefile.am (modified) * testsuites/sptests/sprbtree01/init.c (modified) * testsuites/sptests/sprbtree01/sprbtree01.doc (modified) * testsuites/sptests/spsimplesched01/Makefile.am (modified) * testsuites/sptests/spsimplesched01/init.c (modified) * testsuites/sptests/spsimplesched01/spsimplesched01.doc (modified) * testsuites/sptests/spsimplesched02/Makefile.am (modified) * testsuites/sptests/spsimplesched02/init.c (modified) * testsuites/sptests/spsimplesched02/spsimplesched02.doc (modified) * testsuites/sptests/spsimplesched03/Makefile.am (modified) * testsuites/sptests/spsimplesched03/init.c (modified) * testsuites/sptests/spsimplesched03/spsimplesched03.doc (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/sptests/spsize/getint.c (modified) * testsuites/sptests/spsize/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/spsize.doc (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/sptests/spstkalloc/Makefile.am (modified) * testsuites/sptests/spstkalloc/init.c (modified) * testsuites/sptests/spstkalloc/spstkalloc.doc (modified) * testsuites/sptests/spstkalloc02/Makefile.am (modified) * testsuites/sptests/spstkalloc02/init.c (modified) * testsuites/sptests/spstkalloc02/spstkalloc02.doc (modified) * testsuites/sptests/spthreadq01/Makefile.am (modified) * testsuites/sptests/spthreadq01/init.c (modified) * testsuites/sptests/spthreadq01/spthreadq01.doc (modified) * testsuites/sptests/spwatchdog/Makefile.am (modified) * testsuites/sptests/spwatchdog/delay.c (modified) * testsuites/sptests/spwatchdog/init.c (modified) * testsuites/sptests/spwatchdog/prtime.c (modified) * testsuites/sptests/spwatchdog/spwatchdog.doc (modified) * testsuites/sptests/spwatchdog/system.h (modified) * testsuites/sptests/spwatchdog/task1.c (modified) * testsuites/sptests/spwkspace/Makefile.am (modified) * testsuites/sptests/spwkspace/init.c (modified) * testsuites/sptests/spwkspace/spwkspace.doc (modified) * testsuites/support/include/buffer_test_io.h (modified) * testsuites/support/include/test_support.h (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/support/include/tmtests_empty_function.h (modified) * testsuites/support/src/locked_print.c (modified) * testsuites/support/src/spin.c (modified) * testsuites/support/src/test_support.c (modified) * testsuites/support/src/tmtests_empty_function.c (modified) * testsuites/support/src/tmtests_support.c (modified) * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/README (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm01/task1.c (modified) * testsuites/tmtests/tm01/tm01.doc (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm02/tm02.doc (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm03/tm03.doc (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm04/task1.c (modified) * testsuites/tmtests/tm04/tm04.doc (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm05/task1.c (modified) * testsuites/tmtests/tm05/tm05.doc (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm06/task1.c (modified) * testsuites/tmtests/tm06/tm06.doc (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm07/task1.c (modified) * testsuites/tmtests/tm07/tm07.doc (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm08/tm08.doc (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm09/tm09.doc (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm10/tm10.doc (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm11/tm11.doc (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm12/tm12.doc (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm13/tm13.doc (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm14/tm14.doc (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm15/task1.c (modified) * testsuites/tmtests/tm15/tm15.doc (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm16/task1.c (modified) * testsuites/tmtests/tm16/tm16.doc (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm17/task1.c (modified) * testsuites/tmtests/tm17/tm17.doc (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm18/task1.c (modified) * testsuites/tmtests/tm18/tm18.doc (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm19/task1.c (modified) * testsuites/tmtests/tm19/tm19.doc (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm20/tm20.doc (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm21/tm21.doc (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm22/tm22.doc (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm23/task1.c (modified) * testsuites/tmtests/tm23/tm23.doc (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm24/task1.c (modified) * testsuites/tmtests/tm24/tm24.doc (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm25/task1.c (modified) * testsuites/tmtests/tm25/tm25.doc (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm26/fptest.h (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm26/tm26.doc (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm27/tm27.doc (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm28/task1.c (modified) * testsuites/tmtests/tm28/tm28.doc (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tm29/task1.c (modified) * testsuites/tmtests/tm29/tm29.doc (modified) * testsuites/tmtests/tm30/Makefile.am (modified) * testsuites/tmtests/tm30/init.c (modified) * testsuites/tmtests/tm30/tm30.doc (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmck/tmck.doc (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/empty.c (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) * testsuites/tmtests/tmoverhd/tmoverhd.doc (modified) * testsuites/tools/Makefile.am (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/Makefile.am (modified) * testsuites/tools/generic/configure.ac (modified) * testsuites/tools/generic/difftest.in (modified) * testsuites/tools/generic/sorttimes.in (modified) * tools/build/Makefile.am (modified) * tools/build/README (modified) * tools/build/binpatch.c (modified) * tools/build/cklength.c (modified) * tools/build/configure.ac (modified) * tools/build/eolstrip.c (modified) * tools/build/install-if-change.in (modified) * tools/build/packhex.c (modified) * tools/build/unhex.c (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/nios2/Makefile.am (modified) * tools/cpu/nios2/README (modified) * tools/cpu/nios2/bridges.c (modified) * tools/cpu/nios2/bridges.h (modified) * tools/cpu/nios2/clocks.c (modified) * tools/cpu/nios2/clocks.h (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/nios2/devices.c (modified) * tools/cpu/nios2/devices.h (modified) * tools/cpu/nios2/linkcmds.c (modified) * tools/cpu/nios2/linkcmds.h (modified) * tools/cpu/nios2/memory.c (modified) * tools/cpu/nios2/memory.h (modified) * tools/cpu/nios2/nios2gen.c (modified) * tools/cpu/nios2/output.c (modified) * tools/cpu/nios2/output.h (modified) * tools/cpu/nios2/ptf.c (modified) * tools/cpu/nios2/ptf.h (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/configure.ac (modified) Remove All CVS Id Strings Possible Using a Script Script does what ... Mon, 07 May 2012 16:08:48 GMT Joel Sherrill [33a105fb] * Makefile.am (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/check-custom-bsp.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rtems-debug.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-smp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/path-ksh.m4 (modified) * aclocal/project-root.m4 (modified) * aclocal/rtems-top.m4 (modified) * c/Makefile.am (modified) * c/acinclude.m4 (modified) * c/configure.ac (modified) * c/src/Makefile.am (modified) * c/src/acinclude.m4 (modified) * c/src/aclocal/bsp-alias.m4 (modified) * c/src/aclocal/bsp-arg-enable.m4 (modified) * c/src/aclocal/bsp-bootcard-options.m4 (modified) * c/src/aclocal/bsp-bspcleanup-options.m4 (modified) * c/src/aclocal/bsp-configure.m4 (modified) * c/src/aclocal/bsp-linkcmds.m4 (modified) * c/src/aclocal/bspopts.m4 (modified) * c/src/aclocal/canonical-target-name.m4 (modified) * c/src/aclocal/canonicalize-tools.m4 (modified) * c/src/aclocal/check-custom-bsp.m4 (modified) * c/src/aclocal/check-cxx.m4 (modified) * c/src/aclocal/check-multiprocessing.m4 (modified) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/check-posix.m4 (modified) * c/src/aclocal/check-smp.m4 (modified) * c/src/aclocal/check-tool.m4 (modified) * c/src/aclocal/config-subdirs.m4 (modified) * c/src/aclocal/enable-cxx.m4 (modified) * c/src/aclocal/enable-multiprocessing.m4 (modified) * c/src/aclocal/enable-networking.m4 (modified) * c/src/aclocal/enable-posix.m4 (modified) * c/src/aclocal/enable-rtemsbsp.m4 (modified) * c/src/aclocal/enable-smp.m4 (modified) * c/src/aclocal/env-rtemsbsp.m4 (modified) * c/src/aclocal/gcc-isystem.m4 (modified) * c/src/aclocal/gcc-pipe.m4 (modified) * c/src/aclocal/gcc-specs.m4 (modified) * c/src/aclocal/i386-gas-code16.m4 (modified) * c/src/aclocal/path-ksh.m4 (modified) * c/src/aclocal/ppc.m4 (modified) * c/src/aclocal/prog-cc.m4 (modified) * c/src/aclocal/prog-ccas.m4 (modified) * c/src/aclocal/prog-cxx.m4 (modified) * c/src/aclocal/project-root.m4 (modified) * c/src/aclocal/rtems-ampolish.m4 (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/aclocal/target.m4 (modified) * c/src/ada-tests/Makefile.am (modified) * c/src/ada-tests/aclocal/prog-gnat.m4 (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/mptests/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp02/Makefile.am (modified) * c/src/ada-tests/mptests/mp02/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp02/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp03/Makefile.am (modified) * c/src/ada-tests/mptests/mp03/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp03/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp04/Makefile.am (modified) * c/src/ada-tests/mptests/mp04/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp04/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp05/Makefile.am (modified) * c/src/ada-tests/mptests/mp05/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp05/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp06/Makefile.am (modified) * c/src/ada-tests/mptests/mp06/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp06/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp07/Makefile.am (modified) * c/src/ada-tests/mptests/mp07/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp07/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp08/Makefile.am (modified) * c/src/ada-tests/mptests/mp08/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp08/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp09/Makefile.am (modified) * c/src/ada-tests/mptests/mp09/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp09/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp10/Makefile.am (modified) * c/src/ada-tests/mptests/mp10/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp10/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp11/Makefile.am (modified) * c/src/ada-tests/mptests/mp11/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp11/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp12/Makefile.am (modified) * c/src/ada-tests/mptests/mp12/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp12/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp13/Makefile.am (modified) * c/src/ada-tests/mptests/mp13/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp13/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp14/Makefile.am (modified) * c/src/ada-tests/mptests/mp14/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp14/node2/Makefile.am (modified) * c/src/ada-tests/samples/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node1/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (modified) * c/src/ada-tests/samples/base_sp/Makefile.am (modified) * c/src/ada-tests/samples/hello/Makefile.am (modified) * c/src/ada-tests/samples/nsecs/Makefile.am (modified) * c/src/ada-tests/samples/ticker/Makefile.am (modified) * c/src/ada-tests/sptests/Makefile.am (modified) * c/src/ada-tests/sptests/sp01/Makefile.am (modified) * c/src/ada-tests/sptests/sp02/Makefile.am (modified) * c/src/ada-tests/sptests/sp03/Makefile.am (modified) * c/src/ada-tests/sptests/sp04/Makefile.am (modified) * c/src/ada-tests/sptests/sp05/Makefile.am (modified) * c/src/ada-tests/sptests/sp06/Makefile.am (modified) * c/src/ada-tests/sptests/sp07/Makefile.am (modified) * c/src/ada-tests/sptests/sp08/Makefile.am (modified) * c/src/ada-tests/sptests/sp09/Makefile.am (modified) * c/src/ada-tests/sptests/sp11/Makefile.am (modified) * c/src/ada-tests/sptests/sp12/Makefile.am (modified) * c/src/ada-tests/sptests/sp13/Makefile.am (modified) * c/src/ada-tests/sptests/sp14/Makefile.am (modified) * c/src/ada-tests/sptests/sp15/Makefile.am (modified) * c/src/ada-tests/sptests/sp16/Makefile.am (modified) * c/src/ada-tests/sptests/sp17/Makefile.am (modified) * c/src/ada-tests/sptests/sp19/Makefile.am (modified) * c/src/ada-tests/sptests/sp20/Makefile.am (modified) * c/src/ada-tests/sptests/sp22/Makefile.am (modified) * c/src/ada-tests/sptests/sp23/Makefile.am (modified) * c/src/ada-tests/sptests/sp24/Makefile.am (modified) * c/src/ada-tests/sptests/sp25/Makefile.am (modified) * c/src/ada-tests/sptests/spname01/Makefile.am (modified) * c/src/ada-tests/support/Makefile.am (modified) * c/src/ada-tests/tmtests/Makefile.am (modified) * c/src/ada-tests/tmtests/tm01/Makefile.am (modified) * c/src/ada-tests/tmtests/tm02/Makefile.am (modified) * c/src/ada-tests/tmtests/tm03/Makefile.am (modified) * c/src/ada-tests/tmtests/tm04/Makefile.am (modified) * c/src/ada-tests/tmtests/tm05/Makefile.am (modified) * c/src/ada-tests/tmtests/tm06/Makefile.am (modified) * c/src/ada-tests/tmtests/tm07/Makefile.am (modified) * c/src/ada-tests/tmtests/tm08/Makefile.am (modified) * c/src/ada-tests/tmtests/tm09/Makefile.am (modified) * c/src/ada-tests/tmtests/tm10/Makefile.am (modified) * c/src/ada-tests/tmtests/tm11/Makefile.am (modified) * c/src/ada-tests/tmtests/tm12/Makefile.am (modified) * c/src/ada-tests/tmtests/tm13/Makefile.am (modified) * c/src/ada-tests/tmtests/tm14/Makefile.am (modified) * c/src/ada-tests/tmtests/tm15/Makefile.am (modified) * c/src/ada-tests/tmtests/tm16/Makefile.am (modified) * c/src/ada-tests/tmtests/tm17/Makefile.am (modified) * c/src/ada-tests/tmtests/tm18/Makefile.am (modified) * c/src/ada-tests/tmtests/tm19/Makefile.am (modified) * c/src/ada-tests/tmtests/tm20/Makefile.am (modified) * c/src/ada-tests/tmtests/tm21/Makefile.am (modified) * c/src/ada-tests/tmtests/tm22/Makefile.am (modified) * c/src/ada-tests/tmtests/tm23/Makefile.am (modified) * c/src/ada-tests/tmtests/tm24/Makefile.am (modified) * c/src/ada-tests/tmtests/tm25/Makefile.am (modified) * c/src/ada-tests/tmtests/tm28/Makefile.am (modified) * c/src/ada-tests/tmtests/tm29/Makefile.am (modified) * c/src/ada-tests/tmtests/tmck/Makefile.am (modified) * c/src/ada-tests/tmtests/tmoverhd/Makefile.am (modified) * c/src/ada/Makefile.am (modified) * c/src/configure.ac (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/gp32/include/bsp.h (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m32r/Makefile.am (modified) * c/src/lib/libbsp/m32r/configure.ac (modified) * c/src/lib/libbsp/m32r/m32rsim/Makefile.am (modified) * c/src/lib/libbsp/m32r/m32rsim/configure.ac (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/nios2/Makefile.am (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libcpu/Makefile.am (modified) * c/src/libchip/Makefile.am (modified) * c/src/librtems++/Makefile.am (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/Makefile.am (modified) * c/src/make/aclocal/rtems-flags.m4 (modified) * c/src/make/configure.ac (modified) * c/src/support/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) * configure.ac (modified) * cpukit/Makefile.am (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/canonicalize-tools.m4 (modified) * cpukit/aclocal/check-func.m4 (modified) * cpukit/aclocal/check-multiprocessing.m4 (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/aclocal/check-newlib.m4 (modified) * cpukit/aclocal/check-posix.m4 (modified) * cpukit/aclocal/check-rtems-debug.m4 (modified) * cpukit/aclocal/check-smp.m4 (modified) * cpukit/aclocal/check-tool.m4 (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/aclocal/enable-networking.m4 (modified) * cpukit/aclocal/enable-posix.m4 (modified) * cpukit/aclocal/enable-rtems-debug.m4 (modified) * cpukit/aclocal/enable-smp.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/gcc-pipe.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/aclocal/prog-ccas.m4 (modified) * cpukit/aclocal/rtems-ampolish.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/configure.ac (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/nfsclient/Makefile.am (modified) * cpukit/libgnat/Makefile.am (modified) * cpukit/libi2c/Makefile.am (modified) * cpukit/libmd/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/avr/Makefile.am (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/h8300/Makefile.am (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m32r/Makefile.am (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/telnetd/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) * cpukit/zlib/Makefile.am (modified) * doc/Makefile.am (modified) * doc/ada_user/Makefile.am (modified) * doc/bsp_howto/Makefile.am (modified) * doc/cpu_supplement/Makefile.am (modified) * doc/develenv/Makefile.am (modified) * doc/filesystem/Makefile.am (modified) * doc/networking/Makefile.am (modified) * doc/new_chapters/Makefile.am (modified) * doc/porting/Makefile.am (modified) * doc/posix1003.1/Makefile.am (modified) * doc/posix_users/Makefile.am (modified) * doc/relnotes/Makefile.am (modified) * doc/shell/Makefile.am (modified) * doc/started/Makefile.am (modified) * doc/tools/Makefile.am (modified) * doc/tools/bmenu/Makefile.am (modified) * doc/user/Makefile.am (modified) * testsuites/Makefile.am (modified) * testsuites/aclocal/canonical-target-name.m4 (modified) * testsuites/aclocal/canonicalize-tools.m4 (modified) * testsuites/aclocal/check-cpuopts.m4 (modified) * testsuites/aclocal/check-custom-bsp.m4 (modified) * testsuites/aclocal/check-cxx.m4 (modified) * testsuites/aclocal/check-tool.m4 (modified) * testsuites/aclocal/enable-cxx.m4 (modified) * testsuites/aclocal/enable-rtemsbsp.m4 (modified) * testsuites/aclocal/enable-tests.m4 (modified) * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/aclocal/prog-cc.m4 (modified) * testsuites/aclocal/prog-cxx.m4 (modified) * testsuites/aclocal/project-root.m4 (modified) * testsuites/aclocal/rtems-top.m4 (modified) * testsuites/configure.ac (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/imfs_fserror/Makefile.am (modified) * testsuites/fstests/imfs_fslink/Makefile.am (modified) * testsuites/fstests/imfs_fspatheval/Makefile.am (modified) * testsuites/fstests/imfs_fspermission/Makefile.am (modified) * testsuites/fstests/imfs_fsrdwr/Makefile.am (modified) * testsuites/fstests/imfs_fssymlink/Makefile.am (modified) * testsuites/fstests/imfs_fstime/Makefile.am (modified) * testsuites/fstests/mdosfs_fserror/Makefile.am (modified) * testsuites/fstests/mdosfs_fspatheval/Makefile.am (modified) * testsuites/fstests/mdosfs_fsrdwr/Makefile.am (modified) * testsuites/fstests/mdosfs_fstime/Makefile.am (modified) * testsuites/fstests/mimfs_fserror/Makefile.am (modified) * testsuites/fstests/mimfs_fslink/Makefile.am (modified) * testsuites/fstests/mimfs_fspatheval/Makefile.am (modified) * testsuites/fstests/mimfs_fspermission/Makefile.am (modified) * testsuites/fstests/mimfs_fsrdwr/Makefile.am (modified) * testsuites/fstests/mimfs_fssymlink/Makefile.am (modified) * testsuites/fstests/mimfs_fstime/Makefile.am (modified) * testsuites/fstests/mrfs_fserror/Makefile.am (modified) * testsuites/fstests/mrfs_fslink/Makefile.am (modified) * testsuites/fstests/mrfs_fspatheval/Makefile.am (modified) * testsuites/fstests/mrfs_fspermission/Makefile.am (modified) * testsuites/fstests/mrfs_fsrdwr/Makefile.am (modified) * testsuites/fstests/mrfs_fssymlink/Makefile.am (modified) * testsuites/fstests/mrfs_fstime/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/block01/Makefile.am (modified) * testsuites/libtests/block02/Makefile.am (modified) * testsuites/libtests/block03/Makefile.am (modified) * testsuites/libtests/block04/Makefile.am (modified) * testsuites/libtests/block05/Makefile.am (modified) * testsuites/libtests/block06/Makefile.am (modified) * testsuites/libtests/block07/Makefile.am (modified) * testsuites/libtests/block08/Makefile.am (modified) * testsuites/libtests/block09/Makefile.am (modified) * testsuites/libtests/block10/Makefile.am (modified) * testsuites/libtests/block11/Makefile.am (modified) * testsuites/libtests/bspcmdline01/Makefile.am (modified) * testsuites/libtests/complex/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/devfs01/Makefile.am (modified) * testsuites/libtests/devfs02/Makefile.am (modified) * testsuites/libtests/devfs03/Makefile.am (modified) * testsuites/libtests/devfs04/Makefile.am (modified) * testsuites/libtests/deviceio01/Makefile.am (modified) * testsuites/libtests/devnullfatal01/Makefile.am (modified) * testsuites/libtests/dumpbuf01/Makefile.am (modified) * testsuites/libtests/ftp01/Makefile.am (modified) * testsuites/libtests/gxx01/Makefile.am (modified) * testsuites/libtests/heapwalk/Makefile.am (modified) * testsuites/libtests/malloc02/Makefile.am (modified) * testsuites/libtests/malloc03/Makefile.am (modified) * testsuites/libtests/malloc04/Makefile.am (modified) * testsuites/libtests/malloc05/Makefile.am (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/math/Makefile.am (modified) * testsuites/libtests/mathf/Makefile.am (modified) * testsuites/libtests/mathl/Makefile.am (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/monitor02/Makefile.am (modified) * testsuites/libtests/mouse01/Makefile.am (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/stackchk01/Makefile.am (modified) * testsuites/libtests/stringto01/Makefile.am (modified) * testsuites/libtests/tar01/Makefile.am (modified) * testsuites/libtests/tar02/Makefile.am (modified) * testsuites/libtests/tar03/Makefile.am (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/libtests/termios01/Makefile.am (modified) * testsuites/libtests/termios02/Makefile.am (modified) * testsuites/libtests/termios03/Makefile.am (modified) * testsuites/libtests/termios04/Makefile.am (modified) * testsuites/libtests/termios05/Makefile.am (modified) * testsuites/libtests/termios06/Makefile.am (modified) * testsuites/libtests/termios07/Makefile.am (modified) * testsuites/libtests/termios08/Makefile.am (modified) * testsuites/libtests/tztest/Makefile.am (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/mptests/configure.ac (modified) * testsuites/mptests/mp01/Makefile.am (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp02/Makefile.am (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp03/Makefile.am (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp04/Makefile.am (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp05/Makefile.am (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp06/Makefile.am (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp07/Makefile.am (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp08/Makefile.am (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp09/Makefile.am (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp10/Makefile.am (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp11/Makefile.am (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp12/Makefile.am (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp13/Makefile.am (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psx14/Makefile.am (modified) * testsuites/psxtests/psx15/Makefile.am (modified) * testsuites/psxtests/psx16/Makefile.am (modified) * testsuites/psxtests/psxaio01/Makefile.am (modified) * testsuites/psxtests/psxaio02/Makefile.am (modified) * testsuites/psxtests/psxaio03/Makefile.am (modified) * testsuites/psxtests/psxalarm01/Makefile.am (modified) * testsuites/psxtests/psxautoinit01/Makefile.am (modified) * testsuites/psxtests/psxautoinit02/Makefile.am (modified) * testsuites/psxtests/psxbarrier01/Makefile.am (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxcancel01/Makefile.am (modified) * testsuites/psxtests/psxchroot01/Makefile.am (modified) * testsuites/psxtests/psxclassic01/Makefile.am (modified) * testsuites/psxtests/psxcleanup/Makefile.am (modified) * testsuites/psxtests/psxcleanup01/Makefile.am (modified) * testsuites/psxtests/psxclock/Makefile.am (modified) * testsuites/psxtests/psxcond01/Makefile.am (modified) * testsuites/psxtests/psxconfig01/Makefile.am (modified) * testsuites/psxtests/psxeintr_join/Makefile.am (modified) * testsuites/psxtests/psxenosys/Makefile.am (modified) * testsuites/psxtests/psxfatal01/Makefile.am (modified) * testsuites/psxtests/psxfatal02/Makefile.am (modified) * testsuites/psxtests/psxfchx01/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxfile02/Makefile.am (modified) * testsuites/psxtests/psxfilelock01/Makefile.am (modified) * testsuites/psxtests/psxgetrusage01/Makefile.am (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxid01/Makefile.am (modified) * testsuites/psxtests/psximfs01/Makefile.am (modified) * testsuites/psxtests/psximfs02/Makefile.am (modified) * testsuites/psxtests/psxintrcritical01/Makefile.am (modified) * testsuites/psxtests/psxitimer/Makefile.am (modified) * testsuites/psxtests/psxkey01/Makefile.am (modified) * testsuites/psxtests/psxkey02/Makefile.am (modified) * testsuites/psxtests/psxkey03/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxmsgq02/Makefile.am (modified) * testsuites/psxtests/psxmsgq03/Makefile.am (modified) * testsuites/psxtests/psxmsgq04/Makefile.am (modified) * testsuites/psxtests/psxmutexattr01/Makefile.am (modified) * testsuites/psxtests/psxobj01/Makefile.am (modified) * testsuites/psxtests/psxpasswd01/Makefile.am (modified) * testsuites/psxtests/psxpasswd02/Makefile.am (modified) * testsuites/psxtests/psxpipe01/Makefile.am (modified) * testsuites/psxtests/psxrdwrv/Makefile.am (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxrwlock01/Makefile.am (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxsignal01/Makefile.am (modified) * testsuites/psxtests/psxsignal02/Makefile.am (modified) * testsuites/psxtests/psxsignal03/Makefile.am (modified) * testsuites/psxtests/psxsignal04/Makefile.am (modified) * testsuites/psxtests/psxsignal05/Makefile.am (modified) * testsuites/psxtests/psxsignal06/Makefile.am (modified) * testsuites/psxtests/psxspin01/Makefile.am (modified) * testsuites/psxtests/psxspin02/Makefile.am (modified) * testsuites/psxtests/psxstack01/Makefile.am (modified) * testsuites/psxtests/psxstack02/Makefile.am (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxsysconf/Makefile.am (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtimer01/Makefile.am (modified) * testsuites/psxtests/psxtimer02/Makefile.am (modified) * testsuites/psxtests/psxtimes01/Makefile.am (modified) * testsuites/psxtests/psxualarm/Makefile.am (modified) * testsuites/psxtests/psxusleep/Makefile.am (modified) * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmbarrier01/Makefile.am (modified) * testsuites/psxtmtests/psxtmbarrier02/Makefile.am (modified) * testsuites/psxtmtests/psxtmbarrier03/Makefile.am (modified) * testsuites/psxtmtests/psxtmkey01/Makefile.am (modified) * testsuites/psxtmtests/psxtmkey02/Makefile.am (modified) * testsuites/psxtmtests/psxtmmq01/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex01/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex02/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex03/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex04/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex05/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex06/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex07/Makefile.am (modified) * testsuites/psxtmtests/psxtmnanosleep01/Makefile.am (modified) * testsuites/psxtmtests/psxtmnanosleep02/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock01/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock02/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock03/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock04/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock05/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock06/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock07/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem01/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem02/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem03/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem04/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem05/Makefile.am (modified) * testsuites/psxtmtests/psxtmsleep01/Makefile.am (modified) * testsuites/psxtmtests/psxtmsleep02/Makefile.am (modified) * testsuites/psxtmtests/psxtmthread01/Makefile.am (modified) * testsuites/psxtmtests/psxtmthread03/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) * testsuites/samples/base_mp/Makefile.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/base_sp/Makefile.am (modified) * testsuites/samples/capture/Makefile.am (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/configure.ac (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/iostream/Makefile.am (modified) * testsuites/samples/loopback/Makefile.am (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/nsecs/Makefile.am (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/pppd/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smp01/Makefile.am (modified) * testsuites/smptests/smp02/Makefile.am (modified) * testsuites/smptests/smp03/Makefile.am (modified) * testsuites/smptests/smp04/Makefile.am (modified) * testsuites/smptests/smp05/Makefile.am (modified) * testsuites/smptests/smp06/Makefile.am (modified) * testsuites/smptests/smp07/Makefile.am (modified) * testsuites/smptests/smp08/Makefile.am (modified) * testsuites/smptests/smp09/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp10/Makefile.am (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp18/Makefile.am (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp2038/Makefile.am (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp27a/Makefile.am (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/sp30/Makefile.am (modified) * testsuites/sptests/sp31/Makefile.am (modified) * testsuites/sptests/sp32/Makefile.am (modified) * testsuites/sptests/sp33/Makefile.am (modified) * testsuites/sptests/sp34/Makefile.am (modified) * testsuites/sptests/sp35/Makefile.am (modified) * testsuites/sptests/sp36/Makefile.am (modified) * testsuites/sptests/sp37/Makefile.am (modified) * testsuites/sptests/sp38/Makefile.am (modified) * testsuites/sptests/sp39/Makefile.am (modified) * testsuites/sptests/sp40/Makefile.am (modified) * testsuites/sptests/sp41/Makefile.am (modified) * testsuites/sptests/sp42/Makefile.am (modified) * testsuites/sptests/sp43/Makefile.am (modified) * testsuites/sptests/sp44/Makefile.am (modified) * testsuites/sptests/sp45/Makefile.am (modified) * testsuites/sptests/sp46/Makefile.am (modified) * testsuites/sptests/sp47/Makefile.am (modified) * testsuites/sptests/sp48/Makefile.am (modified) * testsuites/sptests/sp49/Makefile.am (modified) * testsuites/sptests/sp50/Makefile.am (modified) * testsuites/sptests/sp51/Makefile.am (modified) * testsuites/sptests/sp52/Makefile.am (modified) * testsuites/sptests/sp53/Makefile.am (modified) * testsuites/sptests/sp54/Makefile.am (modified) * testsuites/sptests/sp55/Makefile.am (modified) * testsuites/sptests/sp56/Makefile.am (modified) * testsuites/sptests/sp57/Makefile.am (modified) * testsuites/sptests/sp58/Makefile.am (modified) * testsuites/sptests/sp59/Makefile.am (modified) * testsuites/sptests/sp60/Makefile.am (modified) * testsuites/sptests/sp62/Makefile.am (modified) * testsuites/sptests/sp63/Makefile.am (modified) * testsuites/sptests/sp64/Makefile.am (modified) * testsuites/sptests/sp65/Makefile.am (modified) * testsuites/sptests/sp66/Makefile.am (modified) * testsuites/sptests/sp67/Makefile.am (modified) * testsuites/sptests/sp68/Makefile.am (modified) * testsuites/sptests/sp69/Makefile.am (modified) * testsuites/sptests/sp70/Makefile.am (modified) * testsuites/sptests/sp71/Makefile.am (modified) * testsuites/sptests/sp72/Makefile.am (modified) * testsuites/sptests/sp73/Makefile.am (modified) * testsuites/sptests/sp74/Makefile.am (modified) * testsuites/sptests/sp75/Makefile.am (modified) * testsuites/sptests/sp76/Makefile.am (modified) * testsuites/sptests/spassoc01/Makefile.am (modified) * testsuites/sptests/spcbssched01/Makefile.am (modified) * testsuites/sptests/spcbssched02/Makefile.am (modified) * testsuites/sptests/spcbssched03/Makefile.am (modified) * testsuites/sptests/spchain/Makefile.am (modified) * testsuites/sptests/spclockget/Makefile.am (modified) * testsuites/sptests/spcoverage/Makefile.am (modified) * testsuites/sptests/spedfsched01/Makefile.am (modified) * testsuites/sptests/spedfsched02/Makefile.am (modified) * testsuites/sptests/spedfsched03/Makefile.am (modified) * testsuites/sptests/sperror01/Makefile.am (modified) * testsuites/sptests/sperror02/Makefile.am (modified) * testsuites/sptests/sperror03/Makefile.am (modified) * testsuites/sptests/spfatal01/Makefile.am (modified) * testsuites/sptests/spfatal02/Makefile.am (modified) * testsuites/sptests/spfatal03/Makefile.am (modified) * testsuites/sptests/spfatal04/Makefile.am (modified) * testsuites/sptests/spfatal05/Makefile.am (modified) * testsuites/sptests/spfatal06/Makefile.am (modified) * testsuites/sptests/spfatal07/Makefile.am (modified) * testsuites/sptests/spfatal08/Makefile.am (modified) * testsuites/sptests/spfatal09/Makefile.am (modified) * testsuites/sptests/spfatal10/Makefile.am (modified) * testsuites/sptests/spfatal11/Makefile.am (modified) * testsuites/sptests/spfatal12/Makefile.am (modified) * testsuites/sptests/spfatal13/Makefile.am (modified) * testsuites/sptests/spfatal14/Makefile.am (modified) * testsuites/sptests/spfatal15/Makefile.am (modified) * testsuites/sptests/spfatal16/Makefile.am (modified) * testsuites/sptests/spfatal17/Makefile.am (modified) * testsuites/sptests/spfatal18/Makefile.am (modified) * testsuites/sptests/spfatal19/Makefile.am (modified) * testsuites/sptests/spfatal20/Makefile.am (modified) * testsuites/sptests/spfatal21/Makefile.am (modified) * testsuites/sptests/spfatal22/Makefile.am (modified) * testsuites/sptests/spfatal23/Makefile.am (modified) * testsuites/sptests/spfatal24/Makefile.am (modified) * testsuites/sptests/spfatal25/Makefile.am (modified) * testsuites/sptests/spfifo01/Makefile.am (modified) * testsuites/sptests/spfifo02/Makefile.am (modified) * testsuites/sptests/spfifo03/Makefile.am (modified) * testsuites/sptests/spfifo04/Makefile.am (modified) * testsuites/sptests/spfifo05/Makefile.am (modified) * testsuites/sptests/spheapprot/Makefile.am (modified) * testsuites/sptests/spintrcritical01/Makefile.am (modified) * testsuites/sptests/spintrcritical02/Makefile.am (modified) * testsuites/sptests/spintrcritical03/Makefile.am (modified) * testsuites/sptests/spintrcritical04/Makefile.am (modified) * testsuites/sptests/spintrcritical05/Makefile.am (modified) * testsuites/sptests/spintrcritical06/Makefile.am (modified) * testsuites/sptests/spintrcritical07/Makefile.am (modified) * testsuites/sptests/spintrcritical08/Makefile.am (modified) * testsuites/sptests/spintrcritical09/Makefile.am (modified) * testsuites/sptests/spintrcritical10/Makefile.am (modified) * testsuites/sptests/spintrcritical11/Makefile.am (modified) * testsuites/sptests/spintrcritical12/Makefile.am (modified) * testsuites/sptests/spintrcritical13/Makefile.am (modified) * testsuites/sptests/spintrcritical14/Makefile.am (modified) * testsuites/sptests/spintrcritical15/Makefile.am (modified) * testsuites/sptests/spintrcritical16/Makefile.am (modified) * testsuites/sptests/spintrcritical17/Makefile.am (modified) * testsuites/sptests/spmkdir/Makefile.am (modified) * testsuites/sptests/spmountmgr01/Makefile.am (modified) * testsuites/sptests/spnotepad01/Makefile.am (modified) * testsuites/sptests/spnsext01/Makefile.am (modified) * testsuites/sptests/spobjgetnext/Makefile.am (modified) * testsuites/sptests/spprintk/Makefile.am (modified) * testsuites/sptests/spprivenv01/Makefile.am (modified) * testsuites/sptests/spqreslib/Makefile.am (modified) * testsuites/sptests/sprbtree01/Makefile.am (modified) * testsuites/sptests/spsimplesched01/Makefile.am (modified) * testsuites/sptests/spsimplesched02/Makefile.am (modified) * testsuites/sptests/spsimplesched03/Makefile.am (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/sptests/spstkalloc/Makefile.am (modified) * testsuites/sptests/spstkalloc02/Makefile.am (modified) * testsuites/sptests/spthreadq01/Makefile.am (modified) * testsuites/sptests/spwatchdog/Makefile.am (modified) * testsuites/sptests/spwkspace/Makefile.am (modified) * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tm30/Makefile.am (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) * testsuites/tools/Makefile.am (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/Makefile.am (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/Makefile.am (modified) * tools/build/configure.ac (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/Makefile.am (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/configure.ac (modified) Revert: Remove CVS Ids See ... Fri, 04 May 2012 06:55:28 GMT Ralf Corsépius [ee32f67a] * cpukit/Makefile.am (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/canonicalize-tools.m4 (modified) * cpukit/aclocal/check-func.m4 (modified) * cpukit/aclocal/check-multiprocessing.m4 (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/aclocal/check-newlib.m4 (modified) * cpukit/aclocal/check-posix.m4 (modified) * cpukit/aclocal/check-rtems-debug.m4 (modified) * cpukit/aclocal/check-smp.m4 (modified) * cpukit/aclocal/check-tool.m4 (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/aclocal/enable-networking.m4 (modified) * cpukit/aclocal/enable-posix.m4 (modified) * cpukit/aclocal/enable-rtems-debug.m4 (modified) * cpukit/aclocal/enable-smp.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/gcc-pipe.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/aclocal/prog-ccas.m4 (modified) * cpukit/aclocal/rtems-ampolish.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/configure.ac (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/nfsclient/Makefile.am (modified) * cpukit/libgnat/Makefile.am (modified) * cpukit/libi2c/Makefile.am (modified) * cpukit/libmd/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/avr/Makefile.am (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/h8300/Makefile.am (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m32r/Makefile.am (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/telnetd/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) * cpukit/zlib/Makefile.am (modified) Remove CVS-Ids. Thu, 26 Jan 2012 08:58:10 GMT Sebastian Huber [be42aa1a] * cpukit/Makefile.am (modified) * cpukit/aclocal/enable-cxx.m4 (deleted) * cpukit/aclocal/prog-cxx.m4 (deleted) * cpukit/configure.ac (modified) * cpukit/gtest/Makefile.am (deleted) * cpukit/gtest/include/gtest/gtest-death-test.h (deleted) * cpukit/gtest/include/gtest/gtest-main.h (deleted) * cpukit/gtest/include/gtest/gtest-message.h (deleted) * cpukit/gtest/include/gtest/gtest-param-test.h (deleted) * cpukit/gtest/include/gtest/gtest-printers.h (deleted) * cpukit/gtest/include/gtest/gtest-spi.h (deleted) * cpukit/gtest/include/gtest/gtest-test-part.h (deleted) * cpukit/gtest/include/gtest/gtest-typed-test.h (deleted) * cpukit/gtest/include/gtest/gtest.h (deleted) * cpukit/gtest/include/gtest/gtest_pred_impl.h (deleted) * cpukit/gtest/include/gtest/gtest_prod.h (deleted) * cpukit/gtest/include/gtest/internal/gtest-death-test-internal.h (deleted) * cpukit/gtest/include/gtest/internal/gtest-filepath.h (deleted) * cpukit/gtest/include/gtest/internal/gtest-internal.h (deleted) * cpukit/gtest/include/gtest/internal/gtest-linked_ptr.h (deleted) * cpukit/gtest/include/gtest/internal/gtest-param-util-generated.h (deleted) * cpukit/gtest/include/gtest/internal/gtest-param-util.h (deleted) * cpukit/gtest/include/gtest/internal/gtest-port.h (deleted) * cpukit/gtest/include/gtest/internal/gtest-string.h (deleted) * cpukit/gtest/include/gtest/internal/gtest-tuple.h (deleted) * cpukit/gtest/include/gtest/internal/gtest-type-util.h (deleted) * cpukit/gtest/preinstall.am (deleted) * cpukit/gtest/src/gtest-all.cc (deleted) * cpukit/gtest/src/gtest-death-test.cc (deleted) * cpukit/gtest/src/gtest-filepath.cc (deleted) * cpukit/gtest/src/gtest-internal-inl.h (deleted) * cpukit/gtest/src/gtest-port.cc (deleted) * cpukit/gtest/src/gtest-printers.cc (deleted) * cpukit/gtest/src/gtest-test-part.cc (deleted) * cpukit/gtest/src/gtest-typed-test.cc (deleted) * cpukit/gtest/src/gtest.cc (deleted) Revert "Google C++ Testing Framework 1.6.0." This reverts commit ... Wed, 11 Jan 2012 13:37:24 GMT Sebastian Huber [9bf3a868] * cpukit/Makefile.am (modified) * cpukit/aclocal/enable-cxx.m4 (added) * cpukit/aclocal/prog-cxx.m4 (added) * cpukit/configure.ac (modified) * cpukit/gtest/Makefile.am (added) * cpukit/gtest/include/gtest/gtest-death-test.h (added) * cpukit/gtest/include/gtest/gtest-main.h (added) * cpukit/gtest/include/gtest/gtest-message.h (added) * cpukit/gtest/include/gtest/gtest-param-test.h (added) * cpukit/gtest/include/gtest/gtest-printers.h (added) * cpukit/gtest/include/gtest/gtest-spi.h (added) * cpukit/gtest/include/gtest/gtest-test-part.h (added) * cpukit/gtest/include/gtest/gtest-typed-test.h (added) * cpukit/gtest/include/gtest/gtest.h (added) * cpukit/gtest/include/gtest/gtest_pred_impl.h (added) * cpukit/gtest/include/gtest/gtest_prod.h (added) * cpukit/gtest/include/gtest/internal/gtest-death-test-internal.h (added) * cpukit/gtest/include/gtest/internal/gtest-filepath.h (added) * cpukit/gtest/include/gtest/internal/gtest-internal.h (added) * cpukit/gtest/include/gtest/internal/gtest-linked_ptr.h (added) * cpukit/gtest/include/gtest/internal/gtest-param-util-generated.h (added) * cpukit/gtest/include/gtest/internal/gtest-param-util.h (added) * cpukit/gtest/include/gtest/internal/gtest-port.h (added) * cpukit/gtest/include/gtest/internal/gtest-string.h (added) * cpukit/gtest/include/gtest/internal/gtest-tuple.h (added) * cpukit/gtest/include/gtest/internal/gtest-type-util.h (added) * cpukit/gtest/preinstall.am (added) * cpukit/gtest/src/gtest-all.cc (added) * cpukit/gtest/src/gtest-death-test.cc (added) * cpukit/gtest/src/gtest-filepath.cc (added) * cpukit/gtest/src/gtest-internal-inl.h (added) * cpukit/gtest/src/gtest-port.cc (added) * cpukit/gtest/src/gtest-printers.cc (added) * cpukit/gtest/src/gtest-test-part.cc (added) * cpukit/gtest/src/gtest-typed-test.cc (added) * cpukit/gtest/src/gtest.cc (added) Google C++ Testing Framework 1.6.0. Thu, 01 Dec 2011 16:43:28 GMT Ralf Corsepius [e493e2a8] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-smp.m4 (modified) 2011-12-01 Ralf Corsépius * ... Wed, 16 Mar 2011 20:05:06 GMT Joel Sherrill [06dcaf0] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-smp.m4 (added) * cpukit/aclocal/enable-smp.m4 (added) * cpukit/configure.ac (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/bspsmp.h (added) * cpukit/score/include/rtems/score/basedefs.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smplock.h (added) * cpukit/score/preinstall.am (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/smp.c (added) * cpukit/score/src/smplock.c (added) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadcreateidle.c (modified) 2011-03-16 Jennifer Averett ... Fri, 04 Mar 2011 16:17:27 GMT Ralf Corsepius [4c7b674a] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/aclocal/version.m4 (modified) 2011-03-04 Ralf Corsépius * ... Fri, 25 Feb 2011 06:17:36 GMT Ralf Corsepius [38d1150] * c/src/ChangeLog (modified) * c/src/aclocal/canonical-target-name.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/canonical-target-name.m4 (modified) 2011-02-25 Ralf Corsépius * ... Fri, 25 Feb 2011 03:58:33 GMT Ralf Corsepius [8dc08d2] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/aclocal/check-posix.m4 (modified) 2011-02-25 Ralf Corsépius * ... Fri, 08 Oct 2010 09:42:11 GMT Ralf Corsepius [b2b13e8a] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-func.m4 (modified) 2010-10-08 Ralf Corsépius * ... Tue, 03 Aug 2010 15:42:44 GMT Ralf Corsepius [26c6706] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-func.m4 (added) 2010-08-03 Ralf Corsépius * ... Thu, 17 Jun 2010 15:29:01 GMT Ralf Corsepius [b77d6e1] * cpukit/aclocal/check-itron.m4 (deleted) * cpukit/aclocal/enable-itron.m4 (deleted) * cpukit/score/src/objectallocatebyindex.c (deleted) * cpukit/score/src/objectgetbyindex.c (deleted) * cpukit/score/src/threadrotatequeue.c (deleted) Remove. Wed, 09 Jun 2010 08:06:08 GMT Ralf Corsepius [dc352017] * cpukit/aclocal/enable-shttpd.m4 (deleted) * cpukit/shttpd/.cvsignore (deleted) * cpukit/shttpd/Makefile.am (deleted) * cpukit/shttpd/Makefile.shttpd (deleted) * cpukit/shttpd/auth.c (deleted) * cpukit/shttpd/cgi.c (deleted) * cpukit/shttpd/compat_rtems.c (deleted) * cpukit/shttpd/compat_rtems.h (deleted) * cpukit/shttpd/compat_unix.c (deleted) * cpukit/shttpd/compat_unix.h (deleted) * cpukit/shttpd/compat_win32.c (deleted) * cpukit/shttpd/compat_win32.h (deleted) * cpukit/shttpd/compat_wince.c (deleted) * cpukit/shttpd/compat_wince.h (deleted) * cpukit/shttpd/config.c (deleted) * cpukit/shttpd/defs.h (deleted) * cpukit/shttpd/io.h (deleted) * cpukit/shttpd/io_cgi.c (deleted) * cpukit/shttpd/io_dir.c (deleted) * cpukit/shttpd/io_emb.c (deleted) * cpukit/shttpd/io_file.c (deleted) * cpukit/shttpd/io_socket.c (deleted) * cpukit/shttpd/io_ssl.c (deleted) * cpukit/shttpd/llist.h (deleted) * cpukit/shttpd/log.c (deleted) * cpukit/shttpd/md5.c (deleted) * cpukit/shttpd/md5.h (deleted) * cpukit/shttpd/mime_type.c (deleted) * cpukit/shttpd/preinstall.am (deleted) * cpukit/shttpd/shttpd.1 (deleted) * cpukit/shttpd/shttpd.c (deleted) * cpukit/shttpd/shttpd.h (deleted) * cpukit/shttpd/ssl.h (deleted) * cpukit/shttpd/standalone.c (deleted) * cpukit/shttpd/std_includes.h (deleted) * cpukit/shttpd/string.c (deleted) Remove. Wed, 09 Jun 2010 05:47:46 GMT Ralf Corsepius [468b8df] * cpukit/aclocal/enable-httpd.m4 (deleted) Remove. Mon, 07 Jun 2010 19:33:53 GMT Ralf Corsepius [ba021d5c] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2010-06-07 Ralf Corsépius * ... Thu, 29 Apr 2010 07:45:01 GMT Ralf Corsepius [292b0c3] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-itron.m4 (modified) * cpukit/aclocal/enable-itron.m4 (modified) 2010-04-29 Ralf Corsépius * ... Thu, 29 Apr 2010 05:18:41 GMT Ralf Corsepius [70f3aaa5] * cpukit/ChangeLog (modified) * cpukit/aclocal/enable-itron.m4 (modified) 2010-04-29 Ralf Corsépius * ... Thu, 29 Apr 2010 05:12:49 GMT Ralf Corsepius [e4f7ccb4] * cpukit/aclocal/enable-httpd.m4 (added) * cpukit/aclocal/enable-shttpd.m4 (added) New. Tue, 13 Apr 2010 04:23:26 GMT Ralf Corsepius [b3950931] * cpukit/aclocal/gcc-sanity.m4 (modified) Add RTEMS_CHECK_GCC_PRINTF_LD_OFF_T, RTEMS_CHECK_GCC_PRINTF_LLD_OFF_T. Thu, 19 Nov 2009 14:46:11 GMT Ralf Corsepius [b5b51fc] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-networking.m4 (modified) 2009-11-19 Ralf Corsépius * ... Fri, 30 Oct 2009 05:45:40 GMT Ralf Corsepius [50f7234] * cpukit/aclocal/gcc-sanity.m4 (added) New. Fri, 23 Oct 2009 14:58:16 GMT Ralf Corsepius [b9b3a5c5] * cpukit/aclocal/prog-cc.m4 (modified) Remove RTEMS_CFLAGS. Rework CFLAGS setup. Wed, 14 Oct 2009 12:40:15 GMT Ralf Corsepius [8d5caea] * cpukit/ChangeLog (modified) * cpukit/aclocal/sysv-ipc.m4 (deleted) 2009-10-14 Ralf Corsépius * ... Wed, 14 Oct 2009 12:25:59 GMT Ralf Corsepius [5bd2447] * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/aclocal/check-posix.m4 (modified) * cpukit/aclocal/enable-posix.m4 (modified) Remove unix/posix. Mon, 17 Aug 2009 21:18:34 GMT Joel Sherrill [118472cf] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-networking.m4 (modified) 2009-08-17 Joel Sherrill * ... Thu, 23 Jul 2009 21:23:13 GMT Ralf Corsepius [18e23e91] * ChangeLog (modified) * aclocal/enable-itron.m4 (modified) * c/src/make/ChangeLog (modified) * c/src/make/aclocal/enable-itron.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/enable-itron.m4 (modified) 2009-07-23 Ralf Corsepius * ... Thu, 02 Apr 2009 11:49:51 GMT Ralf Corsepius [52f8e7aa] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-rtems-debug.m4 (modified) 2009-04-02 Ralf Corsépius * ... Fri, 06 Feb 2009 07:58:21 GMT Ralf Corsepius [a8f71b8] * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/enable-posix.m4 (modified) Remove comment referring to HPUX. Mon, 22 Dec 2008 03:58:22 GMT Ralf Corsepius [ab922554] * aclocal/canonical-target-name.m4 (modified) * c/src/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) * testsuites/aclocal/canonical-target-name.m4 (modified) Remove tic4x. Wed, 10 Dec 2008 23:30:54 GMT Ralf Corsepius [30ad45f] * c/src/aclocal/prog-cc.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) Use -r instead of -Wl,-r to build *.rels. Mon, 08 Dec 2008 13:14:32 GMT Ralf Corsepius [21f0aac] * cpukit/ChangeLog (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/libfs/src/nfsclient/Makefile.am (modified) 2008-12-08 Ralf Corsépius * ... Mon, 22 Sep 2008 14:12:12 GMT Ralf Corsepius [64600d01] * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2008-09-11 Ralf Corsépius * ... Wed, 10 Sep 2008 15:41:37 GMT Joel Sherrill [7a28ac8] * cpukit/ChangeLog (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/configure.ac (modified) * cpukit/score/cpu/c4x/.cvsignore (added) * cpukit/score/cpu/c4x/ChangeLog (added) * cpukit/score/cpu/c4x/Makefile.am (added) * cpukit/score/cpu/c4x/cpu.c (added) * cpukit/score/cpu/c4x/cpu_asm.S (added) * cpukit/score/cpu/c4x/irq.c (added) * cpukit/score/cpu/c4x/preinstall.am (added) * cpukit/score/cpu/c4x/rtems/asm.h (added) * cpukit/score/cpu/c4x/rtems/score/c4x.h (added) * cpukit/score/cpu/c4x/rtems/score/cpu.h (added) * cpukit/score/cpu/c4x/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/c4x/rtems/score/types.h (added) * cpukit/score/cpu/c4x/rtems/tic4x/c4xio.h (added) * cpukit/score/cpu/nios2/.cvsignore (added) * cpukit/score/cpu/nios2/ChangeLog (added) * cpukit/score/cpu/nios2/Makefile.am (added) * cpukit/score/cpu/nios2/cpu.c (added) * cpukit/score/cpu/nios2/cpu_asm.S (added) * cpukit/score/cpu/nios2/irq.c (added) * cpukit/score/cpu/nios2/preinstall.am (added) * cpukit/score/cpu/nios2/rtems/asm.h (added) * cpukit/score/cpu/nios2/rtems/score/cpu.h (added) * cpukit/score/cpu/nios2/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/nios2/rtems/score/nios2.h (added) * cpukit/score/cpu/nios2/rtems/score/types.h (added) 2008-09-10 Joel Sherrill * ... Wed, 10 Sep 2008 15:35:28 GMT Joel Sherrill [4ff2c04] * cpukit/ChangeLog (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/configure.ac (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/cpu/c4x/.cvsignore (deleted) * cpukit/score/cpu/c4x/ChangeLog (deleted) * cpukit/score/cpu/c4x/Makefile.am (deleted) * cpukit/score/cpu/c4x/cpu.c (deleted) * cpukit/score/cpu/c4x/cpu_asm.S (deleted) * cpukit/score/cpu/c4x/irq.c (deleted) * cpukit/score/cpu/c4x/preinstall.am (deleted) * cpukit/score/cpu/c4x/rtems/asm.h (deleted) * cpukit/score/cpu/c4x/rtems/score/c4x.h (deleted) * cpukit/score/cpu/c4x/rtems/score/cpu.h (deleted) * cpukit/score/cpu/c4x/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/c4x/rtems/score/types.h (deleted) * cpukit/score/cpu/c4x/rtems/tic4x/c4xio.h (deleted) * cpukit/score/cpu/nios2/.cvsignore (deleted) * cpukit/score/cpu/nios2/ChangeLog (deleted) * cpukit/score/cpu/nios2/Makefile.am (deleted) * cpukit/score/cpu/nios2/cpu.c (deleted) * cpukit/score/cpu/nios2/cpu_asm.S (deleted) * cpukit/score/cpu/nios2/irq.c (deleted) * cpukit/score/cpu/nios2/preinstall.am (deleted) * cpukit/score/cpu/nios2/rtems/asm.h (deleted) * cpukit/score/cpu/nios2/rtems/score/cpu.h (deleted) * cpukit/score/cpu/nios2/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/nios2/rtems/score/nios2.h (deleted) * cpukit/score/cpu/nios2/rtems/score/types.h (deleted) 2008-09-10 Joel Sherrill * ... Mon, 18 Aug 2008 15:13:59 GMT Ralf Corsepius [a6998d79] * cpukit/ChangeLog (modified) * cpukit/aclocal/prog-cc.m4 (modified) 2008-08-18 Ralf Corsepius * ... Sat, 16 Aug 2008 04:02:41 GMT Ralf Corsepius [0063a93a] * c/src/ChangeLog (modified) * c/src/aclocal/prog-cc.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/prog-cc.m4 (modified) 2008-08-16 Ralf Corsepius * ... Mon, 30 Jun 2008 08:54:41 GMT Ralf Corsepius [6208c2a] * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2008-06-30 Ralf Corsépius * ... Fri, 21 Sep 2007 08:50:19 GMT Ralf Corsepius [90a51d8a] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2007-09-21 Ralf Corsépius * ... Tue, 07 Aug 2007 14:39:50 GMT Joel Sherrill [c3b6484f] * VERSION (modified) * aclocal/version.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/aclocal/version.m4 (modified) Upgrade to 4.7.99.2 Tue, 13 Mar 2007 19:45:55 GMT Joel Sherrill [307c7af1] * VERSION (modified) * aclocal/version.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/aclocal/version.m4 (modified) Upgrade to 4.7.99.1 Thu, 22 Feb 2007 09:12:51 GMT Ralf Corsepius [1fa64f9] * VERSION (modified) * aclocal/version.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/aclocal/version.m4 (modified) Revert to version 4.7.99-0 Thu, 22 Feb 2007 07:42:53 GMT Ralf Corsepius [5e854044] * VERSION (modified) * aclocal/version.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/aclocal/version.m4 (modified) Testing: Upgrade to 4.7.99.1 Wed, 13 Dec 2006 05:37:07 GMT Ralf Corsepius [b25d6119] * c/src/aclocal/rtems-ampolish.m4 (modified) * cpukit/aclocal/rtems-ampolish.m4 (modified) Use am_aux_dir/ampolish3. Tue, 12 Dec 2006 16:41:22 GMT Ralf Corsepius [a208413] * cpukit/aclocal/rtems-top.m4 (modified) Remove RTEMS_AMPOLISH. Tue, 12 Dec 2006 16:36:21 GMT Ralf Corsepius [fcb08612] * cpukit/aclocal/rtems-ampolish.m4 (modified) Remove RTEMS_AMPOLISH. Sat, 18 Nov 2006 03:41:42 GMT Ralf Corsepius [d4cbf34] * cpukit/aclocal/check-networking.m4 (modified) Integrate type checks. Sat, 18 Nov 2006 03:14:37 GMT Ralf Corsepius [943fe10] * cpukit/aclocal/check-itron.m4 (modified) Integrate ITRON-type checks. Wed, 15 Nov 2006 14:19:47 GMT Ralf Corsepius [728c3167] * cpukit/aclocal/rtems-top.m4 (modified) Add RTEMS_AMPOLISH3. Wed, 15 Nov 2006 14:18:27 GMT Ralf Corsepius [28c4602] * cpukit/aclocal/rtems-ampolish.m4 (modified) Pick up ampolish3 from ac_aux_dir. Sat, 21 Oct 2006 05:56:10 GMT Ralf Corsepius [80886bd] * cpukit/aclocal/enable-inlines.m4 (deleted) * cpukit/aclocal/prog-gnat.m4 (deleted) Remove. Wed, 18 Oct 2006 03:37:19 GMT Ralf Corsepius [9b5e72b] * ChangeLog (modified) * aclocal/rtems-top.m4 (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/rtems-top.m4 (modified) * testsuites/aclocal/version.m4 (modified) 2006-10-18 Ralf Corsépius * ... Tue, 17 Oct 2006 17:49:59 GMT Ralf Corsepius [0ec8e35] * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 15:49:31 GMT Ralf Corsepius [2e28876] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2006-10-17 Ralf Corsépius * ... Mon, 16 Oct 2006 15:58:13 GMT Ralf Corsepius [ed908735] * cpukit/aclocal/multi.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/aclocal/prog-ccas.m4 (modified) * cpukit/automake/compile.am (modified) * cpukit/configure.ac (modified) Adaptations to automake-1.10. Thu, 29 Jun 2006 07:15:28 GMT Ralf Corsepius [e0554ce] * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-ampolish.m4 (modified) * cpukit/ampolish3 (added) 2006-06-28 Ralf Corsépius * ... Tue, 16 May 2006 14:26:57 GMT Ralf Corsepius [068cf700] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-ampolish.m4 (added) * c/src/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-ampolish.m4 (added) * cpukit/configure.ac (modified) 2006-05-16 Ralf Corsépius * ... Tue, 18 Apr 2006 21:47:28 GMT Joel Sherrill [c5a67176] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2006-04-18 Joel Sherrill * ... Fri, 02 Sep 2005 14:50:05 GMT Joel Sherrill [95f9447] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2005-09-02 Joel Sherrill * ... Tue, 22 Feb 2005 17:50:30 GMT Ralf Corsepius [d8f159c] * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2005-02-22 Ralf Corsepius * ... Tue, 08 Feb 2005 02:50:06 GMT Ralf Corsepius [0598fb8] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2005-02-08 Ralf Corsepius * ... Tue, 01 Feb 2005 16:06:39 GMT Ralf Corsepius [891aa12e] * cpukit/ChangeLog (modified) * cpukit/aclocal/gcc-isystem.m4 (deleted) * cpukit/aclocal/prog-cc.m4 (modified) 2005-02-01 Ralf Corsepius * ... Wed, 05 Jan 2005 17:12:37 GMT Ralf Corsepius [635c2fe7] * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-flags.m4 (deleted) 2005-01-05 Ralf Corsepius * ... Wed, 05 Jan 2005 16:59:31 GMT Ralf Corsepius [69ad3b33] * cpukit/ChangeLog (modified) * cpukit/aclocal/prog-ccas.m4 (modified) 2005-01-05 Ralf Corsepius * ... Wed, 05 Jan 2005 16:07:20 GMT Ralf Corsepius [7ddfdb2] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/automake/compile.am (modified) 2005-01-05 Ralf Corsepius * ... Wed, 05 Jan 2005 08:41:18 GMT Ralf Corsepius [20cef00f] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/automake/compile.am (modified) 2005-01-05 Ralf Corsepius * ... Mon, 22 Nov 2004 13:52:17 GMT Ralf Corsepius [a1ca28d] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-itron.m4 (modified) * cpukit/aclocal/enable-itron.m4 (modified) 2004-11-22 Ralf Corsepius * ... Tue, 21 Sep 2004 14:30:53 GMT Ralf Corsepius [d71ab7fd] * c/src/ChangeLog (modified) * c/src/aclocal/gcc-weak.m4 (added) * c/src/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/gcc-weak.m4 (added) * cpukit/configure.ac (modified) 2004-09-21 Ralf Corsepius * ... Wed, 18 Aug 2004 11:06:47 GMT Ralf Corsepius [31ca690e] * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2004-08-18 Ralf Corsepius PR ... Wed, 28 Jul 2004 15:32:02 GMT Joel Sherrill [82fe9c1] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2004-07-28 * aclocal/version.m4: Updated to rtems-4.6.99.1. Tue, 06 Apr 2004 02:38:22 GMT Ralf Corsepius [e9d90764] * cpukit/aclocal/rtems-cpu-subdirs.m4 (deleted) * cpukit/configure.ac (modified) * cpukit/score/cpu/Makefile.am (modified) 2004-04-06 Ralf Corsepius * ... Tue, 30 Mar 2004 15:19:48 GMT Ralf Corsepius [6855663] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2004-03-30 Ralf Corsepius * ... Mon, 29 Mar 2004 12:35:15 GMT Ralf Corsepius [894b7f97] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2004-03-29 Ralf Corsepius * ... Thu, 12 Feb 2004 14:41:32 GMT Ralf Corsepius [31ffd58] * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2004-02-12 Ralf Corsepius * ... Wed, 21 Jan 2004 17:56:37 GMT Ralf Corsepius [faf45cc] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/configure.ac (modified) 2004-01-21 Ralf Corsepius * ... Sun, 11 Jan 2004 12:21:40 GMT Ralf Corsepius [c6e26e06] * cpukit/ChangeLog (modified) * cpukit/aclocal/enable-bare.m4 (deleted) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2004-01-11 Ralf Corsepius * ... Sun, 11 Jan 2004 09:38:10 GMT Ralf Corsepius [ca0eeaa] * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2004-01-11 Ralf Corsepius * ... Sun, 11 Jan 2004 02:30:12 GMT Ralf Corsepius [35d9b418] * cpukit/ChangeLog (modified) * cpukit/aclocal/enable-bare.m4 (modified) * cpukit/aclocal/enable-inlines.m4 (modified) * cpukit/aclocal/enable-itron.m4 (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/aclocal/enable-networking.m4 (modified) * cpukit/aclocal/enable-posix.m4 (modified) * cpukit/aclocal/enable-rtems-debug.m4 (modified) * cpukit/aclocal/multi.m4 (modified) * cpukit/aclocal/multilib.m4 (modified) * cpukit/automake/local.am (modified) * cpukit/configure.ac (modified) 2004-01-11 Ralf Corsepius * ... Fri, 09 Jan 2004 18:14:38 GMT Ralf Corsepius [d7a7573] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/aclocal/enable-networking.m4 (modified) * cpukit/automake/amcompile.am (modified) * cpukit/wrapup/Makefile.am (modified) 2004-01-08 Ralf Corsepius * ... Wed, 07 Jan 2004 20:45:20 GMT Joel Sherrill [161624c] * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-cpu-subdirs.m4 (modified) 2004-01-07 Joel Sherrill * ... Wed, 17 Dec 2003 20:56:10 GMT Joel Sherrill [44652f8] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2003-12-17 Joel Sherrill * ... Sat, 13 Dec 2003 09:31:17 GMT Ralf Corsepius [b7235805] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/wrapup/Makefile.am (modified) 2003-12-13 Ralf Corsepius * ... Sat, 13 Dec 2003 04:10:07 GMT Ralf Corsepius [efe9ef4] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/wrapup/Makefile.am (modified) 2003-12-13 Ralf Corsepius * ... Fri, 12 Dec 2003 10:37:19 GMT Ralf Corsepius [ba962ea] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/lead-dot.m4 (deleted) * cpukit/automake/lib.am (modified) 2003-12-12 Ralf Corsepius * ... Sun, 30 Nov 2003 07:02:49 GMT Ralf Corsepius [e3407a4] * cpukit/ChangeLog (modified) * cpukit/aclocal/lead-dot.m4 (added) * cpukit/aclocal/rtems-top.m4 (modified) 2003-11-30 Ralf Corsepius * ... Thu, 27 Nov 2003 14:36:23 GMT Ralf Corsepius [1bcbe41] * cpukit/ChangeLog (modified) * cpukit/acinclude.m4 (modified) * cpukit/aclocal/check-itron.m4 (modified) * cpukit/aclocal/check-multiprocessing.m4 (modified) * cpukit/aclocal/check-posix.m4 (modified) * cpukit/configure.ac (modified) 2003-11-27 Ralf Corsepius * ... Wed, 26 Nov 2003 06:56:28 GMT Ralf Corsepius [863fb4f] * cpukit/ChangeLog (modified) * cpukit/aclocal/canonicalize-tools.m4 (modified) * cpukit/aclocal/check-itron.m4 (modified) * cpukit/aclocal/check-multiprocessing.m4 (modified) * cpukit/aclocal/check-newlib.m4 (modified) * cpukit/aclocal/check-posix.m4 (modified) * cpukit/aclocal/check-rtems-debug.m4 (modified) * cpukit/aclocal/check-tool.m4 (modified) * cpukit/aclocal/enable-bare.m4 (modified) * cpukit/aclocal/enable-inlines.m4 (modified) * cpukit/aclocal/enable-itron.m4 (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/aclocal/enable-networking.m4 (modified) * cpukit/aclocal/enable-posix.m4 (modified) * cpukit/aclocal/enable-rtems-debug.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/gcc-isystem.m4 (modified) * cpukit/aclocal/gcc-pipe.m4 (modified) * cpukit/aclocal/multi.m4 (modified) * cpukit/aclocal/multilib.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/aclocal/sysv-ipc.m4 (modified) 2003-11-26 Ralf Corsepius * ... Mon, 24 Nov 2003 09:57:09 GMT Ralf Corsepius [dcfba35] * cpukit/.cvsignore (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/enable-inlines.m4 (modified) * cpukit/configure.ac (modified) 2003-11-24 Ralf Corsepius * ... Thu, 20 Nov 2003 07:02:53 GMT Ralf Corsepius [3da33bf8] * cpukit/ChangeLog (modified) * cpukit/acinclude.m4 (added) * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/enable-inlines.m4 (modified) * cpukit/configure.ac (modified) 2003-11-20 Ralf Corsepius * ... Tue, 21 Oct 2003 15:17:21 GMT Ralf Corsepius [ed4b894] * cpukit/ChangeLog (modified) * cpukit/aclocal/canonical-host.m4 (deleted) * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/check-posix.m4 (modified) * cpukit/aclocal/sysv-ipc.m4 (modified) * cpukit/configure.ac (modified) 2003-10-21 Ralf Corsepius * ... Tue, 21 Oct 2003 14:51:01 GMT Ralf Corsepius [5b2e199] * cpukit/ChangeLog (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/check-cpu.m4 (deleted) * cpukit/aclocal/check-itron.m4 (modified) * cpukit/aclocal/check-multiprocessing.m4 (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/configure.ac (modified) 2003-10-21 Ralf Corsepius * ... Fri, 17 Oct 2003 08:17:55 GMT Ralf Corsepius [62f0829] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/configure.ac (modified) 2003-10-17 Ralf Corsepius * ... Fri, 29 Aug 2003 00:06:15 GMT Ralf Corsepius [ac3786b] * aclocal/rtems-top.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/aclocal/rtems-top.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/rtems-top.m4 (modified) 2003-08-28 Ralf Corsepius * ... Mon, 18 Aug 2003 09:45:40 GMT Ralf Corsepius [30d5640] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-rtems-debug.m4 (added) * cpukit/aclocal/enable-rtems-debug.m4 (moved) 2003-08-18 Ralf Corsepius * ... Thu, 03 Jul 2003 14:17:35 GMT Joel Sherrill [73defea0] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-07-03 Joel Sherrill * ... Tue, 27 May 2003 13:03:29 GMT Ralf Corsepius [d46ec86] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/automake/compile.am (modified) * cpukit/automake/local.am (modified) 2003-05-27 Ralf Corsepius PR ... Fri, 02 May 2003 20:29:10 GMT Ralf Corsepius [1e030c49] * cpukit/ChangeLog (modified) * cpukit/aclocal/enable-rtemsbsp.m4 (deleted) * cpukit/aclocal/env-rtemsbsp.m4 (deleted) * cpukit/aclocal/env-rtemscpu.m4 (modified) 2003-05-02 Ralf Corsepius * ... Thu, 17 Apr 2003 19:44:03 GMT Joel Sherrill [7ae9530] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-04-17 Joel Sherrill * ...
