source: rtems/cpukit/Makefile.am
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @ebf9a05   09/14/14 22:50:28 Chris Johns libmisc: Add a stdio redirector helper. This module makes it easy to … 4.115
(edit) @2a86615   08/05/14 20:48:01 Jennifer Averett capture: Add support for variable length records. 4.115
(edit) @8cb2882   10/31/13 14:00:20 Sebastian Huber Filesystem: Add kernel event filter handler This handler is necessary … 4.115
(edit) @16829460   10/31/13 14:00:14 Sebastian Huber Filesystem: Add poll() handler This handler is necessary to implement … 4.115
(edit) @3c96bee   09/12/13 13:32:07 Sebastian Huber JFFS2: Add RTEMS support 4.115
(edit) @46b7f921   02/26/13 11:00:34 ralf.kirchner libmisc: Add utf8proc-v1.1.5 utf8proc is a small library for … 4.115
(edit) @bb679b3   01/23/13 19:09:18 Joel Sherrill Move <memory.h> and <sys/uio.h> to non-networking directory These two … 4.115
(edit) @7fab7fc   12/05/12 09:54:17 ralf.kirchner libblock: Add sparse disk 4.115
(edit) @9b4422a2   05/03/12 15:09:24 Joel Sherrill Remove All CVS Id Strings Possible Using a Script Script does what is … 4.115
(edit) @33a105fb   05/07/12 16:08:48 Joel Sherrill Revert: Remove CVS Ids See … 4.115
(edit) @ee32f67a   05/04/12 06:55:28 Ralf Corsepius Remove CVS-Ids. 4.115
(edit) @fb78f91   04/23/12 13:10:04 Gedare Bloom PR1908: consolidate libqos code and fix installed header location 4.115
(edit) @c050143   04/16/12 03:06:34 Petr Benes PR1908: QoS library for CBS scheduler Since the CBS scheduler is … 4.115
(edit) @be42aa1a   01/26/12 08:58:10 Sebastian Huber Revert "Google C++ Testing Framework 1.6.0." This reverts commit … 4.115
(edit) @9bf3a868   01/11/12 13:37:24 Sebastian Huber Google C++ Testing Framework 1.6.0. 4.115
(edit) @9d9b6653   05/16/11 14:12:16 Ralf Corsepius 2011-05-16 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.115
(edit) @158b416   05/13/11 13:46:43 Sebastian Huber 2011-05-13 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @013fef8   03/24/11 11:21:58 Ralf Corsepius 2011-03-24 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @3d6c1bb   03/14/11 14:56:08 Joel Sherrill 2011-03-14 Joel Sherrill <joel.sherrill@…> PR 1762/cpukit … 4.115
(edit) @46d6e7a9   02/09/11 06:15:53 Ralf Corsepius 2011-02-09 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @538453e   10/04/10 17:45:32 Joel Sherrill 2010-10-04 Joel Sherrill <joel.sherrill@…> * Makefile.am, … 4.115
(edit) @21dd3ab8   10/04/10 15:32:36 Joel Sherrill 2010-10-04 Joel Sherrill <joel.sherrill@…> * Makefile.am, … 4.115
(edit) @d91e3a7   08/13/10 12:40:16 Sebastian Huber 2010-08-13 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @fce31ab   06/17/10 15:29:22 Ralf Corsepius Remove itron. 4.115
(edit) @d2065e3   06/14/10 11:57:06 Sebastian Huber 2010-06-14 Sebastian Huber <sebastian.huber@…> PR … 4.115
(edit) @de93598   06/13/10 03:36:58 Ralf Corsepius 2010-06-13 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @f600eebd   06/11/10 19:37:12 Ralf Corsepius 2010-06-11 Ralf Corsépius <ralf.corsepius@…> * Doxygen.in: … 4.115
(edit) @ec6f27c2   06/09/10 08:06:26 Ralf Corsepius 2010-06-09 Ralf Corsépius <ralf.corsepius@…> * Makefile.am, … 4.115
(edit) @1908a5f   06/09/10 05:48:04 Ralf Corsepius 2010-06-09 Ralf Corsépius <ralf.corsepius@…> * Makefile.am, … 4.115
(edit) @a9fa9b7   02/18/10 00:24:25 Chris Johns 2010-02-18 Chris Johns <chrisj@…> * … 4.104.115
(edit) @1eefa75   11/22/09 07:04:54 Ralf Corsepius 2009-11-22 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.115
(edit) @e0a045e   10/14/09 14:54:00 Ralf Corsepius 2009-10-14 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.115
(edit) @eb649786   10/08/09 07:07:36 Chris Johns 2009-10-08 Chris Johns <chrisj@…> * Makefile.am, … 4.104.115
(edit) @cb09a5da   08/21/09 18:39:59 Joel Sherrill 2009-08-21 Roxana Leontie <roxana.leontie@…> * Makefile.am, … 4.104.115
(edit) @e152ecb7   08/05/09 19:37:55 Joel Sherrill 2009-08-05 Joel Sherrill <joel.sherrill@…> * Makefile.am, … 4.104.115
(edit) @a20baf9   08/03/09 15:10:10 Joel Sherrill 2009-08-03 Roxana Leontie <roxana.leontie@…> * Makefile.am, … 4.104.115
(edit) @e8d59ca   07/22/09 14:26:25 Joel Sherrill 2009-07-22 Joel Sherrill <joel.sherrill@…> * Makefile.am, … 4.104.115
(edit) @870d0a2   05/05/09 12:52:29 Thomas.Doerfler Update 4.104.115
(edit) @e4bd96ec   04/14/09 10:22:53 Thomas.Doerfler removed obsolete references to login.h 4.104.115
(edit) @8a775c27   03/27/09 13:45:31 Joel Sherrill 2009-03-27 Sebastian Huber <sebastian.huber@…> * … 4.104.115
(edit) @b4a2209   02/20/09 14:27:38 Ralf Corsepius Add include/sys/priority.h. 4.104.115
(edit) @465b36f9   02/06/09 17:23:33 Ralf Corsepius Remove tar.h. 4.104.115
(edit) @62a210d3   01/05/09 06:03:40 Ralf Corsepius Install libnetworking/sys/uio.h if building for NEWLIB. 4.104.115
(edit) @b8c5277f   12/17/08 06:41:36 Ralf Corsepius Remove include/rtems/stdint.h. 4.104.115
(edit) @e2324c0   10/14/08 15:06:25 Joel Sherrill 2008-10-14 Wei Shen <cquark@…> * Makefile.am, preinstall.am, … 4.104.115
(edit) @d40da79b   09/17/08 16:12:04 Joel Sherrill 2008-09-17 Miao Yan <yanmiaobest@…> * Makefile.am, … 4.104.115
(edit) @224aebb3   07/11/08 10:07:00 Thomas.Doerfler added BSP to m68k adapted PPC exception code 4.104.114.95
(edit) @5a2b5b2   05/01/08 04:15:36 Chris Johns 2008-05-01 Chris Johns <chrisj@…> * … 4.104.114.95
(edit) @3c68c6c8   12/14/07 04:58:04 Chris Johns 2007-12-12 Chris Johns <chrisj@…> * Makefile.am, … 4.104.114.95
(edit) @06bd7c7   12/12/07 10:10:38 Chris Johns 2007-12-12 Chris Johns <chrisj@…> * Makefile.am: Added … 4.104.114.95
(edit) @db27544   12/12/07 00:15:54 Joel Sherrill 2007-12-11 Joel Sherrill <joel.sherrill@…> * Makefile.am, … 4.104.114.95
(edit) @a70b07b   06/12/07 15:57:35 Ralf Corsepius 2007-06-12 Ralf Corsépius <ralf.corsepius@…> * configure.ac, … 4.104.114.84.95
(edit) @31903f07   06/11/07 13:32:25 Ralf Corsepius Add shttpd. 4.104.114.84.95
(edit) @e1bce86   05/15/07 20:16:16 Joel Sherrill 2007-05-15 Joel Sherrill <joel.sherrill@…> * Makefile.am, … 4.104.114.84.95
(edit) @1a9aa7e   05/10/07 07:34:07 Ralf Corsepius 2007-05-10 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @e8475e8   05/10/07 07:21:22 Ralf Corsepius Reflect introduction of include/rtems/bsd/sys/cdefs.h. 4.104.114.84.95
(edit) @7a1c421f   05/10/07 04:52:42 Ralf Corsepius 2007-05-10 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @6e4bc7c   05/09/07 16:28:48 Ralf Corsepius 2007-05-09 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @7ecaafa   12/13/06 07:21:53 Ralf Corsepius Abandon DEPRECATED_TYPES. 4.104.114.84.95
(edit) @70bb55f   11/20/06 05:55:01 Ralf Corsepius 2006-11-20 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @3fe615ba   11/18/06 02:28:35 Ralf Corsepius Replace AM_CONDITIONAL(HAS_NETWORKING) with AM_CONDITIONAL(LIBNETWORKING). 4.104.114.84.95
(edit) @5669334   11/17/06 09:49:29 Ralf Corsepius Introduce AM_CONDITIONAL(LIBITRON). Remove AM_CONDITIONAL(HAS_ITRON). 4.104.114.84.95
(edit) @10bf8e69   11/17/06 08:46:45 Ralf Corsepius 2006-11-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac, … 4.104.114.84.95
(edit) @d8f6534   11/12/06 11:18:21 Ralf Corsepius Remove RTEMS_PROVIDES_STDINT_H, RTEMS_PROVIDES_INTTYPES_H. 4.104.114.84.95
(edit) @bf1cade   06/29/06 09:08:07 Ralf Corsepius 2006-06-28 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @ef60f1ef   01/13/06 13:21:23 Ralf Corsepius 2006-01-13 Ralf Corsepius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @4e97166   01/12/06 09:57:43 Ralf Corsepius Remove all-local. 4.104.114.84.95
(edit) @dbe8e519   01/12/06 04:19:28 Ralf Corsepius Cleanups 4.104.114.84.95
(edit) @6339f467   11/03/05 02:44:59 strauman 2005-11-02 straumanatslacdotstanford.edu * libi2c/Makefile.am, … 4.104.114.84.95
(edit) @fa645f6   10/30/05 04:40:46 Ralf Corsepius Add zlib. 4.104.114.84.95
(edit) @aa40f6f   10/27/05 04:13:14 Ralf Corsepius Cosmetics. 4.104.114.84.95
(edit) @c5bb2a4e   10/26/05 16:27:10 Ralf Corsepius Add pppd. 4.104.114.84.95
(edit) @7021a2ec   10/26/05 02:44:15 Ralf Corsepius 2005-10-26 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @8280caa4   10/25/05 16:14:23 Ralf Corsepius Add telnetd. 4.104.114.84.95
(edit) @66e365f   08/05/05 10:32:53 Ralf Corsepius 2005-08-05 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @f554b02   05/23/05 07:28:06 Ralf Corsepius Remove ada. 4.104.114.84.95
(edit) @e01c480d   05/17/05 14:38:37 Jennifer.Averett 2005-05-17 Jennifer Averett <jennifer.averett@…> * … 4.104.114.84.95
(edit) @f9452cd   05/09/05 13:06:56 Ralf Corsepius Add rtems_bsdnet_HEADERS. 4.104.114.84.95
(edit) @ff1eb4c0   03/04/05 16:20:05 Ralf Corsepius 2005-03-04 Ralf Corsepius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @6265b83   02/08/05 15:02:25 Ralf Corsepius Split preinstallation rules in to separate files (preinstall.am). 4.104.114.84.95
(edit) @fa73ccb   02/08/05 04:04:46 Ralf Corsepius 2005-02-08 Ralf Corsepius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @9d0e65ed   02/07/05 13:19:45 Ralf Corsepius 2005-02-07 Ralf Corsepius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @a29d2e7   02/04/05 14:58:01 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @f26145b   02/04/05 12:40:16 Ralf Corsepius 2005-02-03 Ralf Corsepius <ralf.corsepius@…> PR 756/rtems * … 4.104.114.84.95
(edit) @e18080ab   01/27/05 06:42:37 Ralf Corsepius 2005-01-27 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @be4bd26   10/27/04 05:48:46 Ralf Corsepius Add httpd. 4.104.114.84.95
(edit) @a59e6c0   04/12/04 10:55:57 Ralf Corsepius 2004-04-12 Ralf Corsepius <ralf_corsepius@…> * acinclude.m4 … 4.104.114.84.95
(edit) @f8284c95   04/01/04 15:12:39 Ralf Corsepius 2004-04-01 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @30f66299   04/01/04 10:59:51 Ralf Corsepius 2004-04-01 Ralf Corsepius <ralf_corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @2f4c86f   03/29/04 12:43:20 Ralf Corsepius 2004-03-29 Ralf Corsepius <ralf_corsepius@…> PR 561/rtems * … 4.104.114.84.95
(edit) @3d1de20   01/19/04 07:29:05 Ralf Corsepius 2004-01-19 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @5c24afe9   01/14/04 05:20:59 Ralf Corsepius 2004-01-14 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @a42f159a   01/11/04 05:25:27 Ralf Corsepius 2004-01-11 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @b0805d8   12/12/03 16:08:28 Ralf Corsepius 2003-12-12 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @ba962ea   12/12/03 10:37:19 Ralf Corsepius 2003-12-12 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @6041409   11/30/03 10:37:29 Ralf Corsepius 2003-11-30 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @6547cf0   11/26/03 15:31:12 Ralf Corsepius 2003-11-20 Ralf Corsepius <corsepiu@…> * acinclude.m4: … 4.104.114.84.95
(edit) @71e66df   09/24/03 08:11:33 Ralf Corsepius 2003-09-24 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @da0fc5d   07/08/03 17:08:05 Ralf Corsepius 2003-07-08 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @07da959   07/08/03 15:27:02 Ralf Corsepius 2003-07-08 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
