# # ChangeLog for cpukit/Makefile.am in rtems # # Generated by Trac 1.2.1.dev0 # 05/23/24 20:13:13 Thu, 16 Apr 2020 10:22:06 GMT Sebastian Huber [34e4df55] * cpukit/Makefile.am (modified) * cpukit/libtest/t-test-rtems-objs.c (modified) * cpukit/libtest/t-test-rtems-posix-keys.c (added) * cpukit/libtest/t-test-rtems.h (added) libtest: Split POSIX Keys support Update #3199. Fri, 17 Jul 2020 12:49:42 GMT Sebastian Huber [af92665] * cpukit/Makefile.am (modified) * cpukit/include/rtems/test-info.h (modified) * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-busy-tick.c (added) * cpukit/libtest/testbusy.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) libtest: Add T_get_one_clock_tick_busy() Update #3199. Fri, 17 Jul 2020 12:40:36 GMT Sebastian Huber [e3e3b871] * cpukit/Makefile.am (modified) * cpukit/include/rtems/test-info.h (modified) * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-busy.c (added) * cpukit/libtest/testbusy.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) libtest: Add T_busy() Update #3199. Fri, 03 Jul 2020 05:46:24 GMT Sebastian Huber [401b237] * bsps/epiphany/epiphany_sim/README (deleted) * bsps/epiphany/epiphany_sim/btimer/btimer.c (deleted) * bsps/epiphany/epiphany_sim/config/epiphany_sim.cfg (deleted) * bsps/epiphany/epiphany_sim/console/console-io.c (deleted) * bsps/epiphany/epiphany_sim/headers.am (deleted) * bsps/epiphany/epiphany_sim/include/bsp.h (deleted) * bsps/epiphany/epiphany_sim/include/bsp/irq.h (deleted) * bsps/epiphany/epiphany_sim/include/tm27.h (deleted) * bsps/epiphany/epiphany_sim/irq/irq.c (deleted) * bsps/epiphany/epiphany_sim/start/bsp_specs (deleted) * bsps/epiphany/epiphany_sim/start/linkcmds (deleted) * bsps/epiphany/epiphany_sim/start/start.S (deleted) * bsps/epiphany/headers.am (deleted) * bsps/epiphany/include/bsp/linker-symbols.h (deleted) * bsps/epiphany/shared/doxygen.h (deleted) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/epiphany/Makefile.am (deleted) * c/src/lib/libbsp/epiphany/acinclude.m4 (deleted) * c/src/lib/libbsp/epiphany/configure.ac (deleted) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (deleted) * c/src/lib/libbsp/epiphany/epiphany_sim/configure.ac (deleted) * cpukit/Makefile.am (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/configure.ac (modified) * cpukit/score/cpu/epiphany/cpu.c (deleted) * cpukit/score/cpu/epiphany/epiphany-context-initialize.c (deleted) * cpukit/score/cpu/epiphany/epiphany-context-switch.S (deleted) * cpukit/score/cpu/epiphany/epiphany-exception-handler.S (deleted) * cpukit/score/cpu/epiphany/headers.am (deleted) * cpukit/score/cpu/epiphany/include/rtems/asm.h (deleted) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (deleted) * cpukit/score/cpu/epiphany/include/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/epiphany/include/rtems/score/cpuatomic.h (deleted) * cpukit/score/cpu/epiphany/include/rtems/score/cpuimpl.h (deleted) * cpukit/score/cpu/epiphany/include/rtems/score/epiphany-utility.h (deleted) * cpukit/score/cpu/epiphany/include/rtems/score/epiphany.h (deleted) * cpukit/score/cpu/epiphany/setjmp.S (deleted) epiphany: Remove support for this target Due to an unmaintained ... Tue, 05 May 2020 14:11:39 GMT Sebastian Huber [1af8e45b] * cpukit/Makefile.am (modified) * cpukit/include/rtems.h (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/sapi/src/getcopyrightnotice.c (added) * testsuites/sptests/sp43/init.c (modified) * testsuites/sptests/sp43/sp43.scn (modified) rtems: Add rtems_get_copyright_notice() Update #3973. Sun, 05 Apr 2020 07:58:24 GMT Sebastian Huber [d582d0e] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/percpu.h (modified) * cpukit/score/src/isrstackareaend.c (deleted) Revert "score: Fix _ISR_Stack_area_end" This reverts commit ... Fri, 03 Apr 2020 07:47:21 GMT Sebastian Huber [8e80876] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/percpu.h (modified) * cpukit/score/src/isrstackareaend.c (added) score: Fix _ISR_Stack_area_end The _ISR_Stack_area_begin and ... Thu, 12 Mar 2020 17:29:48 GMT Sebastian Huber [ab42b3e] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs/extensions.h (modified) * cpukit/include/rtems/record.h (modified) * cpukit/include/rtems/recorddump.h (added) * cpukit/libtrace/record/record-dump-base64.c (added) * cpukit/libtrace/record/record-dump-fatal.c (added) * cpukit/libtrace/record/record-dump-zbase64.c (added) * cpukit/libtrace/record/record-dump-zfatal.c (added) * cpukit/libtrace/record/record-dump.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/record02/init.c (modified) record: Add rtems_record_dump() Add rtems_record_dump_base64() and ... Fri, 13 Mar 2020 09:14:04 GMT Sebastian Huber [c584d4e] * cpukit/Makefile.am (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/libcsupport/src/rtems_put_char.c (added) * cpukit/libcsupport/src/vprintk.c (modified) rtems: Add rtems_put_char() Update #3904. Thu, 12 Mar 2020 14:43:17 GMT Sebastian Huber [a6b36334] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/io.h (modified) * cpukit/score/src/iobase64.c (added) * testsuites/sptests/spprintk/init.c (modified) score: Add _IO_Base64() Update #3904. Tue, 03 Mar 2020 18:23:53 GMT Sebastian Huber [0161b93d] * bsps/i386/pc386/include/bsp.h (modified) * bsps/riscv/griscv/include/bsp.h (modified) * bsps/sparc/leon3/include/bsp.h (modified) * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs/bsp.h (modified) * cpukit/include/rtems/confdefs/libio.h (modified) * cpukit/include/rtems/confdefs/obsolete.h (modified) * cpukit/include/rtems/devfs.h (deleted) * cpukit/include/rtems/imfs.h (modified) * cpukit/libfs/src/devfs/devclose.c (deleted) * cpukit/libfs/src/devfs/devfs_eval.c (deleted) * cpukit/libfs/src/devfs/devfs_init.c (deleted) * cpukit/libfs/src/devfs/devfs_mknod.c (deleted) * cpukit/libfs/src/devfs/devfs_show.c (deleted) * cpukit/libfs/src/devfs/devioctl.c (deleted) * cpukit/libfs/src/devfs/devopen.c (deleted) * cpukit/libfs/src/devfs/devread.c (deleted) * cpukit/libfs/src/devfs/devstat.c (deleted) * cpukit/libfs/src/devfs/devwrite.c (deleted) * cpukit/libfs/src/imfs/imfs_eval_devfs.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/devfs01/init.c (modified) * testsuites/libtests/devfs02/devfs02.doc (deleted) * testsuites/libtests/devfs02/devfs02.scn (deleted) * testsuites/libtests/devfs02/init.c (deleted) * testsuites/libtests/devfs03/devfs03.doc (deleted) * testsuites/libtests/devfs03/devfs03.scn (deleted) * testsuites/libtests/devfs03/init.c (deleted) * testsuites/libtests/devfs04/init.c (modified) * testsuites/libtests/deviceio01/init.c (modified) imfs: Replace devfs with an IMFS specialization Add a simplified ... Sat, 29 Feb 2020 15:14:31 GMT Sebastian Huber [fa44c39] * cpukit/Makefile.am (modified) * cpukit/include/rtems/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_add_node.c (added) * cpukit/libfs/src/imfs/imfs_node.c (modified) * cpukit/libfs/src/imfs/imfs_node_destroy_default.c (added) * testsuites/fstests/fsimfsgeneric01/init.c (modified) imfs: Add IMFS_add_node() Update #3894. Tue, 03 Mar 2020 12:45:50 GMT Sebastian Huber [8b73ee5] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/getcurrentprocessor.c (deleted) * cpukit/rtems/src/getprocessorcount.c (deleted) rtems: rtems_scheduler_get_processor_maximum() In uniprocessor ... Mon, 24 Feb 2020 13:06:41 GMT Sebastian Huber [18020109] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/schedulermapfromposix.c (added) * testsuites/sptests/spscheduler01/init.c (modified) rtems: Add rtems_scheduler_map_priority_from_posix() Update #3881. Mon, 24 Feb 2020 13:06:16 GMT Sebastian Huber [38736c6] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/schedulermaptoposix.c (added) * testsuites/sptests/spscheduler01/init.c (modified) rtems: Add rtems_scheduler_map_priority_to_posix() Update #3881. Tue, 25 Feb 2020 12:47:59 GMT Sebastian Huber [c36fae22] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/iodrivers.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/iodefault.c (added) * testsuites/sptests/spsysinit01/init.c (modified) config: Initialize IO drivers on demand Thu, 20 Feb 2020 06:33:59 GMT Sebastian Huber [03aff2c] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/malloc.h (added) * cpukit/libcsupport/src/mallocdirtydefault.c (added) * cpukit/libcsupport/src/mallocextenddefault.c (added) config: Add Remove all comments and ... Fri, 14 Feb 2020 12:48:18 GMT Sebastian Huber [ad85c00] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/wkspacedata.h (modified) * cpukit/score/src/wkspaceisunifieddefault.c (added) config: Add _Workspace_Is_unified Move the unified workspace ... Fri, 14 Feb 2020 12:36:30 GMT Sebastian Huber [5180762c] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/threadidledata.h (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadidledefault.c (added) config: Add _Thread_Idle_body Move the idle thread body ... Fri, 14 Feb 2020 11:58:21 GMT Sebastian Huber [308a2e0f] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/watchdogticks.h (modified) * cpukit/score/src/watchdogtimeslicedefault.c (added) config: Add _Watchdog_Ticks_per_timeslice Move the ticks per ... Fri, 14 Feb 2020 08:31:44 GMT Sebastian Huber [9520ec3] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/include/rtems/rtems/tasksdata.h (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/rtems/src/getapiconfig.c (added) * cpukit/rtems/src/taskinitdefault.c (added) * cpukit/rtems/src/taskinitusers.c (modified) config: Simplify initialization task config With the removal of the ... Tue, 10 Dec 2019 10:13:18 GMT Sebastian Huber [d252e20a] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/threadallocateunlimited.c (added) * cpukit/score/src/threadinitialize.c (modified) * testsuites/samples/unlimited/test1.c (modified) score: Simplify _Thread_Initialize() Allocate new thread queue ... Mon, 16 Dec 2019 13:50:59 GMT Sebastian Huber [6135747] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectfreestatic.c (added) score: Split up objects free Split up the different objects free ... Tue, 10 Dec 2019 09:41:48 GMT Sebastian Huber [2485156] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectallocatenone.c (added) * cpukit/score/src/objectallocatestatic.c (added) * cpukit/score/src/objectallocateunlimited.c (added) score: Split up objects allocation Split up the different objects ... Mon, 16 Dec 2019 13:32:47 GMT Sebastian Huber [00c7ad4] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/score/src/stackallocator.c (added) score: Split stack allocator configuration This allows the linker ... Mon, 09 Dec 2019 09:12:14 GMT Sebastian Huber [f4dbf37d] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/score/src/configstackspacesize.c (added) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/tlsallocsize.c (added) * cpukit/score/src/wkspace.c (modified) score: Simplify TLS area allocation Use the stack area to allocate ... Tue, 04 Feb 2020 14:26:31 GMT Sebastian Huber [2d07ce6] * bsps/shared/start/bootcard.c (modified) * c/src/aclocal/bsp-bootcard-options.m4 (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/memory.h (modified) * cpukit/score/src/memorydirtyfreeareas.c (added) * testsuites/sptests/sp54/init.c (modified) config: Add CONFIGURE_DIRTY_MEMORY Replace the BSP_DIRTY_MEMORY BSP ... Tue, 04 Feb 2020 12:56:41 GMT Sebastian Huber [8ecbc38] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/memory.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/sapi/src/sysinitverbose.c (modified) * cpukit/score/src/memoryzerobeforeuse.c (added) * cpukit/score/src/memoryzerofreeareas.c (added) * cpukit/score/src/wkspace.c (modified) * testsuites/sptests/sp54/init.c (modified) sysinit: Add RTEMS_SYSINIT_ZERO_MEMORY Use a dedicate system ... Sun, 02 Feb 2020 10:00:05 GMT Sebastian Huber [e44ae80] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/sapi/src/sysinitverbose.c (added) * testsuites/sptests/spsysinit01/init.c (modified) config: Add CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION Update #3861. Fri, 13 Dec 2019 05:25:03 GMT Sebastian Huber [c477d927] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/memory.h (modified) * cpukit/score/src/memoryfill.c (added) score: Add _Memory_Fill() Update #3838. Tue, 10 Dec 2019 19:03:53 GMT Sebastian Huber [1cb9257] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/score/memory.h (added) * cpukit/score/src/memoryallocate.c (added) score: Add Memory Handler Update #3838. Fri, 20 Dec 2019 08:29:33 GMT Sebastian Huber [556e45f2] * cpukit/Makefile.am (modified) * cpukit/include/t.h (modified) * cpukit/libtest/t-test-rtems-context.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/ttest01/init.c (modified) * testsuites/libtests/ttest01/test-task-context.c (added) libtest: Add T_check_task_context() action Thu, 12 Dec 2019 06:11:54 GMT Sebastian Huber [24f8915] * bsps/include/shm_driver.h (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/include/rtems/score/mpci.h (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-mpci.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mpcidefault.c (added) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * testsuites/sptests/spsize/size.c (modified) config: Add _MPCI_Configuration Replace the user MPCI configuration ... Tue, 12 Nov 2019 15:33:41 GMT Joel Sherrill [08bd7d3] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/todimpl.h (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/score/src/coretodhookdata.c (added) * cpukit/score/src/coretodhookregister.c (added) * cpukit/score/src/coretodhookrun.c (added) * cpukit/score/src/coretodhookunregister.c (added) * cpukit/score/src/coretodset.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spclock_todhook01/init.c (added) * testsuites/sptests/spclock_todhook01/spclock_todhook01.doc (added) * testsuites/sptests/spclock_todhook01/spclock_todhook01.scn (added) Add TOD Hooks to allow BSP to take action when TOD is set Two use ... Mon, 18 Nov 2019 05:55:43 GMT Sebastian Huber [f377998] * cpukit/Makefile.am (modified) * cpukit/include/rtems/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_linfile.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_make_linfile.c (added) * testsuites/libtests/shell01/init.c (modified) imfs: Add IMFS_make_linfile() Update #3818. Wed, 02 Oct 2019 21:49:00 GMT Joel Sherrill [667501a] * cpukit/Makefile.am (modified) * cpukit/include/rtems/libio.h (modified) * cpukit/include/rtems/rtems/status.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_posix_isig_handler.c (added) * cpukit/rtems/src/statustext.c (modified) * cpukit/rtems/src/statustoerrno.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/termios10/init.c (added) * testsuites/libtests/termios10/termios10.doc (added) * testsuites/libtests/termios10/termios10.scn (added) * testsuites/libtests/termios11/termios11.doc (added) * testsuites/libtests/termios11/termios11.scn (added) termios: Add Capability to Generate SIGINTR and SIGQUIT This patch ... Wed, 02 Oct 2019 04:40:30 GMT Sebastian Huber [6ae2522] * cpukit/Makefile.am (modified) * cpukit/libtrace/record/record-wrap-malloc.c (deleted) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/record02/init.c (modified) * testsuites/libtests/record02/record02.scn (modified) Revert "record: Add wrappers for malloc() functions" It was ... Fri, 30 Aug 2019 13:01:38 GMT Sebastian Huber [a314544a] * cpukit/Makefile.am (modified) * cpukit/libtrace/record/record-wrap-malloc.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/record02/init.c (modified) * testsuites/libtests/record02/record02.scn (modified) record: Add wrappers for malloc() functions Introduce new library ... Mon, 26 Aug 2019 12:58:54 GMT Sebastian Huber [58bd67b] * cpukit/Makefile.am (modified) * cpukit/include/rtems/record.h (modified) * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record-util.c (added) * testsuites/libtests/record02/init.c (modified) * testsuites/libtests/record02/record02.scn (modified) record: Add more system events Reduce the system dependencies to ... Tue, 25 Jun 2019 11:07:40 GMT Chris Johns [cb1e8497] * cpukit/Makefile.am (modified) * cpukit/include/rtems/debugger/rtems-debugger-bsp.h (added) * cpukit/libdebugger/rtems-debugger-arm.c (modified) * cpukit/libdebugger/rtems-debugger-bsp.c (added) * cpukit/libdebugger/rtems-debugger-server.c (modified) * cpukit/libdebugger/rtems-debugger-threads.c (modified) libdebugger: ARM fixes for Cortex-A8 and ARM mode. - Fix destorying ... Mon, 20 May 2019 07:15:36 GMT Sebastian Huber [5fa893e] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpunicastaction.c (added) * testsuites/smptests/smpmulticast01/init.c (modified) * testsuites/smptests/smpmulticast01/smpmulticast01.scn (modified) score: Add _SMP_Unicast_action() Thu, 31 Jan 2019 13:45:31 GMT Sebastian Huber [cfcc2cbf] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/t.h (added) * cpukit/libtest/t-test-checks-eno.c (added) * cpukit/libtest/t-test-checks-psx.c (added) * cpukit/libtest/t-test-checks.c (added) * cpukit/libtest/t-test-hash-sha256.c (added) * cpukit/libtest/t-test-malloc.c (added) * cpukit/libtest/t-test-rtems-fds.c (added) * cpukit/libtest/t-test-rtems-heap.c (added) * cpukit/libtest/t-test-rtems-measure.c (added) * cpukit/libtest/t-test-rtems-objs.c (added) * cpukit/libtest/t-test-rtems.c (added) * cpukit/libtest/t-test-time.c (added) * cpukit/libtest/t-test.c (added) Add RTEMS Test Framework Update #3199. Mon, 14 Jan 2019 08:08:18 GMT Sebastian Huber [6fe01e4b] * cpukit/Makefile.am (modified) * cpukit/libtest/testbeginend.c (moved) * cpukit/libtest/testbusy.c (moved) * cpukit/libtest/testextension.c (moved) * cpukit/libtest/testparallel.c (moved) * cpukit/libtest/testwrappers.c (moved) * testsuites/ada/ada.am (modified) * testsuites/automake/compile.am (modified) build: Move test support to librtemstest.a One reason to move the ... Mon, 25 Mar 2019 07:09:09 GMT Sebastian Huber [7a1934d] * cpukit/Makefile.am (modified) build: Always build libmghttpd.a Sat, 02 Feb 2019 04:09:53 GMT Chris Johns [6c9f017] * bsps/powerpc/psim/start/linkcmds (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-bit-alloc.c (added) * cpukit/libdl/rtl-bit-alloc.h (added) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/dl01/dl-load.c (modified) * testsuites/libtests/dl02/dl-load.c (modified) * testsuites/libtests/dl02/dl-o1.c (modified) * testsuites/libtests/dl02/dl-o2.c (modified) * testsuites/libtests/dl03/dl-bit-alloc.c (added) * testsuites/libtests/dl03/dl-bit-alloc.h (added) * testsuites/libtests/dl03/init.c (modified) * testsuites/libtests/dl05/dl-load.c (modified) * testsuites/libtests/dl07/dl-load.c (modified) * testsuites/libtests/dl07/dl-o1.c (modified) * testsuites/libtests/dl07/dl-o2.c (modified) * testsuites/libtests/dl07/dl-o3.c (modified) * testsuites/libtests/dl07/dl-o4.c (modified) * testsuites/libtests/dl07/dl-o5.c (modified) * testsuites/libtests/dl07/init.c (modified) * testsuites/libtests/dl08/dl-o1.c (modified) * testsuites/libtests/dl08/dl-o2.c (modified) * testsuites/libtests/dl08/dl-o3.c (modified) * testsuites/libtests/dl08/dl-o4.c (modified) * testsuites/libtests/dl08/dl-o5.c (modified) * testsuites/libtests/dl08/dl-o6-123456789-123456789.c (modified) * testsuites/libtests/dl09/dl-load.c (modified) * testsuites/libtests/dl09/dl-o1.c (modified) * testsuites/libtests/dl09/dl-o2.c (modified) * testsuites/libtests/dl09/dl-o3.c (modified) * testsuites/libtests/dl09/dl-o4.c (modified) * testsuites/libtests/dl09/dl-o5.c (modified) libdl: Add powerpc large memory and small data support. - Add ... Mon, 17 Dec 2018 05:36:48 GMT Chris Johns [89c59be] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtl/rtl-archive.h (added) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-shell.h (moved) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rtl-archive.c (added) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-string.h (modified) * cpukit/libdl/rtl-trace.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) libdl: Add symbol searching and loading from archives. - Load ... Sat, 28 Apr 2018 09:36:11 GMT Sebastian Huber [dca6184] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/record.h (added) * cpukit/include/rtems/recordclient.h (added) * cpukit/include/rtems/recorddata.h (added) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/libtrace/record/record-client.c (added) * cpukit/libtrace/record/record-server.c (added) * cpukit/libtrace/record/record-sysinit.c (added) * cpukit/libtrace/record/record-text.c (added) * cpukit/libtrace/record/record-userext.c (added) * cpukit/libtrace/record/record.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/record01/init.c (added) * testsuites/libtests/record01/record01.doc (added) * testsuites/libtests/record01/record01.scn (added) * testsuites/libtests/record02/init.c (added) * testsuites/libtests/record02/record02.doc (added) * testsuites/libtests/record02/record02.scn (added) Add low level event recording support Add low level event recording ... Wed, 19 Dec 2018 08:25:29 GMT Sebastian Huber [2158621] * cpukit/Makefile.am (modified) * cpukit/libcsupport/src/alignedalloc.c (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spcxx01/init.cc (added) * testsuites/sptests/spcxx01/spcxx01.doc (added) * testsuites/sptests/spcxx01/spcxx01.scn (added) Add aligned_alloc() and memalign() Ensure that the C++17 aligned ... Thu, 22 Nov 2018 18:14:51 GMT Sebastian Huber [21275b58] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/extensiondata.h (modified) * cpukit/include/rtems/extensionimpl.h (modified) * cpukit/include/rtems/posix/key.h (modified) * cpukit/include/rtems/posix/keyimpl.h (modified) * cpukit/include/rtems/posix/mqueue.h (modified) * cpukit/include/rtems/posix/mqueueimpl.h (modified) * cpukit/include/rtems/posix/pthread.h (modified) * cpukit/include/rtems/posix/pthreadimpl.h (modified) * cpukit/include/rtems/posix/semaphore.h (modified) * cpukit/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/include/rtems/posix/shm.h (modified) * cpukit/include/rtems/posix/shmimpl.h (modified) * cpukit/include/rtems/posix/sigset.h (modified) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/include/rtems/posix/timerimpl.h (modified) * cpukit/include/rtems/rtems/barrierdata.h (modified) * cpukit/include/rtems/rtems/barrierimpl.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/include/rtems/rtems/dpmemdata.h (modified) * cpukit/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/include/rtems/rtems/messagedata.h (modified) * cpukit/include/rtems/rtems/messageimpl.h (modified) * cpukit/include/rtems/rtems/msgmp.h (modified) * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/rtems/partmp.h (modified) * cpukit/include/rtems/rtems/ratemondata.h (modified) * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/rtems/regiondata.h (modified) * cpukit/include/rtems/rtems/regionimpl.h (modified) * cpukit/include/rtems/rtems/semdata.h (modified) * cpukit/include/rtems/rtems/semimpl.h (modified) * cpukit/include/rtems/rtems/semmp.h (modified) * cpukit/include/rtems/rtems/tasksdata.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/include/rtems/rtems/timerdata.h (modified) * cpukit/include/rtems/rtems/timerimpl.h (modified) * cpukit/include/rtems/score/freechain.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadq.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keyzerokvp.c (added) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/psxsemaphore.c (modified) * cpukit/posix/src/psxtimercreate.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/shm.c (modified) * cpukit/posix/src/shmopen.c (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/barriercreate.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/score/src/freechain.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/psxtests/psxobj01/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal13/spfatal13.doc (deleted) * testsuites/sptests/spfatal13/spfatal13.scn (deleted) * testsuites/sptests/spfatal13/testcase.h (deleted) * testsuites/sptests/spfreechain01/init.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) score: Static Objects_Information initialization Statically ... Mon, 10 Dec 2018 11:51:33 GMT Sebastian Huber [0f5b2c09] * cpukit/Makefile.am (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/getconfigmax.c (added) rtems: Use object information to get config max Use functions ... Thu, 06 Dec 2018 08:57:01 GMT Sebastian Huber [7ee6437] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/schedulergetmaxprio.c (added) * testsuites/sptests/spscheduler01/init.c (modified) rtems: Add rtems_scheduler_get_maximum_priority() Update #3636. Thu, 03 May 2018 11:03:27 GMT Sebastian Huber [0a1f5df9] * bsps/or1k/generic_or1k/clock/clockdrv.c (modified) * bsps/shared/dev/cpucounter/cpucounterdiff.c (deleted) * bsps/sparc/erc32/clock/ckinit.c (modified) * bsps/sparc/leon2/clock/ckinit.c (modified) * bsps/sparc/leon3/clock/ckinit.c (modified) * bsps/sparc/leon3/include/leon.h (modified) * bsps/sparc/leon3/start/cpucounter.c (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h (modified) * cpukit/score/cpu/sparc/sparc-counter-asm.S (modified) * cpukit/score/cpu/sparc/sparc-counter.c (deleted) Simplify _CPU_Counter_difference() In order to simplify the use of ... Fri, 09 Nov 2018 06:56:48 GMT Sebastian Huber [ed9da8e] * cpukit/Makefile.am (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (deleted) powerpc: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 15:03:10 GMT Sebastian Huber [12dfa5e2] * cpukit/Makefile.am (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-isr-install-raw-handler.c (deleted) * cpukit/score/cpu/nios2/nios2-isr-install-vector.c (modified) nios2: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 11:57:26 GMT Sebastian Huber [e897c7d] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/tasksdata.h (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/rtems/src/rtemsmaxprio.c (added) rtems: Avoid include of Update #3598. Thu, 08 Nov 2018 10:32:13 GMT Sebastian Huber [98c01a5] * cpukit/Makefile.am (modified) * cpukit/include/rtems/imfs.h (modified) * cpukit/include/rtems/rtems/clock.h (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (added) rtems: Avoid in API Use a real function ... Thu, 08 Nov 2018 15:21:48 GMT Sebastian Huber [bfcf1473] * bsps/m32c/m32cbsp/README (deleted) * bsps/m32c/m32cbsp/btimer/btimer.c (deleted) * bsps/m32c/m32cbsp/config/m32csim-testsuite.tcfg (deleted) * bsps/m32c/m32cbsp/config/m32csim.cfg (deleted) * bsps/m32c/m32cbsp/console/console-io.c (deleted) * bsps/m32c/m32cbsp/console/syscalls.S (deleted) * bsps/m32c/m32cbsp/doxygen.h (deleted) * bsps/m32c/m32cbsp/headers.am (deleted) * bsps/m32c/m32cbsp/include/bsp.h (deleted) * bsps/m32c/m32cbsp/include/tm27.h (deleted) * bsps/m32c/m32cbsp/start/bsp_specs (deleted) * bsps/m32c/m32cbsp/start/bspstart.c (deleted) * bsps/m32c/m32cbsp/start/crtn.S (deleted) * bsps/m32c/m32cbsp/start/linkcmds (deleted) * bsps/m32c/m32cbsp/start/start.S (deleted) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/m32c/Makefile.am (deleted) * c/src/lib/libbsp/m32c/acinclude.m4 (deleted) * c/src/lib/libbsp/m32c/configure.ac (deleted) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (deleted) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (deleted) * cpukit/Makefile.am (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/configure.ac (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) * cpukit/score/cpu/m32c/context_init.c (deleted) * cpukit/score/cpu/m32c/context_switch.S (deleted) * cpukit/score/cpu/m32c/cpu.c (deleted) * cpukit/score/cpu/m32c/headers.am (deleted) * cpukit/score/cpu/m32c/include/rtems/asm.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpuatomic.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/m32c.h (deleted) * cpukit/score/cpu/m32c/include/varvects.h (deleted) * cpukit/score/cpu/m32c/m32c-exception-frame-print.c (deleted) * cpukit/score/cpu/m32c/varvects.S (deleted) * testsuites/sptests/sptask_err03/init.c (modified) * testsuites/sptests/sptimer_err02/init.c (modified) m32c: Remove this target Update #3599. Tue, 06 Nov 2018 18:34:15 GMT Sebastian Huber [4fea054c] * bsps/mips/shared/irq/exception.S (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/isr.h (modified) * cpukit/score/cpu/m32c/cpu_asm.c (deleted) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/moxie/cpu_asm.S (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/interrupt.S (modified) score: Remove _ISR_Dispatch() This function was only used on some ... Tue, 06 Nov 2018 12:04:11 GMT Sebastian Huber [d1f7204] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/libcsupport/src/getreentglobal.c (added) config: Fix CONFIGURE_DISABLE_NEWLIB_REENTRANCY Move the ... Thu, 25 Oct 2018 08:54:12 GMT Sebastian Huber [54f35888] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/monitor.h (modified) * cpukit/include/rtems/posix/pthreadattrimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/score/src/threaditerate.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/wkspace.c (modified) posix: Provide threads by default Update #2514. Thu, 25 Oct 2018 08:12:39 GMT Sebastian Huber [fe7aefd5] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) posix: Provide message queues by default Update #2514. Thu, 25 Oct 2018 08:07:46 GMT Sebastian Huber [701057e0] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/posix/src/shmops.c (added) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) posix: Provide shared memory objects by default Update #2514. Sun, 14 Oct 2018 10:43:13 GMT Sebastian Huber [9318cfb0] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) posix: Provide named semaphores by default Update #2514. Sun, 14 Oct 2018 17:20:05 GMT Sebastian Huber [e97806a] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/posix/config.h (modified) * cpukit/include/rtems/posix/mqueue.h (modified) * cpukit/include/rtems/posix/psignal.h (modified) * cpukit/include/rtems/posix/pthread.h (modified) * cpukit/include/rtems/posix/semaphore.h (modified) * cpukit/include/rtems/posix/shm.h (modified) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueueconfig.c (added) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalconfig.c (added) * cpukit/posix/src/psxsemaphore.c (modified) * cpukit/posix/src/psxsemaphoreconfig.c (added) * cpukit/posix/src/psxtimerconfig.c (added) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadconfig.c (added) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/shm.c (modified) * cpukit/posix/src/shmconfig.c (added) * cpukit/score/src/wkspace.c (modified) posix: Split posix_api_configuration_table Use separate ... Mon, 15 Oct 2018 06:33:45 GMT Sebastian Huber [55b69ed] * cpukit/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) Move default config to librtemsdefaultconfig.a An RTEMS application ... Thu, 25 Oct 2018 12:37:08 GMT Sebastian Huber [0dbf67b] * cpukit/Makefile.am (modified) posix: Provide aio_suspend() by default Update #2514. Thu, 25 Oct 2018 07:56:02 GMT Sebastian Huber [135cb10] * cpukit/Makefile.am (modified) posix: Provide more functions by default Update #2514. Wed, 24 Oct 2018 05:54:27 GMT Sebastian Huber [4b801ac] * cpukit/Makefile.am (modified) posix: Provide simple thread functions by default Update #2514. Wed, 24 Oct 2018 05:40:23 GMT Sebastian Huber [c1ce9a2] * cpukit/Makefile.am (modified) * cpukit/include/rtems/posix/pthreadattrimpl.h (modified) * cpukit/posix/src/psxtransschedparam.c (modified) posix: Provide get thread attributes by default Update #2514. Sun, 14 Oct 2018 15:10:32 GMT Sebastian Huber [8d81622] * cpukit/Makefile.am (modified) posix: Provide non-thread functions by default Update #2514. Sun, 14 Oct 2018 10:41:22 GMT Sebastian Huber [0b2808ce] * cpukit/Makefile.am (modified) posix: Provide scheduler support by default Update #2514. Sun, 14 Oct 2018 10:36:22 GMT Sebastian Huber [dd804bb] * cpukit/Makefile.am (modified) posix: Provide cancel state/type by default Sort POSIX sources ... Thu, 18 Oct 2018 12:58:31 GMT Sebastian Huber [6da1bb0] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) Remove superfluous configure checks The results of these checks are ... Thu, 18 Oct 2018 12:39:09 GMT Sebastian Huber [f59edebf] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libcsupport/src/getcwd.c (deleted) Remove getcwd() This function is provided by Newlib since 2000. ... Thu, 18 Oct 2018 12:33:58 GMT Sebastian Huber [e161767e] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libcsupport/src/ttyname.c (deleted) Remove ttyname() This function is provided by Newlib since 2000. ... Thu, 18 Oct 2018 12:22:46 GMT Sebastian Huber [87a9900f] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libcsupport/src/isatty.c (deleted) Remove isatty() These functions are provided by Newlib since 2000. ... Thu, 18 Oct 2018 12:11:10 GMT Sebastian Huber [3cf12c9] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libcsupport/src/readdir_r.c (deleted) * cpukit/libcsupport/src/strlcat.c (deleted) * cpukit/libcsupport/src/strlcpy.c (deleted) * cpukit/libnetworking/libc/strsep.c (deleted) Remove strlcat(), strlcpy(), strsep(), readdir_r() These functions ... Thu, 11 Oct 2018 17:34:35 GMT Sebastian Huber [9d1f17a9] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) build: Fix build on Windows Avoid a long argument list while ... Mon, 10 Sep 2018 15:38:14 GMT Sebastian Huber [2548d14] * bootstrap (modified) * cpukit/Makefile.am (modified) * cpukit/automake/subdirs.am (deleted) * cpukit/configure.ac (modified) * cpukit/header-dirs.am (added) * cpukit/headers.am (modified) * cpukit/libnetworking/Makefile.am (deleted) * cpukit/libnetworking/headers.am (modified) * cpukit/score/Makefile.am (deleted) * cpukit/score/cpu/Makefile.am (deleted) * cpukit/score/cpu/arm/Makefile.am (deleted) * cpukit/score/cpu/arm/headers.am (modified) * cpukit/score/cpu/bfin/Makefile.am (deleted) * cpukit/score/cpu/bfin/headers.am (modified) * cpukit/score/cpu/epiphany/Makefile.am (deleted) * cpukit/score/cpu/epiphany/headers.am (modified) * cpukit/score/cpu/h8300/headers.am (modified) * cpukit/score/cpu/i386/Makefile.am (deleted) * cpukit/score/cpu/i386/headers.am (modified) * cpukit/score/cpu/lm32/Makefile.am (deleted) * cpukit/score/cpu/lm32/headers.am (modified) * cpukit/score/cpu/m32c/Makefile.am (deleted) * cpukit/score/cpu/m32c/headers.am (modified) * cpukit/score/cpu/m68k/Makefile.am (deleted) * cpukit/score/cpu/m68k/headers.am (modified) * cpukit/score/cpu/mips/Makefile.am (deleted) * cpukit/score/cpu/mips/headers.am (modified) * cpukit/score/cpu/moxie/Makefile.am (deleted) * cpukit/score/cpu/moxie/headers.am (modified) * cpukit/score/cpu/nios2/Makefile.am (deleted) * cpukit/score/cpu/nios2/headers.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (deleted) * cpukit/score/cpu/no_cpu/headers.am (modified) * cpukit/score/cpu/or1k/Makefile.am (deleted) * cpukit/score/cpu/or1k/headers.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (deleted) * cpukit/score/cpu/powerpc/headers.am (modified) * cpukit/score/cpu/riscv/Makefile.am (deleted) * cpukit/score/cpu/riscv/headers.am (modified) * cpukit/score/cpu/sh/Makefile.am (deleted) * cpukit/score/cpu/sh/headers.am (modified) * cpukit/score/cpu/sparc/Makefile.am (deleted) * cpukit/score/cpu/sparc/headers.am (modified) * cpukit/score/cpu/sparc64/Makefile.am (deleted) * cpukit/score/cpu/sparc64/headers.am (modified) * cpukit/score/cpu/v850/Makefile.am (deleted) * cpukit/score/cpu/v850/headers.am (modified) * cpukit/score/cpu/x86_64/Makefile.am (deleted) * cpukit/score/cpu/x86_64/headers.am (modified) build: Include header.am in cpukit/Makefile.am Include all ... Sat, 06 Oct 2018 08:59:10 GMT Sebastian Huber [477bca2] * automake/local.am (deleted) * c/src/Makefile.am (modified) * c/src/automake/local.am (deleted) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * c/src/lib/libbsp/x86_64/Makefile.am (modified) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * c/src/make/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/automake/local.am (deleted) * cpukit/score/cpu/Makefile.am (modified) * testsuites/Makefile.am (modified) * testsuites/ada/Makefile.am (modified) * testsuites/ada/mptests/Makefile.am (modified) * testsuites/ada/mptests/mp01/Makefile.am (modified) * testsuites/ada/mptests/mp01/node1/Makefile.am (modified) * testsuites/ada/mptests/mp01/node2/Makefile.am (modified) * testsuites/ada/mptests/mp03/Makefile.am (modified) * testsuites/ada/mptests/mp03/node1/Makefile.am (modified) * testsuites/ada/mptests/mp03/node2/Makefile.am (modified) * testsuites/ada/mptests/mp04/Makefile.am (modified) * testsuites/ada/mptests/mp04/node1/Makefile.am (modified) * testsuites/ada/mptests/mp04/node2/Makefile.am (modified) * testsuites/ada/mptests/mp05/Makefile.am (modified) * testsuites/ada/mptests/mp05/node1/Makefile.am (modified) * testsuites/ada/mptests/mp05/node2/Makefile.am (modified) * testsuites/ada/mptests/mp06/Makefile.am (modified) * testsuites/ada/mptests/mp06/node1/Makefile.am (modified) * testsuites/ada/mptests/mp06/node2/Makefile.am (modified) * testsuites/ada/mptests/mp07/Makefile.am (modified) * testsuites/ada/mptests/mp07/node1/Makefile.am (modified) * testsuites/ada/mptests/mp07/node2/Makefile.am (modified) * testsuites/ada/mptests/mp08/Makefile.am (modified) * testsuites/ada/mptests/mp08/node1/Makefile.am (modified) * testsuites/ada/mptests/mp08/node2/Makefile.am (modified) * testsuites/ada/mptests/mp09/Makefile.am (modified) * testsuites/ada/mptests/mp09/node1/Makefile.am (modified) * testsuites/ada/mptests/mp09/node2/Makefile.am (modified) * testsuites/ada/mptests/mp10/Makefile.am (modified) * testsuites/ada/mptests/mp10/node1/Makefile.am (modified) * testsuites/ada/mptests/mp10/node2/Makefile.am (modified) * testsuites/ada/mptests/mp11/Makefile.am (modified) * testsuites/ada/mptests/mp11/node1/Makefile.am (modified) * testsuites/ada/mptests/mp11/node2/Makefile.am (modified) * testsuites/ada/mptests/mp12/Makefile.am (modified) * testsuites/ada/mptests/mp12/node1/Makefile.am (modified) * testsuites/ada/mptests/mp12/node2/Makefile.am (modified) * testsuites/ada/mptests/mp13/Makefile.am (modified) * testsuites/ada/mptests/mp13/node1/Makefile.am (modified) * testsuites/ada/mptests/mp13/node2/Makefile.am (modified) * testsuites/ada/mptests/mp14/Makefile.am (modified) * testsuites/ada/mptests/mp14/node1/Makefile.am (modified) * testsuites/ada/mptests/mp14/node2/Makefile.am (modified) * testsuites/ada/samples/Makefile.am (modified) * testsuites/ada/samples/base_mp/Makefile.am (modified) * testsuites/ada/samples/base_mp/node1/Makefile.am (modified) * testsuites/ada/samples/base_mp/node2/Makefile.am (modified) * testsuites/ada/samples/base_sp/Makefile.am (modified) * testsuites/ada/samples/hello/Makefile.am (modified) * testsuites/ada/samples/nsecs/Makefile.am (modified) * testsuites/ada/samples/ticker/Makefile.am (modified) * testsuites/ada/sptests/Makefile.am (modified) * testsuites/ada/sptests/sp01/Makefile.am (modified) * testsuites/ada/sptests/sp02/Makefile.am (modified) * testsuites/ada/sptests/sp03/Makefile.am (modified) * testsuites/ada/sptests/sp04/Makefile.am (modified) * testsuites/ada/sptests/sp05/Makefile.am (modified) * testsuites/ada/sptests/sp06/Makefile.am (modified) * testsuites/ada/sptests/sp07/Makefile.am (modified) * testsuites/ada/sptests/sp08/Makefile.am (modified) * testsuites/ada/sptests/sp09/Makefile.am (modified) * testsuites/ada/sptests/sp11/Makefile.am (modified) * testsuites/ada/sptests/sp12/Makefile.am (modified) * testsuites/ada/sptests/sp13/Makefile.am (modified) * testsuites/ada/sptests/sp14/Makefile.am (modified) * testsuites/ada/sptests/sp15/Makefile.am (modified) * testsuites/ada/sptests/sp16/Makefile.am (modified) * testsuites/ada/sptests/sp17/Makefile.am (modified) * testsuites/ada/sptests/sp19/Makefile.am (modified) * testsuites/ada/sptests/sp20/Makefile.am (modified) * testsuites/ada/sptests/sp22/Makefile.am (modified) * testsuites/ada/sptests/sp23/Makefile.am (modified) * testsuites/ada/sptests/sp24/Makefile.am (modified) * testsuites/ada/sptests/sp25/Makefile.am (modified) * testsuites/ada/sptests/spatcb01/Makefile.am (modified) * testsuites/ada/sptests/spname01/Makefile.am (modified) * testsuites/ada/support/Makefile.am (modified) * testsuites/ada/tmtests/Makefile.am (modified) * testsuites/ada/tmtests/tm01/Makefile.am (modified) * testsuites/ada/tmtests/tm02/Makefile.am (modified) * testsuites/ada/tmtests/tm03/Makefile.am (modified) * testsuites/ada/tmtests/tm04/Makefile.am (modified) * testsuites/ada/tmtests/tm05/Makefile.am (modified) * testsuites/ada/tmtests/tm06/Makefile.am (modified) * testsuites/ada/tmtests/tm07/Makefile.am (modified) * testsuites/ada/tmtests/tm08/Makefile.am (modified) * testsuites/ada/tmtests/tm09/Makefile.am (modified) * testsuites/ada/tmtests/tm10/Makefile.am (modified) * testsuites/ada/tmtests/tm11/Makefile.am (modified) * testsuites/ada/tmtests/tm12/Makefile.am (modified) * testsuites/ada/tmtests/tm13/Makefile.am (modified) * testsuites/ada/tmtests/tm14/Makefile.am (modified) * testsuites/ada/tmtests/tm15/Makefile.am (modified) * testsuites/ada/tmtests/tm16/Makefile.am (modified) * testsuites/ada/tmtests/tm17/Makefile.am (modified) * testsuites/ada/tmtests/tm18/Makefile.am (modified) * testsuites/ada/tmtests/tm19/Makefile.am (modified) * testsuites/ada/tmtests/tm20/Makefile.am (modified) * testsuites/ada/tmtests/tm21/Makefile.am (modified) * testsuites/ada/tmtests/tm22/Makefile.am (modified) * testsuites/ada/tmtests/tm23/Makefile.am (modified) * testsuites/ada/tmtests/tm24/Makefile.am (modified) * testsuites/ada/tmtests/tm25/Makefile.am (modified) * testsuites/ada/tmtests/tm28/Makefile.am (modified) * testsuites/ada/tmtests/tm29/Makefile.am (modified) * testsuites/ada/tmtests/tmck/Makefile.am (modified) * testsuites/ada/tmtests/tmoverhd/Makefile.am (modified) * testsuites/automake/local.am (deleted) * testsuites/benchmarks/Makefile.am (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/mptests/mp01/Makefile.am (modified) * testsuites/mptests/mp03/Makefile.am (modified) * testsuites/mptests/mp04/Makefile.am (modified) * testsuites/mptests/mp05/Makefile.am (modified) * testsuites/mptests/mp06/Makefile.am (modified) * testsuites/mptests/mp07/Makefile.am (modified) * testsuites/mptests/mp08/Makefile.am (modified) * testsuites/mptests/mp09/Makefile.am (modified) * testsuites/mptests/mp10/Makefile.am (modified) * testsuites/mptests/mp11/Makefile.am (modified) * testsuites/mptests/mp12/Makefile.am (modified) * testsuites/mptests/mp13/Makefile.am (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtmtests/Makefile.am (modified) * testsuites/rhealstone/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/tmtests/Makefile.am (modified) build: Remove local.am Sat, 06 Oct 2018 08:12:21 GMT Sebastian Huber [9da5d5fd] * cpukit/Makefile.am (modified) * testsuites/automake/compile.am (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) build: Directly reference libraries in tests Remove use of ... Fri, 05 Oct 2018 18:12:40 GMT Sebastian Huber [637546a] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/epiphany/Makefile.am (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/moxie/Makefile.am (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/or1k/Makefile.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/x86_64/Makefile.am (modified) * cpukit/wrapup/Makefile.am (deleted) build: Merge score/cpu/*/Makefile.am Thu, 04 Oct 2018 18:32:12 GMT Sebastian Huber [96ad2b2] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libmisc/Makefile.am (deleted) * cpukit/wrapup/Makefile.am (modified) build: Merge libmisc/Makefile.am Thu, 04 Oct 2018 18:07:16 GMT Sebastian Huber [19b7db50] * cpukit/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) build: Merge libnetworking/Makefile.am Thu, 04 Oct 2018 15:58:48 GMT Sebastian Huber [a40bb03] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/zlib/Makefile.am (deleted) build: Merge zlib/Makefile.am Thu, 04 Oct 2018 15:48:23 GMT Sebastian Huber [7f0eac30] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/telnetd/Makefile.am (deleted) build: Merge telnetd/Makefile.am Fri, 14 Sep 2018 18:02:02 GMT Sebastian Huber [1d93843] * cpukit/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) build: Merge score/Makefile.am Fri, 14 Sep 2018 17:55:00 GMT Sebastian Huber [640271f] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/rtems/Makefile.am (deleted) * cpukit/wrapup/Makefile.am (modified) build: Merge rtems/Makefile.am Fri, 14 Sep 2018 17:51:38 GMT Sebastian Huber [24312f34] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/pppd/Makefile.am (deleted) build: Merge pppd/Makefile.am Fri, 14 Sep 2018 17:46:58 GMT Sebastian Huber [b3ef89f9] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/posix/Makefile.am (deleted) * cpukit/wrapup/Makefile.am (modified) build: Merge posix/Makefile.am Fri, 14 Sep 2018 14:12:19 GMT Sebastian Huber [028b0ce] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/mghttpd/Makefile.am (deleted) build: Merge mghttpd/Makefile.am Fri, 14 Sep 2018 14:00:45 GMT Sebastian Huber [a2a71b5] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libstdthreads/Makefile.am (deleted) * cpukit/libstdthreads/cnd.c (modified) * cpukit/libstdthreads/mtx.c (modified) * cpukit/wrapup/Makefile.am (modified) build: Merge libstdthreads/Makefile.am Fri, 14 Sep 2018 13:56:26 GMT Sebastian Huber [5079524] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/librpc/Makefile.am (deleted) * cpukit/wrapup/Makefile.am (modified) build: Merge librpc/Makefile.am Fri, 14 Sep 2018 04:43:35 GMT Sebastian Huber [c38d517] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libpci/Makefile.am (deleted) * cpukit/wrapup/Makefile.am (modified) build: Merge libpci/Makefile.am Fri, 14 Sep 2018 04:41:27 GMT Sebastian Huber [e39642a4] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libmd/Makefile.am (deleted) * cpukit/wrapup/Makefile.am (modified) build: Merge libmd/Makefile.am Fri, 14 Sep 2018 04:38:50 GMT Sebastian Huber [0c56264] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libi2c/Makefile.am (deleted) * cpukit/wrapup/Makefile.am (modified) build: Merge libi2c/Makefile.am Fri, 14 Sep 2018 04:35:59 GMT Sebastian Huber [8d677cf] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libgnat/Makefile.am (deleted) * cpukit/wrapup/Makefile.am (modified) build: Merge libgnat/Makefile.am Fri, 14 Sep 2018 04:34:02 GMT Sebastian Huber [b45a853] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libfs/Makefile.am (deleted) * cpukit/libfs/src/nfsclient/Makefile.am (deleted) * cpukit/wrapup/Makefile.am (modified) build: Merge libfs/Makefile.am Fri, 14 Sep 2018 04:22:19 GMT Sebastian Huber [d3d1243] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libdrvmgr/Makefile.am (deleted) * cpukit/wrapup/Makefile.am (modified) build: Merge libdrvmgr/Makefile.am Fri, 14 Sep 2018 04:19:15 GMT Sebastian Huber [551f473] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libdl/Makefile.am (deleted) * cpukit/wrapup/Makefile.am (modified) build: Merge libdl/Makefile.am
