Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/contrib
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @d942dc2   07/23/07 09:44:40 Ralf Corsepius Various updates. 4.104.114.84.95
(edit) @131ee1cc   07/23/07 09:43:49 Ralf Corsepius New. 4.104.114.84.95
(edit) @f81476f   07/23/07 02:02:15 Ralf Corsepius Sync GCC with testing. 4.104.114.84.95
(edit) @86a30d0   07/22/07 07:08:30 Ralf Corsepius Various patches from rtems-4-8-testing branch. 4.104.114.84.95
(edit) @4acc7e2   07/20/07 05:36:13 Ralf Corsepius Sync with testing. 4.104.114.84.95
(edit) @70ea34b   07/20/07 05:32:17 Ralf Corsepius Sync with devel. 4.104.114.84.95
(edit) @ed332c8   07/20/07 05:23:59 Ralf Corsepius Sync with testing. 4.104.114.84.95
(edit) @280e1308   07/20/07 04:59:16 Ralf Corsepius New. 4.104.114.84.95
(edit) @4b0be6c   07/15/07 05:02:51 Ralf Corsepius Preps for gcc-4.2.1. 4.104.114.84.95
(edit) @20074c49   07/05/07 19:06:15 Joel Sherrill Needed to compile Ada. ACATS run on both psim and erc32. Results are … 4.104.114.84.95
(edit) @22cc95f5   06/18/07 11:22:49 Ralf Corsepius Preps for next spin. 4.104.114.84.95
(edit) @55e9fca   06/18/07 10:32:03 Ralf Corsepius Preps for next spin. 4.104.114.84.95
(edit) @3fac2408   06/18/07 09:42:00 Ralf Corsepius Update. 4.104.114.84.95
(edit) @9b31b29   06/18/07 07:02:32 Ralf Corsepius --disable-libstdcxx-pch 4.104.114.84.95
(edit) @bb96485   06/18/07 07:01:22 Ralf Corsepius Upgrade to gcc-4.2.0 final. 4.104.114.84.95
(edit) @7d846d4   06/18/07 04:46:14 Ralf Corsepius GCC_RPMREL = 18 4.104.114.84.95
(edit) @849ed685   06/18/07 04:45:51 Ralf Corsepius Cleanup. 20070613 patches. 4.104.114.84.95
(edit) @7f3319e   06/18/07 04:38:33 Ralf Corsepius GCC_RPMREL = 13 4.104.114.84.95
(edit) @611aa7dd   06/18/07 04:37:39 Ralf Corsepius Cleanup. 20070613 patches. 4.104.114.84.95
(edit) @169dbb55   06/18/07 04:36:33 Ralf Corsepius GCC_RPMREL = 14 4.104.114.84.95
(edit) @0d04790   06/18/07 04:35:41 Ralf Corsepius Cleanup. 4.104.114.84.95
(edit) @8cf555e   06/13/07 16:38:22 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @a43f670   06/13/07 15:42:41 Ralf Corsepius Add *20070613.diff 4.104.114.84.95
(edit) @fc463855   06/13/07 15:42:22 Ralf Corsepius GCC_RPMREL = 13 4.104.114.84.95
(edit) @c0064d39   06/13/07 15:40:32 Ralf Corsepius Add sparc fpu bug fix. 4.104.114.84.95
(edit) @967c8974   06/04/07 09:12:43 Ralf Corsepius New. 4.104.114.84.95
(edit) @4fec4975   06/03/07 15:26:45 Ralf Corsepius GCC_RPMREL = 17. 4.104.114.84.95
(edit) @0ae15e60   06/03/07 06:03:58 Ralf Corsepius GCC_RPMREL = 12 4.104.114.84.95
(edit) @87e21be   06/03/07 06:01:55 Ralf Corsepius New. 4.104.114.84.95
(edit) @ab86b62   06/02/07 07:54:37 Ralf Corsepius New. 4.104.114.84.95
(edit) @e2a00ab   06/02/07 07:54:07 Ralf Corsepius GCC_RPMREL = 12. 4.104.114.84.95
(edit) @ecf3c8c   06/02/07 05:57:31 Ralf Corsepius New. 4.104.114.84.95
(edit) @88d97467   06/02/07 05:57:05 Ralf Corsepius GCC_RPMREL = 12. 4.104.114.84.95
(edit) @9bc3ef5   06/02/07 04:52:01 Ralf Corsepius New. 4.104.114.84.95
(edit) @7b8fbed   06/02/07 04:51:44 Ralf Corsepius GCC_RPMREL = 11. 4.104.114.84.95
(edit) @498f319   06/02/07 04:29:21 Ralf Corsepius New. 4.104.114.84.95
(edit) @b34fda5   06/02/07 03:23:15 Ralf Corsepius New. 4.104.114.84.95
(edit) @6a4e3360   06/02/07 03:19:37 Ralf Corsepius GCC_RPMREL = 12. 4.104.114.84.95
(edit) @0925496   06/01/07 08:46:51 Ralf Corsepius GCC_RPMREL = 11. 4.104.114.84.95
(edit) @f7d5d6e3   05/25/07 13:42:51 Ralf Corsepius Backup. 4.104.114.84.95
(edit) @24848b6   05/25/07 13:42:27 Ralf Corsepius New. 4.104.114.84.95
(edit) @d183ac2a   05/25/07 08:39:01 Ralf Corsepius Add gprof.info handling. 4.104.114.84.95
(edit) @36c8e140   05/24/07 02:58:23 Ralf Corsepius Remove %{_libdir}/libiberty.a 4.104.114.84.95
(edit) @7860a37   05/22/07 08:11:26 Ralf Corsepius Bump version to 0.7 4.104.114.84.95
(edit) @54457f44   05/22/07 08:11:04 Ralf Corsepius Add suse 4.104.114.84.95
(edit) @4741b0b2   05/21/07 19:27:34 Joel Sherrill 2007-05-21 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @3fafc63   05/21/07 10:55:01 Ralf Corsepius Add --libexecdir. 4.104.114.84.95
(edit) @e57739d   05/17/07 15:39:50 Ralf Corsepius Add .rh clause to extra_arg. 4.104.114.84.95
(edit) @4ec03d7   05/17/07 15:34:10 Ralf Corsepius Add --enable-os-subdir. Bump version to 0.6. 4.104.114.84.95
(edit) @44302c7e   05/17/07 15:33:51 Ralf Corsepius Add --enable-os-subdir. 4.104.114.84.95
(edit) @9d3f291   05/17/07 15:33:13 Ralf Corsepius Add OS_SUBDIR. 4.104.114.84.95
(edit) @412058fa   05/16/07 02:12:27 Ralf Corsepius Remove (Obsolete). 4.104.114.84.95
(edit) @4c50a600   05/15/07 06:24:01 Ralf Corsepius New (Re-base patch against gcc-4.2.0 final) 4.104.114.84.95
(edit) @f324b08   05/14/07 15:36:30 Ralf Corsepius New (merge-in gcc-4.2.0 final patches). 4.104.114.84.95
(edit) @b40f354   05/11/07 08:56:46 Ralf Corsepius Comment out cpukit. 4.104.114.84.95
(edit) @206cc90f   05/11/07 03:04:06 Ralf Corsepius Add PATH if prefix != /usr 4.104.114.84.95
(edit) @6bdfa7a   05/10/07 14:31:51 Ralf Corsepius New. 4.104.114.84.95
(edit) @60baadf   05/10/07 14:30:57 Ralf Corsepius Add cpukit. 4.104.114.84.95
(edit) @2620f00   05/10/07 14:25:23 Ralf Corsepius New. 4.104.114.84.95
(edit) @1fa2436   05/03/07 02:16:26 Ralf Corsepius New. 4.104.114.84.95
(edit) @22a8f05   05/01/07 04:46:31 Ralf Corsepius Rebase against gcc-core-4.2.0-20070430 (gcc-4.2.0 rc2) 4.104.114.84.95
(edit) @f8518873   04/14/07 03:46:10 Ralf Corsepius Update to newlib-1.15.0-rtems4.8-20070413.diff 4.104.114.84.95
(edit) @0df1fb63   04/13/07 08:52:52 Ralf Corsepius Add CLOCK_MONOTONIC. Sync readlink, usleep with SUSv3. 4.104.114.84.95
(edit) @382c020   04/09/07 09:55:02 Ralf Corsepius Add mips .sdata handling from GCC-4.2 4.104.114.84.95
(edit) @0e944ec3   04/09/07 09:54:02 Ralf Corsepius Bump GCC_RPMREL. 4.104.114.84.95
(edit) @bf740cf   04/09/07 09:53:46 Ralf Corsepius Upgrade to gcc-core-4.1.2-rtems4.8-20070405.diff 4.104.114.84.95
(edit) @bf09c649   03/28/07 03:42:07 Ralf Corsepius Update. 4.104.114.84.95
(edit) @ad0a865   03/16/07 13:39:25 Ralf Corsepius Upgrade to gcc-4.1.2. Remove rtprio.h from newlib. 4.104.114.84.95
(edit) @20bc17f   03/16/07 04:41:34 Ralf Corsepius Upgrade to newlib-1.15.0-rtems4.8-20070316.diff 4.104.114.84.95
(edit) @fb3201c2   03/16/07 04:39:44 Ralf Corsepius New (Eliminate rtprio.h) 4.104.114.84.95
(edit) @41c3ed9   03/06/07 12:53:35 Ralf Corsepius New (Incorporate Joels patch to increase mem-sizes for erc32 sim.) 4.104.114.84.95
(edit) @58255f77   03/06/07 12:15:22 Ralf Corsepius Add exec_prefix. 4.104.114.84.95
(edit) @1f88fa0   03/01/07 06:20:02 Ralf Corsepius Add support for exec_prefix. 4.104.114.84.95
(edit) @0a6c808   02/28/07 07:30:11 Ralf Corsepius Remove (obsolete). 4.104.114.84.95
(edit) @661d5c8   02/28/07 07:29:32 Ralf Corsepius New. 4.104.114.84.95
(edit) @f05a343e   02/28/07 07:27:53 Ralf Corsepius Upgrade to gcc-4.2-20070221 4.104.114.84.95
(edit) @34a0e1d   02/28/07 03:27:30 Ralf Corsepius Remove unused code. 4.104.114.84.95
(edit) @41bd972   02/27/07 16:11:37 Ralf Corsepius Rebase binutils/gcc 4.104.114.84.95
(edit) @258d7d5a   02/27/07 14:34:01 Ralf Corsepius Add BINTUTILS_PKGVERS. 4.104.114.84.95
(edit) @916bb726   02/27/07 14:33:15 Ralf Corsepius Remove _use_internal_dependency_generator 0. Remove … 4.104.114.84.95
(edit) @cd5bd9b   02/27/07 07:38:04 Ralf Corsepius Use MKSPEC0. 4.104.114.84.95
(edit) @5da8174   02/27/07 07:33:19 Ralf Corsepius Add BINUTILS_PKGVERS. Add GCC_PKGVERS. 4.104.114.84.95
(edit) @a73220f   02/27/07 07:32:19 Ralf Corsepius Upgrade to cygwin-1.5.24-2. Upgrade to w32api-3.8-1. 4.104.114.84.95
(edit) @37304358   02/27/07 07:30:41 Ralf Corsepius Remove _use_internal_dependency_generator 0. Remove … 4.104.114.84.95
(edit) @2e03ec5a   02/27/07 04:55:39 Ralf Corsepius Upgrade to gcc-4.1.2. 4.104.114.84.95
(edit) @d967064   02/27/07 04:02:00 Ralf Corsepius Add BINUTILS_PKGVERS. Add GCC_PKGVERS. gcc-4.1.2. 4.104.114.84.95
(edit) @44b241c   02/27/07 04:00:37 Ralf Corsepius mf-runtime.h is still broken in gcc-4.1.2 4.104.114.84.95
(edit) @161e2739   02/27/07 03:59:07 Ralf Corsepius Add freebsd6.2 4.104.114.84.95
(edit) @2aa2177   02/27/07 03:57:55 Ralf Corsepius New. 4.104.114.84.95
(edit) @754b79a   02/26/07 16:50:20 Ralf Corsepius Add BINUTILS_PKGVERS. Add GCC_PKGVERS. 4.104.114.84.95
(edit) @856c8e48   02/26/07 16:47:54 Ralf Corsepius Add BINUTILS_PKGVERS. Add GCC_PKGVERS. Try gcc-4.1.2. 4.104.114.84.95
(edit) @67c1bb5e   02/26/07 15:54:49 Ralf Corsepius Add MKSPEC0. 4.104.114.84.95
(edit) @a8149e7   02/26/07 09:55:59 Ralf Corsepius Use binutils_pkgvers instead of binutils_version in Source0. 4.104.114.84.95
(edit) @8d182ca   02/26/07 09:35:04 Ralf Corsepius Add BINUTILS_PKGVERS. 4.104.114.84.95
(edit) @397a1bec   02/26/07 09:33:39 Ralf Corsepius Add GDB_PKGVERS. 4.104.114.84.95
(edit) @f3a77dd   02/26/07 09:29:52 Ralf Corsepius Add BINUTILS_PKGVERS. 4.104.114.84.95
(edit) @f7712468   02/26/07 09:26:59 Ralf Corsepius Add BINUTILS_PKGVERS. 4.104.114.84.95
(edit) @99a06927   02/26/07 09:23:23 Ralf Corsepius Add GCC_PKGVERS. 4.104.114.84.95
(edit) @f189de8   02/26/07 09:05:22 Ralf Corsepius Add GDB_PKGVERS. 4.104.114.84.95
(edit) @33b4b91   02/26/07 09:02:07 Ralf Corsepius Add BINUTILS_PKGVERS. 4.104.114.84.95
