@c85dad9
11/19/08 05:48:01 |
Ralf Corsepius |
Regenerate.
4.104.115
@c3bba34a
11/19/08 05:47:33 |
Ralf Corsepius |
Bump GCC_RPMREL.
Activate c++.
4.104.115
@c51adc79
11/19/08 03:31:05 |
Ralf Corsepius |
Update.
4.104.115
@f1322b47
11/10/08 10:47:51 |
Ralf Corsepius |
Regenerate.
4.104.115
@782c454
11/10/08 10:46:50 |
Ralf Corsepius |
Bump GCC_RPMREL.
4.104.115
@2c792a7
11/10/08 10:16:20 |
Ralf Corsepius |
Upgrade to cygwin-1.5.25-14.
Upgrade to w32api-3.12-1.
4.104.115
@f8552286
11/10/08 10:14:55 |
Ralf Corsepius |
Suppress debug_install-post for noarch.
4.104.115
@719a5c7
11/07/08 02:54:05 |
Ralf Corsepius |
Regenerate.
4.104.115
@4362e69e
11/07/08 02:43:05 |
Ralf Corsepius |
Add %{gcclib}/@tool_target@/%{gcc_version}/include-fixed.
4.104.115
@181e2da
11/07/08 02:42:13 |
Ralf Corsepius |
Bump GCC_RPMREL.
4.104.115
@05c66cf
11/05/08 19:07:46 |
Ralf Corsepius |
Update.
4.104.115
@156764a6
11/05/08 17:08:10 |
Ralf Corsepius |
Filter find-debuginfo.sh not to mistreat foreign binaries.
4.104.115
@95a9a73
11/05/08 16:55:58 |
Ralf Corsepius |
Upgrade to binutils-2.19, gcc-4.2.4.
4.104.115
@0e4d925
11/05/08 16:55:46 |
Ralf Corsepius |
Upgrade to binutils-2.19.
4.104.115
@d2c15d6
11/05/08 16:54:08 |
Ralf Corsepius |
Bump version.
4.104.115
@81f386b
11/04/08 07:54:58 |
Ralf Corsepius |
Silence unpackaging objc.
4.104.115
@2e34d125
11/04/08 07:53:37 |
Ralf Corsepius |
Filter out -std=gnu99 from CFLAGS.
4.104.115
@d41e18f8
10/28/08 22:12:04 |
Ralf Corsepius |
Bump BINUTILS_RPMREL.
4.104.115
@01ed848
10/28/08 22:09:59 |
Ralf Corsepius |
Add %sysdir %{_prefix} to cater rpm5.
4.104.115
@d6223f8
10/24/08 06:46:54 |
Ralf Corsepius |
Add OS_NAME.
4.104.115
@5ac4461
10/24/08 06:46:33 |
Ralf Corsepius |
Bump version. Add OS_NAME
4.104.115
@dcd0d35b
10/24/08 06:46:08 |
Ralf Corsepius |
Fix names.
4.104.115
@d9bea0c9
10/23/08 05:16:43 |
Ralf Corsepius |
Remove testing.
4.104.115
@ca3950e
10/23/08 04:45:09 |
Ralf Corsepius |
Bump version.
4.104.115
@0aebf87
10/23/08 04:42:33 |
Ralf Corsepius |
Rename *-debug repo into *-debuginfo to support debuginfo-install.
4.104.115
@0b6975a6
10/23/08 04:34:49 |
Ralf Corsepius |
New.
4.104.115
@b3bfca66
10/23/08 04:34:14 |
Ralf Corsepius |
Regenerate.
4.104.115
@1cf80bf
10/23/08 04:32:35 |
Ralf Corsepius |
binutils-2.19.
4.104.115
@54726239
10/16/08 03:09:18 |
Ralf Corsepius |
Regenerate.
4.104.115
@bc23d85
10/16/08 03:08:20 |
Ralf Corsepius |
Bump GDB_RPMREL.
4.104.115
@e56584fb
10/16/08 02:49:07 |
Ralf Corsepius |
Regenerate.
4.104.115
@d596630
10/16/08 02:48:16 |
Ralf Corsepius |
4.104.115
@6440a9c9
10/16/08 02:31:01 |
Ralf Corsepius |
New.
4.104.115
@04c9086c
10/16/08 02:30:20 |
Ralf Corsepius |
Bump RPMREL.
4.104.115
@7589cbfc
10/16/08 02:28:57 |
Ralf Corsepius |
Add full list of rpm path-macros (regression in FC10's rpm).
4.104.115
@f3b9811
10/15/08 12:33:48 |
Ralf Corsepius |
Remove.
4.104.115
@0b4445f
10/10/08 02:34:06 |
Ralf Corsepius |
New.
4.104.115
@945f9df9
10/10/08 02:33:18 |
Ralf Corsepius |
Regenerate.
4.104.115
@1171c46
10/10/08 02:32:36 |
Ralf Corsepius |
binutils-2.18.93-rtems4.10-20081010.diff.
4.104.115
@c81b995
10/10/08 02:30:19 |
Ralf Corsepius |
BINUTILS_VERS = 2.18.93
4.104.115
@c41d6b4
10/04/08 05:01:08 |
Ralf Corsepius |
Regenerate.
4.104.115
@e7910cd7
10/04/08 05:00:16 |
Ralf Corsepius |
Update to binutils-2.18.92.
4.104.115
@1547cff6
10/04/08 04:58:19 |
Ralf Corsepius |
Update to 2.18.92.
4.104.115
@a5ece1a5
10/03/08 06:18:38 |
Ralf Corsepius |
Regenerate.
4.104.115
@2abe16dd
10/03/08 06:18:17 |
Ralf Corsepius |
New.
4.104.115
@933e34a6
10/03/08 06:17:04 |
Ralf Corsepius |
GCC_RPMREL = 6. Disable cxx, infos.
4.104.115
@bba70f4
10/03/08 06:16:38 |
Ralf Corsepius |
GCC_RPMREL = 6.
4.104.115
@dc7c0df
10/03/08 06:15:57 |
Ralf Corsepius |
gcc-core-4.3.2-rtems4.10-20081003.diff, …
4.104.115
@525b90e5
10/03/08 06:14:31 |
Ralf Corsepius |
Add m32r/m32c. Undef ATTRIBUTE_IMPURE_PTR for mips only.
4.104.115
@f4bacae
10/03/08 06:13:17 |
Ralf Corsepius |
Add m32r/m32c.
4.104.115
@b38ae26b
10/03/08 03:41:40 |
Ralf Corsepius |
Regenerate.
4.104.115
@df339c2
10/03/08 03:40:27 |
Ralf Corsepius |
gdb-6.8-rtems4.10-20081003.diff.
Abandon _without_sources.
4.104.115
@30e604d
10/03/08 03:39:44 |
Ralf Corsepius |
Bump GDB_RPMREL.
4.104.115
@241aa252
10/03/08 03:35:23 |
Ralf Corsepius |
Add m32r-*-rtems*, m32c-*-rtems*.
4.104.115
@3d0a3acb
10/03/08 02:59:19 |
Ralf Corsepius |
Regenerate.
4.104.115
@e0c7ecf
10/03/08 02:58:08 |
Ralf Corsepius |
Build binutils infos.
4.104.115
@175b145c
10/03/08 02:55:10 |
Ralf Corsepius |
New.
4.104.115
@b2fd3b7
10/03/08 02:54:04 |
Ralf Corsepius |
Add m32r, m32c.
4.104.115
@24d6e0b
10/03/08 02:53:26 |
Ralf Corsepius |
4.104.115
@7d28f71
10/03/08 02:52:48 |
Ralf Corsepius |
Add binutils-2.18.91-rtems4.10-20081003.diff
4.104.115
@943b7d9
10/01/08 17:17:22 |
Joel Sherrill |
2008-10-01 Joel Sherrill <joel.sherrill@…>
4.104.115
@d45dff4
09/25/08 18:28:24 |
Joel Sherrill |
2008-09-25 Joel Sherrill <joel.sherrill@…>
4.104.115
@858407d
09/25/08 10:44:29 |
Ralf Corsepius |
newlib-1.16.0-rtems4.10-20080925.diff.
4.104.115
@190e9d5
09/25/08 10:40:49 |
Ralf Corsepius |
Undef ATTRIBUTE_IMPURE_PTR.
4.104.115
@641ef00
09/18/08 03:51:34 |
Ralf Corsepius |
Remove *.orig files having crept into patch.
4.104.115
@aa2d0450
09/17/08 15:26:36 |
Ralf Corsepius |
binutils-2.18.91.
4.104.115
@9a5e29b
09/17/08 14:38:54 |
Ralf Corsepius |
Switch to gdb-6.8-rtems4.10-20080917.diff.
4.104.115
@aa9a6dc
09/17/08 14:34:15 |
Ralf Corsepius |
Add patch from http://sourceware.org/ml/gdb-patches/2008-02/msg00472.html
4.104.115
@f63871e3
09/17/08 14:02:49 |
Ralf Corsepius |
Switch to gcc-core-4.3.2-rtems4.10-20080917.diff.
4.104.115
@c490a1a3
09/17/08 14:01:23 |
Ralf Corsepius |
Remove MULTILIB_EXTRA_OPTS from gcc/config/rs6000/t-rtems.
4.104.115
@fd92869
09/12/08 07:48:11 |
Ralf Corsepius |
Regenerate.
4.104.115
@c42b2459
09/12/08 07:47:01 |
Ralf Corsepius |
Bump GDB_RPMREL.
4.104.115
@0558e58
09/12/08 07:46:06 |
Ralf Corsepius |
Update.
4.104.115
@10d4919
09/12/08 07:43:34 |
Ralf Corsepius |
Remove (unused).
4.104.115
@ebe7bf28
09/12/08 06:44:19 |
Ralf Corsepius |
Merge-in Joels gdb-6.8-sysv-ipc-1.diff.
4.104.115
@3e256081
09/11/08 15:57:25 |
Ralf Corsepius |
GCC_RPMREL = 3 (Rebuild against binutils-2.18.90).
4.104.115
@518adaf
09/11/08 15:56:31 |
Ralf Corsepius |
Abandon gcc-4.3.1.
4.104.115
@6176ff0
09/11/08 15:53:10 |
Ralf Corsepius |
Remove (unused).
4.104.115
@04e8c69
09/11/08 12:00:46 |
Ralf Corsepius |
Upgrade to binutils-2.18.90.
4.104.115
@03a85d32
09/10/08 20:15:26 |
Ralf Corsepius |
Remove.
4.104.115
@93e1140
09/10/08 20:13:03 |
Ralf Corsepius |
Upgrade autoconf to 2.63.
4.104.115
@64c5bec5
09/10/08 20:12:00 |
Ralf Corsepius |
Bump RTEMS_API to 4.10.
4.104.115
@44c2d06d
09/10/08 20:09:27 |
Ralf Corsepius |
Remove freebsd6.2, freebsd6.3, rtems4.9.
4.104.115
@9d0c693
09/10/08 20:08:31 |
Ralf Corsepius |
Remove.
4.104.115
@7af2a17
09/08/08 13:32:05 |
Joel Sherrill |
2008-09-08 Joel Sherrill <joel.sherrill@…>
* AUTHORS: …
4.104.114.95
@c68637e
09/08/08 13:31:59 |
Joel Sherrill |
* AUTHORS, …
4.104.114.95
@2528c92
09/08/08 10:04:49 |
Ralf Corsepius |
Add --enable-newlib-io-c99-formats.
4.104.114.95
@9589c665
09/03/08 22:48:11 |
Ralf Corsepius |
Regenerate.
4.104.114.95
@d043ebc2
09/03/08 22:39:16 |
Ralf Corsepius |
Sync with rtems-4.10.
4.104.114.95
@3f01023
09/03/08 22:36:35 |
Ralf Corsepius |
New.
4.104.114.95
@d5982b4
09/03/08 09:29:30 |
Ralf Corsepius |
Remove.
4.104.114.95
@d8a213b2
08/28/08 19:54:29 |
Ralf Corsepius |
Regenerate.
4.104.114.95
@e90124e
08/28/08 19:53:37 |
Ralf Corsepius |
Bump GCC_RPMREL.
4.104.114.95
@183e5cf
08/28/08 14:13:55 |
Ralf Corsepius |
Regenerate.
4.104.114.95
@c9ef27b
08/28/08 14:12:42 |
Ralf Corsepius |
Add rtems4.10.
4.104.114.95
@68e6a18d
08/28/08 14:11:48 |
Ralf Corsepius |
4.104.114.95
@2fb65fbf
08/28/08 14:08:37 |
Ralf Corsepius |
gcc-4.3.2
4.104.114.95
@d5c49aa3
08/28/08 14:07:19 |
Ralf Corsepius |
New.
4.104.114.95
@882a12a
08/28/08 01:14:03 |
Ralf Corsepius |
Use URLs for patches.
4.104.114.95
@55315135
08/27/08 09:42:00 |
Ralf Corsepius |
4.104.114.95
