@be77d1f
07/21/06 00:04:20 |
Chris Johns |
Add NSIS installer support for MinGW.
4.104.114.84.95
@44a6dcc
07/20/06 23:32:32 |
Chris Johns |
Use gcc-core-4.1.1-rtems-20060720.diff.
4.104.114.84.95
@c29d0a21
07/20/06 05:17:36 |
Ralf Corsepius |
Remove $build_infos.
Add SPECSTRIP_OPTS.
4.104.114.84.95
@8747e99a
07/20/06 05:16:29 |
Ralf Corsepius |
Add --enable/disable-infos.
4.104.114.84.95
@40459fbf
07/20/06 05:15:47 |
Ralf Corsepius |
Add SPECSTRIP_OPTS.
4.104.114.84.95
@a1abfb95
07/20/06 00:40:11 |
Chris Johns |
2006-07-19 Chris Johns <chrisj@…>
4.104.114.84.95
@45def1d
07/19/06 21:51:39 |
Chris Johns |
Added patch to fix GCC bug PR28400.
4.104.114.84.95
@d4609b2
07/18/06 07:26:10 |
Ralf Corsepius |
Use newlib-1.14.0-rtems-20060707.diff
4.104.114.84.95
@22f187d0
07/18/06 07:25:19 |
Ralf Corsepius |
Fix setting up targets for solaris*
4.104.114.84.95
@4557d3c
07/18/06 02:32:19 |
Ralf Corsepius |
Remove infos and man7 if !%build_infos.
4.104.114.84.95
@c10a31b
07/17/06 15:23:04 |
Ralf Corsepius |
Require: base packages iff %build_infos
4.104.114.84.95
@176aca7
07/17/06 15:22:05 |
Ralf Corsepius |
Require: base-g77 iff %build_infos
4.104.114.84.95
@f69ae2e
07/17/06 15:21:33 |
Ralf Corsepius |
Require: base-gfortran iff %build_infos
4.104.114.84.95
@d2b94e76
07/17/06 14:30:28 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@f3ef35af
07/16/06 06:17:32 |
Ralf Corsepius |
Require base-gnat if build_infos is true.
4.104.114.84.95
@45fbca9
07/16/06 06:15:33 |
Ralf Corsepius |
Require base-gcc if build_infos is true.
4.104.114.84.95
@c20efa7
07/16/06 06:05:37 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@4edae5cf
07/16/06 06:05:02 |
Ralf Corsepius |
Let *-gcc subpackage require base-package.
4.104.114.84.95
@473fe62
07/16/06 06:03:36 |
Ralf Corsepius |
Remove rpmlint warning on subject.
4.104.114.84.95
@aaf5563
07/16/06 05:05:11 |
Ralf Corsepius |
Remove @build_infos@.
4.104.114.84.95
@116f0fc
07/16/06 04:52:38 |
Ralf Corsepius |
Eliminate @osversion@
4.104.114.84.95
@1ac7a00
07/16/06 04:51:16 |
Ralf Corsepius |
Eliminate @osversion. Hard-code 4.7.
4.104.114.84.95
@26bdc875
07/14/06 06:54:23 |
Ralf Corsepius |
Use <os>/<arch>/Makefile.am in check for all/rtems.
4.104.114.84.95
@cb9c5a8
07/14/06 06:05:04 |
Ralf Corsepius |
include ../gcc.am
4.104.114.84.95
@969f4d5
07/14/06 06:04:51 |
Ralf Corsepius |
New. Split out from i686/Makefile.am
4.104.114.84.95
@7681446
07/14/06 05:19:05 |
Ralf Corsepius |
include ../gcc.am
4.104.114.84.95
@4e7fb7b
07/14/06 05:18:42 |
Ralf Corsepius |
4.104.114.84.95
@984ccfed
07/13/06 20:50:54 |
Joel Sherrill |
Change RTEMS to Joel.
4.104.114.84.95
@460d7e7
07/13/06 16:48:53 |
Joel Sherrill |
2006-07-13 Joel Sherrill <joel@…>
* configure.ac, …
4.104.114.84.95
@6933a4c
07/13/06 12:50:17 |
Ralf Corsepius |
BR: libtermcap-devel for sparc-rtems.
4.104.114.84.95
@d959898
07/12/06 20:48:51 |
Joel Sherrill |
2006-07-12 RTEMS
* rtems4.7/arm/gdb-sources.add, …
4.104.114.84.95
@daf46560
07/11/06 14:46:22 |
Ralf Corsepius |
Sync.
4.104.114.84.95
@0b130fae
07/11/06 14:45:24 |
Ralf Corsepius |
Rebuild with arm-patch applied.
4.104.114.84.95
@dfc207ea
07/11/06 11:33:19 |
Ralf Corsepius |
4.104.114.84.95
@2dd8aa1e
07/11/06 11:32:10 |
Ralf Corsepius |
New. Remove arm/endian.h
4.104.114.84.95
@bfb422d0
07/11/06 07:23:11 |
Ralf Corsepius |
Add short notice
4.104.114.84.95
@46a9d63
07/11/06 03:29:26 |
Ralf Corsepius |
Remove %define build_infos.
4.104.114.84.95
@61d66ffb
07/11/06 03:28:44 |
Ralf Corsepius |
Add binutils-2.17-rtems-20060711.diff.
4.104.114.84.95
@9807f04
07/11/06 03:28:02 |
Ralf Corsepius |
New. m68k/cpu32 patch.
4.104.114.84.95
@a650ebb1
07/09/06 05:22:06 |
Ralf Corsepius |
Sync from freebsd6.1
4.104.114.84.95
@08cbfbce
07/08/06 05:57:32 |
Ralf Corsepius |
Sync.
4.104.114.84.95
@fc4d7d2
07/08/06 05:56:39 |
Ralf Corsepius |
Update to binutils-2.17, gcc-4.1.1
4.104.114.84.95
@a3182b55
07/07/06 09:02:17 |
Ralf Corsepius |
Split out GCC.
4.104.114.84.95
@0767028
07/07/06 09:01:47 |
Ralf Corsepius |
New.
4.104.114.84.95
@80bd514f
07/07/06 07:04:53 |
Ralf Corsepius |
Split out binutils.
4.104.114.84.95
@394555c
07/07/06 07:03:21 |
Ralf Corsepius |
New.
4.104.114.84.95
@0f9fd94f
07/07/06 05:02:39 |
Ralf Corsepius |
New.
4.104.114.84.95
@7df0f40e
07/07/06 04:58:19 |
Ralf Corsepius |
Use relative dirs to automake fragments.
4.104.114.84.95
@6c53b7a
07/07/06 04:57:49 |
Ralf Corsepius |
Add leading blank to version string.
4.104.114.84.95
@7fa51bb
07/07/06 03:35:46 |
Ralf Corsepius |
Use $(srcdir)/patches/*.diff to make make dist happy
4.104.114.84.95
@748c2019
07/07/06 03:34:53 |
Ralf Corsepius |
Bump version.
4.104.114.84.95
@3cf21a25
07/07/06 03:34:06 |
Ralf Corsepius |
Add GCC_OPTS.
4.104.114.84.95
@9e9cf678
07/07/06 03:33:31 |
Ralf Corsepius |
Comment out gdb.
4.104.114.84.95
@a53af803
07/07/06 03:33:00 |
Ralf Corsepius |
Reflex setting up version string has changed in gcc-4.1.0
4.104.114.84.95
@309cd3f0
07/07/06 03:32:13 |
Ralf Corsepius |
Fix stupid typo
4.104.114.84.95
@9b88fb3
07/06/06 13:39:05 |
Ralf Corsepius |
Remove.
4.104.114.84.95
@c484d2ef
07/06/06 13:19:11 |
Ralf Corsepius |
New.
4.104.114.84.95
@05fac2c
07/05/06 15:30:05 |
Ralf Corsepius |
Remove build_infos
4.104.114.84.95
@65e2634
07/05/06 15:29:03 |
Ralf Corsepius |
Move %define _prefix inside of %if/%endif
4.104.114.84.95
@b4c81f7
07/05/06 15:25:32 |
Ralf Corsepius |
Sync.
4.104.114.84.95
@72f8c0c6
07/05/06 14:22:52 |
Ralf Corsepius |
New.
4.104.114.84.95
@9a70e14
07/05/06 14:18:00 |
Ralf Corsepius |
Sync with other rtems4.7 targets.
4.104.114.84.95
@2a9cd34
07/05/06 13:23:37 |
Ralf Corsepius |
Add patches/*.diff to EXTRA_DIST
4.104.114.84.95
@6caac6d
07/05/06 13:21:52 |
Ralf Corsepius |
New.
4.104.114.84.95
@749361d
07/05/06 09:11:23 |
Ralf Corsepius |
Bump version.
4.104.114.84.95
@f82ddbe4
07/05/06 09:10:02 |
Ralf Corsepius |
Eliminate target_os
4.104.114.84.95
@d90e3387
07/05/06 09:08:05 |
Ralf Corsepius |
Remove AC_CANONICAL_TARGET.
4.104.114.84.95
@15fcf913
07/05/06 09:06:24 |
Ralf Corsepius |
Add --enable-targets.
4.104.114.84.95
@4fea6f06
07/05/06 08:55:51 |
Ralf Corsepius |
Add new AC_CONFIG_FILES.
4.104.114.84.95
@4f66134
07/05/06 08:52:45 |
Ralf Corsepius |
Do not subst build_newlib.
4.104.114.84.95
@055f31e5
07/05/06 08:49:34 |
Ralf Corsepius |
Cleanup EXTRA_DIST
4.104.114.84.95
@da0c2a1d
07/05/06 08:48:47 |
Ralf Corsepius |
Remove unused constructs.
4.104.114.84.95
@c77cc1de
07/05/06 08:42:42 |
Ralf Corsepius |
EXTRA_DIST += ../gcc-prep.add
4.104.114.84.95
@3ab5794
07/05/06 08:36:52 |
Ralf Corsepius |
New.
4.104.114.84.95
@db66352
07/05/06 08:34:18 |
Ralf Corsepius |
Remove RPM_OS, rtems/
4.104.114.84.95
@a56b23b
07/05/06 08:24:05 |
Ralf Corsepius |
Add rtems4.7, freebsd6.1
4.104.114.84.95
@da52805
07/05/06 08:22:27 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@bc51e6ab
07/05/06 08:15:58 |
Ralf Corsepius |
Package sources by default.
4.104.114.84.95
@a98d1937
07/05/06 08:05:56 |
Ralf Corsepius |
Sync freebsd*/*/Makefile.ams
4.104.114.84.95
@b7e8b3e
07/05/06 07:38:53 |
Ralf Corsepius |
Reflect changes.
4.104.114.84.95
@1f193a8b
07/05/06 07:37:04 |
Ralf Corsepius |
New.
4.104.114.84.95
@478a318
07/05/06 07:32:19 |
Ralf Corsepius |
Remove.
4.104.114.84.95
@f5638da
07/05/06 07:31:07 |
Ralf Corsepius |
New.
4.104.114.84.95
@120c2980
07/05/06 07:29:55 |
Ralf Corsepius |
Moved from ..
4.104.114.84.95
@88744c95
07/04/06 15:52:53 |
Ralf Corsepius |
Fix ugly typo
4.104.114.84.95
@5727b17
07/04/06 15:41:24 |
Ralf Corsepius |
New.
4.104.114.84.95
@b63e4ba
07/04/06 15:33:56 |
Ralf Corsepius |
New.
4.104.114.84.95
@c34612ce
07/03/06 17:19:32 |
Ralf Corsepius |
Reflect new mkspec.
4.104.114.84.95
@611845b
07/03/06 17:17:20 |
Ralf Corsepius |
Move noinst_DATA, CLEANFILES, EXTRA_DIST to mkspec.am
4.104.114.84.95
@9f5f501f
07/03/06 14:33:13 |
Ralf Corsepius |
Apply SPECSTRIP.
4.104.114.84.95
@ae03064c
07/03/06 14:32:12 |
Ralf Corsepius |
Apply SPECSTRIP. Build f95
4.104.114.84.95
@21920c51
07/03/06 14:27:48 |
Ralf Corsepius |
Apply SPECSTRIP
4.104.114.84.95
@81e7cd80
06/25/06 04:13:33 |
Ralf Corsepius |
Fix typo in previous change
4.104.114.84.95
@ad8e65e
06/25/06 04:08:59 |
Ralf Corsepius |
Bump version
4.104.114.84.95
@b38a934b
06/25/06 03:59:02 |
Ralf Corsepius |
Add SPECSTRIP
4.104.114.84.95
@c57fb63e
06/25/06 03:53:32 |
Ralf Corsepius |
Add specstrip
4.104.114.84.95
@ff5bd63
06/25/06 03:51:37 |
Ralf Corsepius |
New.
4.104.114.84.95
@cdd1564
06/21/06 03:56:24 |
Ralf Corsepius |
GCC-4.1.1 still installs mf-runtime.h to the wrong directory.
4.104.114.84.95
@e8a6236
06/20/06 16:40:41 |
Ralf Corsepius |
Replace %{build_infos} with %build_infos.
4.104.114.84.95
@8c311120
06/20/06 12:09:37 |
Ralf Corsepius |
Use star to untar the sources
4.104.114.84.95
