@bbe338e
04/28/08 14:28:10 |
Ralf Corsepius |
New.
4.104.114.95
@2d29b143
04/28/08 14:15:25 |
Ralf Corsepius |
Abandon gdb-6.7.1.
Use gdb-6.8-rtems4.9-20080428.diff.
4.104.114.95
@d9393d5
04/28/08 13:38:47 |
Ralf Corsepius |
Minor restructurization.
4.104.114.95
@1ef4b6c
04/27/08 05:27:02 |
Ralf Corsepius |
Move %{?dist} to Makefile.am.
4.104.114.95
@42f9ca8b
04/27/08 05:26:37 |
Ralf Corsepius |
Move %{?dist} to Makefile.am. BR: m4 > 1.4.5 for autoconf >= 2.62.
4.104.114.95
@17002619
04/26/08 05:36:01 |
Ralf Corsepius |
Use rtems_api.
4.104.114.95
@02c93793
04/26/08 05:33:04 |
Ralf Corsepius |
Add rtems_api.
4.104.114.95
@dc6771a7
04/25/08 15:19:47 |
Ralf Corsepius |
Remove stray newline.
4.104.114.95
@84f140c
04/21/08 06:01:23 |
Ralf Corsepius |
autoconf-2.62.
4.104.114.95
@2e4550cf
04/21/08 06:01:07 |
Ralf Corsepius |
Use AUTOCONF_VERS.
4.104.114.95
@2dc7132
04/21/08 06:00:44 |
Ralf Corsepius |
Add AUTOCONF_VERS.
4.104.114.95
@ffd1050
03/31/08 04:46:57 |
Ralf Corsepius |
gdb-6.8-rtems4.9-20080331.diff.
4.104.114.95
@eca11fcd
03/31/08 04:45:03 |
Ralf Corsepius |
Bump GDB_RPMREL.
4.104.114.95
@cb63bf0
03/31/08 04:42:24 |
Ralf Corsepius |
BR: %{_host_rpmprefix}readline-devel.
BR: …
4.104.114.95
@f86abfa
03/31/08 04:40:59 |
Ralf Corsepius |
BR: %{_host_rpmprefix}expat-devel.
4.104.114.95
@ad476d6e
03/31/08 04:38:55 |
Ralf Corsepius |
Unconditionally BR: %{_host_rpmprefix}gcc.
4.104.114.95
@23347e95
03/31/08 04:36:55 |
Ralf Corsepius |
Remove readline/configure to force not building the bundled readline …
4.104.114.95
@ef5c018
03/29/08 17:38:22 |
Ralf Corsepius |
gdb-6.8.
4.104.114.95
@a408b33a
03/29/08 04:38:36 |
Ralf Corsepius |
New.
4.104.114.95
@84a996a6
03/29/08 04:38:02 |
Ralf Corsepius |
Add gdb-6.8.
4.104.114.95
@14994204
03/28/08 05:48:42 |
Ralf Corsepius |
Run cygwins libncurses-devel.sh.
4.104.114.95
@9d076cc1
03/28/08 05:44:52 |
Ralf Corsepius |
Add _host_rpmprefix.
4.104.114.95
@db6bd68
03/26/08 17:59:34 |
Ralf Corsepius |
Remove stray blank line.
4.104.114.95
@e50a0b2
03/26/08 07:35:00 |
Ralf Corsepius |
4.104.114.95
@dd56645
03/26/08 06:00:04 |
Ralf Corsepius |
Add CFLAGS_FOR_BUILD.
4.104.114.95
@1f129d87
03/25/08 05:50:32 |
Ralf Corsepius |
Regenerate.
4.104.114.95
@4e78050
03/24/08 17:11:02 |
Ralf Corsepius |
gdb-6.7.1-rtems4.9-20080324.diff, gdb-6.7.1-gdb-6.7.90-config.diff.
4.104.114.95
@063d030
03/24/08 17:08:45 |
Ralf Corsepius |
Bump GDB_RPMREL.
4.104.114.95
@c0141a36
03/24/08 16:02:02 |
Ralf Corsepius |
Add %{_host}-gcc for CdnX
4.104.114.95
@4ae739d
03/24/08 16:00:10 |
Ralf Corsepius |
Add patch1.
4.104.114.95
@afeefd1
03/24/08 15:57:27 |
Ralf Corsepius |
New.
4.104.114.95
@6d71a6f3
03/24/08 15:52:15 |
Ralf Corsepius |
Add _bindir to $PATH.
4.104.114.95
@8338208
03/23/08 10:46:55 |
Ralf Corsepius |
New.
4.104.114.95
@2ebf170
03/22/08 10:32:03 |
Ralf Corsepius |
Fix package name.
4.104.114.95
@66b3cc5
03/22/08 10:28:52 |
Ralf Corsepius |
Add termcap.
4.104.114.95
@cd27172
03/22/08 10:28:05 |
Ralf Corsepius |
New.
4.104.114.95
@adee1dd2
03/22/08 05:51:46 |
Ralf Corsepius |
New.
4.104.114.95
@c75d74ad
03/22/08 05:51:29 |
Ralf Corsepius |
Add readline.
4.104.114.95
@0b80c067
03/22/08 05:34:16 |
Ralf Corsepius |
include ../mpfr.am
4.104.114.95
@3736628
03/22/08 05:33:46 |
Ralf Corsepius |
Remove.
4.104.114.95
@8ef2834b
03/22/08 05:33:24 |
Ralf Corsepius |
New.
4.104.114.95
@1fc6c38
03/22/08 04:57:30 |
Ralf Corsepius |
Split-out mpfr.add ncurses.am zlib.am.
4.104.114.95
@a837ab2
03/22/08 04:56:51 |
Ralf Corsepius |
New (Split-out from i686/Makefile.am).
4.104.114.95
@24c5f7b
03/22/08 04:53:19 |
Ralf Corsepius |
Replaced with ncurses*.add
4.104.114.95
@0c52be2
03/22/08 04:23:14 |
Ralf Corsepius |
Replace libncurses-devel with ncurses.
4.104.114.95
@ee7e515
03/22/08 04:22:24 |
Ralf Corsepius |
New.
4.104.114.95
@b0fc2ec
03/20/08 11:54:54 |
Ralf Corsepius |
Add mpfr.
4.104.114.95
@229f500
03/20/08 11:54:34 |
Ralf Corsepius |
New.
4.104.114.95
@0d4551f2
03/20/08 09:27:08 |
Ralf Corsepius |
Add gmp.
4.104.114.95
@4ae0edf
03/20/08 09:26:44 |
Ralf Corsepius |
New.
4.104.114.95
@f9dff196
03/20/08 07:01:06 |
Ralf Corsepius |
Disable debug_package for cygwin.
4.104.114.95
@310132c
03/20/08 04:04:44 |
Ralf Corsepius |
Add _libdir for cygwin.
4.104.114.95
@28904d41
03/20/08 04:03:34 |
Ralf Corsepius |
Add cygwin optflags hack.
4.104.114.95
@fc7d623
03/20/08 04:02:31 |
Ralf Corsepius |
Use %tar instead of /usr/bin/star.
4.104.114.95
@a0291e05
03/19/08 17:07:56 |
Ralf Corsepius |
Rename Source60 into Source70.
4.104.114.95
@5a63a1e
03/19/08 12:48:48 |
Ralf Corsepius |
Upgrade to cygwin-1.5.25-11, w32api-3.11-1.
4.104.114.95
@5589eac0
03/18/08 06:12:40 |
Ralf Corsepius |
Add %{_bindir} to PATH to cater CdnX-builds.
Set CFLAGS_FOR_BUILD.
4.104.114.95
@7940f96
03/18/08 06:11:17 |
Ralf Corsepius |
Add %{_bindir} to PATH to catter CdnX-builds.
4.104.114.95
@1fb6a01
03/18/08 06:09:42 |
Ralf Corsepius |
BR: @rpmprefix@%{_host}-gcc for CdnX-builds.
4.104.114.95
@18f7bf5a
03/18/08 05:39:21 |
Ralf Corsepius |
Set CFLAGS_FOR_BUILD and CC for CdnX-builds.
4.104.114.95
@368708b
03/18/08 05:37:40 |
Ralf Corsepius |
BR: @rpmprefix@@tool_target@-gcc and @rpmprefix@%{_host}-gcc for …
4.104.114.95
@7da626b
03/18/08 05:36:13 |
Ralf Corsepius |
BR: @rpmprefix@@tool_target@-gcc-c++ for CdnX-builds.
4.104.114.95
@5431a717
03/14/08 16:14:48 |
Ralf Corsepius |
Bump RPMRELS. Sync with rtems-4-8-branch.
4.104.114.95
@d06b28e
03/14/08 16:05:12 |
Ralf Corsepius |
Fix typo.
4.104.114.95
@211c22eb
03/14/08 15:34:59 |
Ralf Corsepius |
Regenerate.
4.104.114.95
@dcd4562c
03/12/08 03:25:39 |
Ralf Corsepius |
Add binutils-patch.
4.104.114.95
@672465e
03/12/08 03:24:11 |
Ralf Corsepius |
New.
4.104.114.95
@44cc441
03/06/08 15:35:51 |
Ralf Corsepius |
Switch back to old GCC_RPMREL versioning scheme.
4.104.114.95
@cd7b673
03/06/08 15:34:40 |
Ralf Corsepius |
Bump version.
4.104.114.95
@6a90a4a
03/06/08 15:33:52 |
Ralf Corsepius |
Use binutils-2.18-rtems4.9-20080211.diff.
4.104.114.95
@d401b14
03/06/08 15:31:20 |
Ralf Corsepius |
New.
4.104.114.95
@fcac0c7
03/06/08 15:30:45 |
Ralf Corsepius |
Preps for gcc-4.3.0 final.
4.104.114.95
@5b5a0dd
03/06/08 05:44:25 |
Ralf Corsepius |
Sync with freebsd7.0.
4.104.114.95
@28c664d1
03/06/08 05:42:56 |
Ralf Corsepius |
Upgrade to binutils-2.18.
Upgrade to gcc-4.2.3.
Activate objc.
4.104.114.95
@f8ee67eb
03/06/08 05:40:03 |
Ralf Corsepius |
Require gmp and mpfr for gcc > 4.2.0 fortran.
4.104.114.95
@0764085
03/05/08 05:58:48 |
Ralf Corsepius |
Sync with the freebsds.
4.104.114.95
@dff01852
03/05/08 03:03:47 |
Ralf Corsepius |
Abandon freebsd6.1.
4.104.114.95
@5aaa497
03/05/08 03:02:54 |
Ralf Corsepius |
Abandon.
4.104.114.95
@6b81c78
03/05/08 03:01:37 |
Ralf Corsepius |
Add freebsd6.3, freebsd7.0
4.104.114.95
@905cbd1
03/05/08 02:47:30 |
Ralf Corsepius |
New.
4.104.114.95
@610c400
03/05/08 02:38:07 |
Ralf Corsepius |
Abandon freebsd6.0
4.104.114.95
@2301a644
03/05/08 02:37:22 |
Ralf Corsepius |
Abandon.
4.104.114.95
@01993e1
03/05/08 02:35:52 |
Ralf Corsepius |
Abandon freebsd5.2
4.104.114.95
@f0c4cf75
03/03/08 07:40:26 |
Ralf Corsepius |
Add *_ARG to getopt.c.
4.104.114.95
@fb974c6
03/03/08 06:36:28 |
Ralf Corsepius |
Regenerate.
4.104.114.95
@d0abb93
03/03/08 06:35:42 |
Ralf Corsepius |
Bump GCC_RPMREL = 10.20080301.2%{?dist}.
4.104.114.95
@84126da9
03/03/08 06:35:07 |
Ralf Corsepius |
Bump GCC_RPMREL = 10.1%{?dist}.
4.104.114.95
@834a670c
03/03/08 06:34:37 |
Ralf Corsepius |
Bump GCC_RPMREL = 7%{?dist}.
4.104.114.95
@94299fd3
03/03/08 06:33:49 |
Ralf Corsepius |
Update to newlib-1.16.0-rtems4.9-20080302.diff.
4.104.114.95
@5df181db
03/03/08 06:14:59 |
Ralf Corsepius |
Add getopt*_r.
4.104.114.95
@e2fe8948
03/02/08 06:52:59 |
Ralf Corsepius |
Regenerate.
4.104.114.95
@3aa2d40
03/02/08 06:51:36 |
Ralf Corsepius |
Update to gcc-4.3.0-RC-20080301.
4.104.114.95
@e122f592
02/27/08 15:31:30 |
Ralf Corsepius |
Regenerate.
4.104.114.95
@26c2bea
02/27/08 15:28:21 |
Ralf Corsepius |
Build bundled mpfr for suse10.2 and suse10.3.
4.104.114.95
@7cfcdc1
02/27/08 14:17:39 |
Ralf Corsepius |
Bump GCC_RPMREL to 10.20080222.1
4.104.114.95
@caeacf7b
02/27/08 14:16:53 |
Ralf Corsepius |
Upgrade to gcc-4.3.0-RC-20080222.
4.104.114.95
@8e6bf2b
02/27/08 14:04:47 |
Ralf Corsepius |
4.104.114.95
@8de5e41
02/27/08 11:59:11 |
Ralf Corsepius |
4.104.114.95
@2561ee9
02/27/08 11:47:30 |
Ralf Corsepius |
4.104.114.95
@069046a7
02/27/08 11:21:58 |
Ralf Corsepius |
4.104.114.95
