@8de2d56
10/19/06 07:58:56 |
Ralf Corsepius |
Bump GCC_RPMREL
4.104.114.84.95
@7dce5bf5
10/19/06 07:57:29 |
Ralf Corsepius |
rtems-4.7-h8300-rtems4.7-gcc-4.1.1-5
4.104.114.84.95
@5b5e9031
10/19/06 07:56:52 |
Ralf Corsepius |
rtems-4.7-avr-rtems4.7-gcc-4.0.3-2
4.104.114.84.95
@a59a751b
10/16/06 14:55:56 |
Ralf Corsepius |
2006-10-16 Ralf Corsépius <ralf.corsepius@…>
* configure.ac: …
4.104.114.84.95
@e337b49
10/16/06 11:14:07 |
Ralf Corsepius |
4.104.114.84.95
@4bbd0b4
09/13/06 11:50:03 |
Ralf Corsepius |
New.
4.104.114.84.95
@9cb14887
09/08/06 20:33:52 |
Joel Sherrill |
New file.
4.104.114.84.95
@4b88b73
09/03/06 10:50:36 |
Chris Johns |
Default to not building bsps. Too many problems.
4.104.114.84.95
@896247d
08/27/06 12:46:13 |
Chris Johns |
Handle the noarch rpms. Dump the file list.
4.104.114.84.95
@2ba11f8
08/27/06 12:45:28 |
Chris Johns |
Set the prefix into the MSYS fstab, This is a hack but it works.
4.104.114.84.95
@e25ff2c
08/27/06 12:44:47 |
Chris Johns |
Ignore more build output files.
4.104.114.84.95
@5ceb567e
08/27/06 12:44:08 |
Chris Johns |
Build the autotools for each RTEMS target.
4.104.114.84.95
@4f5d2dfc
08/27/06 12:43:13 |
Chris Johns |
Move the target list into a shared file.
4.104.114.84.95
@eb6276b
08/23/06 03:53:18 |
Ralf Corsepius |
2006-08-23 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@99e02e7
08/23/06 03:52:40 |
Ralf Corsepius |
Add gcc-4.0.3
4.104.114.84.95
@7989747
08/23/06 03:45:43 |
Ralf Corsepius |
4.104.114.84.95
@d867214
08/22/06 12:08:05 |
Chris Johns |
2006-08-22 Chris Johns <chrisj@…>
4.104.114.84.95
@f7891617
08/22/06 11:57:36 |
Chris Johns |
Add the 4.0.3 patch.
4.104.114.84.95
@e5e88aa
08/22/06 11:57:03 |
Chris Johns |
The .exe for the versioned execuable for MinGW.
4.104.114.84.95
@ef50593
08/22/06 11:41:51 |
Chris Johns |
Change the rpm to use the version.
4.104.114.84.95
@5428a43e
08/22/06 11:41:31 |
Chris Johns |
Add a version for rtems.
Add checking messages.
4.104.114.84.95
@a2d7c41
08/21/06 22:29:53 |
Chris Johns |
Move the build to host tools out of the target root,
4.104.114.84.95
@a94075b
08/21/06 14:38:33 |
Joel Sherrill |
2006-08-21 Joel Sherrill <joel@…>
4.104.114.84.95
@7272828
08/20/06 23:02:44 |
Chris Johns |
Fix the path in the batch file to the installed path.
4.104.114.84.95
@8a1c14b
08/18/06 11:28:17 |
Chris Johns |
Renamed the spec file.
4.104.114.84.95
@0e872e6a
08/18/06 11:27:56 |
Chris Johns |
Updated the specs file.
4.104.114.84.95
@0e61a81
08/17/06 05:51:36 |
Chris Johns |
Move to rtems.specs.in.
4.104.114.84.95
@01f1b60c
08/17/06 05:43:00 |
Chris Johns |
Add the rtemsrpms package to RTEMS.
4.104.114.84.95
@67eede5
08/16/06 07:54:10 |
Ralf Corsepius |
Pickup common.add from $(top_srcdir).
4.104.114.84.95
@ea3839aa
08/15/06 03:38:29 |
Chris Johns |
Ignore the build output.
4.104.114.84.95
@6ed42ac
08/12/06 06:04:05 |
Ralf Corsepius |
binutils-2.17-rtems-20060812.diff
4.104.114.84.95
@070cf12
08/12/06 06:03:27 |
Ralf Corsepius |
Remove (Merged into binutils-2.17-rtems-20060812.diff).
4.104.114.84.95
@d218a83
08/12/06 06:02:29 |
Ralf Corsepius |
Update from binutils-2.17_branch.
Merge bfin patch.
4.104.114.84.95
@056498a7
08/12/06 05:07:04 |
Ralf Corsepius |
Add bfin
4.104.114.84.95
@a2ced07
08/12/06 05:05:52 |
Ralf Corsepius |
Reset RPMRELS.
4.104.114.84.95
@6d7e836
08/11/06 21:37:40 |
Joel Sherrill |
2006-08-11 Joel Sherrill <joel@…>
* configure.ac, …
4.104.114.84.95
@1a39b67
08/10/06 07:04:25 |
Ralf Corsepius |
Bump RPMREL.
4.104.114.84.95
@3b97526c
08/09/06 23:06:58 |
Joel Sherrill |
2006-08-09 Joel Sherrill <joel@…>
* .cvsignore: Add INSTALL.
4.104.114.84.95
@a819821
08/07/06 07:30:45 |
Chris Johns |
2006-08-07 Chris Johns <chrisj@…>
* build.sh: Log …
4.104.114.84.95
@b7c9b29
08/07/06 07:03:13 |
Chris Johns |
Log the script command lines.
4.104.114.84.95
@72eb02e
08/07/06 07:02:41 |
Chris Johns |
Updated to handle a different build processor to a i686.
4.104.114.84.95
@61e5a32
08/07/06 07:01:54 |
Chris Johns |
Removed the tool version as Ralf has removed it from the rpms.
4.104.114.84.95
@979f36f
08/05/06 04:28:22 |
Chris Johns |
Update the release tag.
4.104.114.84.95
@5adb73a
08/04/06 09:50:08 |
Chris Johns |
Updated to support the new installer.
4.104.114.84.95
@1a768ef
08/04/06 09:49:35 |
Chris Johns |
Updated to use common rather than base. More rpmbuild work arounds.
4.104.114.84.95
@808db8e
08/04/06 09:48:38 |
Chris Johns |
Fix the return code when used with tee.
4.104.114.84.95
@5aafd7a
08/04/06 09:47:54 |
Chris Johns |
Updated hello screen.
4.104.114.84.95
@b4723b0d
08/04/06 09:47:17 |
Chris Johns |
Generate the batch files when installing.
4.104.114.84.95
@7eb4d4b0
08/04/06 09:46:14 |
Chris Johns |
Convert to DOS format.
4.104.114.84.95
@6bdebc3a
08/03/06 04:29:22 |
Ralf Corsepius |
Bump version.
4.104.114.84.95
@c1a25af9
08/03/06 04:28:43 |
Ralf Corsepius |
Use hard-coded %release.
4.104.114.84.95
@5b151f87
08/03/06 03:57:47 |
Ralf Corsepius |
4.104.114.84.95
@e85211e
08/03/06 02:50:36 |
Ralf Corsepius |
Remove (Obsolete)
4.104.114.84.95
@52053484
08/03/06 02:48:31 |
Ralf Corsepius |
Remove
4.104.114.84.95
@3219756b
08/03/06 02:47:53 |
Ralf Corsepius |
Update to using newlib-1.14.0-rtems-20060707.diff
4.104.114.84.95
@300dce7
08/02/06 03:39:00 |
Ralf Corsepius |
Bump version.
4.104.114.84.95
@d9e9a5a
08/02/06 03:37:34 |
Ralf Corsepius |
Use further shared spec-fragments.
4.104.114.84.95
@6c873da
08/02/06 03:36:22 |
Ralf Corsepius |
Split out target-autoconf.add
4.104.114.84.95
@a5b38ea
08/02/06 03:36:11 |
Ralf Corsepius |
Split out target-automake.add
4.104.114.84.95
@e5f924d
08/02/06 03:35:10 |
Ralf Corsepius |
New.
4.104.114.84.95
@6d05356
07/25/06 16:16:07 |
Ralf Corsepius |
Add objc
4.104.114.84.95
@8eb71ea4
07/25/06 16:11:49 |
Ralf Corsepius |
Remove sed -e /[@]tool_target[@]-newlib/d"
4.104.114.84.95
@eca59879
07/25/06 16:11:21 |
Ralf Corsepius |
Remove blank lines.
4.104.114.84.95
@e8b0467
07/25/06 16:10:46 |
Ralf Corsepius |
More %if %build_newlib blocks.
4.104.114.84.95
@6cbe966
07/25/06 14:18:12 |
Ralf Corsepius |
New.
4.104.114.84.95
@f391f6a
07/25/06 13:15:18 |
Ralf Corsepius |
Fix rpmgroup.
Cosmetics.
4.104.114.84.95
@41e4caf
07/25/06 11:47:04 |
Ralf Corsepius |
Upgrade to gcc-3.4.4-2, cygwin-1.5.21-1
4.104.114.84.95
@c45ec73
07/24/06 09:01:22 |
Ralf Corsepius |
Bump version.
Add AC_CONFIG_FILES([autotools/Makefile])
4.104.114.84.95
@9b966c30
07/24/06 08:57:02 |
Ralf Corsepius |
Add autotools.
4.104.114.84.95
@35ed8723
07/24/06 08:56:11 |
Ralf Corsepius |
Add provisory/preliminary autotools support.
4.104.114.84.95
@43fe4445
07/24/06 08:54:04 |
Ralf Corsepius |
Cleanup.
Add note on autotools.
4.104.114.84.95
@a26364de
07/24/06 08:51:15 |
Ralf Corsepius |
New.
4.104.114.84.95
@262bea9
07/24/06 08:50:28 |
Ralf Corsepius |
Add Chris and Joel.
4.104.114.84.95
@c791b9d
07/24/06 08:48:26 |
Ralf Corsepius |
2006-07-23 Rename "*-base-*" packages into <tool>-common.
Rename …
4.104.114.84.95
@a61e8325
07/23/06 14:24:25 |
Ralf Corsepius |
Bump version
4.104.114.84.95
@5e58aa92
07/23/06 14:23:21 |
Ralf Corsepius |
Minor fixes.
4.104.114.84.95
@1528803c
07/23/06 14:22:37 |
Ralf Corsepius |
Let rpm Obsolete < %{binutils_version}-%{release}
4.104.114.84.95
@6255333
07/23/06 14:21:26 |
Ralf Corsepius |
Rename *base packages into gcc*-common gcc/base*.add
4.104.114.84.95
@f789c8a2
07/23/06 14:20:22 |
Ralf Corsepius |
Rename *gfortran …
4.104.114.84.95
@6f60abde
07/23/06 14:19:57 |
Ralf Corsepius |
Rename *g77 into …
4.104.114.84.95
@6d206e16
07/23/06 14:19:14 |
Ralf Corsepius |
Rename *objc into …
4.104.114.84.95
@bf7b460
07/23/06 14:18:56 |
Ralf Corsepius |
Rename *gcj into …
4.104.114.84.95
@45c41764
07/23/06 14:18:39 |
Ralf Corsepius |
Rename *gnat into …
4.104.114.84.95
@48b256c3
07/23/06 14:18:24 |
Ralf Corsepius |
Rename *c++ into …
4.104.114.84.95
@793bad2
07/23/06 14:17:48 |
Ralf Corsepius |
4.104.114.84.95
@e41b8b7
07/23/06 14:16:21 |
Ralf Corsepius |
Let rpm Obsolete < %{gdb_version}-%{release}
4.104.114.84.95
@9a626a3
07/23/06 14:14:55 |
Ralf Corsepius |
Add --enable-threads.
4.104.114.84.95
@aec66f3
07/23/06 05:36:19 |
Ralf Corsepius |
Elminate blank lines.
4.104.114.84.95
@332fd2a
07/22/06 07:23:51 |
Chris Johns |
Changes to the installer and an extra script to build all.
4.104.114.84.95
@e302e959
07/22/06 05:05:22 |
Ralf Corsepius |
Eliminate white spaces.
4.104.114.84.95
@385f81c
07/22/06 02:40:16 |
Ralf Corsepius |
Rename rtems4.7-base-gdb into gdb-common
4.104.114.84.95
@65f75598
07/21/06 15:55:08 |
Ralf Corsepius |
Rename rtems4.7-base-binutils into binutils-common
4.104.114.84.95
@7bcdece
07/21/06 05:02:12 |
Ralf Corsepius |
Remove --sources (Unused)
4.104.114.84.95
@a52dc937
07/21/06 04:51:54 |
Ralf Corsepius |
Add %{gcclib}/@tool_target@/%{gcc_version}/include/ssp
4.104.114.84.95
@0c8a556
07/21/06 04:38:56 |
Ralf Corsepius |
Make install-patches more verbose.
4.104.114.84.95
@e8ba788
07/21/06 04:36:14 |
Ralf Corsepius |
Add install-patches.
4.104.114.84.95
@654cb682
07/21/06 04:29:02 |
Ralf Corsepius |
Add objc.
4.104.114.84.95
@83fc6ac
07/21/06 00:13:42 |
Chris Johns |
2006-07-21 Chris Johns <chrisj@…>
* build-rpms.sh: Add the …
4.104.114.84.95
@ed70a496
07/21/06 00:11:54 |
Chris Johns |
Add the build-rpms.sh here until moved to crossrpms.
4.104.114.84.95
@7cadb8e
07/21/06 00:07:45 |
Chris Johns |
Add the support files.
4.104.114.84.95
