Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/contrib
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @3219756b   08/03/06 02:47:53 Ralf Corsepius Update to using newlib-1.14.0-rtems-20060707.diff 4.104.114.84.95
(edit) @300dce7   08/02/06 03:39:00 Ralf Corsepius Bump version. 4.104.114.84.95
(edit) @d9e9a5a   08/02/06 03:37:34 Ralf Corsepius Use further shared spec-fragments. 4.104.114.84.95
(edit) @6c873da   08/02/06 03:36:22 Ralf Corsepius Split out target-autoconf.add 4.104.114.84.95
(edit) @a5b38ea   08/02/06 03:36:11 Ralf Corsepius Split out target-automake.add 4.104.114.84.95
(edit) @e5f924d   08/02/06 03:35:10 Ralf Corsepius New. 4.104.114.84.95
(edit) @6d05356   07/25/06 16:16:07 Ralf Corsepius Add objc 4.104.114.84.95
(edit) @8eb71ea4   07/25/06 16:11:49 Ralf Corsepius Remove sed -e /[@]tool_target[@]-newlib/d" 4.104.114.84.95
(edit) @eca59879   07/25/06 16:11:21 Ralf Corsepius Remove blank lines. 4.104.114.84.95
(edit) @e8b0467   07/25/06 16:10:46 Ralf Corsepius More %if %build_newlib blocks. 4.104.114.84.95
(edit) @6cbe966   07/25/06 14:18:12 Ralf Corsepius New. 4.104.114.84.95
(edit) @f391f6a   07/25/06 13:15:18 Ralf Corsepius Fix rpmgroup. Cosmetics. 4.104.114.84.95
(edit) @41e4caf   07/25/06 11:47:04 Ralf Corsepius Upgrade to gcc-3.4.4-2, cygwin-1.5.21-1 4.104.114.84.95
(edit) @c45ec73   07/24/06 09:01:22 Ralf Corsepius Bump version. Add AC_CONFIG_FILES([autotools/Makefile]) 4.104.114.84.95
(edit) @9b966c30   07/24/06 08:57:02 Ralf Corsepius Add autotools. 4.104.114.84.95
(edit) @35ed8723   07/24/06 08:56:11 Ralf Corsepius Add provisory/preliminary autotools support. 4.104.114.84.95
(edit) @43fe4445   07/24/06 08:54:04 Ralf Corsepius Cleanup. Add note on autotools. 4.104.114.84.95
(edit) @a26364de   07/24/06 08:51:15 Ralf Corsepius New. 4.104.114.84.95
(edit) @262bea9   07/24/06 08:50:28 Ralf Corsepius Add Chris and Joel. 4.104.114.84.95
(edit) @c791b9d   07/24/06 08:48:26 Ralf Corsepius 2006-07-23 Rename "*-base-*" packages into <tool>-common. Rename … 4.104.114.84.95
(edit) @a61e8325   07/23/06 14:24:25 Ralf Corsepius Bump version 4.104.114.84.95
(edit) @5e58aa92   07/23/06 14:23:21 Ralf Corsepius Minor fixes. 4.104.114.84.95
(edit) @1528803c   07/23/06 14:22:37 Ralf Corsepius Let rpm Obsolete < %{binutils_version}-%{release} 4.104.114.84.95
(edit) @6255333   07/23/06 14:21:26 Ralf Corsepius Rename *base packages into gcc*-common gcc/base*.add 4.104.114.84.95
(edit) @f789c8a2   07/23/06 14:20:22 Ralf Corsepius Rename *base packages into gcc*-common gcc/base*.add Rename *gfortran … 4.104.114.84.95
(edit) @6f60abde   07/23/06 14:19:57 Ralf Corsepius Rename *base packages into gcc*-common gcc/base*.add Rename *g77 into … 4.104.114.84.95
(edit) @6d206e16   07/23/06 14:19:14 Ralf Corsepius Rename *base packages into gcc*-common gcc/base*.add Rename *objc into … 4.104.114.84.95
(edit) @bf7b460   07/23/06 14:18:56 Ralf Corsepius Rename *base packages into gcc*-common gcc/base*.add Rename *gcj into … 4.104.114.84.95
(edit) @45c41764   07/23/06 14:18:39 Ralf Corsepius Rename *base packages into gcc*-common gcc/base*.add Rename *gnat into … 4.104.114.84.95
(edit) @48b256c3   07/23/06 14:18:24 Ralf Corsepius Rename *base packages into gcc*-common gcc/base*.add Rename *c++ into … 4.104.114.84.95
(edit) @793bad2   07/23/06 14:17:48 Ralf Corsepius Rename *base packages into gcc*-common 4.104.114.84.95
(edit) @e41b8b7   07/23/06 14:16:21 Ralf Corsepius Let rpm Obsolete < %{gdb_version}-%{release} 4.104.114.84.95
(edit) @9a626a3   07/23/06 14:14:55 Ralf Corsepius Add --enable-threads. 4.104.114.84.95
(edit) @aec66f3   07/23/06 05:36:19 Ralf Corsepius Elminate blank lines. 4.104.114.84.95
(edit) @332fd2a   07/22/06 07:23:51 Chris Johns Changes to the installer and an extra script to build all. 4.104.114.84.95
(edit) @e302e959   07/22/06 05:05:22 Ralf Corsepius Eliminate white spaces. 4.104.114.84.95
(edit) @385f81c   07/22/06 02:40:16 Ralf Corsepius Rename rtems4.7-base-gdb into gdb-common 4.104.114.84.95
(edit) @65f75598   07/21/06 15:55:08 Ralf Corsepius Rename rtems4.7-base-binutils into binutils-common 4.104.114.84.95
(edit) @7bcdece   07/21/06 05:02:12 Ralf Corsepius Remove --sources (Unused) 4.104.114.84.95
(edit) @a52dc937   07/21/06 04:51:54 Ralf Corsepius Add %{gcclib}/@tool_target@/%{gcc_version}/include/ssp 4.104.114.84.95
(edit) @0c8a556   07/21/06 04:38:56 Ralf Corsepius Make install-patches more verbose. 4.104.114.84.95
(edit) @e8ba788   07/21/06 04:36:14 Ralf Corsepius Add install-patches. 4.104.114.84.95
(edit) @654cb682   07/21/06 04:29:02 Ralf Corsepius Add objc. 4.104.114.84.95
(edit) @83fc6ac   07/21/06 00:13:42 Chris Johns 2006-07-21 Chris Johns <chrisj@…> * build-rpms.sh: Add the … 4.104.114.84.95
(edit) @ed70a496   07/21/06 00:11:54 Chris Johns Add the build-rpms.sh here until moved to crossrpms. 4.104.114.84.95
(edit) @7cadb8e   07/21/06 00:07:45 Chris Johns Add the support files. 4.104.114.84.95
(edit) @be77d1f   07/21/06 00:04:20 Chris Johns Add NSIS installer support for MinGW. 4.104.114.84.95
(edit) @44a6dcc   07/20/06 23:32:32 Chris Johns Use gcc-core-4.1.1-rtems-20060720.diff. 4.104.114.84.95
(edit) @c29d0a21   07/20/06 05:17:36 Ralf Corsepius Remove $build_infos. Add SPECSTRIP_OPTS. 4.104.114.84.95
(edit) @8747e99a   07/20/06 05:16:29 Ralf Corsepius Add --enable/disable-infos. 4.104.114.84.95
(edit) @40459fbf   07/20/06 05:15:47 Ralf Corsepius Add SPECSTRIP_OPTS. 4.104.114.84.95
(edit) @a1abfb95   07/20/06 00:40:11 Chris Johns 2006-07-19 Chris Johns <chrisj@…> * … 4.104.114.84.95
(edit) @45def1d   07/19/06 21:51:39 Chris Johns Added patch to fix GCC bug PR28400. 4.104.114.84.95
(edit) @d4609b2   07/18/06 07:26:10 Ralf Corsepius Use newlib-1.14.0-rtems-20060707.diff 4.104.114.84.95
(edit) @22f187d0   07/18/06 07:25:19 Ralf Corsepius Fix setting up targets for solaris* 4.104.114.84.95
(edit) @4557d3c   07/18/06 02:32:19 Ralf Corsepius Remove infos and man7 if !%build_infos. 4.104.114.84.95
(edit) @c10a31b   07/17/06 15:23:04 Ralf Corsepius Require: base packages iff %build_infos 4.104.114.84.95
(edit) @176aca7   07/17/06 15:22:05 Ralf Corsepius Require: base-g77 iff %build_infos 4.104.114.84.95
(edit) @f69ae2e   07/17/06 15:21:33 Ralf Corsepius Require: base-gfortran iff %build_infos 4.104.114.84.95
(edit) @d2b94e76   07/17/06 14:30:28 Ralf Corsepius Cosmetics. 4.104.114.84.95
(edit) @f3ef35af   07/16/06 06:17:32 Ralf Corsepius Require base-gnat if build_infos is true. 4.104.114.84.95
(edit) @45fbca9   07/16/06 06:15:33 Ralf Corsepius Require base-gcc if build_infos is true. 4.104.114.84.95
(edit) @c20efa7   07/16/06 06:05:37 Ralf Corsepius Cosmetics. 4.104.114.84.95
(edit) @4edae5cf   07/16/06 06:05:02 Ralf Corsepius Let *-gcc subpackage require base-package. 4.104.114.84.95
(edit) @473fe62   07/16/06 06:03:36 Ralf Corsepius Remove rpmlint warning on subject. 4.104.114.84.95
(edit) @aaf5563   07/16/06 05:05:11 Ralf Corsepius Remove @build_infos@. 4.104.114.84.95
(edit) @116f0fc   07/16/06 04:52:38 Ralf Corsepius Eliminate @osversion@ 4.104.114.84.95
(edit) @1ac7a00   07/16/06 04:51:16 Ralf Corsepius Eliminate @osversion. Hard-code 4.7. 4.104.114.84.95
(edit) @26bdc875   07/14/06 06:54:23 Ralf Corsepius Use <os>/<arch>/Makefile.am in check for all/rtems. 4.104.114.84.95
(edit) @cb9c5a8   07/14/06 06:05:04 Ralf Corsepius include ../gcc.am 4.104.114.84.95
(edit) @969f4d5   07/14/06 06:04:51 Ralf Corsepius New. Split out from i686/Makefile.am 4.104.114.84.95
(edit) @7681446   07/14/06 05:19:05 Ralf Corsepius include ../gcc.am 4.104.114.84.95
(edit) @4e7fb7b   07/14/06 05:18:42 Ralf Corsepius New. Split out from i686/Makefile.am 4.104.114.84.95
(edit) @984ccfed   07/13/06 20:50:54 Joel Sherrill Change RTEMS to Joel. 4.104.114.84.95
(edit) @460d7e7   07/13/06 16:48:53 Joel Sherrill 2006-07-13 Joel Sherrill <joel@…> * configure.ac, … 4.104.114.84.95
(edit) @6933a4c   07/13/06 12:50:17 Ralf Corsepius BR: libtermcap-devel for sparc-rtems. 4.104.114.84.95
(edit) @d959898   07/12/06 20:48:51 Joel Sherrill 2006-07-12 RTEMS * rtems4.7/arm/gdb-sources.add, … 4.104.114.84.95
(edit) @daf46560   07/11/06 14:46:22 Ralf Corsepius Sync. 4.104.114.84.95
(edit) @0b130fae   07/11/06 14:45:24 Ralf Corsepius Rebuild with arm-patch applied. 4.104.114.84.95
(edit) @dfc207ea   07/11/06 11:33:19 Ralf Corsepius Use newlib-1.14.0-rtems-20060707.diff 4.104.114.84.95
(edit) @2dd8aa1e   07/11/06 11:32:10 Ralf Corsepius New. Remove arm/endian.h 4.104.114.84.95
(edit) @bfb422d0   07/11/06 07:23:11 Ralf Corsepius Add short notice 4.104.114.84.95
(edit) @46a9d63   07/11/06 03:29:26 Ralf Corsepius Remove %define build_infos. 4.104.114.84.95
(edit) @61d66ffb   07/11/06 03:28:44 Ralf Corsepius Add binutils-2.17-rtems-20060711.diff. 4.104.114.84.95
(edit) @9807f04   07/11/06 03:28:02 Ralf Corsepius New. m68k/cpu32 patch. 4.104.114.84.95
(edit) @a650ebb1   07/09/06 05:22:06 Ralf Corsepius Sync from freebsd6.1 4.104.114.84.95
(edit) @08cbfbce   07/08/06 05:57:32 Ralf Corsepius Sync. 4.104.114.84.95
(edit) @fc4d7d2   07/08/06 05:56:39 Ralf Corsepius Update to binutils-2.17, gcc-4.1.1 4.104.114.84.95
(edit) @a3182b55   07/07/06 09:02:17 Ralf Corsepius Split out GCC. 4.104.114.84.95
(edit) @0767028   07/07/06 09:01:47 Ralf Corsepius New. 4.104.114.84.95
(edit) @80bd514f   07/07/06 07:04:53 Ralf Corsepius Split out binutils. 4.104.114.84.95
(edit) @394555c   07/07/06 07:03:21 Ralf Corsepius New. 4.104.114.84.95
(edit) @0f9fd94f   07/07/06 05:02:39 Ralf Corsepius New. 4.104.114.84.95
(edit) @7df0f40e   07/07/06 04:58:19 Ralf Corsepius Use relative dirs to automake fragments. 4.104.114.84.95
(edit) @6c53b7a   07/07/06 04:57:49 Ralf Corsepius Add leading blank to version string. 4.104.114.84.95
(edit) @7fa51bb   07/07/06 03:35:46 Ralf Corsepius Use $(srcdir)/patches/*.diff to make make dist happy 4.104.114.84.95
(edit) @748c2019   07/07/06 03:34:53 Ralf Corsepius Bump version. 4.104.114.84.95
(edit) @3cf21a25   07/07/06 03:34:06 Ralf Corsepius Add GCC_OPTS. 4.104.114.84.95
(edit) @9e9cf678   07/07/06 03:33:31 Ralf Corsepius Comment out gdb. 4.104.114.84.95
(edit) @a53af803   07/07/06 03:33:00 Ralf Corsepius Reflex setting up version string has changed in gcc-4.1.0 4.104.114.84.95
