@0b4445f
10/10/08 02:34:06 |
Ralf Corsepius |
New.
4.104.115
@945f9df9
10/10/08 02:33:18 |
Ralf Corsepius |
Regenerate.
4.104.115
@1171c46
10/10/08 02:32:36 |
Ralf Corsepius |
binutils-2.18.93-rtems4.10-20081010.diff.
4.104.115
@c81b995
10/10/08 02:30:19 |
Ralf Corsepius |
BINUTILS_VERS = 2.18.93
4.104.115
@c41d6b4
10/04/08 05:01:08 |
Ralf Corsepius |
Regenerate.
4.104.115
@e7910cd7
10/04/08 05:00:16 |
Ralf Corsepius |
Update to binutils-2.18.92.
4.104.115
@1547cff6
10/04/08 04:58:19 |
Ralf Corsepius |
Update to 2.18.92.
4.104.115
@a5ece1a5
10/03/08 06:18:38 |
Ralf Corsepius |
Regenerate.
4.104.115
@2abe16dd
10/03/08 06:18:17 |
Ralf Corsepius |
New.
4.104.115
@933e34a6
10/03/08 06:17:04 |
Ralf Corsepius |
GCC_RPMREL = 6. Disable cxx, infos.
4.104.115
@bba70f4
10/03/08 06:16:38 |
Ralf Corsepius |
GCC_RPMREL = 6.
4.104.115
@dc7c0df
10/03/08 06:15:57 |
Ralf Corsepius |
gcc-core-4.3.2-rtems4.10-20081003.diff, …
4.104.115
@525b90e5
10/03/08 06:14:31 |
Ralf Corsepius |
Add m32r/m32c. Undef ATTRIBUTE_IMPURE_PTR for mips only.
4.104.115
@f4bacae
10/03/08 06:13:17 |
Ralf Corsepius |
Add m32r/m32c.
4.104.115
@b38ae26b
10/03/08 03:41:40 |
Ralf Corsepius |
Regenerate.
4.104.115
@df339c2
10/03/08 03:40:27 |
Ralf Corsepius |
gdb-6.8-rtems4.10-20081003.diff.
Abandon _without_sources.
4.104.115
@30e604d
10/03/08 03:39:44 |
Ralf Corsepius |
Bump GDB_RPMREL.
4.104.115
@241aa252
10/03/08 03:35:23 |
Ralf Corsepius |
Add m32r-*-rtems*, m32c-*-rtems*.
4.104.115
@3d0a3acb
10/03/08 02:59:19 |
Ralf Corsepius |
Regenerate.
4.104.115
@e0c7ecf
10/03/08 02:58:08 |
Ralf Corsepius |
Build binutils infos.
4.104.115
@175b145c
10/03/08 02:55:10 |
Ralf Corsepius |
New.
4.104.115
@b2fd3b7
10/03/08 02:54:04 |
Ralf Corsepius |
Add m32r, m32c.
4.104.115
@24d6e0b
10/03/08 02:53:26 |
Ralf Corsepius |
Bump BINUTILS_RPMREL
4.104.115
@7d28f71
10/03/08 02:52:48 |
Ralf Corsepius |
Add binutils-2.18.91-rtems4.10-20081003.diff
4.104.115
@943b7d9
10/01/08 17:17:22 |
Joel Sherrill |
2008-10-01 Joel Sherrill <joel.sherrill@…>
4.104.115
@d45dff4
09/25/08 18:28:24 |
Joel Sherrill |
2008-09-25 Joel Sherrill <joel.sherrill@…>
4.104.115
@858407d
09/25/08 10:44:29 |
Ralf Corsepius |
newlib-1.16.0-rtems4.10-20080925.diff.
4.104.115
@190e9d5
09/25/08 10:40:49 |
Ralf Corsepius |
Undef ATTRIBUTE_IMPURE_PTR.
4.104.115
@641ef00
09/18/08 03:51:34 |
Ralf Corsepius |
Remove *.orig files having crept into patch.
4.104.115
@aa2d0450
09/17/08 15:26:36 |
Ralf Corsepius |
binutils-2.18.91.
4.104.115
@9a5e29b
09/17/08 14:38:54 |
Ralf Corsepius |
Switch to gdb-6.8-rtems4.10-20080917.diff.
4.104.115
@aa9a6dc
09/17/08 14:34:15 |
Ralf Corsepius |
Add patch from http://sourceware.org/ml/gdb-patches/2008-02/msg00472.html
4.104.115
@f63871e3
09/17/08 14:02:49 |
Ralf Corsepius |
Switch to gcc-core-4.3.2-rtems4.10-20080917.diff.
4.104.115
@c490a1a3
09/17/08 14:01:23 |
Ralf Corsepius |
Remove MULTILIB_EXTRA_OPTS from gcc/config/rs6000/t-rtems.
4.104.115
@fd92869
09/12/08 07:48:11 |
Ralf Corsepius |
Regenerate.
4.104.115
@c42b2459
09/12/08 07:47:01 |
Ralf Corsepius |
Bump GDB_RPMREL.
4.104.115
@0558e58
09/12/08 07:46:06 |
Ralf Corsepius |
Update.
4.104.115
@10d4919
09/12/08 07:43:34 |
Ralf Corsepius |
Remove (unused).
4.104.115
@ebe7bf28
09/12/08 06:44:19 |
Ralf Corsepius |
Merge-in Joels gdb-6.8-sysv-ipc-1.diff.
4.104.115
@3e256081
09/11/08 15:57:25 |
Ralf Corsepius |
GCC_RPMREL = 3 (Rebuild against binutils-2.18.90).
4.104.115
@518adaf
09/11/08 15:56:31 |
Ralf Corsepius |
Abandon gcc-4.3.1.
4.104.115
@6176ff0
09/11/08 15:53:10 |
Ralf Corsepius |
Remove (unused).
4.104.115
@04e8c69
09/11/08 12:00:46 |
Ralf Corsepius |
Upgrade to binutils-2.18.90.
4.104.115
@03a85d32
09/10/08 20:15:26 |
Ralf Corsepius |
Remove.
4.104.115
@93e1140
09/10/08 20:13:03 |
Ralf Corsepius |
Upgrade autoconf to 2.63.
4.104.115
@64c5bec5
09/10/08 20:12:00 |
Ralf Corsepius |
Bump RTEMS_API to 4.10.
4.104.115
@44c2d06d
09/10/08 20:09:27 |
Ralf Corsepius |
Remove freebsd6.2, freebsd6.3, rtems4.9.
4.104.115
@9d0c693
09/10/08 20:08:31 |
Ralf Corsepius |
Remove.
4.104.115
@7af2a17
09/08/08 13:32:05 |
Joel Sherrill |
2008-09-08 Joel Sherrill <joel.sherrill@…>
* AUTHORS: …
4.104.114.95
@c68637e
09/08/08 13:31:59 |
Joel Sherrill |
* AUTHORS, …
4.104.114.95
@2528c92
09/08/08 10:04:49 |
Ralf Corsepius |
Add --enable-newlib-io-c99-formats.
4.104.114.95
@9589c665
09/03/08 22:48:11 |
Ralf Corsepius |
Regenerate.
4.104.114.95
@d043ebc2
09/03/08 22:39:16 |
Ralf Corsepius |
Sync with rtems-4.10.
4.104.114.95
@3f01023
09/03/08 22:36:35 |
Ralf Corsepius |
New.
4.104.114.95
@d5982b4
09/03/08 09:29:30 |
Ralf Corsepius |
Remove.
4.104.114.95
@d8a213b2
08/28/08 19:54:29 |
Ralf Corsepius |
Regenerate.
4.104.114.95
@e90124e
08/28/08 19:53:37 |
Ralf Corsepius |
Bump GCC_RPMREL.
4.104.114.95
@183e5cf
08/28/08 14:13:55 |
Ralf Corsepius |
Regenerate.
4.104.114.95
@c9ef27b
08/28/08 14:12:42 |
Ralf Corsepius |
Add rtems4.10.
4.104.114.95
@68e6a18d
08/28/08 14:11:48 |
Ralf Corsepius |
Bump BINUTILS_RPMREL.
4.104.114.95
@2fb65fbf
08/28/08 14:08:37 |
Ralf Corsepius |
gcc-4.3.2
4.104.114.95
@d5c49aa3
08/28/08 14:07:19 |
Ralf Corsepius |
New.
4.104.114.95
@882a12a
08/28/08 01:14:03 |
Ralf Corsepius |
Use URLs for patches.
4.104.114.95
@55315135
08/27/08 09:42:00 |
Ralf Corsepius |
4.104.114.95
@aef162f
08/27/08 09:33:58 |
Ralf Corsepius |
Remove (Obsolete).
4.104.114.95
@65c3aaf4
08/27/08 09:31:37 |
Ralf Corsepius |
4.104.114.95
@8371640
08/27/08 09:30:57 |
Ralf Corsepius |
Abandon gcc-4.3.0.
Use URLs for patches. …
4.104.114.95
@5c7a69ba
08/27/08 07:52:59 |
Ralf Corsepius |
Update.
4.104.114.95
@d880bc54
08/27/08 07:50:31 |
Ralf Corsepius |
New.
4.104.114.95
@c85397c
08/27/08 07:49:12 |
Ralf Corsepius |
Remove.
4.104.114.95
@f9ad4a6
08/27/08 07:42:21 |
Ralf Corsepius |
Remove tic4x (Abandoned).
4.104.114.95
@71ca05a
08/27/08 07:41:11 |
Ralf Corsepius |
Remove.
4.104.114.95
@cc1ec8c3
08/27/08 07:40:52 |
Ralf Corsepius |
Remove (Abandon).
4.104.114.95
@e69afe2
08/27/08 07:38:40 |
Ralf Corsepius |
Use full URLs to patches.
4.104.114.95
@d0cccc9
08/27/08 07:29:31 |
Ralf Corsepius |
Abandon rtems4.10/tic4x.
4.104.114.95
@f837cfd
08/27/08 07:28:36 |
Ralf Corsepius |
Abandon tic4x.
4.104.114.95
@674811a3
08/27/08 07:27:53 |
Ralf Corsepius |
Remove (Abandoned).
4.104.114.95
@476c9f4
07/27/08 06:25:12 |
Ralf Corsepius |
Don't install windmc.1 if windmc is not available.
4.104.114.95
@ef94f04f
07/07/08 16:55:00 |
Ralf Corsepius |
Remove (Incorporated by upstream.)
4.104.114.95
@874f7ec3
07/06/08 06:01:44 |
Ralf Corsepius |
New.
4.104.114.95
@dbb26e7
07/05/08 05:33:27 |
Ralf Corsepius |
Add full URL to patch.
4.104.114.95
@06a23329
07/03/08 16:36:20 |
Ralf Corsepius |
Add rtems-4.10.
4.104.114.95
@343a28e8
07/03/08 15:44:49 |
Ralf Corsepius |
gcc-core-4.3.1-rtems4.9-20080628.diff
4.104.114.95
@3f6e3fa
07/03/08 15:30:57 |
Ralf Corsepius |
New.
4.104.114.95
@2c20b745
07/03/08 15:28:12 |
Ralf Corsepius |
Backup.
4.104.114.95
@5b622a9d
07/03/08 15:25:01 |
Ralf Corsepius |
Add m68k/cf 5329
4.104.114.95
@5916f579
07/03/08 08:37:15 |
Ralf Corsepius |
Remove 4.3.0.
4.104.114.95
@35f8615
07/03/08 08:24:44 |
Ralf Corsepius |
Set target to rtems4.10.
4.104.114.95
@b1bd76b
07/03/08 08:20:43 |
Ralf Corsepius |
Reset *_RPMREL.
4.104.114.95
@01141c5
07/03/08 08:18:22 |
Ralf Corsepius |
New.
4.104.114.95
@7e851f92
06/09/08 14:31:19 |
Ralf Corsepius |
Upgrade to gcc-4.3.1
4.104.114.95
@01c1694
06/09/08 07:36:08 |
Ralf Corsepius |
Add gcc-4.3.1. Abandon gcc-4.2.3.
4.104.114.95
@22bd5223
06/09/08 07:34:37 |
Ralf Corsepius |
Upgrade to gcc-4.3.1.
4.104.114.95
@ff1a93b
06/09/08 07:33:25 |
Ralf Corsepius |
Do not use string comparisions.
4.104.114.95
@705c7b0
06/09/08 07:32:48 |
Ralf Corsepius |
New.
4.104.114.95
@5a820918
06/05/08 02:53:52 |
Ralf Corsepius |
Remove.
4.104.114.95
@1f5ac415
06/04/08 17:35:06 |
Ralf Corsepius |
Bump GCC_RPMREL.
4.104.114.95
@37fe6ec
06/04/08 15:46:08 |
Ralf Corsepius |
Upgrade to binutils-20080523-1.
4.104.114.95
@19fc339
06/04/08 10:55:45 |
Ralf Corsepius |
Add hack to adjust n/ncr260vt300wpp
4.104.114.95
@b51c8b0
06/04/08 10:49:18 |
Ralf Corsepius |
Bump ncurses RPMREL.
4.104.114.95
