# # ChangeLog for contrib in rtems # # Generated by Trac 1.2.1.dev0 # 05/10/24 10:41:48 Mon, 28 Apr 2008 14:28:10 GMT Ralf Corsepius [bbe338e] * contrib/crossrpms/patches/gdb-6.8-rtems4.9-20080428.diff (added) New. Mon, 28 Apr 2008 14:15:25 GMT Ralf Corsepius [2d29b143] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) Abandon gdb-6.7.1. Use gdb-6.8-rtems4.9-20080428.diff. Mon, 28 Apr 2008 13:38:47 GMT Ralf Corsepius [d9393d5] * contrib/crossrpms/gdb/gdb.add (modified) Minor restructurization. Sun, 27 Apr 2008 05:27:02 GMT Ralf Corsepius [1ef4b6c] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/automake.add (modified) Move %{?dist} to Makefile.am. Sun, 27 Apr 2008 05:26:37 GMT Ralf Corsepius [42f9ca8b] * contrib/crossrpms/autotools/autoconf.add (modified) Move %{?dist} to Makefile.am. BR: m4 > 1.4.5 for autoconf >= 2.62. Sat, 26 Apr 2008 05:36:01 GMT Ralf Corsepius [17002619] * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Use rtems_api. Sat, 26 Apr 2008 05:33:04 GMT Ralf Corsepius [02c93793] * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/mkspec.am (modified) Add rtems_api. Fri, 25 Apr 2008 15:19:47 GMT Ralf Corsepius [dc6771a7] * contrib/crossrpms/gcc/base-gcc.add (modified) Remove stray newline. Mon, 21 Apr 2008 06:01:23 GMT Ralf Corsepius [84f140c] * contrib/crossrpms/autotools/Makefile.am (modified) autoconf-2.62. Mon, 21 Apr 2008 06:01:07 GMT Ralf Corsepius [2e4550cf] * contrib/crossrpms/autotools/autoconf.add (modified) Use AUTOCONF_VERS. Mon, 21 Apr 2008 06:00:44 GMT Ralf Corsepius [2dc7132] * contrib/crossrpms/autotools/autoconf.am (modified) Add AUTOCONF_VERS. Mon, 31 Mar 2008 04:46:57 GMT Ralf Corsepius [ffd1050] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) gdb-6.8-rtems4.9-20080331.diff. Mon, 31 Mar 2008 04:45:03 GMT Ralf Corsepius [eca11fcd] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL. Mon, 31 Mar 2008 04:42:24 GMT Ralf Corsepius [cb63bf0] * contrib/crossrpms/gdb/gdb.add (modified) BR: %{_host_rpmprefix}readline-devel. BR: ... Mon, 31 Mar 2008 04:40:59 GMT Ralf Corsepius [f86abfa] * contrib/crossrpms/gdb/gdb.add (modified) BR: %{_host_rpmprefix}expat-devel. Mon, 31 Mar 2008 04:38:55 GMT Ralf Corsepius [ad476d6e] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Unconditionally BR: %{_host_rpmprefix}gcc. Mon, 31 Mar 2008 04:36:55 GMT Ralf Corsepius [23347e95] * contrib/crossrpms/gdb/prep.add (modified) Remove readline/configure to force not building the bundled readline ... Sat, 29 Mar 2008 17:38:22 GMT Ralf Corsepius [ef5c018] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) gdb-6.8. Sat, 29 Mar 2008 04:38:36 GMT Ralf Corsepius [a408b33a] * contrib/crossrpms/patches/gdb-6.8-rtems4.9-20080329.diff (added) New. Sat, 29 Mar 2008 04:38:02 GMT Ralf Corsepius [84a996a6] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) Add gdb-6.8. Fri, 28 Mar 2008 05:48:42 GMT Ralf Corsepius [14994204] * contrib/crossrpms/cygwin/i686/ncurses.add (modified) Run cygwins libncurses-devel.sh. Fri, 28 Mar 2008 05:44:52 GMT Ralf Corsepius [9d076cc1] * contrib/crossrpms/common/common.add (modified) Add _host_rpmprefix. Wed, 26 Mar 2008 17:59:34 GMT Ralf Corsepius [db6bd68] * contrib/crossrpms/binutils/target-binutils.add (modified) Remove stray blank line. Wed, 26 Mar 2008 07:35:00 GMT Ralf Corsepius [e50a0b2] * contrib/crossrpms/gdb/target-gdb.add (modified) Remove stray blank line. Wed, 26 Mar 2008 06:00:04 GMT Ralf Corsepius [dd56645] * contrib/crossrpms/gdb/build.add (modified) Add CFLAGS_FOR_BUILD. Tue, 25 Mar 2008 05:50:32 GMT Ralf Corsepius [1f129d87] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Regenerate. Mon, 24 Mar 2008 17:11:02 GMT Ralf Corsepius [4e78050] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) gdb-6.7.1-rtems4.9-20080324.diff, gdb-6.7.1-gdb-6.7.90-config.diff. Mon, 24 Mar 2008 17:08:45 GMT Ralf Corsepius [063d030] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL. Mon, 24 Mar 2008 16:02:02 GMT Ralf Corsepius [c0141a36] * contrib/crossrpms/gdb/gdb.add (modified) Add %{_host}-gcc for CdnX Mon, 24 Mar 2008 16:00:10 GMT Ralf Corsepius [4ae739d] * contrib/crossrpms/gdb/prep.add (modified) Add patch1. Mon, 24 Mar 2008 15:57:27 GMT Ralf Corsepius [afeefd1] * contrib/crossrpms/patches/gdb-6.7.1-gdb-6.7.90-config.diff (added) * contrib/crossrpms/patches/gdb-6.7.1-rtems4.9-20080324.diff (added) New. Mon, 24 Mar 2008 15:52:15 GMT Ralf Corsepius [6d71a6f3] * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/install.add (modified) Add _bindir to $PATH. Sun, 23 Mar 2008 10:46:55 GMT Ralf Corsepius [8338208] * contrib/crossrpms/cygwin/cygwin.am (added) * contrib/crossrpms/cygwin/expat.am (added) * contrib/crossrpms/cygwin/w32api.am (added) New. Sat, 22 Mar 2008 10:32:03 GMT Ralf Corsepius [2ebf170] * contrib/crossrpms/cygwin/i686/termcap.add (modified) Fix package name. Sat, 22 Mar 2008 10:28:52 GMT Ralf Corsepius [66b3cc5] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Add termcap. Sat, 22 Mar 2008 10:28:05 GMT Ralf Corsepius [cd27172] * contrib/crossrpms/cygwin/i686/target-termcap.add (added) * contrib/crossrpms/cygwin/i686/termcap.add (added) * contrib/crossrpms/cygwin/termcap.am (added) New. Sat, 22 Mar 2008 05:51:46 GMT Ralf Corsepius [adee1dd2] * contrib/crossrpms/cygwin/readline.am (added) New. Sat, 22 Mar 2008 05:51:29 GMT Ralf Corsepius [c75d74ad] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/cygwin/i686/readline.add (added) * contrib/crossrpms/cygwin/i686/target-readline.add (added) Add readline. Sat, 22 Mar 2008 05:34:16 GMT Ralf Corsepius [0b80c067] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) include ../mpfr.am Sat, 22 Mar 2008 05:33:46 GMT Ralf Corsepius [3736628] * contrib/crossrpms/cygwin/mpfr.add (deleted) Remove. Sat, 22 Mar 2008 05:33:24 GMT Ralf Corsepius [8ef2834b] * contrib/crossrpms/cygwin/gmp.am (added) * contrib/crossrpms/cygwin/mpfr.am (added) New. Sat, 22 Mar 2008 04:57:30 GMT Ralf Corsepius [1fc6c38] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Split-out mpfr.add ncurses.am zlib.am. Sat, 22 Mar 2008 04:56:51 GMT Ralf Corsepius [a837ab2] * contrib/crossrpms/cygwin/mpfr.add (added) * contrib/crossrpms/cygwin/ncurses.am (added) * contrib/crossrpms/cygwin/zlib.am (added) New (Split-out from i686/Makefile.am). Sat, 22 Mar 2008 04:53:19 GMT Ralf Corsepius [24c5f7b] * contrib/crossrpms/cygwin/i686/libncurses-devel.add (deleted) * contrib/crossrpms/cygwin/i686/target-libncurses-devel.add (deleted) Replaced with ncurses*.add Sat, 22 Mar 2008 04:23:14 GMT Ralf Corsepius [0c52be2] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Replace libncurses-devel with ncurses. Sat, 22 Mar 2008 04:22:24 GMT Ralf Corsepius [ee7e515] * contrib/crossrpms/cygwin/i686/ncurses.add (added) * contrib/crossrpms/cygwin/i686/target-ncurses.add (added) New. Thu, 20 Mar 2008 11:54:54 GMT Ralf Corsepius [b0fc2ec] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Add mpfr. Thu, 20 Mar 2008 11:54:34 GMT Ralf Corsepius [229f500] * contrib/crossrpms/cygwin/i686/mpfr.add (added) * contrib/crossrpms/cygwin/i686/target-mpfr.add (added) New. Thu, 20 Mar 2008 09:27:08 GMT Ralf Corsepius [0d4551f2] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Add gmp. Thu, 20 Mar 2008 09:26:44 GMT Ralf Corsepius [4ae0edf] * contrib/crossrpms/cygwin/i686/gmp.add (added) * contrib/crossrpms/cygwin/i686/target-gmp.add (added) New. Thu, 20 Mar 2008 07:01:06 GMT Ralf Corsepius [f9dff196] * contrib/crossrpms/common/common.add (modified) Disable debug_package for cygwin. Thu, 20 Mar 2008 04:04:44 GMT Ralf Corsepius [310132c] * contrib/crossrpms/common/common.add (modified) Add _libdir for cygwin. Thu, 20 Mar 2008 04:03:34 GMT Ralf Corsepius [28904d41] * contrib/crossrpms/common/common.add (modified) Add cygwin optflags hack. Thu, 20 Mar 2008 04:02:31 GMT Ralf Corsepius [fc7d623] * contrib/crossrpms/freebsd6.2/i586/libs.add (modified) Use %__tar instead of /usr/bin/star. Wed, 19 Mar 2008 17:07:56 GMT Ralf Corsepius [a0291e05] * contrib/crossrpms/cygwin/gcc-prep.add (modified) * contrib/crossrpms/cygwin/i686/gcc-sources.add (modified) Rename Source60 into Source70. Wed, 19 Mar 2008 12:48:48 GMT Ralf Corsepius [5a63a1e] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Upgrade to cygwin-1.5.25-11, w32api-3.11-1. Tue, 18 Mar 2008 06:12:40 GMT Ralf Corsepius [5589eac0] * contrib/crossrpms/binutils/build.add (modified) Add %{_bindir} to PATH to cater CdnX-builds. Set CFLAGS_FOR_BUILD. Tue, 18 Mar 2008 06:11:17 GMT Ralf Corsepius [7940f96] * contrib/crossrpms/binutils/install.add (modified) Add %{_bindir} to PATH to catter CdnX-builds. Tue, 18 Mar 2008 06:09:42 GMT Ralf Corsepius [1fb6a01] * contrib/crossrpms/binutils/binutils.add (modified) BR: @rpmprefix@%{_host}-gcc for CdnX-builds. Tue, 18 Mar 2008 05:39:21 GMT Ralf Corsepius [18f7bf5a] * contrib/crossrpms/gcc/build.add (modified) Set CFLAGS_FOR_BUILD and CC for CdnX-builds. Tue, 18 Mar 2008 05:37:40 GMT Ralf Corsepius [368708b] * contrib/crossrpms/gcc/gccnewlib.add (modified) BR: @rpmprefix@@tool_target@-gcc and @rpmprefix@%{_host}-gcc for ... Tue, 18 Mar 2008 05:36:13 GMT Ralf Corsepius [7da626b] * contrib/crossrpms/gcc/target-c++.add (modified) BR: @rpmprefix@@tool_target@-gcc-c++ for CdnX-builds. Fri, 14 Mar 2008 16:14:48 GMT Ralf Corsepius [5431a717] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Bump RPMRELS. Sync with rtems-4-8-branch. Fri, 14 Mar 2008 16:05:12 GMT Ralf Corsepius [d06b28e] * contrib/crossrpms/cygwin/i686/libncurses-devel.add (modified) Fix typo. Fri, 14 Mar 2008 15:34:59 GMT Ralf Corsepius [211c22eb] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Wed, 12 Mar 2008 03:25:39 GMT Ralf Corsepius [dcd4562c] * contrib/crossrpms/cygwin/i686/binutils-sources.add (modified) Add binutils-patch. Wed, 12 Mar 2008 03:24:11 GMT Ralf Corsepius [672465e] * contrib/crossrpms/patches/binutils-2.17.50-cygwin-20060817-1.diff (added) New. Thu, 06 Mar 2008 15:35:51 GMT Ralf Corsepius [44cc441] * contrib/crossrpms/freebsd6.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.3/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.0/i586/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Switch back to old GCC_RPMREL versioning scheme. Thu, 06 Mar 2008 15:34:40 GMT Ralf Corsepius [cd7b673] * contrib/crossrpms/configure.ac (modified) Bump version. Thu, 06 Mar 2008 15:33:52 GMT Ralf Corsepius [6a90a4a] * contrib/crossrpms/freebsd6.2/i586/binutils-sources.add (modified) * contrib/crossrpms/freebsd6.3/i586/binutils-sources.add (modified) * contrib/crossrpms/freebsd7.0/i586/binutils-sources.add (modified) * contrib/crossrpms/solaris2.7/sparc/binutils-sources.add (modified) Use binutils-2.18-rtems4.9-20080211.diff. Thu, 06 Mar 2008 15:31:20 GMT Ralf Corsepius [d401b14] * contrib/crossrpms/patches/gcc-core-4.3.0-rtems4.9-20080306.diff (added) New. Thu, 06 Mar 2008 15:30:45 GMT Ralf Corsepius [fcac0c7] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Preps for gcc-4.3.0 final. Thu, 06 Mar 2008 05:44:25 GMT Ralf Corsepius [5b5a0dd] * contrib/crossrpms/freebsd6.2/i586/binutils-sources.add (modified) Sync with freebsd7.0. Thu, 06 Mar 2008 05:42:56 GMT Ralf Corsepius [28c664d1] * contrib/crossrpms/freebsd6.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.3/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.0/i586/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Upgrade to binutils-2.18. Upgrade to gcc-4.2.3. Activate objc. Thu, 06 Mar 2008 05:40:03 GMT Ralf Corsepius [f8ee67eb] * contrib/crossrpms/gcc/gccnewlib.add (modified) Require gmp and mpfr for gcc > 4.2.0 fortran. Wed, 05 Mar 2008 05:58:48 GMT Ralf Corsepius [0764085] * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/binutils-sources.add (modified) Sync with the freebsds. Wed, 05 Mar 2008 03:03:47 GMT Ralf Corsepius [dff01852] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd6.1. Wed, 05 Mar 2008 03:02:54 GMT Ralf Corsepius [5aaa497] * contrib/crossrpms/freebsd6.1/.cvsignore (deleted) * contrib/crossrpms/freebsd6.1/Makefile.am (deleted) * contrib/crossrpms/freebsd6.1/binutils.am (deleted) * contrib/crossrpms/freebsd6.1/gcc-prep.add (deleted) * contrib/crossrpms/freebsd6.1/gcc.am (deleted) * contrib/crossrpms/freebsd6.1/i586/.cvsignore (deleted) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (deleted) * contrib/crossrpms/freebsd6.1/i586/binutils-sources.add (deleted) * contrib/crossrpms/freebsd6.1/i586/gcc-sources.add (deleted) * contrib/crossrpms/freebsd6.1/i586/libs.add (deleted) * contrib/crossrpms/freebsd6.1/i586/target-libs.add (deleted) Abandon. Wed, 05 Mar 2008 03:01:37 GMT Ralf Corsepius [6b81c78] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add freebsd6.3, freebsd7.0 Wed, 05 Mar 2008 02:47:30 GMT Ralf Corsepius [905cbd1] * contrib/crossrpms/freebsd6.3/.cvsignore (added) * contrib/crossrpms/freebsd6.3/Makefile.am (added) * contrib/crossrpms/freebsd6.3/binutils.am (added) * contrib/crossrpms/freebsd6.3/gcc-prep.add (added) * contrib/crossrpms/freebsd6.3/gcc.am (added) * contrib/crossrpms/freebsd6.3/i586/.cvsignore (added) * contrib/crossrpms/freebsd6.3/i586/Makefile.am (added) * contrib/crossrpms/freebsd6.3/i586/binutils-sources.add (added) * contrib/crossrpms/freebsd6.3/i586/gcc-sources.add (added) * contrib/crossrpms/freebsd6.3/i586/libs.add (added) * contrib/crossrpms/freebsd6.3/i586/target-libs.add (added) * contrib/crossrpms/freebsd7.0/.cvsignore (added) * contrib/crossrpms/freebsd7.0/Makefile.am (added) * contrib/crossrpms/freebsd7.0/binutils.am (added) * contrib/crossrpms/freebsd7.0/gcc-prep.add (added) * contrib/crossrpms/freebsd7.0/gcc.am (added) * contrib/crossrpms/freebsd7.0/i586/.cvsignore (added) * contrib/crossrpms/freebsd7.0/i586/Makefile.am (added) * contrib/crossrpms/freebsd7.0/i586/binutils-sources.add (added) * contrib/crossrpms/freebsd7.0/i586/gcc-sources.add (added) * contrib/crossrpms/freebsd7.0/i586/libs.add (added) * contrib/crossrpms/freebsd7.0/i586/target-libs.add (added) New. Wed, 05 Mar 2008 02:38:07 GMT Ralf Corsepius [610c400] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd6.0 Wed, 05 Mar 2008 02:37:22 GMT Ralf Corsepius [2301a644] * contrib/crossrpms/freebsd5.2/.cvsignore (deleted) * contrib/crossrpms/freebsd5.2/Makefile.am (deleted) * contrib/crossrpms/freebsd5.2/binutils.am (deleted) * contrib/crossrpms/freebsd5.2/gcc-prep.add (deleted) * contrib/crossrpms/freebsd5.2/gcc.am (deleted) * contrib/crossrpms/freebsd5.2/i586/.cvsignore (deleted) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (deleted) * contrib/crossrpms/freebsd5.2/i586/binutils-sources.add (deleted) * contrib/crossrpms/freebsd5.2/i586/gcc-prep.add (deleted) * contrib/crossrpms/freebsd5.2/i586/gcc-sources.add (deleted) * contrib/crossrpms/freebsd5.2/i586/libs.add (deleted) * contrib/crossrpms/freebsd5.2/i586/target-libs.add (deleted) * contrib/crossrpms/freebsd6.0/.cvsignore (deleted) * contrib/crossrpms/freebsd6.0/Makefile.am (deleted) * contrib/crossrpms/freebsd6.0/binutils.am (deleted) * contrib/crossrpms/freebsd6.0/gcc-prep.add (deleted) * contrib/crossrpms/freebsd6.0/gcc.am (deleted) * contrib/crossrpms/freebsd6.0/i586/.cvsignore (deleted) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (deleted) * contrib/crossrpms/freebsd6.0/i586/binutils-sources.add (deleted) * contrib/crossrpms/freebsd6.0/i586/gcc-sources.add (deleted) * contrib/crossrpms/freebsd6.0/i586/libs.add (deleted) * contrib/crossrpms/freebsd6.0/i586/target-libs.add (deleted) Abandon. Wed, 05 Mar 2008 02:35:52 GMT Ralf Corsepius [01993e1] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd5.2 Mon, 03 Mar 2008 07:40:26 GMT Ralf Corsepius [f0c4cf75] * contrib/crossrpms/patches/newlib-1.16.0-rtems4.9-20080302.diff (modified) Add *_ARG to getopt.c. Mon, 03 Mar 2008 06:36:28 GMT Ralf Corsepius [fb974c6] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Mon, 03 Mar 2008 06:35:42 GMT Ralf Corsepius [d0abb93] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GCC_RPMREL = 10.20080301.2%{?dist}. Mon, 03 Mar 2008 06:35:07 GMT Ralf Corsepius [84126da9] * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) Bump GCC_RPMREL = 10.1%{?dist}. Mon, 03 Mar 2008 06:34:37 GMT Ralf Corsepius [834a670c] * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Bump GCC_RPMREL = 7%{?dist}. Mon, 03 Mar 2008 06:33:49 GMT Ralf Corsepius [94299fd3] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Update to newlib-1.16.0-rtems4.9-20080302.diff. Mon, 03 Mar 2008 06:14:59 GMT Ralf Corsepius [5df181db] * contrib/crossrpms/patches/newlib-1.16.0-rtems4.9-20080302.diff (added) Add getopt*_r. Sun, 02 Mar 2008 06:52:59 GMT Ralf Corsepius [e2fe8948] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Sun, 02 Mar 2008 06:51:36 GMT Ralf Corsepius [3aa2d40] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Update to gcc-4.3.0-RC-20080301. Wed, 27 Feb 2008 15:31:30 GMT Ralf Corsepius [e122f592] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Wed, 27 Feb 2008 15:28:21 GMT Ralf Corsepius [26c2bea] * contrib/crossrpms/gcc/gccnewlib.add (modified) Build bundled mpfr for suse10.2 and suse10.3. Wed, 27 Feb 2008 14:17:39 GMT Ralf Corsepius [7cfcdc1] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GCC_RPMREL to 10.20080222.1 Wed, 27 Feb 2008 14:16:53 GMT Ralf Corsepius [caeacf7b] * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) Upgrade to gcc-4.3.0-RC-20080222. Wed, 27 Feb 2008 14:04:47 GMT Ralf Corsepius [8e6bf2b] * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) Upgrade to gcc-4.3.0-RC-20080222. Wed, 27 Feb 2008 11:59:11 GMT Ralf Corsepius [8de5e41] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) Upgrade to gcc-4.3.0-RC-20080222. Wed, 27 Feb 2008 11:47:30 GMT Ralf Corsepius [2561ee9] * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) Upgrade to gcc-4.3.0-RC-20080222. Wed, 27 Feb 2008 11:21:58 GMT Ralf Corsepius [069046a7] * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) Upgrade to gcc-4.3.0-RC-20080222.
