# # ChangeLog for contrib in rtems # # Generated by Trac 1.2.1.dev0 # 05/22/24 11:09:00 Wed, 29 Aug 2007 02:51:40 GMT Ralf Corsepius [9ce762b] * contrib/crossrpms/binutils/base-binutils.add (modified) Abandon binutils < 2.13. Wed, 22 Aug 2007 23:52:43 GMT Chris Johns [2e2cbfa9] * contrib/mingw/ChangeLog (modified) * contrib/mingw/mingw-path.nsi (modified) 2007-0823 Chris Johns * ... Mon, 20 Aug 2007 02:12:48 GMT Chris Johns [598aab1f] * contrib/mingw/ChangeLog (modified) * contrib/mingw/ba-wrap.sh (modified) * contrib/mingw/build-exes.sh (modified) * contrib/mingw/filewrite.nsi (added) * contrib/mingw/getparameters.nsi (added) * contrib/mingw/instance-check.nsi (added) * contrib/mingw/mingw-path.nsi (added) * contrib/mingw/msys-path.nsi (modified) * contrib/mingw/options.nsi (added) * contrib/mingw/rtems-autotools.nsi (modified) * contrib/mingw/rtems-tools.nsi (modified) * contrib/mingw/rtems.ini (modified) * contrib/mingw/rtems_logo.bmp (modified) * contrib/mingw/sm-dummy.nsi (added) * contrib/mingw/strslash.nsi (added) * contrib/mingw/strstr.nsi (added) 2007-08-20 Chris Johns * ... Thu, 09 Aug 2007 16:57:09 GMT Ralf Corsepius [ece78df6] * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (modified) gdb-6.6-9. Thu, 09 Aug 2007 05:20:07 GMT Ralf Corsepius [876c33f1] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (modified) gdb-6.6-9. Thu, 09 Aug 2007 03:05:41 GMT Ralf Corsepius [9aa1472] * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (modified) Regenerate. Thu, 09 Aug 2007 03:05:00 GMT Ralf Corsepius [e90748fd] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gdb.spec (added) New. Thu, 09 Aug 2007 03:01:40 GMT Ralf Corsepius [6ed5f75] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Increment GDB_RPMREL. Thu, 09 Aug 2007 02:58:36 GMT Ralf Corsepius [984e8d8d] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Append %{?dist} to GDB_RPMREL. Thu, 09 Aug 2007 02:55:36 GMT Ralf Corsepius [2ef64f2] * contrib/crossrpms/gdb/base-gdb.add (modified) Remove references to base packages. Thu, 09 Aug 2007 02:54:01 GMT Ralf Corsepius [9452ee4a] * contrib/crossrpms/gdb/base-gdb.add (modified) Remove support for gdb < 6.0. Thu, 09 Aug 2007 02:53:30 GMT Ralf Corsepius [ee19567c] * contrib/crossrpms/gdb/gdb.add (modified) Remove %{?dist} Wed, 08 Aug 2007 12:21:26 GMT Ralf Corsepius [c2cc8b2] * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90. Wed, 08 Aug 2007 10:10:51 GMT Ralf Corsepius [4db732d] * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90. Wed, 08 Aug 2007 08:24:48 GMT Ralf Corsepius [8ee1b11] * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90. Wed, 08 Aug 2007 04:22:50 GMT Ralf Corsepius [9e516ac] * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (modified) Revert to gcc-4.0.3-12, gcc-4.2.1 doesn't build Wed, 08 Aug 2007 04:13:44 GMT Ralf Corsepius [baa2d55] * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90. Wed, 08 Aug 2007 04:11:02 GMT Ralf Corsepius [1cb554a6] * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:43:09 GMT Ralf Corsepius [cc85dda] * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:42:47 GMT Ralf Corsepius [1a8165f6] * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Wed, 08 Aug 2007 03:36:40 GMT Ralf Corsepius [8d88aa2] * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:36:15 GMT Ralf Corsepius [92b76712] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Wed, 08 Aug 2007 03:30:27 GMT Ralf Corsepius [ff3a2d87] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:30:15 GMT Ralf Corsepius [5d991cf] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Wed, 08 Aug 2007 03:21:54 GMT Ralf Corsepius [3675f57] * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:21:29 GMT Ralf Corsepius [8d25d2e] * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Tue, 07 Aug 2007 15:41:57 GMT Ralf Corsepius [c48c3590] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (modified) BINUTILS_RPMREL = 2 Tue, 07 Aug 2007 15:38:23 GMT Ralf Corsepius [4907b96] * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) Regenerate. Tue, 07 Aug 2007 15:38:10 GMT Ralf Corsepius [90aab6d] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Enable infos for binutils. Tue, 07 Aug 2007 15:21:40 GMT Ralf Corsepius [69fb982] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (modified) Upgrade to binutils-2.17.90. Tue, 07 Aug 2007 15:15:42 GMT Ralf Corsepius [039d51b] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (added) Regenerate. Tue, 07 Aug 2007 08:20:59 GMT Ralf Corsepius [cae995d] * contrib/crossrpms/patches/binutils-2.17.90-rtems4.8-20070807.diff (added) New. Sat, 04 Aug 2007 08:21:33 GMT Ralf Corsepius [3ffefc3] * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) Sync. Sat, 04 Aug 2007 08:20:59 GMT Ralf Corsepius [9e84b8e8] * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) GCC_RPMREL = 22. Sat, 04 Aug 2007 08:20:43 GMT Ralf Corsepius [55230f2e] * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) Update to gcc-core-4.2.1-rtems4.8-20070804.diff. Sat, 04 Aug 2007 08:18:14 GMT Ralf Corsepius [5332bc6e] * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20070804.diff (added) Add m68k -m528x. Sat, 04 Aug 2007 06:24:12 GMT Chris Johns [56f6b907] * contrib/mingw/ChangeLog (modified) * contrib/mingw/build-exes.sh (modified) * contrib/mingw/msys-path.nsi (modified) * contrib/mingw/rtems-autotools.nsi (modified) * contrib/mingw/rtems-tools.nsi (modified) * contrib/mingw/rtems.ini (modified) * contrib/mingw/rtems_logo.bmp (modified) * contrib/mingw/upload.sh (modified) * contrib/mingw/version (modified) 2007-08-03 Chris Johns * ... Sat, 04 Aug 2007 06:13:39 GMT Ralf Corsepius [26ccaab0] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) GCC_RPMREL = 21 Sat, 04 Aug 2007 06:03:04 GMT Ralf Corsepius [31139c3] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Update to newlib-1.15.0-rtems4.8-20070804.diff Sat, 04 Aug 2007 04:34:30 GMT Ralf Corsepius [b39173b0] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070804.diff (added) Add tar.h. Sat, 28 Jul 2007 08:31:57 GMT Chris Johns [f6cd0db] * contrib/mingw/ChangeLog (modified) * contrib/mingw/README (modified) * contrib/mingw/autoconf.def (added) * contrib/mingw/automake.def (added) * contrib/mingw/ba-wrap.sh (added) * contrib/mingw/build-autotools.sh (added) * contrib/mingw/build-exes.sh (modified) * contrib/mingw/build-rpms.sh (modified) * contrib/mingw/msys-path.nsi (added) * contrib/mingw/rtems-autotools.nsi (added) * contrib/mingw/rtems-tools.nsi (modified) * contrib/mingw/rtems.ini (modified) * contrib/mingw/target-section-text (added) * contrib/mingw/upload.sh (added) * contrib/mingw/version (added) 2007-07-28 Chris Johns * README, ... Thu, 26 Jul 2007 09:31:41 GMT Ralf Corsepius [462b28d] * contrib/crossrpms/cygwin/i686/libncurses-devel.add (modified) chmod +x etc/postinstall/libncurses-devel.sh Thu, 26 Jul 2007 09:19:22 GMT Ralf Corsepius [5a379b01] * contrib/crossrpms/cygwin/i686/libncurses-devel.add (modified) Don't use sed -i. Thu, 26 Jul 2007 09:19:02 GMT Ralf Corsepius [1b1452b6] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) NCURSES_RPMREL = 0.20070726.1 Tue, 24 Jul 2007 14:26:46 GMT Ralf Corsepius [e0d85b74] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.2/i586/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Move %{?dist} into BINUTILS_RPMREL. Tue, 24 Jul 2007 14:24:43 GMT Ralf Corsepius [b8a8bfb0] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.2/i586/Makefile.am (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Move %{?dist} into GCC_RPMREL. Tue, 24 Jul 2007 04:27:05 GMT Ralf Corsepius [c5721b9] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Bump the date on *RPMREL Tue, 24 Jul 2007 03:47:09 GMT Ralf Corsepius [ee4740b] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) Add cygwin hacks. Tue, 24 Jul 2007 03:45:39 GMT Ralf Corsepius [d292aae] * contrib/crossrpms/cygwin/i686/target-zlib.add (added) * contrib/crossrpms/cygwin/i686/zlib.add (added) New. Tue, 24 Jul 2007 03:45:22 GMT Ralf Corsepius [7feadc65] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Add zlib. Mon, 23 Jul 2007 09:44:40 GMT Ralf Corsepius [d942dc2] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/cygwin/i686/libs.add (modified) Various updates. Mon, 23 Jul 2007 09:43:49 GMT Ralf Corsepius [131ee1cc] * contrib/crossrpms/cygwin/i686/libncurses-devel.add (added) * contrib/crossrpms/cygwin/i686/target-libncurses-devel.add (added) New. Mon, 23 Jul 2007 02:02:15 GMT Ralf Corsepius [f81476f] * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) Sync GCC with testing. Sun, 22 Jul 2007 07:08:30 GMT Ralf Corsepius [86a30d0] * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) Various patches from rtems-4-8-testing branch. Fri, 20 Jul 2007 05:36:13 GMT Ralf Corsepius [4acc7e2] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (modified) Sync with testing. Fri, 20 Jul 2007 05:32:17 GMT Ralf Corsepius [70ea34b] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) Sync with devel. Fri, 20 Jul 2007 05:23:59 GMT Ralf Corsepius [ed332c8] * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Sync with testing. Fri, 20 Jul 2007 04:59:16 GMT Ralf Corsepius [280e1308] * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20070719.diff (added) New. Sun, 15 Jul 2007 05:02:51 GMT Ralf Corsepius [4b0be6c] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Preps for gcc-4.2.1. Thu, 05 Jul 2007 19:06:15 GMT Joel Sherrill [20074c49] * contrib/crossrpms/patches/gcc-ada-4.2.0-rtems4.8-20070705.diff (added) Needed to compile Ada. ACATS run on both psim and erc32. Results ... Mon, 18 Jun 2007 11:22:49 GMT Ralf Corsepius [22cc95f5] * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) Preps for next spin. Mon, 18 Jun 2007 10:32:03 GMT Ralf Corsepius [55e9fca] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) Preps for next spin. Mon, 18 Jun 2007 09:42:00 GMT Ralf Corsepius [3fac2408] * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) Update. Mon, 18 Jun 2007 07:02:32 GMT Ralf Corsepius [9b31b29] * contrib/crossrpms/gcc/build.add (modified) --disable-libstdcxx-pch Mon, 18 Jun 2007 07:01:22 GMT Ralf Corsepius [bb96485] * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) Upgrade to gcc-4.2.0 final. Mon, 18 Jun 2007 04:46:14 GMT Ralf Corsepius [7d846d4] * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) GCC_RPMREL = 18 Mon, 18 Jun 2007 04:45:51 GMT Ralf Corsepius [849ed685] * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) Cleanup. 20070613 patches. Mon, 18 Jun 2007 04:38:33 GMT Ralf Corsepius [7f3319e] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) GCC_RPMREL = 13 Mon, 18 Jun 2007 04:37:39 GMT Ralf Corsepius [611aa7dd] * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) Cleanup. 20070613 patches. Mon, 18 Jun 2007 04:36:33 GMT Ralf Corsepius [169dbb55] * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) GCC_RPMREL = 14 Mon, 18 Jun 2007 04:35:41 GMT Ralf Corsepius [0d04790] * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) Cleanup. Wed, 13 Jun 2007 16:38:22 GMT Ralf Corsepius [8cf555e] * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) Regenerate. Wed, 13 Jun 2007 15:42:41 GMT Ralf Corsepius [a43f670] * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) Add *20070613.diff Wed, 13 Jun 2007 15:42:22 GMT Ralf Corsepius [fc463855] * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) GCC_RPMREL = 13 Wed, 13 Jun 2007 15:40:32 GMT Ralf Corsepius [c0064d39] * contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.8-20070613.diff (added) * contrib/crossrpms/patches/gcc-core-4.2.0-rtems4.8-20070613.diff (added) Add sparc fpu bug fix. Mon, 04 Jun 2007 09:12:43 GMT Ralf Corsepius [967c8974] * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (added) New. Sun, 03 Jun 2007 15:26:45 GMT Ralf Corsepius [4fec4975] * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) GCC_RPMREL = 17. Sun, 03 Jun 2007 06:03:58 GMT Ralf Corsepius [0ae15e60] * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) GCC_RPMREL = 12 Sun, 03 Jun 2007 06:01:55 GMT Ralf Corsepius [87e21be] * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (added) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (added) New. Sat, 02 Jun 2007 07:54:37 GMT Ralf Corsepius [ab86b62] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (added) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (added) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (added) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (added) New. Sat, 02 Jun 2007 07:54:07 GMT Ralf Corsepius [e2a00ab] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) GCC_RPMREL = 12. Sat, 02 Jun 2007 05:57:31 GMT Ralf Corsepius [ecf3c8c] * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (added) New. Sat, 02 Jun 2007 05:57:05 GMT Ralf Corsepius [88d97467] * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) GCC_RPMREL = 12. Sat, 02 Jun 2007 04:52:01 GMT Ralf Corsepius [9bc3ef5] * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (added) New. Sat, 02 Jun 2007 04:51:44 GMT Ralf Corsepius [7b8fbed] * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) GCC_RPMREL = 11. Sat, 02 Jun 2007 04:29:21 GMT Ralf Corsepius [498f319] * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (added) New. Sat, 02 Jun 2007 03:23:15 GMT Ralf Corsepius [b34fda5] * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (added) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (added) New. Sat, 02 Jun 2007 03:19:37 GMT Ralf Corsepius [6a4e3360] * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) GCC_RPMREL = 12. Fri, 01 Jun 2007 08:46:51 GMT Ralf Corsepius [0925496] * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) GCC_RPMREL = 11. Fri, 25 May 2007 13:42:51 GMT Ralf Corsepius [f7d5d6e3] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (modified) Backup. Fri, 25 May 2007 13:42:27 GMT Ralf Corsepius [24848b6] * contrib/crossrpms/patches/binutils-2.17.50-rtems4.8-20070525.diff (added) New. Fri, 25 May 2007 08:39:01 GMT Ralf Corsepius [d183ac2a] * contrib/crossrpms/binutils/base-binutils.add (modified) Add gprof.info handling. Thu, 24 May 2007 02:58:23 GMT Ralf Corsepius [36c8e140] * contrib/crossrpms/gcc/install.add (modified) Remove %{_libdir}/libiberty.a Tue, 22 May 2007 08:11:26 GMT Ralf Corsepius [7860a37] * contrib/repo-conf/configure.ac (modified) Bump version to 0.7 Tue, 22 May 2007 08:11:04 GMT Ralf Corsepius [54457f44] * contrib/repo-conf/rtems-repo-conf.spec.in (modified) Add suse Mon, 21 May 2007 19:27:34 GMT Joel Sherrill [4741b0b2] * contrib/mingw/ChangeLog (modified) * contrib/mingw/build-rpms.sh (modified) 2007-05-21 Joel Sherrill * ... Mon, 21 May 2007 10:55:01 GMT Ralf Corsepius [3fafc63] * contrib/crossrpms/gcc/build.add (modified) Add --libexecdir. Thu, 17 May 2007 15:39:50 GMT Ralf Corsepius [e57739d] * contrib/repo-conf/rtems-repo-conf.spec.in (modified) Add .rh clause to extra_arg. Thu, 17 May 2007 15:34:10 GMT Ralf Corsepius [4ec03d7] * contrib/repo-conf/configure.ac (modified) Add --enable-os-subdir. Bump version to 0.6. Thu, 17 May 2007 15:33:51 GMT Ralf Corsepius [44302c7e] * contrib/repo-conf/rtems-repo-conf.spec.in (modified) Add --enable-os-subdir.
