# # ChangeLog for contrib in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 19:46:09 Sat, 24 Apr 2010 14:05:52 GMT Ralf Corsepius [8a2e9181] * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-gcc.spec (modified) * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-gcc.spec (modified) * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/amd64/amd64-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-gcc.spec (modified) Regenerate. Sat, 24 Apr 2010 14:05:25 GMT Ralf Corsepius [0e16f0ad] * contrib/crossrpms/gcc/gccnewlib.add (modified) Require gmp-4.2 if building mpc. Sat, 24 Apr 2010 08:04:56 GMT Ralf Corsepius [f2bb33b2] * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-gcc.spec (modified) * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-gcc.spec (modified) * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/amd64/amd64-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-gcc.spec (modified) Regenerate. Sat, 24 Apr 2010 08:04:22 GMT Ralf Corsepius [f0cb9aea] * contrib/crossrpms/freebsd6.4/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.3/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.0/i586/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/amd64/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) Bump GCC_RPMREL. Sat, 24 Apr 2010 05:59:58 GMT Ralf Corsepius [b2c76e9] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Sat, 24 Apr 2010 05:59:17 GMT Ralf Corsepius [423a18d] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) Revert last patch. Sat, 24 Apr 2010 05:57:58 GMT Ralf Corsepius [461e171b] * contrib/crossrpms/gcc/gccnewlib.add (modified) Fix typo in comment. Use %{el6} to identify building for ... Fri, 23 Apr 2010 16:49:17 GMT Ralf Corsepius [10612755] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Fri, 23 Apr 2010 16:47:01 GMT Ralf Corsepius [4aa415f] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Bump GCC_RPMREL. Fri, 23 Apr 2010 16:46:41 GMT Ralf Corsepius [fee6d69] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20100423.diff. Fri, 23 Apr 2010 13:06:40 GMT Ralf Corsepius [76f2a2e] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20100423.diff (added) New. Fri, 23 Apr 2010 11:01:26 GMT Ralf Corsepius [3a3865f2] * contrib/crossrpms/gcc/gccnewlib.add (modified) Add rhel6. Mon, 19 Apr 2010 16:58:15 GMT Ralf Corsepius [5c2c96f] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd7.2. Mon, 19 Apr 2010 16:57:01 GMT Ralf Corsepius [4e8aad77] * contrib/crossrpms/freebsd7.2/.cvsignore (deleted) * contrib/crossrpms/freebsd7.2/Makefile.am (deleted) * contrib/crossrpms/freebsd7.2/binutils.am (deleted) * contrib/crossrpms/freebsd7.2/gcc-prep.add (deleted) * contrib/crossrpms/freebsd7.2/gcc.am (deleted) * contrib/crossrpms/freebsd7.2/i586/.cvsignore (deleted) * contrib/crossrpms/freebsd7.2/i586/Makefile.am (deleted) * contrib/crossrpms/freebsd7.2/i586/binutils-sources.add (deleted) * contrib/crossrpms/freebsd7.2/i586/gcc-sources.add (deleted) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-binutils.spec (deleted) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-gcc.spec (deleted) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-libs.spec (deleted) * contrib/crossrpms/freebsd7.2/i586/libs.add (deleted) * contrib/crossrpms/freebsd7.2/i586/target-libs.add (deleted) * contrib/crossrpms/freebsd7.2/libs.am (deleted) Abandon freebsd7.2 Mon, 19 Apr 2010 14:19:21 GMT Ralf Corsepius [447de8f3] * contrib/crossrpms/netbsd5.0.2/amd64/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/amd64/amd64-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/amd64/amd64-pc-netbsdelf5.0.2-libs.spec (modified) * contrib/crossrpms/netbsd5.0.2/amd64/libs.add (modified) * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-libs.spec (modified) Regenerate. Mon, 19 Apr 2010 14:13:27 GMT Ralf Corsepius [6aa50b0] * contrib/crossrpms/netbsd5.0.2/amd64/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) Bump GCC_RPMREL. Mon, 19 Apr 2010 14:10:52 GMT Ralf Corsepius [c96718c4] * contrib/crossrpms/netbsd5.0.2/i386/gcc-sources.add (modified) Sync with amd64. Mon, 19 Apr 2010 14:09:59 GMT Ralf Corsepius [2d667cc] * contrib/crossrpms/netbsd5.0.2/i386/libs.add (modified) Fix up Source0, Source1-URL. Mon, 19 Apr 2010 14:08:59 GMT Ralf Corsepius [7bfa75d5] * contrib/crossrpms/netbsd5.0.2/amd64/.cvsignore (added) * contrib/crossrpms/netbsd5.0.2/amd64/Makefile.am (added) * contrib/crossrpms/netbsd5.0.2/amd64/amd64-pc-netbsdelf5.0.2-binutils.spec (added) * contrib/crossrpms/netbsd5.0.2/amd64/amd64-pc-netbsdelf5.0.2-gcc.spec (added) * contrib/crossrpms/netbsd5.0.2/amd64/amd64-pc-netbsdelf5.0.2-libs.spec (added) * contrib/crossrpms/netbsd5.0.2/amd64/binutils-sources.add (added) * contrib/crossrpms/netbsd5.0.2/amd64/gcc-sources.add (added) * contrib/crossrpms/netbsd5.0.2/amd64/libs.add (added) * contrib/crossrpms/netbsd5.0.2/amd64/target-libs.add (added) New. Mon, 19 Apr 2010 14:04:14 GMT Ralf Corsepius [44ac623] * contrib/crossrpms/configure.ac (modified) Add netbsd5.0.2/amd64. Mon, 19 Apr 2010 14:03:35 GMT Ralf Corsepius [b2f215a3] * contrib/crossrpms/netbsd5.0.2/Makefile.am (modified) Add am64 Mon, 19 Apr 2010 14:02:13 GMT Ralf Corsepius [3584ae59] * contrib/crossrpms/patches/gcc-core-4.5.0-rtems4.11-20100419.diff (added) New (add amd64-netbsd*5). Mon, 19 Apr 2010 04:07:54 GMT Ralf Corsepius [a7f3bad9] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon netbsd5.0.1 Mon, 19 Apr 2010 04:07:16 GMT Ralf Corsepius [6bac3f4] * contrib/crossrpms/netbsd5.0.1/.cvsignore (deleted) * contrib/crossrpms/netbsd5.0.1/Makefile.am (deleted) * contrib/crossrpms/netbsd5.0.1/binutils.am (deleted) * contrib/crossrpms/netbsd5.0.1/gcc-prep.add (deleted) * contrib/crossrpms/netbsd5.0.1/gcc.am (deleted) * contrib/crossrpms/netbsd5.0.1/i386/.cvsignore (deleted) * contrib/crossrpms/netbsd5.0.1/i386/Makefile.am (deleted) * contrib/crossrpms/netbsd5.0.1/i386/binutils-sources.add (deleted) * contrib/crossrpms/netbsd5.0.1/i386/gcc-sources.add (deleted) * contrib/crossrpms/netbsd5.0.1/i386/i386-pc-netbsdelf5.0.1-binutils.spec (deleted) * contrib/crossrpms/netbsd5.0.1/i386/i386-pc-netbsdelf5.0.1-gcc.spec (deleted) * contrib/crossrpms/netbsd5.0.1/i386/i386-pc-netbsdelf5.0.1-libs.spec (deleted) * contrib/crossrpms/netbsd5.0.1/i386/libs.add (deleted) * contrib/crossrpms/netbsd5.0.1/i386/target-libs.add (deleted) * contrib/crossrpms/netbsd5.0.1/libs.am (deleted) Remove. Mon, 19 Apr 2010 04:04:48 GMT Ralf Corsepius [de42344] * contrib/crossrpms/patches/gdb-7.0.1-rtems4.10-20091222.diff (deleted) * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090922.diff (deleted) * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20091104.diff (deleted) Housekeeping. Mon, 19 Apr 2010 04:02:28 GMT Ralf Corsepius [d78b2159] * contrib/crossrpms/patches/gcc-core-4.5.0-rtems4.11-20100418.diff (added) New (Add i386*netbsdelf hack.) Mon, 19 Apr 2010 03:55:06 GMT Ralf Corsepius [88687468] * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-binutils.spec (modified) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-libs.spec (modified) Bump *_RPMREL. Mon, 19 Apr 2010 03:44:17 GMT Ralf Corsepius [a6ed8fb] * contrib/crossrpms/netbsd5.0.2/.cvsignore (added) * contrib/crossrpms/netbsd5.0.2/Makefile.am (added) * contrib/crossrpms/netbsd5.0.2/binutils.am (added) * contrib/crossrpms/netbsd5.0.2/gcc-prep.add (added) * contrib/crossrpms/netbsd5.0.2/gcc.am (added) * contrib/crossrpms/netbsd5.0.2/i386/.cvsignore (added) * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (added) * contrib/crossrpms/netbsd5.0.2/i386/binutils-sources.add (added) * contrib/crossrpms/netbsd5.0.2/i386/gcc-sources.add (added) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-binutils.spec (added) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-gcc.spec (added) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-libs.spec (added) * contrib/crossrpms/netbsd5.0.2/i386/libs.add (added) * contrib/crossrpms/netbsd5.0.2/i386/target-libs.add (added) * contrib/crossrpms/netbsd5.0.2/libs.am (added) New. Mon, 19 Apr 2010 03:42:58 GMT Ralf Corsepius [c7a7580] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add netbsd5.0.2. Fri, 16 Apr 2010 03:11:22 GMT Ralf Corsepius [6832a7e6] * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-binutils.spec (added) * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-gcc.spec (added) * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-libs.spec (added) Generate. Fri, 16 Apr 2010 02:59:47 GMT Ralf Corsepius [73057d5] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add freebsd7.3 Fri, 16 Apr 2010 02:58:45 GMT Ralf Corsepius [a87e7d88] * contrib/crossrpms/freebsd7.3/.cvsignore (added) * contrib/crossrpms/freebsd7.3/Makefile.am (added) * contrib/crossrpms/freebsd7.3/binutils.am (added) * contrib/crossrpms/freebsd7.3/gcc-prep.add (added) * contrib/crossrpms/freebsd7.3/gcc.am (added) * contrib/crossrpms/freebsd7.3/i586/.cvsignore (added) * contrib/crossrpms/freebsd7.3/i586/Makefile.am (added) * contrib/crossrpms/freebsd7.3/i586/binutils-sources.add (added) * contrib/crossrpms/freebsd7.3/i586/gcc-sources.add (added) * contrib/crossrpms/freebsd7.3/i586/libs.add (added) * contrib/crossrpms/freebsd7.3/i586/target-libs.add (added) * contrib/crossrpms/freebsd7.3/libs.am (added) New. Thu, 15 Apr 2010 17:24:46 GMT Ralf Corsepius [ac367f3] * contrib/crossrpms/freebsd6.4/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-binutils.spec (modified) * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-gcc.spec (modified) gcc-4.5.0. Thu, 15 Apr 2010 16:45:48 GMT Ralf Corsepius [062927e] * contrib/crossrpms/freebsd7.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-binutils.spec (modified) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-gcc.spec (modified) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-libs.spec (modified) gcc-4.5.0 Thu, 15 Apr 2010 13:04:35 GMT Ralf Corsepius [5a0f2c7] * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-binutils.spec (modified) * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-gcc.spec (modified) i586-pc-freebsd8.0-gcc.spec Thu, 15 Apr 2010 13:04:23 GMT Ralf Corsepius [3fe45104] * contrib/crossrpms/freebsd8.0/i586/Makefile.am (modified) Upgrade to gcc-4.5.0. Wed, 14 Apr 2010 13:08:34 GMT Ralf Corsepius [65357b7] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Wed, 14 Apr 2010 13:07:29 GMT Ralf Corsepius [663f5012] * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Bump GCC_RPMREL. Wed, 14 Apr 2010 13:07:28 GMT Ralf Corsepius [6e404fa1] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) Bump GCC_RPMREL. Wed, 14 Apr 2010 13:07:27 GMT Ralf Corsepius [0e685c1] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) gcc-4.5.0. Wed, 14 Apr 2010 13:02:25 GMT Ralf Corsepius [01c5291a] * contrib/crossrpms/patches/gcc-core-4.5.0-rtems4.11-20100414.diff (added) New. Fri, 09 Apr 2010 02:56:59 GMT Ralf Corsepius [6d614c47] * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) gcc-4.5.0-RC-20100406. Thu, 08 Apr 2010 14:48:59 GMT Ralf Corsepius [2a5c880] * contrib/crossrpms/patches/gdb-7.0.90-rtems4.10-20100223.diff (deleted) * contrib/crossrpms/patches/gdb-7.0.90-rtems4.10-20100225.diff (deleted) Housekeeping. Thu, 08 Apr 2010 03:25:54 GMT Ralf Corsepius [d38c830] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Thu, 08 Apr 2010 03:24:52 GMT Ralf Corsepius [32c58e1] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Thu, 08 Apr 2010 03:24:28 GMT Ralf Corsepius [0ebf210b] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) gcc-core-4.4.3-rtems4.10-20100315.diff. Thu, 08 Apr 2010 03:00:44 GMT Ralf Corsepius [98c5c02] * contrib/crossrpms/patches/gcc-core-4.5-20100311-rtems4.11-20100317.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.5-20100325-rtems4.11-20100326.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.5-20100325-rtems4.11-20100330.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.5-20100401-rtems4.11-20100402.diff (deleted) Remove (Abandon). Wed, 07 Apr 2010 02:18:56 GMT Ralf Corsepius [68001c02] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Wed, 07 Apr 2010 02:18:21 GMT Ralf Corsepius [66c7307] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) Upgrade to gcc-4.5.0-RC-20100406 Tue, 06 Apr 2010 12:03:34 GMT Ralf Corsepius [74e1fca] * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Tue, 06 Apr 2010 12:01:28 GMT Ralf Corsepius [04d0b90] * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GDB_RPMREL. Tue, 06 Apr 2010 11:56:49 GMT Ralf Corsepius [530d5014] * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) Regenerate. Tue, 06 Apr 2010 11:49:18 GMT Ralf Corsepius [fa664482] * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Bump GDB_RPMREL Tue, 06 Apr 2010 11:31:11 GMT Ralf Corsepius [bcf95dc] * contrib/crossrpms/specstrip (modified) Rework again. Tue, 06 Apr 2010 04:04:01 GMT Ralf Corsepius [b2e0ac6] * contrib/crossrpms/specstrip (modified) Cleanup. Fri, 02 Apr 2010 12:58:50 GMT Ralf Corsepius [e066e31e] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Fri, 02 Apr 2010 12:57:57 GMT Ralf Corsepius [04923e4] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Fri, 02 Apr 2010 12:57:36 GMT Ralf Corsepius [bdd00f2] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.18.0-rtems4.10-20100402.diff Fri, 02 Apr 2010 04:58:05 GMT Ralf Corsepius [0cd4e62] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Fri, 02 Apr 2010 04:57:45 GMT Ralf Corsepius [b54d8f6] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) Update. Fri, 02 Apr 2010 04:35:03 GMT Ralf Corsepius [528b325] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) Bump GCC_RPMREL. Fri, 02 Apr 2010 04:33:03 GMT Ralf Corsepius [6f6cc68a] * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Preps for next spin. Fri, 02 Apr 2010 04:29:41 GMT Ralf Corsepius [ce83d78d] * contrib/crossrpms/patches/gcc-core-4.5-20100401-rtems4.10-20100402.diff (deleted) Remove (bogus). Fri, 02 Apr 2010 04:29:07 GMT Ralf Corsepius [561e6da8] * contrib/crossrpms/patches/gcc-core-4.5-20100401-rtems4.10-20100402.diff (added) * contrib/crossrpms/patches/gcc-core-4.5-20100401-rtems4.11-20100402.diff (added) * contrib/crossrpms/patches/newlib-1.18.0-rtems4.10-20100402.diff (added) New. Thu, 01 Apr 2010 10:46:48 GMT Ralf Corsepius [c3803a64] * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) Regenerate. Thu, 01 Apr 2010 10:46:35 GMT Ralf Corsepius [ac312a41] * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) gcc-4.5-20100325 Thu, 01 Apr 2010 10:44:20 GMT Ralf Corsepius [3f1dd94] * contrib/crossrpms/patches/gcc-core-4.5-20100325-rtems4.11-20100330.diff (added) New. Mon, 29 Mar 2010 13:31:41 GMT Ralf Corsepius [4a23fa97] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Mon, 29 Mar 2010 13:30:46 GMT Ralf Corsepius [0b45f1a2] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GDB_RPMREL. Mon, 29 Mar 2010 04:03:18 GMT Ralf Corsepius [d52beda] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Mon, 29 Mar 2010 04:02:02 GMT Ralf Corsepius [70c28884] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) Bump GCC_RPMREL. Mon, 29 Mar 2010 03:58:01 GMT Ralf Corsepius [8696950] * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Update. Mon, 29 Mar 2010 03:55:48 GMT Ralf Corsepius [6ebfd35c] * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) Update. Mon, 29 Mar 2010 03:52:52 GMT Ralf Corsepius [76daa873] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) newlib-1.18.0-rtems4.10-20100328.diff, gcc- ... Mon, 29 Mar 2010 03:41:49 GMT Ralf Corsepius [bb221a5c] * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) Switch back to gcc-4.4.3 (gcc-4.5 does not build). Mon, 29 Mar 2010 03:38:23 GMT Ralf Corsepius [cad7844] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.18.0-rtems4.10-20100328.diff Mon, 29 Mar 2010 03:35:21 GMT Ralf Corsepius [d754164] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.10-20100328.diff (modified) Regenerate. Mon, 29 Mar 2010 03:23:19 GMT Ralf Corsepius [ad76276a] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Mon, 29 Mar 2010 03:20:04 GMT Ralf Corsepius [751edc83] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.10-20100328.diff (modified) New. Mon, 29 Mar 2010 02:32:35 GMT Ralf Corsepius [0ada0e8] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.10-20100328.diff (added) New. Fri, 26 Mar 2010 17:06:34 GMT Ralf Corsepius [0c1cb8a] * contrib/apt-conf/.cvsignore (deleted) * contrib/apt-conf/COPYING (deleted) * contrib/apt-conf/ChangeLog (deleted) * contrib/apt-conf/INSTALL (deleted) * contrib/apt-conf/Makefile.am (deleted) * contrib/apt-conf/README (deleted) * contrib/apt-conf/configure.ac (deleted) * contrib/apt-conf/gpg/gpg-pubkey-eac29b6f-3fe1f458 (deleted) * contrib/apt-conf/rtems-apt-conf.spec.in (deleted) * contrib/apt-conf/sources.list.d/rtems-4.6.list (deleted) * contrib/apt-conf/sources.list.d/rtems-4.7.list (deleted) * contrib/apt-conf/vendors.list.d/rtems.list (deleted) Remove (obsolete, unused) Fri, 26 Mar 2010 15:27:47 GMT Ralf Corsepius [142490c6] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Abandon cpukit. Fri, 26 Mar 2010 15:26:36 GMT Ralf Corsepius [27e499d] * contrib/crossrpms/rtems4.10/cpukit-prep.add (deleted) * contrib/crossrpms/rtems4.10/cpukit.am (deleted) Abandoned. Fri, 26 Mar 2010 15:24:05 GMT Ralf Corsepius [8d0c0a1] * contrib/crossrpms/rtems4.10/arm/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/avr/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/bfin/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/h8300/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/i386/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/lm32/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/m32c/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/m32r/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/m68k/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/mips/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/powerpc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/sh/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/sparc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (deleted) Abandon. Fri, 26 Mar 2010 09:29:10 GMT Ralf Corsepius [59ecea5] * contrib/crossrpms/patches/gcc-core-4.5-20100325-rtems4.11-20100326.diff (added) Rebase patch against gcc-4.5-20100325. Fri, 26 Mar 2010 09:28:22 GMT Ralf Corsepius [4c59a1b0] * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Fri, 26 Mar 2010 09:28:03 GMT Ralf Corsepius [5a99664a] * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) gcc-4.5-20100325. Thu, 25 Mar 2010 08:13:14 GMT Ralf Corsepius [89bb075] * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) Regenerate. Thu, 25 Mar 2010 08:12:59 GMT Ralf Corsepius [3e9e257] * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) gcc-4.5-20100318. Thu, 25 Mar 2010 06:37:07 GMT Ralf Corsepius [07acedcc] * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) Regenerate. Thu, 25 Mar 2010 06:36:53 GMT Ralf Corsepius [58fce52] * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) gcc-4.5-20100318. Wed, 24 Mar 2010 18:40:36 GMT Ralf Corsepius [b170079] * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) Regenerate. Wed, 24 Mar 2010 18:40:13 GMT Ralf Corsepius [34b91f78] * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) gcc-4.5-20100318 Wed, 24 Mar 2010 03:55:38 GMT Ralf Corsepius [cd010a34] * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) Regenerate. Wed, 24 Mar 2010 03:55:10 GMT Ralf Corsepius [7b3af16] * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) gcc-4.5-20100318. Tue, 23 Mar 2010 14:50:28 GMT Ralf Corsepius [0e5e088] * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) Regenerate. Tue, 23 Mar 2010 14:49:54 GMT Ralf Corsepius [11ba8c5] * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) gcc-4.4-20100318. Mon, 22 Mar 2010 13:58:24 GMT Ralf Corsepius [2fc8e63] * contrib/crossrpms/autotools/rtems-4.11-autoconf.spec (added) * contrib/crossrpms/autotools/rtems-4.11-automake.spec (added) New. Mon, 22 Mar 2010 12:58:20 GMT Ralf Corsepius [e7a21fe0] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Mon, 22 Mar 2010 12:57:01 GMT Ralf Corsepius [12b31895] * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) Disable plugins (broken).
