# # ChangeLog for contrib in rtems # # Generated by Trac 1.2.1.dev0 # 05/20/24 23:51:12 Thu, 09 Mar 2006 05:11:22 GMT Ralf Corsepius [64391f1] * contrib/crossrpms/TODO (modified) Add note on Ada. Thu, 09 Mar 2006 05:07:57 GMT Ralf Corsepius [f26c821] * contrib/crossrpms/NEWS (modified) * contrib/crossrpms/TODO (modified) Update Thu, 09 Mar 2006 03:30:37 GMT Ralf Corsepius [9b7443c] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) Enable fortran and objc Wed, 08 Mar 2006 09:22:44 GMT Ralf Corsepius [f7c8422] * contrib/crossrpms/mingw32/gcc-sources.add (modified) Deactivate PATCH0 (not required for gcc >= 4.1.0 Wed, 08 Mar 2006 09:21:42 GMT Ralf Corsepius [73d88d14] * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Activate fortran and objc Tue, 07 Mar 2006 14:03:01 GMT Ralf Corsepius [a03debd5] * contrib/crossrpms/TODO (added) New. Tue, 07 Mar 2006 13:42:57 GMT Ralf Corsepius [c429c016] * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) Use gcc_rpmvers for subpackage deps. Tue, 07 Mar 2006 09:02:11 GMT Ralf Corsepius [027c603] * contrib/crossrpms/gcc/gccnewlib.add (modified) Use %echo instead of %%echo in %expand Tue, 07 Mar 2006 05:28:35 GMT Ralf Corsepius [9087b7c] * contrib/crossrpms/configure.ac (modified) Fix main package name. Update version. Tue, 07 Mar 2006 05:26:26 GMT Ralf Corsepius [6eba5919] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Distribute local *.add files. Tue, 07 Mar 2006 05:26:08 GMT Ralf Corsepius [0166739] * contrib/crossrpms/rtems/Makefile.am (modified) Distribute local *.add files. Reflect having renamed *-libc.add into ... Tue, 07 Mar 2006 05:24:02 GMT Ralf Corsepius [29ffb1e7] * contrib/crossrpms/Makefile.am (modified) Reflect having renamed gcc/*-libc.add into gcc/*-newlib.add Tue, 07 Mar 2006 03:29:13 GMT Ralf Corsepius [d11d10fe] * contrib/crossrpms/gcc/base-libc.add (deleted) * contrib/crossrpms/gcc/target-libc.add (deleted) Renamed into *-newlib.add Tue, 07 Mar 2006 03:26:23 GMT Ralf Corsepius [2c7efaa7] * contrib/crossrpms/gcc/base-newlib.add (added) * contrib/crossrpms/gcc/target-newlib.add (added) Renamed from *-libc.add to *-newlib.add Mon, 06 Mar 2006 15:43:10 GMT Ralf Corsepius [ab163629] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) GCC_VERS = 4.1.0 Mon, 06 Mar 2006 15:36:59 GMT Ralf Corsepius [5c8f5f66] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Subst gcc_rpmvers for LIB packages. Mon, 06 Mar 2006 05:55:02 GMT Ralf Corsepius [c04a6103] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/libs.add (modified) * contrib/crossrpms/freebsd5.2/libs.add (modified) * contrib/crossrpms/freebsd6.0/libs.add (modified) * contrib/crossrpms/mingw32/libs.add (modified) * contrib/crossrpms/mingw32/w32api.add (modified) * contrib/crossrpms/solaris2.7/libs.add (modified) Remove stray blank in %expand to setup rpmvers. Sat, 04 Mar 2006 06:04:34 GMT Ralf Corsepius [503be14] * contrib/crossrpms/configure.ac (modified) Add osversion hack Fri, 03 Mar 2006 16:58:51 GMT Ralf Corsepius [a3ba1e2d] * contrib/crossrpms/mkspec.am (modified) Propagate osversion. Fri, 03 Mar 2006 16:56:57 GMT Ralf Corsepius [82e0551] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Add gfortran. Add objc. Wed, 01 Mar 2006 16:43:29 GMT Ralf Corsepius [6355f04] * contrib/crossrpms/rtems/Makefile.am (modified) Remove --sysroot Wed, 01 Mar 2006 16:42:51 GMT Ralf Corsepius [d257306] * contrib/crossrpms/gcc/install.add (modified) gcc-4.1.0 still has issues with mudflap. Tue, 28 Feb 2006 23:09:54 GMT Ralf Corsepius [87f443cc] * contrib/crossrpms/binutils/build.add (modified) Add --with-sysroot (Required by GCC-4.1.0) Mon, 27 Feb 2006 18:03:23 GMT Ralf Corsepius [e25d8c9] * contrib/crossrpms/gcc/prep.add (modified) Revert to cd'ing into gcc-%{gcc_version} for gcc_update Sat, 25 Feb 2006 04:52:44 GMT Ralf Corsepius [2f9c5897] * contrib/crossrpms/binutils/rpm-install.add (modified) * contrib/crossrpms/gcc/rpm-install.add (modified) Fix stupid typo. Sat, 25 Feb 2006 04:50:13 GMT Ralf Corsepius [740d8240] * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) Use gcc_rpmvers to setup Version: Sat, 25 Feb 2006 03:28:52 GMT Ralf Corsepius [2aba80d3] * contrib/crossrpms/NEWS (modified) GPL. Sat, 25 Feb 2006 03:27:17 GMT Ralf Corsepius [975e0f75] * contrib/crossrpms/README (modified) Add my Copyright blurb. Sat, 25 Feb 2006 03:23:34 GMT Ralf Corsepius [00565e4] * contrib/crossrpms/AUTHORS (added) * contrib/crossrpms/COPYING (added) * contrib/crossrpms/ChangeLog (added) * contrib/crossrpms/NEWS (added) * contrib/crossrpms/README (added) New. Fri, 24 Feb 2006 15:46:17 GMT Ralf Corsepius [c046309] * contrib/crossrpms/gcc/rpm-install.add (modified) Use %{_builddir}/%{name}-%{gcc_rpmvers}/find-* to work around ... Fri, 24 Feb 2006 15:28:02 GMT Ralf Corsepius [5e52a84] * contrib/crossrpms/gcc/build.add (modified) Invoke gcc-%{gcc_version}/configure Fri, 24 Feb 2006 15:27:07 GMT Ralf Corsepius [06fb9c3] * contrib/crossrpms/gcc/prep.add (modified) Add @PREP@, remove RTEMS version magic Fri, 24 Feb 2006 15:24:03 GMT Ralf Corsepius [102c876] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Add gcc-prep.add Fri, 24 Feb 2006 15:20:39 GMT Ralf Corsepius [255d476] * contrib/crossrpms/configure.ac (modified) Remove no-define foreign from AM_INIT_AUTOMAKE. Fri, 24 Feb 2006 15:04:25 GMT Ralf Corsepius [ef607c60] * contrib/crossrpms/cygwin/gcc-prep.add (added) * contrib/crossrpms/freebsd5.2/gcc-prep.add (added) * contrib/crossrpms/freebsd6.0/gcc-prep.add (added) * contrib/crossrpms/mingw32/gcc-prep.add (added) * contrib/crossrpms/rtems/gcc-prep.add (added) * contrib/crossrpms/solaris2.7/gcc-prep.add (added) New. Fri, 24 Feb 2006 07:26:51 GMT Ralf Corsepius [61b0cc6] * contrib/crossrpms/gcc/install.add (modified) Allow shared libgfortran Wed, 22 Feb 2006 13:02:32 GMT Ralf Corsepius [0d0560a1] * contrib/crossrpms/cygwin/binutils-sources.add (modified) * contrib/crossrpms/cygwin/gcc-sources.add (modified) * contrib/crossrpms/freebsd5.2/binutils-sources.add (modified) * contrib/crossrpms/freebsd5.2/gcc-sources.add (modified) * contrib/crossrpms/freebsd6.0/binutils-sources.add (modified) * contrib/crossrpms/freebsd6.0/gcc-sources.add (modified) * contrib/crossrpms/mingw32/binutils-sources.add (modified) * contrib/crossrpms/mingw32/gcc-sources.add (modified) * contrib/crossrpms/rtems/binutils-sources.add (modified) * contrib/crossrpms/rtems/gcc-sources.add (modified) * contrib/crossrpms/solaris2.7/binutils-sources.add (modified) * contrib/crossrpms/solaris2.7/gcc-sources.add (modified) Cosmetics. Wed, 22 Feb 2006 11:54:10 GMT Ralf Corsepius [c8956fd7] * contrib/crossrpms/gcc/rpm-install.add (modified) Use gcc_version instead of %version, to work around rpm screwing up ... Wed, 22 Feb 2006 11:52:41 GMT Ralf Corsepius [70aecfc] * contrib/crossrpms/gcc/install.add (modified) Run make install-info to get the newlib infos Wed, 22 Feb 2006 07:48:31 GMT Ralf Corsepius [323f178] * contrib/crossrpms/gcc/install.add (modified) Cleanup comment on vxaddr2line. Wed, 22 Feb 2006 07:45:45 GMT Ralf Corsepius [7afdf54c] * contrib/crossrpms/binutils/rpm-install.add (modified) * contrib/crossrpms/gcc/rpm-install.add (modified) Add ",g" in sed call to propagate _prefix to brp-compress. Wed, 22 Feb 2006 06:35:50 GMT Ralf Corsepius [c2dade8] * contrib/crossrpms/binutils/rpm-install.add (modified) * contrib/crossrpms/gcc/rpm-install.add (modified) Correct /-handling Wed, 22 Feb 2006 03:03:29 GMT Ralf Corsepius [c18cad7] * contrib/cygwin/.cvsignore (deleted) * contrib/cygwin/ChangeLog (deleted) * contrib/cygwin/Makefile.am (deleted) * contrib/cygwin/configure.ac (deleted) * contrib/cygwin/i686-pc-cygwin-binutils.spec.in (deleted) * contrib/cygwin/i686-pc-cygwin-gcc.spec.in (deleted) * contrib/cygwin/i686-pc-cygwin-libs.spec.in (deleted) * contrib/cygwin/i686-pc-cygwin-mingw.spec.in (deleted) * contrib/cygwin/i686-pc-cygwin-w32api.spec.in (deleted) * contrib/cygwin/setup (deleted) * contrib/cygwin/setup.def (deleted) * contrib/freebsd/.cvsignore (deleted) * contrib/freebsd/Makefile.am (deleted) * contrib/freebsd/configure.ac (deleted) * contrib/freebsd/i386-freebsd-binutils.spec.in (deleted) * contrib/freebsd/i386-freebsd-gcc.spec.in (deleted) * contrib/freebsd/i386-freebsd-libs.spec.in (deleted) * contrib/solaris/.cvsignore (deleted) Remove. Wed, 22 Feb 2006 02:59:55 GMT Ralf Corsepius [4af30d8] * contrib/solaris/ChangeLog (deleted) * contrib/solaris/Makefile.am (deleted) * contrib/solaris/configure.ac (deleted) * contrib/solaris/setup (deleted) * contrib/solaris/setup.def (deleted) * contrib/solaris/sparc-solaris-binutils.spec.in (deleted) * contrib/solaris/sparc-solaris-gcc.spec.in (deleted) * contrib/solaris/sparc-solaris-libs.spec.in (deleted) Remove Tue, 21 Feb 2006 11:43:47 GMT Ralf Corsepius [52970c21] * contrib/crossrpms/freebsd5.2/libs.add (modified) * contrib/crossrpms/freebsd6.0/libs.add (modified) Silence the tar calls. Tue, 21 Feb 2006 10:27:52 GMT Ralf Corsepius [4077a78] * contrib/crossrpms/mkspec.am (modified) Add @tool_target@-gcc hacks. Tue, 21 Feb 2006 10:27:25 GMT Ralf Corsepius [cb185ee] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Remove @tool_target@-gcc hacks. Tue, 21 Feb 2006 10:23:26 GMT Ralf Corsepius [0f3d1bb] * contrib/crossrpms/configure.ac (modified) Ignore unsupported targets. Tue, 21 Feb 2006 10:21:29 GMT Ralf Corsepius [fccf862] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Delete refs to *-w32api-sys-root packages in *-gcc.spec.in Tue, 21 Feb 2006 10:14:30 GMT Ralf Corsepius [ce3cc41e] * contrib/crossrpms/rtems/Makefile.am (modified) Delete refs to *-sys-root packages in *-gcc.spec.in Tue, 21 Feb 2006 10:11:07 GMT Ralf Corsepius [3072c09] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Delete refs to *-newlib packages in *-gcc.spec.in Tue, 21 Feb 2006 08:47:54 GMT Ralf Corsepius [c665ca3] * contrib/crossrpms/gcc/base-libc.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) Rename libc to newlib. Tue, 21 Feb 2006 08:46:16 GMT Ralf Corsepius [d70a677] * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gcc/target-libc.add (modified) Rename files.libc to files.newlib. Tue, 21 Feb 2006 08:36:05 GMT Ralf Corsepius [147427ca] * contrib/crossrpms/rtems/Makefile.am (modified) Re-add BINUTILS_*, GCC_* Tue, 21 Feb 2006 08:22:53 GMT Ralf Corsepius [8b479480] * contrib/crossrpms/mkspec.am (modified) Add osversion Tue, 21 Feb 2006 08:22:43 GMT Ralf Corsepius [a310f56] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate osversion Tue, 21 Feb 2006 08:18:29 GMT Ralf Corsepius [1259c55] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate newlib_version Tue, 21 Feb 2006 08:14:06 GMT Ralf Corsepius [14179bab] * contrib/crossrpms/mingw32/Makefile.am (modified) Use $(MKSPEC) to generate *-w32api.spec. Tue, 21 Feb 2006 08:12:54 GMT Ralf Corsepius [42b1efb8] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Use $(MKSPEC) to generate *-binutils.spec. Tue, 21 Feb 2006 08:12:10 GMT Ralf Corsepius [fe977c7] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Use $(MKSPEC) to generate *-gcc.spec. Tue, 21 Feb 2006 08:10:46 GMT Ralf Corsepius [773ab4f] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Use $(MKSPEC) to generate *-libs.spec. Tue, 21 Feb 2006 07:54:50 GMT Ralf Corsepius [f538086] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Include ../mkspec.am Tue, 21 Feb 2006 07:48:59 GMT Ralf Corsepius [026e27dc] * contrib/crossrpms/mkspec.am (added) New. Mon, 20 Feb 2006 16:37:01 GMT Ralf Corsepius [dd3a261] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Backup. Mon, 20 Feb 2006 16:27:09 GMT Ralf Corsepius [f058946] * contrib/crossrpms/binutils/install.add (modified) Unconditionally remove configure.info, because cygwin still ships it:( Mon, 20 Feb 2006 14:25:14 GMT Ralf Corsepius [3596fee] * contrib/crossrpms/gcc/gccnewlib.add (modified) Require/BuildRequire: w32api-sys-root, Remove a comment. Mon, 20 Feb 2006 14:02:46 GMT Ralf Corsepius [c7373465] * contrib/crossrpms/gcc/rpm-install.add (modified) Add blank line. Mon, 20 Feb 2006 14:00:55 GMT Ralf Corsepius [b7cd78c1] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Backup. Mon, 20 Feb 2006 07:50:18 GMT Ralf Corsepius [d31a75a] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Apply @rpmprefix@ to *.spec files. Sun, 19 Feb 2006 15:17:05 GMT Ralf Corsepius [3d612dc4] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Use package version as RPMREL. Sun, 19 Feb 2006 05:07:37 GMT Ralf Corsepius [ca2b4f3] * contrib/crossrpms/rtems/Makefile.am (modified) Apply target_alias to setup TARGET. Sun, 19 Feb 2006 05:06:31 GMT Ralf Corsepius [392c841] * contrib/crossrpms/Makefile.am (modified) Add TARGET_SUBDIRS Sun, 19 Feb 2006 05:06:06 GMT Ralf Corsepius [0ce942a] * contrib/crossrpms/configure.ac (modified) Add AC_CANONICAL_TARGET. Apply target magic to setup rtems. Sat, 18 Feb 2006 14:47:46 GMT Ralf Corsepius [9827ed6f] * contrib/crossrpms/gcc/target-gcc.add (modified) Comment out @tool_target@-gcc %package Sat, 18 Feb 2006 14:45:38 GMT Ralf Corsepius [1c9d6de] * contrib/crossrpms/rtems/Makefile.am (modified) delete sysroot related lines from *gcc.spec Sat, 18 Feb 2006 14:42:05 GMT Ralf Corsepius [38da76ea] * contrib/crossrpms/mingw32/Makefile.am (modified) Switch off _cxx Sat, 18 Feb 2006 11:15:13 GMT Ralf Corsepius [403d2176] * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/rtems/Makefile.am (modified) Add NEWLIB_VERS Sat, 18 Feb 2006 11:13:26 GMT Ralf Corsepius [e3bd4a3] * contrib/crossrpms/gcc/base-gcc.add (modified) Reflect newlib having been split out Sat, 18 Feb 2006 11:11:51 GMT Ralf Corsepius [1b8fc3e4] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Add binutils/prep.add, binutils/build.add binutils/install.add Sat, 18 Feb 2006 11:10:22 GMT Ralf Corsepius [6cc81d31] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Cosmetics. Sat, 18 Feb 2006 11:07:18 GMT Ralf Corsepius [00a9702b] * contrib/crossrpms/binutils/binutils.add (modified) Split out prep, build, install Sat, 18 Feb 2006 11:06:56 GMT Ralf Corsepius [14653c86] * contrib/crossrpms/binutils/build.add (added) * contrib/crossrpms/binutils/install.add (added) * contrib/crossrpms/binutils/prep.add (added) New. Sat, 18 Feb 2006 09:03:22 GMT Ralf Corsepius [31ca289a] * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) Add @rpmprefix@ in comments. Sat, 18 Feb 2006 09:00:56 GMT Ralf Corsepius [82880e5] * contrib/crossrpms/gcc/gccnewlib.add (modified) Remove hard-coded default for _cxx for mingw Sat, 18 Feb 2006 08:03:36 GMT Ralf Corsepius [fd1eb5a] * contrib/crossrpms/gcc/gccnewlib.add (modified) Remove %prep, %build Sat, 18 Feb 2006 08:02:54 GMT Ralf Corsepius [384fa937] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Reflect having split out gcc/prep.add and gcc/build.add Sat, 18 Feb 2006 08:01:11 GMT Ralf Corsepius [c7cc52a] * contrib/crossrpms/gcc/build.add (added) * contrib/crossrpms/gcc/prep.add (added) New. Sat, 18 Feb 2006 06:53:57 GMT Ralf Corsepius [9d07966e] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Misc. sed magic. Sat, 18 Feb 2006 05:17:08 GMT Ralf Corsepius [89d2e86] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Sed out %package -n @rpmprefix@@tool_target@-gcc from *gcc.spec Fri, 17 Feb 2006 20:31:11 GMT Ralf Corsepius [4a35072] * contrib/crossrpms/rtems/Makefile.am (modified) Add target-libc.add base-libc.add Fri, 17 Feb 2006 20:30:18 GMT Ralf Corsepius [e94d6430] * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-libc.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) Cosmetics. Fri, 17 Feb 2006 20:24:52 GMT Ralf Corsepius [85829b5] * contrib/crossrpms/gcc/base-gfortran.add (modified) Cosmetics Fri, 17 Feb 2006 20:24:15 GMT Ralf Corsepius [89864278] * contrib/crossrpms/gcc/target-libc.add (modified) Add %build_newlib guard Fri, 17 Feb 2006 20:22:58 GMT Ralf Corsepius [b780f00] * contrib/crossrpms/gcc/base-libc.add (added) New. Fri, 17 Feb 2006 19:43:37 GMT Ralf Corsepius [ce1402f] * contrib/crossrpms/gcc/base-gcc.add (modified) Install newlib infos only if building newlib Fri, 17 Feb 2006 15:49:16 GMT Ralf Corsepius [149930b1] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Let *.spec.in depend on Makefile.am Fri, 17 Feb 2006 15:45:13 GMT Ralf Corsepius [2fb29308] * contrib/crossrpms/mingw32/Makefile.am (modified) Increment release numbers Fri, 17 Feb 2006 15:44:28 GMT Ralf Corsepius [0d349d29] * contrib/crossrpms/cygwin/libs.add (modified) * contrib/crossrpms/freebsd5.2/libs.add (modified) * contrib/crossrpms/freebsd6.0/libs.add (modified) * contrib/crossrpms/solaris2.7/libs.add (modified) Use %{__tar} instead of plain tar Fri, 17 Feb 2006 15:25:34 GMT Ralf Corsepius [0cc0a8b6] * contrib/crossrpms/freebsd6.0/libs.add (modified) Use @FREEBSD_VERS@ instead of hard-coded 6.0 Fri, 17 Feb 2006 15:22:03 GMT Ralf Corsepius [79a3e1b] * contrib/crossrpms/cygwin/Makefile.am (modified) Add libs.add target-libs.add
