# # ChangeLog for contrib in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/24 09:11:53 Tue, 11 Jul 2006 03:28:44 GMT Ralf Corsepius [61d66ffb] * contrib/crossrpms/rtems4.7/m68k/binutils-sources.add (modified) Add binutils-2.17-rtems-20060711.diff. Tue, 11 Jul 2006 03:28:02 GMT Ralf Corsepius [9807f04] * contrib/crossrpms/patches/binutils-2.17-rtems-20060711.diff (added) New. m68k/cpu32 patch. Sun, 09 Jul 2006 05:22:06 GMT Ralf Corsepius [a650ebb1] * contrib/crossrpms/solaris2.7/gcc.am (added) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/binutils-sources.add (modified) Sync from freebsd6.1 Sat, 08 Jul 2006 05:57:32 GMT Ralf Corsepius [08cbfbce] * contrib/crossrpms/freebsd5.2/i586/binutils-sources.add (modified) * contrib/crossrpms/freebsd6.0/i586/binutils-sources.add (modified) * contrib/crossrpms/freebsd6.1/i586/binutils-sources.add (modified) Sync. Sat, 08 Jul 2006 05:56:39 GMT Ralf Corsepius [fc4d7d2] * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) Update to binutils-2.17, gcc-4.1.1 Fri, 07 Jul 2006 09:02:17 GMT Ralf Corsepius [a3182b55] * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) Split out GCC. Fri, 07 Jul 2006 09:01:47 GMT Ralf Corsepius [0767028] * contrib/crossrpms/freebsd5.2/gcc.am (added) * contrib/crossrpms/freebsd6.0/gcc.am (added) * contrib/crossrpms/freebsd6.1/gcc.am (added) New. Fri, 07 Jul 2006 07:04:53 GMT Ralf Corsepius [80bd514f] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Split out binutils. Fri, 07 Jul 2006 07:03:21 GMT Ralf Corsepius [394555c] * contrib/crossrpms/freebsd5.2/binutils.am (added) * contrib/crossrpms/freebsd6.0/binutils.am (added) * contrib/crossrpms/freebsd6.1/binutils.am (added) * contrib/crossrpms/solaris2.7/binutils.am (added) New. Fri, 07 Jul 2006 05:02:39 GMT Ralf Corsepius [0f9fd94f] * contrib/crossrpms/cygwin/binutils.am (added) * contrib/crossrpms/mingw32/binutils.am (added) New. Fri, 07 Jul 2006 04:58:19 GMT Ralf Corsepius [7df0f40e] * contrib/crossrpms/rtems4.7/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.7/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.7/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.7/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.7/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/tic4x/Makefile.am (modified) Use relative dirs to automake fragments. Fri, 07 Jul 2006 04:57:49 GMT Ralf Corsepius [6c53b7a] * contrib/crossrpms/rtems4.7/gcc-prep.add (modified) Add leading blank to version string. Fri, 07 Jul 2006 03:35:46 GMT Ralf Corsepius [7fa51bb] * contrib/crossrpms/Makefile.am (modified) Use $(srcdir)/patches/*.diff to make make dist happy Fri, 07 Jul 2006 03:34:53 GMT Ralf Corsepius [748c2019] * contrib/crossrpms/configure.ac (modified) Bump version. Fri, 07 Jul 2006 03:34:06 GMT Ralf Corsepius [3cf21a25] * contrib/crossrpms/rtems4.7/avr/Makefile.am (modified) Add GCC_OPTS. Fri, 07 Jul 2006 03:33:31 GMT Ralf Corsepius [9e9cf678] * contrib/crossrpms/rtems4.7/tic4x/Makefile.am (modified) Comment out gdb. Fri, 07 Jul 2006 03:33:00 GMT Ralf Corsepius [a53af803] * contrib/crossrpms/rtems4.7/gcc-prep.add (modified) Reflex setting up version string has changed in gcc-4.1.0 Fri, 07 Jul 2006 03:32:13 GMT Ralf Corsepius [309cd3f0] * contrib/crossrpms/rtems4.7/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (modified) Fix stupid typo Thu, 06 Jul 2006 13:39:05 GMT Ralf Corsepius [9b88fb3] * contrib/crossrpms/rtems/.cvsignore (deleted) * contrib/crossrpms/rtems/Makefile.am (deleted) * contrib/crossrpms/rtems/binutils-sources.add (deleted) * contrib/crossrpms/rtems/gcc-prep.add (deleted) * contrib/crossrpms/rtems/gcc-sources.add (deleted) * contrib/crossrpms/rtems/gdb-sources.add (deleted) Remove. Thu, 06 Jul 2006 13:19:11 GMT Ralf Corsepius [c484d2ef] * contrib/crossrpms/patches/gdb-6.4-rtems-20060311.diff (added) New. Wed, 05 Jul 2006 15:30:05 GMT Ralf Corsepius [05fac2c] * contrib/crossrpms/gdb/gdb.add (modified) Remove build_infos Wed, 05 Jul 2006 15:29:03 GMT Ralf Corsepius [65e2634] * contrib/crossrpms/common/common.add (modified) Move %define _prefix inside of %if/%endif Wed, 05 Jul 2006 15:25:32 GMT Ralf Corsepius [b4c81f7] * contrib/crossrpms/rtems4.7/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (modified) Sync. Wed, 05 Jul 2006 14:22:52 GMT Ralf Corsepius [72f8c0c6] * contrib/crossrpms/patches/binutils-2.16.1-rtems-20050708.diff (added) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060626.diff (added) New. Wed, 05 Jul 2006 14:18:00 GMT Ralf Corsepius [9a70e14] * contrib/crossrpms/rtems4.7/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/binutils-sources.add (modified) Sync with other rtems4.7 targets. Wed, 05 Jul 2006 13:23:37 GMT Ralf Corsepius [2a9cd34] * contrib/crossrpms/Makefile.am (modified) Add patches/*.diff to EXTRA_DIST Wed, 05 Jul 2006 13:21:52 GMT Ralf Corsepius [6caac6d] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060704.diff (added) New. Wed, 05 Jul 2006 09:11:23 GMT Ralf Corsepius [749361d] * contrib/crossrpms/configure.ac (modified) Bump version. Wed, 05 Jul 2006 09:10:02 GMT Ralf Corsepius [f82ddbe4] * contrib/crossrpms/configure.ac (modified) Eliminate target_os Wed, 05 Jul 2006 09:08:05 GMT Ralf Corsepius [d90e3387] * contrib/crossrpms/configure.ac (modified) Remove AC_CANONICAL_TARGET. Wed, 05 Jul 2006 09:06:24 GMT Ralf Corsepius [15fcf913] * contrib/crossrpms/configure.ac (modified) Add --enable-targets. Wed, 05 Jul 2006 08:55:51 GMT Ralf Corsepius [4fea6f06] * contrib/crossrpms/configure.ac (modified) Add new AC_CONFIG_FILES. Wed, 05 Jul 2006 08:52:45 GMT Ralf Corsepius [4f66134] * contrib/crossrpms/rtems4.7/gcc.am (modified) Do not subst build_newlib. Wed, 05 Jul 2006 08:49:34 GMT Ralf Corsepius [055f31e5] * contrib/crossrpms/Makefile.am (modified) Cleanup EXTRA_DIST Wed, 05 Jul 2006 08:48:47 GMT Ralf Corsepius [da0c2a1d] * contrib/crossrpms/gcc/gccnewlib.add (modified) Remove unused constructs. Wed, 05 Jul 2006 08:42:42 GMT Ralf Corsepius [c77cc1de] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) EXTRA_DIST += ../gcc-prep.add Wed, 05 Jul 2006 08:36:52 GMT Ralf Corsepius [3ab5794] * contrib/crossrpms/acinclude.m4 (added) New. Wed, 05 Jul 2006 08:34:18 GMT Ralf Corsepius [db66352] * contrib/crossrpms/Makefile.am (modified) Remove RPM_OS, rtems/ Wed, 05 Jul 2006 08:24:05 GMT Ralf Corsepius [a56b23b] * contrib/crossrpms/Makefile.am (modified) Add rtems4.7, freebsd6.1 Wed, 05 Jul 2006 08:22:27 GMT Ralf Corsepius [da52805] * contrib/crossrpms/specstrip (modified) Cosmetics. Wed, 05 Jul 2006 08:15:58 GMT Ralf Corsepius [bc51e6ab] * contrib/crossrpms/rtems4.7/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gdb-sources.add (modified) Package sources by default. Wed, 05 Jul 2006 08:05:56 GMT Ralf Corsepius [a98d1937] * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) Sync freebsd*/*/Makefile.ams Wed, 05 Jul 2006 07:38:53 GMT Ralf Corsepius [b7e8b3e] * contrib/crossrpms/cygwin/.cvsignore (modified) * contrib/crossrpms/freebsd5.2/.cvsignore (modified) * contrib/crossrpms/freebsd6.0/.cvsignore (modified) * contrib/crossrpms/freebsd6.1/.cvsignore (modified) * contrib/crossrpms/mingw32/.cvsignore (modified) * contrib/crossrpms/solaris2.7/.cvsignore (modified) Reflect changes. Wed, 05 Jul 2006 07:37:04 GMT Ralf Corsepius [1f193a8b] * contrib/crossrpms/cygwin/i686/.cvsignore (added) * contrib/crossrpms/freebsd5.2/i586/.cvsignore (added) * contrib/crossrpms/freebsd6.0/i586/.cvsignore (added) * contrib/crossrpms/freebsd6.1/i586/.cvsignore (added) * contrib/crossrpms/mingw32/i686/.cvsignore (added) * contrib/crossrpms/solaris2.7/sparc/.cvsignore (added) New. Wed, 05 Jul 2006 07:32:19 GMT Ralf Corsepius [478a318] * contrib/crossrpms/cygwin/binutils-sources.add (deleted) * contrib/crossrpms/cygwin/gcc-sources.add (deleted) * contrib/crossrpms/cygwin/libs.add (deleted) * contrib/crossrpms/cygwin/target-libs.add (deleted) * contrib/crossrpms/cygwin/target-w32api.add (deleted) * contrib/crossrpms/cygwin/w32api.add (deleted) * contrib/crossrpms/freebsd5.2/binutils-sources.add (deleted) * contrib/crossrpms/freebsd5.2/gcc-sources.add (deleted) * contrib/crossrpms/freebsd5.2/libs.add (deleted) * contrib/crossrpms/freebsd5.2/target-libs.add (deleted) * contrib/crossrpms/freebsd6.0/binutils-sources.add (deleted) * contrib/crossrpms/freebsd6.0/gcc-sources.add (deleted) * contrib/crossrpms/freebsd6.0/libs.add (deleted) * contrib/crossrpms/freebsd6.0/target-libs.add (deleted) * contrib/crossrpms/freebsd6.1/binutils-sources.add (deleted) * contrib/crossrpms/freebsd6.1/gcc-sources.add (deleted) * contrib/crossrpms/freebsd6.1/libs.add (deleted) * contrib/crossrpms/freebsd6.1/target-libs.add (deleted) * contrib/crossrpms/mingw32/binutils-sources.add (deleted) * contrib/crossrpms/mingw32/gcc-sources.add (deleted) * contrib/crossrpms/mingw32/libs.add (deleted) * contrib/crossrpms/mingw32/target-libs.add (deleted) * contrib/crossrpms/mingw32/target-w32api.add (deleted) * contrib/crossrpms/mingw32/w32api.add (deleted) * contrib/crossrpms/solaris2.7/binutils-sources.add (deleted) * contrib/crossrpms/solaris2.7/gcc-sources.add (deleted) * contrib/crossrpms/solaris2.7/libs.add (deleted) * contrib/crossrpms/solaris2.7/target-libs.add (deleted) Remove. Wed, 05 Jul 2006 07:31:07 GMT Ralf Corsepius [f5638da] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) New. Wed, 05 Jul 2006 07:29:55 GMT Ralf Corsepius [120c2980] * contrib/crossrpms/cygwin/i686/Makefile.am (added) * contrib/crossrpms/cygwin/i686/binutils-sources.add (added) * contrib/crossrpms/cygwin/i686/gcc-sources.add (added) * contrib/crossrpms/cygwin/i686/libs.add (added) * contrib/crossrpms/cygwin/i686/target-libs.add (added) * contrib/crossrpms/cygwin/i686/target-w32api.add (added) * contrib/crossrpms/cygwin/i686/w32api.add (added) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (added) * contrib/crossrpms/freebsd5.2/i586/binutils-sources.add (added) * contrib/crossrpms/freebsd5.2/i586/gcc-prep.add (added) * contrib/crossrpms/freebsd5.2/i586/gcc-sources.add (added) * contrib/crossrpms/freebsd5.2/i586/libs.add (added) * contrib/crossrpms/freebsd5.2/i586/target-libs.add (added) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (added) * contrib/crossrpms/freebsd6.0/i586/binutils-sources.add (added) * contrib/crossrpms/freebsd6.0/i586/gcc-sources.add (added) * contrib/crossrpms/freebsd6.0/i586/libs.add (added) * contrib/crossrpms/freebsd6.0/i586/target-libs.add (added) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (added) * contrib/crossrpms/freebsd6.1/i586/binutils-sources.add (added) * contrib/crossrpms/freebsd6.1/i586/gcc-sources.add (added) * contrib/crossrpms/freebsd6.1/i586/libs.add (added) * contrib/crossrpms/freebsd6.1/i586/target-libs.add (added) * contrib/crossrpms/mingw32/i686/Makefile.am (added) * contrib/crossrpms/mingw32/i686/binutils-sources.add (added) * contrib/crossrpms/mingw32/i686/gcc-sources.add (added) * contrib/crossrpms/mingw32/i686/libs.add (added) * contrib/crossrpms/mingw32/i686/target-libs.add (added) * contrib/crossrpms/mingw32/i686/target-w32api.add (added) * contrib/crossrpms/mingw32/i686/w32api.add (added) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (added) * contrib/crossrpms/solaris2.7/sparc/binutils-sources.add (added) * contrib/crossrpms/solaris2.7/sparc/gcc-sources.add (added) * contrib/crossrpms/solaris2.7/sparc/libs.add (added) * contrib/crossrpms/solaris2.7/sparc/target-libs.add (added) Moved from .. Tue, 04 Jul 2006 15:52:53 GMT Ralf Corsepius [88744c95] * contrib/crossrpms/freebsd6.1/Makefile.am (modified) Fix ugly typo Tue, 04 Jul 2006 15:41:24 GMT Ralf Corsepius [5727b17] * contrib/crossrpms/rtems4.7/arm/.cvsignore (added) * contrib/crossrpms/rtems4.7/arm/Makefile.am (added) * contrib/crossrpms/rtems4.7/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.7/avr/.cvsignore (added) * contrib/crossrpms/rtems4.7/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.7/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.7/i386/.cvsignore (added) * contrib/crossrpms/rtems4.7/i386/Makefile.am (added) * contrib/crossrpms/rtems4.7/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.7/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.7/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.7/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.7/mips/.cvsignore (added) * contrib/crossrpms/rtems4.7/mips/Makefile.am (added) * contrib/crossrpms/rtems4.7/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.7/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.7/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.7/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.7/sh/.cvsignore (added) * contrib/crossrpms/rtems4.7/sh/Makefile.am (added) * contrib/crossrpms/rtems4.7/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.7/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.7/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.7/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.7/tic4x/.cvsignore (added) New. Tue, 04 Jul 2006 15:33:56 GMT Ralf Corsepius [b63e4ba] * contrib/crossrpms/rtems4.7/.cvsignore (added) * contrib/crossrpms/rtems4.7/Makefile.am (added) * contrib/crossrpms/rtems4.7/avr/Makefile.am (added) * contrib/crossrpms/rtems4.7/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.7/binutils.am (added) * contrib/crossrpms/rtems4.7/gcc-prep.add (added) * contrib/crossrpms/rtems4.7/gcc.am (added) * contrib/crossrpms/rtems4.7/gdb.am (added) * contrib/crossrpms/rtems4.7/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.7/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/tic4x/gdb-sources.add (added) New. Mon, 03 Jul 2006 17:19:32 GMT Ralf Corsepius [c34612ce] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Reflect new mkspec. Mon, 03 Jul 2006 17:17:20 GMT Ralf Corsepius [611845b] * contrib/crossrpms/mkspec.am (modified) Move noinst_DATA, CLEANFILES, EXTRA_DIST to mkspec.am Mon, 03 Jul 2006 14:33:13 GMT Ralf Corsepius [9f5f501f] * contrib/crossrpms/mingw32/Makefile.am (modified) Apply SPECSTRIP. Mon, 03 Jul 2006 14:32:12 GMT Ralf Corsepius [ae03064c] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Apply SPECSTRIP. Build f95 Mon, 03 Jul 2006 14:27:48 GMT Ralf Corsepius [21920c51] * contrib/crossrpms/cygwin/Makefile.am (modified) Apply SPECSTRIP Sun, 25 Jun 2006 04:13:33 GMT Ralf Corsepius [81e7cd80] * contrib/crossrpms/configure.ac (modified) Fix typo in previous change Sun, 25 Jun 2006 04:08:59 GMT Ralf Corsepius [ad8e65e] * contrib/crossrpms/configure.ac (modified) Bump version Sun, 25 Jun 2006 03:59:02 GMT Ralf Corsepius [b38a934b] * contrib/crossrpms/mkspec.am (modified) Add SPECSTRIP Sun, 25 Jun 2006 03:53:32 GMT Ralf Corsepius [c57fb63e] * contrib/crossrpms/Makefile.am (modified) Add specstrip Sun, 25 Jun 2006 03:51:37 GMT Ralf Corsepius [ff5bd63] * contrib/crossrpms/specstrip (added) New. Wed, 21 Jun 2006 03:56:24 GMT Ralf Corsepius [cdd1564] * contrib/crossrpms/gcc/install.add (modified) GCC-4.1.1 still installs mf-runtime.h to the wrong directory. Tue, 20 Jun 2006 16:40:41 GMT Ralf Corsepius [e8a6236] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) * contrib/crossrpms/binutils/install.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Replace %{build_infos} with %build_infos. Tue, 20 Jun 2006 12:09:37 GMT Ralf Corsepius [8c311120] * contrib/crossrpms/freebsd5.2/libs.add (modified) Use star to untar the sources Tue, 20 Jun 2006 09:51:02 GMT Ralf Corsepius [c4d4e15] * contrib/crossrpms/configure.ac (modified) Add freebsd6.1 Mon, 19 Jun 2006 07:00:05 GMT Ralf Corsepius [677c3d81] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) More preps for VPATH builds. Sun, 18 Jun 2006 07:13:14 GMT Ralf Corsepius [e8213f3] * contrib/crossrpms/freebsd6.1/libs.add (modified) Update. Sat, 17 Jun 2006 08:42:09 GMT Ralf Corsepius [90deee12] * contrib/crossrpms/configure.ac (modified) Bump version. Add freebsd6.1 Sat, 17 Jun 2006 08:41:16 GMT Ralf Corsepius [918c6a9] * contrib/crossrpms/freebsd6.1/.cvsignore (added) * contrib/crossrpms/freebsd6.1/Makefile.am (added) * contrib/crossrpms/freebsd6.1/binutils-sources.add (added) * contrib/crossrpms/freebsd6.1/gcc-prep.add (added) * contrib/crossrpms/freebsd6.1/gcc-sources.add (added) * contrib/crossrpms/freebsd6.1/libs.add (added) * contrib/crossrpms/freebsd6.1/target-libs.add (added) New. Sat, 17 Jun 2006 08:40:24 GMT Ralf Corsepius [8ae43f2] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) Preps for VPATH builts. Sat, 17 Jun 2006 08:39:38 GMT Ralf Corsepius [a6f99a45] * contrib/crossrpms/freebsd6.0/libs.add (modified) Use star instead of tar. Thu, 08 Jun 2006 15:07:30 GMT Ralf Corsepius [549e88f] * contrib/crossrpms/rtems/Makefile.am (modified) Preps for VPATH builts. Thu, 23 Mar 2006 13:21:05 GMT Ralf Corsepius [12f1d7d0] * contrib/crossrpms/rtems/gdb-sources.add (added) New. Thu, 23 Mar 2006 13:06:28 GMT Ralf Corsepius [e39da00d] * contrib/crossrpms/configure.ac (modified) Add defaults for non-standard $prefix. Fri, 17 Mar 2006 13:14:52 GMT Ralf Corsepius [900ae6fd] * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/mkspec.am (modified) Apply @sysdirpattern@ Fri, 17 Mar 2006 13:13:46 GMT Ralf Corsepius [c3af37c] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-newlib.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Use %sysdir instead of %if %_prefix ==|!= /usr Thu, 16 Mar 2006 06:47:34 GMT Ralf Corsepius [f906d86] * contrib/crossrpms/binutils/binutils.add (modified) Require base-binutils if building infos. Thu, 16 Mar 2006 06:45:40 GMT Ralf Corsepius [bef3adb] * contrib/crossrpms/configure.ac (modified) Remove message erroniously checked in in previous change Thu, 16 Mar 2006 06:44:27 GMT Ralf Corsepius [77cd26d] * contrib/crossrpms/configure.ac (modified) Set defaults for ac_default_prefix Wed, 15 Mar 2006 17:42:31 GMT Ralf Corsepius [b224280] * contrib/crossrpms/configure.ac (modified) Increment version Wed, 15 Mar 2006 17:41:56 GMT Ralf Corsepius [cab09c0b] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/cygwin/target-w32api.add (added) * contrib/crossrpms/cygwin/w32api.add (added) Add w32api Sat, 11 Mar 2006 09:01:52 GMT Ralf Corsepius [760e8186] * contrib/crossrpms/gdb/build.add (modified) configure --enable-sim Sat, 11 Mar 2006 09:01:09 GMT Ralf Corsepius [aa005877] * contrib/crossrpms/gdb/install.add (modified) Use DESTDIR for gdb >= 6.3. Remove bogus lib*-sim.a Fri, 10 Mar 2006 13:47:18 GMT Ralf Corsepius [7f48ec7] * contrib/crossrpms/TODO (modified) Reflect having added --enable-infos Fri, 10 Mar 2006 13:45:05 GMT Ralf Corsepius [1a64d3e] * contrib/crossrpms/configure.ac (modified) Increment version Fri, 10 Mar 2006 13:44:30 GMT Ralf Corsepius [13501927] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) * contrib/crossrpms/binutils/install.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Use %build_infos Fri, 10 Mar 2006 13:40:54 GMT Ralf Corsepius [a56035b] * contrib/crossrpms/mkspec.am (modified) Propagate build_infos to *.spec.ins Fri, 10 Mar 2006 06:24:55 GMT Ralf Corsepius [4d3e4476] * contrib/crossrpms/configure.ac (modified) Rework rpmprefix logic. Add --enable-infos/build_infos. Fri, 10 Mar 2006 06:24:23 GMT Ralf Corsepius [0605460] * contrib/crossrpms/README (modified) Add missing comma. Fri, 10 Mar 2006 06:06:10 GMT Ralf Corsepius [783e6007] * contrib/crossrpms/rtems/Makefile.am (modified) Add gdb Fri, 10 Mar 2006 06:04:31 GMT Ralf Corsepius [81f6a9ef] * contrib/crossrpms/Makefile.am (modified) Add gdb/*.add Fri, 10 Mar 2006 06:03:39 GMT Ralf Corsepius [59c3dfe] * contrib/crossrpms/gdb/base-gdb.add (added) * contrib/crossrpms/gdb/build.add (added) * contrib/crossrpms/gdb/gdb.add (added) * contrib/crossrpms/gdb/install.add (added) * contrib/crossrpms/gdb/prep.add (added) * contrib/crossrpms/gdb/rpm-install.add (added) * contrib/crossrpms/gdb/target-gdb.add (added) New. Fri, 10 Mar 2006 06:03:05 GMT Ralf Corsepius [c2f69fe] * contrib/crossrpms/NEWS (modified) 2006-03-10 Add preliminary rtems-gdb specs. ... Thu, 09 Mar 2006 05:11:22 GMT Ralf Corsepius [64391f1] * contrib/crossrpms/TODO (modified) Add note on Ada. Thu, 09 Mar 2006 05:07:57 GMT Ralf Corsepius [f26c821] * contrib/crossrpms/NEWS (modified) * contrib/crossrpms/TODO (modified) Update Thu, 09 Mar 2006 03:30:37 GMT Ralf Corsepius [9b7443c] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) Enable fortran and objc Wed, 08 Mar 2006 09:22:44 GMT Ralf Corsepius [f7c8422] * contrib/crossrpms/mingw32/gcc-sources.add (modified) Deactivate PATCH0 (not required for gcc >= 4.1.0 Wed, 08 Mar 2006 09:21:42 GMT Ralf Corsepius [73d88d14] * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Activate fortran and objc Tue, 07 Mar 2006 14:03:01 GMT Ralf Corsepius [a03debd5] * contrib/crossrpms/TODO (added) New. Tue, 07 Mar 2006 13:42:57 GMT Ralf Corsepius [c429c016] * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) Use gcc_rpmvers for subpackage deps. Tue, 07 Mar 2006 09:02:11 GMT Ralf Corsepius [027c603] * contrib/crossrpms/gcc/gccnewlib.add (modified) Use %echo instead of %%echo in %expand
