# # ChangeLog for contrib in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 23:09:32 Tue, 13 Nov 2007 08:38:30 GMT Ralf Corsepius [3ef68f9] * contrib/crossrpms/patches/gcc-core-3.4.6-rtems4.9-20071111.diff (modified) Remove *.origs Tue, 13 Nov 2007 08:34:44 GMT Ralf Corsepius [4da971a] * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Tue, 13 Nov 2007 08:34:25 GMT Ralf Corsepius [6790aa4d] * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) GCC_RPMREL = 3. Tue, 13 Nov 2007 08:34:10 GMT Ralf Corsepius [01b9201] * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Add gcc-core-3.4.6-rtems4.9-20071111.diff. Tue, 13 Nov 2007 08:29:18 GMT Ralf Corsepius [d96e1a9] * contrib/crossrpms/patches/gcc-core-3.4.6-rtems4.9-20071111.diff (added) New. Mon, 12 Nov 2007 13:38:24 GMT Ralf Corsepius [9c5fca8] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Bump GCC_RPMREL. Mon, 12 Nov 2007 13:11:16 GMT Ralf Corsepius [40885273] * contrib/crossrpms/gcc/target-gcc.add (modified) Exclude %{gcclib}/@tool_target@/%{gcc_version}/include/ssp for avr. Mon, 12 Nov 2007 08:02:54 GMT Ralf Corsepius [c4ee5df] * contrib/crossrpms/patches/gcc-core-4.0.4-rtems4.9-20071111.diff (modified) Fix stupid typo. Mon, 12 Nov 2007 07:16:21 GMT Ralf Corsepius [fc3e3d8] * contrib/crossrpms/patches/gcc-core-4.0.4-rtems4.9-20071111.diff (added) New. Mon, 12 Nov 2007 07:15:48 GMT Ralf Corsepius [aec05c47] * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) Abandon gcc-4.0.3, gcc-3.4.6. Switch to gcc-4.0.4. gcc- ... Mon, 12 Nov 2007 07:15:18 GMT Ralf Corsepius [15910221] * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) Abandon gcc-4.0.3. Switch to gcc-4.0.4. Fri, 09 Nov 2007 17:10:18 GMT Ralf Corsepius [c6b590d] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Fri, 09 Nov 2007 07:31:34 GMT Ralf Corsepius [1c91942] * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) gcc-3.4.6-2. Fri, 09 Nov 2007 07:16:27 GMT Ralf Corsepius [0be4b8a5] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Abandon gcc-4.1.1 Fri, 09 Nov 2007 07:14:29 GMT Ralf Corsepius [b02c2b04] * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20070719.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20070804.diff (deleted) Remove. Fri, 09 Nov 2007 07:13:49 GMT Ralf Corsepius [0052c92] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Abandon gcc-4.2.1 Fri, 09 Nov 2007 07:12:40 GMT Ralf Corsepius [311f43e] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Abandon gcc-4.1.2. Fri, 09 Nov 2007 07:08:27 GMT Ralf Corsepius [c8720f7] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Abandon gcc-4.2.0. Fri, 09 Nov 2007 07:07:51 GMT Ralf Corsepius [7eb7405a] * contrib/crossrpms/patches/gcc-core-4.2.0-20070501-rtems4.8-20070501.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.0-rtems4.8-20070515.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.0-rtems4.8-20070613.diff (deleted) Remove. Fri, 09 Nov 2007 07:00:46 GMT Ralf Corsepius [710d408] * contrib/crossrpms/patches/gcc-core-4.2.2-rtems4.9-20071011.diff (deleted) Remove. Fri, 09 Nov 2007 07:00:02 GMT Ralf Corsepius [5fd4eae7] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Use gcc-core-4.2.2-rtems4.9-20071109.diff Fri, 09 Nov 2007 06:56:42 GMT Ralf Corsepius [e860aabc] * contrib/crossrpms/patches/gcc-core-4.2.2-rtems4.9-20071109.diff (added) Remove bogus *.origs. Sun, 04 Nov 2007 12:25:19 GMT Ralf Corsepius [83c8c3c] * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (modified) Fix stupid typo Sun, 04 Nov 2007 09:28:35 GMT Ralf Corsepius [6d77c8f5] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (modified) regenerate Sun, 04 Nov 2007 09:26:51 GMT Ralf Corsepius [fd7bb10] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Bump BINUTILS_RPMREL. Sun, 04 Nov 2007 09:26:05 GMT Ralf Corsepius [567fed3] * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) Update. Sun, 04 Nov 2007 09:25:32 GMT Ralf Corsepius [137c410] * contrib/crossrpms/patches/binutils-2.18-rtems4.9-20071104.diff (added) New. Thu, 01 Nov 2007 07:32:07 GMT Ralf Corsepius [7cb1d6ea] * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Assume gdb >= 6.4 Thu, 01 Nov 2007 07:29:24 GMT Ralf Corsepius [e2b16828] * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Remove GDB. Thu, 01 Nov 2007 07:27:39 GMT Ralf Corsepius [d4d9f27] * contrib/crossrpms/patches/gdb-6.4-rtems-20060311.diff (deleted) * contrib/crossrpms/patches/gdb-6.4-rtems-20060712.diff (deleted) Remove. Thu, 01 Nov 2007 05:58:05 GMT Ralf Corsepius [25eda206] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) gdb-6.7.1-4 Wed, 31 Oct 2007 21:35:24 GMT Ralf Corsepius [724eab7a] * contrib/crossrpms/patches/gdb-6.7.1-rtems4.9-20071031.diff (modified) Hard-code -lncurses instead of -ltinfo. Wed, 31 Oct 2007 15:46:35 GMT Ralf Corsepius [83644e9] * contrib/crossrpms/patches/gdb-6.7.1-rtems4.9-20071031.diff (modified) Add hacks to get erc32 building Wed, 31 Oct 2007 15:45:45 GMT Ralf Corsepius [91a492a2] * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Cleanups for erc32. Wed, 31 Oct 2007 12:30:51 GMT Ralf Corsepius [84f86cb] * contrib/crossrpms/gdb/gdb.add (modified) Reflect suse-10.3 having expat in libexpat-devel. Wed, 31 Oct 2007 12:27:07 GMT Ralf Corsepius [a4081ce7] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) gdb-4.7.1 Wed, 31 Oct 2007 05:28:40 GMT Ralf Corsepius [49deaec] * contrib/crossrpms/gdb/build.add (modified) Force building against expat Wed, 31 Oct 2007 05:11:26 GMT Ralf Corsepius [3dd61288] * contrib/crossrpms/patches/gdb-6.7.1-rtems4.9-20071031.diff (added) New. Wed, 17 Oct 2007 16:09:27 GMT Ralf Corsepius [2fc47c6] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/cygwin/i686/libncurses-devel.add (modified) * contrib/crossrpms/cygwin/i686/libs.add (modified) * contrib/crossrpms/cygwin/i686/w32api.add (modified) * contrib/crossrpms/cygwin/i686/zlib.add (modified) Update. Fri, 12 Oct 2007 02:20:32 GMT Ralf Corsepius [efe8291f] * contrib/crossrpms/patches/gdb-6.6.90-rtems4.9-20071002.diff (deleted) Remove Fri, 12 Oct 2007 02:19:42 GMT Ralf Corsepius [a5c8f11] * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Fri, 12 Oct 2007 02:19:02 GMT Ralf Corsepius [ee54f23] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) gdb-6.7-2 Thu, 11 Oct 2007 14:51:28 GMT Ralf Corsepius [5c30f679] * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) gdb-6.7-2 Thu, 11 Oct 2007 14:49:10 GMT Ralf Corsepius [053c2f4] * contrib/crossrpms/patches/gdb-6.7-rtems4.9-20071011.diff (modified) Add A. Modra's makeinfo fixes. Thu, 11 Oct 2007 08:31:50 GMT Ralf Corsepius [df16b8bf] * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) gdb-6.7 Thu, 11 Oct 2007 08:28:07 GMT Ralf Corsepius [777d259b] * contrib/crossrpms/patches/gdb-6.7-rtems4.9-20071011.diff (added) New. Thu, 11 Oct 2007 03:18:10 GMT Ralf Corsepius [6f1919e5] * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Thu, 11 Oct 2007 03:09:36 GMT Ralf Corsepius [d6a7e4fe] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) Regenerate. Thu, 11 Oct 2007 03:04:26 GMT Ralf Corsepius [090d3432] * contrib/crossrpms/patches/gcc-core-4.2.2-rtems4.9-20071011.diff (added) New. Thu, 11 Oct 2007 03:02:46 GMT Ralf Corsepius [0e6d50c] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Update to gcc-4.2.2-2. Thu, 11 Oct 2007 02:53:12 GMT Ralf Corsepius [59b4f42] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Add 4.2.2. Wed, 10 Oct 2007 06:52:31 GMT Ralf Corsepius [5a9f372] * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) update to gdb-6.6.90. Tue, 02 Oct 2007 08:38:06 GMT Ralf Corsepius [d731ccc7] * contrib/crossrpms/patches/gdb-6.6.90-rtems4.9-20071002.diff (added) New. Mon, 01 Oct 2007 10:33:32 GMT Ralf Corsepius [1e7b8d32] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060720.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060908.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060909.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070102.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070131.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.8-20070216.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.8-20070405.diff (deleted) Remove (obsolete). Fri, 28 Sep 2007 08:11:09 GMT Ralf Corsepius [fbb54035] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070202.diff (deleted) Remove (obsolete). Fri, 28 Sep 2007 07:41:49 GMT Ralf Corsepius [dfc0dc23] * contrib/crossrpms/patches/binutils-2.17.50-rtems4.8-20070525.diff (deleted) Remove. Fri, 28 Sep 2007 07:38:40 GMT Ralf Corsepius [51aac0e] * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Cleanups. Fri, 28 Sep 2007 07:35:18 GMT Ralf Corsepius [2d9201a] * contrib/crossrpms/rtems4.9/arm/.cvsignore (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/avr/.cvsignore (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/bfin/.cvsignore (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/h8300/.cvsignore (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/i386/.cvsignore (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/m68k/.cvsignore (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/mips/.cvsignore (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/mipstx39/.cvsignore (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/powerpc/.cvsignore (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/sh/.cvsignore (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/sparc/.cvsignore (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/tic4x/.cvsignore (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (added) Add rtems-4.9*.spec Fri, 28 Sep 2007 07:31:55 GMT Ralf Corsepius [b1f6abc] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Reset GCC_RPMREL, GDB_RPMREL, BINUTILS_RPMREL = 1. Fri, 28 Sep 2007 07:27:06 GMT Ralf Corsepius [1cb8b7f] * contrib/crossrpms/rtems4.8/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/arm/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/arm/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/arm/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/avr/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/avr/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/bfin/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/bfin/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/bfin/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/binutils.am (deleted) * contrib/crossrpms/rtems4.8/cpukit-prep.add (deleted) * contrib/crossrpms/rtems4.8/cpukit.am (deleted) * contrib/crossrpms/rtems4.8/gcc-prep.add (deleted) * contrib/crossrpms/rtems4.8/gcc.am (deleted) * contrib/crossrpms/rtems4.8/gdb.am (deleted) * contrib/crossrpms/rtems4.8/h8300/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/h8300/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/i386/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/i386/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/i386/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/m68k/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/m68k/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/mips/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/mips/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/mips/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/mipstx39/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/powerpc/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/powerpc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/sh/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/sh/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/sh/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/sparc/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/sparc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/tic4x/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (deleted) Remove. Fri, 28 Sep 2007 07:24:56 GMT Ralf Corsepius [ed73806b] * contrib/crossrpms/rtems4.9/.cvsignore (added) * contrib/crossrpms/rtems4.9/Makefile.am (added) * contrib/crossrpms/rtems4.9/arm/.cvsignore (added) * contrib/crossrpms/rtems4.9/arm/Makefile.am (added) * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/arm/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/avr/.cvsignore (added) * contrib/crossrpms/rtems4.9/avr/Makefile.am (added) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/avr/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/binutils.am (added) * contrib/crossrpms/rtems4.9/cpukit-prep.add (added) * contrib/crossrpms/rtems4.9/cpukit.am (added) * contrib/crossrpms/rtems4.9/gcc-prep.add (added) * contrib/crossrpms/rtems4.9/gcc.am (added) * contrib/crossrpms/rtems4.9/gdb.am (added) * contrib/crossrpms/rtems4.9/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/i386/.cvsignore (added) * contrib/crossrpms/rtems4.9/i386/Makefile.am (added) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/i386/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/mips/.cvsignore (added) * contrib/crossrpms/rtems4.9/mips/Makefile.am (added) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/mips/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/sh/.cvsignore (added) * contrib/crossrpms/rtems4.9/sh/Makefile.am (added) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/sh/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/.cvsignore (added) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/gdb-sources.add (added) copy from rtems-4.8 to rtems-4.9. Fri, 28 Sep 2007 07:19:29 GMT Ralf Corsepius [1f60e1c] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) rtems-4.9. Thu, 27 Sep 2007 15:52:19 GMT Ralf Corsepius [36c11ad8] * contrib/repo-conf/aclocal/version.m4 (modified) Bump _RTEMS_API to 4.9. Thu, 27 Sep 2007 15:52:00 GMT Ralf Corsepius [207c636] * contrib/repo-conf/configure.ac (modified) Bump version to 0.8. Thu, 13 Sep 2007 01:12:50 GMT Ralf Corsepius [98e398cb] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070912.diff (modified) Add missing #endif in powerpc/setjmp.S Wed, 12 Sep 2007 19:42:12 GMT Ralf Corsepius [8393f3a] * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) newlib-1.15.0-rtems4.8-20070912.diff. Wed, 12 Sep 2007 19:41:58 GMT Ralf Corsepius [18960f10] * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) GCC_RPMREL = 24. Wed, 12 Sep 2007 19:38:48 GMT Ralf Corsepius [98f890b] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070912.diff (added) New (Incorporate Eric Norum's altivec patch) Sun, 02 Sep 2007 05:24:37 GMT Ralf Corsepius [9bd03749] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (modified) Regenerate. Wed, 29 Aug 2007 02:56:55 GMT Ralf Corsepius [1dbd593d] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) BINUTILS_VERS = 2.18. BINUTILS_RPMREL = 1%{?dist}. Wed, 29 Aug 2007 02:54:39 GMT Ralf Corsepius [a380e47e] * contrib/crossrpms/binutils/base-binutils.add (modified) Abandon *-base-binutils packages. Wed, 29 Aug 2007 02:51:40 GMT Ralf Corsepius [9ce762b] * contrib/crossrpms/binutils/base-binutils.add (modified) Abandon binutils < 2.13. Wed, 22 Aug 2007 23:52:43 GMT Chris Johns [2e2cbfa9] * contrib/mingw/ChangeLog (modified) * contrib/mingw/mingw-path.nsi (modified) 2007-0823 Chris Johns * ... Mon, 20 Aug 2007 02:12:48 GMT Chris Johns [598aab1f] * contrib/mingw/ChangeLog (modified) * contrib/mingw/ba-wrap.sh (modified) * contrib/mingw/build-exes.sh (modified) * contrib/mingw/filewrite.nsi (added) * contrib/mingw/getparameters.nsi (added) * contrib/mingw/instance-check.nsi (added) * contrib/mingw/mingw-path.nsi (added) * contrib/mingw/msys-path.nsi (modified) * contrib/mingw/options.nsi (added) * contrib/mingw/rtems-autotools.nsi (modified) * contrib/mingw/rtems-tools.nsi (modified) * contrib/mingw/rtems.ini (modified) * contrib/mingw/rtems_logo.bmp (modified) * contrib/mingw/sm-dummy.nsi (added) * contrib/mingw/strslash.nsi (added) * contrib/mingw/strstr.nsi (added) 2007-08-20 Chris Johns * ... Thu, 09 Aug 2007 16:57:09 GMT Ralf Corsepius [ece78df6] * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (modified) gdb-6.6-9. Thu, 09 Aug 2007 05:20:07 GMT Ralf Corsepius [876c33f1] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (modified) gdb-6.6-9. Thu, 09 Aug 2007 03:05:41 GMT Ralf Corsepius [9aa1472] * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (modified) Regenerate. Thu, 09 Aug 2007 03:05:00 GMT Ralf Corsepius [e90748fd] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gdb.spec (added) New. Thu, 09 Aug 2007 03:01:40 GMT Ralf Corsepius [6ed5f75] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Increment GDB_RPMREL. Thu, 09 Aug 2007 02:58:36 GMT Ralf Corsepius [984e8d8d] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Append %{?dist} to GDB_RPMREL. Thu, 09 Aug 2007 02:55:36 GMT Ralf Corsepius [2ef64f2] * contrib/crossrpms/gdb/base-gdb.add (modified) Remove references to base packages. Thu, 09 Aug 2007 02:54:01 GMT Ralf Corsepius [9452ee4a] * contrib/crossrpms/gdb/base-gdb.add (modified) Remove support for gdb < 6.0. Thu, 09 Aug 2007 02:53:30 GMT Ralf Corsepius [ee19567c] * contrib/crossrpms/gdb/gdb.add (modified) Remove %{?dist} Wed, 08 Aug 2007 12:21:26 GMT Ralf Corsepius [c2cc8b2] * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90. Wed, 08 Aug 2007 10:10:51 GMT Ralf Corsepius [4db732d] * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90. Wed, 08 Aug 2007 08:24:48 GMT Ralf Corsepius [8ee1b11] * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90. Wed, 08 Aug 2007 04:22:50 GMT Ralf Corsepius [9e516ac] * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (modified) Revert to gcc-4.0.3-12, gcc-4.2.1 doesn't build Wed, 08 Aug 2007 04:13:44 GMT Ralf Corsepius [baa2d55] * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90. Wed, 08 Aug 2007 04:11:02 GMT Ralf Corsepius [1cb554a6] * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:43:09 GMT Ralf Corsepius [cc85dda] * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:42:47 GMT Ralf Corsepius [1a8165f6] * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Wed, 08 Aug 2007 03:36:40 GMT Ralf Corsepius [8d88aa2] * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:36:15 GMT Ralf Corsepius [92b76712] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Wed, 08 Aug 2007 03:30:27 GMT Ralf Corsepius [ff3a2d87] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:30:15 GMT Ralf Corsepius [5d991cf] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Wed, 08 Aug 2007 03:21:54 GMT Ralf Corsepius [3675f57] * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:21:29 GMT Ralf Corsepius [8d25d2e] * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Tue, 07 Aug 2007 15:41:57 GMT Ralf Corsepius [c48c3590] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (modified) BINUTILS_RPMREL = 2 Tue, 07 Aug 2007 15:38:23 GMT Ralf Corsepius [4907b96] * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) Regenerate. Tue, 07 Aug 2007 15:38:10 GMT Ralf Corsepius [90aab6d] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Enable infos for binutils.
