# # ChangeLog for contrib in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 02:33:54 Sun, 18 Feb 2007 08:03:26 GMT Ralf Corsepius [349e2de] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (modified) gdb-6.6-rtems4.8-20070218.diff Sun, 18 Feb 2007 07:59:02 GMT Ralf Corsepius [4778b0a7] * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20070218.diff (added) New. Fix breakage on rh7. Sat, 17 Feb 2007 11:30:40 GMT Ralf Corsepius [1ee16e8] * contrib/crossrpms/gdb/gdb.add (modified) BuildRequire: expat-devel for gdb >= 6.6 Sat, 17 Feb 2007 09:50:25 GMT Ralf Corsepius [08c06d89] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (modified) Preps for gdb-6.6 Sat, 17 Feb 2007 09:40:11 GMT Ralf Corsepius [bb31ed7] * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20070217.diff (added) New. Sat, 17 Feb 2007 07:12:15 GMT Ralf Corsepius [84b62c77] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (modified) Fix URL. Sat, 17 Feb 2007 07:03:17 GMT Ralf Corsepius [71f6a66] * contrib/crossrpms/gdb/base-gdb.add (modified) Add || : to install-info. Sat, 17 Feb 2007 06:48:04 GMT Ralf Corsepius [1293de07] * contrib/crossrpms/binutils/base-binutils.add (modified) Add || : to install-info. Sat, 17 Feb 2007 06:46:00 GMT Ralf Corsepius [0112d07] * contrib/crossrpms/gcc/base-gcc.add (modified) Fix typo. Fri, 16 Feb 2007 08:39:49 GMT Ralf Corsepius [1d17363] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add HOST_SUBDIRS Fri, 16 Feb 2007 08:38:57 GMT Ralf Corsepius [7ded655d] * contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.8-20070216.diff (added) New. Fri, 16 Feb 2007 08:36:50 GMT Ralf Corsepius [61f2bb5] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) Preps for gcc-4.1.2 Fri, 16 Feb 2007 08:31:33 GMT Ralf Corsepius [64ccc152] * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) Ignore errors on install-info. Wed, 14 Feb 2007 17:21:43 GMT Ralf Corsepius [072cbd3] * contrib/crossrpms/autotools/Makefile.am (modified) AUTOCONF_RPMREL = 5 Wed, 14 Feb 2007 17:21:30 GMT Ralf Corsepius [0852a4f7] * contrib/crossrpms/autotools/target-autoconf.add (modified) Add ||: to install-info Wed, 14 Feb 2007 16:47:57 GMT Ralf Corsepius [9c58665b] * contrib/crossrpms/autotools/Makefile.am (modified) AUTOCONF_RPMREL = 4 Wed, 14 Feb 2007 16:46:18 GMT Ralf Corsepius [843ee5d] * contrib/crossrpms/autotools/autoconf.add (modified) Add req/prov filters Wed, 14 Feb 2007 15:51:02 GMT Ralf Corsepius [43858659] * contrib/crossrpms/autotools/Makefile.am (modified) AUTOMAKE_RPMREL = 5 Wed, 14 Feb 2007 15:50:37 GMT Ralf Corsepius [2388d57] * contrib/crossrpms/autotools/automake.add (modified) * contrib/crossrpms/autotools/target-automake.add (modified) Make install-infos safe against --exclude-docs. Filter bogus ... Thu, 08 Feb 2007 08:13:40 GMT Ralf Corsepius [d87efdf] * contrib/crossrpms/patches/newlib-1.14.0-rtems4.8-20061027.diff (deleted) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Abandon newlib-1.14.0. Thu, 08 Feb 2007 07:26:53 GMT Ralf Corsepius [9b45f53] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) newlib-1.15.0-rtems4.8-20070208.diff Thu, 08 Feb 2007 07:26:12 GMT Ralf Corsepius [b9605a95] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Bump GCC_RPMREL Thu, 08 Feb 2007 07:22:11 GMT Ralf Corsepius [ec011e5a] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070208.diff (added) New. Thu, 08 Feb 2007 06:01:40 GMT Ralf Corsepius [92b61a71] * contrib/crossrpms/patches/newlib-1.14.0-rtems4.8-20061109.diff (deleted) * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20061219.diff (deleted) * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070110.diff (deleted) * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070130.diff (deleted) Remove (Obsolete). Thu, 08 Feb 2007 05:58:29 GMT Ralf Corsepius [d044f9d] * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) Abandon newlib-1.14.0. Fri, 02 Feb 2007 15:43:09 GMT Ralf Corsepius [080c23d] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Upgrade to gcc-core-4.1.1-rtems4.8-20070201.diff, ... Fri, 02 Feb 2007 15:07:55 GMT Ralf Corsepius [91350690] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070201.diff (added) * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070202.diff (added) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) Yet another attempt. Wed, 31 Jan 2007 10:39:24 GMT Ralf Corsepius [a8f155b8] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070131.diff (added) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Next try: gcc-core-4.1.1-rtems4.8-20070131.diff Wed, 31 Jan 2007 03:40:12 GMT Ralf Corsepius [a423203] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Preps for next spin. Wed, 31 Jan 2007 03:39:52 GMT Ralf Corsepius [500a9c5d] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070130.diff (added) New. Fri, 12 Jan 2007 08:33:13 GMT Ralf Corsepius [282197c4] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Disable binutils infos. Fri, 12 Jan 2007 08:31:37 GMT Ralf Corsepius [72b911c] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Add BINUTILS_OPTS += Fri, 12 Jan 2007 08:26:51 GMT Ralf Corsepius [85f9bdc] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Bump GCC_RPMREL Fri, 12 Jan 2007 08:26:14 GMT Ralf Corsepius [ec24bd5a] * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) Update to gcc-core-4.2.0-rtems4.8-20070112.diff Fri, 12 Jan 2007 04:36:25 GMT Ralf Corsepius [ce625960] * contrib/crossrpms/patches/gcc-core-4.2-20061031-rtems4.8-20061109.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2-20061114-rtems4.8-20061115.diff (deleted) Remove (Obsolete). Fri, 12 Jan 2007 04:35:49 GMT Ralf Corsepius [652473b3] * contrib/crossrpms/patches/gcc-core-4.2-20070110-rtems4.8-20070112.diff (added) Update (bfin merged into upstream) Fri, 12 Jan 2007 03:57:28 GMT Ralf Corsepius [b4de41dd] * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Use gcc-core-4.1.1-rtems4.8-20070102.diff Fri, 12 Jan 2007 03:53:39 GMT Ralf Corsepius [c116b31] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Upgrade to newlib-1.15.0-rtems4.8-20070110. Fri, 12 Jan 2007 03:49:15 GMT Ralf Corsepius [5709d75e] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Add BINUTILS_OPTS. Fri, 12 Jan 2007 03:39:21 GMT Ralf Corsepius [c80654e] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Bump GCC_RPMREL. Wed, 10 Jan 2007 08:02:41 GMT Ralf Corsepius [cb08aeb] * contrib/crossrpms/autotools/Makefile.am (modified) Bump releases. Wed, 10 Jan 2007 08:02:07 GMT Ralf Corsepius [1b5a5610] * contrib/crossrpms/autotools/automake.add (modified) * contrib/crossrpms/autotools/automake.am (modified) Rename automake-rtems into automake. Rename autoconf-rtems into autoconf. Wed, 10 Jan 2007 08:02:01 GMT Ralf Corsepius [727e8469] * contrib/crossrpms/autotools/autoconf.add (modified) * contrib/crossrpms/autotools/autoconf.am (modified) Rename autoconf-rtems into autoconf. Wed, 10 Jan 2007 06:31:57 GMT Ralf Corsepius [d82b3f1b] * contrib/crossrpms/common/common.add (modified) Update bugfix address Wed, 10 Jan 2007 06:05:01 GMT Ralf Corsepius [3d62598] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070110.diff (added) Add ECANCELED. Thu, 04 Jan 2007 13:43:21 GMT Ralf Corsepius [35db46f] * contrib/crossrpms/cygwin/binutils.am (modified) * contrib/crossrpms/freebsd5.2/binutils.am (modified) * contrib/crossrpms/freebsd6.0/binutils.am (modified) * contrib/crossrpms/freebsd6.1/binutils.am (modified) * contrib/crossrpms/mingw32/binutils.am (modified) * contrib/crossrpms/rtems4.8/binutils.am (modified) * contrib/crossrpms/solaris2.7/binutils.am (modified) Add BINUTILS_OPTS Thu, 04 Jan 2007 12:52:40 GMT Ralf Corsepius [598e035] * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Add support for newlib-1.15.0 Thu, 04 Jan 2007 08:04:31 GMT Ralf Corsepius [6e0bde6] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) Add newlib-1.15.0. New GCC snapshot. Thu, 04 Jan 2007 08:00:32 GMT Ralf Corsepius [e0c27b1] * contrib/crossrpms/patches/gcc-core-4.2-20070102-rtems4.8-20070104.diff (added) New. Tue, 02 Jan 2007 11:49:35 GMT Ralf Corsepius [5ebd9351] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) Upgrade to newlib-1.15.0 Tue, 02 Jan 2007 10:44:12 GMT Ralf Corsepius [227afd10] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070102.diff (added) New. Tue, 19 Dec 2006 16:30:30 GMT Ralf Corsepius [adb07b1] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20061219.diff (added) New. Sat, 02 Dec 2006 06:06:55 GMT Ralf Corsepius [fcb0cd46] * ChangeLog (modified) * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/bfin/ChangeLog (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/ChangeLog (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/nios2/ChangeLog (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/tools/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/nios2/ChangeLog (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/librtems++/ChangeLog (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * contrib/apt-conf/ChangeLog (modified) * contrib/apt-conf/configure.ac (modified) * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) * contrib/repo-conf/ChangeLog (modified) * contrib/repo-conf/configure.ac (modified) * contrib/rtemsrpms/ChangeLog (modified) * contrib/rtemsrpms/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * doc/ChangeLog (modified) * doc/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/ChangeLog (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/ChangeLog (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) 2006-12-02 Ralf Corsépius * ... Mon, 20 Nov 2006 05:39:07 GMT Ralf Corsepius [f319598] * contrib/crossrpms/ChangeLog (modified) 2006-11-19 Ralf Corsépius * ... Sun, 19 Nov 2006 03:38:30 GMT Ralf Corsepius [bd8f4d8] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/autoconf.add (modified) 2006-11-19 Ralf Corsépius * ... Wed, 15 Nov 2006 03:48:56 GMT Ralf Corsepius [206ad76a] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) GCC_REL=4. Upgrade to gcc-core-4.2-20061114-rtems4.8-20061115.diff Wed, 15 Nov 2006 03:48:33 GMT Ralf Corsepius [b2b99f57] * contrib/crossrpms/patches/gcc-4.1.1-bfinrtems-20060810a.diff (deleted) * contrib/crossrpms/patches/newlib-1.14.0-bfinrtems-20060810a.diff (deleted) Remove (Obsolete) Wed, 15 Nov 2006 03:48:11 GMT Ralf Corsepius [9336dd3] * contrib/crossrpms/ChangeLog (modified) 2006-11-15 Ralf Corsépius * ... Wed, 15 Nov 2006 03:43:43 GMT Ralf Corsepius [5a7f1e1] * contrib/crossrpms/patches/gcc-core-4.2-20061114-rtems4.8-20061115.diff (added) New. Tue, 14 Nov 2006 17:50:23 GMT Ralf Corsepius [f4884049] * contrib/crossrpms/patches/binutils-2.17-rtems4.8-20061021.diff (added) Add. Fri, 10 Nov 2006 13:01:42 GMT Ralf Corsepius [9b039313] * contrib/crossrpms/gcc/gccnewlib.add (modified) 'BR: flex bison' for gcc >= 4.2.0 Thu, 09 Nov 2006 14:28:50 GMT Ralf Corsepius [615b6c9] * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/prep.add (modified) * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/gcc-prep.add (modified) * contrib/crossrpms/rtems4.8/gcc.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Introduce GCC_PKGVERS Thu, 09 Nov 2006 14:27:07 GMT Ralf Corsepius [7f59079] * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) Upgrade to gcc-4.2.0-20061031. Thu, 09 Nov 2006 11:19:05 GMT Ralf Corsepius [e315b421] * contrib/crossrpms/patches/gcc-core-4.2-20061031-rtems4.8-20061109.diff (added) * contrib/crossrpms/patches/newlib-1.14.0-rtems4.8-20061109.diff (added) New (Merge BFIN patches). Mon, 30 Oct 2006 03:53:00 GMT Ralf Corsepius [5cde0c4] * contrib/crossrpms/gdb/gdb.add (modified) Update sparc dep to rtems4.8 Fri, 27 Oct 2006 08:42:14 GMT Ralf Corsepius [5fcda02] * contrib/crossrpms/patches/binutils-2.17-rtems-20060711.diff (deleted) * contrib/crossrpms/patches/binutils-2.17-rtems-20060812.diff (deleted) * contrib/crossrpms/patches/binutils-2.17-rtems-20060815.diff (deleted) Remove (unused) Fri, 27 Oct 2006 08:32:40 GMT Ralf Corsepius [d94d76ad] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060909.diff (deleted) Remove (unused). Fri, 27 Oct 2006 08:32:05 GMT Ralf Corsepius [f5b9b5b] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20061026.diff (deleted) Remove (broken). Fri, 27 Oct 2006 08:31:28 GMT Ralf Corsepius [2466600] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060707.diff (deleted) Remove (obsolete). Fri, 27 Oct 2006 08:29:40 GMT Ralf Corsepius [31691791] * contrib/crossrpms/ChangeLog (modified) 2006-10-27 Ralf Corsépius * ... Fri, 27 Oct 2006 08:27:56 GMT Ralf Corsepius [136e234] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Remove rtems-4.7 Fri, 27 Oct 2006 08:26:24 GMT Ralf Corsepius [58b7d38f] * contrib/crossrpms/rtems4.7/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/arm/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/arm/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/arm/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/arm/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/arm/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/avr/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/avr/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/avr/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/avr/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/binutils.am (deleted) * contrib/crossrpms/rtems4.7/gcc-prep.add (deleted) * contrib/crossrpms/rtems4.7/gcc.am (deleted) * contrib/crossrpms/rtems4.7/gdb.am (deleted) * contrib/crossrpms/rtems4.7/h8300/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/h8300/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/h8300/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/i386/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/i386/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/i386/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/i386/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/m68k/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/m68k/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/m68k/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/m68k/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/mips/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/mips/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/mips/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/mips/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/mipstx39/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/mipstx39/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/mipstx39/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/powerpc/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/powerpc/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/powerpc/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/powerpc/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/sh/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/sh/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/sh/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/sh/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/sparc/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/sparc/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/sparc/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/sparc/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/sparc/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/tic4x/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/tic4x/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/tic4x/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/tic4x/gdb-sources.add (deleted) Remove (unused). Fri, 27 Oct 2006 08:24:43 GMT Ralf Corsepius [4e0f6b7] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Bump GCC_RPMREL. Fri, 27 Oct 2006 08:23:17 GMT Ralf Corsepius [969d68c9] * contrib/crossrpms/ChangeLog (modified) 2006-10-27 Ralf Corsépius * ... Fri, 27 Oct 2006 08:21:17 GMT Ralf Corsepius [29aed1fd] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Update to newlib-1.14.0-rtems4.8-20061027.diff Fri, 27 Oct 2006 08:18:04 GMT Ralf Corsepius [653db3f] * contrib/crossrpms/patches/newlib-1.14.0-rtems4.8-20061027.diff (added) New. Thu, 26 Oct 2006 18:01:34 GMT Joel Sherrill [7693aec] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/patches/newlib-1.14.0-rtems-20061026.diff (added) 2006-10-26 Joel Sherrill * ... Wed, 25 Oct 2006 01:23:19 GMT Ralf Corsepius [413b0ecd] * contrib/repo-conf/Makefile.am (modified) Let rtems-@RTEMS_API@-repo-conf.spec depend on configure.ac Wed, 25 Oct 2006 01:22:46 GMT Ralf Corsepius [94f4fde1] * contrib/repo-conf/configure.ac (modified) Bumb version to 0.4 Tue, 24 Oct 2006 14:53:29 GMT Ralf Corsepius [984d9491] * contrib/repo-conf/configure.ac (modified) Bump version to 0.3 Tue, 24 Oct 2006 14:53:00 GMT Ralf Corsepius [e4add0b7] * contrib/repo-conf/apt/sources.list.d/rtems.list.in (modified) * contrib/repo-conf/yum.repos.d/rtems.repo.in (modified) New URL ftp://ftp.rtems.org/pub/rtems/linux Tue, 24 Oct 2006 02:16:27 GMT Ralf Corsepius [efa1c17] * contrib/repo-conf/ChangeLog (modified) Cleanup. Sun, 22 Oct 2006 04:59:33 GMT Ralf Corsepius [fa8b476] * contrib/crossrpms/ChangeLog (modified) 2006-10-22 Ralf Corsépius * ... Sun, 22 Oct 2006 04:59:15 GMT Ralf Corsepius [3b10616] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add rtems-4.8 Sat, 21 Oct 2006 12:34:16 GMT Ralf Corsepius [575371e] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Reset RPMRELs = 1 Sat, 21 Oct 2006 12:33:50 GMT Ralf Corsepius [6598895] * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (modified) Abandon binutils-2.16*. Apply binutils-2.17-rtems4.8-20061021.diff Sat, 21 Oct 2006 10:41:01 GMT Ralf Corsepius [3096ba23] * contrib/crossrpms/rtems4.8/.cvsignore (added) * contrib/crossrpms/rtems4.8/Makefile.am (added) * contrib/crossrpms/rtems4.8/arm/.cvsignore (added) * contrib/crossrpms/rtems4.8/arm/Makefile.am (added) * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/avr/.cvsignore (added) * contrib/crossrpms/rtems4.8/avr/Makefile.am (added) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/binutils.am (added) * contrib/crossrpms/rtems4.8/gcc-prep.add (added) * contrib/crossrpms/rtems4.8/gcc.am (added) * contrib/crossrpms/rtems4.8/gdb.am (added) * contrib/crossrpms/rtems4.8/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/i386/.cvsignore (added) * contrib/crossrpms/rtems4.8/i386/Makefile.am (added) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/mips/.cvsignore (added) * contrib/crossrpms/rtems4.8/mips/Makefile.am (added) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/sh/.cvsignore (added) * contrib/crossrpms/rtems4.8/sh/Makefile.am (added) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/tic4x/.cvsignore (added) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (added) New. Sat, 21 Oct 2006 10:25:20 GMT Ralf Corsepius [c43121f] * contrib/crossrpms/rtems4.7/bfin/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/bfin/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/bfin/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/bfin/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/bfin/gdb-sources.add (deleted) Remove (Unsupported) Sat, 21 Oct 2006 10:22:18 GMT Ralf Corsepius [378354d1] * contrib/crossrpms/rtems4.7/Makefile.am (modified) * contrib/crossrpms/rtems4.7/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (modified) Sync with rtems-4-7-branch Sat, 21 Oct 2006 05:18:51 GMT Ralf Corsepius [ce953cb] * contrib/repo-conf/yum.repos.d/.cvsignore (added) New. Sat, 21 Oct 2006 05:16:32 GMT Ralf Corsepius [6f8ddf19] * contrib/repo-conf/Makefile.am (modified) Let config.status generate rtems-@RTEMS_API@-repo-conf.spec Sat, 21 Oct 2006 05:16:11 GMT Ralf Corsepius [5c729e9] * contrib/repo-conf/rtems-repo-conf.spec.in (modified) Use @PACKAGE_TARNAME@ Sat, 21 Oct 2006 05:11:12 GMT Ralf Corsepius [289eefa] * contrib/repo-conf/Makefile.am (modified) Add missing backslash Sat, 21 Oct 2006 05:09:51 GMT Ralf Corsepius [e4c039a5] * contrib/repo-conf/AUTHORS (modified) Add myself. Sat, 21 Oct 2006 05:09:16 GMT Ralf Corsepius [6f23e9e4] * contrib/repo-conf/.cvsignore (added) * contrib/repo-conf/AUTHORS (added) * contrib/repo-conf/COPYING (added) * contrib/repo-conf/ChangeLog (added) * contrib/repo-conf/INSTALL (added) * contrib/repo-conf/Makefile.am (added) * contrib/repo-conf/NEWS (added) * contrib/repo-conf/README (added) * contrib/repo-conf/aclocal/version.m4 (added) * contrib/repo-conf/apt/sources.list.d/.cvsignore (added) * contrib/repo-conf/apt/sources.list.d/rtems.list.in (added) * contrib/repo-conf/apt/vendors.list.d/rtems.list (added) * contrib/repo-conf/configure.ac (added) * contrib/repo-conf/gpg/gpg-pubkey-69ce4a83-44cc2b30 (added) * contrib/repo-conf/gpg/gpg-pubkey-eac29b6f-3fe1f458 (added) * contrib/repo-conf/rtems-repo-conf.spec.in (added) * contrib/repo-conf/yum.repos.d/rtems.repo.in (added) New. Thu, 19 Oct 2006 13:30:56 GMT Ralf Corsepius [c991316e] * contrib/crossrpms/autotools/automake.add (modified) Cleanup. Thu, 19 Oct 2006 08:03:50 GMT Ralf Corsepius [ae4894a] * contrib/crossrpms/patches/automake-1.8.1-rtems-20040112-1.diff (deleted) Remove. Thu, 19 Oct 2006 07:58:56 GMT Ralf Corsepius [8de2d56] * contrib/crossrpms/rtems4.7/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (modified) Bump GCC_RPMREL Thu, 19 Oct 2006 07:57:29 GMT Ralf Corsepius [7dce5bf5] * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (modified) rtems-4.7-h8300-rtems4.7-gcc-4.1.1-5 Thu, 19 Oct 2006 07:56:52 GMT Ralf Corsepius [5b5e9031] * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (modified) rtems-4.7-avr-rtems4.7-gcc-4.0.3-2
