# # ChangeLog for contrib in rtems # # Generated by Trac 1.2.1.dev0 # 05/24/24 04:46:38 Fri, 27 Oct 2006 08:29:40 GMT Ralf Corsepius [31691791] * contrib/crossrpms/ChangeLog (modified) 2006-10-27 Ralf Corsépius * ... Fri, 27 Oct 2006 08:27:56 GMT Ralf Corsepius [136e234] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Remove rtems-4.7 Fri, 27 Oct 2006 08:26:24 GMT Ralf Corsepius [58b7d38f] * contrib/crossrpms/rtems4.7/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/arm/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/arm/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/arm/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/arm/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/arm/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/avr/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/avr/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/avr/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/avr/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/binutils.am (deleted) * contrib/crossrpms/rtems4.7/gcc-prep.add (deleted) * contrib/crossrpms/rtems4.7/gcc.am (deleted) * contrib/crossrpms/rtems4.7/gdb.am (deleted) * contrib/crossrpms/rtems4.7/h8300/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/h8300/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/h8300/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/i386/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/i386/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/i386/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/i386/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/m68k/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/m68k/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/m68k/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/m68k/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/mips/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/mips/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/mips/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/mips/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/mipstx39/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/mipstx39/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/mipstx39/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/powerpc/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/powerpc/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/powerpc/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/powerpc/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/sh/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/sh/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/sh/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/sh/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/sparc/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/sparc/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/sparc/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/sparc/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/sparc/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.7/tic4x/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/tic4x/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/tic4x/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/tic4x/gdb-sources.add (deleted) Remove (unused). Fri, 27 Oct 2006 08:24:43 GMT Ralf Corsepius [4e0f6b7] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Bump GCC_RPMREL. Fri, 27 Oct 2006 08:23:17 GMT Ralf Corsepius [969d68c9] * contrib/crossrpms/ChangeLog (modified) 2006-10-27 Ralf Corsépius * ... Fri, 27 Oct 2006 08:21:17 GMT Ralf Corsepius [29aed1fd] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Update to newlib-1.14.0-rtems4.8-20061027.diff Fri, 27 Oct 2006 08:18:04 GMT Ralf Corsepius [653db3f] * contrib/crossrpms/patches/newlib-1.14.0-rtems4.8-20061027.diff (added) New. Thu, 26 Oct 2006 18:01:34 GMT Joel Sherrill [7693aec] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/patches/newlib-1.14.0-rtems-20061026.diff (added) 2006-10-26 Joel Sherrill * ... Wed, 25 Oct 2006 01:23:19 GMT Ralf Corsepius [413b0ecd] * contrib/repo-conf/Makefile.am (modified) Let rtems-@RTEMS_API@-repo-conf.spec depend on configure.ac Wed, 25 Oct 2006 01:22:46 GMT Ralf Corsepius [94f4fde1] * contrib/repo-conf/configure.ac (modified) Bumb version to 0.4 Tue, 24 Oct 2006 14:53:29 GMT Ralf Corsepius [984d9491] * contrib/repo-conf/configure.ac (modified) Bump version to 0.3 Tue, 24 Oct 2006 14:53:00 GMT Ralf Corsepius [e4add0b7] * contrib/repo-conf/apt/sources.list.d/rtems.list.in (modified) * contrib/repo-conf/yum.repos.d/rtems.repo.in (modified) New URL ftp://ftp.rtems.org/pub/rtems/linux Tue, 24 Oct 2006 02:16:27 GMT Ralf Corsepius [efa1c17] * contrib/repo-conf/ChangeLog (modified) Cleanup. Sun, 22 Oct 2006 04:59:33 GMT Ralf Corsepius [fa8b476] * contrib/crossrpms/ChangeLog (modified) 2006-10-22 Ralf Corsépius * ... Sun, 22 Oct 2006 04:59:15 GMT Ralf Corsepius [3b10616] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add rtems-4.8 Sat, 21 Oct 2006 12:34:16 GMT Ralf Corsepius [575371e] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Reset RPMRELs = 1 Sat, 21 Oct 2006 12:33:50 GMT Ralf Corsepius [6598895] * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (modified) Abandon binutils-2.16*. Apply binutils-2.17-rtems4.8-20061021.diff Sat, 21 Oct 2006 10:41:01 GMT Ralf Corsepius [3096ba23] * contrib/crossrpms/rtems4.8/.cvsignore (added) * contrib/crossrpms/rtems4.8/Makefile.am (added) * contrib/crossrpms/rtems4.8/arm/.cvsignore (added) * contrib/crossrpms/rtems4.8/arm/Makefile.am (added) * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/avr/.cvsignore (added) * contrib/crossrpms/rtems4.8/avr/Makefile.am (added) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/binutils.am (added) * contrib/crossrpms/rtems4.8/gcc-prep.add (added) * contrib/crossrpms/rtems4.8/gcc.am (added) * contrib/crossrpms/rtems4.8/gdb.am (added) * contrib/crossrpms/rtems4.8/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/i386/.cvsignore (added) * contrib/crossrpms/rtems4.8/i386/Makefile.am (added) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/mips/.cvsignore (added) * contrib/crossrpms/rtems4.8/mips/Makefile.am (added) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/sh/.cvsignore (added) * contrib/crossrpms/rtems4.8/sh/Makefile.am (added) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/tic4x/.cvsignore (added) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (added) New. Sat, 21 Oct 2006 10:25:20 GMT Ralf Corsepius [c43121f] * contrib/crossrpms/rtems4.7/bfin/.cvsignore (deleted) * contrib/crossrpms/rtems4.7/bfin/Makefile.am (deleted) * contrib/crossrpms/rtems4.7/bfin/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.7/bfin/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.7/bfin/gdb-sources.add (deleted) Remove (Unsupported) Sat, 21 Oct 2006 10:22:18 GMT Ralf Corsepius [378354d1] * contrib/crossrpms/rtems4.7/Makefile.am (modified) * contrib/crossrpms/rtems4.7/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (modified) Sync with rtems-4-7-branch Sat, 21 Oct 2006 05:18:51 GMT Ralf Corsepius [ce953cb] * contrib/repo-conf/yum.repos.d/.cvsignore (added) New. Sat, 21 Oct 2006 05:16:32 GMT Ralf Corsepius [6f8ddf19] * contrib/repo-conf/Makefile.am (modified) Let config.status generate rtems-@RTEMS_API@-repo-conf.spec Sat, 21 Oct 2006 05:16:11 GMT Ralf Corsepius [5c729e9] * contrib/repo-conf/rtems-repo-conf.spec.in (modified) Use @PACKAGE_TARNAME@ Sat, 21 Oct 2006 05:11:12 GMT Ralf Corsepius [289eefa] * contrib/repo-conf/Makefile.am (modified) Add missing backslash Sat, 21 Oct 2006 05:09:51 GMT Ralf Corsepius [e4c039a5] * contrib/repo-conf/AUTHORS (modified) Add myself. Sat, 21 Oct 2006 05:09:16 GMT Ralf Corsepius [6f23e9e4] * contrib/repo-conf/.cvsignore (added) * contrib/repo-conf/AUTHORS (added) * contrib/repo-conf/COPYING (added) * contrib/repo-conf/ChangeLog (added) * contrib/repo-conf/INSTALL (added) * contrib/repo-conf/Makefile.am (added) * contrib/repo-conf/NEWS (added) * contrib/repo-conf/README (added) * contrib/repo-conf/aclocal/version.m4 (added) * contrib/repo-conf/apt/sources.list.d/.cvsignore (added) * contrib/repo-conf/apt/sources.list.d/rtems.list.in (added) * contrib/repo-conf/apt/vendors.list.d/rtems.list (added) * contrib/repo-conf/configure.ac (added) * contrib/repo-conf/gpg/gpg-pubkey-69ce4a83-44cc2b30 (added) * contrib/repo-conf/gpg/gpg-pubkey-eac29b6f-3fe1f458 (added) * contrib/repo-conf/rtems-repo-conf.spec.in (added) * contrib/repo-conf/yum.repos.d/rtems.repo.in (added) New. Thu, 19 Oct 2006 13:30:56 GMT Ralf Corsepius [c991316e] * contrib/crossrpms/autotools/automake.add (modified) Cleanup. Thu, 19 Oct 2006 08:03:50 GMT Ralf Corsepius [ae4894a] * contrib/crossrpms/patches/automake-1.8.1-rtems-20040112-1.diff (deleted) Remove. Thu, 19 Oct 2006 07:58:56 GMT Ralf Corsepius [8de2d56] * contrib/crossrpms/rtems4.7/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (modified) Bump GCC_RPMREL Thu, 19 Oct 2006 07:57:29 GMT Ralf Corsepius [7dce5bf5] * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (modified) rtems-4.7-h8300-rtems4.7-gcc-4.1.1-5 Thu, 19 Oct 2006 07:56:52 GMT Ralf Corsepius [5b5e9031] * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (modified) rtems-4.7-avr-rtems4.7-gcc-4.0.3-2 Mon, 16 Oct 2006 14:55:56 GMT Ralf Corsepius [a59a751b] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) 2006-10-16 Ralf Corsépius * ... Mon, 16 Oct 2006 11:14:07 GMT Ralf Corsepius [e337b49] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/automake.add (modified) 2006-10-16 Ralf Corsépius * ... Wed, 13 Sep 2006 11:50:03 GMT Ralf Corsepius [4bbd0b4] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060909.diff (added) * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060909.diff (added) New. Fri, 08 Sep 2006 20:33:52 GMT Joel Sherrill [9cb14887] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060908.diff (added) New file. Sun, 03 Sep 2006 10:50:36 GMT Chris Johns [4b88b73] * contrib/rtemsrpms/configure.ac (modified) * contrib/rtemsrpms/rtems.spec.in (modified) Default to not building bsps. Too many problems. Sun, 27 Aug 2006 12:46:13 GMT Chris Johns [896247d] * contrib/mingw/build-exes.sh (modified) Handle the noarch rpms. Dump the file list. Sun, 27 Aug 2006 12:45:28 GMT Chris Johns [2ba11f8] * contrib/mingw/rtems-tools.nsi (modified) Set the prefix into the MSYS fstab, This is a hack but it works. Sun, 27 Aug 2006 12:44:47 GMT Chris Johns [e25ff2c] * contrib/mingw/.cvsignore (modified) Ignore more build output files. Sun, 27 Aug 2006 12:44:08 GMT Chris Johns [5ceb567e] * contrib/mingw/build-rpms.sh (modified) Build the autotools for each RTEMS target. Sun, 27 Aug 2006 12:43:13 GMT Chris Johns [4f5d2dfc] * contrib/mingw/targets (added) Move the target list into a shared file. Wed, 23 Aug 2006 03:53:18 GMT Ralf Corsepius [eb6276b] * contrib/crossrpms/ChangeLog (modified) 2006-08-23 Ralf Corsépius * ... Wed, 23 Aug 2006 03:52:40 GMT Ralf Corsepius [99e02e7] * contrib/crossrpms/rtems4.7/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (modified) Add gcc-4.0.3 Wed, 23 Aug 2006 03:45:43 GMT Ralf Corsepius [7989747] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/gcc/build.add (modified) 2006-08-23 Ralf Corsépius * ... Tue, 22 Aug 2006 12:08:05 GMT Chris Johns [d867214] * contrib/crossrpms/ChangeLog (modified) 2006-08-22 Chris Johns * ... Tue, 22 Aug 2006 11:57:36 GMT Chris Johns [f7891617] * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (modified) Add the 4.0.3 patch. Tue, 22 Aug 2006 11:57:03 GMT Chris Johns [e5e88aa] * contrib/crossrpms/patches/gcc-core-4.0.3-rtems-20060822.diff (added) The .exe for the versioned execuable for MinGW. Tue, 22 Aug 2006 11:41:51 GMT Chris Johns [ef50593] * contrib/rtemsrpms/rtems.spec.in (modified) Change the rpm to use the version. Tue, 22 Aug 2006 11:41:31 GMT Chris Johns [5428a43e] * contrib/rtemsrpms/configure.ac (modified) Add a version for rtems. Add checking messages. Mon, 21 Aug 2006 22:29:53 GMT Chris Johns [a2d7c41] * contrib/mingw/build-rpms.sh (modified) Move the build to host tools out of the target root, Mon, 21 Aug 2006 14:38:33 GMT Joel Sherrill [a94075b] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/patches/binutils-2.17-rtems-20060815.diff (added) * contrib/crossrpms/rtems4.7/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/binutils-sources.add (modified) 2006-08-21 Joel Sherrill * ... Sun, 20 Aug 2006 23:02:44 GMT Chris Johns [7272828] * contrib/mingw/rtems-tools.nsi (modified) Fix the path in the batch file to the installed path. Fri, 18 Aug 2006 11:28:17 GMT Chris Johns [8a1c14b] * contrib/rtemsrpms/Makefile.am (modified) * contrib/rtemsrpms/configure.ac (modified) Renamed the spec file. Fri, 18 Aug 2006 11:27:56 GMT Chris Johns [0e872e6a] * contrib/rtemsrpms/rtems.spec.in (added) Updated the specs file. Thu, 17 Aug 2006 05:51:36 GMT Chris Johns [0e61a81] * contrib/rtemsrpms/rtems.specs.in (deleted) Move to rtems.specs.in. Thu, 17 Aug 2006 05:43:00 GMT Chris Johns [01f1b60c] * contrib/rtemsrpms/.cvsignore (added) * contrib/rtemsrpms/AUTHORS (added) * contrib/rtemsrpms/COPYING (added) * contrib/rtemsrpms/ChangeLog (added) * contrib/rtemsrpms/INSTALL (added) * contrib/rtemsrpms/Makefile.am (added) * contrib/rtemsrpms/NEWS (added) * contrib/rtemsrpms/README (added) * contrib/rtemsrpms/bootstrap (added) * contrib/rtemsrpms/configure.ac (added) * contrib/rtemsrpms/rtems.specs.in (added) Add the rtemsrpms package to RTEMS. Wed, 16 Aug 2006 07:54:10 GMT Ralf Corsepius [67eede5] * contrib/crossrpms/autotools/autoconf.am (modified) * contrib/crossrpms/autotools/automake.am (modified) Pickup common.add from $(top_srcdir). Tue, 15 Aug 2006 03:38:29 GMT Chris Johns [ea3839aa] * contrib/mingw/.cvsignore (added) Ignore the build output. Sat, 12 Aug 2006 06:04:05 GMT Ralf Corsepius [6ed42ac] * contrib/crossrpms/rtems4.7/bfin/binutils-sources.add (modified) binutils-2.17-rtems-20060812.diff Sat, 12 Aug 2006 06:03:27 GMT Ralf Corsepius [070cf12] * contrib/crossrpms/patches/binutils-2.17-rtems-bfin-20060810.diff (deleted) Remove (Merged into binutils-2.17-rtems-20060812.diff). Sat, 12 Aug 2006 06:02:29 GMT Ralf Corsepius [d218a83] * contrib/crossrpms/patches/binutils-2.17-rtems-20060812.diff (added) Update from binutils-2.17_branch. Merge bfin patch. Sat, 12 Aug 2006 05:07:04 GMT Ralf Corsepius [056498a7] * contrib/crossrpms/rtems4.7/Makefile.am (modified) Add bfin Sat, 12 Aug 2006 05:05:52 GMT Ralf Corsepius [a2ced07] * contrib/crossrpms/rtems4.7/bfin/Makefile.am (modified) Reset RPMRELS. Fri, 11 Aug 2006 21:37:40 GMT Joel Sherrill [6d7e836] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/patches/binutils-2.17-rtems-bfin-20060810.diff (added) * contrib/crossrpms/patches/gcc-4.1.1-bfinrtems-20060810a.diff (added) * contrib/crossrpms/patches/gdb-6.5-bfinrtems-20060810a.diff (added) * contrib/crossrpms/patches/newlib-1.14.0-bfinrtems-20060810a.diff (added) * contrib/crossrpms/rtems4.7/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.7/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.7/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/bfin/gdb-sources.add (added) 2006-08-11 Joel Sherrill * ... Thu, 10 Aug 2006 07:04:25 GMT Ralf Corsepius [1a39b67] * contrib/crossrpms/rtems4.7/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.7/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.7/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.7/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.7/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/tic4x/Makefile.am (modified) Bump RPMREL. Wed, 09 Aug 2006 23:06:58 GMT Joel Sherrill [3b97526c] * contrib/crossrpms/.cvsignore (modified) * contrib/crossrpms/ChangeLog (modified) 2006-08-09 Joel Sherrill * ... Mon, 07 Aug 2006 07:30:45 GMT Chris Johns [a819821] * contrib/mingw/ChangeLog (modified) 2006-08-07 Chris Johns * build.sh: Log ... Mon, 07 Aug 2006 07:03:13 GMT Chris Johns [b7c9b29] * contrib/mingw/build.sh (modified) Log the script command lines. Mon, 07 Aug 2006 07:02:41 GMT Chris Johns [72eb02e] * contrib/mingw/build-rpms.sh (modified) Updated to handle a different build processor to a i686. Mon, 07 Aug 2006 07:01:54 GMT Chris Johns [61e5a32] * contrib/mingw/build-exes.sh (modified) Removed the tool version as Ralf has removed it from the rpms. Sat, 05 Aug 2006 04:28:22 GMT Chris Johns [979f36f] * contrib/mingw/build-exes.sh (modified) Update the release tag. Fri, 04 Aug 2006 09:50:08 GMT Chris Johns [5adb73a] * contrib/mingw/build-exes.sh (modified) Updated to support the new installer. Fri, 04 Aug 2006 09:49:35 GMT Chris Johns [1a768ef] * contrib/mingw/build-rpms.sh (modified) Updated to use common rather than base. More rpmbuild work arounds. Fri, 04 Aug 2006 09:48:38 GMT Chris Johns [808db8e] * contrib/mingw/build.sh (modified) Fix the return code when used with tee. Fri, 04 Aug 2006 09:47:54 GMT Chris Johns [5aafd7a] * contrib/mingw/rtems.ini (modified) Updated hello screen. Fri, 04 Aug 2006 09:47:17 GMT Chris Johns [b4723b0d] * contrib/mingw/rtems-tools.nsi (modified) Generate the batch files when installing. Fri, 04 Aug 2006 09:46:14 GMT Chris Johns [7eb4d4b0] * contrib/mingw/AUTHORS (modified) * contrib/mingw/README (modified) Convert to DOS format. Thu, 03 Aug 2006 04:29:22 GMT Ralf Corsepius [6bdebc3a] * contrib/crossrpms/configure.ac (modified) Bump version. Thu, 03 Aug 2006 04:28:43 GMT Ralf Corsepius [c1a25af9] * contrib/crossrpms/autotools/Makefile.am (modified) Use hard-coded %release. Thu, 03 Aug 2006 03:57:47 GMT Ralf Corsepius [5b151f87] * contrib/crossrpms/rtems4.7/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.7/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.7/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.7/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.7/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/tic4x/Makefile.am (modified) Use hard-coded %release. Thu, 03 Aug 2006 02:50:36 GMT Ralf Corsepius [e85211e] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060626.diff (deleted) Remove (Obsolete) Thu, 03 Aug 2006 02:48:31 GMT Ralf Corsepius [52053484] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060704.diff (deleted) Remove Thu, 03 Aug 2006 02:47:53 GMT Ralf Corsepius [3219756b] * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (modified) Update to using newlib-1.14.0-rtems-20060707.diff Wed, 02 Aug 2006 03:39:00 GMT Ralf Corsepius [300dce7] * contrib/crossrpms/configure.ac (modified) Bump version. Wed, 02 Aug 2006 03:37:34 GMT Ralf Corsepius [d9e9a5a] * contrib/crossrpms/autotools/autoconf.am (modified) * contrib/crossrpms/autotools/automake.am (modified) Use further shared spec-fragments. Wed, 02 Aug 2006 03:36:22 GMT Ralf Corsepius [6c873da] * contrib/crossrpms/autotools/autoconf.add (modified) Split out target-autoconf.add Wed, 02 Aug 2006 03:36:11 GMT Ralf Corsepius [a5b38ea] * contrib/crossrpms/autotools/automake.add (modified) Split out target-automake.add Wed, 02 Aug 2006 03:35:10 GMT Ralf Corsepius [e5f924d] * contrib/crossrpms/autotools/target-autoconf.add (added) * contrib/crossrpms/autotools/target-automake.add (added) New. Tue, 25 Jul 2006 16:16:07 GMT Ralf Corsepius [6d05356] * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) Add objc Tue, 25 Jul 2006 16:11:49 GMT Ralf Corsepius [8eb71ea4] * contrib/crossrpms/cygwin/gcc.am (modified) Remove sed -e /[@]tool_target[@]-newlib/d" Tue, 25 Jul 2006 16:11:21 GMT Ralf Corsepius [eca59879] * contrib/crossrpms/cygwin/gcc-prep.add (modified) Remove blank lines. Tue, 25 Jul 2006 16:10:46 GMT Ralf Corsepius [e8b0467] * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/install.add (modified) More %if %build_newlib blocks. Tue, 25 Jul 2006 14:18:12 GMT Ralf Corsepius [6cbe966] * contrib/crossrpms/patches/automake-1.8.1-rtems-20040112-1.diff (added) New. Tue, 25 Jul 2006 13:15:18 GMT Ralf Corsepius [f391f6a] * contrib/crossrpms/autotools/autoconf.add (modified) * contrib/crossrpms/autotools/automake.add (modified) Fix rpmgroup. Cosmetics. Tue, 25 Jul 2006 11:47:04 GMT Ralf Corsepius [41e4caf] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Upgrade to gcc-3.4.4-2, cygwin-1.5.21-1 Mon, 24 Jul 2006 09:01:22 GMT Ralf Corsepius [c45ec73] * contrib/crossrpms/configure.ac (modified) Bump version. Add AC_CONFIG_FILES([autotools/Makefile]) Mon, 24 Jul 2006 08:57:02 GMT Ralf Corsepius [9b966c30] * contrib/crossrpms/Makefile.am (modified) Add autotools. Mon, 24 Jul 2006 08:56:11 GMT Ralf Corsepius [35ed8723] * contrib/crossrpms/NEWS (modified) Add provisory/preliminary autotools support. Mon, 24 Jul 2006 08:54:04 GMT Ralf Corsepius [43fe4445] * contrib/crossrpms/TODO (modified) Cleanup. Add note on autotools. Mon, 24 Jul 2006 08:51:15 GMT Ralf Corsepius [a26364de] * contrib/crossrpms/autotools/.cvsignore (added) * contrib/crossrpms/autotools/Makefile.am (added) * contrib/crossrpms/autotools/autoconf.add (added) * contrib/crossrpms/autotools/autoconf.am (added) * contrib/crossrpms/autotools/automake.add (added) * contrib/crossrpms/autotools/automake.am (added) New.
