# # ChangeLog for contrib in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 18:06:42 Mon, 11 Jan 2010 12:34:44 GMT Ralf Corsepius [217f347] * contrib/repo-conf/.cvsignore (modified) Add INSTALL. Mon, 11 Jan 2010 12:34:31 GMT Ralf Corsepius [f08ecf0] * contrib/repo-conf/INSTALL (deleted) Remove. Wed, 09 Dec 2009 09:29:27 GMT Ralf Corsepius [d258d35] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/rtems-4.9-automake.spec (modified) Upgrade to automake-1.10.3 Fri, 27 Nov 2009 10:31:33 GMT Ralf Corsepius [ef0bb765] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Fri, 27 Nov 2009 10:30:50 GMT Ralf Corsepius [3979832] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GCC_RPMREL. Fri, 27 Nov 2009 10:29:53 GMT Ralf Corsepius [12fcc89] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Update. Fri, 27 Nov 2009 10:21:05 GMT Ralf Corsepius [9656695] * contrib/crossrpms/specstrip (modified) Eliminate g77, f95. Add fortran. Fri, 27 Nov 2009 10:20:12 GMT Ralf Corsepius [eb714e6] * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/build.add (modified) Elminate build_gfortran. Fri, 27 Nov 2009 07:17:05 GMT Ralf Corsepius [99c0b19] * contrib/crossrpms/gcc/base-g77.add (deleted) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gcc/prep.add (modified) * contrib/crossrpms/gcc/target-g77.add (deleted) * contrib/crossrpms/gcc/target-gfortran.add (modified) Eliminate g77 Fri, 27 Nov 2009 07:13:21 GMT Ralf Corsepius [28dd349] * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/install.add (modified) Eliminate g77 Fri, 27 Nov 2009 06:56:20 GMT Ralf Corsepius [3415fab] * contrib/crossrpms/rtems4.9/gcc-prep.add (modified) * contrib/crossrpms/rtems4.9/gcc.am (modified) Sync with rtems4.10. Wed, 11 Nov 2009 15:16:46 GMT Ralf Corsepius [e067753] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Regenerate. Wed, 11 Nov 2009 15:16:08 GMT Ralf Corsepius [c1a7a9e4] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL. Wed, 11 Nov 2009 15:14:45 GMT Ralf Corsepius [ed71047f] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) gdb-6.8-rtems4.9-20091111.diff Wed, 11 Nov 2009 15:13:58 GMT Ralf Corsepius [3ba8469] * contrib/crossrpms/patches/gdb-6.8-rtems4.9-20091111.diff (added) New. Wed, 11 Nov 2009 15:11:23 GMT Ralf Corsepius [001b4e5a] * contrib/crossrpms/gdb/gdb.add (modified) Rework system_readline hacks Wed, 23 Sep 2009 16:41:27 GMT Ralf Corsepius [c4ad618] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Regenerate. Wed, 23 Sep 2009 16:38:51 GMT Ralf Corsepius [79c05a8] * contrib/crossrpms/patches/gdb-6.8-rtems4.9-20090923.diff (added) New. Wed, 23 Sep 2009 16:38:07 GMT Ralf Corsepius [1afc7e0] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL. Wed, 23 Sep 2009 16:37:46 GMT Ralf Corsepius [81ddf59] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) gdb-6.8-rtems4.9-20090923.diff Wed, 23 Sep 2009 11:13:58 GMT Ralf Corsepius [48569c74] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Regenerate. Wed, 23 Sep 2009 11:11:30 GMT Ralf Corsepius [002e4a4b] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL. Wed, 23 Sep 2009 11:11:04 GMT Ralf Corsepius [a87e94df] * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/prep.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Sync with rtems-4.10. Wed, 23 Sep 2009 03:29:58 GMT Ralf Corsepius [209fadea] * contrib/repo-conf/configure.ac (modified) Bump version. Wed, 23 Sep 2009 03:29:15 GMT Ralf Corsepius [6e813710] * contrib/repo-conf/.cvsignore (modified) * contrib/repo-conf/Makefile.am (modified) * contrib/repo-conf/configure.ac (modified) Sync with rtems-4.10. Wed, 23 Sep 2009 03:27:24 GMT Ralf Corsepius [62af225] * contrib/repo-conf/configure.ac (modified) Sync with rtems-4.10. Tue, 15 Sep 2009 05:32:51 GMT cvs2git [ab51444] * c/src/lib/libbsp/arm/gba/console/defaultfont.h (added) * c/src/lib/libbsp/arm/smdk2410/include/.cvsignore (added) * c/src/lib/libbsp/bare/preinstall.am (added) * c/src/lib/libbsp/m68k/genmcf548x/include/.cvsignore (added) * c/src/lib/libbsp/m68k/mcf52235/include/.cvsignore (added) * c/src/lib/libbsp/m68k/mcf5329/include/.cvsignore (added) * c/src/lib/libbsp/mips/csb350/start/regs.h (added) * c/src/lib/libbsp/mips/genmongoosev/start/regs.h (added) * c/src/lib/libbsp/mips/hurricane/liblnk/regs.h (added) * c/src/lib/libbsp/mips/jmr3904/start/regs.h (added) * c/src/lib/libbsp/mips/rbtx4925/liblnk/regs.h (added) * c/src/lib/libbsp/mips/rbtx4938/liblnk/regs.h (added) * c/src/lib/libbsp/powerpc/mvme3100/include/.cvsignore (added) * c/src/lib/libbsp/powerpc/virtex/include/.cvsignore (added) * contrib/crossrpms/autotools/autoconf-sources.add (added) * contrib/crossrpms/autotools/automake-sources.add (added) * contrib/crossrpms/patches/gdb-6.5-bfinrtems-20090122.diff (added) * cpukit/libcsupport/src/tcgetpgrp.c (added) This commit was manufactured by cvs2svn to create branch ... Tue, 25 Aug 2009 05:10:22 GMT Ralf Corsepius [32b09a90] * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) Regenerate. Tue, 25 Aug 2009 05:09:13 GMT Ralf Corsepius [038b1fe2] * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) gcc-core-4.3.2-rtems4.9-20090825.diff Tue, 25 Aug 2009 05:09:00 GMT Ralf Corsepius [8f0d728] * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) Bump GCC_RPMREL. Tue, 25 Aug 2009 05:07:55 GMT Ralf Corsepius [c64da0b5] * contrib/crossrpms/patches/gcc-core-4.3.2-rtems4.9-20090825.diff (added) avr: Use _exit from newlib Thu, 13 Aug 2009 03:29:53 GMT Ralf Corsepius [8131a3d] * contrib/repo-conf/configure.ac (modified) Remove centos-4, tighten up suse, move fedora-9 to centos-5. Sun, 26 Jul 2009 05:56:46 GMT Ralf Corsepius [80e9324] * contrib/crossrpms/autotools/rtems-4.9-autoconf.spec (modified) * contrib/crossrpms/autotools/rtems-4.9-automake.spec (modified) Regenerate. Sun, 26 Jul 2009 05:56:34 GMT Ralf Corsepius [2dcd85d] * contrib/crossrpms/autotools/automake.add (modified) Set amvers to 1.10. Sun, 26 Jul 2009 05:11:31 GMT Ralf Corsepius [65db3bf] * contrib/crossrpms/autotools/autoconf.add (modified) * contrib/crossrpms/autotools/autoconf.am (modified) * contrib/crossrpms/autotools/automake.add (modified) * contrib/crossrpms/autotools/automake.am (modified) Sync with rtems-4.10. Sun, 26 Jul 2009 05:07:00 GMT Ralf Corsepius [a42ad63] * contrib/crossrpms/autotools/Makefile.am (modified) Don't pass %{?dist} to *_RPM_REL Thu, 23 Jul 2009 09:04:58 GMT Ralf Corsepius [118d237d] * contrib/crossrpms/patches/gcc-core-4.3.1-rtems4.9-20080628.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.3.2-rtems4.9-20080828.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.3.2-rtems4.9-20081205.diff (deleted) Remove. Thu, 23 Jul 2009 09:03:07 GMT Ralf Corsepius [80f2a8bc] * contrib/crossrpms/cpukit/build.add (deleted) * contrib/crossrpms/cpukit/cpukit.add (deleted) * contrib/crossrpms/cpukit/install.add (deleted) * contrib/crossrpms/cpukit/prep.add (deleted) * contrib/crossrpms/cpukit/rpm-install.add (deleted) * contrib/crossrpms/cpukit/target-cpukit.add (deleted) Abandon cpukit. Thu, 23 Jul 2009 09:02:30 GMT Ralf Corsepius [e808cbd] * contrib/crossrpms/Makefile.am (modified) Abandon mingw32. Thu, 23 Jul 2009 09:01:39 GMT Ralf Corsepius [38433f5] * contrib/crossrpms/configure.ac (modified) Abandon cygwin, mingw. Thu, 23 Jul 2009 09:00:39 GMT Ralf Corsepius [feb6eb60] * contrib/crossrpms/Makefile.am (modified) Abandon cygwin. Thu, 23 Jul 2009 08:59:22 GMT Ralf Corsepius [41d5d5f] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Thu, 23 Jul 2009 08:58:59 GMT Ralf Corsepius [a227867] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Update to newlib-1.16.0-rtems4.9-20090324.diff. Thu, 23 Jul 2009 08:52:26 GMT Ralf Corsepius [7f43bed] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Thu, 23 Jul 2009 08:51:30 GMT Ralf Corsepius [794e505] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GCC_RPMREL. Thu, 23 Jul 2009 08:45:20 GMT Ralf Corsepius [a6a241e] * contrib/crossrpms/rtems4.9/gcc.am (modified) Sync. with rtems-4.10. Tue, 21 Jul 2009 06:11:40 GMT Ralf Corsepius [b1f7366] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Regenerate. Tue, 21 Jul 2009 06:10:41 GMT Ralf Corsepius [4a5abe71] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) Sync with rtems-4.10. Tue, 21 Jul 2009 06:10:18 GMT Ralf Corsepius [e71a7066] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL. Tue, 21 Jul 2009 06:00:05 GMT Ralf Corsepius [64181ed2] * contrib/crossrpms/patches/gdb-6.8-rtems4.9-20090721.diff (added) New (Backport from rtems-4.10). Tue, 21 Jul 2009 03:24:18 GMT Ralf Corsepius [fb7962d] * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) Regenerate. Tue, 21 Jul 2009 03:23:49 GMT Ralf Corsepius [a9efdc6] * contrib/crossrpms/rtems4.9/bfin/gdb-sources.add (modified) Sync with rtems-4.10. Tue, 21 Jul 2009 03:22:11 GMT Ralf Corsepius [cda3317] * contrib/crossrpms/patches/gdb-6.5-bfinrtems-20071114.diff (deleted) Remove. Mon, 20 Jul 2009 07:49:38 GMT Ralf Corsepius [0e7cd63c] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GCC_RPMREL. Mon, 20 Jul 2009 07:44:48 GMT Ralf Corsepius [a9c3667] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Regenerate. Mon, 20 Jul 2009 07:40:32 GMT Ralf Corsepius [3985708f] * contrib/crossrpms/rtems4.9/binutils.am (modified) Sync with rtems-4.10. Mon, 20 Jul 2009 07:40:01 GMT Ralf Corsepius [a7fb589] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Remove %{?dist} from BINUTILS_RPMREL. Mon, 20 Jul 2009 07:38:35 GMT Ralf Corsepius [52dfb34] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) Update to gdb-6.8-rtems4.9-20090312.diff. Mon, 20 Jul 2009 07:38:00 GMT Ralf Corsepius [eceb158] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL. Mon, 20 Jul 2009 07:37:06 GMT Ralf Corsepius [1c6fd3a6] * contrib/crossrpms/rtems4.9/gdb.am (modified) Sync with rtems-4.10 Sun, 19 Jul 2009 15:20:27 GMT Ralf Corsepius [a181ab0] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) Regenerate. Sun, 19 Jul 2009 15:18:25 GMT Ralf Corsepius [1edb562] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump BINUTILS_RPMREL. Sat, 18 Jul 2009 04:44:26 GMT Ralf Corsepius [98311ac] * contrib/crossrpms/common/common.add (modified) Sync with CVS-HEAD. Thu, 30 Apr 2009 05:08:12 GMT Ralf Corsepius [56e12a17] * contrib/repo-conf/Makefile.am (modified) * contrib/repo-conf/apt/sources.list.d/rtems.list.in (modified) * contrib/repo-conf/configure.ac (modified) * contrib/repo-conf/yum.repos.d/rtems.repo.in (modified) Merge changes from CVS-HEAD addressing Fedora 11 rpm regressions. Wed, 08 Apr 2009 16:13:28 GMT Ralf Corsepius [58b52ad] * contrib/repo-conf/configure.ac (modified) Bump version. Wed, 08 Apr 2009 16:13:15 GMT Ralf Corsepius [2696175] * contrib/repo-conf/yum.repos.d/rtems.repo.in (modified) Use mirrorlists. Tue, 07 Apr 2009 09:25:21 GMT Ralf Corsepius [b88d4243] * contrib/repo-conf/configure.ac (modified) * contrib/repo-conf/yum.repos.d/rtems.repo.in (modified) Add rtems.eu Mon, 30 Mar 2009 05:53:04 GMT Ralf Corsepius [df2afae] * contrib/crossrpms/gcc/install.add (modified) Backport from CVS-HEAD. Tue, 24 Mar 2009 05:15:07 GMT Ralf Corsepius [6be9bc0] * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) Regenerate. Tue, 24 Mar 2009 05:14:33 GMT Ralf Corsepius [7b32a78] * contrib/crossrpms/patches/newlib-1.16.0-rtems4.9-20090324.diff (added) Remove libc/machine/powerpc/times.c. Tue, 24 Mar 2009 05:12:50 GMT Ralf Corsepius [a70ea802] * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) newlib-1.16.0-rtems4.9-20090324.diff Tue, 24 Mar 2009 05:12:30 GMT Ralf Corsepius [6f0ad35] * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) Bump GCC_RPMREL. Thu, 12 Mar 2009 09:48:47 GMT Ralf Corsepius [1a813d50] * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) Regenerate. Thu, 12 Mar 2009 09:48:35 GMT Ralf Corsepius [0d00cd53] * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) Bump GDB_RPMREL. Thu, 12 Mar 2009 09:48:17 GMT Ralf Corsepius [46b86dd] * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) gdb-6.8-rtems4.9-20090312.diff Thu, 12 Mar 2009 09:47:45 GMT Ralf Corsepius [30a4480f] * contrib/crossrpms/patches/gdb-6.8-rtems4.9-20090312.diff (added) Add psim/configure. Thu, 12 Mar 2009 09:45:33 GMT Ralf Corsepius [f6a237b] * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Sync w/ cvs-head. Sat, 07 Feb 2009 09:26:19 GMT Ralf Corsepius [6cd53b2] * contrib/crossrpms/cpukit/build.add (modified) * contrib/crossrpms/cpukit/cpukit.add (modified) * contrib/crossrpms/cpukit/rpm-install.add (modified) * contrib/crossrpms/cpukit/target-cpukit.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-newlib.add (modified) Sync with CVS-HEAD. Sat, 07 Feb 2009 09:22:02 GMT Ralf Corsepius [bdf53bd4] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Sat, 07 Feb 2009 09:16:48 GMT Ralf Corsepius [c8d8a70] * contrib/crossrpms/rtems4.9/gcc.am (modified) Add NEWLIB_PKGVERS, NEWLIB_RPMREL. Sat, 07 Feb 2009 09:16:16 GMT Ralf Corsepius [8ec3c96] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GCC_RPMREL. Add NEWLIB_PKGVERS, NEWLIB_RPMREL. Sat, 07 Feb 2009 09:15:24 GMT Ralf Corsepius [58a6716] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) newlib-1.16.0-rtems4.9-20090207.diff Sat, 07 Feb 2009 08:56:59 GMT Ralf Corsepius [deb0a5a3] * contrib/crossrpms/patches/newlib-1.16.0-rtems4.9-20090207.diff (added) Remove newlib/libc/include/sched.h. Wed, 21 Jan 2009 15:26:50 GMT Ralf Corsepius [8594dc7] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Bump GCC_RPMREL. Wed, 21 Jan 2009 12:19:03 GMT Ralf Corsepius [a7a8491d] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) Bump BINUTILS_RPMREL. Wed, 21 Jan 2009 12:16:32 GMT Ralf Corsepius [91a3c19b] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/rtems-4.9-autoconf.spec (modified) * contrib/crossrpms/autotools/rtems-4.9-automake.spec (modified) Bump RPMREL. Tue, 20 Jan 2009 16:33:34 GMT Ralf Corsepius [7ad3289] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Regenerate. Tue, 20 Jan 2009 16:31:01 GMT Ralf Corsepius [4196eb67] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL. Tue, 20 Jan 2009 16:29:13 GMT Ralf Corsepius [de057528] * contrib/crossrpms/common/common.add (modified) Sync with CVS-HEAD. Sun, 14 Dec 2008 05:28:55 GMT Ralf Corsepius [757e3465] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Sun, 14 Dec 2008 05:27:39 GMT Ralf Corsepius [26dd590] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) GCC_RPMREL = 18%{?dist}. Sun, 14 Dec 2008 05:26:45 GMT Ralf Corsepius [09a43cb2] * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) Activate c++. Sun, 14 Dec 2008 05:26:06 GMT Ralf Corsepius [7f93a2a2] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Abandon gcc-4.3.1. newlib-1.16.0-rtems4.9-20081203.diff ... Sun, 14 Dec 2008 05:24:15 GMT Ralf Corsepius [50684083] * contrib/crossrpms/patches/gcc-core-4.3.2-rtems4.9-20081214.diff (added) Remove rs6000 MULTILIB_EXTRA_OPTS. Sun, 14 Dec 2008 04:38:16 GMT Ralf Corsepius [40e91555] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) Regenerate. Sun, 14 Dec 2008 04:37:35 GMT Ralf Corsepius [112b010] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) binutils-2.19. Fri, 05 Dec 2008 08:34:16 GMT Ralf Corsepius [a1abe18a] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) Update. Fri, 05 Dec 2008 08:33:35 GMT Ralf Corsepius [538c88e] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) Regenerate. Fri, 05 Dec 2008 08:33:23 GMT Ralf Corsepius [c27b30db] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) Bump GCC_RPMREL. Fri, 05 Dec 2008 08:27:08 GMT Ralf Corsepius [9d146ecc] * contrib/crossrpms/patches/newlib-1.16.0-rtems4.9-20081203.diff (added) Make c99 io default. Add prototype for ttyname_t.
