# # ChangeLog for contrib in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 17:18:41 Wed, 08 Sep 2010 04:20:45 GMT Ralf Corsepius [17ef36e] * contrib/crossrpms/patches/gdb-7.2-rtems4.11-20100907.diff (added) New. Wed, 08 Sep 2010 04:11:06 GMT Ralf Corsepius [45393475] * contrib/crossrpms/specstrip (modified) Parse condstack in final printing. Wed, 08 Sep 2010 04:05:24 GMT Ralf Corsepius [ffa0418] * contrib/crossrpms/specstrip (modified) Prepend @condstack to @buffer4 lines. Wed, 08 Sep 2010 04:04:10 GMT Ralf Corsepius [cf1c37c6] * contrib/crossrpms/specstrip (modified) Prepend @condstack to @buffer4 lines. Wed, 08 Sep 2010 04:01:16 GMT Ralf Corsepius [cc35ad6] * contrib/crossrpms/specstrip (modified) Simplify %if rules. Tue, 07 Sep 2010 17:08:09 GMT Ralf Corsepius [ed50636] * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) Regenerate. Tue, 07 Sep 2010 17:07:44 GMT Ralf Corsepius [174f6f2c] * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (modified) gdb-7.2-rtems4.11-20100907.diff Tue, 07 Sep 2010 17:04:44 GMT Ralf Corsepius [700429e] * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) Bump GDB_RPMREL. Tue, 07 Sep 2010 17:04:16 GMT Ralf Corsepius [0c8ebef] * contrib/crossrpms/gdb/gdb.add (modified) Add --enable-sim-trace for powerpc-rtems* Tue, 07 Sep 2010 14:39:18 GMT Ralf Corsepius [0ffc26d5] * contrib/crossrpms/autotools/rtems-4.11-automake.spec (modified) Regenerate. Tue, 07 Sep 2010 14:38:54 GMT Ralf Corsepius [71f5d6f7] * contrib/crossrpms/autotools/Makefile.am (modified) Bump AUTOMAKE_RPMREL. Tue, 07 Sep 2010 14:38:36 GMT Ralf Corsepius [8a4b9c9] * contrib/crossrpms/autotools/automake.add (modified) Add workaround to mingw shipping an obsolete version of perl. Remove ... Tue, 07 Sep 2010 14:36:40 GMT Ralf Corsepius [4cbe22a] * contrib/crossrpms/autotools/rtems-4.10-autoconf.spec (deleted) * contrib/crossrpms/autotools/rtems-4.10-automake.spec (deleted) Housekeeping Fri, 03 Sep 2010 05:48:42 GMT Ralf Corsepius [18c4308] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gdb.spec (modified) Regenerate. Fri, 03 Sep 2010 05:48:08 GMT Ralf Corsepius [d76de26] * contrib/crossrpms/rtems4.11/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gdb-sources.add (modified) Add gdb-7.2 Fri, 03 Sep 2010 05:47:31 GMT Ralf Corsepius [b791b20c] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) GDB_VERS = 7.2 Fri, 03 Sep 2010 05:46:26 GMT Ralf Corsepius [d40a62d] * contrib/crossrpms/patches/gdb-7.2-rtems4.11-20100903.diff (added) New (gdb-7.1 patches rebased against gdb-7.2) Sat, 28 Aug 2010 06:14:02 GMT Ralf Corsepius [d5811d0] * contrib/crossrpms/gcc/gccnewlib.add (modified) Abandon Fedora 11. Thu, 26 Aug 2010 02:18:24 GMT Ralf Corsepius [74b45094] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-binutils.spec (modified) Regenerate. Thu, 26 Aug 2010 02:16:40 GMT Ralf Corsepius [8c81f884] * contrib/crossrpms/rtems4.11/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/binutils-sources.add (modified) binutils-2.20.1-rtems4.11-20100826.diff Thu, 26 Aug 2010 02:16:19 GMT Ralf Corsepius [d89e247] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump BINUTILS_RPMREL. Thu, 26 Aug 2010 02:15:42 GMT Ralf Corsepius [8c168003] * contrib/crossrpms/patches/binutils-2.20.1-rtems4.11-20100826.diff (added) Add binutils-pr11939 patch. Wed, 25 Aug 2010 12:46:46 GMT Ralf Corsepius [0d10d566] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Wed, 25 Aug 2010 12:46:17 GMT Ralf Corsepius [b51eb88b] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Wed, 25 Aug 2010 12:46:01 GMT Ralf Corsepius [763e117] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20100825.diff. Wed, 25 Aug 2010 12:45:40 GMT Ralf Corsepius [0fa653a6] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20100825.diff (added) New. Wed, 18 Aug 2010 10:31:17 GMT Ralf Corsepius [d7c4e1d] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Wed, 18 Aug 2010 10:30:30 GMT Ralf Corsepius [f1d5b89] * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/prep.add (modified) Add bcond_with gcc_stdint. Wed, 18 Aug 2010 10:29:57 GMT Ralf Corsepius [aea64105] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) gcc-core-4.5.1-rtems4.11-20100818.diff Wed, 18 Aug 2010 10:29:40 GMT Ralf Corsepius [08634cb2] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) GCC_RPMREL = 5 Wed, 18 Aug 2010 10:25:35 GMT Ralf Corsepius [8cfa0bcd] * contrib/crossrpms/patches/gcc-core-4.5.1-rtems4.11-20100818.diff (added) New. Sun, 15 Aug 2010 06:38:50 GMT Ralf Corsepius [b8165ce] * contrib/crossrpms/patches/gcc-core-4.5.1-rtems4.11-20100726.diff (modified) Remove bogusly included files. Fri, 13 Aug 2010 03:06:37 GMT Ralf Corsepius [92101def] * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/i686-pc-mingw32-mpfr.spec (modified) * contrib/crossrpms/mingw32/i686/mpfr.add (modified) mpfr-2.4.2 Fri, 13 Aug 2010 02:13:00 GMT Ralf Corsepius [fb477dd] * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/amd64-pc-netbsdelf5.0.2-gcc.spec (modified) Regenerate. Fri, 13 Aug 2010 02:12:35 GMT Ralf Corsepius [4393d371] * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/Makefile.am (modified) Bump GCC_RPMREL. Thu, 12 Aug 2010 15:39:16 GMT Ralf Corsepius [8d32cc6a] * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-gcc.spec (modified) * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-gcc.spec (modified) * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-gcc.spec (modified) * contrib/crossrpms/freebsd8.0/x86_64/amd64-pc-freebsd8.0-gcc.spec (modified) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-gcc.spec (modified) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-gcc.spec (modified) Regenerate. Thu, 12 Aug 2010 15:38:48 GMT Ralf Corsepius [bd87139e] * contrib/crossrpms/freebsd6.4/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.3/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.0/x86_64/Makefile.am (modified) * contrib/crossrpms/freebsd8.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.1/x86_64/Makefile.am (modified) Bump GCC_RPMREL. Thu, 12 Aug 2010 14:10:27 GMT Ralf Corsepius [aa04052] * contrib/crossrpms/patches/gdb-7.1-rtems4.11-20100812.diff (added) New. Thu, 12 Aug 2010 14:09:54 GMT Ralf Corsepius [9f86f4a9] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gdb.spec (modified) Regenerate. Thu, 12 Aug 2010 14:09:15 GMT Ralf Corsepius [645febd5] * contrib/crossrpms/rtems4.11/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gdb-sources.add (modified) gdb-7.1-rtems4.11-20100812.diff. Thu, 12 Aug 2010 14:08:41 GMT Ralf Corsepius [bff5732] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GDB_RPMREL = 4 Tue, 10 Aug 2010 04:07:41 GMT Ralf Corsepius [aec88a2] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Tue, 10 Aug 2010 04:04:48 GMT Ralf Corsepius [68735e83] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20100810.diff. Tue, 10 Aug 2010 04:04:17 GMT Ralf Corsepius [3f568eb1] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Tue, 10 Aug 2010 04:01:15 GMT Ralf Corsepius [b78a7fa] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20100810.diff (added) New. Thu, 05 Aug 2010 06:01:35 GMT Ralf Corsepius [244ddf5] * contrib/crossrpms/autotools/rtems-4.11-autoconf.spec (modified) Regenerate. Thu, 05 Aug 2010 06:01:02 GMT Ralf Corsepius [96546af] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/autoconf-sources.add (modified) * contrib/crossrpms/autotools/autoconf.add (modified) autoconf-2.67. Thu, 05 Aug 2010 05:15:47 GMT Ralf Corsepius [06889f21] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20100804.diff (added) New. Thu, 05 Aug 2010 05:14:16 GMT Ralf Corsepius [7f45f8f8] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Thu, 05 Aug 2010 05:13:17 GMT Ralf Corsepius [d5791b4] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Thu, 05 Aug 2010 05:13:02 GMT Ralf Corsepius [a12bf1d] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20100804.diff. Thu, 05 Aug 2010 05:11:54 GMT Ralf Corsepius [7f77810] * contrib/crossrpms/gcc/gccnewlib.add (modified) Preps for fedora-14. Fix Source60:-URL (mpfr). Sun, 01 Aug 2010 04:11:56 GMT Ralf Corsepius [674fbe24] * contrib/crossrpms/patches/gcc-core-4.5.1-rtems4.11-20100726.diff (added) Rename to final patch name. Sun, 01 Aug 2010 04:10:14 GMT Ralf Corsepius [e06d0de0] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sun, 01 Aug 2010 04:09:26 GMT Ralf Corsepius [3649bde] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) GCC_PKGVERS = $(GCC_VERS) Sun, 01 Aug 2010 04:04:26 GMT Ralf Corsepius [ffbfa5b] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sun, 01 Aug 2010 04:03:04 GMT Ralf Corsepius [522db213] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Sun, 01 Aug 2010 04:02:12 GMT Ralf Corsepius [1e94b1d] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) gcc-4.5.1 (final). Tue, 27 Jul 2010 15:28:51 GMT Ralf Corsepius [8a51913f] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Tue, 27 Jul 2010 15:28:13 GMT Ralf Corsepius [b61cc954] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) Adjust Source1. Tue, 27 Jul 2010 13:19:56 GMT Ralf Corsepius [6b8ce02] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Apply missing commit. Tue, 27 Jul 2010 13:18:28 GMT Ralf Corsepius [21eb051] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Update cyginw, terminfo. Tue, 27 Jul 2010 13:17:23 GMT Ralf Corsepius [a171d20c] * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-terminfo.spec (modified) Regenerate. Tue, 27 Jul 2010 11:45:50 GMT Ralf Corsepius [e544466] * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-libs.spec (modified) Regenerate. Tue, 27 Jul 2010 09:25:07 GMT Ralf Corsepius [acd71a92] * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-gcc.spec (modified) Regenerate. Tue, 27 Jul 2010 09:24:33 GMT Ralf Corsepius [6e5ddefe] * contrib/crossrpms/freebsd6.4/i586/Makefile.am (modified) Bump GCC_RPMREL. Tue, 27 Jul 2010 09:17:31 GMT Ralf Corsepius [7722a178] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add freebsd8.1. Tue, 27 Jul 2010 04:37:58 GMT Ralf Corsepius [dcbc5458] * contrib/crossrpms/freebsd8.1/.cvsignore (added) * contrib/crossrpms/freebsd8.1/Makefile.am (added) * contrib/crossrpms/freebsd8.1/binutils.am (added) * contrib/crossrpms/freebsd8.1/gcc-prep.add (added) * contrib/crossrpms/freebsd8.1/gcc.am (added) * contrib/crossrpms/freebsd8.1/i586/.cvsignore (added) * contrib/crossrpms/freebsd8.1/i586/Makefile.am (added) * contrib/crossrpms/freebsd8.1/i586/binutils-sources.add (added) * contrib/crossrpms/freebsd8.1/i586/gcc-sources.add (added) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-binutils.spec (added) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-gcc.spec (added) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-libs.spec (added) * contrib/crossrpms/freebsd8.1/i586/libs.add (added) * contrib/crossrpms/freebsd8.1/i586/target-libs.add (added) * contrib/crossrpms/freebsd8.1/libs.am (added) * contrib/crossrpms/freebsd8.1/x86_64/.cvsignore (added) * contrib/crossrpms/freebsd8.1/x86_64/Makefile.am (added) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-binutils.spec (added) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-gcc.spec (added) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-libs.spec (added) * contrib/crossrpms/freebsd8.1/x86_64/binutils-sources.add (added) * contrib/crossrpms/freebsd8.1/x86_64/gcc-sources.add (added) * contrib/crossrpms/freebsd8.1/x86_64/libs.add (added) * contrib/crossrpms/freebsd8.1/x86_64/target-libs.add (added) New. Mon, 26 Jul 2010 09:42:46 GMT Ralf Corsepius [b478902] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Mon, 26 Jul 2010 09:41:53 GMT Ralf Corsepius [935b8ee] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) Upgrade to gcc-4.5.1-RC-20100722. Mon, 12 Jul 2010 03:54:46 GMT Ralf Corsepius [72f9fbfb] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sun, 11 Jul 2010 20:20:21 GMT Ralf Corsepius [f960239] * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/amd64-pc-netbsdelf5.0.2-gcc.spec (modified) Regenerate. Sun, 11 Jul 2010 20:20:00 GMT Ralf Corsepius [9e421af] * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/Makefile.am (modified) Bump GCC_RPMREL. Sun, 11 Jul 2010 20:13:34 GMT Ralf Corsepius [dd5d8232] * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-gcc.spec (modified) Regenerate. Sun, 11 Jul 2010 20:13:14 GMT Ralf Corsepius [f8a53492] * contrib/crossrpms/freebsd7.3/i586/Makefile.am (modified) Bump GCC_RPMREL. Sun, 11 Jul 2010 20:07:59 GMT Ralf Corsepius [6549b1b] * contrib/crossrpms/freebsd8.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.0/x86_64/Makefile.am (modified) Bump GCC_RPMREL. Sun, 11 Jul 2010 20:07:38 GMT Ralf Corsepius [88b51b9] * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-gcc.spec (modified) * contrib/crossrpms/freebsd8.0/x86_64/amd64-pc-freebsd8.0-gcc.spec (modified) suse-11.3 Sun, 11 Jul 2010 20:00:22 GMT Ralf Corsepius [46f41ab] * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-gcc.spec (modified) Add suse-11.3. Update mpfr. Sat, 10 Jul 2010 16:18:25 GMT Ralf Corsepius [766cc49] * contrib/crossrpms/gcc/gccnewlib.add (modified) openSUSE-11.3 has mpc-0.8.1. Sat, 10 Jul 2010 05:41:54 GMT Ralf Corsepius [9f92b78] * contrib/crossrpms/gcc/gccnewlib.add (modified) Add suse-11.3. Thu, 08 Jul 2010 16:46:19 GMT Ralf Corsepius [c302d31a] * contrib/crossrpms/autotools/rtems-4.11-autoconf.spec (modified) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Thu, 08 Jul 2010 16:44:21 GMT Ralf Corsepius [5857fc92] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Thu, 08 Jul 2010 16:43:52 GMT Ralf Corsepius [8d531b4] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20100708.diff Thu, 08 Jul 2010 16:34:11 GMT Ralf Corsepius [36f7824] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20100708.diff (added) New. Thu, 08 Jul 2010 13:01:34 GMT Ralf Corsepius [c19bdd1c] * contrib/crossrpms/patches/autoconf-2.66-611661.diff (added) New. Thu, 08 Jul 2010 13:01:04 GMT Ralf Corsepius [9d323a9] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/autoconf-sources.add (modified) * contrib/crossrpms/autotools/autoconf.add (modified) * contrib/crossrpms/autotools/rtems-4.11-autoconf.spec (modified) autoconf-2.66 Mon, 21 Jun 2010 22:56:35 GMT Joel Sherrill [06911e0] * contrib/rtemsrpms/ChangeLog (modified) * contrib/rtemsrpms/rtems.spec.in (modified) 2010-06-21 Joel Sherrill * ... Thu, 17 Jun 2010 16:36:00 GMT Ralf Corsepius [9a458f9] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20100617.diff (added) New. Thu, 17 Jun 2010 16:35:29 GMT Ralf Corsepius [60729c3] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Thu, 17 Jun 2010 16:33:51 GMT Ralf Corsepius [455acb5] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) GCC_RPMREL = 14. Thu, 17 Jun 2010 16:32:18 GMT Ralf Corsepius [b3036fb] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20100617.diff. Thu, 10 Jun 2010 04:11:31 GMT Ralf Corsepius [9b432db] * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/amd64-pc-netbsdelf5.0.2-gcc.spec (modified) Regenerate. Wed, 09 Jun 2010 07:30:11 GMT Ralf Corsepius [c7bdd77] * contrib/crossrpms/patches/gcc-core-4.5.0-rtems4.11-20100526.diff (deleted) Remove. Wed, 09 Jun 2010 07:29:42 GMT Ralf Corsepius [82519fe] * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/i386/gcc-sources.add (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Update. Wed, 09 Jun 2010 07:26:34 GMT Ralf Corsepius [91d8931] * contrib/crossrpms/patches/gcc-core-4.5.0-rtems4.11-20100609.diff (added) New (Incorporate netbsd hacks) Wed, 09 Jun 2010 07:01:08 GMT Ralf Corsepius [6bd96141] * contrib/crossrpms/patches/gdb-7.1-rtems4.10-20100319.diff (deleted) Remove. Wed, 09 Jun 2010 07:00:45 GMT Ralf Corsepius [4293025] * contrib/crossrpms/patches/gdb-7.1-rtems4.11-20100609.diff (added) Rebase patch for rtems4.11. Wed, 09 Jun 2010 06:59:52 GMT Ralf Corsepius [65dd01e] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gdb.spec (modified) Regenerate. Wed, 09 Jun 2010 06:59:05 GMT Ralf Corsepius [1332cb9] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GDB_RPMREL. Wed, 09 Jun 2010 06:57:18 GMT Ralf Corsepius [53dd37cb] * contrib/crossrpms/rtems4.11/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gdb-sources.add (modified) Abandon gdb-7.0.1
