# # ChangeLog for contrib/rtemsrpms in rtems # # Generated by Trac 1.2.1.dev0 # 05/02/24 21:17:50 Sun, 03 Sep 2006 10:50:36 GMT Chris Johns [4b88b73] * contrib/rtemsrpms/configure.ac (modified) * contrib/rtemsrpms/rtems.spec.in (modified) Default to not building bsps. Too many problems. Tue, 22 Aug 2006 11:41:51 GMT Chris Johns [ef50593] * contrib/rtemsrpms/rtems.spec.in (modified) Change the rpm to use the version. Tue, 22 Aug 2006 11:41:31 GMT Chris Johns [5428a43e] * contrib/rtemsrpms/configure.ac (modified) Add a version for rtems. Add checking messages. Fri, 18 Aug 2006 11:28:17 GMT Chris Johns [8a1c14b] * contrib/rtemsrpms/Makefile.am (modified) * contrib/rtemsrpms/configure.ac (modified) Renamed the spec file. Fri, 18 Aug 2006 11:27:56 GMT Chris Johns [0e872e6a] * contrib/rtemsrpms/rtems.spec.in (added) Updated the specs file. Thu, 17 Aug 2006 05:51:36 GMT Chris Johns [0e61a81] * contrib/rtemsrpms/rtems.specs.in (deleted) Move to rtems.specs.in. Thu, 17 Aug 2006 05:43:00 GMT Chris Johns [01f1b60c] * contrib/rtemsrpms/.cvsignore (added) * contrib/rtemsrpms/AUTHORS (added) * contrib/rtemsrpms/COPYING (added) * contrib/rtemsrpms/ChangeLog (added) * contrib/rtemsrpms/INSTALL (added) * contrib/rtemsrpms/Makefile.am (added) * contrib/rtemsrpms/NEWS (added) * contrib/rtemsrpms/README (added) * contrib/rtemsrpms/bootstrap (added) * contrib/rtemsrpms/configure.ac (added) * contrib/rtemsrpms/rtems.specs.in (added) Add the rtemsrpms package to RTEMS.
