# # ChangeLog for contrib/mingw in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 09:30:02 Sun, 27 Aug 2006 12:46:13 GMT Chris Johns [896247d] * contrib/mingw/build-exes.sh (modified) Handle the noarch rpms. Dump the file list. Sun, 27 Aug 2006 12:45:28 GMT Chris Johns [2ba11f8] * contrib/mingw/rtems-tools.nsi (modified) Set the prefix into the MSYS fstab, This is a hack but it works. Sun, 27 Aug 2006 12:44:47 GMT Chris Johns [e25ff2c] * contrib/mingw/.cvsignore (modified) Ignore more build output files. Sun, 27 Aug 2006 12:44:08 GMT Chris Johns [5ceb567e] * contrib/mingw/build-rpms.sh (modified) Build the autotools for each RTEMS target. Sun, 27 Aug 2006 12:43:13 GMT Chris Johns [4f5d2dfc] * contrib/mingw/targets (added) Move the target list into a shared file. Mon, 21 Aug 2006 22:29:53 GMT Chris Johns [a2d7c41] * contrib/mingw/build-rpms.sh (modified) Move the build to host tools out of the target root, Sun, 20 Aug 2006 23:02:44 GMT Chris Johns [7272828] * contrib/mingw/rtems-tools.nsi (modified) Fix the path in the batch file to the installed path. Tue, 15 Aug 2006 03:38:29 GMT Chris Johns [ea3839aa] * contrib/mingw/.cvsignore (added) Ignore the build output. Mon, 07 Aug 2006 07:30:45 GMT Chris Johns [a819821] * contrib/mingw/ChangeLog (modified) 2006-08-07 Chris Johns * build.sh: Log ... Mon, 07 Aug 2006 07:03:13 GMT Chris Johns [b7c9b29] * contrib/mingw/build.sh (modified) Log the script command lines. Mon, 07 Aug 2006 07:02:41 GMT Chris Johns [72eb02e] * contrib/mingw/build-rpms.sh (modified) Updated to handle a different build processor to a i686. Mon, 07 Aug 2006 07:01:54 GMT Chris Johns [61e5a32] * contrib/mingw/build-exes.sh (modified) Removed the tool version as Ralf has removed it from the rpms. Sat, 05 Aug 2006 04:28:22 GMT Chris Johns [979f36f] * contrib/mingw/build-exes.sh (modified) Update the release tag. Fri, 04 Aug 2006 09:50:08 GMT Chris Johns [5adb73a] * contrib/mingw/build-exes.sh (modified) Updated to support the new installer. Fri, 04 Aug 2006 09:49:35 GMT Chris Johns [1a768ef] * contrib/mingw/build-rpms.sh (modified) Updated to use common rather than base. More rpmbuild work arounds. Fri, 04 Aug 2006 09:48:38 GMT Chris Johns [808db8e] * contrib/mingw/build.sh (modified) Fix the return code when used with tee. Fri, 04 Aug 2006 09:47:54 GMT Chris Johns [5aafd7a] * contrib/mingw/rtems.ini (modified) Updated hello screen. Fri, 04 Aug 2006 09:47:17 GMT Chris Johns [b4723b0d] * contrib/mingw/rtems-tools.nsi (modified) Generate the batch files when installing. Fri, 04 Aug 2006 09:46:14 GMT Chris Johns [7eb4d4b0] * contrib/mingw/AUTHORS (modified) * contrib/mingw/README (modified) Convert to DOS format. Sat, 22 Jul 2006 07:23:51 GMT Chris Johns [332fd2a] * contrib/mingw/COPYING (added) * contrib/mingw/build.sh (added) * contrib/mingw/rtems-license.rtf (added) Changes to the installer and an extra script to build all. Fri, 21 Jul 2006 00:13:42 GMT Chris Johns [83fc6ac] * contrib/mingw/ChangeLog (modified) 2006-07-21 Chris Johns * ... Fri, 21 Jul 2006 00:11:54 GMT Chris Johns [ed70a496] * contrib/mingw/build-rpms.sh (added) Add the build-rpms.sh here until moved to crossrpms. Fri, 21 Jul 2006 00:07:45 GMT Chris Johns [7cadb8e] * contrib/mingw/AUTHORS (added) * contrib/mingw/ChangeLog (added) * contrib/mingw/README (added) Add the support files. Fri, 21 Jul 2006 00:04:20 GMT Chris Johns [be77d1f] * contrib/mingw/build-exes.sh (added) * contrib/mingw/rtems-tools.nsi (added) * contrib/mingw/rtems.ini (added) * contrib/mingw/rtems_logo.bmp (added) Add NSIS installer support for MinGW.
