# # ChangeLog for contrib/mingw/build.sh in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 01:25:16 Mon, 07 Aug 2006 07:03:13 GMT Chris Johns [b7c9b29] * contrib/mingw/build.sh (modified) Log the script command lines. Fri, 04 Aug 2006 09:48:38 GMT Chris Johns [808db8e] * contrib/mingw/build.sh (modified) Fix the return code when used with tee. Sat, 22 Jul 2006 07:23:51 GMT Chris Johns [332fd2a] * contrib/mingw/COPYING (added) * contrib/mingw/build.sh (added) * contrib/mingw/rtems-license.rtf (added) Changes to the installer and an extra script to build all.
