Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/contrib/crossrpms
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @ec011e5a   02/08/07 07:22:11 Ralf Corsepius New. 4.104.114.84.95
(edit) @92b61a71   02/08/07 06:01:40 Ralf Corsepius Remove (Obsolete). 4.104.114.84.95
(edit) @d044f9d   02/08/07 05:58:29 Ralf Corsepius Abandon newlib-1.14.0. 4.104.114.84.95
(edit) @080c23d   02/02/07 15:43:09 Ralf Corsepius Upgrade to gcc-core-4.1.1-rtems4.8-20070201.diff, … 4.104.114.84.95
(edit) @91350690   02/02/07 15:07:55 Ralf Corsepius Yet another attempt. 4.104.114.84.95
(edit) @a8f155b8   01/31/07 10:39:24 Ralf Corsepius Next try: gcc-core-4.1.1-rtems4.8-20070131.diff 4.104.114.84.95
(edit) @a423203   01/31/07 03:40:12 Ralf Corsepius Preps for next spin. 4.104.114.84.95
(edit) @500a9c5d   01/31/07 03:39:52 Ralf Corsepius New. 4.104.114.84.95
(edit) @282197c4   01/12/07 08:33:13 Ralf Corsepius Disable binutils infos. 4.104.114.84.95
(edit) @72b911c   01/12/07 08:31:37 Ralf Corsepius Add BINUTILS_OPTS += 4.104.114.84.95
(edit) @85f9bdc   01/12/07 08:26:51 Ralf Corsepius Bump GCC_RPMREL 4.104.114.84.95
(edit) @ec24bd5a   01/12/07 08:26:14 Ralf Corsepius Update to gcc-core-4.2.0-rtems4.8-20070112.diff 4.104.114.84.95
(edit) @ce625960   01/12/07 04:36:25 Ralf Corsepius Remove (Obsolete). 4.104.114.84.95
(edit) @652473b3   01/12/07 04:35:49 Ralf Corsepius Update (bfin merged into upstream) 4.104.114.84.95
(edit) @b4de41dd   01/12/07 03:57:28 Ralf Corsepius Use gcc-core-4.1.1-rtems4.8-20070102.diff 4.104.114.84.95
(edit) @c116b31   01/12/07 03:53:39 Ralf Corsepius Upgrade to newlib-1.15.0-rtems4.8-20070110. 4.104.114.84.95
(edit) @5709d75e   01/12/07 03:49:15 Ralf Corsepius Add BINUTILS_OPTS. 4.104.114.84.95
(edit) @c80654e   01/12/07 03:39:21 Ralf Corsepius Bump GCC_RPMREL. 4.104.114.84.95
(edit) @cb08aeb   01/10/07 08:02:41 Ralf Corsepius Bump releases. 4.104.114.84.95
(edit) @1b5a5610   01/10/07 08:02:07 Ralf Corsepius Rename automake-rtems into automake. Rename autoconf-rtems into autoconf. 4.104.114.84.95
(edit) @727e8469   01/10/07 08:02:01 Ralf Corsepius Rename autoconf-rtems into autoconf. 4.104.114.84.95
(edit) @d82b3f1b   01/10/07 06:31:57 Ralf Corsepius Update bugfix address 4.104.114.84.95
(edit) @3d62598   01/10/07 06:05:01 Ralf Corsepius Add ECANCELED. 4.104.114.84.95
(edit) @35db46f   01/04/07 13:43:21 Ralf Corsepius Add BINUTILS_OPTS 4.104.114.84.95
(edit) @598e035   01/04/07 12:52:40 Ralf Corsepius Add support for newlib-1.15.0 4.104.114.84.95
(edit) @6e0bde6   01/04/07 08:04:31 Ralf Corsepius Add newlib-1.15.0. New GCC snapshot. 4.104.114.84.95
(edit) @e0c27b1   01/04/07 08:00:32 Ralf Corsepius New. 4.104.114.84.95
(edit) @5ebd9351   01/02/07 11:49:35 Ralf Corsepius Upgrade to newlib-1.15.0 4.104.114.84.95
(edit) @227afd10   01/02/07 10:44:12 Ralf Corsepius New. 4.104.114.84.95
(edit) @adb07b1   12/19/06 16:30:30 Ralf Corsepius New. 4.104.114.84.95
(edit) @fcb0cd46   12/02/06 06:06:55 Ralf Corsepius 2006-12-02 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @f319598   11/20/06 05:39:07 Ralf Corsepius 2006-11-19 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @bd8f4d8   11/19/06 03:38:30 Ralf Corsepius 2006-11-19 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @206ad76a   11/15/06 03:48:56 Ralf Corsepius GCC_REL=4. Upgrade to gcc-core-4.2-20061114-rtems4.8-20061115.diff 4.104.114.84.95
(edit) @b2b99f57   11/15/06 03:48:33 Ralf Corsepius Remove (Obsolete) 4.104.114.84.95
(edit) @9336dd3   11/15/06 03:48:11 Ralf Corsepius 2006-11-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @5a7f1e1   11/15/06 03:43:43 Ralf Corsepius New. 4.104.114.84.95
(edit) @f4884049   11/14/06 17:50:23 Ralf Corsepius Add. 4.104.114.84.95
(edit) @9b039313   11/10/06 13:01:42 Ralf Corsepius 'BR: flex bison' for gcc >= 4.2.0 4.104.114.84.95
(edit) @615b6c9   11/09/06 14:28:50 Ralf Corsepius Introduce GCC_PKGVERS 4.104.114.84.95
(edit) @7f59079   11/09/06 14:27:07 Ralf Corsepius Upgrade to gcc-4.2.0-20061031. 4.104.114.84.95
(edit) @e315b421   11/09/06 11:19:05 Ralf Corsepius New (Merge BFIN patches). 4.104.114.84.95
(edit) @5cde0c4   10/30/06 03:53:00 Ralf Corsepius Update sparc dep to rtems4.8 4.104.114.84.95
(edit) @5fcda02   10/27/06 08:42:14 Ralf Corsepius Remove (unused) 4.104.114.84.95
(edit) @d94d76ad   10/27/06 08:32:40 Ralf Corsepius Remove (unused). 4.104.114.84.95
(edit) @f5b9b5b   10/27/06 08:32:05 Ralf Corsepius Remove (broken). 4.104.114.84.95
(edit) @2466600   10/27/06 08:31:28 Ralf Corsepius Remove (obsolete). 4.104.114.84.95
(edit) @31691791   10/27/06 08:29:40 Ralf Corsepius 2006-10-27 Ralf Corsépius <ralf.corsepius@…> * configure.ac, … 4.104.114.84.95
(edit) @136e234   10/27/06 08:27:56 Ralf Corsepius Remove rtems-4.7 4.104.114.84.95
(edit) @58b7d38f   10/27/06 08:26:24 Ralf Corsepius Remove (unused). 4.104.114.84.95
(edit) @4e0f6b7   10/27/06 08:24:43 Ralf Corsepius Bump GCC_RPMREL. 4.104.114.84.95
(edit) @969d68c9   10/27/06 08:23:17 Ralf Corsepius 2006-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @29aed1fd   10/27/06 08:21:17 Ralf Corsepius Update to newlib-1.14.0-rtems4.8-20061027.diff 4.104.114.84.95
(edit) @653db3f   10/27/06 08:18:04 Ralf Corsepius New. 4.104.114.84.95
(edit) @7693aec   10/26/06 18:01:34 Joel Sherrill 2006-10-26 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @fa8b476   10/22/06 04:59:33 Ralf Corsepius 2006-10-22 Ralf Corsépius <ralf.corsepius@…> * Makefile.am, … 4.104.114.84.95
(edit) @3b10616   10/22/06 04:59:15 Ralf Corsepius Add rtems-4.8 4.104.114.84.95
(edit) @575371e   10/21/06 12:34:16 Ralf Corsepius Reset RPMRELs = 1 4.104.114.84.95
(edit) @6598895   10/21/06 12:33:50 Ralf Corsepius Abandon binutils-2.16*. Apply binutils-2.17-rtems4.8-20061021.diff 4.104.114.84.95
(edit) @3096ba23   10/21/06 10:41:01 Ralf Corsepius New. 4.104.114.84.95
(edit) @c43121f   10/21/06 10:25:20 Ralf Corsepius Remove (Unsupported) 4.104.114.84.95
(edit) @378354d1   10/21/06 10:22:18 Ralf Corsepius Sync with rtems-4-7-branch 4.104.114.84.95
(edit) @c991316e   10/19/06 13:30:56 Ralf Corsepius Cleanup. 4.104.114.84.95
(edit) @ae4894a   10/19/06 08:03:50 Ralf Corsepius Remove. 4.104.114.84.95
(edit) @8de2d56   10/19/06 07:58:56 Ralf Corsepius Bump GCC_RPMREL 4.104.114.84.95
(edit) @7dce5bf5   10/19/06 07:57:29 Ralf Corsepius rtems-4.7-h8300-rtems4.7-gcc-4.1.1-5 4.104.114.84.95
(edit) @5b5e9031   10/19/06 07:56:52 Ralf Corsepius rtems-4.7-avr-rtems4.7-gcc-4.0.3-2 4.104.114.84.95
(edit) @a59a751b   10/16/06 14:55:56 Ralf Corsepius 2006-10-16 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @e337b49   10/16/06 11:14:07 Ralf Corsepius 2006-10-16 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @4bbd0b4   09/13/06 11:50:03 Ralf Corsepius New. 4.104.114.84.95
(edit) @9cb14887   09/08/06 20:33:52 Joel Sherrill New file. 4.104.114.84.95
(edit) @eb6276b   08/23/06 03:53:18 Ralf Corsepius 2006-08-23 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @99e02e7   08/23/06 03:52:40 Ralf Corsepius Add gcc-4.0.3 4.104.114.84.95
(edit) @7989747   08/23/06 03:45:43 Ralf Corsepius 2006-08-23 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @d867214   08/22/06 12:08:05 Chris Johns 2006-08-22 Chris Johns <chrisj@…> * … 4.104.114.84.95
(edit) @f7891617   08/22/06 11:57:36 Chris Johns Add the 4.0.3 patch. 4.104.114.84.95
(edit) @e5e88aa   08/22/06 11:57:03 Chris Johns The .exe for the versioned execuable for MinGW. 4.104.114.84.95
(edit) @a94075b   08/21/06 14:38:33 Joel Sherrill 2006-08-21 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @67eede5   08/16/06 07:54:10 Ralf Corsepius Pickup common.add from $(top_srcdir). 4.104.114.84.95
(edit) @6ed42ac   08/12/06 06:04:05 Ralf Corsepius binutils-2.17-rtems-20060812.diff 4.104.114.84.95
(edit) @070cf12   08/12/06 06:03:27 Ralf Corsepius Remove (Merged into binutils-2.17-rtems-20060812.diff). 4.104.114.84.95
(edit) @d218a83   08/12/06 06:02:29 Ralf Corsepius Update from binutils-2.17_branch. Merge bfin patch. 4.104.114.84.95
(edit) @056498a7   08/12/06 05:07:04 Ralf Corsepius Add bfin 4.104.114.84.95
(edit) @a2ced07   08/12/06 05:05:52 Ralf Corsepius Reset RPMRELS. 4.104.114.84.95
(edit) @6d7e836   08/11/06 21:37:40 Joel Sherrill 2006-08-11 Joel Sherrill <joel@…> * configure.ac, … 4.104.114.84.95
(edit) @1a39b67   08/10/06 07:04:25 Ralf Corsepius Bump RPMREL. 4.104.114.84.95
(edit) @3b97526c   08/09/06 23:06:58 Joel Sherrill 2006-08-09 Joel Sherrill <joel@…> * .cvsignore: Add INSTALL. 4.104.114.84.95
(edit) @6bdebc3a   08/03/06 04:29:22 Ralf Corsepius Bump version. 4.104.114.84.95
(edit) @c1a25af9   08/03/06 04:28:43 Ralf Corsepius Use hard-coded %release. 4.104.114.84.95
(edit) @5b151f87   08/03/06 03:57:47 Ralf Corsepius Use hard-coded %release. 4.104.114.84.95
(edit) @e85211e   08/03/06 02:50:36 Ralf Corsepius Remove (Obsolete) 4.104.114.84.95
(edit) @52053484   08/03/06 02:48:31 Ralf Corsepius Remove 4.104.114.84.95
(edit) @3219756b   08/03/06 02:47:53 Ralf Corsepius Update to using newlib-1.14.0-rtems-20060707.diff 4.104.114.84.95
(edit) @300dce7   08/02/06 03:39:00 Ralf Corsepius Bump version. 4.104.114.84.95
(edit) @d9e9a5a   08/02/06 03:37:34 Ralf Corsepius Use further shared spec-fragments. 4.104.114.84.95
(edit) @6c873da   08/02/06 03:36:22 Ralf Corsepius Split out target-autoconf.add 4.104.114.84.95
(edit) @a5b38ea   08/02/06 03:36:11 Ralf Corsepius Split out target-automake.add 4.104.114.84.95
(edit) @e5f924d   08/02/06 03:35:10 Ralf Corsepius New. 4.104.114.84.95
(edit) @6d05356   07/25/06 16:16:07 Ralf Corsepius Add objc 4.104.114.84.95
(edit) @8eb71ea4   07/25/06 16:11:49 Ralf Corsepius Remove sed -e /[@]tool_target[@]-newlib/d" 4.104.114.84.95
