Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/contrib/crossrpms
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @d06b28e   03/14/08 16:05:12 Ralf Corsepius Fix typo. 4.104.114.95
(edit) @211c22eb   03/14/08 15:34:59 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @dcd4562c   03/12/08 03:25:39 Ralf Corsepius Add binutils-patch. 4.104.114.95
(edit) @672465e   03/12/08 03:24:11 Ralf Corsepius New. 4.104.114.95
(edit) @44cc441   03/06/08 15:35:51 Ralf Corsepius Switch back to old GCC_RPMREL versioning scheme. 4.104.114.95
(edit) @cd7b673   03/06/08 15:34:40 Ralf Corsepius Bump version. 4.104.114.95
(edit) @6a90a4a   03/06/08 15:33:52 Ralf Corsepius Use binutils-2.18-rtems4.9-20080211.diff. 4.104.114.95
(edit) @d401b14   03/06/08 15:31:20 Ralf Corsepius New. 4.104.114.95
(edit) @fcac0c7   03/06/08 15:30:45 Ralf Corsepius Preps for gcc-4.3.0 final. 4.104.114.95
(edit) @5b5a0dd   03/06/08 05:44:25 Ralf Corsepius Sync with freebsd7.0. 4.104.114.95
(edit) @28c664d1   03/06/08 05:42:56 Ralf Corsepius Upgrade to binutils-2.18. Upgrade to gcc-4.2.3. Activate objc. 4.104.114.95
(edit) @f8ee67eb   03/06/08 05:40:03 Ralf Corsepius Require gmp and mpfr for gcc > 4.2.0 fortran. 4.104.114.95
(edit) @0764085   03/05/08 05:58:48 Ralf Corsepius Sync with the freebsds. 4.104.114.95
(edit) @dff01852   03/05/08 03:03:47 Ralf Corsepius Abandon freebsd6.1. 4.104.114.95
(edit) @5aaa497   03/05/08 03:02:54 Ralf Corsepius Abandon. 4.104.114.95
(edit) @6b81c78   03/05/08 03:01:37 Ralf Corsepius Add freebsd6.3, freebsd7.0 4.104.114.95
(edit) @905cbd1   03/05/08 02:47:30 Ralf Corsepius New. 4.104.114.95
(edit) @610c400   03/05/08 02:38:07 Ralf Corsepius Abandon freebsd6.0 4.104.114.95
(edit) @2301a644   03/05/08 02:37:22 Ralf Corsepius Abandon. 4.104.114.95
(edit) @01993e1   03/05/08 02:35:52 Ralf Corsepius Abandon freebsd5.2 4.104.114.95
(edit) @f0c4cf75   03/03/08 07:40:26 Ralf Corsepius Add *_ARG to getopt.c. 4.104.114.95
(edit) @fb974c6   03/03/08 06:36:28 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @d0abb93   03/03/08 06:35:42 Ralf Corsepius Bump GCC_RPMREL = 10.20080301.2%{?dist}. 4.104.114.95
(edit) @84126da9   03/03/08 06:35:07 Ralf Corsepius Bump GCC_RPMREL = 10.1%{?dist}. 4.104.114.95
(edit) @834a670c   03/03/08 06:34:37 Ralf Corsepius Bump GCC_RPMREL = 7%{?dist}. 4.104.114.95
(edit) @94299fd3   03/03/08 06:33:49 Ralf Corsepius Update to newlib-1.16.0-rtems4.9-20080302.diff. 4.104.114.95
(edit) @5df181db   03/03/08 06:14:59 Ralf Corsepius Add getopt*_r. 4.104.114.95
(edit) @e2fe8948   03/02/08 06:52:59 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @3aa2d40   03/02/08 06:51:36 Ralf Corsepius Update to gcc-4.3.0-RC-20080301. 4.104.114.95
(edit) @e122f592   02/27/08 15:31:30 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @26c2bea   02/27/08 15:28:21 Ralf Corsepius Build bundled mpfr for suse10.2 and suse10.3. 4.104.114.95
(edit) @7cfcdc1   02/27/08 14:17:39 Ralf Corsepius Bump GCC_RPMREL to 10.20080222.1 4.104.114.95
(edit) @caeacf7b   02/27/08 14:16:53 Ralf Corsepius Upgrade to gcc-4.3.0-RC-20080222. 4.104.114.95
(edit) @8e6bf2b   02/27/08 14:04:47 Ralf Corsepius Upgrade to gcc-4.3.0-RC-20080222. 4.104.114.95
(edit) @8de5e41   02/27/08 11:59:11 Ralf Corsepius Upgrade to gcc-4.3.0-RC-20080222. 4.104.114.95
(edit) @2561ee9   02/27/08 11:47:30 Ralf Corsepius Upgrade to gcc-4.3.0-RC-20080222. 4.104.114.95
(edit) @069046a7   02/27/08 11:21:58 Ralf Corsepius Upgrade to gcc-4.3.0-RC-20080222. 4.104.114.95
(edit) @4aa20ea8   02/27/08 10:56:11 Ralf Corsepius Upgrade to gcc-4.3.0-RC-20080222. 4.104.114.95
(edit) @96e2c18   02/27/08 09:57:55 Ralf Corsepius Upgrade to gcc-4.3.0-RC-20080222. 4.104.114.95
(edit) @1a2b747   02/27/08 09:45:07 Ralf Corsepius Upgrade to gcc-4.3.0-RC-20080222. 4.104.114.95
(edit) @3c7a743   02/27/08 09:09:49 Ralf Corsepius Upgrade to gcc-4.3.0-RC-20080222. 4.104.114.95
(edit) @ce4d33f   02/27/08 08:49:33 Ralf Corsepius Require autoconf-2.61. Bump version. 4.104.114.95
(edit) @f1b2da23   02/27/08 08:44:13 Ralf Corsepius Add mpfr support. 4.104.114.95
(edit) @cf04e953   02/25/08 16:05:02 Ralf Corsepius Use make DESTDIR= ... install. 4.104.114.95
(edit) @76b0283   02/11/08 17:49:27 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @be2dfb8   02/11/08 17:47:36 Ralf Corsepius Use binutils-2.18-rtems4.9-20080211.diff 4.104.114.95
(edit) @d2d17545   02/11/08 17:47:00 Ralf Corsepius Bump BINUTILS_RPMREL. 4.104.114.95
(edit) @acbb590   02/11/08 17:43:40 Ralf Corsepius Add avr hacks for gcc-4.3 4.104.114.95
(edit) @92150edc   02/06/08 04:33:04 Ralf Corsepius Bump GCC_RPMREL. 4.104.114.95
(edit) @4419987a   02/06/08 04:32:44 Ralf Corsepius gcc-core-4.2.3-rtems4.9-20080205.diff 4.104.114.95
(edit) @f26747e   02/06/08 04:28:40 Ralf Corsepius Add target-libiberty to noconfigdirs. 4.104.114.95
(edit) @b8c28e8   02/03/08 08:21:22 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @0d2a267   02/02/08 04:16:30 Ralf Corsepius Bump GCC_RPMREL. 4.104.114.95
(edit) @7728b8c   02/02/08 04:09:56 Ralf Corsepius newlib-1.16.0-rtems4.9-20080131.diff 4.104.114.95
(edit) @15e5148   02/02/08 04:06:05 Ralf Corsepius Preps for gcc-4.2.3. 4.104.114.95
(edit) @964d1eb   02/02/08 03:31:59 Ralf Corsepius New. 4.104.114.95
(edit) @c539ced1   01/22/08 08:56:18 Ralf Corsepius Preps for automake-1.10.1 4.104.114.95
(edit) @980102a   01/22/08 08:56:01 Ralf Corsepius automake-1.10.1 4.104.114.95
(edit) @5e57f833   01/14/08 09:29:23 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @30b8e468   01/14/08 09:28:24 Ralf Corsepius Bump GCC_RPMREL. 4.104.114.95
(edit) @c23804dd   01/14/08 09:27:45 Ralf Corsepius gcc-core-4.2.2-rtems4.9-20080114.diff.Remove gcc-3.4.6. 4.104.114.95
(edit) @5ec21f41   01/14/08 09:27:15 Ralf Corsepius gcc-core-4.2.2-rtems4.9-20080114.diff. 4.104.114.95
(edit) @b4448d1   01/14/08 09:05:24 Ralf Corsepius New. Add h8sw to h8300-rtems-gcc. 4.104.114.95
(edit) @07c40af   12/20/07 16:14:58 Ralf Corsepius New. 4.104.114.95
(edit) @ab56160   12/20/07 16:13:08 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @d8536e8   12/20/07 16:12:09 Ralf Corsepius Add %{?_smp_mflags}. 4.104.114.95
(edit) @c55ed1d   12/20/07 16:11:34 Ralf Corsepius Prepare upgrade to newlib-1.16.0. 4.104.114.95
(edit) @e4c0acd5   12/17/07 06:42:56 Ralf Corsepius Update. 4.104.114.95
(edit) @4156c83   12/17/07 06:39:58 Ralf Corsepius Remove erronious checkin 4.104.114.95
(edit) @dcb8530   12/17/07 06:11:48 Ralf Corsepius Add _smp_mflags. 4.104.114.95
(edit) @bd10488   12/17/07 06:11:22 Ralf Corsepius BR: texinfo for binutils > 2.18 4.104.114.95
(edit) @ba72882   12/17/07 00:39:10 Chris Johns 2007-12-17 Chris Johns <chrisj@…> * rtems4.8/.cvsignore, … 4.104.114.95
(edit) @fbce31e   12/16/07 08:25:36 Ralf Corsepius Update. 4.104.114.95
(edit) @b72cd6c   12/16/07 08:23:46 Ralf Corsepius No gdb for the tic4x. 4.104.114.95
(edit) @d6c28599   12/16/07 08:20:47 Ralf Corsepius Abandon gdb-6.7. 4.104.114.95
(edit) @2451d88   12/16/07 08:20:27 Ralf Corsepius Abandon gdb-6.6. 4.104.114.95
(edit) @a16841e   12/16/07 08:20:05 Ralf Corsepius Abandon gdb-6.5. 4.104.114.95
(edit) @440b8e5   12/16/07 08:18:49 Ralf Corsepius gdb-6.7.1-rtems4.9-20071216.diff 4.104.114.95
(edit) @69bfa80   12/16/07 08:14:07 Ralf Corsepius Remove. 4.104.114.95
(edit) @5d4ad05d   12/16/07 08:13:19 Ralf Corsepius Add ppc sim stuff. 4.104.114.95
(edit) @fe47a71   12/16/07 08:06:08 Ralf Corsepius Add _smp_mflags. 4.104.114.95
(edit) @ff22573e   12/16/07 08:04:54 Ralf Corsepius Remove. 4.104.114.95
(edit) @29925d99   11/28/07 04:25:28 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @70b2aca   11/28/07 04:24:36 Ralf Corsepius Bump GCC_RPMREL 4.104.114.95
(edit) @e5a29d6c   11/28/07 04:24:17 Ralf Corsepius Upgrade to gcc-core-4.2.2-rtems4.9-20071127.diff 4.104.114.95
(edit) @7d5855c   11/28/07 04:18:34 Ralf Corsepius Remove GTHREAD_MUTEX_INIT (Patch from Daniel Hellstrom … 4.104.114.95
(edit) @7ee5947b   11/14/07 13:40:49 Ralf Corsepius Update. 4.104.114.95
(edit) @568298a   11/14/07 13:39:53 Ralf Corsepius Remove. 4.104.114.95
(edit) @fe1632a   11/14/07 13:38:14 Ralf Corsepius Add makeinfo hacks. 4.104.114.95
(edit) @c89a4e4e   11/14/07 03:15:31 Ralf Corsepius gcc-core-4.2.2-rtems4.9-20071114.diff. 4.104.114.95
(edit) @8b2620e1   11/14/07 03:12:16 Ralf Corsepius Reflect having removed *diffs 4.104.114.95
(edit) @513a419a   11/14/07 03:08:24 Ralf Corsepius Remove. 4.104.114.95
(edit) @8231b5e   11/14/07 03:06:08 Ralf Corsepius Add m68k FreeScale? mv4 multilibs. 4.104.114.95
(edit) @8fea157   11/13/07 17:00:35 Ralf Corsepius Abandon gcc-4.0.3 4.104.114.95
(edit) @1e69498c   11/13/07 16:50:54 Ralf Corsepius Remove. 4.104.114.95
(edit) @dc00c8d   11/13/07 15:09:44 Ralf Corsepius backup. 4.104.114.95
(edit) @3ef68f9   11/13/07 08:38:30 Ralf Corsepius Remove *.origs 4.104.114.95
(edit) @4da971a   11/13/07 08:34:44 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @6790aa4d   11/13/07 08:34:25 Ralf Corsepius GCC_RPMREL = 3. 4.104.114.95
(edit) @01b9201   11/13/07 08:34:10 Ralf Corsepius Add gcc-core-3.4.6-rtems4.9-20071111.diff. 4.104.114.95
