@a34a266a
08/27/09 10:44:18 |
Ralf Corsepius |
New.
4.104.115
@04da1c36
08/27/09 10:05:56 |
Ralf Corsepius |
Modernize.
4.104.115
@dff3caf
08/27/09 10:05:27 |
Ralf Corsepius |
New.
4.104.115
@194a1b9
08/27/09 08:20:56 |
Ralf Corsepius |
New.
4.104.115
@d7bc7aa
08/27/09 08:20:36 |
Ralf Corsepius |
Split out libs.am
4.104.115
@79e55c5
08/27/09 08:14:23 |
Ralf Corsepius |
Modernize.
4.104.115
@1ab6977
08/27/09 06:39:53 |
Ralf Corsepius |
Update.
4.104.115
@4668c7fe
08/27/09 06:33:11 |
Ralf Corsepius |
Regenerate.
4.104.115
@1c360794
08/27/09 06:32:49 |
Ralf Corsepius |
Various updates.
Hard-code release instead of using @VERSION@.
4.104.115
@8514d37
08/27/09 06:31:31 |
Ralf Corsepius |
HACK: filter gcclibdir/* iff _gcclibdir is defined
4.104.115
@dfe5b24b
08/27/09 05:21:30 |
Ralf Corsepius |
More libiberty tweaks
4.104.115
@27e77c93
08/27/09 05:20:57 |
Ralf Corsepius |
exclude finclude for gcc < 4.2.0
4.104.115
@5ec1009
08/27/09 03:40:26 |
Ralf Corsepius |
Install to --libdir=%{_prefix}/lib instead of %{_libdir}
4.104.115
@3f8272d
08/27/09 03:39:14 |
Ralf Corsepius |
Remove work-around to obsolete gfortran bug.
4.104.115
@cd0393ff
08/27/09 02:59:15 |
Ralf Corsepius |
Remove obsolete conditional.
4.104.115
@fdff67bb
08/27/09 02:52:11 |
Ralf Corsepius |
4.104.115
@1bd552a
08/27/09 02:50:11 |
Ralf Corsepius |
4.104.115
@9af225c
08/27/09 02:22:20 |
Ralf Corsepius |
s,%{gcclib},%{_gcclibdir}/gcc/,
4.104.115
@150fd4ca
08/27/09 02:18:11 |
Ralf Corsepius |
Remove outdated conditionals.
4.104.115
@42663eec
08/26/09 17:16:23 |
Ralf Corsepius |
Eliminate %{gccexec}.
4.104.115
@88687a62
08/26/09 17:14:38 |
Ralf Corsepius |
Abandon gcc < 3.4
4.104.115
@bbdde8b
08/26/09 17:03:54 |
Ralf Corsepius |
Move finclude into *-gfortran.
4.104.115
@3b3b3b9
08/26/09 16:58:08 |
Ralf Corsepius |
Use fortran instead of f95.
4.104.115
@4de09b5
08/26/09 16:57:32 |
Ralf Corsepius |
Abandon build_g77.
4.104.115
@b8cb165
08/26/09 16:56:59 |
Ralf Corsepius |
Use build_fortran instead of build_f95.
4.104.115
@9dcd8f7
08/26/09 16:49:08 |
Ralf Corsepius |
Abandon g77.
4.104.115
@0b801216
08/26/09 16:47:48 |
Ralf Corsepius |
Use --language=fortran for fortran.
Abandon g77.
4.104.115
@246717f
08/26/09 16:44:54 |
Ralf Corsepius |
Replace build_f95 with build_fortran.
4.104.115
@439f9f4
08/26/09 16:43:05 |
Ralf Corsepius |
Remove.
4.104.115
@2bbfbf1
08/26/09 11:02:45 |
Ralf Corsepius |
Add mpfr_provided for openSUSE 11.0 + 11.1
4.104.115
@5426f17e
08/26/09 10:57:06 |
Ralf Corsepius |
Update readline.
4.104.115
@2c3e6c5
08/20/09 13:40:26 |
Ralf Corsepius |
Regenerate.
4.104.115
@0ebf6f22
08/20/09 13:40:00 |
Ralf Corsepius |
Remove gcc-4.4.0.
gcc-core-4.4.1--rtems4.10-20090820.diff.
4.104.115
@b610c1b
08/20/09 13:39:24 |
Ralf Corsepius |
Bump GCC_RPMREL.
4.104.115
@5e770e65
08/20/09 13:38:50 |
Ralf Corsepius |
Remove _exit from avr's libgcc.
4.104.115
@810f43e
07/29/09 04:31:59 |
Ralf Corsepius |
Remove.
4.104.115
@e7667a8
07/27/09 11:55:52 |
Ralf Corsepius |
Upgrade to autoconf-2.64.
4.104.115
@9ff8bda
07/27/09 11:54:58 |
Ralf Corsepius |
Regenerate.
4.104.115
@2bdf507
07/27/09 11:52:59 |
Ralf Corsepius |
newlib-1.17.0-rtems4.10-20090727.diff
4.104.115
@28dc5fb
07/27/09 11:52:15 |
Ralf Corsepius |
Bump GCC_RPMREL.
4.104.115
@eec869d3
07/27/09 11:51:27 |
Ralf Corsepius |
New.
4.104.115
@862e1ec
07/26/09 05:00:19 |
Ralf Corsepius |
Regenerate.
4.104.115
@bff8cf4b
07/26/09 04:59:59 |
Ralf Corsepius |
Bump AUTOCONF_RPMREL.
4.104.115
@051e1b2
07/26/09 04:56:06 |
Ralf Corsepius |
Bump AUTOMAKE_RPMREL.
4.104.115
@bcbfc091
07/26/09 04:55:43 |
Ralf Corsepius |
Require help2man for automake < 1.11
4.104.115
@7611ed8e
07/23/09 15:25:09 |
Ralf Corsepius |
Remove.
4.104.115
@e1ffb64
07/22/09 10:18:46 |
Ralf Corsepius |
Regenerate.
4.104.115
@1f70458
07/22/09 10:18:24 |
Ralf Corsepius |
gcc-core-4.4.1-rtems4.10-20090722.diff
4.104.115
@ab16a063
07/22/09 10:12:52 |
Ralf Corsepius |
New.
4.104.115
@df979f27
07/22/09 10:11:59 |
Ralf Corsepius |
Remove.
4.104.115
@e1f0b2d
07/22/09 10:07:14 |
Ralf Corsepius |
GCC-4.4.1.
4.104.115
@115971c
07/21/09 06:52:16 |
Ralf Corsepius |
Update to binutils-2.19.51-20090721.
4.104.115
@ad70382
07/21/09 03:21:10 |
Ralf Corsepius |
Remove.
4.104.115
@1e60ba99
07/18/09 04:15:19 |
Ralf Corsepius |
Regenerate.
4.104.115
@428a4c0
07/18/09 04:07:04 |
Ralf Corsepius |
Regenerate.
4.104.115
@6218ba5b
07/18/09 04:06:26 |
Ralf Corsepius |
GCC_PKGVERS = $(GCC_VERS)-RC-20090715
4.104.115
@6d3f0321
07/18/09 04:02:03 |
Ralf Corsepius |
Regenerate.
4.104.115
@0b7a942
07/18/09 03:58:53 |
Ralf Corsepius |
Bump GDB_RPMREL.
4.104.115
@5e06bf7
07/18/09 03:57:24 |
Ralf Corsepius |
Bump GCC_RPMREL.
4.104.115
@d3baa0d6
07/18/09 03:56:34 |
Ralf Corsepius |
Bump BINUTILS_RPMREL.
4.104.115
@38df5015
07/18/09 03:54:42 |
Ralf Corsepius |
Set _host_rpmprefix %{_host}- for canadian X compiles.
4.104.115
@3f81399
07/17/09 14:34:09 |
Ralf Corsepius |
Update.
4.104.115
@9c4db573
07/17/09 14:34:08 |
Ralf Corsepius |
Update.
4.104.115
@4016765
07/17/09 13:54:39 |
Ralf Corsepius |
New.
4.104.115
@20857e12
07/17/09 13:40:05 |
Ralf Corsepius |
Update.
4.104.115
@5b42429f
07/17/09 13:20:54 |
Ralf Corsepius |
Update.
4.104.115
@c6c0fbf
07/17/09 12:08:02 |
Ralf Corsepius |
Update.
4.104.115
@956c59bb
07/17/09 10:17:13 |
Ralf Corsepius |
Update.
4.104.115
@cbfa82a9
07/17/09 09:49:06 |
Ralf Corsepius |
New.
4.104.115
@b817534f
07/17/09 09:48:22 |
Ralf Corsepius |
Remove.
4.104.115
@a5a7aa4
07/17/09 09:47:54 |
Ralf Corsepius |
Abandon *-w32api.spec
4.104.115
@950b83b
07/17/09 09:38:07 |
Ralf Corsepius |
New.
4.104.115
@e871b60
07/17/09 09:37:21 |
Ralf Corsepius |
Abandon *-libs.
4.104.115
@aa6b8de
07/17/09 09:36:51 |
Ralf Corsepius |
Remove.
4.104.115
@ad0603d
07/17/09 09:21:16 |
Ralf Corsepius |
Remove.
4.104.115
@d5273209
07/17/09 09:20:47 |
Ralf Corsepius |
Remove binutils, gcc.
4.104.115
@dbe0290e
07/16/09 23:54:35 |
Ralf Corsepius |
Regenerate.
4.104.115
@ea4a5b5
07/16/09 23:54:16 |
Ralf Corsepius |
Fix typo.
4.104.115
@c5575c9
07/16/09 23:44:37 |
Ralf Corsepius |
Regenerate.
4.104.115
@eb2d0ff
07/16/09 23:41:07 |
Ralf Corsepius |
Abandon gcc-4.3.3. Add gcc-4.4.1.
4.104.115
@56a5a83
07/16/09 23:36:58 |
Ralf Corsepius |
Bump GCC_VERS, GCC_RPMREL.
4.104.115
@ae596673
07/15/09 07:56:53 |
Ralf Corsepius |
Housekeeping.
4.104.115
@2010a0ef
07/15/09 07:53:26 |
Ralf Corsepius |
Regenerate.
4.104.115
@5e9232a5
07/15/09 07:53:01 |
Ralf Corsepius |
Abandon RH8.
4.104.115
@f1fb836
07/15/09 07:51:32 |
Ralf Corsepius |
Abandon Fedora 9.
4.104.115
@ea4db3a2
07/15/09 07:50:19 |
Ralf Corsepius |
newlib-1.17.0-rtems4.10-20090715.diff.
4.104.115
@a5f1bb7
07/15/09 07:49:19 |
Ralf Corsepius |
Bump GCC_RPMREL.
4.104.115
@9972e99
07/15/09 07:46:10 |
Ralf Corsepius |
New.
4.104.115
@7ff1c29
07/14/09 06:54:20 |
Ralf Corsepius |
Increment BINUTILS_RPMREL for FC11-rebuild.
4.104.115
@edf497bc
07/14/09 06:21:13 |
Ralf Corsepius |
Regenerate.
4.104.115
@7a422bb2
07/14/09 06:20:39 |
Ralf Corsepius |
4.104.115
@1e6f181
07/13/09 14:28:17 |
Ralf Corsepius |
Remove (Unused).
4.104.115
@f76ddaa
07/13/09 14:27:01 |
Ralf Corsepius |
Regenerate.
4.104.115
@700acb98
07/13/09 14:26:49 |
Ralf Corsepius |
Move %{?dist} into autoconf.am
4.104.115
@b08d3f3c
07/13/09 14:23:48 |
Ralf Corsepius |
Remove Obsolete/Provides?.
4.104.115
@186049a
07/13/09 14:21:39 |
Ralf Corsepius |
Regenerate.
4.104.115
@afdc9d7
07/13/09 14:21:05 |
Ralf Corsepius |
4.104.115
@ae1862c
07/13/09 14:20:36 |
Ralf Corsepius |
Add autoconf-sources.add.
4.104.115
@350178d0
07/13/09 14:19:43 |
Ralf Corsepius |
Acknowledge autoconf-sources.add
4.104.115
@e2ae590
07/11/09 07:33:43 |
Ralf Corsepius |
Housekeeping.
4.104.115
