Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/contrib/crossrpms
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @611aa7dd   06/18/07 04:37:39 Ralf Corsepius Cleanup. 20070613 patches. 4.104.114.84.95
(edit) @169dbb55   06/18/07 04:36:33 Ralf Corsepius GCC_RPMREL = 14 4.104.114.84.95
(edit) @0d04790   06/18/07 04:35:41 Ralf Corsepius Cleanup. 4.104.114.84.95
(edit) @8cf555e   06/13/07 16:38:22 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @a43f670   06/13/07 15:42:41 Ralf Corsepius Add *20070613.diff 4.104.114.84.95
(edit) @fc463855   06/13/07 15:42:22 Ralf Corsepius GCC_RPMREL = 13 4.104.114.84.95
(edit) @c0064d39   06/13/07 15:40:32 Ralf Corsepius Add sparc fpu bug fix. 4.104.114.84.95
(edit) @967c8974   06/04/07 09:12:43 Ralf Corsepius New. 4.104.114.84.95
(edit) @4fec4975   06/03/07 15:26:45 Ralf Corsepius GCC_RPMREL = 17. 4.104.114.84.95
(edit) @0ae15e60   06/03/07 06:03:58 Ralf Corsepius GCC_RPMREL = 12 4.104.114.84.95
(edit) @87e21be   06/03/07 06:01:55 Ralf Corsepius New. 4.104.114.84.95
(edit) @ab86b62   06/02/07 07:54:37 Ralf Corsepius New. 4.104.114.84.95
(edit) @e2a00ab   06/02/07 07:54:07 Ralf Corsepius GCC_RPMREL = 12. 4.104.114.84.95
(edit) @ecf3c8c   06/02/07 05:57:31 Ralf Corsepius New. 4.104.114.84.95
(edit) @88d97467   06/02/07 05:57:05 Ralf Corsepius GCC_RPMREL = 12. 4.104.114.84.95
(edit) @9bc3ef5   06/02/07 04:52:01 Ralf Corsepius New. 4.104.114.84.95
(edit) @7b8fbed   06/02/07 04:51:44 Ralf Corsepius GCC_RPMREL = 11. 4.104.114.84.95
(edit) @498f319   06/02/07 04:29:21 Ralf Corsepius New. 4.104.114.84.95
(edit) @b34fda5   06/02/07 03:23:15 Ralf Corsepius New. 4.104.114.84.95
(edit) @6a4e3360   06/02/07 03:19:37 Ralf Corsepius GCC_RPMREL = 12. 4.104.114.84.95
(edit) @0925496   06/01/07 08:46:51 Ralf Corsepius GCC_RPMREL = 11. 4.104.114.84.95
(edit) @f7d5d6e3   05/25/07 13:42:51 Ralf Corsepius Backup. 4.104.114.84.95
(edit) @24848b6   05/25/07 13:42:27 Ralf Corsepius New. 4.104.114.84.95
(edit) @d183ac2a   05/25/07 08:39:01 Ralf Corsepius Add gprof.info handling. 4.104.114.84.95
(edit) @36c8e140   05/24/07 02:58:23 Ralf Corsepius Remove %{_libdir}/libiberty.a 4.104.114.84.95
(edit) @3fafc63   05/21/07 10:55:01 Ralf Corsepius Add --libexecdir. 4.104.114.84.95
(edit) @412058fa   05/16/07 02:12:27 Ralf Corsepius Remove (Obsolete). 4.104.114.84.95
(edit) @4c50a600   05/15/07 06:24:01 Ralf Corsepius New (Re-base patch against gcc-4.2.0 final) 4.104.114.84.95
(edit) @f324b08   05/14/07 15:36:30 Ralf Corsepius New (merge-in gcc-4.2.0 final patches). 4.104.114.84.95
(edit) @b40f354   05/11/07 08:56:46 Ralf Corsepius Comment out cpukit. 4.104.114.84.95
(edit) @206cc90f   05/11/07 03:04:06 Ralf Corsepius Add PATH if prefix != /usr 4.104.114.84.95
(edit) @6bdfa7a   05/10/07 14:31:51 Ralf Corsepius New. 4.104.114.84.95
(edit) @60baadf   05/10/07 14:30:57 Ralf Corsepius Add cpukit. 4.104.114.84.95
(edit) @2620f00   05/10/07 14:25:23 Ralf Corsepius New. 4.104.114.84.95
(edit) @1fa2436   05/03/07 02:16:26 Ralf Corsepius New. 4.104.114.84.95
(edit) @22a8f05   05/01/07 04:46:31 Ralf Corsepius Rebase against gcc-core-4.2.0-20070430 (gcc-4.2.0 rc2) 4.104.114.84.95
(edit) @f8518873   04/14/07 03:46:10 Ralf Corsepius Update to newlib-1.15.0-rtems4.8-20070413.diff 4.104.114.84.95
(edit) @0df1fb63   04/13/07 08:52:52 Ralf Corsepius Add CLOCK_MONOTONIC. Sync readlink, usleep with SUSv3. 4.104.114.84.95
(edit) @382c020   04/09/07 09:55:02 Ralf Corsepius Add mips .sdata handling from GCC-4.2 4.104.114.84.95
(edit) @0e944ec3   04/09/07 09:54:02 Ralf Corsepius Bump GCC_RPMREL. 4.104.114.84.95
(edit) @bf740cf   04/09/07 09:53:46 Ralf Corsepius Upgrade to gcc-core-4.1.2-rtems4.8-20070405.diff 4.104.114.84.95
(edit) @bf09c649   03/28/07 03:42:07 Ralf Corsepius Update. 4.104.114.84.95
(edit) @ad0a865   03/16/07 13:39:25 Ralf Corsepius Upgrade to gcc-4.1.2. Remove rtprio.h from newlib. 4.104.114.84.95
(edit) @20bc17f   03/16/07 04:41:34 Ralf Corsepius Upgrade to newlib-1.15.0-rtems4.8-20070316.diff 4.104.114.84.95
(edit) @fb3201c2   03/16/07 04:39:44 Ralf Corsepius New (Eliminate rtprio.h) 4.104.114.84.95
(edit) @41c3ed9   03/06/07 12:53:35 Ralf Corsepius New (Incorporate Joels patch to increase mem-sizes for erc32 sim.) 4.104.114.84.95
(edit) @58255f77   03/06/07 12:15:22 Ralf Corsepius Add exec_prefix. 4.104.114.84.95
(edit) @1f88fa0   03/01/07 06:20:02 Ralf Corsepius Add support for exec_prefix. 4.104.114.84.95
(edit) @0a6c808   02/28/07 07:30:11 Ralf Corsepius Remove (obsolete). 4.104.114.84.95
(edit) @661d5c8   02/28/07 07:29:32 Ralf Corsepius New. 4.104.114.84.95
(edit) @f05a343e   02/28/07 07:27:53 Ralf Corsepius Upgrade to gcc-4.2-20070221 4.104.114.84.95
(edit) @34a0e1d   02/28/07 03:27:30 Ralf Corsepius Remove unused code. 4.104.114.84.95
(edit) @41bd972   02/27/07 16:11:37 Ralf Corsepius Rebase binutils/gcc 4.104.114.84.95
(edit) @258d7d5a   02/27/07 14:34:01 Ralf Corsepius Add BINTUTILS_PKGVERS. 4.104.114.84.95
(edit) @916bb726   02/27/07 14:33:15 Ralf Corsepius Remove _use_internal_dependency_generator 0. Remove … 4.104.114.84.95
(edit) @cd5bd9b   02/27/07 07:38:04 Ralf Corsepius Use MKSPEC0. 4.104.114.84.95
(edit) @5da8174   02/27/07 07:33:19 Ralf Corsepius Add BINUTILS_PKGVERS. Add GCC_PKGVERS. 4.104.114.84.95
(edit) @a73220f   02/27/07 07:32:19 Ralf Corsepius Upgrade to cygwin-1.5.24-2. Upgrade to w32api-3.8-1. 4.104.114.84.95
(edit) @37304358   02/27/07 07:30:41 Ralf Corsepius Remove _use_internal_dependency_generator 0. Remove … 4.104.114.84.95
(edit) @2e03ec5a   02/27/07 04:55:39 Ralf Corsepius Upgrade to gcc-4.1.2. 4.104.114.84.95
(edit) @d967064   02/27/07 04:02:00 Ralf Corsepius Add BINUTILS_PKGVERS. Add GCC_PKGVERS. gcc-4.1.2. 4.104.114.84.95
(edit) @44b241c   02/27/07 04:00:37 Ralf Corsepius mf-runtime.h is still broken in gcc-4.1.2 4.104.114.84.95
(edit) @161e2739   02/27/07 03:59:07 Ralf Corsepius Add freebsd6.2 4.104.114.84.95
(edit) @2aa2177   02/27/07 03:57:55 Ralf Corsepius New. 4.104.114.84.95
(edit) @754b79a   02/26/07 16:50:20 Ralf Corsepius Add BINUTILS_PKGVERS. Add GCC_PKGVERS. 4.104.114.84.95
(edit) @856c8e48   02/26/07 16:47:54 Ralf Corsepius Add BINUTILS_PKGVERS. Add GCC_PKGVERS. Try gcc-4.1.2. 4.104.114.84.95
(edit) @67c1bb5e   02/26/07 15:54:49 Ralf Corsepius Add MKSPEC0. 4.104.114.84.95
(edit) @a8149e7   02/26/07 09:55:59 Ralf Corsepius Use binutils_pkgvers instead of binutils_version in Source0. 4.104.114.84.95
(edit) @8d182ca   02/26/07 09:35:04 Ralf Corsepius Add BINUTILS_PKGVERS. 4.104.114.84.95
(edit) @397a1bec   02/26/07 09:33:39 Ralf Corsepius Add GDB_PKGVERS. 4.104.114.84.95
(edit) @f3a77dd   02/26/07 09:29:52 Ralf Corsepius Add BINUTILS_PKGVERS. 4.104.114.84.95
(edit) @f7712468   02/26/07 09:26:59 Ralf Corsepius Add BINUTILS_PKGVERS. 4.104.114.84.95
(edit) @99a06927   02/26/07 09:23:23 Ralf Corsepius Add GCC_PKGVERS. 4.104.114.84.95
(edit) @f189de8   02/26/07 09:05:22 Ralf Corsepius Add GDB_PKGVERS. 4.104.114.84.95
(edit) @33b4b91   02/26/07 09:02:07 Ralf Corsepius Add BINUTILS_PKGVERS. 4.104.114.84.95
(edit) @b581f06   02/23/07 07:24:55 Ralf Corsepius Set BINUTILS_RPMREL = 1 4.104.114.84.95
(edit) @3028ab8   02/23/07 07:24:21 Ralf Corsepius Use http://downloads.sourceforge.net/mingw/ as base for Source0. 4.104.114.84.95
(edit) @15fda0f7   02/23/07 06:19:23 Ralf Corsepius Set W32API_RPMREL = 1 4.104.114.84.95
(edit) @62a7c6b   02/23/07 06:18:53 Ralf Corsepius Set MINGW32_RPMREL = 1 4.104.114.84.95
(edit) @6ede2df   02/23/07 06:18:06 Ralf Corsepius Add GCC_PKGVERS (PR 1220) 4.104.114.84.95
(edit) @4442d9b4   02/23/07 06:17:01 Ralf Corsepius Use http://downloads.sourceforge.net/mingw/ as base for Source0. 4.104.114.84.95
(edit) @7a345828   02/23/07 06:03:06 Ralf Corsepius Upgrade to mingw-runtime-3.11, w32api-3.8. Disable building infos for … 4.104.114.84.95
(edit) @470740b9   02/22/07 19:58:46 Ralf Corsepius New. 4.104.114.84.95
(edit) @3473dc5e   02/20/07 04:37:32 Ralf Corsepius Add GDB_OPTS 4.104.114.84.95
(edit) @c7cf374d   02/19/07 06:02:33 Ralf Corsepius Increment BINUTILS_RPMREL 4.104.114.84.95
(edit) @df22adf   02/19/07 06:01:11 Ralf Corsepius Cosmetics 4.104.114.84.95
(edit) @349e2de   02/18/07 08:03:26 Ralf Corsepius gdb-6.6-rtems4.8-20070218.diff 4.104.114.84.95
(edit) @4778b0a7   02/18/07 07:59:02 Ralf Corsepius New. Fix breakage on rh7. 4.104.114.84.95
(edit) @1ee16e8   02/17/07 11:30:40 Ralf Corsepius BuildRequire?: expat-devel for gdb >= 6.6 4.104.114.84.95
(edit) @08c06d89   02/17/07 09:50:25 Ralf Corsepius Preps for gdb-6.6 4.104.114.84.95
(edit) @bb31ed7   02/17/07 09:40:11 Ralf Corsepius New. 4.104.114.84.95
(edit) @84b62c77   02/17/07 07:12:15 Ralf Corsepius Fix URL. 4.104.114.84.95
(edit) @71f6a66   02/17/07 07:03:17 Ralf Corsepius Add || : to install-info. 4.104.114.84.95
(edit) @1293de07   02/17/07 06:48:04 Ralf Corsepius Add || : to install-info. 4.104.114.84.95
(edit) @0112d07   02/17/07 06:46:00 Ralf Corsepius Fix typo. 4.104.114.84.95
(edit) @1d17363   02/16/07 08:39:49 Ralf Corsepius Add HOST_SUBDIRS 4.104.114.84.95
(edit) @7ded655d   02/16/07 08:38:57 Ralf Corsepius New. 4.104.114.84.95
(edit) @61f2bb5   02/16/07 08:36:50 Ralf Corsepius Preps for gcc-4.1.2 4.104.114.84.95
(edit) @64ccc152   02/16/07 08:31:33 Ralf Corsepius Ignore errors on install-info. 4.104.114.84.95
(edit) @072cbd3   02/14/07 17:21:43 Ralf Corsepius AUTOCONF_RPMREL = 5 4.104.114.84.95
