Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/contrib/crossrpms
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @4f66134   07/05/06 08:52:45 Ralf Corsepius Do not subst build_newlib. 4.104.114.84.95
(edit) @055f31e5   07/05/06 08:49:34 Ralf Corsepius Cleanup EXTRA_DIST 4.104.114.84.95
(edit) @da0c2a1d   07/05/06 08:48:47 Ralf Corsepius Remove unused constructs. 4.104.114.84.95
(edit) @c77cc1de   07/05/06 08:42:42 Ralf Corsepius EXTRA_DIST += ../gcc-prep.add 4.104.114.84.95
(edit) @3ab5794   07/05/06 08:36:52 Ralf Corsepius New. 4.104.114.84.95
(edit) @db66352   07/05/06 08:34:18 Ralf Corsepius Remove RPM_OS, rtems/ 4.104.114.84.95
(edit) @a56b23b   07/05/06 08:24:05 Ralf Corsepius Add rtems4.7, freebsd6.1 4.104.114.84.95
(edit) @da52805   07/05/06 08:22:27 Ralf Corsepius Cosmetics. 4.104.114.84.95
(edit) @bc51e6ab   07/05/06 08:15:58 Ralf Corsepius Package sources by default. 4.104.114.84.95
(edit) @a98d1937   07/05/06 08:05:56 Ralf Corsepius Sync freebsd*/*/Makefile.ams 4.104.114.84.95
(edit) @b7e8b3e   07/05/06 07:38:53 Ralf Corsepius Reflect changes. 4.104.114.84.95
(edit) @1f193a8b   07/05/06 07:37:04 Ralf Corsepius New. 4.104.114.84.95
(edit) @478a318   07/05/06 07:32:19 Ralf Corsepius Remove. 4.104.114.84.95
(edit) @f5638da   07/05/06 07:31:07 Ralf Corsepius New. 4.104.114.84.95
(edit) @120c2980   07/05/06 07:29:55 Ralf Corsepius Moved from .. 4.104.114.84.95
(edit) @88744c95   07/04/06 15:52:53 Ralf Corsepius Fix ugly typo 4.104.114.84.95
(edit) @5727b17   07/04/06 15:41:24 Ralf Corsepius New. 4.104.114.84.95
(edit) @b63e4ba   07/04/06 15:33:56 Ralf Corsepius New. 4.104.114.84.95
(edit) @c34612ce   07/03/06 17:19:32 Ralf Corsepius Reflect new mkspec. 4.104.114.84.95
(edit) @611845b   07/03/06 17:17:20 Ralf Corsepius Move noinst_DATA, CLEANFILES, EXTRA_DIST to mkspec.am 4.104.114.84.95
(edit) @9f5f501f   07/03/06 14:33:13 Ralf Corsepius Apply SPECSTRIP. 4.104.114.84.95
(edit) @ae03064c   07/03/06 14:32:12 Ralf Corsepius Apply SPECSTRIP. Build f95 4.104.114.84.95
(edit) @21920c51   07/03/06 14:27:48 Ralf Corsepius Apply SPECSTRIP 4.104.114.84.95
(edit) @81e7cd80   06/25/06 04:13:33 Ralf Corsepius Fix typo in previous change 4.104.114.84.95
(edit) @ad8e65e   06/25/06 04:08:59 Ralf Corsepius Bump version 4.104.114.84.95
(edit) @b38a934b   06/25/06 03:59:02 Ralf Corsepius Add SPECSTRIP 4.104.114.84.95
(edit) @c57fb63e   06/25/06 03:53:32 Ralf Corsepius Add specstrip 4.104.114.84.95
(edit) @ff5bd63   06/25/06 03:51:37 Ralf Corsepius New. 4.104.114.84.95
(edit) @cdd1564   06/21/06 03:56:24 Ralf Corsepius GCC-4.1.1 still installs mf-runtime.h to the wrong directory. 4.104.114.84.95
(edit) @e8a6236   06/20/06 16:40:41 Ralf Corsepius Replace %{build_infos} with %build_infos. 4.104.114.84.95
(edit) @8c311120   06/20/06 12:09:37 Ralf Corsepius Use star to untar the sources 4.104.114.84.95
(edit) @c4d4e15   06/20/06 09:51:02 Ralf Corsepius Add freebsd6.1 4.104.114.84.95
(edit) @677c3d81   06/19/06 07:00:05 Ralf Corsepius More preps for VPATH builds. 4.104.114.84.95
(edit) @e8213f3   06/18/06 07:13:14 Ralf Corsepius Update. 4.104.114.84.95
(edit) @90deee12   06/17/06 08:42:09 Ralf Corsepius Bump version. Add freebsd6.1 4.104.114.84.95
(edit) @918c6a9   06/17/06 08:41:16 Ralf Corsepius New. 4.104.114.84.95
(edit) @8ae43f2   06/17/06 08:40:24 Ralf Corsepius Preps for VPATH builts. 4.104.114.84.95
(edit) @a6f99a45   06/17/06 08:39:38 Ralf Corsepius Use star instead of tar. 4.104.114.84.95
(edit) @549e88f   06/08/06 15:07:30 Ralf Corsepius Preps for VPATH builts. 4.104.114.84.95
(edit) @12f1d7d0   03/23/06 13:21:05 Ralf Corsepius New. 4.104.114.84.95
(edit) @e39da00d   03/23/06 13:06:28 Ralf Corsepius Add defaults for non-standard $prefix. 4.104.114.84.95
(edit) @900ae6fd   03/17/06 13:14:52 Ralf Corsepius Apply @sysdirpattern@ 4.104.114.84.95
(edit) @c3af37c   03/17/06 13:13:46 Ralf Corsepius Use %sysdir instead of %if %_prefix ==|!= /usr 4.104.114.84.95
(edit) @f906d86   03/16/06 06:47:34 Ralf Corsepius Require base-binutils if building infos. 4.104.114.84.95
(edit) @bef3adb   03/16/06 06:45:40 Ralf Corsepius Remove message erroniously checked in in previous change 4.104.114.84.95
(edit) @77cd26d   03/16/06 06:44:27 Ralf Corsepius Set defaults for ac_default_prefix 4.104.114.84.95
(edit) @b224280   03/15/06 17:42:31 Ralf Corsepius Increment version 4.104.114.84.95
(edit) @cab09c0b   03/15/06 17:41:56 Ralf Corsepius Add w32api 4.104.114.84.95
(edit) @760e8186   03/11/06 09:01:52 Ralf Corsepius configure --enable-sim 4.104.114.84.95
(edit) @aa005877   03/11/06 09:01:09 Ralf Corsepius Use DESTDIR for gdb >= 6.3. Remove bogus lib*-sim.a 4.104.114.84.95
(edit) @7f48ec7   03/10/06 13:47:18 Ralf Corsepius Reflect having added --enable-infos 4.104.114.84.95
(edit) @1a64d3e   03/10/06 13:45:05 Ralf Corsepius Increment version 4.104.114.84.95
(edit) @13501927   03/10/06 13:44:30 Ralf Corsepius Use %build_infos 4.104.114.84.95
(edit) @a56035b   03/10/06 13:40:54 Ralf Corsepius Propagate build_infos to *.spec.ins 4.104.114.84.95
(edit) @4d3e4476   03/10/06 06:24:55 Ralf Corsepius Rework rpmprefix logic. Add --enable-infos/build_infos. 4.104.114.84.95
(edit) @0605460   03/10/06 06:24:23 Ralf Corsepius Add missing comma. 4.104.114.84.95
(edit) @783e6007   03/10/06 06:06:10 Ralf Corsepius Add gdb 4.104.114.84.95
(edit) @81f6a9ef   03/10/06 06:04:31 Ralf Corsepius Add gdb/*.add 4.104.114.84.95
(edit) @59c3dfe   03/10/06 06:03:39 Ralf Corsepius New. 4.104.114.84.95
(edit) @c2f69fe   03/10/06 06:03:05 Ralf Corsepius 2006-03-10 Add preliminary rtems-gdb specs. (Immature, incomplete, … 4.104.114.84.95
(edit) @64391f1   03/09/06 05:11:22 Ralf Corsepius Add note on Ada. 4.104.114.84.95
(edit) @f26c821   03/09/06 05:07:57 Ralf Corsepius Update 4.104.114.84.95
(edit) @9b7443c   03/09/06 03:30:37 Ralf Corsepius Enable fortran and objc 4.104.114.84.95
(edit) @f7c8422   03/08/06 09:22:44 Ralf Corsepius Deactivate PATCH0 (not required for gcc >= 4.1.0 4.104.114.84.95
(edit) @73d88d14   03/08/06 09:21:42 Ralf Corsepius Activate fortran and objc 4.104.114.84.95
(edit) @a03debd5   03/07/06 14:03:01 Ralf Corsepius New. 4.104.114.84.95
(edit) @c429c016   03/07/06 13:42:57 Ralf Corsepius Use gcc_rpmvers for subpackage deps. 4.104.114.84.95
(edit) @027c603   03/07/06 09:02:11 Ralf Corsepius Use %echo instead of %%echo in %expand 4.104.114.84.95
(edit) @9087b7c   03/07/06 05:28:35 Ralf Corsepius Fix main package name. Update version. 4.104.114.84.95
(edit) @6eba5919   03/07/06 05:26:26 Ralf Corsepius Distribute local *.add files. 4.104.114.84.95
(edit) @0166739   03/07/06 05:26:08 Ralf Corsepius Distribute local *.add files. Reflect having renamed *-libc.add into … 4.104.114.84.95
(edit) @29ffb1e7   03/07/06 05:24:02 Ralf Corsepius Reflect having renamed gcc/*-libc.add into gcc/*-newlib.add 4.104.114.84.95
(edit) @d11d10fe   03/07/06 03:29:13 Ralf Corsepius Renamed into *-newlib.add 4.104.114.84.95
(edit) @2c7efaa7   03/07/06 03:26:23 Ralf Corsepius Renamed from *-libc.add to *-newlib.add 4.104.114.84.95
(edit) @ab163629   03/06/06 15:43:10 Ralf Corsepius GCC_VERS = 4.1.0 4.104.114.84.95
(edit) @5c8f5f66   03/06/06 15:36:59 Ralf Corsepius Subst gcc_rpmvers for LIB packages. 4.104.114.84.95
(edit) @c04a6103   03/06/06 05:55:02 Ralf Corsepius Remove stray blank in %expand to setup rpmvers. 4.104.114.84.95
(edit) @503be14   03/04/06 06:04:34 Ralf Corsepius Add osversion hack 4.104.114.84.95
(edit) @a3ba1e2d   03/03/06 16:58:51 Ralf Corsepius Propagate osversion. 4.104.114.84.95
(edit) @82e0551   03/03/06 16:56:57 Ralf Corsepius Add gfortran. Add objc. 4.104.114.84.95
(edit) @6355f04   03/01/06 16:43:29 Ralf Corsepius Remove --sysroot 4.104.114.84.95
(edit) @d257306   03/01/06 16:42:51 Ralf Corsepius gcc-4.1.0 still has issues with mudflap. 4.104.114.84.95
(edit) @87f443cc   02/28/06 23:09:54 Ralf Corsepius Add --with-sysroot (Required by GCC-4.1.0) 4.104.114.84.95
(edit) @e25d8c9   02/27/06 18:03:23 Ralf Corsepius Revert to cd'ing into gcc-%{gcc_version} for gcc_update 4.104.114.84.95
(edit) @2f9c5897   02/25/06 04:52:44 Ralf Corsepius Fix stupid typo. 4.104.114.84.95
(edit) @740d8240   02/25/06 04:50:13 Ralf Corsepius Use gcc_rpmvers to setup Version: 4.104.114.84.95
(edit) @2aba80d3   02/25/06 03:28:52 Ralf Corsepius GPL. 4.104.114.84.95
(edit) @975e0f75   02/25/06 03:27:17 Ralf Corsepius Add my Copyright blurb. 4.104.114.84.95
(edit) @00565e4   02/25/06 03:23:34 Ralf Corsepius New. 4.104.114.84.95
(edit) @c046309   02/24/06 15:46:17 Ralf Corsepius Use %{_builddir}/%{name}-%{gcc_rpmvers}/find-* to work around rpmbuild … 4.104.114.84.95
(edit) @5e52a84   02/24/06 15:28:02 Ralf Corsepius Invoke gcc-%{gcc_version}/configure 4.104.114.84.95
(edit) @06fb9c3   02/24/06 15:27:07 Ralf Corsepius Add @PREP@, remove RTEMS version magic 4.104.114.84.95
(edit) @102c876   02/24/06 15:24:03 Ralf Corsepius Add gcc-prep.add 4.104.114.84.95
(edit) @255d476   02/24/06 15:20:39 Ralf Corsepius Remove no-define foreign from AM_INIT_AUTOMAKE. 4.104.114.84.95
(edit) @ef607c60   02/24/06 15:04:25 Ralf Corsepius New. 4.104.114.84.95
(edit) @61b0cc6   02/24/06 07:26:51 Ralf Corsepius Allow shared libgfortran 4.104.114.84.95
(edit) @0d0560a1   02/22/06 13:02:32 Ralf Corsepius Cosmetics. 4.104.114.84.95
(edit) @c8956fd7   02/22/06 11:54:10 Ralf Corsepius Use gcc_version instead of %version, to work around rpm screwing up on … 4.104.114.84.95
(edit) @70aecfc   02/22/06 11:52:41 Ralf Corsepius Run make install-info to get the newlib infos 4.104.114.84.95
(edit) @323f178   02/22/06 07:48:31 Ralf Corsepius Cleanup comment on vxaddr2line. 4.104.114.84.95
