# # ChangeLog for contrib/crossrpms in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 18:01:25 Sun, 04 Nov 2007 09:26:51 GMT Ralf Corsepius [fd7bb10] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Bump BINUTILS_RPMREL. Sun, 04 Nov 2007 09:26:05 GMT Ralf Corsepius [567fed3] * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) Update. Sun, 04 Nov 2007 09:25:32 GMT Ralf Corsepius [137c410] * contrib/crossrpms/patches/binutils-2.18-rtems4.9-20071104.diff (added) New. Thu, 01 Nov 2007 07:32:07 GMT Ralf Corsepius [7cb1d6ea] * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Assume gdb >= 6.4 Thu, 01 Nov 2007 07:29:24 GMT Ralf Corsepius [e2b16828] * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Remove GDB. Thu, 01 Nov 2007 07:27:39 GMT Ralf Corsepius [d4d9f27] * contrib/crossrpms/patches/gdb-6.4-rtems-20060311.diff (deleted) * contrib/crossrpms/patches/gdb-6.4-rtems-20060712.diff (deleted) Remove. Thu, 01 Nov 2007 05:58:05 GMT Ralf Corsepius [25eda206] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) gdb-6.7.1-4 Wed, 31 Oct 2007 21:35:24 GMT Ralf Corsepius [724eab7a] * contrib/crossrpms/patches/gdb-6.7.1-rtems4.9-20071031.diff (modified) Hard-code -lncurses instead of -ltinfo. Wed, 31 Oct 2007 15:46:35 GMT Ralf Corsepius [83644e9] * contrib/crossrpms/patches/gdb-6.7.1-rtems4.9-20071031.diff (modified) Add hacks to get erc32 building Wed, 31 Oct 2007 15:45:45 GMT Ralf Corsepius [91a492a2] * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Cleanups for erc32. Wed, 31 Oct 2007 12:30:51 GMT Ralf Corsepius [84f86cb] * contrib/crossrpms/gdb/gdb.add (modified) Reflect suse-10.3 having expat in libexpat-devel. Wed, 31 Oct 2007 12:27:07 GMT Ralf Corsepius [a4081ce7] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) gdb-4.7.1 Wed, 31 Oct 2007 05:28:40 GMT Ralf Corsepius [49deaec] * contrib/crossrpms/gdb/build.add (modified) Force building against expat Wed, 31 Oct 2007 05:11:26 GMT Ralf Corsepius [3dd61288] * contrib/crossrpms/patches/gdb-6.7.1-rtems4.9-20071031.diff (added) New. Wed, 17 Oct 2007 16:09:27 GMT Ralf Corsepius [2fc47c6] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/cygwin/i686/libncurses-devel.add (modified) * contrib/crossrpms/cygwin/i686/libs.add (modified) * contrib/crossrpms/cygwin/i686/w32api.add (modified) * contrib/crossrpms/cygwin/i686/zlib.add (modified) Update. Fri, 12 Oct 2007 02:20:32 GMT Ralf Corsepius [efe8291f] * contrib/crossrpms/patches/gdb-6.6.90-rtems4.9-20071002.diff (deleted) Remove Fri, 12 Oct 2007 02:19:42 GMT Ralf Corsepius [a5c8f11] * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Fri, 12 Oct 2007 02:19:02 GMT Ralf Corsepius [ee54f23] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) gdb-6.7-2 Thu, 11 Oct 2007 14:51:28 GMT Ralf Corsepius [5c30f679] * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) gdb-6.7-2 Thu, 11 Oct 2007 14:49:10 GMT Ralf Corsepius [053c2f4] * contrib/crossrpms/patches/gdb-6.7-rtems4.9-20071011.diff (modified) Add A. Modra's makeinfo fixes. Thu, 11 Oct 2007 08:31:50 GMT Ralf Corsepius [df16b8bf] * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) gdb-6.7 Thu, 11 Oct 2007 08:28:07 GMT Ralf Corsepius [777d259b] * contrib/crossrpms/patches/gdb-6.7-rtems4.9-20071011.diff (added) New. Thu, 11 Oct 2007 03:18:10 GMT Ralf Corsepius [6f1919e5] * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Thu, 11 Oct 2007 03:09:36 GMT Ralf Corsepius [d6a7e4fe] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) Regenerate. Thu, 11 Oct 2007 03:04:26 GMT Ralf Corsepius [090d3432] * contrib/crossrpms/patches/gcc-core-4.2.2-rtems4.9-20071011.diff (added) New. Thu, 11 Oct 2007 03:02:46 GMT Ralf Corsepius [0e6d50c] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Update to gcc-4.2.2-2. Thu, 11 Oct 2007 02:53:12 GMT Ralf Corsepius [59b4f42] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Add 4.2.2. Wed, 10 Oct 2007 06:52:31 GMT Ralf Corsepius [5a9f372] * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) update to gdb-6.6.90. Tue, 02 Oct 2007 08:38:06 GMT Ralf Corsepius [d731ccc7] * contrib/crossrpms/patches/gdb-6.6.90-rtems4.9-20071002.diff (added) New. Mon, 01 Oct 2007 10:33:32 GMT Ralf Corsepius [1e7b8d32] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060720.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060908.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060909.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070102.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070131.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.8-20070216.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.8-20070405.diff (deleted) Remove (obsolete). Fri, 28 Sep 2007 08:11:09 GMT Ralf Corsepius [fbb54035] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070202.diff (deleted) Remove (obsolete). Fri, 28 Sep 2007 07:41:49 GMT Ralf Corsepius [dfc0dc23] * contrib/crossrpms/patches/binutils-2.17.50-rtems4.8-20070525.diff (deleted) Remove. Fri, 28 Sep 2007 07:38:40 GMT Ralf Corsepius [51aac0e] * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Cleanups. Fri, 28 Sep 2007 07:35:18 GMT Ralf Corsepius [2d9201a] * contrib/crossrpms/rtems4.9/arm/.cvsignore (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/avr/.cvsignore (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/bfin/.cvsignore (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/h8300/.cvsignore (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/i386/.cvsignore (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/m68k/.cvsignore (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/mips/.cvsignore (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/mipstx39/.cvsignore (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/powerpc/.cvsignore (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/sh/.cvsignore (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/sparc/.cvsignore (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/tic4x/.cvsignore (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (added) Add rtems-4.9*.spec Fri, 28 Sep 2007 07:31:55 GMT Ralf Corsepius [b1f6abc] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Reset GCC_RPMREL, GDB_RPMREL, BINUTILS_RPMREL = 1. Fri, 28 Sep 2007 07:27:06 GMT Ralf Corsepius [1cb8b7f] * contrib/crossrpms/rtems4.8/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/arm/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/arm/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/arm/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/avr/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/avr/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/bfin/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/bfin/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/bfin/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/binutils.am (deleted) * contrib/crossrpms/rtems4.8/cpukit-prep.add (deleted) * contrib/crossrpms/rtems4.8/cpukit.am (deleted) * contrib/crossrpms/rtems4.8/gcc-prep.add (deleted) * contrib/crossrpms/rtems4.8/gcc.am (deleted) * contrib/crossrpms/rtems4.8/gdb.am (deleted) * contrib/crossrpms/rtems4.8/h8300/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/h8300/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/i386/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/i386/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/i386/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/m68k/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/m68k/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/mips/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/mips/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/mips/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/mipstx39/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/powerpc/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/powerpc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/sh/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/sh/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/sh/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/sparc/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/sparc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/tic4x/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (deleted) Remove. Fri, 28 Sep 2007 07:24:56 GMT Ralf Corsepius [ed73806b] * contrib/crossrpms/rtems4.9/.cvsignore (added) * contrib/crossrpms/rtems4.9/Makefile.am (added) * contrib/crossrpms/rtems4.9/arm/.cvsignore (added) * contrib/crossrpms/rtems4.9/arm/Makefile.am (added) * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/arm/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/avr/.cvsignore (added) * contrib/crossrpms/rtems4.9/avr/Makefile.am (added) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/avr/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/binutils.am (added) * contrib/crossrpms/rtems4.9/cpukit-prep.add (added) * contrib/crossrpms/rtems4.9/cpukit.am (added) * contrib/crossrpms/rtems4.9/gcc-prep.add (added) * contrib/crossrpms/rtems4.9/gcc.am (added) * contrib/crossrpms/rtems4.9/gdb.am (added) * contrib/crossrpms/rtems4.9/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/i386/.cvsignore (added) * contrib/crossrpms/rtems4.9/i386/Makefile.am (added) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/i386/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/mips/.cvsignore (added) * contrib/crossrpms/rtems4.9/mips/Makefile.am (added) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/mips/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/sh/.cvsignore (added) * contrib/crossrpms/rtems4.9/sh/Makefile.am (added) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/sh/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/.cvsignore (added) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/gdb-sources.add (added) copy from rtems-4.8 to rtems-4.9. Fri, 28 Sep 2007 07:19:29 GMT Ralf Corsepius [1f60e1c] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) rtems-4.9. Thu, 13 Sep 2007 01:12:50 GMT Ralf Corsepius [98e398cb] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070912.diff (modified) Add missing #endif in powerpc/setjmp.S Wed, 12 Sep 2007 19:42:12 GMT Ralf Corsepius [8393f3a] * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) newlib-1.15.0-rtems4.8-20070912.diff. Wed, 12 Sep 2007 19:41:58 GMT Ralf Corsepius [18960f10] * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) GCC_RPMREL = 24. Wed, 12 Sep 2007 19:38:48 GMT Ralf Corsepius [98f890b] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070912.diff (added) New (Incorporate Eric Norum's altivec patch) Sun, 02 Sep 2007 05:24:37 GMT Ralf Corsepius [9bd03749] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (modified) Regenerate. Wed, 29 Aug 2007 02:56:55 GMT Ralf Corsepius [1dbd593d] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) BINUTILS_VERS = 2.18. BINUTILS_RPMREL = 1%{?dist}. Wed, 29 Aug 2007 02:54:39 GMT Ralf Corsepius [a380e47e] * contrib/crossrpms/binutils/base-binutils.add (modified) Abandon *-base-binutils packages. Wed, 29 Aug 2007 02:51:40 GMT Ralf Corsepius [9ce762b] * contrib/crossrpms/binutils/base-binutils.add (modified) Abandon binutils < 2.13. Thu, 09 Aug 2007 16:57:09 GMT Ralf Corsepius [ece78df6] * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (modified) gdb-6.6-9. Thu, 09 Aug 2007 05:20:07 GMT Ralf Corsepius [876c33f1] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (modified) gdb-6.6-9. Thu, 09 Aug 2007 03:05:41 GMT Ralf Corsepius [9aa1472] * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (modified) Regenerate. Thu, 09 Aug 2007 03:05:00 GMT Ralf Corsepius [e90748fd] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (added) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gdb.spec (added) New. Thu, 09 Aug 2007 03:01:40 GMT Ralf Corsepius [6ed5f75] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Increment GDB_RPMREL. Thu, 09 Aug 2007 02:58:36 GMT Ralf Corsepius [984e8d8d] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Append %{?dist} to GDB_RPMREL. Thu, 09 Aug 2007 02:55:36 GMT Ralf Corsepius [2ef64f2] * contrib/crossrpms/gdb/base-gdb.add (modified) Remove references to base packages. Thu, 09 Aug 2007 02:54:01 GMT Ralf Corsepius [9452ee4a] * contrib/crossrpms/gdb/base-gdb.add (modified) Remove support for gdb < 6.0. Thu, 09 Aug 2007 02:53:30 GMT Ralf Corsepius [ee19567c] * contrib/crossrpms/gdb/gdb.add (modified) Remove %{?dist} Wed, 08 Aug 2007 12:21:26 GMT Ralf Corsepius [c2cc8b2] * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90. Wed, 08 Aug 2007 10:10:51 GMT Ralf Corsepius [4db732d] * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90. Wed, 08 Aug 2007 08:24:48 GMT Ralf Corsepius [8ee1b11] * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90. Wed, 08 Aug 2007 04:22:50 GMT Ralf Corsepius [9e516ac] * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (modified) Revert to gcc-4.0.3-12, gcc-4.2.1 doesn't build Wed, 08 Aug 2007 04:13:44 GMT Ralf Corsepius [baa2d55] * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90. Wed, 08 Aug 2007 04:11:02 GMT Ralf Corsepius [1cb554a6] * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:43:09 GMT Ralf Corsepius [cc85dda] * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:42:47 GMT Ralf Corsepius [1a8165f6] * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Wed, 08 Aug 2007 03:36:40 GMT Ralf Corsepius [8d88aa2] * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:36:15 GMT Ralf Corsepius [92b76712] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Wed, 08 Aug 2007 03:30:27 GMT Ralf Corsepius [ff3a2d87] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:30:15 GMT Ralf Corsepius [5d991cf] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Wed, 08 Aug 2007 03:21:54 GMT Ralf Corsepius [3675f57] * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:21:29 GMT Ralf Corsepius [8d25d2e] * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Tue, 07 Aug 2007 15:41:57 GMT Ralf Corsepius [c48c3590] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (modified) BINUTILS_RPMREL = 2 Tue, 07 Aug 2007 15:38:23 GMT Ralf Corsepius [4907b96] * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) Regenerate. Tue, 07 Aug 2007 15:38:10 GMT Ralf Corsepius [90aab6d] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Enable infos for binutils. Tue, 07 Aug 2007 15:21:40 GMT Ralf Corsepius [69fb982] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (modified) Upgrade to binutils-2.17.90. Tue, 07 Aug 2007 15:15:42 GMT Ralf Corsepius [039d51b] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (added) Regenerate. Tue, 07 Aug 2007 08:20:59 GMT Ralf Corsepius [cae995d] * contrib/crossrpms/patches/binutils-2.17.90-rtems4.8-20070807.diff (added) New. Sat, 04 Aug 2007 08:21:33 GMT Ralf Corsepius [3ffefc3] * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) Sync. Sat, 04 Aug 2007 08:20:59 GMT Ralf Corsepius [9e84b8e8] * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) GCC_RPMREL = 22. Sat, 04 Aug 2007 08:20:43 GMT Ralf Corsepius [55230f2e] * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) Update to gcc-core-4.2.1-rtems4.8-20070804.diff. Sat, 04 Aug 2007 08:18:14 GMT Ralf Corsepius [5332bc6e] * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20070804.diff (added) Add m68k -m528x. Sat, 04 Aug 2007 06:13:39 GMT Ralf Corsepius [26ccaab0] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) GCC_RPMREL = 21 Sat, 04 Aug 2007 06:03:04 GMT Ralf Corsepius [31139c3] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Update to newlib-1.15.0-rtems4.8-20070804.diff Sat, 04 Aug 2007 04:34:30 GMT Ralf Corsepius [b39173b0] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070804.diff (added) Add tar.h. Thu, 26 Jul 2007 09:31:41 GMT Ralf Corsepius [462b28d] * contrib/crossrpms/cygwin/i686/libncurses-devel.add (modified) chmod +x etc/postinstall/libncurses-devel.sh Thu, 26 Jul 2007 09:19:22 GMT Ralf Corsepius [5a379b01] * contrib/crossrpms/cygwin/i686/libncurses-devel.add (modified) Don't use sed -i. Thu, 26 Jul 2007 09:19:02 GMT Ralf Corsepius [1b1452b6] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) NCURSES_RPMREL = 0.20070726.1 Tue, 24 Jul 2007 14:26:46 GMT Ralf Corsepius [e0d85b74] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.2/i586/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Move %{?dist} into BINUTILS_RPMREL. Tue, 24 Jul 2007 14:24:43 GMT Ralf Corsepius [b8a8bfb0] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.2/i586/Makefile.am (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Move %{?dist} into GCC_RPMREL. Tue, 24 Jul 2007 04:27:05 GMT Ralf Corsepius [c5721b9] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Bump the date on *RPMREL Tue, 24 Jul 2007 03:47:09 GMT Ralf Corsepius [ee4740b] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) Add cygwin hacks. Tue, 24 Jul 2007 03:45:39 GMT Ralf Corsepius [d292aae] * contrib/crossrpms/cygwin/i686/target-zlib.add (added) * contrib/crossrpms/cygwin/i686/zlib.add (added) New. Tue, 24 Jul 2007 03:45:22 GMT Ralf Corsepius [7feadc65] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Add zlib. Mon, 23 Jul 2007 09:44:40 GMT Ralf Corsepius [d942dc2] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/cygwin/i686/libs.add (modified) Various updates. Mon, 23 Jul 2007 09:43:49 GMT Ralf Corsepius [131ee1cc] * contrib/crossrpms/cygwin/i686/libncurses-devel.add (added) * contrib/crossrpms/cygwin/i686/target-libncurses-devel.add (added) New. Mon, 23 Jul 2007 02:02:15 GMT Ralf Corsepius [f81476f] * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) Sync GCC with testing. Sun, 22 Jul 2007 07:08:30 GMT Ralf Corsepius [86a30d0] * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) Various patches from rtems-4-8-testing branch. Fri, 20 Jul 2007 05:36:13 GMT Ralf Corsepius [4acc7e2] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (modified) Sync with testing. Fri, 20 Jul 2007 05:32:17 GMT Ralf Corsepius [70ea34b] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) Sync with devel. Fri, 20 Jul 2007 05:23:59 GMT Ralf Corsepius [ed332c8] * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Sync with testing. Fri, 20 Jul 2007 04:59:16 GMT Ralf Corsepius [280e1308] * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20070719.diff (added) New. Sun, 15 Jul 2007 05:02:51 GMT Ralf Corsepius [4b0be6c] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Preps for gcc-4.2.1.
