# # ChangeLog for contrib/crossrpms in rtems # # Generated by Trac 1.2.1.dev0 # 04/27/24 10:52:44 Sat, 12 Aug 2006 06:02:29 GMT Ralf Corsepius [d218a83] * contrib/crossrpms/patches/binutils-2.17-rtems-20060812.diff (added) Update from binutils-2.17_branch. Merge bfin patch. Sat, 12 Aug 2006 05:07:04 GMT Ralf Corsepius [056498a7] * contrib/crossrpms/rtems4.7/Makefile.am (modified) Add bfin Sat, 12 Aug 2006 05:05:52 GMT Ralf Corsepius [a2ced07] * contrib/crossrpms/rtems4.7/bfin/Makefile.am (modified) Reset RPMRELS. Fri, 11 Aug 2006 21:37:40 GMT Joel Sherrill [6d7e836] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/patches/binutils-2.17-rtems-bfin-20060810.diff (added) * contrib/crossrpms/patches/gcc-4.1.1-bfinrtems-20060810a.diff (added) * contrib/crossrpms/patches/gdb-6.5-bfinrtems-20060810a.diff (added) * contrib/crossrpms/patches/newlib-1.14.0-bfinrtems-20060810a.diff (added) * contrib/crossrpms/rtems4.7/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.7/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.7/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/bfin/gdb-sources.add (added) 2006-08-11 Joel Sherrill * ... Thu, 10 Aug 2006 07:04:25 GMT Ralf Corsepius [1a39b67] * contrib/crossrpms/rtems4.7/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.7/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.7/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.7/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.7/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/tic4x/Makefile.am (modified) Bump RPMREL. Wed, 09 Aug 2006 23:06:58 GMT Joel Sherrill [3b97526c] * contrib/crossrpms/.cvsignore (modified) * contrib/crossrpms/ChangeLog (modified) 2006-08-09 Joel Sherrill * ... Thu, 03 Aug 2006 04:29:22 GMT Ralf Corsepius [6bdebc3a] * contrib/crossrpms/configure.ac (modified) Bump version. Thu, 03 Aug 2006 04:28:43 GMT Ralf Corsepius [c1a25af9] * contrib/crossrpms/autotools/Makefile.am (modified) Use hard-coded %release. Thu, 03 Aug 2006 03:57:47 GMT Ralf Corsepius [5b151f87] * contrib/crossrpms/rtems4.7/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.7/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.7/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.7/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.7/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/tic4x/Makefile.am (modified) Use hard-coded %release. Thu, 03 Aug 2006 02:50:36 GMT Ralf Corsepius [e85211e] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060626.diff (deleted) Remove (Obsolete) Thu, 03 Aug 2006 02:48:31 GMT Ralf Corsepius [52053484] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060704.diff (deleted) Remove Thu, 03 Aug 2006 02:47:53 GMT Ralf Corsepius [3219756b] * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (modified) Update to using newlib-1.14.0-rtems-20060707.diff Wed, 02 Aug 2006 03:39:00 GMT Ralf Corsepius [300dce7] * contrib/crossrpms/configure.ac (modified) Bump version. Wed, 02 Aug 2006 03:37:34 GMT Ralf Corsepius [d9e9a5a] * contrib/crossrpms/autotools/autoconf.am (modified) * contrib/crossrpms/autotools/automake.am (modified) Use further shared spec-fragments. Wed, 02 Aug 2006 03:36:22 GMT Ralf Corsepius [6c873da] * contrib/crossrpms/autotools/autoconf.add (modified) Split out target-autoconf.add Wed, 02 Aug 2006 03:36:11 GMT Ralf Corsepius [a5b38ea] * contrib/crossrpms/autotools/automake.add (modified) Split out target-automake.add Wed, 02 Aug 2006 03:35:10 GMT Ralf Corsepius [e5f924d] * contrib/crossrpms/autotools/target-autoconf.add (added) * contrib/crossrpms/autotools/target-automake.add (added) New. Tue, 25 Jul 2006 16:16:07 GMT Ralf Corsepius [6d05356] * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) Add objc Tue, 25 Jul 2006 16:11:49 GMT Ralf Corsepius [8eb71ea4] * contrib/crossrpms/cygwin/gcc.am (modified) Remove sed -e /[@]tool_target[@]-newlib/d" Tue, 25 Jul 2006 16:11:21 GMT Ralf Corsepius [eca59879] * contrib/crossrpms/cygwin/gcc-prep.add (modified) Remove blank lines. Tue, 25 Jul 2006 16:10:46 GMT Ralf Corsepius [e8b0467] * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/install.add (modified) More %if %build_newlib blocks. Tue, 25 Jul 2006 14:18:12 GMT Ralf Corsepius [6cbe966] * contrib/crossrpms/patches/automake-1.8.1-rtems-20040112-1.diff (added) New. Tue, 25 Jul 2006 13:15:18 GMT Ralf Corsepius [f391f6a] * contrib/crossrpms/autotools/autoconf.add (modified) * contrib/crossrpms/autotools/automake.add (modified) Fix rpmgroup. Cosmetics. Tue, 25 Jul 2006 11:47:04 GMT Ralf Corsepius [41e4caf] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Upgrade to gcc-3.4.4-2, cygwin-1.5.21-1 Mon, 24 Jul 2006 09:01:22 GMT Ralf Corsepius [c45ec73] * contrib/crossrpms/configure.ac (modified) Bump version. Add AC_CONFIG_FILES([autotools/Makefile]) Mon, 24 Jul 2006 08:57:02 GMT Ralf Corsepius [9b966c30] * contrib/crossrpms/Makefile.am (modified) Add autotools. Mon, 24 Jul 2006 08:56:11 GMT Ralf Corsepius [35ed8723] * contrib/crossrpms/NEWS (modified) Add provisory/preliminary autotools support. Mon, 24 Jul 2006 08:54:04 GMT Ralf Corsepius [43fe4445] * contrib/crossrpms/TODO (modified) Cleanup. Add note on autotools. Mon, 24 Jul 2006 08:51:15 GMT Ralf Corsepius [a26364de] * contrib/crossrpms/autotools/.cvsignore (added) * contrib/crossrpms/autotools/Makefile.am (added) * contrib/crossrpms/autotools/autoconf.add (added) * contrib/crossrpms/autotools/autoconf.am (added) * contrib/crossrpms/autotools/automake.add (added) * contrib/crossrpms/autotools/automake.am (added) New. Mon, 24 Jul 2006 08:50:28 GMT Ralf Corsepius [262bea9] * contrib/crossrpms/AUTHORS (modified) Add Chris and Joel. Mon, 24 Jul 2006 08:48:26 GMT Ralf Corsepius [c791b9d] * contrib/crossrpms/NEWS (modified) 2006-07-23 Rename "*-base-*" packages into -common. ... Sun, 23 Jul 2006 14:24:25 GMT Ralf Corsepius [a61e8325] * contrib/crossrpms/configure.ac (modified) Bump version Sun, 23 Jul 2006 14:23:21 GMT Ralf Corsepius [5e58aa92] * contrib/crossrpms/gcc/target-gcc.add (modified) Minor fixes. Sun, 23 Jul 2006 14:22:37 GMT Ralf Corsepius [1528803c] * contrib/crossrpms/binutils/base-binutils.add (modified) Let rpm Obsolete < %{binutils_version}-%{release} Sun, 23 Jul 2006 14:21:26 GMT Ralf Corsepius [6255333] * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-newlib.add (modified) Rename *base packages into gcc*-common gcc/base*.add Sun, 23 Jul 2006 14:20:22 GMT Ralf Corsepius [f789c8a2] * contrib/crossrpms/gcc/target-gfortran.add (modified) Rename *base packages into gcc*-common gcc/base*.add Rename ... Sun, 23 Jul 2006 14:19:57 GMT Ralf Corsepius [6f60abde] * contrib/crossrpms/gcc/target-g77.add (modified) Rename *base packages into gcc*-common gcc/base*.add Rename *g77 ... Sun, 23 Jul 2006 14:19:14 GMT Ralf Corsepius [6d206e16] * contrib/crossrpms/gcc/target-objc.add (modified) Rename *base packages into gcc*-common gcc/base*.add Rename *objc ... Sun, 23 Jul 2006 14:18:56 GMT Ralf Corsepius [bf7b460] * contrib/crossrpms/gcc/target-gcj.add (modified) Rename *base packages into gcc*-common gcc/base*.add Rename *gcj ... Sun, 23 Jul 2006 14:18:39 GMT Ralf Corsepius [45c41764] * contrib/crossrpms/gcc/target-gnat.add (modified) Rename *base packages into gcc*-common gcc/base*.add Rename *gnat ... Sun, 23 Jul 2006 14:18:24 GMT Ralf Corsepius [48b256c3] * contrib/crossrpms/gcc/target-c++.add (modified) Rename *base packages into gcc*-common gcc/base*.add Rename *c++ ... Sun, 23 Jul 2006 14:17:48 GMT Ralf Corsepius [793bad2] * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) Rename *base packages into gcc*-common Sun, 23 Jul 2006 14:16:21 GMT Ralf Corsepius [e41b8b7] * contrib/crossrpms/gdb/base-gdb.add (modified) Let rpm Obsolete < %{gdb_version}-%{release} Sun, 23 Jul 2006 14:14:55 GMT Ralf Corsepius [9a626a3] * contrib/crossrpms/gcc/build.add (modified) Add --enable-threads. Sun, 23 Jul 2006 05:36:19 GMT Ralf Corsepius [aec66f3] * contrib/crossrpms/cygwin/i686/gcc-sources.add (modified) * contrib/crossrpms/freebsd5.2/i586/gcc-sources.add (modified) * contrib/crossrpms/freebsd6.0/i586/gcc-sources.add (modified) * contrib/crossrpms/freebsd6.1/i586/gcc-sources.add (modified) * contrib/crossrpms/mingw32/i686/gcc-sources.add (modified) * contrib/crossrpms/solaris2.7/sparc/gcc-sources.add (modified) Elminate blank lines. Sat, 22 Jul 2006 05:05:22 GMT Ralf Corsepius [e302e959] * contrib/crossrpms/rtems4.7/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (modified) Eliminate white spaces. Sat, 22 Jul 2006 02:40:16 GMT Ralf Corsepius [385f81c] * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Rename rtems4.7-base-gdb into gdb-common Fri, 21 Jul 2006 15:55:08 GMT Ralf Corsepius [65f75598] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) Rename rtems4.7-base-binutils into binutils-common Fri, 21 Jul 2006 05:02:12 GMT Ralf Corsepius [7bcdece] * contrib/crossrpms/specstrip (modified) Remove --sources (Unused) Fri, 21 Jul 2006 04:51:54 GMT Ralf Corsepius [a52dc937] * contrib/crossrpms/gcc/target-gcc.add (modified) Add %{gcclib}/@tool_target@/%{gcc_version}/include/ssp Fri, 21 Jul 2006 04:38:56 GMT Ralf Corsepius [0c8a556] * contrib/crossrpms/Makefile.am (modified) Make install-patches more verbose. Fri, 21 Jul 2006 04:36:14 GMT Ralf Corsepius [e8ba788] * contrib/crossrpms/Makefile.am (modified) Add install-patches. Fri, 21 Jul 2006 04:29:02 GMT Ralf Corsepius [654cb682] * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Add objc. Thu, 20 Jul 2006 23:32:32 GMT Chris Johns [44a6dcc] * contrib/crossrpms/rtems4.7/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gcc-sources.add (modified) Use gcc-core-4.1.1-rtems-20060720.diff. Thu, 20 Jul 2006 05:17:36 GMT Ralf Corsepius [c29d0a21] * contrib/crossrpms/configure.ac (modified) Remove $build_infos. Add SPECSTRIP_OPTS. Thu, 20 Jul 2006 05:16:29 GMT Ralf Corsepius [8747e99a] * contrib/crossrpms/specstrip (modified) Add --enable/disable-infos. Thu, 20 Jul 2006 05:15:47 GMT Ralf Corsepius [40459fbf] * contrib/crossrpms/mkspec.am (modified) Add SPECSTRIP_OPTS. Thu, 20 Jul 2006 00:40:11 GMT Chris Johns [a1abfb95] * contrib/crossrpms/ChangeLog (modified) 2006-07-19 Chris Johns * ... Wed, 19 Jul 2006 21:51:39 GMT Chris Johns [45def1d] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060720.diff (added) Added patch to fix GCC bug PR28400. Tue, 18 Jul 2006 07:26:10 GMT Ralf Corsepius [d4609b2] * contrib/crossrpms/rtems4.7/h8300/gcc-sources.add (modified) Use newlib-1.14.0-rtems-20060707.diff Tue, 18 Jul 2006 07:25:19 GMT Ralf Corsepius [22f187d0] * contrib/crossrpms/configure.ac (modified) Fix setting up targets for solaris* Tue, 18 Jul 2006 02:32:19 GMT Ralf Corsepius [4557d3c] * contrib/crossrpms/gcc/install.add (modified) Remove infos and man7 if !%build_infos. Mon, 17 Jul 2006 15:23:04 GMT Ralf Corsepius [c10a31b] * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Require: base packages iff %build_infos Mon, 17 Jul 2006 15:22:05 GMT Ralf Corsepius [176aca7] * contrib/crossrpms/gcc/target-g77.add (modified) Require: base-g77 iff %build_infos Mon, 17 Jul 2006 15:21:33 GMT Ralf Corsepius [f69ae2e] * contrib/crossrpms/gcc/target-gfortran.add (modified) Require: base-gfortran iff %build_infos Mon, 17 Jul 2006 14:30:28 GMT Ralf Corsepius [d2b94e76] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) Cosmetics. Sun, 16 Jul 2006 06:17:32 GMT Ralf Corsepius [f3ef35af] * contrib/crossrpms/gcc/target-gnat.add (modified) Require base-gnat if build_infos is true. Sun, 16 Jul 2006 06:15:33 GMT Ralf Corsepius [45fbca9] * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) Require base-gcc if build_infos is true. Sun, 16 Jul 2006 06:05:37 GMT Ralf Corsepius [c20efa7] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Cosmetics. Sun, 16 Jul 2006 06:05:02 GMT Ralf Corsepius [4edae5cf] * contrib/crossrpms/gcc/gccnewlib.add (modified) Let *-gcc subpackage require base-package. Sun, 16 Jul 2006 06:03:36 GMT Ralf Corsepius [473fe62] * contrib/crossrpms/gdb/base-gdb.add (modified) Remove rpmlint warning on subject. Sun, 16 Jul 2006 05:05:11 GMT Ralf Corsepius [aaf5563] * contrib/crossrpms/mkspec.am (modified) Remove @build_infos@. Sun, 16 Jul 2006 04:52:38 GMT Ralf Corsepius [116f0fc] * contrib/crossrpms/mkspec.am (modified) Eliminate @osversion@ Sun, 16 Jul 2006 04:51:16 GMT Ralf Corsepius [1ac7a00] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Eliminate @osversion. Hard-code 4.7. Fri, 14 Jul 2006 06:54:23 GMT Ralf Corsepius [26bdc875] * contrib/crossrpms/configure.ac (modified) Use //Makefile.am in check for all/rtems. Fri, 14 Jul 2006 06:05:04 GMT Ralf Corsepius [cb9c5a8] * contrib/crossrpms/mingw32/i686/Makefile.am (modified) include ../gcc.am Fri, 14 Jul 2006 06:04:51 GMT Ralf Corsepius [969f4d5] * contrib/crossrpms/mingw32/gcc.am (added) New. Split out from i686/Makefile.am Fri, 14 Jul 2006 05:19:05 GMT Ralf Corsepius [7681446] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) include ../gcc.am Fri, 14 Jul 2006 05:18:42 GMT Ralf Corsepius [4e7fb7b] * contrib/crossrpms/cygwin/gcc.am (added) New. Split out from i686/Makefile.am Thu, 13 Jul 2006 20:50:54 GMT Joel Sherrill [984ccfed] * contrib/crossrpms/ChangeLog (modified) Change RTEMS to Joel. Thu, 13 Jul 2006 16:48:53 GMT Joel Sherrill [460d7e7] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/patches/gdb-6.5-rtems-20060713.diff (added) * contrib/crossrpms/rtems4.7/Makefile.am (modified) * contrib/crossrpms/rtems4.7/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.7/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.7/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.7/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.7/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.7/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.7/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.7/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.7/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gdb-sources.add (modified) 2006-07-13 Joel Sherrill * ... Thu, 13 Jul 2006 12:50:17 GMT Ralf Corsepius [6933a4c] * contrib/crossrpms/gdb/gdb.add (modified) BR: libtermcap-devel for sparc-rtems. Wed, 12 Jul 2006 20:48:51 GMT Joel Sherrill [d959898] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/patches/gdb-6.4-rtems-20060712.diff (added) * contrib/crossrpms/rtems4.7/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gdb-sources.add (modified) 2006-07-12 RTEMS * rtems4.7/arm/gdb-sources.add, ... Tue, 11 Jul 2006 14:46:22 GMT Ralf Corsepius [daf46560] * contrib/crossrpms/rtems4.7/avr/gcc-sources.add (modified) Sync. Tue, 11 Jul 2006 14:45:24 GMT Ralf Corsepius [0b130fae] * contrib/crossrpms/rtems4.7/sparc/gcc-sources.add (modified) Rebuild with arm-patch applied. Tue, 11 Jul 2006 11:33:19 GMT Ralf Corsepius [dfc207ea] * contrib/crossrpms/rtems4.7/arm/gcc-sources.add (modified) Use newlib-1.14.0-rtems-20060707.diff Tue, 11 Jul 2006 11:32:10 GMT Ralf Corsepius [2dd8aa1e] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060707.diff (added) New. Remove arm/endian.h Tue, 11 Jul 2006 07:23:11 GMT Ralf Corsepius [bfb422d0] * contrib/crossrpms/NEWS (modified) Add short notice Tue, 11 Jul 2006 03:29:26 GMT Ralf Corsepius [46a9d63] * contrib/crossrpms/binutils/binutils.add (modified) Remove %define build_infos. Tue, 11 Jul 2006 03:28:44 GMT Ralf Corsepius [61d66ffb] * contrib/crossrpms/rtems4.7/m68k/binutils-sources.add (modified) Add binutils-2.17-rtems-20060711.diff. Tue, 11 Jul 2006 03:28:02 GMT Ralf Corsepius [9807f04] * contrib/crossrpms/patches/binutils-2.17-rtems-20060711.diff (added) New. m68k/cpu32 patch. Sun, 09 Jul 2006 05:22:06 GMT Ralf Corsepius [a650ebb1] * contrib/crossrpms/solaris2.7/gcc.am (added) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/binutils-sources.add (modified) Sync from freebsd6.1 Sat, 08 Jul 2006 05:57:32 GMT Ralf Corsepius [08cbfbce] * contrib/crossrpms/freebsd5.2/i586/binutils-sources.add (modified) * contrib/crossrpms/freebsd6.0/i586/binutils-sources.add (modified) * contrib/crossrpms/freebsd6.1/i586/binutils-sources.add (modified) Sync. Sat, 08 Jul 2006 05:56:39 GMT Ralf Corsepius [fc4d7d2] * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) Update to binutils-2.17, gcc-4.1.1 Fri, 07 Jul 2006 09:02:17 GMT Ralf Corsepius [a3182b55] * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) Split out GCC. Fri, 07 Jul 2006 09:01:47 GMT Ralf Corsepius [0767028] * contrib/crossrpms/freebsd5.2/gcc.am (added) * contrib/crossrpms/freebsd6.0/gcc.am (added) * contrib/crossrpms/freebsd6.1/gcc.am (added) New. Fri, 07 Jul 2006 07:04:53 GMT Ralf Corsepius [80bd514f] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Split out binutils. Fri, 07 Jul 2006 07:03:21 GMT Ralf Corsepius [394555c] * contrib/crossrpms/freebsd5.2/binutils.am (added) * contrib/crossrpms/freebsd6.0/binutils.am (added) * contrib/crossrpms/freebsd6.1/binutils.am (added) * contrib/crossrpms/solaris2.7/binutils.am (added) New. Fri, 07 Jul 2006 05:02:39 GMT Ralf Corsepius [0f9fd94f] * contrib/crossrpms/cygwin/binutils.am (added) * contrib/crossrpms/mingw32/binutils.am (added) New. Fri, 07 Jul 2006 04:58:19 GMT Ralf Corsepius [7df0f40e] * contrib/crossrpms/rtems4.7/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.7/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.7/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.7/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.7/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/tic4x/Makefile.am (modified) Use relative dirs to automake fragments.
