# # ChangeLog for contrib/crossrpms in rtems # # Generated by Trac 1.2.1.dev0 # 04/24/24 21:22:12 Mon, 26 May 2008 08:43:06 GMT Ralf Corsepius [4cf3275] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) Add gcc-4.2.4 Mon, 26 May 2008 08:41:48 GMT Ralf Corsepius [fc19fcbd] * contrib/crossrpms/patches/gcc-core-4.2.4-rtems4.8-20080526.diff (added) New. Fri, 09 May 2008 12:33:23 GMT Ralf Corsepius [37c77c5c] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Upgrade to gcc-4.2.3 Thu, 08 May 2008 05:07:27 GMT Ralf Corsepius [01ab562f] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) GCC_RPMREL = 29. Thu, 08 May 2008 05:06:24 GMT Ralf Corsepius [7567f4d] * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) Back out to gcc-4.2.2. Thu, 08 May 2008 05:04:59 GMT Ralf Corsepius [492e450] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) Add support for gcc-4.3.0, gcc-4.2.3. Update to ... Thu, 08 May 2008 05:01:27 GMT Ralf Corsepius [84d31bc5] * contrib/crossrpms/gcc/gccnewlib.add (modified) Sync with CVS HEAD. Thu, 08 May 2008 04:58:00 GMT Ralf Corsepius [b61c8cca] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20080508.diff (added) Add SIZE_MAX fix. Thu, 08 May 2008 04:57:32 GMT Ralf Corsepius [9a73a4c9] * contrib/crossrpms/patches/gcc-core-4.2.3-rtems4.8-20080508.diff (added) Rebase patch against gcc-core-4.2.3. Disable building libiberty. Thu, 08 May 2008 02:50:24 GMT Ralf Corsepius [f79feff] * contrib/crossrpms/gdb/build.add (modified) Enable --with-system-readline only for gdb >= 6.7 Fri, 02 May 2008 05:00:14 GMT Ralf Corsepius [8c0a48d] * contrib/crossrpms/patches/gdb-6.7.1-rtems4.8-20071216.diff (deleted) * contrib/crossrpms/patches/gdb-6.7.1-rtems4.8-20080429.diff (deleted) Remove (Obsolete). Fri, 02 May 2008 04:57:58 GMT Ralf Corsepius [0c4dd1c] * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gdb.spec (modified) Regenerate. Fri, 02 May 2008 04:56:36 GMT Ralf Corsepius [83ea84b6] * contrib/crossrpms/patches/gdb-6.8-rtems4.8-20080429.diff (added) Sync with RTEMS CVS-HEAD. Fri, 02 May 2008 04:55:06 GMT Ralf Corsepius [1f567f2] * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) Upgrade to gdb-6.8. Tue, 29 Apr 2008 15:00:41 GMT Ralf Corsepius [355d23b7] * contrib/crossrpms/patches/gdb-6.7.1-rtems4.8-20080429.diff (added) New. Include erc32 hacks from RTEMS CVS-HEAD. Tue, 29 Apr 2008 14:50:12 GMT Ralf Corsepius [433f689] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gdb.spec (modified) Update gdb packaging. Tue, 29 Apr 2008 14:49:15 GMT Ralf Corsepius [269f5a2] * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) gdb-6.7.1-rtems4.8-20080429.diff. Tue, 29 Apr 2008 14:43:30 GMT Ralf Corsepius [9d2aae8] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Bump GDB_RPMREL. Tue, 29 Apr 2008 11:38:26 GMT Ralf Corsepius [90c85d5b] * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/prep.add (modified) Sync with CVS-HEAD. Sat, 26 Apr 2008 05:46:39 GMT Ralf Corsepius [b0f67b53] * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Use rtems_api. Sat, 26 Apr 2008 05:33:51 GMT Ralf Corsepius [229c0470] * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/mkspec.am (modified) Add rtems_api. Fri, 25 Apr 2008 15:30:46 GMT Ralf Corsepius [5bb8ddf] * contrib/crossrpms/gcc/base-gcc.add (modified) Remove stray blank line. Fri, 25 Apr 2008 15:29:12 GMT Ralf Corsepius [e3ad849] * contrib/crossrpms/gcc/prep.add (modified) Add mpfr for gcc-4.3.0. Fri, 28 Mar 2008 05:45:41 GMT Ralf Corsepius [0b77003] * contrib/crossrpms/common/common.add (modified) Add _host_rpmprefix. Wed, 26 Mar 2008 17:54:59 GMT Ralf Corsepius [4c081642] * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Remove stray line. Tue, 25 Mar 2008 07:27:33 GMT Ralf Corsepius [c2a5fa56] * contrib/crossrpms/gdb/gdb.add (modified) BuildRequire: @rpmprefix@%{_host}-gcc for CdnX. Tue, 25 Mar 2008 07:26:09 GMT Ralf Corsepius [bf33c69e] * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/install.add (modified) Add _bindir to PATH. Thu, 20 Mar 2008 08:33:07 GMT Ralf Corsepius [1187fce8] * contrib/crossrpms/common/common.add (modified) Add cygwin hacks from CVS-HEAD. Tue, 18 Mar 2008 06:12:56 GMT Ralf Corsepius [5ee16ab] * contrib/crossrpms/binutils/build.add (modified) Add %{_bindir} to PATH to cater CdnX-builds. Set CFLAGS_FOR_BUILD. Tue, 18 Mar 2008 06:11:28 GMT Ralf Corsepius [10d6b97] * contrib/crossrpms/binutils/install.add (modified) Add %{_bindir} to PATH to cater CdnX-builds. Tue, 18 Mar 2008 06:09:49 GMT Ralf Corsepius [1ded262b] * contrib/crossrpms/binutils/binutils.add (modified) BR: @rpmprefix@%{_host}-gcc for CdnX-builds. Tue, 18 Mar 2008 06:07:14 GMT Ralf Corsepius [1e2a76e] * contrib/crossrpms/binutils/install.add (modified) Sync with CVS-HEAD. Tue, 18 Mar 2008 05:39:28 GMT Ralf Corsepius [9ee9a7d] * contrib/crossrpms/gcc/build.add (modified) Set CFLAGS_FOR_BUILD and CC for CdnX-builds. Tue, 18 Mar 2008 05:37:48 GMT Ralf Corsepius [c8ecbf9] * contrib/crossrpms/gcc/gccnewlib.add (modified) BR: @rpmprefix@@tool_target@-gcc and @rpmprefix@%{_host}-gcc for ... Tue, 18 Mar 2008 05:36:22 GMT Ralf Corsepius [44303a8f] * contrib/crossrpms/gcc/target-c++.add (modified) BR: @rpmprefix@@tool_target@-gcc-c++ for CdnX-builds. Mon, 17 Mar 2008 15:07:46 GMT Ralf Corsepius [a967c73] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd6.1 Sat, 15 Mar 2008 05:30:59 GMT Ralf Corsepius [3438bc3a] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd6.0. Fri, 14 Mar 2008 10:11:14 GMT Ralf Corsepius [847c7e3] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd5.2 Sat, 22 Dec 2007 00:29:06 GMT Ralf Corsepius [2bf27202] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20071221.diff (modified) Regenerate. Fri, 21 Dec 2007 11:31:44 GMT Ralf Corsepius [7d25764] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) newlib-1.15.0-rtems4.8-20071221.diff Fri, 21 Dec 2007 11:31:06 GMT Ralf Corsepius [faa0950] * contrib/crossrpms/gcc/build.add (modified) Apply %{?_smp_mflags}. Fri, 21 Dec 2007 11:30:36 GMT Ralf Corsepius [f5cc928] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20071221.diff (added) Reflect API changes from newlib-1.16.0 Mon, 17 Dec 2007 07:52:25 GMT Ralf Corsepius [d475f9d] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) Regenerate. Mon, 17 Dec 2007 07:51:52 GMT Ralf Corsepius [e945d6b9] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) Backport from HEAD. Mon, 17 Dec 2007 03:57:46 GMT Ralf Corsepius [50f25ac] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gdb.spec (modified) Sync. Sun, 16 Dec 2007 12:45:35 GMT Ralf Corsepius [ed36c35] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Bump GDB_RPMREL. Sun, 16 Dec 2007 12:45:16 GMT Ralf Corsepius [5dd2ecbb] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) gdb-6.6-rtems4.8-20071216.diff. Sun, 16 Dec 2007 12:38:14 GMT Ralf Corsepius [ce195afa] * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20071216.diff (added) New. Sun, 16 Dec 2007 12:37:49 GMT Ralf Corsepius [bd025cde] * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20071110.diff (deleted) * contrib/crossrpms/patches/gdb-6.7.1-rtems4.8-20071031.diff (deleted) Remove. Sun, 16 Dec 2007 12:35:49 GMT Ralf Corsepius [1ecaae4] * contrib/crossrpms/patches/gdb-6.7.1-rtems4.8-20071216.diff (added) Back port from HEAD. Sun, 16 Dec 2007 12:29:29 GMT Ralf Corsepius [16b5fa31] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/cpukit-prep.add (deleted) * contrib/crossrpms/rtems4.8/cpukit.am (deleted) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/cpukit-sources.add (deleted) Remove cpukit. Sun, 16 Dec 2007 12:18:51 GMT Ralf Corsepius [ae8600f] * contrib/crossrpms/gdb/build.add (modified) Add %{?_smp_mflags}. Tue, 04 Dec 2007 16:24:06 GMT Ralf Corsepius [ccdfdb20] * contrib/crossrpms/configure.ac (modified) Remove tic4x, avr. Tue, 04 Dec 2007 16:23:21 GMT Ralf Corsepius [3753b007] * contrib/crossrpms/rtems4.8/Makefile.am (modified) Remove tic4x, avr from rtems-4-8-branch. Tue, 04 Dec 2007 16:22:31 GMT Ralf Corsepius [29cce4be] * c/src/lib/libbsp/c4x/.cvsignore (deleted) * c/src/lib/libbsp/c4x/ChangeLog (deleted) * c/src/lib/libbsp/c4x/Makefile.am (deleted) * c/src/lib/libbsp/c4x/acinclude.m4 (deleted) * c/src/lib/libbsp/c4x/c4xsim/.cvsignore (deleted) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (deleted) * c/src/lib/libbsp/c4x/c4xsim/Makefile.am (deleted) * c/src/lib/libbsp/c4x/c4xsim/README (deleted) * c/src/lib/libbsp/c4x/c4xsim/bsp_specs (deleted) * c/src/lib/libbsp/c4x/c4xsim/clock/clock.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (deleted) * c/src/lib/libbsp/c4x/c4xsim/console/console.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/console/consolereserveresources.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/console/debugio.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/console/simio.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/include/.cvsignore (deleted) * c/src/lib/libbsp/c4x/c4xsim/include/bsp.h (deleted) * c/src/lib/libbsp/c4x/c4xsim/include/simio.h (deleted) * c/src/lib/libbsp/c4x/c4xsim/include/tm27.h (deleted) * c/src/lib/libbsp/c4x/c4xsim/preinstall.am (deleted) * c/src/lib/libbsp/c4x/c4xsim/start/start.S (deleted) * c/src/lib/libbsp/c4x/c4xsim/startup/bspstart.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/startup/linkcmds (deleted) * c/src/lib/libbsp/c4x/c4xsim/startup/spurious.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/timer/timer.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/.cvsignore (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/Makefile.am (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/runtest.in (deleted) * c/src/lib/libbsp/c4x/configure.ac (deleted) * c/src/lib/libbsp/c4x/shared/bspspuriousinit.c (deleted) * c/src/lib/libbsp/c4x/shared/c3xspurious.c (deleted) * c/src/lib/libbsp/c4x/shared/c4xspurious.c (deleted) * c/src/lib/libbsp/nios2/.cvsignore (deleted) * c/src/lib/libbsp/nios2/ChangeLog (deleted) * c/src/lib/libbsp/nios2/Makefile.am (deleted) * c/src/lib/libbsp/nios2/README (deleted) * c/src/lib/libbsp/nios2/acinclude.m4 (deleted) * c/src/lib/libbsp/nios2/configure.ac (deleted) * c/src/lib/libbsp/nios2/nios2_iss/.cvsignore (deleted) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (deleted) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (deleted) * c/src/lib/libbsp/nios2/nios2_iss/bsp_specs (deleted) * c/src/lib/libbsp/nios2/nios2_iss/clock/clock.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (deleted) * c/src/lib/libbsp/nios2/nios2_iss/console/console.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/include/.cvsignore (deleted) * c/src/lib/libbsp/nios2/nios2_iss/include/bsp.h (deleted) * c/src/lib/libbsp/nios2/nios2_iss/include/coverhd.h (deleted) * c/src/lib/libbsp/nios2/nios2_iss/include/tm27.h (deleted) * c/src/lib/libbsp/nios2/nios2_iss/nios2_iss.ptf (deleted) * c/src/lib/libbsp/nios2/nios2_iss/nios2_iss.sh (deleted) * c/src/lib/libbsp/nios2/nios2_iss/preinstall.am (deleted) * c/src/lib/libbsp/nios2/nios2_iss/shmsupp/addrconv.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/shmsupp/getcfg.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/shmsupp/lock.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/shmsupp/mpisr.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/start/crtnn.s (deleted) * c/src/lib/libbsp/nios2/nios2_iss/start/start.S (deleted) * c/src/lib/libbsp/nios2/nios2_iss/startup/bspclean.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/startup/bspstart.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/startup/linkcmds (deleted) * c/src/lib/libbsp/nios2/nios2_iss/startup/main.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/startup/setvec.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/times (deleted) * contrib/crossrpms/rtems4.8/avr/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/avr/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/tic4x/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (deleted) Remove from rtems-4-8-branch. Fri, 30 Nov 2007 06:02:22 GMT Ralf Corsepius [cf148c7] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) Regnerate. Fri, 30 Nov 2007 06:00:40 GMT Ralf Corsepius [b32338ab] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) GCC_RPMREL = 27. Thu, 29 Nov 2007 17:24:15 GMT Ralf Corsepius [afb21a9] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Upgrade to gcc-4.2.2 Thu, 29 Nov 2007 17:20:26 GMT Ralf Corsepius [eb5b37d] * contrib/crossrpms/patches/gcc-core-4.2.2-rtems4.8-20071127.diff (added) Copy from CVS-HEAD/rtems-4.9 Thu, 29 Nov 2007 13:38:44 GMT Ralf Corsepius [b5273f0] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) gcc-core-4.2.1-rtems4.8-20071129. Thu, 29 Nov 2007 13:37:27 GMT Ralf Corsepius [385451b] * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20071129.diff (added) Backport from CVS-HEAD/rtems-4.9 Thu, 15 Nov 2007 04:38:18 GMT Ralf Corsepius [08988b7] * contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.8-20070216.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.8-20070405.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.8-20070613.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2-20070221-rtems4.8-20070228.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.0-rtems4.8-20070515.diff (deleted) * contrib/crossrpms/patches/gdb-6.5-rtems-20060713.diff (deleted) * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20070306.diff (deleted) * contrib/crossrpms/patches/gdb-6.7-rtems4.8-20071011.diff (deleted) Remove. Wed, 14 Nov 2007 14:37:33 GMT Ralf Corsepius [27de0e70] * contrib/crossrpms/rtems4.8/bfin/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gdb.spec (modified) Update. Wed, 14 Nov 2007 14:35:06 GMT Ralf Corsepius [72c04e8] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060720.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060908.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060909.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070102.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070131.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070201.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.0-20070501-rtems4.8-20070501.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.0-rtems4.8-20070613.diff (deleted) * contrib/crossrpms/patches/gdb-6.5-bfinrtems-20060810a.diff (deleted) Remove. Tue, 13 Nov 2007 15:09:07 GMT Ralf Corsepius [6dba71e] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) backup. Tue, 13 Nov 2007 09:29:15 GMT Ralf Corsepius [02058598] * contrib/crossrpms/gcc/target-gcc.add (modified) Backport from HEAD. Tue, 13 Nov 2007 09:26:55 GMT Ralf Corsepius [be4e5f69] * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) GCC_RPMREL = 14. Tue, 13 Nov 2007 09:26:17 GMT Ralf Corsepius [fc98297] * contrib/crossrpms/patches/gcc-core-3.4.6-rtems4.8-20071111.diff (added) New. Sun, 11 Nov 2007 16:58:15 GMT Ralf Corsepius [425cb26] * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20071111.diff (modified) More makeinfo hacks. Sun, 11 Nov 2007 13:19:55 GMT Ralf Corsepius [484d126] * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20071111.diff (added) New. Sun, 11 Nov 2007 13:19:12 GMT Ralf Corsepius [e55f7f7] * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) Remove gcc-3.4.6. Sun, 11 Nov 2007 13:17:20 GMT Ralf Corsepius [3254133] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Remove gcc-4.2.0. Sun, 11 Nov 2007 13:16:07 GMT Ralf Corsepius [02e1bdb] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Remove gcc-4.0.3. Sun, 11 Nov 2007 13:14:31 GMT Ralf Corsepius [a3459e8] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Remove gcc-4.1.2. Sun, 11 Nov 2007 13:13:51 GMT Ralf Corsepius [501a675a] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Remove gcc-4.1.1. Sun, 11 Nov 2007 13:11:41 GMT Ralf Corsepius [78945895] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) gcc-core-4.2.1-rtems4.8-20071111.diff. Sun, 11 Nov 2007 13:11:05 GMT Ralf Corsepius [4ee3225] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) GCC_RPMREL = 25. Sat, 10 Nov 2007 07:05:17 GMT Ralf Corsepius [cfa08cf] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (modified) Regenerate. Sat, 10 Nov 2007 07:04:57 GMT Ralf Corsepius [2b6a100] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) gdb-6.6-rtems4.8-20071110.diff Sat, 10 Nov 2007 07:03:42 GMT Ralf Corsepius [70a276a] * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20071110.diff (added) New. Sat, 10 Nov 2007 07:02:16 GMT Ralf Corsepius [4256152] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) GDB_RPMREL = 10 Sat, 10 Nov 2007 05:47:54 GMT Ralf Corsepius [116826e7] * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (deleted) Remove (Unused). Sat, 10 Nov 2007 05:46:40 GMT Ralf Corsepius [66a55224] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) Remove gdb-6.5 Sat, 10 Nov 2007 05:43:14 GMT Ralf Corsepius [001c1508] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (modified) Update gdb-6.6 patch. Sun, 04 Nov 2007 09:36:15 GMT Ralf Corsepius [0e95f1e] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (modified) Regenerate. Sun, 04 Nov 2007 09:34:49 GMT Ralf Corsepius [7d1ca2a] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) BINUTILS_RPMREL = 2. Sun, 04 Nov 2007 09:34:31 GMT Ralf Corsepius [6dc54314] * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (modified) binutils-2.18-rtems4.8-20071104.diff. Sun, 04 Nov 2007 09:31:43 GMT Ralf Corsepius [7eb30458] * contrib/crossrpms/patches/binutils-2.18-rtems4.8-20071104.diff (added) New. Thu, 01 Nov 2007 07:47:41 GMT Ralf Corsepius [0e7cee45] * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gdb.spec (modified) Upgrade to gdb-4.7.1 Thu, 01 Nov 2007 07:46:19 GMT Ralf Corsepius [547657c] * contrib/crossrpms/gdb/gdb.add (modified) Remove ref to rtems4.9 Thu, 01 Nov 2007 07:36:50 GMT Ralf Corsepius [6d837a6] * contrib/crossrpms/patches/gdb-6.7.1-rtems4.8-20071031.diff (added) New (from TRUNK). Thu, 01 Nov 2007 07:35:16 GMT Ralf Corsepius [aa26724] * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Sync with trunk Thu, 01 Nov 2007 07:29:05 GMT Ralf Corsepius [21b3f3b1] * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Remove GDB. Fri, 12 Oct 2007 02:39:00 GMT Ralf Corsepius [a38723dd] * contrib/crossrpms/patches/gdb-6.7-rtems4.8-20071011.diff (added) New. Fri, 12 Oct 2007 02:36:58 GMT Ralf Corsepius [2e4aab87] * contrib/crossrpms/patches/gdb-6.4-rtems-20060311.diff (deleted) * contrib/crossrpms/patches/gdb-6.4-rtems-20060712.diff (deleted) * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20070217.diff (deleted) * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20070218.diff (deleted) * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20070222.diff (deleted) * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070202.diff (deleted) * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070208.diff (deleted) Remove. Fri, 28 Sep 2007 07:47:33 GMT Ralf Corsepius [e463596f] * contrib/crossrpms/rtems4.8/arm/.cvsignore (modified) * contrib/crossrpms/rtems4.8/avr/.cvsignore (modified) * contrib/crossrpms/rtems4.8/bfin/.cvsignore (modified) * contrib/crossrpms/rtems4.8/h8300/.cvsignore (modified) * contrib/crossrpms/rtems4.8/i386/.cvsignore (modified) * contrib/crossrpms/rtems4.8/m68k/.cvsignore (modified) * contrib/crossrpms/rtems4.8/mips/.cvsignore (modified) * contrib/crossrpms/rtems4.8/mipstx39/.cvsignore (modified) * contrib/crossrpms/rtems4.8/powerpc/.cvsignore (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sh/.cvsignore (modified) * contrib/crossrpms/rtems4.8/sparc/.cvsignore (modified) * contrib/crossrpms/rtems4.8/tic4x/.cvsignore (modified) Update. Wed, 19 Sep 2007 06:34:26 GMT cvs2git [a24f700] * contrib/crossrpms/cygwin/.cvsignore (deleted) * contrib/crossrpms/cygwin/Makefile.am (deleted) * contrib/crossrpms/cygwin/binutils.am (deleted) * contrib/crossrpms/cygwin/gcc-prep.add (deleted) * contrib/crossrpms/cygwin/gcc.am (deleted) * contrib/crossrpms/cygwin/i686/.cvsignore (deleted) * contrib/crossrpms/cygwin/i686/Makefile.am (deleted) * contrib/crossrpms/cygwin/i686/binutils-sources.add (deleted) * contrib/crossrpms/cygwin/i686/gcc-sources.add (deleted) * contrib/crossrpms/cygwin/i686/libncurses-devel.add (deleted) * contrib/crossrpms/cygwin/i686/libs.add (deleted) * contrib/crossrpms/cygwin/i686/target-libncurses-devel.add (deleted) * contrib/crossrpms/cygwin/i686/target-libs.add (deleted) * contrib/crossrpms/cygwin/i686/target-w32api.add (deleted) * contrib/crossrpms/cygwin/i686/target-zlib.add (deleted) * contrib/crossrpms/cygwin/i686/w32api.add (deleted) * contrib/crossrpms/cygwin/i686/zlib.add (deleted) * contrib/crossrpms/freebsd5.2/.cvsignore (deleted) * contrib/crossrpms/freebsd5.2/Makefile.am (deleted) * contrib/crossrpms/freebsd5.2/binutils.am (deleted) * contrib/crossrpms/freebsd5.2/gcc-prep.add (deleted) * contrib/crossrpms/freebsd5.2/gcc.am (deleted) * contrib/crossrpms/freebsd5.2/i586/.cvsignore (deleted) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (deleted) * contrib/crossrpms/freebsd5.2/i586/binutils-sources.add (deleted) * contrib/crossrpms/freebsd5.2/i586/gcc-prep.add (deleted) * contrib/crossrpms/freebsd5.2/i586/gcc-sources.add (deleted) * contrib/crossrpms/freebsd5.2/i586/libs.add (deleted) * contrib/crossrpms/freebsd5.2/i586/target-libs.add (deleted) * contrib/crossrpms/freebsd6.0/.cvsignore (deleted) * contrib/crossrpms/freebsd6.0/Makefile.am (deleted) * contrib/crossrpms/freebsd6.0/binutils.am (deleted) * contrib/crossrpms/freebsd6.0/gcc-prep.add (deleted) * contrib/crossrpms/freebsd6.0/gcc.am (deleted) * contrib/crossrpms/freebsd6.0/i586/.cvsignore (deleted) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (deleted) * contrib/crossrpms/freebsd6.0/i586/binutils-sources.add (deleted) * contrib/crossrpms/freebsd6.0/i586/gcc-sources.add (deleted) * contrib/crossrpms/freebsd6.0/i586/libs.add (deleted) * contrib/crossrpms/freebsd6.0/i586/target-libs.add (deleted) * contrib/crossrpms/freebsd6.1/.cvsignore (deleted) * contrib/crossrpms/freebsd6.1/Makefile.am (deleted) * contrib/crossrpms/freebsd6.1/binutils.am (deleted) * contrib/crossrpms/freebsd6.1/gcc-prep.add (deleted) * contrib/crossrpms/freebsd6.1/gcc.am (deleted) * contrib/crossrpms/freebsd6.1/i586/.cvsignore (deleted) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (deleted) * contrib/crossrpms/freebsd6.1/i586/binutils-sources.add (deleted) * contrib/crossrpms/freebsd6.1/i586/gcc-sources.add (deleted) * contrib/crossrpms/freebsd6.1/i586/libs.add (deleted) * contrib/crossrpms/freebsd6.1/i586/target-libs.add (deleted) * contrib/crossrpms/freebsd6.2/.cvsignore (deleted) * contrib/crossrpms/freebsd6.2/Makefile.am (deleted) * contrib/crossrpms/freebsd6.2/binutils.am (deleted) * contrib/crossrpms/freebsd6.2/gcc-prep.add (deleted) * contrib/crossrpms/freebsd6.2/gcc.am (deleted) * contrib/crossrpms/freebsd6.2/i586/.cvsignore (deleted) * contrib/crossrpms/freebsd6.2/i586/Makefile.am (deleted) * contrib/crossrpms/freebsd6.2/i586/binutils-sources.add (deleted) * contrib/crossrpms/freebsd6.2/i586/gcc-sources.add (deleted) * contrib/crossrpms/freebsd6.2/i586/libs.add (deleted) * contrib/crossrpms/freebsd6.2/i586/target-libs.add (deleted) * contrib/crossrpms/mingw32/.cvsignore (deleted) * contrib/crossrpms/mingw32/Makefile.am (deleted) * contrib/crossrpms/mingw32/binutils.am (deleted) * contrib/crossrpms/mingw32/gcc-prep.add (deleted) * contrib/crossrpms/mingw32/gcc.am (deleted) * contrib/crossrpms/mingw32/i686/.cvsignore (deleted) * contrib/crossrpms/mingw32/i686/Makefile.am (deleted) * contrib/crossrpms/mingw32/i686/binutils-sources.add (deleted) * contrib/crossrpms/mingw32/i686/gcc-sources.add (deleted) * contrib/crossrpms/mingw32/i686/libs.add (deleted) * contrib/crossrpms/mingw32/i686/target-libs.add (deleted) * contrib/crossrpms/mingw32/i686/target-w32api.add (deleted) * contrib/crossrpms/mingw32/i686/w32api.add (deleted) * contrib/crossrpms/solaris2.7/.cvsignore (deleted) * contrib/crossrpms/solaris2.7/Makefile.am (deleted) * contrib/crossrpms/solaris2.7/binutils.am (deleted) * contrib/crossrpms/solaris2.7/gcc-prep.add (deleted) * contrib/crossrpms/solaris2.7/gcc.am (deleted) * contrib/crossrpms/solaris2.7/sparc/.cvsignore (deleted) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (deleted) * contrib/crossrpms/solaris2.7/sparc/binutils-sources.add (deleted) * contrib/crossrpms/solaris2.7/sparc/gcc-sources.add (deleted) * contrib/crossrpms/solaris2.7/sparc/libs.add (deleted) * contrib/crossrpms/solaris2.7/sparc/target-libs.add (deleted) * cpukit/zlib/doc/rfc1950.txt (deleted) * cpukit/zlib/doc/rfc1951.txt (deleted) * cpukit/zlib/doc/rfc1952.txt (deleted) * cpukit/zlib/doc/txtvsbin.txt (deleted) * cpukit/zlib/examples/zran.c (deleted) * cpukit/zlib/old/as400/bndsrc (deleted) * cpukit/zlib/old/as400/compile.clp (deleted) * cpukit/zlib/old/as400/readme.txt (deleted) * cpukit/zlib/old/visualc6/README.txt (deleted) * cpukit/zlib/old/visualc6/example.dsp (deleted) * cpukit/zlib/old/visualc6/minigzip.dsp (deleted) * cpukit/zlib/old/visualc6/zlib.dsw (deleted) * cpukit/zlib/zlib.pc.in (deleted) * cpukit/zlib/zlib2ansi (deleted) This commit was manufactured by cvs2svn to create branch ... Thu, 13 Sep 2007 01:12:50 GMT Ralf Corsepius [98e398cb] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070912.diff (modified) Add missing #endif in powerpc/setjmp.S Wed, 12 Sep 2007 19:42:12 GMT Ralf Corsepius [8393f3a] * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) newlib-1.15.0-rtems4.8-20070912.diff. Wed, 12 Sep 2007 19:41:58 GMT Ralf Corsepius [18960f10] * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) GCC_RPMREL = 24.
