# # ChangeLog for contrib/crossrpms in rtems # # Generated by Trac 1.2.1.dev0 # 05/17/24 14:13:33 Wed, 23 Mar 2011 12:19:51 GMT Ralf Corsepius [298b54bb] * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) gcc-core-4.6.0-RC-20110321-rtems4.11-20110323.diff Wed, 23 Mar 2011 12:19:03 GMT Ralf Corsepius [86ca98ae] * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Wed, 23 Mar 2011 12:08:39 GMT Ralf Corsepius [0a36b442] * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Tue, 22 Mar 2011 11:00:30 GMT Ralf Corsepius [963d052] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Tue, 22 Mar 2011 10:57:57 GMT Ralf Corsepius [8024bba] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Update to gcc-4.6.0-RC-20110321. Tue, 22 Mar 2011 10:52:08 GMT Ralf Corsepius [6397b9f4] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) Preps for gcc-4.6.0. Tue, 22 Mar 2011 07:21:59 GMT Ralf Corsepius [5f22726c] * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) Preps for gcc-4.6.0. Mon, 21 Mar 2011 11:17:41 GMT Ralf Corsepius [48d5f82] * contrib/crossrpms/freebsd8.1/.cvsignore (deleted) * contrib/crossrpms/freebsd8.1/Makefile.am (deleted) * contrib/crossrpms/freebsd8.1/binutils.am (deleted) * contrib/crossrpms/freebsd8.1/gcc-prep.add (deleted) * contrib/crossrpms/freebsd8.1/gcc.am (deleted) * contrib/crossrpms/freebsd8.1/i586/.cvsignore (deleted) * contrib/crossrpms/freebsd8.1/i586/Makefile.am (deleted) * contrib/crossrpms/freebsd8.1/i586/binutils-sources.add (deleted) * contrib/crossrpms/freebsd8.1/i586/gcc-sources.add (deleted) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-binutils.spec (deleted) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-gcc.spec (deleted) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-libs.spec (deleted) * contrib/crossrpms/freebsd8.1/i586/libs.add (deleted) * contrib/crossrpms/freebsd8.1/i586/target-libs.add (deleted) * contrib/crossrpms/freebsd8.1/libs.am (deleted) * contrib/crossrpms/freebsd8.1/x86_64/.cvsignore (deleted) * contrib/crossrpms/freebsd8.1/x86_64/Makefile.am (deleted) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-binutils.spec (deleted) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-gcc.spec (deleted) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-libs.spec (deleted) * contrib/crossrpms/freebsd8.1/x86_64/binutils-sources.add (deleted) * contrib/crossrpms/freebsd8.1/x86_64/gcc-sources.add (deleted) * contrib/crossrpms/freebsd8.1/x86_64/libs.add (deleted) * contrib/crossrpms/freebsd8.1/x86_64/target-libs.add (deleted) Abandon. Mon, 21 Mar 2011 11:17:26 GMT Ralf Corsepius [f399887] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd8.1 Mon, 21 Mar 2011 08:48:28 GMT Ralf Corsepius [0196e8a] * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-gcc.spec (modified) * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-gcc.spec (modified) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-gcc.spec (modified) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-gcc.spec (modified) * contrib/crossrpms/freebsd8.2/i586/i586-pc-freebsd8.2-gcc.spec (modified) * contrib/crossrpms/freebsd8.2/x86_64/amd64-pc-freebsd8.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/amd64-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.1/i386/i386-pc-netbsdelf5.1-gcc.spec (modified) * contrib/crossrpms/netbsd5.1/x86_64/amd64-pc-netbsdelf5.1-gcc.spec (modified) Regenerate. Mon, 21 Mar 2011 08:47:08 GMT Ralf Corsepius [e3646a7] * contrib/crossrpms/freebsd6.4/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.3/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.1/x86_64/Makefile.am (modified) * contrib/crossrpms/freebsd8.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.2/x86_64/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/Makefile.am (modified) * contrib/crossrpms/netbsd5.1/i386/Makefile.am (modified) * contrib/crossrpms/netbsd5.1/x86_64/Makefile.am (modified) GCC_VERS = 4.5.2. GCC_RPMREL = 0.20110321.1. Mon, 21 Mar 2011 08:43:54 GMT Ralf Corsepius [4e115770] * contrib/crossrpms/freebsd6.4/i586/gcc-sources.add (modified) * contrib/crossrpms/freebsd7.3/i586/gcc-sources.add (modified) * contrib/crossrpms/freebsd8.1/i586/gcc-sources.add (modified) * contrib/crossrpms/freebsd8.1/x86_64/gcc-sources.add (modified) * contrib/crossrpms/freebsd8.2/i586/gcc-sources.add (modified) * contrib/crossrpms/freebsd8.2/x86_64/gcc-sources.add (modified) * contrib/crossrpms/netbsd5.0.2/i386/gcc-sources.add (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/gcc-sources.add (modified) * contrib/crossrpms/netbsd5.1/i386/gcc-sources.add (modified) * contrib/crossrpms/netbsd5.1/x86_64/gcc-sources.add (modified) Preps for gcc-4.5.2. Sun, 20 Mar 2011 17:11:53 GMT Ralf Corsepius [c3a42e17] * contrib/crossrpms/netbsd5.1/.cvsignore (added) * contrib/crossrpms/netbsd5.1/Makefile.am (added) * contrib/crossrpms/netbsd5.1/binutils.am (added) * contrib/crossrpms/netbsd5.1/gcc-prep.add (added) * contrib/crossrpms/netbsd5.1/gcc.am (added) * contrib/crossrpms/netbsd5.1/i386/.cvsignore (added) * contrib/crossrpms/netbsd5.1/i386/Makefile.am (added) * contrib/crossrpms/netbsd5.1/i386/binutils-sources.add (added) * contrib/crossrpms/netbsd5.1/i386/gcc-sources.add (added) * contrib/crossrpms/netbsd5.1/i386/i386-pc-netbsdelf5.1-binutils.spec (added) * contrib/crossrpms/netbsd5.1/i386/i386-pc-netbsdelf5.1-gcc.spec (added) * contrib/crossrpms/netbsd5.1/i386/i386-pc-netbsdelf5.1-libs.spec (added) * contrib/crossrpms/netbsd5.1/i386/libs.add (added) * contrib/crossrpms/netbsd5.1/i386/target-libs.add (added) * contrib/crossrpms/netbsd5.1/libs.am (added) * contrib/crossrpms/netbsd5.1/x86_64/.cvsignore (added) * contrib/crossrpms/netbsd5.1/x86_64/Makefile.am (added) * contrib/crossrpms/netbsd5.1/x86_64/amd64-pc-netbsdelf5.1-binutils.spec (added) * contrib/crossrpms/netbsd5.1/x86_64/amd64-pc-netbsdelf5.1-gcc.spec (added) * contrib/crossrpms/netbsd5.1/x86_64/amd64-pc-netbsdelf5.1-libs.spec (added) * contrib/crossrpms/netbsd5.1/x86_64/binutils-sources.add (added) * contrib/crossrpms/netbsd5.1/x86_64/gcc-sources.add (added) * contrib/crossrpms/netbsd5.1/x86_64/libs.add (added) * contrib/crossrpms/netbsd5.1/x86_64/target-libs.add (added) New. Sun, 20 Mar 2011 17:09:47 GMT Ralf Corsepius [3cf3d467] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add netbsd5.1. Sun, 20 Mar 2011 07:34:21 GMT Ralf Corsepius [ce18152c] * contrib/crossrpms/configure.ac (modified) Eliminate RPM_OS. Sun, 20 Mar 2011 06:52:50 GMT Ralf Corsepius [787cf0df] * contrib/crossrpms/.cvsignore (modified) Add config.status, config.sub, config.log. Thu, 10 Mar 2011 07:03:20 GMT Ralf Corsepius [6c16501] * contrib/crossrpms/freebsd8.2/x86_64/amd64-pc-freebsd8.2-gcc.spec (modified) Regenerate. Thu, 10 Mar 2011 07:03:09 GMT Ralf Corsepius [855c6b0] * contrib/crossrpms/freebsd8.2/Makefile.am (modified) Rename amd64 into x86_64. Thu, 10 Mar 2011 06:56:14 GMT Ralf Corsepius [31396c12] * contrib/crossrpms/configure.ac (modified) Rename freebsd8.2/amd64/ into freebsd8.2/x86_64/. Thu, 10 Mar 2011 06:52:30 GMT Ralf Corsepius [8aaceef] * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/Makefile.am (modified) Remove bogus comment. Thu, 10 Mar 2011 05:22:06 GMT Ralf Corsepius [166bb376] * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/amd64-pc-netbsdelf5.0.2-gcc.spec (modified) Regenerate. Thu, 10 Mar 2011 05:21:33 GMT Ralf Corsepius [73f7208] * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/Makefile.am (modified) Bump GCC_RPMREL. Thu, 10 Mar 2011 04:39:36 GMT Ralf Corsepius [f9fb5ba2] * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-gcc.spec (modified) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-gcc.spec (modified) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-gcc.spec (modified) * contrib/crossrpms/freebsd8.2/i586/i586-pc-freebsd8.2-gcc.spec (modified) Regenerate. Thu, 10 Mar 2011 04:39:06 GMT Ralf Corsepius [dd81f4b] * contrib/crossrpms/freebsd7.3/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.1/x86_64/Makefile.am (modified) * contrib/crossrpms/freebsd8.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.2/x86_64/Makefile.am (modified) Bump GCC_RPMREL. Thu, 10 Mar 2011 04:37:36 GMT Ralf Corsepius [6a61aefe] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd8.0. Thu, 10 Mar 2011 04:36:25 GMT Ralf Corsepius [b15cd01e] * contrib/crossrpms/freebsd8.0/.cvsignore (deleted) * contrib/crossrpms/freebsd8.0/Makefile.am (deleted) * contrib/crossrpms/freebsd8.0/binutils.am (deleted) * contrib/crossrpms/freebsd8.0/gcc-prep.add (deleted) * contrib/crossrpms/freebsd8.0/gcc.am (deleted) * contrib/crossrpms/freebsd8.0/i586/.cvsignore (deleted) * contrib/crossrpms/freebsd8.0/i586/Makefile.am (deleted) * contrib/crossrpms/freebsd8.0/i586/binutils-sources.add (deleted) * contrib/crossrpms/freebsd8.0/i586/gcc-sources.add (deleted) * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-binutils.spec (deleted) * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-gcc.spec (deleted) * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-libs.spec (deleted) * contrib/crossrpms/freebsd8.0/i586/libs.add (deleted) * contrib/crossrpms/freebsd8.0/i586/target-libs.add (deleted) * contrib/crossrpms/freebsd8.0/libs.am (deleted) * contrib/crossrpms/freebsd8.0/x86_64/.cvsignore (deleted) * contrib/crossrpms/freebsd8.0/x86_64/Makefile.am (deleted) * contrib/crossrpms/freebsd8.0/x86_64/amd64-pc-freebsd8.0-binutils.spec (deleted) * contrib/crossrpms/freebsd8.0/x86_64/amd64-pc-freebsd8.0-gcc.spec (deleted) * contrib/crossrpms/freebsd8.0/x86_64/amd64-pc-freebsd8.0-libs.spec (deleted) * contrib/crossrpms/freebsd8.0/x86_64/binutils-sources.add (deleted) * contrib/crossrpms/freebsd8.0/x86_64/gcc-sources.add (deleted) * contrib/crossrpms/freebsd8.0/x86_64/libs.add (deleted) * contrib/crossrpms/freebsd8.0/x86_64/target-libs.add (deleted) Abandon. Thu, 10 Mar 2011 04:30:41 GMT Ralf Corsepius [75c3414] * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-gcc.spec (modified) * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-gcc.spec (modified) Regenerate. Thu, 10 Mar 2011 04:30:29 GMT Ralf Corsepius [aaeaea4] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd6.4/i586/Makefile.am (modified) Bump GCC_RPMREL. Thu, 10 Mar 2011 04:20:14 GMT Ralf Corsepius [c64306b] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Thu, 10 Mar 2011 04:19:19 GMT Ralf Corsepius [e8dcdec0] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Thu, 10 Mar 2011 03:42:57 GMT Ralf Corsepius [514ecebb] * contrib/crossrpms/gcc/gccnewlib.add (modified) Add suse11_4. Mon, 28 Feb 2011 08:54:16 GMT Ralf Corsepius [11fe00d5] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add freebsd8.2 Sun, 27 Feb 2011 22:01:39 GMT Ralf Corsepius [c7eec17f] * contrib/crossrpms/freebsd8.2/.cvsignore (added) * contrib/crossrpms/freebsd8.2/Makefile.am (added) * contrib/crossrpms/freebsd8.2/binutils.am (added) * contrib/crossrpms/freebsd8.2/gcc-prep.add (added) * contrib/crossrpms/freebsd8.2/gcc.am (added) * contrib/crossrpms/freebsd8.2/i586/.cvsignore (added) * contrib/crossrpms/freebsd8.2/i586/Makefile.am (added) * contrib/crossrpms/freebsd8.2/i586/binutils-sources.add (added) * contrib/crossrpms/freebsd8.2/i586/gcc-sources.add (added) * contrib/crossrpms/freebsd8.2/i586/i586-pc-freebsd8.2-binutils.spec (added) * contrib/crossrpms/freebsd8.2/i586/i586-pc-freebsd8.2-gcc.spec (added) * contrib/crossrpms/freebsd8.2/i586/i586-pc-freebsd8.2-libs.spec (added) * contrib/crossrpms/freebsd8.2/i586/libs.add (added) * contrib/crossrpms/freebsd8.2/i586/target-libs.add (added) * contrib/crossrpms/freebsd8.2/libs.am (added) * contrib/crossrpms/freebsd8.2/x86_64/.cvsignore (added) * contrib/crossrpms/freebsd8.2/x86_64/Makefile.am (added) * contrib/crossrpms/freebsd8.2/x86_64/amd64-pc-freebsd8.2-binutils.spec (added) * contrib/crossrpms/freebsd8.2/x86_64/amd64-pc-freebsd8.2-gcc.spec (added) * contrib/crossrpms/freebsd8.2/x86_64/amd64-pc-freebsd8.2-libs.spec (added) * contrib/crossrpms/freebsd8.2/x86_64/binutils-sources.add (added) * contrib/crossrpms/freebsd8.2/x86_64/gcc-sources.add (added) * contrib/crossrpms/freebsd8.2/x86_64/libs.add (added) * contrib/crossrpms/freebsd8.2/x86_64/target-libs.add (added) New. Sun, 20 Feb 2011 21:43:07 GMT Ralf Corsepius [261f36d7] * contrib/crossrpms/patches/gcc-core-4.5.2-rtems4.11-20110220.diff (modified) Add -mcpu=8540/-mfloat-gprs=double multilib. Remove -mcpu=601 multilib. Sun, 20 Feb 2011 05:24:41 GMT Ralf Corsepius [e6fd169] * contrib/crossrpms/patches/gcc-core-4.5.2-rtems4.11-20110220.diff (modified) Add missing brace. Sun, 20 Feb 2011 05:02:56 GMT Ralf Corsepius [e2a90c9] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sun, 20 Feb 2011 05:02:43 GMT Ralf Corsepius [d798b2b] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) Fix typo. Sun, 20 Feb 2011 05:00:59 GMT Ralf Corsepius [e3b8eb8] * contrib/crossrpms/patches/gcc-core-4.5.2-rtems4.11-20110220.diff (added) New. Sun, 20 Feb 2011 05:00:17 GMT Ralf Corsepius [33e73086] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sun, 20 Feb 2011 04:57:01 GMT Ralf Corsepius [f5e39d5] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Sun, 20 Feb 2011 04:56:47 GMT Ralf Corsepius [f71c791c] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) gcc-core-4.5.2-rtems4.11-20110220.diff Sun, 20 Feb 2011 04:17:27 GMT Ralf Corsepius [0be3eb1] * contrib/crossrpms/patches/gcc-g++-4.5.2-rtems4.11-20110131.diff (added) New. Wed, 02 Feb 2011 15:01:43 GMT Ralf Corsepius [8ee3775] * ChangeLog (modified) * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/ChangeLog (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gp32/ChangeLog (modified) * c/src/lib/libbsp/arm/gp32/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/ChangeLog (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/nds/ChangeLog (modified) * c/src/lib/libbsp/arm/nds/configure.ac (modified) * c/src/lib/libbsp/arm/nds/tools/ChangeLog (modified) * c/src/lib/libbsp/arm/nds/tools/configure.ac (modified) * c/src/lib/libbsp/arm/rtl22xx/ChangeLog (modified) * c/src/lib/libbsp/arm/rtl22xx/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/ChangeLog (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/avr/ChangeLog (modified) * c/src/lib/libbsp/avr/avrtest/ChangeLog (modified) * c/src/lib/libbsp/avr/avrtest/configure.ac (modified) * c/src/lib/libbsp/avr/configure.ac (modified) * c/src/lib/libbsp/bfin/ChangeLog (modified) * c/src/lib/libbsp/bfin/bf537Stamp/ChangeLog (modified) * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/lm32/ChangeLog (modified) * c/src/lib/libbsp/lm32/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/ChangeLog (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/milkymist/ChangeLog (modified) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) * c/src/lib/libbsp/m32c/ChangeLog (modified) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/ChangeLog (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m32r/ChangeLog (modified) * c/src/lib/libbsp/m32r/configure.ac (modified) * c/src/lib/libbsp/m32r/m32rsim/ChangeLog (modified) * c/src/lib/libbsp/m32r/m32rsim/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/ChangeLog (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/ChangeLog (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/nios2/ChangeLog (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/beatnik/ChangeLog (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/ChangeLog (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/ChangeLog (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/tools/configure.ac (modified) * c/src/lib/libbsp/sparc64/ChangeLog (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/ChangeLog (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/ChangeLog (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/bfin/ChangeLog (modified) * c/src/lib/libcpu/bfin/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/lm32/ChangeLog (modified) * c/src/lib/libcpu/lm32/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/nios2/ChangeLog (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/lib/libcpu/sparc64/ChangeLog (modified) * c/src/lib/libcpu/sparc64/configure.ac (modified) * c/src/librtems++/ChangeLog (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) * contrib/rtemsrpms/ChangeLog (modified) * contrib/rtemsrpms/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * doc/ChangeLog (modified) * doc/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtmtests/ChangeLog (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/ChangeLog (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/ChangeLog (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) * tools/schedsim/ChangeLog (modified) * tools/schedsim/configure.ac (modified) 2011-02-02 Ralf Corsépius * ... Mon, 31 Jan 2011 12:11:12 GMT Ralf Corsepius [f95073ab] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) Add gcc-g++-4.5.2-rtems4.11-20110131.diff. Sat, 29 Jan 2011 06:58:27 GMT Ralf Corsepius [511a00e2] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sat, 29 Jan 2011 06:58:03 GMT Ralf Corsepius [7a49363] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Sat, 29 Jan 2011 06:51:13 GMT Ralf Corsepius [33636498] * contrib/crossrpms/gcc/gccnewlib.add (modified) BR: cloog-ppl-devel on f15. Sat, 29 Jan 2011 05:59:41 GMT Ralf Corsepius [a235e60] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-w32api.spec (modified) Update to w32api-3.15-1. Sat, 29 Jan 2011 05:41:07 GMT Ralf Corsepius [117bf41] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-libs.spec (modified) Update to cygwin-1.7.7-1. Sat, 29 Jan 2011 05:39:50 GMT Ralf Corsepius [5bb2870b] * contrib/crossrpms/gcc/gccnewlib.add (modified) Abandon fedora-11, fedora-12, openSUSE-11.0, openSUSE-11.0. Sun, 09 Jan 2011 08:17:42 GMT Ralf Corsepius [7f206d17] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sun, 09 Jan 2011 08:16:43 GMT Ralf Corsepius [d742765] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.19.0-rtems4.11-20110109.diff Sun, 09 Jan 2011 08:15:29 GMT Ralf Corsepius [9fbe66f3] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Sun, 09 Jan 2011 08:14:28 GMT Ralf Corsepius [3877306] * contrib/crossrpms/patches/newlib-1.19.0-rtems4.11-20110109.diff (added) New (Add 32bit double tgamma fixes). Fri, 07 Jan 2011 17:11:08 GMT Ralf Corsepius [609ec1b2] * contrib/crossrpms/patches/newlib-1.19.0-rtems4.11-20110107.diff (modified) Update. Fri, 07 Jan 2011 08:19:39 GMT Ralf Corsepius [ac18636] * contrib/crossrpms/patches/newlib-1.19.0-rtems4.11-20110107.diff (added) New. Fri, 07 Jan 2011 08:19:12 GMT Ralf Corsepius [2d0e0c9] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Fri, 07 Jan 2011 08:18:09 GMT Ralf Corsepius [b16b20d9] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.19.0-rtems4.11-20110107.diff. Abandon gcc-4.5.0, gcc-4.5.1. Fri, 07 Jan 2011 08:16:52 GMT Ralf Corsepius [358b757e] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. NEWLIB_VERS = 1.19.0. Reset NEWLIB_RPMREL. Fri, 07 Jan 2011 08:02:39 GMT Ralf Corsepius [2ff81e9d] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-binutils.spec (modified) Regenerate. Fri, 07 Jan 2011 08:01:01 GMT Ralf Corsepius [7d6fa95] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump BINUTILS_RPMREL = 2. Fri, 07 Jan 2011 07:59:00 GMT Ralf Corsepius [ba696c19] * contrib/crossrpms/rtems4.11/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/binutils-sources.add (modified) Add binutils-2.21-rtems4.11-20110107.diff. Fri, 07 Jan 2011 07:58:01 GMT Ralf Corsepius [9f1ab235] * contrib/crossrpms/patches/binutils-2.21-rtems4.11-20110107.diff (added) New. Fri, 07 Jan 2011 07:57:37 GMT Ralf Corsepius [ac948cd] * contrib/crossrpms/patches/binutils-2.20.1-rtems4.11-20100521.diff (deleted) * contrib/crossrpms/patches/binutils-2.20.1-rtems4.11-20100826.diff (deleted) * contrib/crossrpms/patches/binutils-2.20.90-rtems4.11-20101109.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.5.0-rtems4.11-20100609.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.5.1-rtems4.11-20100726.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.5.1-rtems4.11-20100818.diff (deleted) Housekeeping. Sun, 26 Dec 2010 17:08:45 GMT Ralf Corsepius [9f82dfb] * contrib/crossrpms/patches/autoconf-2.66-611661.diff (deleted) Remove. Fri, 17 Dec 2010 15:24:02 GMT Ralf Corsepius [e715ecbd] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Fri, 17 Dec 2010 15:22:35 GMT Ralf Corsepius [00ae84c0] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) gcc-4.5.2 (final). Fri, 17 Dec 2010 15:18:04 GMT Ralf Corsepius [42462e8d] * contrib/crossrpms/patches/gcc-core-4.5.2-rtems4.11-20101216.diff (added) Rebase patch for gcc-4.5.2. Thu, 16 Dec 2010 03:52:16 GMT Ralf Corsepius [5d2b63c] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-zlib.spec (modified) Update to zlib-1.2.5-1. Sat, 11 Dec 2010 12:58:31 GMT Ralf Corsepius [8e03eb3] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sat, 11 Dec 2010 12:57:50 GMT Ralf Corsepius [08146883] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) gcc-4.5.2 Sat, 11 Dec 2010 12:56:41 GMT Ralf Corsepius [fd623d5] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) GCC_VERS = 4.5.2 Sat, 11 Dec 2010 09:14:09 GMT Ralf Corsepius [814dd292] * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-binutils.spec (modified) * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-gcc.spec (modified) * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-binutils.spec (modified) * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-gcc.spec (modified) * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-binutils.spec (modified) * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-gcc.spec (modified) * contrib/crossrpms/freebsd8.0/x86_64/amd64-pc-freebsd8.0-binutils.spec (modified) * contrib/crossrpms/freebsd8.0/x86_64/amd64-pc-freebsd8.0-gcc.spec (modified) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-binutils.spec (modified) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-gcc.spec (modified) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-binutils.spec (modified) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-binutils.spec (modified) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/amd64-pc-netbsdelf5.0.2-binutils.spec (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/amd64-pc-netbsdelf5.0.2-gcc.spec (modified) Regenerate. Sat, 11 Dec 2010 09:12:01 GMT Ralf Corsepius [812a9bd] * contrib/crossrpms/freebsd6.4/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.3/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.0/x86_64/Makefile.am (modified) * contrib/crossrpms/freebsd8.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.1/x86_64/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/Makefile.am (modified) Binutils-2.21. BINUTILS_RPMREL = 0.20101211.0. GCC_RPMREL = ... Sat, 11 Dec 2010 02:15:39 GMT Ralf Corsepius [8d8de6c2] * contrib/crossrpms/gcc/gccnewlib.add (modified) Add fedora 15. Remove fedora 12. Thu, 09 Dec 2010 10:02:22 GMT Ralf Corsepius [7831277] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-binutils.spec (modified) binutils-2.21. Fri, 26 Nov 2010 09:00:31 GMT Ralf Corsepius [c64a033] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Fri, 26 Nov 2010 08:59:36 GMT Ralf Corsepius [782145ed] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20101126.diff Fri, 26 Nov 2010 08:59:00 GMT Ralf Corsepius [f41c4c2] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Fri, 26 Nov 2010 08:58:16 GMT Ralf Corsepius [38d6dcfe] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20101126.diff (added) New. Tue, 09 Nov 2010 14:22:14 GMT Ralf Corsepius [2c9b61f] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-binutils.spec (modified) Regenerate. Tue, 09 Nov 2010 14:21:04 GMT Ralf Corsepius [d22fa9e] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/binutils-sources.add (modified) binutils-2.20.90 Tue, 09 Nov 2010 14:19:51 GMT Ralf Corsepius [91234a4] * contrib/crossrpms/patches/binutils-2.20.90-rtems4.11-20101109.diff (added) New. Rebase patch against binutils-2.20.90. Sat, 06 Nov 2010 06:48:07 GMT Ralf Corsepius [b7e0c21] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20100423.diff (deleted) * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20100617.diff (deleted) * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20100708.diff (deleted) * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20100804.diff (deleted) * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20100810.diff (deleted) * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20100825.diff (deleted) * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20101004.diff (deleted) * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20101006.diff (deleted) Housekeeping. Thu, 14 Oct 2010 15:12:12 GMT Ralf Corsepius [5f3ebd2] * contrib/crossrpms/autotools/rtems-4.11-autoconf.spec (modified) Regenerate. Thu, 14 Oct 2010 15:11:48 GMT Ralf Corsepius [8ef2d0f1] * contrib/crossrpms/autotools/autoconf.add (modified) Abandon autoconf < 2.68. Exclude test 199. Thu, 14 Oct 2010 15:10:53 GMT Ralf Corsepius [02e9f5f] * contrib/crossrpms/autotools/autoconf-sources.add (modified) Use xz-compressed tarball except on el5. Abandon autoconf < 2.68. Thu, 14 Oct 2010 14:57:52 GMT Ralf Corsepius [e469c17] * contrib/crossrpms/autotools/Makefile.am (modified) Bump AUTOCONF_RPMREL. Sat, 09 Oct 2010 06:51:17 GMT Ralf Corsepius [bc0b351] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sat, 09 Oct 2010 06:50:25 GMT Ralf Corsepius [1fcd11ea] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20101009.diff Sat, 09 Oct 2010 06:50:03 GMT Ralf Corsepius [76c0d6d6] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Sat, 09 Oct 2010 06:49:05 GMT Ralf Corsepius [5fd4e689] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20101009.diff (added) New. Fri, 08 Oct 2010 14:26:06 GMT Ralf Corsepius [72ea1c2f] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Fri, 08 Oct 2010 14:25:29 GMT Ralf Corsepius [b94bb03e] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20101008.diff. Fri, 08 Oct 2010 14:24:56 GMT Ralf Corsepius [c6e8ae8d] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Fri, 08 Oct 2010 13:24:22 GMT Ralf Corsepius [34fb242d] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20101008.diff (added) Add upstream newlib's complex math. Wed, 06 Oct 2010 05:32:23 GMT Ralf Corsepius [df24385e] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Wed, 06 Oct 2010 05:31:36 GMT Ralf Corsepius [c2f7c6d] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Wed, 06 Oct 2010 05:31:09 GMT Ralf Corsepius [78c0766] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20101006.diff. Wed, 06 Oct 2010 05:30:16 GMT Ralf Corsepius [6ca6057b] * contrib/crossrpms/patches/newlib-1.18.0-rtems4.11-20101006.diff (added) Add patch from http://sourceware.org/ml/newlib/2010/msg00502.html.
