# # ChangeLog for contrib/crossrpms in rtems # # Generated by Trac 1.2.1.dev0 # 03/28/24 17:38:05 Fri, 12 Sep 2008 07:46:06 GMT Ralf Corsepius [0558e58] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) Update. Fri, 12 Sep 2008 07:43:34 GMT Ralf Corsepius [10d4919] * contrib/crossrpms/patches/gdb-6.8-rtems4.9-20080429.diff (deleted) Remove (unused). Fri, 12 Sep 2008 06:44:19 GMT Ralf Corsepius [ebe7bf28] * contrib/crossrpms/patches/gdb-6.8-rtems4.10-20080912.diff (added) Merge-in Joels gdb-6.8-sysv-ipc-1.diff. Thu, 11 Sep 2008 15:57:25 GMT Ralf Corsepius [3e256081] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) GCC_RPMREL = 3 (Rebuild against binutils-2.18.90). Thu, 11 Sep 2008 15:56:31 GMT Ralf Corsepius [518adaf] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) Abandon gcc-4.3.1. Thu, 11 Sep 2008 15:53:10 GMT Ralf Corsepius [6176ff0] * contrib/crossrpms/patches/binutils-2.18-rtems4.9-20080211.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.3.1-rtems4.9-20080628.diff (deleted) Remove (unused). Thu, 11 Sep 2008 12:00:46 GMT Ralf Corsepius [04e8c69] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Upgrade to binutils-2.18.90. Wed, 10 Sep 2008 20:15:26 GMT Ralf Corsepius [03a85d32] * contrib/crossrpms/patches/gcc-core-4.3.2-rtems4.9-20080828.diff (deleted) * contrib/crossrpms/patches/newlib-1.16.0-rtems4.9-20080430.diff (deleted) * contrib/crossrpms/patches/newlib-1.16.0-rtems4.9-20080827.diff (deleted) Remove. Wed, 10 Sep 2008 20:13:03 GMT Ralf Corsepius [93e1140] * contrib/crossrpms/autotools/Makefile.am (modified) Upgrade autoconf to 2.63. Wed, 10 Sep 2008 20:12:00 GMT Ralf Corsepius [64c5bec5] * contrib/crossrpms/configure.ac (modified) Bump RTEMS_API to 4.10. Wed, 10 Sep 2008 20:09:27 GMT Ralf Corsepius [44c2d06d] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Remove freebsd6.2, freebsd6.3, rtems4.9. Wed, 10 Sep 2008 20:08:31 GMT Ralf Corsepius [9d0c693] * contrib/crossrpms/freebsd6.2/.cvsignore (deleted) * contrib/crossrpms/freebsd6.2/Makefile.am (deleted) * contrib/crossrpms/freebsd6.2/binutils.am (deleted) * contrib/crossrpms/freebsd6.2/gcc-prep.add (deleted) * contrib/crossrpms/freebsd6.2/gcc.am (deleted) * contrib/crossrpms/freebsd6.2/i586/.cvsignore (deleted) * contrib/crossrpms/freebsd6.2/i586/Makefile.am (deleted) * contrib/crossrpms/freebsd6.2/i586/binutils-sources.add (deleted) * contrib/crossrpms/freebsd6.2/i586/gcc-sources.add (deleted) * contrib/crossrpms/freebsd6.2/i586/libs.add (deleted) * contrib/crossrpms/freebsd6.2/i586/target-libs.add (deleted) * contrib/crossrpms/freebsd6.3/.cvsignore (deleted) * contrib/crossrpms/freebsd6.3/Makefile.am (deleted) * contrib/crossrpms/freebsd6.3/binutils.am (deleted) * contrib/crossrpms/freebsd6.3/gcc-prep.add (deleted) * contrib/crossrpms/freebsd6.3/gcc.am (deleted) * contrib/crossrpms/freebsd6.3/i586/.cvsignore (deleted) * contrib/crossrpms/freebsd6.3/i586/Makefile.am (deleted) * contrib/crossrpms/freebsd6.3/i586/binutils-sources.add (deleted) * contrib/crossrpms/freebsd6.3/i586/gcc-sources.add (deleted) * contrib/crossrpms/freebsd6.3/i586/libs.add (deleted) * contrib/crossrpms/freebsd6.3/i586/target-libs.add (deleted) * contrib/crossrpms/rtems4.9/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/arm/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/arm/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.9/arm/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (deleted) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (deleted) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (deleted) * contrib/crossrpms/rtems4.9/avr/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/avr/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.9/avr/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (deleted) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (deleted) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (deleted) * contrib/crossrpms/rtems4.9/bfin/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.9/bfin/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.9/bfin/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (deleted) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (deleted) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (deleted) * contrib/crossrpms/rtems4.9/binutils.am (deleted) * contrib/crossrpms/rtems4.9/cpukit-prep.add (deleted) * contrib/crossrpms/rtems4.9/cpukit.am (deleted) * contrib/crossrpms/rtems4.9/gcc-prep.add (deleted) * contrib/crossrpms/rtems4.9/gcc.am (deleted) * contrib/crossrpms/rtems4.9/gdb.am (deleted) * contrib/crossrpms/rtems4.9/h8300/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.9/h8300/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (deleted) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (deleted) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (deleted) * contrib/crossrpms/rtems4.9/i386/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/i386/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.9/i386/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (deleted) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (deleted) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (deleted) * contrib/crossrpms/rtems4.9/m68k/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.9/m68k/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (deleted) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (deleted) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (deleted) * contrib/crossrpms/rtems4.9/mips/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/mips/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.9/mips/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (deleted) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (deleted) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (deleted) * contrib/crossrpms/rtems4.9/mipstx39/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (deleted) * contrib/crossrpms/rtems4.9/powerpc/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.9/powerpc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (deleted) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (deleted) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (deleted) * contrib/crossrpms/rtems4.9/sh/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/sh/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.9/sh/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (deleted) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (deleted) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (deleted) * contrib/crossrpms/rtems4.9/sparc/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.9/sparc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (deleted) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (deleted) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (deleted) Remove. Mon, 08 Sep 2008 10:04:49 GMT Ralf Corsepius [2528c92] * contrib/crossrpms/gcc/build.add (modified) Add --enable-newlib-io-c99-formats. Wed, 03 Sep 2008 22:48:11 GMT Ralf Corsepius [9589c665] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Regenerate. Wed, 03 Sep 2008 22:39:16 GMT Ralf Corsepius [d043ebc2] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Sync with rtems-4.10. Wed, 03 Sep 2008 22:36:35 GMT Ralf Corsepius [3f01023] * contrib/crossrpms/patches/gcc-core-4.3.2-rtems4.9-20080828.diff (added) New. Wed, 03 Sep 2008 09:29:30 GMT Ralf Corsepius [d5982b4] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070804.diff (deleted) Remove. Thu, 28 Aug 2008 19:54:29 GMT Ralf Corsepius [d8a213b2] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Thu, 28 Aug 2008 19:53:37 GMT Ralf Corsepius [e90124e] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Thu, 28 Aug 2008 14:13:55 GMT Ralf Corsepius [183e5cf] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Regenerate. Thu, 28 Aug 2008 14:12:42 GMT Ralf Corsepius [c9ef27b] * contrib/crossrpms/Makefile.am (modified) Add rtems4.10. Thu, 28 Aug 2008 14:11:48 GMT Ralf Corsepius [68e6a18d] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump BINUTILS_RPMREL. Thu, 28 Aug 2008 14:08:37 GMT Ralf Corsepius [2fb65fbf] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) gcc-4.3.2 Thu, 28 Aug 2008 14:07:19 GMT Ralf Corsepius [d5c49aa3] * contrib/crossrpms/patches/gcc-core-4.3.2-rtems4.10-20080828.diff (added) New. Thu, 28 Aug 2008 01:14:03 GMT Ralf Corsepius [882a12a] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) Use URLs for patches. Wed, 27 Aug 2008 09:42:00 GMT Ralf Corsepius [55315135] * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (modified) Use URLs for patches. Wed, 27 Aug 2008 09:33:58 GMT Ralf Corsepius [aef162f] * contrib/crossrpms/patches/gcc-core-4.2.3-rtems4.9-20080205.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.4-rtems4.9-20080526.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.3.0-rtems4.9-20080501.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.3.1-rtems4.9-20080609.diff (deleted) Remove (Obsolete). Wed, 27 Aug 2008 09:31:37 GMT Ralf Corsepius [65c3aaf4] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) Use URLs for patches. Wed, 27 Aug 2008 09:30:57 GMT Ralf Corsepius [8371640] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Abandon gcc-4.3.0. Use URLs for patches. ... Wed, 27 Aug 2008 07:52:59 GMT Ralf Corsepius [5c7a69ba] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) Update. Wed, 27 Aug 2008 07:50:31 GMT Ralf Corsepius [d880bc54] * contrib/crossrpms/patches/newlib-1.16.0-rtems4.10-20080827.diff (added) * contrib/crossrpms/patches/newlib-1.16.0-rtems4.9-20080827.diff (added) New. Wed, 27 Aug 2008 07:49:12 GMT Ralf Corsepius [c85397c] * contrib/crossrpms/patches/gcc-core-3.4.6-rtems4.9-20071111.diff (deleted) Remove. Wed, 27 Aug 2008 07:42:21 GMT Ralf Corsepius [f9ad4a6] * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/rtems4.9/Makefile.am (modified) Remove tic4x (Abandoned). Wed, 27 Aug 2008 07:41:11 GMT Ralf Corsepius [71ca05a] * contrib/crossrpms/rtems4.9/tic4x/.cvsignore (deleted) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (deleted) Remove. Wed, 27 Aug 2008 07:40:52 GMT Ralf Corsepius [cc1ec8c3] * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (deleted) * contrib/crossrpms/rtems4.9/tic4x/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (deleted) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (deleted) Remove (Abandon). Wed, 27 Aug 2008 07:38:40 GMT Ralf Corsepius [e69afe2] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) Use full URLs to patches. Wed, 27 Aug 2008 07:29:31 GMT Ralf Corsepius [d0cccc9] * contrib/crossrpms/configure.ac (modified) Abandon rtems4.10/tic4x. Wed, 27 Aug 2008 07:28:36 GMT Ralf Corsepius [f837cfd] * contrib/crossrpms/rtems4.10/Makefile.am (modified) Abandon tic4x. Wed, 27 Aug 2008 07:27:53 GMT Ralf Corsepius [674811a3] * contrib/crossrpms/rtems4.10/tic4x/.cvsignore (deleted) * contrib/crossrpms/rtems4.10/tic4x/Makefile.am (deleted) * contrib/crossrpms/rtems4.10/tic4x/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.10/tic4x/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/tic4x/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.10/tic4x/rtems-4.10-tic4x-rtems4.10-binutils.spec (deleted) * contrib/crossrpms/rtems4.10/tic4x/rtems-4.10-tic4x-rtems4.10-gcc.spec (deleted) Remove (Abandoned). Sun, 27 Jul 2008 06:25:12 GMT Ralf Corsepius [476c9f4] * contrib/crossrpms/binutils/install.add (modified) Don't install windmc.1 if windmc is not available. Mon, 07 Jul 2008 16:55:00 GMT Ralf Corsepius [ef94f04f] * contrib/crossrpms/patches/binutils-2.18.50-rtems4.10-20080706.diff (deleted) Remove (Incorporated by upstream.) Sun, 06 Jul 2008 06:01:44 GMT Ralf Corsepius [874f7ec3] * contrib/crossrpms/patches/binutils-2.18.50-rtems4.10-20080706.diff (added) New. Sat, 05 Jul 2008 05:33:27 GMT Ralf Corsepius [dbb26e7] * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/tic4x/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) Add full URL to patch. Thu, 03 Jul 2008 16:36:20 GMT Ralf Corsepius [06a23329] * contrib/crossrpms/configure.ac (modified) Add rtems-4.10. Thu, 03 Jul 2008 15:44:49 GMT Ralf Corsepius [343a28e8] * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) gcc-core-4.3.1-rtems4.9-20080628.diff Thu, 03 Jul 2008 15:30:57 GMT Ralf Corsepius [3f6e3fa] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/tic4x/rtems-4.10-tic4x-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/tic4x/rtems-4.10-tic4x-rtems4.10-gcc.spec (added) New. Thu, 03 Jul 2008 15:28:12 GMT Ralf Corsepius [2c20b745] * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) Backup. Thu, 03 Jul 2008 15:25:01 GMT Ralf Corsepius [5b622a9d] * contrib/crossrpms/patches/gcc-core-4.3.1-rtems4.9-20080628.diff (added) Add m68k/cf 5329 Thu, 03 Jul 2008 08:37:15 GMT Ralf Corsepius [5916f579] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) Remove 4.3.0. Thu, 03 Jul 2008 08:24:44 GMT Ralf Corsepius [35f8615] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/tic4x/Makefile.am (modified) Set target to rtems4.10. Thu, 03 Jul 2008 08:20:43 GMT Ralf Corsepius [b1bd76b] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/tic4x/Makefile.am (modified) Reset *_RPMREL. Thu, 03 Jul 2008 08:18:22 GMT Ralf Corsepius [01141c5] * contrib/crossrpms/rtems4.10/.cvsignore (added) * contrib/crossrpms/rtems4.10/Makefile.am (added) * contrib/crossrpms/rtems4.10/arm/.cvsignore (added) * contrib/crossrpms/rtems4.10/arm/Makefile.am (added) * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/arm/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/avr/.cvsignore (added) * contrib/crossrpms/rtems4.10/avr/Makefile.am (added) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/avr/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/bfin/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/binutils.am (added) * contrib/crossrpms/rtems4.10/cpukit-prep.add (added) * contrib/crossrpms/rtems4.10/cpukit.am (added) * contrib/crossrpms/rtems4.10/gcc-prep.add (added) * contrib/crossrpms/rtems4.10/gcc.am (added) * contrib/crossrpms/rtems4.10/gdb.am (added) * contrib/crossrpms/rtems4.10/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/h8300/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/i386/.cvsignore (added) * contrib/crossrpms/rtems4.10/i386/Makefile.am (added) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/i386/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/m68k/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/mips/.cvsignore (added) * contrib/crossrpms/rtems4.10/mips/Makefile.am (added) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/mips/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/powerpc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/sh/.cvsignore (added) * contrib/crossrpms/rtems4.10/sh/Makefile.am (added) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/sh/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/sparc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/tic4x/.cvsignore (added) * contrib/crossrpms/rtems4.10/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.10/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/tic4x/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/tic4x/gcc-sources.add (added) New. Mon, 09 Jun 2008 14:31:19 GMT Ralf Corsepius [7e851f92] * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) Upgrade to gcc-4.3.1 Mon, 09 Jun 2008 07:36:08 GMT Ralf Corsepius [01c1694] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Add gcc-4.3.1. Abandon gcc-4.2.3. Mon, 09 Jun 2008 07:34:37 GMT Ralf Corsepius [22bd5223] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Upgrade to gcc-4.3.1. Mon, 09 Jun 2008 07:33:25 GMT Ralf Corsepius [ff1a93b] * contrib/crossrpms/gcc/gccnewlib.add (modified) Do not use string comparisions. Mon, 09 Jun 2008 07:32:48 GMT Ralf Corsepius [705c7b0] * contrib/crossrpms/patches/gcc-core-4.3.1-rtems4.9-20080609.diff (added) New. Thu, 05 Jun 2008 02:53:52 GMT Ralf Corsepius [5a820918] * contrib/crossrpms/patches/binutils-2.16.1-rtems-20050708.diff (deleted) * contrib/crossrpms/patches/binutils-2.17-rtems4.8-20061021.diff (deleted) * contrib/crossrpms/patches/binutils-2.17.90-rtems4.8-20070807.diff (deleted) * contrib/crossrpms/patches/binutils-2.18-rtems4.9-20071104.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.0.4-rtems4.9-20071111.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.3-rtems4.9-20080202.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.3.0-rtems4.9-20080306.diff (deleted) * contrib/crossrpms/patches/gdb-6.8-rtems4.9-20080428.diff (deleted) * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070208.diff (deleted) * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070316.diff (deleted) * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070413.diff (deleted) * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070912.diff (deleted) * contrib/crossrpms/patches/newlib-1.16.0-rtems4.9-20071220.diff (deleted) * contrib/crossrpms/patches/newlib-1.16.0-rtems4.9-20080131.diff (deleted) * contrib/crossrpms/patches/newlib-1.16.0-rtems4.9-20080302.diff (deleted) Remove. Wed, 04 Jun 2008 17:35:06 GMT Ralf Corsepius [1f5ac415] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Bump GCC_RPMREL. Wed, 04 Jun 2008 15:46:08 GMT Ralf Corsepius [37fe6ec] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/cygwin/i686/binutils-sources.add (modified) Upgrade to binutils-20080523-1. Wed, 04 Jun 2008 10:55:45 GMT Ralf Corsepius [19fc339] * contrib/crossrpms/cygwin/i686/terminfo.add (modified) Add hack to adjust n/ncr260vt300wpp Wed, 04 Jun 2008 10:49:18 GMT Ralf Corsepius [b51c8b0] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Bump ncurses RPMREL. Wed, 04 Jun 2008 10:48:42 GMT Ralf Corsepius [704d9ef] * contrib/crossrpms/cygwin/i686/ncurses.add (modified) BR/R: terminfo Wed, 04 Jun 2008 10:45:51 GMT Ralf Corsepius [56059395] * contrib/crossrpms/cygwin/i686/terminfo.add (modified) Add hack to adjust Eterm-color Wed, 04 Jun 2008 10:41:56 GMT Ralf Corsepius [5743475] * contrib/crossrpms/cygwin/i686/terminfo.add (modified) Add hack to adjust Eterm-color Wed, 04 Jun 2008 10:23:46 GMT Ralf Corsepius [a53c42a] * contrib/crossrpms/cygwin/i686/target-terminfo.add (added) * contrib/crossrpms/cygwin/i686/terminfo.add (added) * contrib/crossrpms/cygwin/terminfo.am (added) New. Wed, 04 Jun 2008 10:23:30 GMT Ralf Corsepius [b206999] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Add TERMINFO. Wed, 04 Jun 2008 07:10:38 GMT Ralf Corsepius [17cf7866] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Upgrade to cygwin-1.5.25-14 Mon, 26 May 2008 23:43:45 GMT Ralf Corsepius [1e642c6] * contrib/crossrpms/patches/gcc-core-4.2.2-rtems4.9-20071127.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.2-rtems4.9-20080114.diff (deleted) Remove. Mon, 26 May 2008 23:29:56 GMT Ralf Corsepius [ee6c822] * contrib/crossrpms/patches/gcc-core-4.2.2-rtems4.9-20071109.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.2-rtems4.9-20071114.diff (deleted) Remove. Mon, 26 May 2008 23:27:40 GMT Ralf Corsepius [26ad27c] * contrib/crossrpms/patches/gcc-core-4.2.4-rtems4.9-20080526.diff (added) New. Mon, 26 May 2008 23:27:03 GMT Ralf Corsepius [498d35e] * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) GCC 4.2.4 Sat, 10 May 2008 03:13:02 GMT Ralf Corsepius [397afef4] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Update. Sat, 10 May 2008 03:12:31 GMT Ralf Corsepius [77d17fff] * contrib/crossrpms/cygwin/i686/expat.add (added) * contrib/crossrpms/cygwin/i686/target-expat.add (added) New. Fri, 09 May 2008 12:43:57 GMT Ralf Corsepius [dc49fb9] * contrib/crossrpms/autotools/autoconf.add (modified) BuildRequire: m4 > 1.4.5 Thu, 08 May 2008 02:56:34 GMT Ralf Corsepius [ac91ec77] * contrib/crossrpms/gdb/build.add (modified) Enable --with-system-readline only for gdb >= 6.7 Thu, 01 May 2008 08:13:14 GMT Ralf Corsepius [5633d25f] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Thu, 01 May 2008 08:10:28 GMT Ralf Corsepius [1acb6bac] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Upgrade to newlib-1.16.0-rtems4.9-20080430.diff, gcc- ... Thu, 01 May 2008 08:09:25 GMT Ralf Corsepius [14082517] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Bump GCC_RPMREL. Thu, 01 May 2008 08:08:19 GMT Ralf Corsepius [c29338cc] * contrib/crossrpms/patches/newlib-1.16.0-rtems4.9-20080430.diff (added) Add upstream SIZE_MIN/SIZE_MAX fixes. Thu, 01 May 2008 08:01:10 GMT Ralf Corsepius [7bf236d] * contrib/crossrpms/patches/gcc-core-4.3.0-rtems4.9-20080501.diff (added) Add include-fixed to FLAGS_FOR_TARGET to let Cdn-X build succeed. Tue, 29 Apr 2008 11:40:37 GMT Ralf Corsepius [9bb08af] * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/prep.add (modified) Improvements for gdb-6.6/6.7 Tue, 29 Apr 2008 04:01:12 GMT Ralf Corsepius [9c3c512] * contrib/crossrpms/patches/gdb-6.8-rtems4.9-20080429.diff (added) Once more rework erc32 simulator configuration. Tue, 29 Apr 2008 03:45:00 GMT Ralf Corsepius [905700d] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) Upgrade to gdb-6.8-rtems4.9-20080429.diff. Tue, 29 Apr 2008 03:44:19 GMT Ralf Corsepius [2870240] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL. Mon, 28 Apr 2008 14:32:07 GMT Ralf Corsepius [ea7a607] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Regenerate. Mon, 28 Apr 2008 14:30:15 GMT Ralf Corsepius [7df9456] * contrib/crossrpms/patches/gdb-6.7.1-gdb-6.7.90-config.diff (deleted) * contrib/crossrpms/patches/gdb-6.7.1-rtems4.9-20071216.diff (deleted) * contrib/crossrpms/patches/gdb-6.7.1-rtems4.9-20080324.diff (deleted) * contrib/crossrpms/patches/gdb-6.8-rtems4.9-20080329.diff (deleted) Remove. Mon, 28 Apr 2008 14:28:10 GMT Ralf Corsepius [bbe338e] * contrib/crossrpms/patches/gdb-6.8-rtems4.9-20080428.diff (added) New. Mon, 28 Apr 2008 14:15:25 GMT Ralf Corsepius [2d29b143] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) Abandon gdb-6.7.1. Use gdb-6.8-rtems4.9-20080428.diff. Mon, 28 Apr 2008 13:38:47 GMT Ralf Corsepius [d9393d5] * contrib/crossrpms/gdb/gdb.add (modified) Minor restructurization. Sun, 27 Apr 2008 05:27:02 GMT Ralf Corsepius [1ef4b6c] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/automake.add (modified) Move %{?dist} to Makefile.am. Sun, 27 Apr 2008 05:26:37 GMT Ralf Corsepius [42f9ca8b] * contrib/crossrpms/autotools/autoconf.add (modified) Move %{?dist} to Makefile.am. BR: m4 > 1.4.5 for autoconf >= 2.62. Sat, 26 Apr 2008 05:36:01 GMT Ralf Corsepius [17002619] * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Use rtems_api. Sat, 26 Apr 2008 05:33:04 GMT Ralf Corsepius [02c93793] * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/mkspec.am (modified) Add rtems_api. Fri, 25 Apr 2008 15:19:47 GMT Ralf Corsepius [dc6771a7] * contrib/crossrpms/gcc/base-gcc.add (modified) Remove stray newline. Mon, 21 Apr 2008 06:01:23 GMT Ralf Corsepius [84f140c] * contrib/crossrpms/autotools/Makefile.am (modified) autoconf-2.62. Mon, 21 Apr 2008 06:01:07 GMT Ralf Corsepius [2e4550cf] * contrib/crossrpms/autotools/autoconf.add (modified) Use AUTOCONF_VERS. Mon, 21 Apr 2008 06:00:44 GMT Ralf Corsepius [2dc7132] * contrib/crossrpms/autotools/autoconf.am (modified) Add AUTOCONF_VERS. Mon, 31 Mar 2008 04:46:57 GMT Ralf Corsepius [ffd1050] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) gdb-6.8-rtems4.9-20080331.diff. Mon, 31 Mar 2008 04:45:03 GMT Ralf Corsepius [eca11fcd] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL.
