# # ChangeLog for contrib/crossrpms/solaris2.7 in rtems # # Generated by Trac 1.2.1.dev0 # 05/02/24 07:01:42 Tue, 21 Feb 2006 08:18:29 GMT Ralf Corsepius [1259c55] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate newlib_version Tue, 21 Feb 2006 08:12:54 GMT Ralf Corsepius [42b1efb8] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Use $(MKSPEC) to generate *-binutils.spec. Tue, 21 Feb 2006 08:12:10 GMT Ralf Corsepius [fe977c7] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Use $(MKSPEC) to generate *-gcc.spec. Tue, 21 Feb 2006 08:10:46 GMT Ralf Corsepius [773ab4f] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Use $(MKSPEC) to generate *-libs.spec. Tue, 21 Feb 2006 07:54:50 GMT Ralf Corsepius [f538086] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Include ../mkspec.am Mon, 20 Feb 2006 16:37:01 GMT Ralf Corsepius [dd3a261] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Backup. Mon, 20 Feb 2006 14:00:55 GMT Ralf Corsepius [b7cd78c1] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Backup. Mon, 20 Feb 2006 07:50:18 GMT Ralf Corsepius [d31a75a] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Apply @rpmprefix@ to *.spec files. Sun, 19 Feb 2006 15:17:05 GMT Ralf Corsepius [3d612dc4] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Use package version as RPMREL. Sat, 18 Feb 2006 11:11:51 GMT Ralf Corsepius [1b8fc3e4] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Add binutils/prep.add, binutils/build.add binutils/install.add Sat, 18 Feb 2006 11:10:22 GMT Ralf Corsepius [6cc81d31] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Cosmetics. Sat, 18 Feb 2006 08:02:54 GMT Ralf Corsepius [384fa937] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Reflect having split out gcc/prep.add and gcc/build.add Sat, 18 Feb 2006 06:53:57 GMT Ralf Corsepius [9d07966e] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Misc. sed magic. Sat, 18 Feb 2006 05:17:08 GMT Ralf Corsepius [89d2e86] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Sed out %package -n @rpmprefix@@tool_target@-gcc from *gcc.spec Fri, 17 Feb 2006 15:49:16 GMT Ralf Corsepius [149930b1] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Let *.spec.in depend on Makefile.am Fri, 17 Feb 2006 15:44:28 GMT Ralf Corsepius [0d349d29] * contrib/crossrpms/cygwin/libs.add (modified) * contrib/crossrpms/freebsd5.2/libs.add (modified) * contrib/crossrpms/freebsd6.0/libs.add (modified) * contrib/crossrpms/solaris2.7/libs.add (modified) Use %{__tar} instead of plain tar Fri, 17 Feb 2006 14:28:41 GMT Ralf Corsepius [f991f51] * contrib/crossrpms/freebsd6.0/.cvsignore (modified) * contrib/crossrpms/solaris2.7/.cvsignore (modified) Add *.spec.in Fri, 17 Feb 2006 11:17:26 GMT Ralf Corsepius [e4ddd55] * contrib/crossrpms/solaris2.7/Makefile.am (modified) Add libs.add target-libs.add Fri, 17 Feb 2006 11:16:48 GMT Ralf Corsepius [df2337b7] * contrib/crossrpms/solaris2.7/libs.add (modified) * contrib/crossrpms/solaris2.7/target-libs.add (modified) New. Fri, 17 Feb 2006 08:22:55 GMT Ralf Corsepius [8fd80ac] * contrib/crossrpms/solaris2.7/libs.add (added) * contrib/crossrpms/solaris2.7/target-libs.add (added) New. Fri, 17 Feb 2006 03:10:28 GMT Ralf Corsepius [e7fd334b] * contrib/crossrpms/common/common.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Propagate $prefix as %_prefix Thu, 16 Feb 2006 17:22:17 GMT Ralf Corsepius [ebc03f5] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Propagate rpmprefix Thu, 16 Feb 2006 14:46:08 GMT Ralf Corsepius [5a4eb6e1] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %binutils_target Thu, 16 Feb 2006 14:45:01 GMT Ralf Corsepius [2fbb0a0] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %gcc_target Thu, 16 Feb 2006 14:38:01 GMT Ralf Corsepius [0f60691] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate deps on %{newlib_version} Thu, 16 Feb 2006 14:16:14 GMT Ralf Corsepius [0510c027] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Unify @PATCH handling. Thu, 16 Feb 2006 14:05:36 GMT Ralf Corsepius [4fa25687] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/common/common.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-libc.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %{rpmgroup} Wed, 15 Feb 2006 15:21:54 GMT Ralf Corsepius [d72421b] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Backup. Wed, 15 Feb 2006 15:04:03 GMT Ralf Corsepius [c0b13f0] * contrib/crossrpms/.cvsignore (added) * contrib/crossrpms/binutils/.cvsignore (added) * contrib/crossrpms/freebsd5.2/binutils-sources.add (modified) * contrib/crossrpms/freebsd5.2/gcc-sources.add (added) * contrib/crossrpms/freebsd6.0/binutils-sources.add (modified) * contrib/crossrpms/freebsd6.0/gcc-sources.add (added) * contrib/crossrpms/mingw32/libs.add (added) * contrib/crossrpms/mingw32/target-libs.add (added) * contrib/crossrpms/mingw32/target-w32api.add (added) * contrib/crossrpms/mingw32/w32api.add (added) * contrib/crossrpms/rtems/.cvsignore (added) * contrib/crossrpms/rtems/Makefile.am (added) * contrib/crossrpms/rtems/binutils-sources.add (added) * contrib/crossrpms/rtems/gcc-sources.add (added) * contrib/crossrpms/solaris2.7/Makefile.am (modified) * contrib/crossrpms/solaris2.7/binutils-sources.add (modified) * contrib/crossrpms/solaris2.7/gcc-sources.add (added) New. Tue, 14 Feb 2006 14:33:19 GMT Ralf Corsepius [d5b3bb8e] * contrib/crossrpms/solaris2.7/.cvsignore (added) * contrib/crossrpms/solaris2.7/Makefile.am (added) * contrib/crossrpms/solaris2.7/binutils-sources.add (added) New.
