# # ChangeLog for contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec in rtems # # Generated by Trac 1.2.1.dev0 # 04/18/24 20:53:02 Sun, 04 Nov 2007 09:28:35 GMT Ralf Corsepius [6d77c8f5] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (modified) regenerate Fri, 28 Sep 2007 07:35:18 GMT Ralf Corsepius [2d9201a] * contrib/crossrpms/rtems4.9/arm/.cvsignore (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/avr/.cvsignore (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/bfin/.cvsignore (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/h8300/.cvsignore (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/i386/.cvsignore (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/m68k/.cvsignore (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/mips/.cvsignore (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/mipstx39/.cvsignore (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/powerpc/.cvsignore (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/sh/.cvsignore (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/sparc/.cvsignore (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/tic4x/.cvsignore (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (added) Add rtems-4.9*.spec
