# # ChangeLog for contrib/crossrpms/rtems4.9/m68k in rtems # # Generated by Trac 1.2.1.dev0 # 04/20/24 01:51:37 Mon, 10 Nov 2008 14:32:26 GMT Ralf Corsepius [430c0f6d] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GCC_RPMREL. Sat, 08 Nov 2008 03:25:35 GMT Ralf Corsepius [11c9109] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) Regenerate. Sat, 08 Nov 2008 03:25:13 GMT Ralf Corsepius [e5c9d67] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump BINUTILS_RPMREL. Thu, 06 Nov 2008 07:31:58 GMT Ralf Corsepius [6fd1e692] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Remove cpukit (Unsupported). Thu, 06 Nov 2008 07:29:45 GMT Ralf Corsepius [7d3548a1] * contrib/crossrpms/rtems4.9/arm/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/avr/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/bfin/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/cpukit-prep.add (deleted) * contrib/crossrpms/rtems4.9/cpukit.am (deleted) * contrib/crossrpms/rtems4.9/h8300/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/i386/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/m68k/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/mips/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/powerpc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/sh/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-cpukit.spec (deleted) * contrib/crossrpms/rtems4.9/sparc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-cpukit.spec (deleted) Remove (Unsupported). Thu, 18 Sep 2008 08:48:17 GMT Ralf Corsepius [c07a9c00] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Update to gdb-6.8-rtems4.9-20080917.diff. Wed, 10 Sep 2008 19:43:40 GMT Ralf Corsepius [9852009] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Wed, 03 Sep 2008 22:48:11 GMT Ralf Corsepius [9589c665] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Regenerate. Wed, 03 Sep 2008 22:39:16 GMT Ralf Corsepius [d043ebc2] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Sync with rtems-4.10. Wed, 27 Aug 2008 09:31:37 GMT Ralf Corsepius [65c3aaf4] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) Use URLs for patches. Wed, 27 Aug 2008 09:30:57 GMT Ralf Corsepius [8371640] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Abandon gcc-4.3.0. Use URLs for patches. ... Sat, 05 Jul 2008 05:33:27 GMT Ralf Corsepius [dbb26e7] * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/tic4x/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) Add full URL to patch. Thu, 03 Jul 2008 15:44:49 GMT Ralf Corsepius [343a28e8] * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) gcc-core-4.3.1-rtems4.9-20080628.diff Thu, 03 Jul 2008 15:28:12 GMT Ralf Corsepius [2c20b745] * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-cpukit.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) Backup. Mon, 09 Jun 2008 07:36:08 GMT Ralf Corsepius [01c1694] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Add gcc-4.3.1. Abandon gcc-4.2.3. Mon, 09 Jun 2008 07:34:37 GMT Ralf Corsepius [22bd5223] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Upgrade to gcc-4.3.1. Thu, 01 May 2008 08:13:14 GMT Ralf Corsepius [5633d25f] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Thu, 01 May 2008 08:10:28 GMT Ralf Corsepius [1acb6bac] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Upgrade to newlib-1.16.0-rtems4.9-20080430.diff, gcc- ... Thu, 01 May 2008 08:09:25 GMT Ralf Corsepius [14082517] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Bump GCC_RPMREL. Tue, 29 Apr 2008 03:45:00 GMT Ralf Corsepius [905700d] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) Upgrade to gdb-6.8-rtems4.9-20080429.diff. Tue, 29 Apr 2008 03:44:19 GMT Ralf Corsepius [2870240] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL. Mon, 28 Apr 2008 14:32:07 GMT Ralf Corsepius [ea7a607] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Regenerate. Mon, 28 Apr 2008 14:15:25 GMT Ralf Corsepius [2d29b143] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) Abandon gdb-6.7.1. Use gdb-6.8-rtems4.9-20080428.diff. Mon, 31 Mar 2008 04:46:57 GMT Ralf Corsepius [ffd1050] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) gdb-6.8-rtems4.9-20080331.diff. Mon, 31 Mar 2008 04:45:03 GMT Ralf Corsepius [eca11fcd] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL. Sat, 29 Mar 2008 17:38:22 GMT Ralf Corsepius [ef5c018] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) gdb-6.8. Sat, 29 Mar 2008 04:38:02 GMT Ralf Corsepius [84a996a6] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) Add gdb-6.8. Tue, 25 Mar 2008 05:50:32 GMT Ralf Corsepius [1f129d87] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Regenerate. Mon, 24 Mar 2008 17:11:02 GMT Ralf Corsepius [4e78050] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) gdb-6.7.1-rtems4.9-20080324.diff, gdb-6.7.1-gdb-6.7.90-config.diff. Mon, 24 Mar 2008 17:08:45 GMT Ralf Corsepius [063d030] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GDB_RPMREL. Fri, 14 Mar 2008 15:34:59 GMT Ralf Corsepius [211c22eb] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Thu, 06 Mar 2008 15:30:45 GMT Ralf Corsepius [fcac0c7] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Preps for gcc-4.3.0 final. Mon, 03 Mar 2008 06:36:28 GMT Ralf Corsepius [fb974c6] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Mon, 03 Mar 2008 06:35:42 GMT Ralf Corsepius [d0abb93] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GCC_RPMREL = 10.20080301.2%{?dist}. Mon, 03 Mar 2008 06:33:49 GMT Ralf Corsepius [94299fd3] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Update to newlib-1.16.0-rtems4.9-20080302.diff. Sun, 02 Mar 2008 06:52:59 GMT Ralf Corsepius [e2fe8948] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Sun, 02 Mar 2008 06:51:36 GMT Ralf Corsepius [3aa2d40] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Update to gcc-4.3.0-RC-20080301. Wed, 27 Feb 2008 15:31:30 GMT Ralf Corsepius [e122f592] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Wed, 27 Feb 2008 14:17:39 GMT Ralf Corsepius [7cfcdc1] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GCC_RPMREL to 10.20080222.1 Wed, 27 Feb 2008 10:56:11 GMT Ralf Corsepius [4aa20ea8] * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) Upgrade to gcc-4.3.0-RC-20080222. Mon, 11 Feb 2008 17:49:27 GMT Ralf Corsepius [76b0283] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Mon, 11 Feb 2008 17:47:36 GMT Ralf Corsepius [be2dfb8] * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) Use binutils-2.18-rtems4.9-20080211.diff Mon, 11 Feb 2008 17:47:00 GMT Ralf Corsepius [d2d17545] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Bump BINUTILS_RPMREL. Wed, 06 Feb 2008 04:33:04 GMT Ralf Corsepius [92150edc] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GCC_RPMREL. Wed, 06 Feb 2008 04:32:44 GMT Ralf Corsepius [4419987a] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) gcc-core-4.2.3-rtems4.9-20080205.diff Sun, 03 Feb 2008 08:21:22 GMT Ralf Corsepius [b8c28e8] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Sat, 02 Feb 2008 04:16:30 GMT Ralf Corsepius [0d2a267] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Bump GCC_RPMREL. Sat, 02 Feb 2008 04:09:56 GMT Ralf Corsepius [7728b8c] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) newlib-1.16.0-rtems4.9-20080131.diff Sat, 02 Feb 2008 04:06:05 GMT Ralf Corsepius [15e5148] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Preps for gcc-4.2.3. Mon, 14 Jan 2008 09:29:23 GMT Ralf Corsepius [5e57f833] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Mon, 14 Jan 2008 09:28:24 GMT Ralf Corsepius [30b8e468] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GCC_RPMREL. Mon, 14 Jan 2008 09:27:45 GMT Ralf Corsepius [c23804dd] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) gcc-core-4.2.2-rtems4.9-20080114.diff.Remove gcc-3.4.6. Thu, 20 Dec 2007 16:13:08 GMT Ralf Corsepius [ab56160] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Thu, 20 Dec 2007 16:11:34 GMT Ralf Corsepius [c55ed1d] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Prepare upgrade to newlib-1.16.0. Mon, 17 Dec 2007 06:42:56 GMT Ralf Corsepius [e4c0acd5] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (modified) Update. Sun, 16 Dec 2007 08:25:36 GMT Ralf Corsepius [fbce31e] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) Update. Sun, 16 Dec 2007 08:20:47 GMT Ralf Corsepius [d6c28599] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) Abandon gdb-6.7. Sun, 16 Dec 2007 08:20:27 GMT Ralf Corsepius [2451d88] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gdb-sources.add (modified) Abandon gdb-6.6. Sun, 16 Dec 2007 08:20:05 GMT Ralf Corsepius [a16841e] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gdb-sources.add (modified) Abandon gdb-6.5. Sun, 16 Dec 2007 08:18:49 GMT Ralf Corsepius [440b8e5] * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) gdb-6.7.1-rtems4.9-20071216.diff Wed, 28 Nov 2007 04:25:28 GMT Ralf Corsepius [29925d99] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Regenerate. Wed, 28 Nov 2007 04:24:36 GMT Ralf Corsepius [70b2aca] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Bump GCC_RPMREL Wed, 28 Nov 2007 04:24:17 GMT Ralf Corsepius [e5a29d6c] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Upgrade to gcc-core-4.2.2-rtems4.9-20071127.diff Wed, 14 Nov 2007 03:15:31 GMT Ralf Corsepius [c89a4e4e] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) gcc-core-4.2.2-rtems4.9-20071114.diff. Wed, 14 Nov 2007 03:12:16 GMT Ralf Corsepius [8b2620e1] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Reflect having removed *diffs Tue, 13 Nov 2007 17:00:35 GMT Ralf Corsepius [8fea157] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) Abandon gcc-4.0.3 Tue, 13 Nov 2007 15:09:44 GMT Ralf Corsepius [dc00c8d] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) backup. Mon, 12 Nov 2007 13:38:24 GMT Ralf Corsepius [9c5fca8] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Bump GCC_RPMREL. Fri, 09 Nov 2007 17:10:18 GMT Ralf Corsepius [c6b590d] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Fri, 09 Nov 2007 07:16:27 GMT Ralf Corsepius [0be4b8a5] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Abandon gcc-4.1.1 Fri, 09 Nov 2007 07:13:49 GMT Ralf Corsepius [0052c92] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Abandon gcc-4.2.1 Fri, 09 Nov 2007 07:12:40 GMT Ralf Corsepius [311f43e] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Abandon gcc-4.1.2. Fri, 09 Nov 2007 07:08:27 GMT Ralf Corsepius [c8720f7] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Abandon gcc-4.2.0. Fri, 09 Nov 2007 07:00:02 GMT Ralf Corsepius [5fd4eae7] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Use gcc-core-4.2.2-rtems4.9-20071109.diff Sun, 04 Nov 2007 12:25:19 GMT Ralf Corsepius [83c8c3c] * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (modified) Fix stupid typo Sun, 04 Nov 2007 09:28:35 GMT Ralf Corsepius [6d77c8f5] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (modified) regenerate Sun, 04 Nov 2007 09:26:51 GMT Ralf Corsepius [fd7bb10] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Bump BINUTILS_RPMREL. Sun, 04 Nov 2007 09:26:05 GMT Ralf Corsepius [567fed3] * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) Update. Thu, 01 Nov 2007 05:58:05 GMT Ralf Corsepius [25eda206] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) gdb-6.7.1-4 Wed, 31 Oct 2007 12:27:07 GMT Ralf Corsepius [a4081ce7] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (modified) gdb-4.7.1 Fri, 12 Oct 2007 02:19:02 GMT Ralf Corsepius [ee54f23] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) gdb-6.7-2 Thu, 11 Oct 2007 03:18:10 GMT Ralf Corsepius [6f1919e5] * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Thu, 11 Oct 2007 03:02:46 GMT Ralf Corsepius [0e6d50c] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Update to gcc-4.2.2-2. Thu, 11 Oct 2007 02:53:12 GMT Ralf Corsepius [59b4f42] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Add 4.2.2. Fri, 28 Sep 2007 07:38:40 GMT Ralf Corsepius [51aac0e] * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Cleanups. Fri, 28 Sep 2007 07:35:18 GMT Ralf Corsepius [2d9201a] * contrib/crossrpms/rtems4.9/arm/.cvsignore (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/avr/.cvsignore (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/bfin/.cvsignore (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/h8300/.cvsignore (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/i386/.cvsignore (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/m68k/.cvsignore (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/mips/.cvsignore (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/mipstx39/.cvsignore (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/powerpc/.cvsignore (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/sh/.cvsignore (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/sparc/.cvsignore (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/tic4x/.cvsignore (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (added) Add rtems-4.9*.spec Fri, 28 Sep 2007 07:31:55 GMT Ralf Corsepius [b1f6abc] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Reset GCC_RPMREL, GDB_RPMREL, BINUTILS_RPMREL = 1. Fri, 28 Sep 2007 07:24:56 GMT Ralf Corsepius [ed73806b] * contrib/crossrpms/rtems4.9/.cvsignore (added) * contrib/crossrpms/rtems4.9/Makefile.am (added) * contrib/crossrpms/rtems4.9/arm/.cvsignore (added) * contrib/crossrpms/rtems4.9/arm/Makefile.am (added) * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/arm/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/avr/.cvsignore (added) * contrib/crossrpms/rtems4.9/avr/Makefile.am (added) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/avr/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/binutils.am (added) * contrib/crossrpms/rtems4.9/cpukit-prep.add (added) * contrib/crossrpms/rtems4.9/cpukit.am (added) * contrib/crossrpms/rtems4.9/gcc-prep.add (added) * contrib/crossrpms/rtems4.9/gcc.am (added) * contrib/crossrpms/rtems4.9/gdb.am (added) * contrib/crossrpms/rtems4.9/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/i386/.cvsignore (added) * contrib/crossrpms/rtems4.9/i386/Makefile.am (added) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/i386/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/mips/.cvsignore (added) * contrib/crossrpms/rtems4.9/mips/Makefile.am (added) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/mips/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/sh/.cvsignore (added) * contrib/crossrpms/rtems4.9/sh/Makefile.am (added) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/sh/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/.cvsignore (added) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/gdb-sources.add (added) copy from rtems-4.8 to rtems-4.9.
