# # ChangeLog for contrib/crossrpms/rtems4.9/bfin in rtems # # Generated by Trac 1.2.1.dev0 # 05/17/24 00:13:00 Fri, 09 Nov 2007 07:12:40 GMT Ralf Corsepius [311f43e] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Abandon gcc-4.1.2. Fri, 09 Nov 2007 07:08:27 GMT Ralf Corsepius [c8720f7] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Abandon gcc-4.2.0. Fri, 09 Nov 2007 07:00:02 GMT Ralf Corsepius [5fd4eae7] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Use gcc-core-4.2.2-rtems4.9-20071109.diff Sun, 04 Nov 2007 12:25:19 GMT Ralf Corsepius [83c8c3c] * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (modified) Fix stupid typo Sun, 04 Nov 2007 09:28:35 GMT Ralf Corsepius [6d77c8f5] * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (modified) regenerate Sun, 04 Nov 2007 09:26:51 GMT Ralf Corsepius [fd7bb10] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Bump BINUTILS_RPMREL. Sun, 04 Nov 2007 09:26:05 GMT Ralf Corsepius [567fed3] * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) Update. Thu, 01 Nov 2007 05:58:05 GMT Ralf Corsepius [25eda206] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) gdb-6.7.1-4 Thu, 11 Oct 2007 03:18:10 GMT Ralf Corsepius [6f1919e5] * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) Regenerate. Thu, 11 Oct 2007 03:02:46 GMT Ralf Corsepius [0e6d50c] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) Update to gcc-4.2.2-2. Thu, 11 Oct 2007 02:53:12 GMT Ralf Corsepius [59b4f42] * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (modified) Add 4.2.2. Fri, 28 Sep 2007 07:38:40 GMT Ralf Corsepius [51aac0e] * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Cleanups. Fri, 28 Sep 2007 07:35:18 GMT Ralf Corsepius [2d9201a] * contrib/crossrpms/rtems4.9/arm/.cvsignore (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/avr/.cvsignore (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/bfin/.cvsignore (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/h8300/.cvsignore (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/i386/.cvsignore (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/m68k/.cvsignore (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/mips/.cvsignore (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/mipstx39/.cvsignore (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/powerpc/.cvsignore (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/sh/.cvsignore (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/sparc/.cvsignore (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-cpukit.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (added) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (added) * contrib/crossrpms/rtems4.9/tic4x/.cvsignore (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (added) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (added) Add rtems-4.9*.spec Fri, 28 Sep 2007 07:31:55 GMT Ralf Corsepius [b1f6abc] * contrib/crossrpms/rtems4.9/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.9/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.9/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (modified) Reset GCC_RPMREL, GDB_RPMREL, BINUTILS_RPMREL = 1. Fri, 28 Sep 2007 07:24:56 GMT Ralf Corsepius [ed73806b] * contrib/crossrpms/rtems4.9/.cvsignore (added) * contrib/crossrpms/rtems4.9/Makefile.am (added) * contrib/crossrpms/rtems4.9/arm/.cvsignore (added) * contrib/crossrpms/rtems4.9/arm/Makefile.am (added) * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/arm/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/avr/.cvsignore (added) * contrib/crossrpms/rtems4.9/avr/Makefile.am (added) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/avr/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/binutils.am (added) * contrib/crossrpms/rtems4.9/cpukit-prep.add (added) * contrib/crossrpms/rtems4.9/cpukit.am (added) * contrib/crossrpms/rtems4.9/gcc-prep.add (added) * contrib/crossrpms/rtems4.9/gcc.am (added) * contrib/crossrpms/rtems4.9/gdb.am (added) * contrib/crossrpms/rtems4.9/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/i386/.cvsignore (added) * contrib/crossrpms/rtems4.9/i386/Makefile.am (added) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/i386/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/mips/.cvsignore (added) * contrib/crossrpms/rtems4.9/mips/Makefile.am (added) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/mips/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/sh/.cvsignore (added) * contrib/crossrpms/rtems4.9/sh/Makefile.am (added) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/sh/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/.cvsignore (added) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/gdb-sources.add (added) copy from rtems-4.8 to rtems-4.9.
