# # ChangeLog for contrib/crossrpms/rtems4.9/avr/binutils-sources.add in rtems # # Generated by Trac 1.2.1.dev0 # 04/16/24 18:14:46 Sat, 05 Jul 2008 05:33:27 GMT Ralf Corsepius [dbb26e7] * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/tic4x/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) Add full URL to patch. Mon, 11 Feb 2008 17:47:36 GMT Ralf Corsepius [be2dfb8] * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) Use binutils-2.18-rtems4.9-20080211.diff Sun, 04 Nov 2007 12:25:19 GMT Ralf Corsepius [83c8c3c] * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-binutils.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-binutils.spec (modified) Fix stupid typo Sun, 04 Nov 2007 09:26:05 GMT Ralf Corsepius [567fed3] * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (modified) Update. Fri, 28 Sep 2007 07:24:56 GMT Ralf Corsepius [ed73806b] * contrib/crossrpms/rtems4.9/.cvsignore (added) * contrib/crossrpms/rtems4.9/Makefile.am (added) * contrib/crossrpms/rtems4.9/arm/.cvsignore (added) * contrib/crossrpms/rtems4.9/arm/Makefile.am (added) * contrib/crossrpms/rtems4.9/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/arm/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/avr/.cvsignore (added) * contrib/crossrpms/rtems4.9/avr/Makefile.am (added) * contrib/crossrpms/rtems4.9/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/avr/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.9/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.9/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/binutils.am (added) * contrib/crossrpms/rtems4.9/cpukit-prep.add (added) * contrib/crossrpms/rtems4.9/cpukit.am (added) * contrib/crossrpms/rtems4.9/gcc-prep.add (added) * contrib/crossrpms/rtems4.9/gcc.am (added) * contrib/crossrpms/rtems4.9/gdb.am (added) * contrib/crossrpms/rtems4.9/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.9/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.9/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/i386/.cvsignore (added) * contrib/crossrpms/rtems4.9/i386/Makefile.am (added) * contrib/crossrpms/rtems4.9/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/i386/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.9/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.9/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/mips/.cvsignore (added) * contrib/crossrpms/rtems4.9/mips/Makefile.am (added) * contrib/crossrpms/rtems4.9/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/mips/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.9/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.9/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.9/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.9/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/sh/.cvsignore (added) * contrib/crossrpms/rtems4.9/sh/Makefile.am (added) * contrib/crossrpms/rtems4.9/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/sh/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.9/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.9/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/.cvsignore (added) * contrib/crossrpms/rtems4.9/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.9/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/cpukit-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/gcc-sources.add (added) * contrib/crossrpms/rtems4.9/tic4x/gdb-sources.add (added) copy from rtems-4.8 to rtems-4.9.
