# # ChangeLog for contrib/crossrpms/rtems4.8/sparc/gdb-sources.add in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 13:22:08 Fri, 20 Jul 2007 05:36:13 GMT Ralf Corsepius [4acc7e2] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (modified) Sync with testing. Sun, 18 Feb 2007 08:03:26 GMT Ralf Corsepius [349e2de] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (modified) gdb-6.6-rtems4.8-20070218.diff Sat, 17 Feb 2007 09:50:25 GMT Ralf Corsepius [08c06d89] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (modified) Preps for gdb-6.6 Sat, 17 Feb 2007 07:12:15 GMT Ralf Corsepius [84b62c77] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (modified) Fix URL. Sat, 21 Oct 2006 10:41:01 GMT Ralf Corsepius [3096ba23] * contrib/crossrpms/rtems4.8/.cvsignore (added) * contrib/crossrpms/rtems4.8/Makefile.am (added) * contrib/crossrpms/rtems4.8/arm/.cvsignore (added) * contrib/crossrpms/rtems4.8/arm/Makefile.am (added) * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/avr/.cvsignore (added) * contrib/crossrpms/rtems4.8/avr/Makefile.am (added) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/binutils.am (added) * contrib/crossrpms/rtems4.8/gcc-prep.add (added) * contrib/crossrpms/rtems4.8/gcc.am (added) * contrib/crossrpms/rtems4.8/gdb.am (added) * contrib/crossrpms/rtems4.8/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/i386/.cvsignore (added) * contrib/crossrpms/rtems4.8/i386/Makefile.am (added) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/mips/.cvsignore (added) * contrib/crossrpms/rtems4.8/mips/Makefile.am (added) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/sh/.cvsignore (added) * contrib/crossrpms/rtems4.8/sh/Makefile.am (added) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/tic4x/.cvsignore (added) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (added) New.
