# # ChangeLog for contrib/crossrpms/rtems4.8/mips in rtems # # Generated by Trac 1.2.1.dev0 # 05/01/24 09:32:46 Fri, 12 Jan 2007 03:53:39 GMT Ralf Corsepius [c116b31] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Upgrade to newlib-1.15.0-rtems4.8-20070110. Fri, 12 Jan 2007 03:49:15 GMT Ralf Corsepius [5709d75e] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Add BINUTILS_OPTS. Fri, 12 Jan 2007 03:39:21 GMT Ralf Corsepius [c80654e] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Bump GCC_RPMREL. Tue, 02 Jan 2007 11:49:35 GMT Ralf Corsepius [5ebd9351] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) Upgrade to newlib-1.15.0 Thu, 09 Nov 2006 14:28:50 GMT Ralf Corsepius [615b6c9] * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/prep.add (modified) * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/gcc-prep.add (modified) * contrib/crossrpms/rtems4.8/gcc.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Introduce GCC_PKGVERS Fri, 27 Oct 2006 08:24:43 GMT Ralf Corsepius [4e0f6b7] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Bump GCC_RPMREL. Fri, 27 Oct 2006 08:21:17 GMT Ralf Corsepius [29aed1fd] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Update to newlib-1.14.0-rtems4.8-20061027.diff Sat, 21 Oct 2006 12:34:16 GMT Ralf Corsepius [575371e] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) Reset RPMRELs = 1 Sat, 21 Oct 2006 12:33:50 GMT Ralf Corsepius [6598895] * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (modified) Abandon binutils-2.16*. Apply binutils-2.17-rtems4.8-20061021.diff Sat, 21 Oct 2006 10:41:01 GMT Ralf Corsepius [3096ba23] * contrib/crossrpms/rtems4.8/.cvsignore (added) * contrib/crossrpms/rtems4.8/Makefile.am (added) * contrib/crossrpms/rtems4.8/arm/.cvsignore (added) * contrib/crossrpms/rtems4.8/arm/Makefile.am (added) * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/avr/.cvsignore (added) * contrib/crossrpms/rtems4.8/avr/Makefile.am (added) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/binutils.am (added) * contrib/crossrpms/rtems4.8/gcc-prep.add (added) * contrib/crossrpms/rtems4.8/gcc.am (added) * contrib/crossrpms/rtems4.8/gdb.am (added) * contrib/crossrpms/rtems4.8/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/i386/.cvsignore (added) * contrib/crossrpms/rtems4.8/i386/Makefile.am (added) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/mips/.cvsignore (added) * contrib/crossrpms/rtems4.8/mips/Makefile.am (added) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/sh/.cvsignore (added) * contrib/crossrpms/rtems4.8/sh/Makefile.am (added) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.8/tic4x/.cvsignore (added) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (added) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (added) New.
