# # ChangeLog for contrib/crossrpms/rtems4.11/powerpc in rtems # # Generated by Trac 1.2.1.dev0 # 05/16/24 16:06:09 Tue, 09 Nov 2010 14:22:14 GMT Ralf Corsepius [2c9b61f] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-binutils.spec (modified) Regenerate. Tue, 09 Nov 2010 14:21:04 GMT Ralf Corsepius [d22fa9e] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/binutils-sources.add (modified) binutils-2.20.90 Sat, 09 Oct 2010 06:51:17 GMT Ralf Corsepius [bc0b351] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sat, 09 Oct 2010 06:50:25 GMT Ralf Corsepius [1fcd11ea] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20101009.diff Sat, 09 Oct 2010 06:50:03 GMT Ralf Corsepius [76c0d6d6] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Fri, 08 Oct 2010 14:26:06 GMT Ralf Corsepius [72ea1c2f] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Fri, 08 Oct 2010 14:25:29 GMT Ralf Corsepius [b94bb03e] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20101008.diff. Fri, 08 Oct 2010 14:24:56 GMT Ralf Corsepius [c6e8ae8d] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Wed, 06 Oct 2010 05:32:23 GMT Ralf Corsepius [df24385e] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Wed, 06 Oct 2010 05:31:36 GMT Ralf Corsepius [c2f7c6d] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Wed, 06 Oct 2010 05:31:09 GMT Ralf Corsepius [78c0766] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20101006.diff. Mon, 04 Oct 2010 12:19:07 GMT Ralf Corsepius [ad8adcc] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Mon, 04 Oct 2010 12:18:00 GMT Ralf Corsepius [b3e30af0] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20101004.diff Mon, 04 Oct 2010 12:17:22 GMT Ralf Corsepius [8b7c5d9] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Mon, 04 Oct 2010 05:04:12 GMT Ralf Corsepius [bf0f339] * contrib/crossrpms/rtems4.11/arm/.cvsignore (modified) * contrib/crossrpms/rtems4.11/avr/.cvsignore (modified) * contrib/crossrpms/rtems4.11/bfin/.cvsignore (modified) * contrib/crossrpms/rtems4.11/h8300/.cvsignore (modified) * contrib/crossrpms/rtems4.11/i386/.cvsignore (modified) * contrib/crossrpms/rtems4.11/lm32/.cvsignore (modified) * contrib/crossrpms/rtems4.11/m32c/.cvsignore (modified) * contrib/crossrpms/rtems4.11/m32r/.cvsignore (modified) * contrib/crossrpms/rtems4.11/m68k/.cvsignore (modified) * contrib/crossrpms/rtems4.11/mips/.cvsignore (modified) * contrib/crossrpms/rtems4.11/mipstx39/.cvsignore (modified) * contrib/crossrpms/rtems4.11/powerpc/.cvsignore (modified) * contrib/crossrpms/rtems4.11/sh/.cvsignore (modified) * contrib/crossrpms/rtems4.11/sparc/.cvsignore (modified) * contrib/crossrpms/rtems4.11/sparc64/.cvsignore (modified) Add *.spec Tue, 21 Sep 2010 05:46:53 GMT Ralf Corsepius [794687a4] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Abandon Fedora 11. Tue, 07 Sep 2010 17:08:09 GMT Ralf Corsepius [ed50636] * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) Regenerate. Tue, 07 Sep 2010 17:07:44 GMT Ralf Corsepius [174f6f2c] * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (modified) gdb-7.2-rtems4.11-20100907.diff Tue, 07 Sep 2010 17:04:44 GMT Ralf Corsepius [700429e] * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) Bump GDB_RPMREL. Fri, 03 Sep 2010 05:48:42 GMT Ralf Corsepius [18c4308] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gdb.spec (modified) Regenerate. Fri, 03 Sep 2010 05:48:08 GMT Ralf Corsepius [d76de26] * contrib/crossrpms/rtems4.11/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gdb-sources.add (modified) Add gdb-7.2 Fri, 03 Sep 2010 05:47:31 GMT Ralf Corsepius [b791b20c] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) GDB_VERS = 7.2 Thu, 26 Aug 2010 02:18:24 GMT Ralf Corsepius [74b45094] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-binutils.spec (modified) Regenerate. Thu, 26 Aug 2010 02:16:40 GMT Ralf Corsepius [8c81f884] * contrib/crossrpms/rtems4.11/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/binutils-sources.add (modified) binutils-2.20.1-rtems4.11-20100826.diff Thu, 26 Aug 2010 02:16:19 GMT Ralf Corsepius [d89e247] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump BINUTILS_RPMREL. Wed, 25 Aug 2010 12:46:46 GMT Ralf Corsepius [0d10d566] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Wed, 25 Aug 2010 12:46:17 GMT Ralf Corsepius [b51eb88b] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Wed, 25 Aug 2010 12:46:01 GMT Ralf Corsepius [763e117] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20100825.diff. Wed, 18 Aug 2010 10:31:17 GMT Ralf Corsepius [d7c4e1d] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Wed, 18 Aug 2010 10:29:57 GMT Ralf Corsepius [aea64105] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) gcc-core-4.5.1-rtems4.11-20100818.diff Wed, 18 Aug 2010 10:29:40 GMT Ralf Corsepius [08634cb2] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) GCC_RPMREL = 5 Thu, 12 Aug 2010 14:09:54 GMT Ralf Corsepius [9f86f4a9] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gdb.spec (modified) Regenerate. Thu, 12 Aug 2010 14:09:15 GMT Ralf Corsepius [645febd5] * contrib/crossrpms/rtems4.11/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gdb-sources.add (modified) gdb-7.1-rtems4.11-20100812.diff. Thu, 12 Aug 2010 14:08:41 GMT Ralf Corsepius [bff5732] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GDB_RPMREL = 4 Tue, 10 Aug 2010 04:07:41 GMT Ralf Corsepius [aec88a2] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Tue, 10 Aug 2010 04:04:48 GMT Ralf Corsepius [68735e83] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20100810.diff. Tue, 10 Aug 2010 04:04:17 GMT Ralf Corsepius [3f568eb1] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Thu, 05 Aug 2010 05:14:16 GMT Ralf Corsepius [7f45f8f8] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Thu, 05 Aug 2010 05:13:17 GMT Ralf Corsepius [d5791b4] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Thu, 05 Aug 2010 05:13:02 GMT Ralf Corsepius [a12bf1d] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20100804.diff. Sun, 01 Aug 2010 04:10:14 GMT Ralf Corsepius [e06d0de0] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sun, 01 Aug 2010 04:09:26 GMT Ralf Corsepius [3649bde] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) GCC_PKGVERS = $(GCC_VERS) Sun, 01 Aug 2010 04:04:26 GMT Ralf Corsepius [ffbfa5b] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sun, 01 Aug 2010 04:03:04 GMT Ralf Corsepius [522db213] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Sun, 01 Aug 2010 04:02:12 GMT Ralf Corsepius [1e94b1d] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) gcc-4.5.1 (final). Tue, 27 Jul 2010 15:28:51 GMT Ralf Corsepius [8a51913f] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Tue, 27 Jul 2010 15:28:13 GMT Ralf Corsepius [b61cc954] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) Adjust Source1. Mon, 26 Jul 2010 09:42:46 GMT Ralf Corsepius [b478902] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Mon, 26 Jul 2010 09:41:53 GMT Ralf Corsepius [935b8ee] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) Upgrade to gcc-4.5.1-RC-20100722. Mon, 12 Jul 2010 03:54:46 GMT Ralf Corsepius [72f9fbfb] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Thu, 08 Jul 2010 16:46:19 GMT Ralf Corsepius [c302d31a] * contrib/crossrpms/autotools/rtems-4.11-autoconf.spec (modified) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Thu, 08 Jul 2010 16:44:21 GMT Ralf Corsepius [5857fc92] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Thu, 08 Jul 2010 16:43:52 GMT Ralf Corsepius [8d531b4] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20100708.diff Thu, 17 Jun 2010 16:35:29 GMT Ralf Corsepius [60729c3] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Thu, 17 Jun 2010 16:33:51 GMT Ralf Corsepius [455acb5] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) GCC_RPMREL = 14. Thu, 17 Jun 2010 16:32:18 GMT Ralf Corsepius [b3036fb] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20100617.diff. Wed, 09 Jun 2010 07:29:42 GMT Ralf Corsepius [82519fe] * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/i386/gcc-sources.add (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Update. Wed, 09 Jun 2010 06:59:52 GMT Ralf Corsepius [65dd01e] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gdb.spec (modified) Regenerate. Wed, 09 Jun 2010 06:59:05 GMT Ralf Corsepius [1332cb9] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GDB_RPMREL. Wed, 09 Jun 2010 06:57:18 GMT Ralf Corsepius [53dd37cb] * contrib/crossrpms/rtems4.11/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gdb-sources.add (modified) Abandon gdb-7.0.1 Wed, 09 Jun 2010 06:40:48 GMT Ralf Corsepius [62294ae3] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Wed, 09 Jun 2010 06:39:55 GMT Ralf Corsepius [89aaddf8] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) gcc-core-4.5.0-rtems4.11-20100526.diff. Wed, 09 Jun 2010 06:39:28 GMT Ralf Corsepius [1192a1e0] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Wed, 09 Jun 2010 06:10:43 GMT Ralf Corsepius [b77532c] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-binutils.spec (modified) Regenerate. Wed, 09 Jun 2010 06:09:23 GMT Ralf Corsepius [3e38161] * contrib/crossrpms/rtems4.11/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/binutils-sources.add (modified) Update to binutils-2.20.1-rtems4.11-20100521.diff. Wed, 09 Jun 2010 06:09:02 GMT Ralf Corsepius [8a4846d] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Bump BINUTILS_RPMREL. Mon, 07 Jun 2010 09:43:31 GMT Ralf Corsepius [1f85410] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-cpukit.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-cpukit.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-cpukit.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-cpukit.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-cpukit.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-cpukit.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-cpukit.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-cpukit.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-cpukit.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-cpukit.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-cpukit.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-cpukit.spec (modified) Regenerate. Mon, 24 May 2010 04:19:09 GMT Ralf Corsepius [0e8f21d] * contrib/crossrpms/rtems4.11/arm/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/cpukit-sources.add (modified) Update. Sat, 22 May 2010 03:32:34 GMT Ralf Corsepius [57e060b5] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sat, 22 May 2010 03:31:45 GMT Ralf Corsepius [be66b516] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) GCC_RPMREL = 12. Sat, 22 May 2010 03:28:26 GMT Ralf Corsepius [015f757] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) Abandon gcc-4.4.3. gcc-core-4.5.0-rtems4.11-20100522.diff. Tue, 27 Apr 2010 03:28:28 GMT Ralf Corsepius [2733f477] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Mon, 26 Apr 2010 14:32:00 GMT Ralf Corsepius [e2e8537] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Mon, 26 Apr 2010 14:30:56 GMT Ralf Corsepius [9c20cff4] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) Abandon gcc-g++-4.4.2. Mon, 26 Apr 2010 13:42:01 GMT Ralf Corsepius [8bddec3b] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) Abandon 4.4.2. newlib-1.18.0-rtems4.11-20100423.diff. Mon, 26 Apr 2010 13:17:35 GMT Ralf Corsepius [7d29d54a] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Bump GCC_RPMREL. Sat, 24 Apr 2010 14:18:05 GMT Ralf Corsepius [4bb28d4] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Sat, 24 Apr 2010 05:59:58 GMT Ralf Corsepius [b2c76e9] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Sat, 24 Apr 2010 05:59:17 GMT Ralf Corsepius [423a18d] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) Revert last patch. Fri, 23 Apr 2010 16:49:17 GMT Ralf Corsepius [10612755] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Fri, 23 Apr 2010 16:47:01 GMT Ralf Corsepius [4aa415f] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Bump GCC_RPMREL. Fri, 23 Apr 2010 16:46:41 GMT Ralf Corsepius [fee6d69] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) newlib-1.18.0-rtems4.11-20100423.diff. Wed, 14 Apr 2010 13:08:34 GMT Ralf Corsepius [65357b7] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Wed, 14 Apr 2010 13:07:29 GMT Ralf Corsepius [663f5012] * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Bump GCC_RPMREL. Wed, 14 Apr 2010 13:07:27 GMT Ralf Corsepius [0e685c1] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) gcc-4.5.0. Wed, 07 Apr 2010 02:18:56 GMT Ralf Corsepius [68001c02] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Wed, 07 Apr 2010 02:18:21 GMT Ralf Corsepius [66c7307] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) Upgrade to gcc-4.5.0-RC-20100406 Tue, 06 Apr 2010 11:56:49 GMT Ralf Corsepius [530d5014] * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) Regenerate. Tue, 06 Apr 2010 11:49:18 GMT Ralf Corsepius [fa664482] * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Bump GDB_RPMREL Fri, 02 Apr 2010 04:58:05 GMT Ralf Corsepius [0cd4e62] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Fri, 02 Apr 2010 04:57:45 GMT Ralf Corsepius [b54d8f6] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) Update. Fri, 02 Apr 2010 04:33:03 GMT Ralf Corsepius [6f6cc68a] * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Preps for next spin. Mon, 29 Mar 2010 04:03:18 GMT Ralf Corsepius [d52beda] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Mon, 29 Mar 2010 03:58:01 GMT Ralf Corsepius [8696950] * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Update. Mon, 29 Mar 2010 03:55:48 GMT Ralf Corsepius [6ebfd35c] * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) Update. Mon, 29 Mar 2010 03:52:52 GMT Ralf Corsepius [76daa873] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) newlib-1.18.0-rtems4.10-20100328.diff, gcc- ... Thu, 25 Mar 2010 06:37:07 GMT Ralf Corsepius [07acedcc] * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) Regenerate. Thu, 25 Mar 2010 06:36:53 GMT Ralf Corsepius [58fce52] * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) gcc-4.5-20100318. Mon, 22 Mar 2010 12:58:20 GMT Ralf Corsepius [e7a21fe0] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate. Mon, 22 Mar 2010 10:40:46 GMT Ralf Corsepius [bba6a24] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) Regenerate.
