# # ChangeLog for contrib/crossrpms/rtems4.11/mipstx39 in rtems # # Generated by Trac 1.2.1.dev0 # 03/29/24 08:39:32 Fri, 03 Sep 2010 05:48:08 GMT Ralf Corsepius [d76de26] * contrib/crossrpms/rtems4.11/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gdb-sources.add (modified) Add gdb-7.2 Fri, 03 Sep 2010 05:47:31 GMT Ralf Corsepius [b791b20c] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) GDB_VERS = 7.2 Thu, 12 Aug 2010 14:09:54 GMT Ralf Corsepius [9f86f4a9] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gdb.spec (modified) Regenerate. Thu, 12 Aug 2010 14:09:15 GMT Ralf Corsepius [645febd5] * contrib/crossrpms/rtems4.11/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gdb-sources.add (modified) gdb-7.1-rtems4.11-20100812.diff. Thu, 12 Aug 2010 14:08:41 GMT Ralf Corsepius [bff5732] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GDB_RPMREL = 4 Wed, 09 Jun 2010 06:59:52 GMT Ralf Corsepius [65dd01e] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gdb.spec (modified) Regenerate. Wed, 09 Jun 2010 06:59:05 GMT Ralf Corsepius [1332cb9] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GDB_RPMREL. Wed, 09 Jun 2010 06:57:18 GMT Ralf Corsepius [53dd37cb] * contrib/crossrpms/rtems4.11/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gdb-sources.add (modified) Abandon gdb-7.0.1 Tue, 06 Apr 2010 11:56:49 GMT Ralf Corsepius [530d5014] * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) Regenerate. Tue, 06 Apr 2010 11:49:18 GMT Ralf Corsepius [fa664482] * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Bump GDB_RPMREL Sat, 20 Mar 2010 06:59:01 GMT Ralf Corsepius [64c228c4] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) Regenerate. Sat, 20 Mar 2010 06:41:23 GMT Ralf Corsepius [94d1975e] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) Hard-code rtems_api. Fri, 19 Mar 2010 10:34:41 GMT Ralf Corsepius [9e61167] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (modified) Regenerate. Fri, 19 Mar 2010 10:22:50 GMT Ralf Corsepius [6edfe30] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/gdb-sources.add (modified) gdb-7.1 Wed, 17 Mar 2010 05:07:25 GMT Ralf Corsepius [bf862710] * contrib/crossrpms/rtems4.11/.cvsignore (added) * contrib/crossrpms/rtems4.11/Makefile.am (added) * contrib/crossrpms/rtems4.11/arm/.cvsignore (added) * contrib/crossrpms/rtems4.11/arm/Makefile.am (added) * contrib/crossrpms/rtems4.11/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/arm/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/avr/.cvsignore (added) * contrib/crossrpms/rtems4.11/avr/Makefile.am (added) * contrib/crossrpms/rtems4.11/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/avr/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.11/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/bfin/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/binutils.am (added) * contrib/crossrpms/rtems4.11/cpukit-prep.add (added) * contrib/crossrpms/rtems4.11/cpukit.am (added) * contrib/crossrpms/rtems4.11/gcc-prep.add (added) * contrib/crossrpms/rtems4.11/gcc.am (added) * contrib/crossrpms/rtems4.11/gdb.am (added) * contrib/crossrpms/rtems4.11/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.11/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/h8300/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/i386/.cvsignore (added) * contrib/crossrpms/rtems4.11/i386/Makefile.am (added) * contrib/crossrpms/rtems4.11/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/i386/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/lm32/.cvsignore (added) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (added) * contrib/crossrpms/rtems4.11/lm32/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/lm32/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/lm32/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/m32c/.cvsignore (added) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (added) * contrib/crossrpms/rtems4.11/m32c/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/m32c/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/m32c/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/m32r/.cvsignore (added) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (added) * contrib/crossrpms/rtems4.11/m32r/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/m32r/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/m32r/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.11/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/m68k/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/mips/.cvsignore (added) * contrib/crossrpms/rtems4.11/mips/Makefile.am (added) * contrib/crossrpms/rtems4.11/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/mips/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.11/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.11/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/powerpc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/sh/.cvsignore (added) * contrib/crossrpms/rtems4.11/sh/Makefile.am (added) * contrib/crossrpms/rtems4.11/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/sh/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.11/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/sparc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (added) Fork preps.
