# # ChangeLog for contrib/crossrpms/rtems4.11/binutils.am in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 07:35:26 Wed, 17 Mar 2010 05:07:25 GMT Ralf Corsepius [bf862710] * contrib/crossrpms/rtems4.11/.cvsignore (added) * contrib/crossrpms/rtems4.11/Makefile.am (added) * contrib/crossrpms/rtems4.11/arm/.cvsignore (added) * contrib/crossrpms/rtems4.11/arm/Makefile.am (added) * contrib/crossrpms/rtems4.11/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/arm/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/avr/.cvsignore (added) * contrib/crossrpms/rtems4.11/avr/Makefile.am (added) * contrib/crossrpms/rtems4.11/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/avr/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.11/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/bfin/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/binutils.am (added) * contrib/crossrpms/rtems4.11/cpukit-prep.add (added) * contrib/crossrpms/rtems4.11/cpukit.am (added) * contrib/crossrpms/rtems4.11/gcc-prep.add (added) * contrib/crossrpms/rtems4.11/gcc.am (added) * contrib/crossrpms/rtems4.11/gdb.am (added) * contrib/crossrpms/rtems4.11/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.11/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/h8300/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/i386/.cvsignore (added) * contrib/crossrpms/rtems4.11/i386/Makefile.am (added) * contrib/crossrpms/rtems4.11/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/i386/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/lm32/.cvsignore (added) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (added) * contrib/crossrpms/rtems4.11/lm32/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/lm32/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/lm32/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/m32c/.cvsignore (added) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (added) * contrib/crossrpms/rtems4.11/m32c/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/m32c/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/m32c/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/m32r/.cvsignore (added) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (added) * contrib/crossrpms/rtems4.11/m32r/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/m32r/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/m32r/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.11/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/m68k/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/mips/.cvsignore (added) * contrib/crossrpms/rtems4.11/mips/Makefile.am (added) * contrib/crossrpms/rtems4.11/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/mips/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.11/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.11/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.11/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/powerpc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/sh/.cvsignore (added) * contrib/crossrpms/rtems4.11/sh/Makefile.am (added) * contrib/crossrpms/rtems4.11/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/sh/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec (added) * contrib/crossrpms/rtems4.11/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.11/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.11/sparc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.11/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-binutils.spec (added) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-cpukit.spec (added) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (added) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec (added) Fork preps.
