# # ChangeLog for contrib/crossrpms/rtems4.10/sparc/gdb-sources.add in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 15:23:03 Fri, 12 Sep 2008 07:46:06 GMT Ralf Corsepius [0558e58] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) Update. Thu, 28 Aug 2008 01:14:03 GMT Ralf Corsepius [882a12a] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) Use URLs for patches. Thu, 03 Jul 2008 08:18:22 GMT Ralf Corsepius [01141c5] * contrib/crossrpms/rtems4.10/.cvsignore (added) * contrib/crossrpms/rtems4.10/Makefile.am (added) * contrib/crossrpms/rtems4.10/arm/.cvsignore (added) * contrib/crossrpms/rtems4.10/arm/Makefile.am (added) * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/arm/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/avr/.cvsignore (added) * contrib/crossrpms/rtems4.10/avr/Makefile.am (added) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/avr/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/bfin/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/binutils.am (added) * contrib/crossrpms/rtems4.10/cpukit-prep.add (added) * contrib/crossrpms/rtems4.10/cpukit.am (added) * contrib/crossrpms/rtems4.10/gcc-prep.add (added) * contrib/crossrpms/rtems4.10/gcc.am (added) * contrib/crossrpms/rtems4.10/gdb.am (added) * contrib/crossrpms/rtems4.10/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/h8300/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/i386/.cvsignore (added) * contrib/crossrpms/rtems4.10/i386/Makefile.am (added) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/i386/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/m68k/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/mips/.cvsignore (added) * contrib/crossrpms/rtems4.10/mips/Makefile.am (added) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/mips/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/powerpc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/sh/.cvsignore (added) * contrib/crossrpms/rtems4.10/sh/Makefile.am (added) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/sh/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/sparc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/tic4x/.cvsignore (added) * contrib/crossrpms/rtems4.10/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.10/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/tic4x/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/tic4x/gcc-sources.add (added) New.
