# # ChangeLog for contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add in rtems # # Generated by Trac 1.2.1.dev0 # 05/13/24 04:33:01 Tue, 22 Dec 2009 16:30:22 GMT Ralf Corsepius [b0015ab] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) gdb-7.0.1 Wed, 07 Oct 2009 06:51:32 GMT Ralf Corsepius [fb406b5] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) Switch back to gnu.org hosted sources. Thu, 01 Oct 2009 03:26:56 GMT Ralf Corsepius [97e47da] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-6.8.92-rtems4.10-20091001.diff Sat, 26 Sep 2009 06:04:43 GMT Ralf Corsepius [aca3753] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-6.8.91-rtems4.10-20090918.diff Fri, 18 Sep 2009 10:38:28 GMT Ralf Corsepius [6d41d186] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-6.8.91-rtems4.10-20090918.diff. Thu, 17 Sep 2009 03:29:39 GMT Ralf Corsepius [7a7949b1] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) Update Source0-URL. Thu, 17 Sep 2009 03:06:39 GMT Ralf Corsepius [19db385] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-%{gdb_version}-rtems4.10-20090917.diff Thu, 03 Sep 2009 01:55:34 GMT Ralf Corsepius [ccadb684] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) Upgrade to gdb-6.8.50.20090902. Thu, 12 Mar 2009 09:00:39 GMT Ralf Corsepius [c6c6b00] * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) gdb-6.8-rtems4.10-20090312.diff Thu, 22 Jan 2009 14:44:14 GMT Ralf Corsepius [bf0597e] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) Update to gdb-*-20090122.diff Fri, 03 Oct 2008 03:40:27 GMT Ralf Corsepius [df339c2] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-6.8-rtems4.10-20081003.diff. Abandon _without_sources. Wed, 17 Sep 2008 14:38:54 GMT Ralf Corsepius [9a5e29b] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Switch to gdb-6.8-rtems4.10-20080917.diff. Fri, 12 Sep 2008 07:46:06 GMT Ralf Corsepius [0558e58] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) Update. Thu, 28 Aug 2008 01:14:03 GMT Ralf Corsepius [882a12a] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) Use URLs for patches. Thu, 03 Jul 2008 08:18:22 GMT Ralf Corsepius [01141c5] * contrib/crossrpms/rtems4.10/.cvsignore (added) * contrib/crossrpms/rtems4.10/Makefile.am (added) * contrib/crossrpms/rtems4.10/arm/.cvsignore (added) * contrib/crossrpms/rtems4.10/arm/Makefile.am (added) * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/arm/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/avr/.cvsignore (added) * contrib/crossrpms/rtems4.10/avr/Makefile.am (added) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/avr/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/bfin/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/bfin/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/binutils.am (added) * contrib/crossrpms/rtems4.10/cpukit-prep.add (added) * contrib/crossrpms/rtems4.10/cpukit.am (added) * contrib/crossrpms/rtems4.10/gcc-prep.add (added) * contrib/crossrpms/rtems4.10/gcc.am (added) * contrib/crossrpms/rtems4.10/gdb.am (added) * contrib/crossrpms/rtems4.10/h8300/.cvsignore (added) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (added) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/h8300/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/i386/.cvsignore (added) * contrib/crossrpms/rtems4.10/i386/Makefile.am (added) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/i386/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/m68k/.cvsignore (added) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (added) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/m68k/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/mips/.cvsignore (added) * contrib/crossrpms/rtems4.10/mips/Makefile.am (added) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/mips/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/powerpc/.cvsignore (added) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (added) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/powerpc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/sh/.cvsignore (added) * contrib/crossrpms/rtems4.10/sh/Makefile.am (added) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/sh/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/sparc/.cvsignore (added) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (added) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/sparc/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/tic4x/.cvsignore (added) * contrib/crossrpms/rtems4.10/tic4x/Makefile.am (added) * contrib/crossrpms/rtems4.10/tic4x/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/tic4x/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/tic4x/gcc-sources.add (added) New.
