# # ChangeLog for contrib/crossrpms/rtems4.10/m32r/gdb-sources.add in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 08:42:17 Thu, 22 Jan 2009 14:44:14 GMT Ralf Corsepius [bf0597e] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) Update to gdb-*-20090122.diff Fri, 03 Oct 2008 03:40:27 GMT Ralf Corsepius [df339c2] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-6.8-rtems4.10-20081003.diff. Abandon _without_sources. Fri, 03 Oct 2008 02:55:10 GMT Ralf Corsepius [175b145c] * contrib/crossrpms/patches/binutils-2.18.91-rtems4.10-20081003.diff (added) * contrib/crossrpms/rtems4.10/m32c/.cvsignore (added) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (added) * contrib/crossrpms/rtems4.10/m32c/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/m32c/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/m32r/.cvsignore (added) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (added) * contrib/crossrpms/rtems4.10/m32r/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/m32r/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (added) New.
