Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/contrib/crossrpms/rtems4.10/m32c
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @0f0c13b1   02/03/09 05:43:32 Ralf Corsepius Bump GCC_RPMREL, NEWLIB_RPMREL. 4.104.115
(edit) @147257d4   01/26/09 07:36:15 Ralf Corsepius Regenerate. 4.104.115
(edit) @e709b88c   01/26/09 07:35:35 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @11feece9   01/26/09 07:26:01 Ralf Corsepius Regenerate. 4.104.115
(edit) @fddb62c   01/26/09 07:25:38 Ralf Corsepius Upgrade to gcc-4.3.3 4.104.115
(edit) @eb58d81   01/26/09 07:21:55 Ralf Corsepius NEWLIB_RPMREL = 22%{?dist} 4.104.115
(edit) @aaf9eb47   01/26/09 07:20:05 Ralf Corsepius GCC_VERS = 1%{?dist} 4.104.115
(edit) @09cc8fb   01/26/09 07:19:11 Ralf Corsepius GCC_VERS = 4.3.3 4.104.115
(edit) @35381baa   01/26/09 07:17:37 Ralf Corsepius BR: exact version of build host tools for Cdn-X builds. 4.104.115
(edit) @a3eb107   01/26/09 04:53:50 Ralf Corsepius Bump GCC_RPMREL. Add NEWLIB_RPMREL. 4.104.115
(edit) @3b35bcc5   01/22/09 14:45:06 Ralf Corsepius Regenerate. 4.104.115
(edit) @bf0597e   01/22/09 14:44:14 Ralf Corsepius Update to gdb-*-20090122.diff 4.104.115
(edit) @17a806a3   01/22/09 14:43:15 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @c51f900b   12/23/08 07:06:09 Ralf Corsepius newlib-1.17.0 4.104.115
(edit) @8ffd16bb   12/23/08 07:00:55 Ralf Corsepius newlib-1.17.0 4.104.115
(edit) @4590417b   12/17/08 13:31:48 Ralf Corsepius Use gdb-6.8-rtems4.10-20081217.diff 4.104.115
(edit) @d965b2e7   12/17/08 13:31:23 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @cf53d16   12/16/08 05:48:59 Ralf Corsepius Regenerate. 4.104.115
(edit) @0c094d1e   12/16/08 05:47:53 Ralf Corsepius Update to newlib-1.16.0.cvs.20081216. 4.104.115
(edit) @94522086   12/12/08 04:54:29 Ralf Corsepius Regenerate. 4.104.115
(edit) @0f7b5907   12/12/08 04:48:36 Ralf Corsepius newlib-1.16.0.cvs.20081212 4.104.115
(edit) @d9eafed   12/05/08 13:12:26 Ralf Corsepius Regenerate. 4.104.115
(edit) @6ded73b   12/05/08 13:12:09 Ralf Corsepius gcc-core-4.3.2-rtems4.10-20081205.diff. 4.104.115
(edit) @92651ada   12/05/08 13:08:45 Ralf Corsepius Regenerate. 4.104.115
(edit) @bea2a18   12/05/08 13:08:02 Ralf Corsepius GCC_RPMREL = 17, newlib-1.16.0.cvs.20081205. 4.104.115
(edit) @92862e81   11/28/08 03:31:59 Ralf Corsepius Regenerate. 4.104.115
(edit) @78a345f6   11/28/08 03:31:07 Ralf Corsepius newlib-1.16.0.cvs.20081128. 4.104.115
(edit) @7b65330c   11/27/08 16:12:42 Ralf Corsepius Regenerate. 4.104.115
(edit) @5aea6380   11/27/08 16:11:52 Ralf Corsepius newlib-1.16.0.cvs.20081127 4.104.115
(edit) @ac1ddec6   11/27/08 16:11:37 Ralf Corsepius newlib-1.16.0.cvs.20081127--rtems4.10-20081127.diff 4.104.115
(edit) @f8c34e8d   11/27/08 16:09:20 Ralf Corsepius Bump GCC_RPMREL = 15%{?dist}. 4.104.115
(edit) @8856a19   11/25/08 06:24:01 Ralf Corsepius Regenerate. 4.104.115
(edit) @03073e3b   11/25/08 06:16:02 Ralf Corsepius newlib-1.16.0.cvs.20081125-rtems4.10-20081125.diff. 4.104.115
(edit) @1981cc5f   11/25/08 06:14:53 Ralf Corsepius GCC_RELVER = 14%{?dist}. NEWLIB_PKGVERS = $(NEWLIB_VERS).cvs.20081125. 4.104.115
(edit) @95e4d243   11/25/08 03:43:24 Ralf Corsepius Regenerate. 4.104.115
(edit) @c2352fc   11/25/08 03:42:40 Ralf Corsepius newlib-1.16.0.cvs.20081124-rtems4.10-20081124.diff 4.104.115
(edit) @1efc075   11/25/08 03:41:52 Ralf Corsepius newlib-1.16.0.cvs.20081124. GCC_RPMREL = 13%{?dist}. 4.104.115
(edit) @9fb5c8a   11/24/08 06:21:17 Ralf Corsepius Regenerate. 4.104.115
(edit) @aebe4b6   11/24/08 06:19:54 Ralf Corsepius GCC_RPMREL = 12%{?dist}. 4.104.115
(edit) @56e3371   11/24/08 06:19:17 Ralf Corsepius newlib-1.16.0-rtems4.10-20081120.diff. 4.104.115
(edit) @8429438   11/19/08 17:07:56 Ralf Corsepius Regenerate. 4.104.115
(edit) @aedc2d5a   11/19/08 17:04:50 Ralf Corsepius Preps for newlib-cvs. Bump GCC_RPMREL. 4.104.115
(edit) @6357d742   11/19/08 17:04:21 Ralf Corsepius Update to gcc-core-4.3.2-rtems4.10-20081119.diff. Preps for newlib-cvs. 4.104.115
(edit) @f1322b47   11/10/08 10:47:51 Ralf Corsepius Regenerate. 4.104.115
(edit) @782c454   11/10/08 10:46:50 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @719a5c7   11/07/08 02:54:05 Ralf Corsepius Regenerate. 4.104.115
(edit) @181e2da   11/07/08 02:42:13 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @05c66cf   11/05/08 19:07:46 Ralf Corsepius Update. 4.104.115
(edit) @d41e18f8   10/28/08 22:12:04 Ralf Corsepius Bump BINUTILS_RPMREL. 4.104.115
(edit) @b3bfca66   10/23/08 04:34:14 Ralf Corsepius Regenerate. 4.104.115
(edit) @1cf80bf   10/23/08 04:32:35 Ralf Corsepius binutils-2.19. 4.104.115
(edit) @54726239   10/16/08 03:09:18 Ralf Corsepius Regenerate. 4.104.115
(edit) @bc23d85   10/16/08 03:08:20 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @e56584fb   10/16/08 02:49:07 Ralf Corsepius Regenerate. 4.104.115
(edit) @d596630   10/16/08 02:48:16 Ralf Corsepius Bump BINUTILS_RPMREL. 4.104.115
(edit) @945f9df9   10/10/08 02:33:18 Ralf Corsepius Regenerate. 4.104.115
(edit) @1171c46   10/10/08 02:32:36 Ralf Corsepius binutils-2.18.93-rtems4.10-20081010.diff. 4.104.115
(edit) @c81b995   10/10/08 02:30:19 Ralf Corsepius BINUTILS_VERS = 2.18.93 4.104.115
(edit) @c41d6b4   10/04/08 05:01:08 Ralf Corsepius Regenerate. 4.104.115
(edit) @e7910cd7   10/04/08 05:00:16 Ralf Corsepius Update to binutils-2.18.92. 4.104.115
(edit) @2abe16dd   10/03/08 06:18:17 Ralf Corsepius New. 4.104.115
(edit) @933e34a6   10/03/08 06:17:04 Ralf Corsepius GCC_RPMREL = 6. Disable cxx, infos. 4.104.115
(edit) @dc7c0df   10/03/08 06:15:57 Ralf Corsepius gcc-core-4.3.2-rtems4.10-20081003.diff, … 4.104.115
(edit) @b38ae26b   10/03/08 03:41:40 Ralf Corsepius Regenerate. 4.104.115
(edit) @df339c2   10/03/08 03:40:27 Ralf Corsepius gdb-6.8-rtems4.10-20081003.diff. Abandon _without_sources. 4.104.115
(edit) @30e604d   10/03/08 03:39:44 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @3d0a3acb   10/03/08 02:59:19 Ralf Corsepius Regenerate. 4.104.115
(edit) @e0c7ecf   10/03/08 02:58:08 Ralf Corsepius Build binutils infos. 4.104.115
(add) @175b145c   10/03/08 02:55:10 Ralf Corsepius New. 4.104.115
