# # ChangeLog for contrib/crossrpms/rtems4.10/m32c in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 17:30:15 Fri, 02 Apr 2010 12:57:36 GMT Ralf Corsepius [bdd00f2] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.18.0-rtems4.10-20100402.diff Mon, 29 Mar 2010 13:31:41 GMT Ralf Corsepius [4a23fa97] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Mon, 29 Mar 2010 13:30:46 GMT Ralf Corsepius [0b45f1a2] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GDB_RPMREL. Mon, 29 Mar 2010 03:38:23 GMT Ralf Corsepius [cad7844] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.18.0-rtems4.10-20100328.diff Mon, 29 Mar 2010 03:23:19 GMT Ralf Corsepius [ad76276a] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Fri, 26 Mar 2010 15:27:47 GMT Ralf Corsepius [142490c6] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Abandon cpukit. Fri, 26 Mar 2010 15:24:05 GMT Ralf Corsepius [8d0c0a1] * contrib/crossrpms/rtems4.10/arm/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/avr/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/bfin/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/h8300/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/i386/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/lm32/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/m32c/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/m32r/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/m68k/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/mips/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/powerpc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/sh/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-cpukit.spec (deleted) * contrib/crossrpms/rtems4.10/sparc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (deleted) Abandon. Fri, 19 Mar 2010 03:19:44 GMT Ralf Corsepius [7808d84] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Fri, 19 Mar 2010 03:15:07 GMT Ralf Corsepius [fac4ca16] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) gdb-7.1 Fri, 19 Mar 2010 03:14:18 GMT Ralf Corsepius [6bb79ac] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-7.1.spec Mon, 15 Mar 2010 16:38:34 GMT Ralf Corsepius [a2f4fc1] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Mon, 15 Mar 2010 16:37:57 GMT Ralf Corsepius [237bb65f] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) GCC_RPMREL=6 Mon, 15 Mar 2010 16:37:22 GMT Ralf Corsepius [207b1f47] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.18.0-rtems4.10-20100310.diff Wed, 10 Mar 2010 07:09:06 GMT Ralf Corsepius [4ad7a69] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Regenerate. Wed, 10 Mar 2010 07:07:59 GMT Ralf Corsepius [0ea222f5] * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (modified) Add binutils-patch. Wed, 10 Mar 2010 07:07:39 GMT Ralf Corsepius [84b257de] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump BINUTILS_RPMREL. Fri, 05 Mar 2010 03:36:39 GMT Ralf Corsepius [6ac9461] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Update to binutils-2.20.1 Thu, 25 Feb 2010 05:52:05 GMT Ralf Corsepius [6f8d49b4] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Thu, 25 Feb 2010 05:51:30 GMT Ralf Corsepius [06f0f66] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-7.0.90-rtems4.10-20100225.diff. Thu, 25 Feb 2010 05:50:59 GMT Ralf Corsepius [8e6a6a02] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GDG_RPMREL. Tue, 23 Feb 2010 06:12:52 GMT Ralf Corsepius [2d9d0a15] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) gdb-7.0.90. Thu, 11 Feb 2010 04:44:13 GMT Ralf Corsepius [d09e7fc] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Thu, 11 Feb 2010 04:43:01 GMT Ralf Corsepius [3bf44c20] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) GCC_RPMREL = 5. Wed, 10 Feb 2010 14:38:44 GMT Ralf Corsepius [b83fc5b3] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Remove cygwin hacks. Wed, 10 Feb 2010 14:36:41 GMT Ralf Corsepius [dc94d043] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Update. Thu, 21 Jan 2010 14:59:53 GMT Ralf Corsepius [e9fd94ce] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Upgrade to gcc-4.4.3. Thu, 21 Jan 2010 12:01:32 GMT Ralf Corsepius [d40d7cd4] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Thu, 21 Jan 2010 11:57:22 GMT Ralf Corsepius [ebb0d04b] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Update tp 4.4.3-RC-20100116. Thu, 21 Jan 2010 11:56:04 GMT Ralf Corsepius [5acf121] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) Update to newlib-1.18.0-rtems4.10-20100121.diff. Thu, 21 Jan 2010 05:04:25 GMT Ralf Corsepius [3554547] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) Fix typo in previous patch. Thu, 21 Jan 2010 04:58:33 GMT Ralf Corsepius [040e7950] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) Preps for gcc-4.4.3. Abandon newlib-1.17.0. Tue, 22 Dec 2009 16:30:22 GMT Ralf Corsepius [b0015ab] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) gdb-7.0.1 Sat, 19 Dec 2009 05:52:49 GMT Ralf Corsepius [86bde6f] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Sat, 19 Dec 2009 05:51:44 GMT Ralf Corsepius [5688a1b] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Reset NEWLIB_RPMREL. NEWLIB_VERS = 1.18.0 Sat, 19 Dec 2009 05:31:39 GMT Ralf Corsepius [995305c] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Sat, 19 Dec 2009 05:27:06 GMT Ralf Corsepius [4ce9e4b] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) Preps for newlib-1.18.0 Fri, 27 Nov 2009 06:35:32 GMT Ralf Corsepius [d9bf21e] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Fri, 27 Nov 2009 06:34:25 GMT Ralf Corsepius [4cfd1e07] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Wed, 04 Nov 2009 15:55:45 GMT Ralf Corsepius [620e3fb5] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Wed, 04 Nov 2009 15:55:11 GMT Ralf Corsepius [69234cac] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Wed, 04 Nov 2009 15:53:35 GMT Ralf Corsepius [bd38bb67] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) gcc-core-4.4.2-rtems4.10-20091104.diff. ... Fri, 30 Oct 2009 10:38:27 GMT Ralf Corsepius [3fd5ece0] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Update. Wed, 28 Oct 2009 15:45:18 GMT Ralf Corsepius [36fcb023] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Update. Sat, 17 Oct 2009 06:14:54 GMT Ralf Corsepius [532add7] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) binutils-2.20. Thu, 15 Oct 2009 16:42:51 GMT Ralf Corsepius [60c9ceb] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Update to gcc-4.4.2. Fri, 09 Oct 2009 04:20:09 GMT Ralf Corsepius [0c9bb8ad] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Fri, 09 Oct 2009 04:17:52 GMT Ralf Corsepius [b85a6f5] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) Preps for gcc-4.4.2. Wed, 07 Oct 2009 09:02:12 GMT Ralf Corsepius [cdf0be6] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Regenerate Wed, 07 Oct 2009 09:01:04 GMT Ralf Corsepius [baf0a66] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) BINUTILS_VERS = 2.19.92. Wed, 07 Oct 2009 06:52:08 GMT Ralf Corsepius [2cd6377a] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Wed, 07 Oct 2009 06:51:32 GMT Ralf Corsepius [fb406b5] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) Switch back to gnu.org hosted sources. Wed, 07 Oct 2009 06:50:12 GMT Ralf Corsepius [b26f0a1] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) GDB_VERS = 7.0 Thu, 01 Oct 2009 03:39:57 GMT Ralf Corsepius [c429eca7] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Thu, 01 Oct 2009 03:39:10 GMT Ralf Corsepius [8c55a6c] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Fix typo in previous patch. Thu, 01 Oct 2009 03:29:26 GMT Ralf Corsepius [bc5f3d6d] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Thu, 01 Oct 2009 03:29:02 GMT Ralf Corsepius [8ab053c] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) GDB_RVERS = 6.8.92. Thu, 01 Oct 2009 03:26:56 GMT Ralf Corsepius [97e47da] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-6.8.92-rtems4.10-20091001.diff Thu, 01 Oct 2009 03:25:28 GMT Ralf Corsepius [e1b4795] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Bump GCC_RPMREL. Sat, 26 Sep 2009 06:06:37 GMT Ralf Corsepius [626f03d] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Sat, 26 Sep 2009 06:04:43 GMT Ralf Corsepius [aca3753] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-6.8.91-rtems4.10-20090918.diff Sat, 26 Sep 2009 06:02:24 GMT Ralf Corsepius [e92355e6] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GDB_RPMREL. Wed, 23 Sep 2009 10:17:02 GMT Ralf Corsepius [d80603e] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Wed, 23 Sep 2009 10:16:12 GMT Ralf Corsepius [41bab5c9] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GDB_RPMREL. Tue, 22 Sep 2009 08:39:30 GMT Ralf Corsepius [846e46a] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Update. Fri, 18 Sep 2009 10:39:06 GMT Ralf Corsepius [c74285e] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Fri, 18 Sep 2009 10:38:28 GMT Ralf Corsepius [6d41d186] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-6.8.91-rtems4.10-20090918.diff. Fri, 18 Sep 2009 10:36:16 GMT Ralf Corsepius [c2b4d2d] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GDB_RPMREL. Thu, 17 Sep 2009 03:29:39 GMT Ralf Corsepius [7a7949b1] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) Update Source0-URL. Thu, 17 Sep 2009 03:10:40 GMT Ralf Corsepius [a4c2b009] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Thu, 17 Sep 2009 03:09:24 GMT Ralf Corsepius [caa9f1e] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) gdb-6.8.91. Thu, 17 Sep 2009 03:06:39 GMT Ralf Corsepius [19db385] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-%{gdb_version}-rtems4.10-20090917.diff Wed, 16 Sep 2009 09:14:16 GMT Ralf Corsepius [18e835a] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Wed, 16 Sep 2009 09:13:20 GMT Ralf Corsepius [e5df322] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Wed, 16 Sep 2009 07:45:44 GMT Ralf Corsepius [9d14e599] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.17.0-rtems4.10-20090916.diff. Sun, 13 Sep 2009 03:43:04 GMT Ralf Corsepius [3c078c7a] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Sun, 13 Sep 2009 03:37:08 GMT Ralf Corsepius [d6c9c1d] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL for mass rebuild against binutils-2.19.90. Sun, 13 Sep 2009 03:34:26 GMT Ralf Corsepius [c91a0c7] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Regenerate. Sun, 13 Sep 2009 03:33:44 GMT Ralf Corsepius [a0b9cc0c] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (modified) Upgrade to binutils 2.19.90. Fri, 11 Sep 2009 15:20:49 GMT Ralf Corsepius [7cc0554] * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) Update. Fri, 11 Sep 2009 02:07:30 GMT Ralf Corsepius [b5060e5] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Fri, 11 Sep 2009 02:06:45 GMT Ralf Corsepius [100fb17] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.17.0-rtems4.10-20090910.diff Fri, 11 Sep 2009 02:06:28 GMT Ralf Corsepius [6cf310c] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Wed, 09 Sep 2009 14:06:56 GMT Ralf Corsepius [ed5bd27b] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Wed, 09 Sep 2009 14:05:50 GMT Ralf Corsepius [8c5fc41] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.17.0-rtems4.10-20090909.diff. Wed, 09 Sep 2009 14:04:20 GMT Ralf Corsepius [1184ef95] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Mon, 07 Sep 2009 04:13:14 GMT Ralf Corsepius [86c6f95b] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Mon, 07 Sep 2009 04:12:14 GMT Ralf Corsepius [ed2cb7c] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Sun, 06 Sep 2009 14:18:39 GMT Ralf Corsepius [6685aa09] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Sun, 06 Sep 2009 14:17:51 GMT Ralf Corsepius [9914cad] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Sun, 06 Sep 2009 14:17:16 GMT Ralf Corsepius [503fdc1] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.17.0-rtems4.10-20090906.diff Sat, 05 Sep 2009 05:10:06 GMT Ralf Corsepius [757e5de0] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Activate python. Sat, 05 Sep 2009 05:09:01 GMT Ralf Corsepius [7b05a7a] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GDB_RPMREL = 2. Wed, 02 Sep 2009 16:57:03 GMT Ralf Corsepius [eb33c6e1] * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Upgrade to gdb-6.8.50.20090902. Wed, 02 Sep 2009 06:46:41 GMT Ralf Corsepius [cae117d9] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Wed, 02 Sep 2009 06:45:31 GMT Ralf Corsepius [b0699f5] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GDB_RPMREL. Wed, 02 Sep 2009 05:34:11 GMT Ralf Corsepius [6a3de2f] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Wed, 02 Sep 2009 05:32:07 GMT Ralf Corsepius [840e413] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Mon, 31 Aug 2009 11:36:55 GMT Ralf Corsepius [7a925529] * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Mon, 31 Aug 2009 11:27:12 GMT Ralf Corsepius [016c9ea] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Mon, 31 Aug 2009 11:26:26 GMT Ralf Corsepius [65998e3] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL.
