# # ChangeLog for contrib/crossrpms/rtems4.10/lm32 in rtems # # Generated by Trac 1.2.1.dev0 # 05/12/24 08:16:41 Sun, 29 Mar 2009 03:27:15 GMT Ralf Corsepius [88ad0c9] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Wed, 11 Mar 2009 08:48:22 GMT Ralf Corsepius [c033221] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Wed, 11 Mar 2009 08:45:05 GMT Ralf Corsepius [cf3e180] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.17.0-rtems4.10-20090311.diff. Wed, 11 Mar 2009 08:44:37 GMT Ralf Corsepius [2eb41aee] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Wed, 25 Feb 2009 07:42:28 GMT Ralf Corsepius [d35ffd68] * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) Regenerate. Wed, 25 Feb 2009 07:42:16 GMT Ralf Corsepius [8ac2414] * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) Bump GDB_RPMREL. Wed, 25 Feb 2009 06:13:06 GMT Ralf Corsepius [beb5d47] * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) Regenerate. Wed, 25 Feb 2009 06:12:47 GMT Ralf Corsepius [5a994432] * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) Add gdb-6.8.50.20090224-rtems4.10-20090225.diff Tue, 24 Feb 2009 09:04:51 GMT Ralf Corsepius [19409e42] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Tue, 24 Feb 2009 09:03:38 GMT Ralf Corsepius [47616e9e] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) GCC_RPMREL = 8 Tue, 24 Feb 2009 09:03:21 GMT Ralf Corsepius [9702d56] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.17.0-rtems4.10-20090224.diff Tue, 24 Feb 2009 05:47:47 GMT Ralf Corsepius [ddde079] * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) Regenerate. Tue, 24 Feb 2009 05:36:05 GMT Ralf Corsepius [8a6a2fd] * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (added) New. Tue, 24 Feb 2009 05:35:34 GMT Ralf Corsepius [5e40650] * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) Activate GDB. Tue, 24 Feb 2009 05:34:13 GMT Ralf Corsepius [946dcf8] * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) Use a gdb-snapshot. Mon, 23 Feb 2009 10:22:24 GMT Ralf Corsepius [e01c09d4] * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (added) Regenerate. Mon, 23 Feb 2009 10:21:43 GMT Ralf Corsepius [d636a27] * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) Update. Mon, 23 Feb 2009 10:21:25 GMT Ralf Corsepius [851c7cac] * contrib/crossrpms/rtems4.10/lm32/binutils-sources.add (modified) binutils-2.19.51-20090222. Mon, 23 Feb 2009 10:20:54 GMT Ralf Corsepius [178c339] * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) Activate GCC-4.3.3 Sun, 22 Feb 2009 04:51:10 GMT Ralf Corsepius [da589d0] * contrib/crossrpms/rtems4.10/lm32/.cvsignore (added) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (added) * contrib/crossrpms/rtems4.10/lm32/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/lm32/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (added) New.
