Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/contrib/crossrpms/rtems4.10/i386
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @a0b9cc0c   09/13/09 03:33:44 Ralf Corsepius Upgrade to binutils 2.19.90. 4.104.115
(edit) @b5060e5   09/11/09 02:07:30 Ralf Corsepius Regenerate. 4.104.115
(edit) @100fb17   09/11/09 02:06:45 Ralf Corsepius newlib-1.17.0-rtems4.10-20090910.diff 4.104.115
(edit) @6cf310c   09/11/09 02:06:28 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @ed5bd27b   09/09/09 14:06:56 Ralf Corsepius Regenerate. 4.104.115
(edit) @8c5fc41   09/09/09 14:05:50 Ralf Corsepius newlib-1.17.0-rtems4.10-20090909.diff. 4.104.115
(edit) @1184ef95   09/09/09 14:04:20 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @86c6f95b   09/07/09 04:13:14 Ralf Corsepius Regenerate. 4.104.115
(edit) @ed2cb7c   09/07/09 04:12:14 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @6685aa09   09/06/09 14:18:39 Ralf Corsepius Regenerate. 4.104.115
(edit) @9914cad   09/06/09 14:17:51 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @503fdc1   09/06/09 14:17:16 Ralf Corsepius newlib-1.17.0-rtems4.10-20090906.diff 4.104.115
(edit) @757e5de0   09/05/09 05:10:06 Ralf Corsepius Activate python. 4.104.115
(edit) @7b05a7a   09/05/09 05:09:01 Ralf Corsepius Bump GDB_RPMREL = 2. 4.104.115
(edit) @a707320   09/03/09 01:59:29 Ralf Corsepius Regenerate. 4.104.115
(edit) @21a21c2   09/03/09 01:59:00 Ralf Corsepius Reset GDB_RPMREL. 4.104.115
(edit) @ccadb684   09/03/09 01:55:34 Ralf Corsepius Upgrade to gdb-6.8.50.20090902. 4.104.115
(edit) @cae117d9   09/02/09 06:46:41 Ralf Corsepius Regenerate. 4.104.115
(edit) @b0699f5   09/02/09 06:45:31 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @6a3de2f   09/02/09 05:34:11 Ralf Corsepius Regenerate. 4.104.115
(edit) @840e413   09/02/09 05:32:07 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @7a925529   08/31/09 11:36:55 Ralf Corsepius Regenerate. 4.104.115
(edit) @016c9ea   08/31/09 11:27:12 Ralf Corsepius Regenerate. 4.104.115
(edit) @65998e3   08/31/09 11:26:26 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @6ef6f88   08/29/09 04:18:00 Ralf Corsepius Regenerate. 4.104.115
(edit) @db05093   08/29/09 04:16:56 Ralf Corsepius Bump BINUTILS_RPMREL. 4.104.115
(edit) @9b9c6153   08/27/09 20:32:31 Ralf Corsepius Regenerate. 4.104.115
(edit) @3274a39a   08/27/09 20:31:58 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @cdc1b123   08/27/09 15:47:52 Ralf Corsepius Regenerate. 4.104.115
(edit) @a2acf4f0   08/27/09 15:46:56 Ralf Corsepius GCC_RPMREL = 6. 4.104.115
(edit) @34ada7c0   08/27/09 15:46:23 Ralf Corsepius Abandon 4.4.0. Update to gcc-core-4.4.1-rtems4.10-20090820.diff. 4.104.115
(edit) @b8cb165   08/26/09 16:56:59 Ralf Corsepius Use build_fortran instead of build_f95. 4.104.115
(edit) @9ff8bda   07/27/09 11:54:58 Ralf Corsepius Regenerate. 4.104.115
(edit) @2bdf507   07/27/09 11:52:59 Ralf Corsepius newlib-1.17.0-rtems4.10-20090727.diff 4.104.115
(edit) @28dc5fb   07/27/09 11:52:15 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @e1ffb64   07/22/09 10:18:46 Ralf Corsepius Regenerate. 4.104.115
(edit) @1f70458   07/22/09 10:18:24 Ralf Corsepius gcc-core-4.4.1-rtems4.10-20090722.diff 4.104.115
(edit) @e1f0b2d   07/22/09 10:07:14 Ralf Corsepius GCC-4.4.1. 4.104.115
(edit) @428a4c0   07/18/09 04:07:04 Ralf Corsepius Regenerate. 4.104.115
(edit) @6218ba5b   07/18/09 04:06:26 Ralf Corsepius GCC_PKGVERS = $(GCC_VERS)-RC-20090715 4.104.115
(edit) @6d3f0321   07/18/09 04:02:03 Ralf Corsepius Regenerate. 4.104.115
(edit) @0b7a942   07/18/09 03:58:53 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @5e06bf7   07/18/09 03:57:24 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @d3baa0d6   07/18/09 03:56:34 Ralf Corsepius Bump BINUTILS_RPMREL. 4.104.115
(edit) @dbe0290e   07/16/09 23:54:35 Ralf Corsepius Regenerate. 4.104.115
(edit) @ea4a5b5   07/16/09 23:54:16 Ralf Corsepius Fix typo. 4.104.115
(edit) @c5575c9   07/16/09 23:44:37 Ralf Corsepius Regenerate. 4.104.115
(edit) @eb2d0ff   07/16/09 23:41:07 Ralf Corsepius Abandon gcc-4.3.3. Add gcc-4.4.1. 4.104.115
(edit) @56a5a83   07/16/09 23:36:58 Ralf Corsepius Bump GCC_VERS, GCC_RPMREL. 4.104.115
(edit) @2010a0ef   07/15/09 07:53:26 Ralf Corsepius Regenerate. 4.104.115
(edit) @ea4db3a2   07/15/09 07:50:19 Ralf Corsepius newlib-1.17.0-rtems4.10-20090715.diff. 4.104.115
(edit) @a5f1bb7   07/15/09 07:49:19 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @7ff1c29   07/14/09 06:54:20 Ralf Corsepius Increment BINUTILS_RPMREL for FC11-rebuild. 4.104.115
(edit) @e2ae590   07/11/09 07:33:43 Ralf Corsepius Housekeeping. 4.104.115
(edit) @79d15192   05/05/09 12:14:19 Ralf Corsepius Regenerate. 4.104.115
(edit) @90c3b73   05/05/09 12:13:58 Ralf Corsepius Revert previous change; Update newlib-patch. 4.104.115
(edit) @28c62a10   05/05/09 11:20:58 Ralf Corsepius Regenerate. 4.104.115
(edit) @21964afd   05/05/09 11:20:14 Ralf Corsepius newlib-1.17.0-rtems4.10-20090505.diff. 4.104.115
(edit) @16b04bb   05/05/09 11:19:48 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @3bbe1b1   04/21/09 16:45:14 Ralf Corsepius Regenerate. 4.104.115
(edit) @2d5910f5   04/21/09 16:44:52 Ralf Corsepius Use ftp.gnu.org Source0-URL. 4.104.115
(edit) @1dc2a94   04/21/09 16:40:31 Ralf Corsepius Regenerate. 4.104.115
(edit) @556bc15   04/21/09 16:38:23 Ralf Corsepius gcc-core-4.4.0-rtems4.10-20090421.diff 4.104.115
(edit) @ea31afaa   04/21/09 16:33:17 Ralf Corsepius gcc-4.4.0. 4.104.115
(edit) @3521985b   04/21/09 05:24:32 Ralf Corsepius Regenerate. 4.104.115
(edit) @8c40f6e1   04/21/09 05:22:36 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @5faedff   04/20/09 09:28:37 Ralf Corsepius Regenerate. 4.104.115
(edit) @b77b3672   04/20/09 09:28:07 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @1bb1f322   04/17/09 02:23:14 Ralf Corsepius Regenerate. 4.104.115
(edit) @b68a3f1   04/17/09 02:21:42 Ralf Corsepius GCC_RPMREL = 2. 4.104.115
(edit) @d41660f9   04/17/09 02:09:59 Ralf Corsepius gcc-core-4.4.0-RC-20090414-rtems4.10-20090415.diff 4.104.115
(edit) @9937a7a   04/14/09 17:32:07 Ralf Corsepius Regenerate. 4.104.115
(edit) @edbbbf28   04/14/09 17:31:37 Ralf Corsepius GCC-4.4.0--RC-20090414. 4.104.115
(edit) @af86b82   04/14/09 17:26:05 Ralf Corsepius Preps. for gcc-4.4.0 4.104.115
(edit) @241a259d   03/30/09 05:55:09 Ralf Corsepius Regenerate. 4.104.115
(edit) @68946ac7   03/30/09 05:54:34 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @49a5e79   03/29/09 03:28:22 Ralf Corsepius Regenerate. 4.104.115
(edit) @88ad0c9   03/29/09 03:27:15 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @c033221   03/11/09 08:48:22 Ralf Corsepius Regenerate. 4.104.115
(edit) @cf3e180   03/11/09 08:45:05 Ralf Corsepius newlib-1.17.0-rtems4.10-20090311.diff. 4.104.115
(edit) @2eb41aee   03/11/09 08:44:37 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @88ab8f3   02/24/09 09:10:23 Ralf Corsepius Regenerate, fix spec file. 4.104.115
(edit) @4ec1692   02/24/09 09:09:54 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @19409e42   02/24/09 09:04:51 Ralf Corsepius Regenerate. 4.104.115
(edit) @47616e9e   02/24/09 09:03:38 Ralf Corsepius GCC_RPMREL = 8 4.104.115
(edit) @9702d56   02/24/09 09:03:21 Ralf Corsepius newlib-1.17.0-rtems4.10-20090224.diff 4.104.115
(edit) @6c3fa5b   02/20/09 10:10:16 Ralf Corsepius Regenerate. 4.104.115
(edit) @16e6f5b   02/19/09 16:49:17 Ralf Corsepius Regenerate. 4.104.115
(edit) @aa941f8   02/19/09 16:49:02 Ralf Corsepius Move %{?dist} handling to rtems4.10/*.am. 4.104.115
(edit) @327c70b2   02/19/09 16:11:21 Ralf Corsepius Update. 4.104.115
(edit) @5c24de44   02/19/09 15:12:07 Ralf Corsepius Bump GCC_RPMREL, NEWLIB_RPMREL. 4.104.115
(edit) @2659fa26   02/07/09 08:45:12 Ralf Corsepius Regenerate. 4.104.115
(edit) @65205315   02/06/09 23:33:01 Ralf Corsepius Regenerate. 4.104.115
(edit) @d9e5793   02/06/09 23:07:43 Ralf Corsepius Regenerate. 4.104.115
(edit) @bdd38fe1   02/06/09 23:06:35 Ralf Corsepius newlib-1.17.0-rtems4.10-20090206.diff 4.104.115
(edit) @95159f95   02/06/09 23:04:47 Ralf Corsepius Bump GCC_RPMREL, NEWLIB_RPMREL. Rework CPUKIT*. 4.104.115
(edit) @92f690c9   02/03/09 12:10:29 Ralf Corsepius Regenerate. 4.104.115
(edit) @5e152a01   02/03/09 12:08:56 Ralf Corsepius Bump GCC_RPMREL, NEWLIB_RPMREL to rebuild against binutils-2.19.1 4.104.115
(edit) @2453f66   02/03/09 11:40:15 Ralf Corsepius Upgrade to binutils-2.19.1 4.104.115
(edit) @7f7a3ca4   02/03/09 06:40:33 Ralf Corsepius Regenerate. 4.104.115
